I am trying to run FAHclient on Fedora 33, and it failed with a bad_cast exception.
FAHClient /etc/fahclient/config.xml
15:59:46:Read GPUs.txt
terminate called after throwing an instance of 'std::bad_cast'
what(): std::bad_cast
Aborted (core dumped)
I tried to run it under gdb and it gives the following stack trace:
#0 0x00007ffff7c919d5 in raise () from /lib64/libc.so.6
#1 0x00007ffff7c7a8a4 in abort () from /lib64/libc.so.6
#2 0x00007ffff452f926 in __gnu_cxx::__verbose_terminate_handler() [clone .cold] ()
from /lib64/libstdc++.so.6
#3 0x00007ffff453b1ac in __cxxabiv1::__terminate(void (*)()) () from /lib64/libstdc++.so.6
#4 0x00007ffff453b217 in std::terminate() () from /lib64/libstdc++.so.6
#5 0x00007ffff453b4c9 in __cxa_throw () from /lib64/libstdc++.so.6
#6 0x00007ffff4532222 in std::__throw_bad_cast() () from /lib64/libstdc++.so.6
#7 0x00007ffff79ea110 in std::__check_facet<std::ctype<char> > (__f=0x0)
at /usr/include/c++/4.8.2/bits/basic_ios.h:49
#8 std::basic_ios<char, std::char_traits<char> >::widen (this=<optimized out>, __c=10 '\n')
at /usr/include/c++/4.8.2/bits/basic_ios.h:444
#9 std::istream::getline (__n=5120, __s=0x7fffffff92c0 "", this=0x7fffffff90b0)
at /usr/include/c++/4.8.2/istream:428
#10 Intel::OpenCL::Utils::GetModulePathName (
modulePtr=0x7ffff79fd323 <Intel::OpenCL::Utils::ConfigFile::ReadFile(std::string const&, Intel::OpenCL::Utils::ConfigFile&)::__FUNCTION__>, fileName=fileName@entry=0x7fffffffa9f0 "", strLen=4095)
at /netbatch/donb41412_00/runDir/93/20180921_000000/llvm/projects/opencl/utils/cl_sys_utils/cl_sys_info_linux.cpp:262
#11 0x00007ffff79ea12d in Intel::OpenCL::Utils::GetModuleDirectoryImp (addr=<optimized out>,
szModuleDir=0x7fffffffa9f0 "", strLen=<optimized out>)
at /netbatch/donb41412_00/runDir/93/20180921_000000/llvm/projects/opencl/utils/cl_sys_utils/cl_sys_info_linux.cpp:205
#12 0x00007ffff79e3590 in Intel::OpenCL::Utils::ConfigFile::ReadFile (fileName="cl.cfg", cfg=...)
at /netbatch/donb41412_00/runDir/93/20180921_000000/llvm/projects/opencl/utils/cl_sys_utils/cl_config.cpp:297
#13 0x00007ffff79e402e in Intel::OpenCL::Utils::ConfigFile::ConfigFile (this=0x7fffffffbb00,
filename="cl.cfg", delimiter=..., comment="",
sentry="hc\367\000\000\000\000\000\316\027\235\367\377\177\000\000\000\000\000\000\000\000\000\000@\273\377\377\377\177", '\000' <repeats 14 times>, "\377\177\000\000\000\000\000\000\000\000\000\000\b\273\377\377\377\177\000\000\b\273\377\377\377\177\000\000\000\000\000\000\000\000\000\000\070e\367\000\000\000\000\000\070b\367\000\000\000\000\000hc\367\000\000\000\000\000\377\377\377\377\000\000\000\000\367\020\000\000\000\000\000\000\350\306\302\367\377\177\000\000\001\000\000\000\000\000\000\000\210\335\377\377\377\177\000\000\230\335\377\377\377\177\000\000\210\310\302\367\377\177\000\000\000\000\000\000\000\000\000\000\304\344\217\367\377\177\000\000\350\306\302\367\377\177\000\000ߨ\217\367\377\177\000\000\210\310\302\367\377\177\000\000"...)
at /netbatch/donb41412_00/runDir/93/20180921_000000/llvm/projects/opencl/utils/cl_sys_utils/cl_config.cpp:220
#14 0x00007ffff79e85d9 in Intel::OpenCL::Utils::FrameworkUserLogger::FrameworkUserLogger (
this=0x7ffff7c449c0 <Intel::OpenCL::Utils::FrameworkUserLogger::Instance()::instance>)
at /netbatch/donb41412_00/runDir/93/20180921_000000/llvm/projects/opencl/utils/cl_sys_utils/cl_user_logger.cpp:161
#15 0x00007ffff78fe4c4 in Intel::OpenCL::Utils::FrameworkUserLogger::Instance ()
at /netbatch/donb41412_00/runDir/93/20180921_000000/llvm/projects/opencl/framework/ocl_config.cpp:52
#16 0x00007ffff78fa8df in __static_initialization_and_destruction_0 (__initialize_p=1, __priority=65535)
at /netbatch/donb41412_00/runDir/93/20180921_000000/llvm/projects/opencl/framework/ocl_config.cpp:58
#17 _GLOBAL__sub_I_ocl_config.cpp(void) ()
at /netbatch/donb41412_00/runDir/93/20180921_000000/llvm/projects/opencl/framework/ocl_config.cpp:60
#18 0x00007ffff7fe18ee in call_init.part () from /lib64/ld-linux-x86-64.so.2
#19 0x00007ffff7fe19d8 in _dl_init () from /lib64/ld-linux-x86-64.so.2
#20 0x00007ffff7d91095 in _dl_catch_exception () from /lib64/libc.so.6
#21 0x00007ffff7fe5e35 in dl_open_worker () from /lib64/ld-linux-x86-64.so.2
#22 0x00007ffff7d91038 in _dl_catch_exception () from /lib64/libc.so.6
#23 0x00007ffff7fe566e in _dl_open () from /lib64/ld-linux-x86-64.so.2
#24 0x00007ffff7f8539c in dlopen_doit () from /lib64/libdl.so.2
--Type <RET> for more, q to quit, c to continue without paging--
#25 0x00007ffff7d91038 in _dl_catch_exception () from /lib64/libc.so.6
#26 0x00007ffff7d91103 in _dl_catch_error () from /lib64/libc.so.6
#27 0x00007ffff7f85bd9 in _dlerror_run () from /lib64/libdl.so.2
#28 0x00007ffff7f85428 in dlopen@@GLIBC_2.2.5 () from /lib64/libdl.so.2
#29 0x00007ffff742e0ee in _open_driver () from /lib64/libOpenCL.so
#30 0x00007ffff7434d15 in _initClIcd_real () from /lib64/libOpenCL.so
#31 0x00007ffff7435804 in clGetPlatformIDs () from /lib64/libOpenCL.so
#32 0x0000000000650423 in ?? ()
#33 0x0000000000482569 in ?? ()
#34 0x00000000004c272f in ?? ()
#35 0x000000000043efc0 in ?? ()
#36 0x0000000000510194 in ?? ()
#37 0x0000000000522fcc in ?? ()
#38 0x00000000004380d4 in ?? ()
#39 0x000000000042dcd7 in ?? ()
#40 0x00007ffff7c7c1e2 in __libc_start_main () from /lib64/libc.so.6
#41 0x000000000042d0f1 in ?? ()
#42 0x00007fffffffdd78 in ?? ()
#43 0x00007ffff7ffe020 in ?? () from /lib64/ld-linux-x86-64.so.2
#44 0x0000000000000001 in ?? ()
#45 0x00007fffffffe0e7 in ?? ()
#46 0x0000000000000000 in ?? ()
Any help with how to troubleshoot this problem will be very appreciated.
