OpenCL on ARM or Xbox
Microsoft now also provides an OpenCL driver which runs on top of DirectX12. This would it make possible in theory to run FAH on Xbox X when FAH delivers this OpenCL wrapper. https://github.com/microsoft/OpenCLOn12
JohnChodera
- Pande Group Member
Re: OpenCL on ARM or Xbox
Interesting! Thanks for the heads up here---we'll raise this issue internally.
~ John Chodera // MSKCC
For ARM devices running Windows Insider it can now also run OpenCL apps on top of DX12
https://devblogs.microsoft.com/directx/ ... 10-on-arm/
OpenCLOn12 has MIT license and is fully compliant with OpenCL 1.2
Don't know if a similar approach would be possible to make an OpenCL 1.2 wrapper for Playstation 5 OpenGL driver
I hope the XBox X will run Windows exe files.
There is a possibility it won't run all programs Windows does. It may need a Windows store client app version of FAH.
Yes it needs a Windows store app. But the problem for Xbox was it does not have OpenCL driver. With OpenCLonDX12 now FAH has an option.
