Issue submitting WUs
xaybzc9
Post by xaybzc9 »
Hello,
This is my first post on f@h forums. I have 2 laptops doing f@h. I recently started having problems with my AMD laptop. Both CPU and GPU have the same kind of error message below.
I was folding on covid cause and switched to cancer cause as I thought covid WUs are the problem. After I switched to cancer cause, I can submit CPU WUs. Any idea?
CPU: Amd Ryzen 3700U Vega
Graphics: Vega gfx902
f@h version: 7.6.21
Graphics Log
12:32:02:WU00:FS00:0x22:*************************** Core22 Folding@home Core ***************************
12:32:02:WU00:FS00:0x22:       Core: Core22
12:32:02:WU00:FS00:0x22:       Type: 0x22
12:32:02:WU00:FS00:0x22:    Version: 0.0.13
12:32:02:WU00:FS00:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:32:02:WU00:FS00:0x22:  Copyright: 2020 foldingathome.org
12:32:02:WU00:FS00:0x22:   Homepage: https://foldingathome.org/
12:32:02:WU00:FS00:0x22:       Date: Sep 19 2020
12:32:02:WU00:FS00:0x22:       Time: 02:35:58
12:32:02:WU00:FS00:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
12:32:02:WU00:FS00:0x22:     Branch: core22-0.0.13
12:32:02:WU00:FS00:0x22:   Compiler: Visual C++ 2015
12:32:02:WU00:FS00:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
12:32:02:WU00:FS00:0x22:             -DOPENMM_GIT_HASH="\"189320d0\""
12:32:02:WU00:FS00:0x22:   Platform: win32 10
12:32:02:WU00:FS00:0x22:       Bits: 64
12:32:02:WU00:FS00:0x22:       Mode: Release
12:32:02:WU00:FS00:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
12:32:02:WU00:FS00:0x22:             <peastman@stanford.edu>
12:32:02:WU00:FS00:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 13464 -checkpoint 15
12:32:02:WU00:FS00:0x22:             -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0
12:32:02:WU00:FS00:0x22:             -gpu-usage 100
12:32:02:WU00:FS00:0x22:************************************ libFAH ************************************
12:32:02:WU00:FS00:0x22:       Date: Sep 7 2020
12:32:02:WU00:FS00:0x22:       Time: 19:09:56
12:32:02:WU00:FS00:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
12:32:02:WU00:FS00:0x22:     Branch: HEAD
12:32:02:WU00:FS00:0x22:************************************ CBang *************************************
12:32:02:WU00:FS00:0x22:       Time: 19:08:30
12:32:02:WU00:FS00:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
12:32:02:WU00:FS00:0x22:************************************ System ************************************
12:32:02:WU00:FS00:0x22:        CPU: AMD Ryzen 7 3700U with Radeon Vega Mobile Gfx
12:32:02:WU00:FS00:0x22:     CPU ID: AuthenticAMD Family 23 Model 24 Stepping 1
12:32:02:WU00:FS00:0x22:       CPUs: 8
12:32:02:WU00:FS00:0x22:     Memory: 29.88GiB
12:32:02:WU00:FS00:0x22:Free Memory: 25.65GiB
12:32:02:WU00:FS00:0x22:    Threads: WINDOWS_THREADS
12:32:02:WU00:FS00:0x22: OS Version: 6.2
12:32:02:WU00:FS00:0x22:Has Battery: true
12:32:02:WU00:FS00:0x22: On Battery: false
12:32:02:WU00:FS00:0x22: UTC Offset: 8
12:32:02:WU00:FS00:0x22:        PID: 13484
12:32:02:WU00:FS00:0x22:        CWD: C:\Users\<snip>\AppData\Roaming\FAHClient\work
12:32:02:WU00:FS00:0x22:************************************ OpenMM ************************************
12:32:02:WU00:FS00:0x22:   Revision: 189320d0
12:32:02:WU00:FS00:0x22:********************************************************************************
12:32:02:WU00:FS00:0x22:Project: 13438 (Run 2941, Clone 27, Gen 1)
12:32:02:WU00:FS00:0x22:Unit: 0x0000000212bc7d9a000000000b7d001b
12:32:02:WU00:FS00:0x22:Digital signatures verified
12:32:02:WU00:FS00:0x22:Folding@home GPU Core22 Folding@home Core
12:32:02:WU00:FS00:0x22:Version 0.0.13
12:32:03:WU00:FS00:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
12:32:03:WU00:FS00:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
12:32:03:WU00:FS00:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
12:32:03:WU00:FS00:0x22:  Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
12:32:03:WU00:FS00:0x22:There are 3 platforms available.
12:32:03:WU00:FS00:0x22:Platform 0: Reference
12:32:03:WU00:FS00:0x22:Platform 1: CPU
12:32:03:WU00:FS00:0x22:Platform 2: OpenCL
12:32:03:WU00:FS00:0x22:  opencl-device 0 specified
11:56:07:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13438 run:2941 clone:27 gen:1 core:0x22 unit:0x0000000212bc7d9a000000000b7d001b
11:56:07:WU00:FS00:Uploading 7.73MiB to 18.188.125.154
11:56:38:WARNING:WU00:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
11:56:38:WU00:FS00:Trying to send results to collection server
11:56:38:WU00:FS00:Uploading 7.73MiB to 150.136.14.110
11:57:09:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
CPU Log
23:35:53:WU01:FS01:0xa7:*********************** Log Started 2020-12-11T23:35:52Z ***********************
23:35:53:WU01:FS01:0xa7:************************** Gromacs Folding@home Core ***************************
23:35:53:WU01:FS01:0xa7:       Type: 0xa7
23:35:53:WU01:FS01:0xa7:       Core: Gromacs
23:35:53:WU01:FS01:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 10432 -checkpoint 15 -np
23:35:53:WU01:FS01:0xa7:             7
23:35:53:WU01:FS01:0xa7:************************************ CBang *************************************
23:35:53:WU01:FS01:0xa7:       Date: Nov 27 2019
23:35:53:WU01:FS01:0xa7:       Time: 03:40:09
23:35:53:WU01:FS01:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
23:35:53:WU01:FS01:0xa7:     Branch: master
23:35:53:WU01:FS01:0xa7:   Compiler: Visual C++ 2008
23:35:53:WU01:FS01:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:35:53:WU01:FS01:0xa7:   Platform: win32 10
23:35:53:WU01:FS01:0xa7:       Bits: 64
23:35:53:WU01:FS01:0xa7:       Mode: Release
23:35:53:WU01:FS01:0xa7:************************************ System ************************************
23:35:53:WU01:FS01:0xa7:        CPU: AMD Ryzen 7 3700U with Radeon Vega Mobile Gfx
23:35:53:WU01:FS01:0xa7:     CPU ID: AuthenticAMD Family 23 Model 24 Stepping 1
23:35:53:WU01:FS01:0xa7:       CPUs: 8
23:35:53:WU01:FS01:0xa7:     Memory: 29.88GiB
23:35:53:WU01:FS01:0xa7:Free Memory: 24.50GiB
23:35:53:WU01:FS01:0xa7:    Threads: WINDOWS_THREADS
23:35:53:WU01:FS01:0xa7: OS Version: 6.2
23:35:53:WU01:FS01:0xa7:Has Battery: true
23:35:53:WU01:FS01:0xa7: On Battery: false
23:35:53:WU01:FS01:0xa7: UTC Offset: 8
23:35:53:WU01:FS01:0xa7:        PID: 13756
23:35:53:WU01:FS01:0xa7:        CWD: C:\Users\<snip>\AppData\Roaming\FAHClient\work
23:35:53:WU01:FS01:0xa7:******************************** Build - libFAH ********************************
23:35:53:WU01:FS01:0xa7:    Version: 0.0.19
23:35:53:WU01:FS01:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:35:53:WU01:FS01:0xa7:  Copyright: 2019 foldingathome.org
23:35:53:WU01:FS01:0xa7:   Homepage: https://foldingathome.org/
23:35:53:WU01:FS01:0xa7:       Date: Nov 25 2019
23:35:53:WU01:FS01:0xa7:       Time: 17:12:41
23:35:53:WU01:FS01:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
23:35:53:WU01:FS01:0xa7:************************************ Build *************************************
23:35:53:WU01:FS01:0xa7:       SIMD: avx_256
23:35:53:WU01:FS01:0xa7:********************************************************************************
Re: Issue submitting WUs
Welcome to the F@H Forum xaybzc9,
Apologies for the delay but are you still encountering uploading issues to the Servers or not? I am aware that there were few issues that were identified and resolved so hopefully, things are working fine at your end :)
(Additional information FYI) There are quite a number of FAH Work Servers and most are dedicated to a single cause, so when you change the cause, you almost certainly will be dealing with a different WS. The status of the WS can be found at https://apps.foldingathome.org/serverstats (though it may take a while for you to find that page useful so asking here is fine). The completed WUs are normally returned directly to the WS that issued them so (as has already been suggested) you're returning the results to a different destination. Your report is consistent with a problem on one server but not on the other and the only thing you can do about that is report it 8-) .
