GPU "disabled"?
peanut05
GPU "disabled"?
Post by peanut05 »
Hello everyone. I'm new to f@h and was wondering what is going on. It says my GPU is disabled and to get help here.
*********************** Log Started 2020-12-06T11:14:23Z ***********************
11:14:23:******************************* libFAH ********************************
11:14:23:           Date: Oct 20 2020
11:14:23:           Time: 13:36:55
11:14:23:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
11:14:23:         Branch: master
11:14:23:       Compiler: Visual C++ 2015
11:14:23:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
11:14:23:       Platform: win32 10
11:14:23:           Bits: 32
11:14:23:           Mode: Release
11:14:23:****************************** FAHClient ******************************
11:14:23:        Version: 7.6.21
11:14:23:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:14:23:      Copyright: 2020 foldingathome.org
11:14:23:       Homepage: https://foldingathome.org/
11:14:23:           Time: 13:41:04
11:14:23:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
11:14:23:           Bits: 32
11:14:23:           Args: --open-web-control
11:14:23:         Config: C:\ProgramData\FAHClient\config.xml
11:14:23:******************************** CBang ********************************
11:14:23:           Time: 11:36:18
11:14:23:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
11:14:23:           Bits: 32
11:14:23:******************************* System ********************************
11:14:23:            CPU: Intel(R) Core(TM) i5-8250U CPU @ 1.60GHz
11:14:23:         CPU ID: GenuineIntel Family 6 Model 142 Stepping 10
11:14:23:           CPUs: 8
11:14:23:         Memory: 7.84GiB
11:14:23:    Free Memory: 4.36GiB
11:14:23:        Threads: WINDOWS_THREADS
11:14:23:     OS Version: 6.2
11:14:23:    Has Battery: true
11:14:23:     On Battery: false
11:14:23:     UTC Offset: 3
11:14:23:            PID: 3620
11:14:23:            CWD: C:\ProgramData\FAHClient
11:14:23:  Win32 Service: false
11:14:23:             OS: Windows 10 Home
11:14:23:        OS Arch: AMD64
11:14:23:           GPUs: 1
11:14:23:          GPU 0: Bus:0 Slot:2 Func:0 INTEL:1 KBL GT2 [UHD Graphics 620]
11:14:23:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
11:14:23:                 specified module could not be found.
11:14:23:
11:14:23:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:26.20
11:14:23:***********************************************************************
11:14:23:<config>
11:14:23:  <!-- Folding Slot Configuration -->
11:14:23:  <cause v='HIGH_PRIORITY'/>
11:14:23:
11:14:23:  <!-- Slot Control -->
11:14:23:  <power v='MEDIUM'/>
11:14:23:
11:14:23:  <!-- User Information -->
11:14:23:  <passkey v='*****'/>
11:14:23:  <user v='PeanutHat'/>
11:14:23:
11:14:23:  <!-- Folding Slots -->
11:14:23:  <slot id='0' type='CPU'>
11:14:23:    <idle v='true'/>
11:14:23:  </slot>
11:14:23:  <slot id='1' type='GPU'>
11:14:23:    <pci-bus v='0'/>
11:14:23:    <pci-slot v='2'/>
11:14:23:  </slot>
11:14:23:</config>
11:14:23:Trying to access database...
11:14:23:Successfully acquired database lock
11:14:23:FS00:Initialized folding slot 00: cpu:6
11:14:23:WARNING:FS01:Guessing ambiguous GPU to OpenCL device mapping for 01: gpu:0:2 KBL GT2 [UHD Graphics 620].  Consider upgrading your graphics driver or manually setting ``opencl-index`` in this slot's configuration.
11:14:23:WARNING:FS01:Disabling beta GPU slot 01: gpu:0:2 KBL GT2 [UHD Graphics 620].  Beta GPUs can be tested for no points by setting ``gpu-beta=true`` in the configuration.
11:14:39:17:127.0.0.1:New Web session
11:14:44:WU00:FS00:Starting
11:14:44:WARNING:WU00:FS00:Changed SMP threads from 4 to 6 this can cause some work units to fail
11:14:44:WARNING:WU00:FS00:AS lowered CPUs from 6 to 4
11:14:44:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 3620 -checkpoint 15 -np 4
11:14:44:WU00:FS00:Started FahCore on PID 8548
11:14:44:WU00:FS00:Core PID:10484
11:14:44:WU00:FS00:FahCore 0xa7 started
11:14:44:WU00:FS00:0xa7:*********************** Log Started 2020-12-06T11:14:44Z ***********************
11:14:44:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
11:14:44:WU00:FS00:0xa7:       Type: 0xa7
11:14:44:WU00:FS00:0xa7:       Core: Gromacs
11:14:44:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 8548 -checkpoint 15 -np 4
11:14:44:WU00:FS00:0xa7:************************************ CBang *************************************
11:14:44:WU00:FS00:0xa7:       Date: Nov 27 2019
11:14:44:WU00:FS00:0xa7:       Time: 03:40:09
11:14:44:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
11:14:44:WU00:FS00:0xa7:     Branch: master
11:14:44:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
11:14:44:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:14:44:WU00:FS00:0xa7:   Platform: win32 10
11:14:44:WU00:FS00:0xa7:       Bits: 64
11:14:44:WU00:FS00:0xa7:       Mode: Release
11:14:44:WU00:FS00:0xa7:************************************ System ************************************
11:14:44:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-8250U CPU @ 1.60GHz
11:14:44:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 10
11:14:44:WU00:FS00:0xa7:       CPUs: 8
11:14:44:WU00:FS00:0xa7:     Memory: 7.84GiB
11:14:44:WU00:FS00:0xa7:Free Memory: 3.47GiB
11:14:44:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
11:14:44:WU00:FS00:0xa7: OS Version: 6.2
11:14:44:WU00:FS00:0xa7:Has Battery: true
11:14:44:WU00:FS00:0xa7: On Battery: false
11:14:44:WU00:FS00:0xa7: UTC Offset: 3
11:14:44:WU00:FS00:0xa7:        PID: 10484
11:14:44:WU00:FS00:0xa7:        CWD: C:\ProgramData\FAHClient\work
11:14:44:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
11:14:44:WU00:FS00:0xa7:    Version: 0.0.19
11:14:44:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:14:44:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
11:14:44:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
11:14:44:WU00:FS00:0xa7:       Date: Nov 25 2019
11:14:44:WU00:FS00:0xa7:       Time: 17:12:41
11:14:44:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
11:14:45:WU00:FS00:0xa7:     Branch: master
11:14:45:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
11:14:45:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:14:45:WU00:FS00:0xa7:   Platform: win32 10
11:14:45:WU00:FS00:0xa7:       Bits: 64
11:14:45:WU00:FS00:0xa7:       Mode: Release
11:14:45:WU00:FS00:0xa7:************************************ Build *************************************
11:14:45:WU00:FS00:0xa7:       SIMD: avx_256
11:14:45:WU00:FS00:0xa7:********************************************************************************
11:14:45:WU00:FS00:0xa7:Project: 14259 (Run 0, Clone 3432, Gen 239)
11:14:45:WU00:FS00:0xa7:Unit: 0x00000110cedfaa920000000000000d68
11:14:45:WU00:FS00:0xa7:Digital signatures verified
11:14:45:WU00:FS00:0xa7:Calling: mdrun -s frame239.tpr -o frame239.trr -x frame239.xtc -cpi state.cpt -cpt 15 -nt 4
11:14:45:WU00:FS00:0xa7:Steps: first=59750000 total=250000
11:14:46:WU00:FS00:0xa7:Completed 55022 out of 250000 steps (22%)
11:15:24:Saving configuration to config.xml
11:15:24:<config>
11:15:24:  <!-- Folding Slot Configuration -->
11:15:24:  <cause v='HIGH_PRIORITY'/>
11:15:24:
11:15:24:  <!-- Slot Control -->
11:15:24:  <power v='MEDIUM'/>
11:15:24:
11:15:24:  <!-- User Information -->
11:15:24:  <passkey v='*****'/>
11:15:24:  <user v='PeanutHat'/>
11:15:24:
11:15:24:  <!-- Folding Slots -->
11:15:24:  <slot id='0' type='CPU'/>
11:15:24:  <slot id='1' type='GPU'>
11:15:24:    <pci-bus v='0'/>
11:15:24:    <pci-slot v='2'/>
11:15:24:  </slot>
11:15:24:</config>
11:17:14:WU00:FS00:0xa7:Completed 57500 out of 250000 steps (23%)
11:19:33:WU00:FS00:0xa7:Completed 60000 out of 250000 steps (24%)
11:21:24:FS00:Shutting core down
11:21:25:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 10484
11:21:25:WU00:FS00:0xa7:Exiting, please wait. . .
11:21:26:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
11:21:27:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
11:21:27:WU00:FS00:Starting
11:21:27:WARNING:WU00:FS00:Changed SMP threads from 6 to 7 this can cause some work units to fail
11:21:27:WARNING:WU00:FS00:AS lowered CPUs from 7 to 4
11:21:27:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 3620 -checkpoint 15 -np 4
11:21:27:WU00:FS00:Started FahCore on PID 1560
11:21:27:WU00:FS00:Core PID:11996
11:21:27:WU00:FS00:FahCore 0xa7 started
11:21:28:WU00:FS00:0xa7:*********************** Log Started 2020-12-06T11:21:27Z ***********************
11:21:28:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
11:21:28:WU00:FS00:0xa7:       Type: 0xa7
11:21:28:WU00:FS00:0xa7:       Core: Gromacs
11:21:28:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 1560 -checkpoint 15 -np 4
11:21:28:WU00:FS00:0xa7:************************************ CBang *************************************
11:21:28:WU00:FS00:0xa7:       Date: Nov 27 2019
11:21:28:WU00:FS00:0xa7:       Time: 03:40:09
11:21:28:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
11:21:28:WU00:FS00:0xa7:     Branch: master
11:21:28:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
11:21:28:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:21:28:WU00:FS00:0xa7:   Platform: win32 10
11:21:28:WU00:FS00:0xa7:       Bits: 64
11:21:28:WU00:FS00:0xa7:       Mode: Release
11:21:28:WU00:FS00:0xa7:************************************ System ************************************
11:21:28:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-8250U CPU @ 1.60GHz
11:21:28:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 10
11:21:28:WU00:FS00:0xa7:       CPUs: 8
11:21:28:WU00:FS00:0xa7:     Memory: 7.84GiB
11:21:28:WU00:FS00:0xa7:Free Memory: 3.19GiB
11:21:28:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
11:21:28:WU00:FS00:0xa7: OS Version: 6.2
11:21:28:WU00:FS00:0xa7:Has Battery: true
11:21:28:WU00:FS00:0xa7: On Battery: false
11:21:28:WU00:FS00:0xa7: UTC Offset: 3
11:21:28:WU00:FS00:0xa7:        PID: 11996
11:21:28:WU00:FS00:0xa7:        CWD: C:\ProgramData\FAHClient\work
11:21:28:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
11:21:28:WU00:FS00:0xa7:    Version: 0.0.19
11:21:28:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:21:28:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
11:21:28:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
11:21:28:WU00:FS00:0xa7:       Date: Nov 25 2019
11:21:28:WU00:FS00:0xa7:       Time: 17:12:41
11:21:28:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
11:21:28:WU00:FS00:0xa7:************************************ Build *************************************
11:21:28:WU00:FS00:0xa7:       SIMD: avx_256
11:21:28:WU00:FS00:0xa7:********************************************************************************
11:21:28:WU00:FS00:0xa7:Project: 14259 (Run 0, Clone 3432, Gen 239)
11:21:28:WU00:FS00:0xa7:Unit: 0x00000110cedfaa920000000000000d68
11:21:28:WU00:FS00:0xa7:Digital signatures verified
11:21:28:WU00:FS00:0xa7:Calling: mdrun -s frame239.tpr -o frame239.trr -x frame239.xtc -cpi state.cpt -cpt 15 -nt 4
11:21:28:WU00:FS00:0xa7:Steps: first=59750000 total=250000
11:21:29:WU00:FS00:0xa7:Completed 62052 out of 250000 steps (24%)
11:21:30:Saving configuration to config.xml
11:21:30:<config>
11:21:30:  <!-- Folding Slot Configuration -->
11:21:30:  <cause v='HIGH_PRIORITY'/>
11:21:30:
11:21:30:  <!-- Slot Control -->
11:21:30:  <power v='FULL'/>
11:21:30:
11:21:30:  <!-- User Information -->
11:21:30:  <passkey v='*****'/>
11:21:30:  <user v='PeanutHat'/>
11:21:30:
11:21:30:  <!-- Folding Slots -->
11:21:30:  <slot id='0' type='CPU'/>
11:21:30:  <slot id='1' type='GPU'>
11:21:30:    <pci-bus v='0'/>
11:21:30:    <pci-slot v='2'/>
11:21:30:  </slot>
11:21:30:</config>
11:21:54:WU00:FS00:0xa7:Completed 62500 out of 250000 steps (25%)
11:24:14:WU00:FS00:0xa7:Completed 65000 out of 250000 steps (26%)
11:26:36:WU00:FS00:0xa7:Completed 67500 out of 250000 steps (27%)
11:28:58:WU00:FS00:0xa7:Completed 70000 out of 250000 steps (28%)
11:29:56:38:127.0.0.1:New Web session
11:30:06:47:127.0.0.1:New Web session
11:30:15:FS00:Shutting core down
11:30:15:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 11996
11:30:15:WU00:FS00:0xa7:Exiting, please wait. . .
11:30:17:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
11:30:17:WU00:FS00:Starting
11:30:17:WARNING:WU00:FS00:Changed SMP threads from 7 to 6 this can cause some work units to fail
11:30:17:WARNING:WU00:FS00:AS lowered CPUs from 6 to 4
11:30:17:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 3620 -checkpoint 15 -np 4
11:30:17:WU00:FS00:Started FahCore on PID 13800
11:30:17:WU00:FS00:Core PID:2572
11:30:17:WU00:FS00:FahCore 0xa7 started
11:30:18:WU00:FS00:0xa7:*********************** Log Started 2020-12-06T11:30:17Z ***********************
11:30:18:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
11:30:18:WU00:FS00:0xa7:       Type: 0xa7
11:30:18:WU00:FS00:0xa7:       Core: Gromacs
11:30:18:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 13800 -checkpoint 15 -np
11:30:18:WU00:FS00:0xa7:             4
11:30:18:WU00:FS00:0xa7:************************************ CBang *************************************
11:30:18:WU00:FS00:0xa7:       Date: Nov 27 2019
11:30:18:WU00:FS00:0xa7:       Time: 03:40:09
11:30:18:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
11:30:18:WU00:FS00:0xa7:     Branch: master
11:30:18:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
11:30:18:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:30:18:WU00:FS00:0xa7:   Platform: win32 10
11:30:18:WU00:FS00:0xa7:       Bits: 64
11:30:18:WU00:FS00:0xa7:       Mode: Release
11:30:18:WU00:FS00:0xa7:************************************ System ************************************
11:30:18:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-8250U CPU @ 1.60GHz
11:30:18:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 10
11:30:18:WU00:FS00:0xa7:       CPUs: 8
11:30:18:WU00:FS00:0xa7:     Memory: 7.84GiB
11:30:18:WU00:FS00:0xa7:Free Memory: 3.19GiB
11:30:18:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
11:30:18:WU00:FS00:0xa7: OS Version: 6.2
11:30:18:WU00:FS00:0xa7:Has Battery: true
11:30:18:WU00:FS00:0xa7: On Battery: false
11:30:18:WU00:FS00:0xa7: UTC Offset: 3
11:30:18:WU00:FS00:0xa7:        PID: 2572
11:30:18:WU00:FS00:0xa7:        CWD: C:\ProgramData\FAHClient\work
11:30:18:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
11:30:18:WU00:FS00:0xa7:    Version: 0.0.19
11:30:18:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:30:18:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
11:30:18:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
11:30:18:WU00:FS00:0xa7:       Date: Nov 25 2019
11:30:18:WU00:FS00:0xa7:       Time: 17:12:41
11:30:18:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
11:30:18:WU00:FS00:0xa7:************************************ Build *************************************
11:30:18:WU00:FS00:0xa7:       SIMD: avx_256
11:30:18:WU00:FS00:0xa7:********************************************************************************
11:30:18:WU00:FS00:0xa7:Project: 14259 (Run 0, Clone 3432, Gen 239)
11:30:18:WU00:FS00:0xa7:Unit: 0x00000110cedfaa920000000000000d68
11:30:18:WU00:FS00:0xa7:Digital signatures verified
11:30:18:WU00:FS00:0xa7:Calling: mdrun -s frame239.tpr -o frame239.trr -x frame239.xtc -cpi state.cpt -cpt 15 -nt 4
11:30:18:WU00:FS00:0xa7:Steps: first=59750000 total=250000
11:30:19:WU00:FS00:0xa7:Completed 71272 out of 250000 steps (28%)
11:30:39:Saving configuration to config.xml
11:30:39:<config>
11:30:39:  <!-- Folding Slot Configuration -->
11:30:39:  <cause v='HIGH_PRIORITY'/>
11:30:39:
11:30:39:  <!-- Slot Control -->
11:30:39:  <power v='MEDIUM'/>
11:30:39:
11:30:39:  <!-- User Information -->
11:30:39:  <passkey v='*****'/>
11:30:39:  <user v='PeanutHat'/>
11:30:39:
11:30:39:  <!-- Folding Slots -->
11:30:39:  <slot id='0' type='CPU'/>
11:30:39:  <slot id='1' type='GPU'>
11:30:39:    <pci-bus v='0'/>
11:30:39:    <pci-slot v='2'/>
11:30:39:  </slot>
11:30:39:</config>
11:31:29:WU00:FS00:0xa7:Completed 72500 out of 250000 steps (29%)
11:33:46:WU00:FS00:0xa7:Completed 75000 out of 250000 steps (30%)
11:36:12:WU00:FS00:0xa7:Completed 77500 out of 250000 steps (31%)
11:38:29:WU00:FS00:0xa7:Completed 80000 out of 250000 steps (32%)
11:40:34:WU00:FS00:0xa7:Completed 82500 out of 250000 steps (33%)
11:42:51:WU00:FS00:0xa7:Completed 85000 out of 250000 steps (34%)
11:45:10:WU00:FS00:0xa7:Completed 87500 out of 250000 steps (35%)
11:47:41:WU00:FS00:0xa7:Completed 90000 out of 250000 steps (36%)
11:50:05:WU00:FS00:0xa7:Completed 92500 out of 250000 steps (37%)
11:52:32:WU00:FS00:0xa7:Completed 95000 out of 250000 steps (38%)
Re: GPU "disabled"?
If the only GPU you have is the integrated one on your CPU, if you want to do folding on it you can use Configure through FAHControl (Advanced Control) to add `gpu-beta=true`to your GPU slot. In the Configure window select the Slots tab, click on the GPU slot to select it, and then click on Edit. Then click on Add at the bottom right, enter the option name of cpu-beta and the value of trure. Then Okay, Okay and Save the change.
From the type of CPU I am assuming this is a laptop or similar system. Support for the Intel iGPUs was recently added - viewtopic.php?f=24&t=36512#p346637, you may need to update video drivers. The UHD 620 is not the most powerful GPU, and it shares cooling with the CPU on the chip, so it may or may not increase your folding output. Currently this is open beta testing of the newly supported GPUs.
If you do have another GPU that is not showing up, post that information and we will attempt to help you get that recognized.
