18:47:17:WU01:FS00:0xa7:Completed 242500 out of 250000 steps (97%)
18:48:04:WU01:FS00:0xa7:Completed 245000 out of 250000 steps (98%)
18:48:50:WU01:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
18:49:37:WU01:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
18:49:38:WU01:FS00:0xa7:Saving result file ../logfile_01.txt
18:49:38:WU01:FS00:0xa7:Saving result file frame208.trr
18:49:38:WU01:FS00:0xa7:Saving result file frame208.xtc
18:49:38:WU01:FS00:0xa7:Saving result file md.log
18:49:38:WU01:FS00:0xa7:Saving result file science.log
18:49:38:WU01:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
18:49:38:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
18:49:38:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:14255 run:0 clone:2047 gen:208 core:0xa7 unit:0x000000f3cedfaa9200000000000007ff
18:49:38:WU01:FS00:Uploading 2.85MiB to 206.223.170.146
18:49:38:WU01:FS00:Connecting to 206.223.170.146:8080
18:51:48:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
18:51:48:WU01:FS00:Connecting to 206.223.170.146:80
18:53:59:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: Connection timed out
18:53:59:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:14255 run:0 clone:2047 gen:208 core:0xa7 unit:0x000000f3cedfaa9200000000000007ff
18:53:59:WU01:FS00:Uploading 2.85MiB to 206.223.170.146
18:53:59:WU01:FS00:Connecting to 206.223.170.146:8080
18:56:10:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
18:56:10:WU01:FS00:Connecting to 206.223.170.146:80
18:58:21:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: Connection timed out
18:58:21:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:14255 run:0 clone:2047 gen:208 core:0xa7 unit:0x000000f3cedfaa9200000000000007ff
18:58:21:WU01:FS00:Uploading 2.85MiB to 206.223.170.146
18:58:21:WU01:FS00:Connecting to 206.223.170.146:8080
19:00:32:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
19:00:32:WU01:FS00:Connecting to 206.223.170.146:80
19:02:43:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: Connection timed out
19:02:44:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:14255 run:0 clone:2047 gen:208 core:0xa7 unit:0x000000f3cedfaa9200000000000007ff
19:02:44:WU01:FS00:Uploading 2.85MiB to 206.223.170.146
19:02:44:WU01:FS00:Connecting to 206.223.170.146:8080
19:04:54:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
19:04:54:WU01:FS00:Connecting to 206.223.170.146:80
19:07:05:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: Connection timed out
19:07:06:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:14255 run:0 clone:2047 gen:208 core:0xa7 unit:0x000000f3cedfaa9200000000000007ff
19:07:06:WU01:FS00:Uploading 2.85MiB to 206.223.170.146
19:07:06:WU01:FS00:Connecting to 206.223.170.146:8080
19:09:16:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
19:09:16:WU01:FS00:Connecting to 206.223.170.146:80
19:11:28:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: Connection timed out
19:11:28:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:14255 run:0 clone:2047 gen:208 core:0xa7 unit:0x000000f3cedfaa9200000000000007ff
19:11:28:WU01:FS00:Uploading 2.85MiB to 206.223.170.146
19:11:28:WU01:FS00:Connecting to 206.223.170.146:8080
19:13:39:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
19:13:39:WU01:FS00:Connecting to 206.223.170.146:80
19:15:50:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: Connection timed out
