Faling to send results to server (active host disconnects)
M&M_Dutch
Hardware configuration: OS: Windows 10 Home 64-bit
CPU: Intel Processor Cores 6, Threads 12, Specification: Intel Core i7-10710U CPU @ 1.10GHz
Motherboard: Manufacturer: Intel Corporation, Model NUC10i7FNB (U3E1)
Graphics: Monitor = BenQ GW2470 on Intel UHD Graphics
Current Resolution 1920x1080 pixels
Work Resolution 1920x1040 pixels
State Enabled, Primary
Monitor Width 1920
Monitor Height 1080
Monitor BPP 32 bits per pixel
Monitor Frequency 59 Hz
Intel UHD Graphics:
Manufacturer Intel
Model UHD Graphics
Post by M&M_Dutch »
Hello,
from time to time, FAH can't upload the results to a server. Log says "Failed to send results to work server: Failed to connect to 69.94.66.7:80: Kan geen verbinding maken omdat de doelcomputer de verbinding actief heeft geweigerd." As a result, status remains at "send" for hours.
Here's the log:
*********************** Log Started 2020-11-01T13:08:04Z ***********************
13:08:04:******************************* libFAH ********************************
13:08:04:           Date: Oct 20 2020
13:08:04:           Time: 13:36:55
13:08:04:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
13:08:04:         Branch: master
13:08:04:       Compiler: Visual C++ 2015
13:08:04:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
13:08:04:       Platform: win32 10
13:08:04:           Bits: 32
13:08:04:           Mode: Release
13:08:04:****************************** FAHClient ******************************
13:08:04:        Version: 7.6.21
13:08:04:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:08:04:      Copyright: 2020 foldingathome.org
13:08:04:       Homepage: https://foldingathome.org/
13:08:04:           Time: 13:41:04
13:08:04:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
13:08:04:           Bits: 32
13:08:04:         Config: C:\Users\mdego\AppData\Roaming\FAHClient\config.xml
13:08:04:******************************** CBang ********************************
13:08:04:           Time: 11:36:18
13:08:04:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
13:08:04:           Bits: 32
13:08:04:******************************* System ********************************
13:08:04:            CPU: Intel(R) Core(TM) i7-10710U CPU @ 1.10GHz
13:08:04:         CPU ID: GenuineIntel Family 6 Model 166 Stepping 0
13:08:04:           CPUs: 12
13:08:04:         Memory: 15.81GiB
13:08:04:    Free Memory: 12.09GiB
13:08:04:        Threads: WINDOWS_THREADS
13:08:04:     OS Version: 6.2
13:08:04:    Has Battery: false
13:08:04:     On Battery: false
13:08:04:     UTC Offset: 1
13:08:04:            PID: 1472
13:08:04:            CWD: C:\Users\mdego\AppData\Roaming\FAHClient
13:08:04:  Win32 Service: false
13:08:04:             OS: Windows 10 Home
13:08:04:        OS Arch: AMD64
13:08:04:           GPUs: 0
13:08:04:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': Kan
13:08:04:                 opgegeven module niet vinden.
13:08:04:
13:08:04:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:26.20
13:08:04:***********************************************************************
13:08:04:<config>
13:08:04:  <!-- Network -->
13:08:04:  <proxy v=':8080'/>
13:08:04:
13:08:04:  <!-- User Information -->
13:08:04:  <passkey v='*****'/>
13:08:04:  <user v='Martin71'/>
13:08:04:
13:08:04:  <!-- Folding Slots -->
13:08:04:  <slot id='0' type='CPU'/>
13:08:04:</config>
13:08:04:Trying to access database...
13:08:04:Successfully acquired database lock
13:08:04:FS00:Initialized folding slot 00: cpu:11
13:08:05:WU01:FS00:Sending unit results: id:01 state:SEND error:FAILED project:14379 run:1161 clone:0 gen:652 core:0xa7 unit:0x000002e3455e42070000000004890000
13:08:05:WU01:FS00:Connecting to 69.94.66.7:8080
13:08:05:WU02:FS00:Starting
13:08:05:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\mdego\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 1472 -checkpoint 15 -np 11
13:08:05:WU02:FS00:Started FahCore on PID 11896
13:08:05:WU02:FS00:Core PID:10604
13:08:05:WU02:FS00:FahCore 0xa7 started
13:08:05:WU02:FS00:0xa7:*********************** Log Started 2020-11-01T13:08:05Z ***********************
13:08:05:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
13:08:05:WU02:FS00:0xa7:       Type: 0xa7
13:08:05:WU02:FS00:0xa7:       Core: Gromacs
13:08:05:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 706 -lifeline 11896 -checkpoint 15 -np
13:08:05:WU02:FS00:0xa7:             11
13:08:05:WU02:FS00:0xa7:************************************ CBang *************************************
13:08:05:WU02:FS00:0xa7:       Date: Nov 27 2019
13:08:05:WU02:FS00:0xa7:       Time: 03:40:09
13:08:05:WU02:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
13:08:05:WU02:FS00:0xa7:     Branch: master
13:08:05:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
13:08:05:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
13:08:05:WU02:FS00:0xa7:   Platform: win32 10
13:08:05:WU02:FS00:0xa7:       Bits: 64
13:08:05:WU02:FS00:0xa7:       Mode: Release
13:08:05:WU02:FS00:0xa7:************************************ System ************************************
13:08:05:WU02:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-10710U CPU @ 1.10GHz
13:08:05:WU02:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 166 Stepping 0
13:08:05:WU02:FS00:0xa7:       CPUs: 12
13:08:05:WU02:FS00:0xa7:     Memory: 15.81GiB
13:08:05:WU02:FS00:0xa7:Free Memory: 11.97GiB
13:08:05:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
13:08:05:WU02:FS00:0xa7: OS Version: 6.2
13:08:05:WU02:FS00:0xa7:Has Battery: false
13:08:05:WU02:FS00:0xa7: On Battery: false
13:08:05:WU02:FS00:0xa7: UTC Offset: 1
13:08:05:WU02:FS00:0xa7:        PID: 10604
13:08:05:WU02:FS00:0xa7:        CWD: C:\Users\mdego\AppData\Roaming\FAHClient\work
13:08:05:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
13:08:05:WU02:FS00:0xa7:    Version: 0.0.19
13:08:05:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:08:05:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
13:08:05:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
13:08:05:WU02:FS00:0xa7:       Date: Nov 25 2019
13:08:05:WU02:FS00:0xa7:       Time: 17:12:41
13:08:05:WU02:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
13:08:05:WU02:FS00:0xa7:************************************ Build *************************************
13:08:05:WU02:FS00:0xa7:       SIMD: avx_256
13:08:05:WU02:FS00:0xa7:********************************************************************************
13:08:05:WU02:FS00:0xa7:Project: 16925 (Run 35, Clone 3579, Gen 2)
13:08:05:WU02:FS00:0xa7:Unit: 0x0000000281d528e55f9bdcb5dab461ce
13:08:05:WU02:FS00:0xa7:Digital signatures verified
13:08:05:WU02:FS00:0xa7:Reducing thread count from 11 to 10 to avoid domain decomposition by a prime number > 3
13:08:05:WU02:FS00:0xa7:Calling: mdrun -s frame2.tpr -o frame2.trr -cpi state.cpt -cpt 15 -nt 10
13:08:05:WU02:FS00:0xa7:Steps: first=1000000 total=500000
13:08:07:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
13:08:07:WU01:FS00:Connecting to 69.94.66.7:80
13:08:09:WU02:FS00:0xa7:Completed 289681 out of 500000 steps (57%)
13:08:10:WARNING:WU01:FS00:Exception:[color=#FFFF00] Failed to send results to work server: Failed to connect to 69.94.66.7:80: Kan geen verbinding maken omdat de doelcomputer de verbinding actief heeft geweigerd.[/color]
13:08:11:WU01:FS00:Sending unit results: id:01 state:SEND error:FAILED project:14379 run:1161 clone:0 gen:652 core:0xa7 unit:0x000002e3455e42070000000004890000
13:08:11:WU01:FS00:Connecting to 69.94.66.7:8080
13:08:13:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
13:08:13:WU01:FS00:Connecting to 69.94.66.7:80
13:08:15:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 69.94.66.7:80: Kan geen verbinding maken omdat de doelcomputer de verbinding actief heeft geweigerd.
13:08:20:WU02:FS00:0xa7:Completed 290000 out of 500000 steps (58%)
13:09:11:WU01:FS00:Sending unit results: id:01 state:SEND error:FAILED project:14379 run:1161 clone:0 gen:652 core:0xa7 unit:0x000002e3455e42070000000004890000
13:09:11:WU01:FS00:Connecting to 69.94.66.7:8080
13:09:13:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
13:09:13:WU01:FS00:Connecting to 69.94.66.7:80
13:09:16:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 69.94.66.7:80: Kan geen verbinding maken omdat de doelcomputer de verbinding actief heeft geweigerd.
13:10:48:WU01:FS00:Sending unit results: id:01 state:SEND error:FAILED project:14379 run:1161 clone:0 gen:652 core:0xa7 unit:0x000002e3455e42070000000004890000
13:10:48:WU01:FS00:Connecting to 69.94.66.7:8080
13:10:50:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
13:10:50:WU01:FS00:Connecting to 69.94.66.7:80
13:10:53:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 69.94.66.7:80: Kan geen verbinding maken omdat de doelcomputer de verbinding actief heeft geweigerd.
13:11:15:WU02:FS00:0xa7:Completed 295000 out of 500000 steps (59%)
13:13:25:WU01:FS00:Sending unit results: id:01 state:SEND error:FAILED project:14379 run:1161 clone:0 gen:652 core:0xa7 unit:0x000002e3455e42070000000004890000
13:13:25:WU01:FS00:Connecting to 69.94.66.7:8080
13:13:27:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
13:13:27:WU01:FS00:Connecting to 69.94.66.7:80
13:13:30:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 69.94.66.7:80: Kan geen verbinding maken omdat de doelcomputer de verbinding actief heeft geweigerd.
13:13:57:WU02:FS00:0xa7:Completed 300000 out of 500000 steps (60%)
13:16:38:WU02:FS00:0xa7:Completed 305000 out of 500000 steps (61%)
13:17:39:WU01:FS00:Sending unit results: id:01 state:SEND error:FAILED project:14379 run:1161 clone:0 gen:652 core:0xa7 unit:0x000002e3455e42070000000004890000
13:17:39:WU01:FS00:Connecting to 69.94.66.7:8080
13:17:42:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
13:17:42:WU01:FS00:Connecting to 69.94.66.7:80
13:17:44:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 69.94.66.7:80: Kan geen verbinding maken omdat de doelcomputer de verbinding actief heeft geweigerd.
13:19:21:WU02:FS00:0xa7:Completed 310000 out of 500000 steps (62%)
13:22:04:WU02:FS00:0xa7:Completed 315000 out of 500000 steps (63%)
13:24:31:WU01:FS00:Sending unit results: id:01 state:SEND error:FAILED project:14379 run:1161 clone:0 gen:652 core:0xa7 unit:0x000002e3455e42070000000004890000
13:24:31:WU01:FS00:Connecting to 69.94.66.7:8080
13:24:33:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
13:24:33:WU01:FS00:Connecting to 69.94.66.7:80
13:24:36:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 69.94.66.7:80: Kan geen verbinding maken omdat de doelcomputer de verbinding actief heeft geweigerd.
13:24:45:WU02:FS00:0xa7:Completed 320000 out of 500000 steps (64%)
13:27:26:WU02:FS00:0xa7:Completed 325000 out of 500000 steps (65%)
13:30:08:WU02:FS00:0xa7:Completed 330000 out of 500000 steps (66%)
13:32:49:WU02:FS00:0xa7:Completed 335000 out of 500000 steps (67%)
13:35:31:WU02:FS00:0xa7:Completed 340000 out of 500000 steps (68%)
13:35:36:WU01:FS00:Sending unit results: id:01 state:SEND error:FAILED project:14379 run:1161 clone:0 gen:652 core:0xa7 unit:0x000002e3455e42070000000004890000
13:35:36:WU01:FS00:Connecting to 69.94.66.7:8080
13:35:39:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
13:35:39:WU01:FS00:Connecting to 69.94.66.7:80
13:35:42:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 69.94.66.7:80: Kan geen verbinding maken omdat de doelcomputer de verbinding actief heeft geweigerd.
13:38:14:WU02:FS00:0xa7:Completed 345000 out of 500000 steps (69%)
13:40:55:WU02:FS00:0xa7:Completed 350000 out of 500000 steps (70%)
13:43:37:WU02:FS00:0xa7:Completed 355000 out of 500000 steps (71%)
13:46:18:WU02:FS00:0xa7:Completed 360000 out of 500000 steps (72%)
13:49:13:WU02:FS00:0xa7:Completed 365000 out of 500000 steps (73%)
13:52:08:WU02:FS00:0xa7:Completed 370000 out of 500000 steps (74%)
13:53:33:WU01:FS00:Sending unit results: id:01 state:SEND error:FAILED project:14379 run:1161 clone:0 gen:652 core:0xa7 unit:0x000002e3455e42070000000004890000
13:53:33:WU01:FS00:Connecting to 69.94.66.7:8080
13:53:36:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
13:53:36:WU01:FS00:Connecting to 69.94.66.7:80
13:53:38:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 69.94.66.7:80: Kan geen verbinding maken omdat de doelcomputer de verbinding actief heeft geweigerd.
13:55:03:WU02:FS00:0xa7:Completed 375000 out of 500000 steps (75%)
13:55:56:ERROR:Receive error: 10054: De externe host heeft een verbinding verbroken.
13:57:50:WU02:FS00:0xa7:Completed 380000 out of 500000 steps (76%)
14:00:30:WU02:FS00:0xa7:Completed 385000 out of 500000 steps (77%)
14:03:10:WU02:FS00:0xa7:Completed 390000 out of 500000 steps (78%)
Is this just a capacity issue or maybe an error?
Also, from time to time, I have the same issue as mentioned in this topic: viewtopic.php?f=108&t=36179 Except I have a windows 10 NUC. Thusfare, with some patience, FAH manages to solve it by itself and folding starts.
I am curious as to the answers.
grtz,
M&M
Re: Faling to send results to server (active host disconnect
Currently 69.94.66.7 is down as shown on the Server Status page, link at the top of the forum. That has already been reported - viewtopic.php?f=18&t=36348.
For the second issue, currently there are more systems requesting types of WUs at times than there are available. This is due to a number of circumstances such as projects that have finished, others in the process of being set up and being readied for release, and other factors. More are in the pipeline to be available in the near future. For now depending on the time of day and such, a WU request might go through on the first time, or it may take minutes or longer.
M&M_Dutch
Monitor Width 1920
Monitor Height 1080
Intel UHD Graphics:
Manufacturer Intel
Model UHD Graphics
Post by M&M_Dutch »
Joe_H wrote:Currently 69.94.66.7 is down as shown on the Server Status page, link at the top of the forum. That has already been reported - viewtopic.php?f=18&t=36348.
Ok. Thx for the link and your clear answer :) U may close this topic if there are no other relevant answers possible.
