GeForce RTX 3080 and 3090 support enabled !
The new Ampere GeForce GPUs are now officially enabled in GPUs.txt !
0x2204 = GA102 [GeForce RTX 3090]
0x2206 = GA102 [GeForce RTX 3080]
If you are one of the happy few that have been able to get one, let us know how it works ! ;)
MeeLee
Re: GeForce RTX 3080 and 3090 support enabled !
Post by MeeLee »
The 3090 is highly unlikely, as review sites don't even have them.
The 3080, I wished I had, but I'm saving up for a 3090.
road-runner
Post by road-runner »
Looks like 3.5 million PPD so far on 3080 a reviewer is running folding I asked him if he would
https://forums.overclockersclub.com/top ... nt=2173904
Would be keen to grab what the Projects are since small atom WUs would generate lower PPD than higher atom WUs.
Plus, once FahCore_22 version 0.0.12 with CUDA support is released (after the Beta testing), that will change the game completely! Looking forward to it once it is released... very soon!
kiore
Post by kiore »
That folder on overclockers is saying 3.5-4.5 Mppd on 3080 looks like has completed just 3 units so far and not big ones, seems to be on windows from comment. Good to see some data even if partial.
road-runner
Hes on windows pcie 3.0 only using 41% bandwidth
https://forums.overclockersclub.com/top ... nt=2173907
kiore
Post by kiore »
road-runner wrote:Hes on windows pcie 3.0 only using 41% bandwidth
Oh so his QRB not enabled yet, maybe not such small units then.
road-runner
Maybe not I was thinking the same thing I posted a link to here maybe he will answer what projects/PPD
says he can never post here on the forum says authorization needed, here is a log on one..
02:19:18:WU01:FS01:Started FahCore on PID 2908
02:19:18:WU01:FS01:Core PID:5952
02:19:18:WU01:FS01:FahCore 0x22 started
02:19:18:WU01:FS01:0x22:*********************** Log Started 2020-09-19T02:19:18Z ***********************
02:19:18:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
02:19:18:WU01:FS01:0x22:       Core: Core22
02:19:18:WU01:FS01:0x22:       Type: 0x22
02:19:18:WU01:FS01:0x22:    Version: 0.0.11
02:19:18:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:19:18:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
02:19:18:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
02:19:18:WU01:FS01:0x22:       Date: Jun 26 2020
02:19:18:WU01:FS01:0x22:       Time: 19:49:16
02:19:18:WU01:FS01:0x22:   Revision: 22010df8a4db48db1b35d33e666b64d8ce48689d
02:19:18:WU01:FS01:0x22:     Branch: core22-0.0.11
02:19:18:WU01:FS01:0x22:   Compiler: Visual C++ 2015
02:19:18:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
02:19:18:WU01:FS01:0x22:   Platform: win32 10
02:19:18:WU01:FS01:0x22:       Bits: 64
02:19:18:WU01:FS01:0x22:       Mode: Release
02:19:18:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
02:19:18:WU01:FS01:0x22:             <peastman@stanford.edu>
02:19:18:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 2908 -checkpoint 15
02:19:18:WU01:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
02:19:18:WU01:FS01:0x22:             0 -gpu 0
02:19:18:WU01:FS01:0x22:************************************ libFAH ************************************
02:19:18:WU01:FS01:0x22:       Time: 19:47:12
02:19:18:WU01:FS01:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
02:19:18:WU01:FS01:0x22:     Branch: HEAD
02:19:18:WU01:FS01:0x22:************************************ CBang *************************************
02:19:18:WU01:FS01:0x22:       Time: 19:46:11
02:19:18:WU01:FS01:0x22:   Revision: f8529962055b0e7bde23e429f5072ff758089dee
02:19:18:WU01:FS01:0x22:     Branch: master
02:19:18:WU01:FS01:0x22:************************************ System ************************************
02:19:18:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i9-10900K CPU @ 3.70GHz
02:19:18:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 165 Stepping 5
02:19:18:WU01:FS01:0x22:       CPUs: 20
02:19:18:WU01:FS01:0x22:     Memory: 15.92GiB
02:19:18:WU01:FS01:0x22:Free Memory: 13.02GiB
02:19:18:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
02:19:18:WU01:FS01:0x22: OS Version: 6.2
02:19:18:WU01:FS01:0x22:Has Battery: false
02:19:18:WU01:FS01:0x22: On Battery: false
02:19:18:WU01:FS01:0x22: UTC Offset: -7
02:19:18:WU01:FS01:0x22:        PID: 5952
02:19:18:WU01:FS01:0x22:        CWD: C:\Users\Intel-Test\AppData\Roaming\FAHClient\work
02:19:18:WU01:FS01:0x22:********************************************************************************
02:19:18:WU01:FS01:0x22:Project: 16918 (Run 25, Clone 123, Gen 77)
02:19:18:WU01:FS01:0x22:Unit: 0x0000006c0002894c5f1761bbb0a5002c
02:19:18:WU01:FS01:0x22:Digital signatures verified
02:19:18:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
02:19:18:WU01:FS01:0x22:Version 0.0.11
02:19:18:WU01:FS01:0x22:  Checkpoint write interval: 100000 steps (2%) [50 total]
02:19:18:WU01:FS01:0x22:  JSON viewer frame write interval: 50000 steps (1%) [100 total]
02:19:18:WU01:FS01:0x22:  XTC frame write interval: 250000 steps (5%) [20 total]
02:19:18:WU01:FS01:0x22:  Global context and integrator variables write interval: disabled
02:19:24:WU01:FS01:0x22:Completed 0 out of 5000000 steps (0%)
02:19:38:Saving configuration to config.xml
02:19:38:<config>
02:19:38:  <!-- Network -->
02:19:38:  <proxy v=':8080'/>
02:19:38:
02:19:38:  <!-- Slot Control -->
02:19:38:  <power v='full'/>
02:19:38:
02:19:38:  <!-- User Information -->
02:19:38:  <passkey v='*****'/>
02:19:38:  <team v='12772'/>
02:19:38:  <user v='ir_cow'/>
02:19:38:
02:19:38:  <!-- Folding Slots -->
02:19:38:  <slot id='1' type='GPU'/>
02:19:38:</config>
02:20:21:WU01:FS01:0x22:Completed 50000 out of 5000000 steps (1%)
02:21:18:WU01:FS01:0x22:Completed 100000 out of 5000000 steps (2%)
02:22:15:WU01:FS01:0x22:Completed 150000 out of 5000000 steps (3%)
02:23:12:WU01:FS01:0x22:Completed 200000 out of 5000000 steps (4%)
02:23:48:12:127.0.0.1:New Web session
02:24:09:WU01:FS01:0x22:Completed 250000 out of 5000000 steps (5%)
02:25:06:WU01:FS01:0x22:Completed 300000 out of 5000000 steps (6%)
02:26:03:WU01:FS01:0x22:Completed 350000 out of 5000000 steps (7%)
02:26:59:WU01:FS01:0x22:Completed 400000 out of 5000000 steps (8%)
02:27:56:WU01:FS01:0x22:Completed 450000 out of 5000000 steps (9%)
02:28:53:WU01:FS01:0x22:Completed 500000 out of 5000000 steps (10%)
02:29:50:WU01:FS01:0x22:Completed 550000 out of 5000000 steps (11%)
02:30:46:WU01:FS01:0x22:Completed 600000 out of 5000000 steps (12%)
02:31:44:WU01:FS01:0x22:Completed 650000 out of 5000000 steps (13%)
02:32:40:WU01:FS01:0x22:Completed 700000 out of 5000000 steps (14%)
02:33:37:WU01:FS01:0x22:Completed 750000 out of 5000000 steps (15%)
02:34:34:WU01:FS01:0x22:Completed 800000 out of 5000000 steps (16%)
02:35:31:WU01:FS01:0x22:Completed 850000 out of 5000000 steps (17%)
02:36:28:WU01:FS01:0x22:Completed 900000 out of 5000000 steps (18%)
02:37:25:WU01:FS01:0x22:Completed 950000 out of 5000000 steps (19%)
02:38:21:WU01:FS01:0x22:Completed 1000000 out of 5000000 steps (20%)
02:39:18:WU01:FS01:0x22:Completed 1050000 out of 5000000 steps (21%)
ir_cow
Post by ir_cow »
Hey all,
RR sent me over here. See if I can answer any found questions for the RTX 3080.
Welcome to the F@H Forum ir_cow,
Thanks for taking time to run F@H on your RTX 3080 and sharing the results. My suggestion would be to get HFM.NET (https://github.com/harlam357/hfm-net) which can easily collect stats on your client when GPU folding making it easy to share the information :)
I don't know why, but I guess that we'll see PPD between 3.5 and 6 millions on the 3080 ... ;)
Post by foldy »
For performance testing you could run 2 fah work units concurrently on the RTX 3080 - that should fill those shaders
ap1978
Post by ap1978 »
toTOW wrote:I don't know why, but I guess that we'll see PPD between 3.5 and 6 millions on the 3080 ... ;)
Not bad :)
bunkermagnus
Post by bunkermagnus »
Great that the RTX 3080 was added so fast to the GPU.txt.
I just updated mine and started folding.
With default settings and silent BIOS profile on my Gigabyte RTX 3080 Gaming OC it's humming along with:
Temp: 69 C
GPU load: 39% (Can I put more load on the GPU?)
PPD hovers around 4 000 000 halfway into the first WU.
*********************** Log Started 2020-09-19T17:21:48Z ***********************
17:22:34:WU00:FS01:FahCore 0x22 started
17:22:35:WU00:FS01:0x22:*********************** Log Started 2020-09-19T17:22:34Z ***********************
17:22:35:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
17:22:35:WU00:FS01:0x22:       Core: Core22
17:22:35:WU00:FS01:0x22:       Type: 0x22
17:22:35:WU00:FS01:0x22:    Version: 0.0.11
17:22:35:WU00:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:22:35:WU00:FS01:0x22:  Copyright: 2020 foldingathome.org
17:22:35:WU00:FS01:0x22:   Homepage: https://foldingathome.org/
17:22:35:WU00:FS01:0x22:       Date: Jun 26 2020
17:22:35:WU00:FS01:0x22:       Time: 19:49:16
17:22:35:WU00:FS01:0x22:   Revision: 22010df8a4db48db1b35d33e666b64d8ce48689d
17:22:35:WU00:FS01:0x22:     Branch: core22-0.0.11
17:22:35:WU00:FS01:0x22:   Compiler: Visual C++ 2015
17:22:35:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
17:22:35:WU00:FS01:0x22:   Platform: win32 10
17:22:35:WU00:FS01:0x22:       Bits: 64
17:22:35:WU00:FS01:0x22:       Mode: Release
17:22:35:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
17:22:35:WU00:FS01:0x22:             <peastman@stanford.edu>
17:22:35:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 13748 -checkpoint 15
17:22:35:WU00:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
17:22:35:WU00:FS01:0x22:             0 -gpu 0
17:22:35:WU00:FS01:0x22:************************************ libFAH ************************************
17:22:35:WU00:FS01:0x22:       Time: 19:47:12
17:22:35:WU00:FS01:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
17:22:35:WU00:FS01:0x22:     Branch: HEAD
17:22:35:WU00:FS01:0x22:************************************ CBang *************************************
17:22:35:WU00:FS01:0x22:       Time: 19:46:11
17:22:35:WU00:FS01:0x22:   Revision: f8529962055b0e7bde23e429f5072ff758089dee
17:22:35:WU00:FS01:0x22:     Branch: master
17:22:35:WU00:FS01:0x22:************************************ System ************************************
17:22:35:WU00:FS01:0x22:        CPU: AMD Ryzen 9 3950X 16-Core Processor
17:22:35:WU00:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
17:22:35:WU00:FS01:0x22:       CPUs: 32
17:22:35:WU00:FS01:0x22:     Memory: 31.95GiB
17:22:35:WU00:FS01:0x22:Free Memory: 25.90GiB
17:22:35:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
17:22:35:WU00:FS01:0x22: OS Version: 6.2
17:22:35:WU00:FS01:0x22:Has Battery: false
17:22:35:WU00:FS01:0x22: On Battery: false
17:22:35:WU00:FS01:0x22: UTC Offset: 2
17:22:35:WU00:FS01:0x22:        PID: 15632
17:22:35:WU00:FS01:0x22:        CWD: C:\Users\bunke\AppData\Roaming\FAHClient\work
17:22:35:WU00:FS01:0x22:********************************************************************************
17:22:35:WU00:FS01:0x22:Project: 14905 (Run 273, Clone 6, Gen 20)
17:22:35:WU00:FS01:0x22:Unit: 0x0000001f81d59d695f4ec9dc704c4ec8
17:22:35:WU00:FS01:0x22:Reading tar file core.xml
17:22:35:WU00:FS01:0x22:Reading tar file integrator.xml
17:22:35:WU00:FS01:0x22:Reading tar file state.xml
17:22:35:WU00:FS01:0x22:Reading tar file system.xml
17:22:36:WU00:FS01:0x22:Digital signatures verified
17:22:36:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
17:22:36:WU00:FS01:0x22:Version 0.0.11
17:22:36:WU00:FS01:0x22:  Checkpoint write interval: 100000 steps (5%) [20 total]
17:22:36:WU00:FS01:0x22:  JSON viewer frame write interval: 20000 steps (1%) [100 total]
17:22:36:WU00:FS01:0x22:  XTC frame write interval: 50000 steps (2.5%) [40 total]
17:22:36:WU00:FS01:0x22:  Global context and integrator variables write interval: disabled
17:22:49:Removing old file 'configs/config-20200721-103347.xml'
17:22:49:Saving configuration to config.xml
17:22:49:<config>
17:22:49:  <!-- Folding Core -->
17:22:49:  <core-priority v='low'/>
17:22:49:
17:22:49:  <slot id='1' type='GPU'/>
17:22:49:</config>
17:22:49:WU00:FS01:0x22:Completed 0 out of 2000000 steps (0%)
17:23:01:Removing old file 'configs/config-20200721-103457.xml'
17:23:01:Saving configuration to config.xml
17:23:01:<config>
17:23:01:  <!-- Folding Core -->
17:23:01:  <core-priority v='low'/>
17:23:01:
17:23:01:
17:23:01:  <!-- Folding Slots -->
17:23:01:  <slot id='0' type='CPU'>
17:23:01:    <pause-on-start v='True'/>
17:23:01:    <paused v='true'/>
17:23:01:  </slot>
17:23:01:  <slot id='1' type='GPU'>
17:23:01:  </slot>
17:23:01:</config>
17:23:30:WU00:FS01:0x22:Completed 20000 out of 2000000 steps (1%)
17:23:50:Removing old file 'configs/config-20200721-103549.xml'
17:23:50:Saving configuration to config.xml
17:23:50:<config>
17:23:50:  <!-- Folding Core -->
17:23:50:  <core-priority v='low'/>
17:23:50:
17:23:50:
17:23:50:
17:23:50:  <!-- Folding Slots -->
17:23:50:  <slot id='0' type='CPU'>
17:23:50:    <pause-on-start v='True'/>
17:23:50:    <paused v='true'/>
17:23:50:  </slot>
17:23:50:  <slot id='1' type='GPU'>
17:23:50:  </slot>
17:23:50:</config>
17:24:11:WU00:FS01:0x22:Completed 40000 out of 2000000 steps (2%)
17:24:52:WU00:FS01:0x22:Completed 60000 out of 2000000 steps (3%)
17:25:33:WU00:FS01:0x22:Completed 80000 out of 2000000 steps (4%)
17:26:14:WU00:FS01:0x22:Completed 100000 out of 2000000 steps (5%)
17:26:55:WU00:FS01:0x22:Completed 120000 out of 2000000 steps (6%)
17:27:36:WU00:FS01:0x22:Completed 140000 out of 2000000 steps (7%)
17:28:17:WU00:FS01:0x22:Completed 160000 out of 2000000 steps (8%)
17:28:57:WU00:FS01:0x22:Completed 180000 out of 2000000 steps (9%)
17:29:38:WU00:FS01:0x22:Completed 200000 out of 2000000 steps (10%)
17:30:19:WU00:FS01:0x22:Completed 220000 out of 2000000 steps (11%)
17:31:00:WU00:FS01:0x22:Completed 240000 out of 2000000 steps (12%)
17:31:41:WU00:FS01:0x22:Completed 260000 out of 2000000 steps (13%)
17:32:21:WU00:FS01:0x22:Completed 280000 out of 2000000 steps (14%)
17:33:02:WU00:FS01:0x22:Completed 300000 out of 2000000 steps (15%)
17:33:42:WU00:FS01:0x22:Completed 320000 out of 2000000 steps (16%)
17:34:22:WU00:FS01:0x22:Completed 340000 out of 2000000 steps (17%)
17:35:03:WU00:FS01:0x22:Completed 360000 out of 2000000 steps (18%)
17:35:44:WU00:FS01:0x22:Completed 380000 out of 2000000 steps (19%)
17:36:24:WU00:FS01:0x22:Completed 400000 out of 2000000 steps (20%)
17:37:05:WU00:FS01:0x22:Completed 420000 out of 2000000 steps (21%)
17:37:46:WU00:FS01:0x22:Completed 440000 out of 2000000 steps (22%)
17:38:27:WU00:FS01:0x22:Completed 460000 out of 2000000 steps (23%)
17:39:08:WU00:FS01:0x22:Completed 480000 out of 2000000 steps (24%)
17:39:48:WU00:FS01:0x22:Completed 500000 out of 2000000 steps (25%)
17:40:29:WU00:FS01:0x22:Completed 520000 out of 2000000 steps (26%)
17:41:10:WU00:FS01:0x22:Completed 540000 out of 2000000 steps (27%)
17:41:50:WU00:FS01:0x22:Completed 560000 out of 2000000 steps (28%)
17:42:31:WU00:FS01:0x22:Completed 580000 out of 2000000 steps (29%)
17:43:11:WU00:FS01:0x22:Completed 600000 out of 2000000 steps (30%)
17:43:52:WU00:FS01:0x22:Completed 620000 out of 2000000 steps (31%)
17:44:32:WU00:FS01:0x22:Completed 640000 out of 2000000 steps (32%)
17:45:12:WU00:FS01:0x22:Completed 660000 out of 2000000 steps (33%)
17:45:54:WU00:FS01:0x22:Completed 680000 out of 2000000 steps (34%)
17:46:36:WU00:FS01:0x22:Completed 700000 out of 2000000 steps (35%)
17:47:18:WU00:FS01:0x22:Completed 720000 out of 2000000 steps (36%)
17:48:00:WU00:FS01:0x22:Completed 740000 out of 2000000 steps (37%)
17:48:42:WU00:FS01:0x22:Completed 760000 out of 2000000 steps (38%)
17:49:24:WU00:FS01:0x22:Completed 780000 out of 2000000 steps (39%)
17:50:07:WU00:FS01:0x22:Completed 800000 out of 2000000 steps (40%)
17:50:50:WU00:FS01:0x22:Completed 820000 out of 2000000 steps (41%)
17:51:32:WU00:FS01:0x22:Completed 840000 out of 2000000 steps (42%)
17:52:13:WU00:FS01:0x22:Completed 860000 out of 2000000 steps (43%)
17:52:55:WU00:FS01:0x22:Completed 880000 out of 2000000 steps (44%)
17:53:37:WU00:FS01:0x22:Completed 900000 out of 2000000 steps (45%)
17:54:19:WU00:FS01:0x22:Completed 920000 out of 2000000 steps (46%)
17:55:00:WU00:FS01:0x22:Completed 940000 out of 2000000 steps (47%)
17:55:41:WU00:FS01:0x22:Completed 960000 out of 2000000 steps (48%)
17:56:22:WU00:FS01:0x22:Completed 980000 out of 2000000 steps (49%)
17:57:02:WU00:FS01:0x22:Completed 1000000 out of 2000000 steps (50%)
17:57:44:WU00:FS01:0x22:Completed 1020000 out of 2000000 steps (51%)
17:58:24:WU00:FS01:0x22:Completed 1040000 out of 2000000 steps (52%)
17:59:05:WU00:FS01:0x22:Completed 1060000 out of 2000000 steps (53%)
17:59:45:WU00:FS01:0x22:Completed 1080000 out of 2000000 steps (54%)
18:00:26:WU00:FS01:0x22:Completed 1100000 out of 2000000 steps (55%)
18:01:08:WU00:FS01:0x22:Completed 1120000 out of 2000000 steps (56%)
18:01:48:WU00:FS01:0x22:Completed 1140000 out of 2000000 steps (57%)
18:02:28:WU00:FS01:0x22:Completed 1160000 out of 2000000 steps (58%)
18:03:09:WU00:FS01:0x22:Completed 1180000 out of 2000000 steps (59%)
18:03:49:WU00:FS01:0x22:Completed 1200000 out of 2000000 steps (60%)
18:04:30:WU00:FS01:0x22:Completed 1220000 out of 2000000 steps (61%)
18:05:11:WU00:FS01:0x22:Completed 1240000 out of 2000000 steps (62%)
18:05:51:WU00:FS01:0x22:Completed 1260000 out of 2000000 steps (63%)
18:06:32:WU00:FS01:0x22:Completed 1280000 out of 2000000 steps (64%)
18:07:12:WU00:FS01:0x22:Completed 1300000 out of 2000000 steps (65%)
18:07:53:WU00:FS01:0x22:Completed 1320000 out of 2000000 steps (66%)
18:08:34:WU00:FS01:0x22:Completed 1340000 out of 2000000 steps (67%)
18:09:15:WU00:FS01:0x22:Completed 1360000 out of 2000000 steps (68%)
18:09:56:WU00:FS01:0x22:Completed 1380000 out of 2000000 steps (69%)
18:10:37:WU00:FS01:0x22:Completed 1400000 out of 2000000 steps (70%)
18:11:19:WU00:FS01:0x22:Completed 1420000 out of 2000000 steps (71%)
18:12:00:WU00:FS01:0x22:Completed 1440000 out of 2000000 steps (72%)
18:12:40:WU00:FS01:0x22:Completed 1460000 out of 2000000 steps (73%)
18:13:21:WU00:FS01:0x22:Completed 1480000 out of 2000000 steps (74%)
18:14:02:WU00:FS01:0x22:Completed 1500000 out of 2000000 steps (75%)
18:14:44:WU00:FS01:0x22:Completed 1520000 out of 2000000 steps (76%)
18:15:24:WU00:FS01:0x22:Completed 1540000 out of 2000000 steps (77%)
18:16:05:WU00:FS01:0x22:Completed 1560000 out of 2000000 steps (78%)
18:16:45:WU00:FS01:0x22:Completed 1580000 out of 2000000 steps (79%)
18:17:27:WU00:FS01:0x22:Completed 1600000 out of 2000000 steps (80%)
18:18:08:WU00:FS01:0x22:Completed 1620000 out of 2000000 steps (81%)
18:18:49:WU00:FS01:0x22:Completed 1640000 out of 2000000 steps (82%)
18:19:33:WU00:FS01:0x22:Completed 1660000 out of 2000000 steps (83%)
18:20:15:WU00:FS01:0x22:Completed 1680000 out of 2000000 steps (84%)
18:20:57:WU00:FS01:0x22:Completed 1700000 out of 2000000 steps (85%)
18:21:40:WU00:FS01:0x22:Completed 1720000 out of 2000000 steps (86%)
18:22:22:WU00:FS01:0x22:Completed 1740000 out of 2000000 steps (87%)
18:23:04:WU00:FS01:0x22:Completed 1760000 out of 2000000 steps (88%)
18:23:46:WU00:FS01:0x22:Completed 1780000 out of 2000000 steps (89%)
18:24:28:WU00:FS01:0x22:Completed 1800000 out of 2000000 steps (90%)
18:25:11:WU00:FS01:0x22:Completed 1820000 out of 2000000 steps (91%)
18:25:53:WU00:FS01:0x22:Completed 1840000 out of 2000000 steps (92%)
18:26:36:WU00:FS01:0x22:Completed 1860000 out of 2000000 steps (93%)
18:27:19:WU00:FS01:0x22:Completed 1880000 out of 2000000 steps (94%)
18:28:01:WU00:FS01:0x22:Completed 1900000 out of 2000000 steps (95%)
18:28:44:WU00:FS01:0x22:Completed 1920000 out of 2000000 steps (96%)
18:29:26:WU00:FS01:0x22:Completed 1940000 out of 2000000 steps (97%)
18:30:09:WU00:FS01:0x22:Completed 1960000 out of 2000000 steps (98%)
18:30:52:WU00:FS01:0x22:Completed 1980000 out of 2000000 steps (99%)
18:31:35:WU00:FS01:0x22:Completed 2000000 out of 2000000 steps (100%)
18:31:35:WU00:FS01:0x22:Average performance: 40.5634 ns/day
18:31:38:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
18:31:38:WU00:FS01:0x22:Saving result file checkpointState.xml
18:31:39:WU00:FS01:0x22:Saving result file positions.xtc
18:31:39:WU00:FS01:0x22:Saving result file science.log
18:31:39:WU00:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
18:31:39:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
18:31:39:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:14905 run:273 clone:6 gen:20 core:0x22 unit:0x0000001f81d59d695f4ec9dc704c4ec8
18:31:39:WU00:FS01:Uploading 10.54MiB to 129.213.157.105
18:31:39:WU00:FS01:Connecting to 129.213.157.105:8080
18:31:45:WU00:FS01:Upload 21.95%
18:31:51:WU00:FS01:Upload 48.05%
18:31:57:WU00:FS01:Upload 74.74%
18:32:03:WU00:FS01:Upload complete
18:32:03:WU00:FS01:Server responded WORK_ACK (400)
18:32:03:WU00:FS01:Final credit estimate, 186713.00 points
18:32:03:WU00:FS01:Cleaning up
bunkermagnus
foldy wrote:For performance testing you could run 2 fah work units concurrently on the RTX 3080 - that should fill those shaders
Are there any instructions on how to achieve this somewhere?
