Very low download speed
Re: Very low download speed
Same issue for me, but even better:
at 99,X percent it stops and doesn't finish.
Is there any possibility to install the new Core_22 manually?
With a browser I can perfectly download it from
So there is no firewall etc blocking it. CPU Core Downloads work (also slow, but they finish and the core gets extracted)
http://cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah. Re: Very low download speed
Downloading the FAHCore manually won't help. That is not the issue. That should happen automatically if needed, once the WU arrives.
Your log shows a new WU is downloading from 140.163.4.241
