WU's Not Completing
FireFox-89
Hardware configuration: Luna - Active
AMD Ryzen 7 3700X @ stock | Noctua NH-U9s
Gigabyte B550 Gaming X V2 Revision 1.3 | BIOS version FG
Corsair Vengeance LPX 2x16GB DDR4-3600 | Timings 18-22-22-42
ASUS GeForce RTX 3060 Ti Strix OC 8GB
SeaSonic M12II 850w 80+ Bronze PSU
Terra - Active
AMD Ryzen 7 2700X | Corsair H100i V2
ASRock B450M/ac R2.0 | BIOS version p10.43
G.Skill Trident RGB 2x8GB DDR4-2800 | Timings 15-15-15-36
Asus GeForce GTX 1070 Ti Strix OC 8GB
OCZ Technology ZS Series 550w 80+ Bronze PSU
Anubis - Active
Intel Xeon E5-2695 V4 @ 0.980 Vcore | Cooler Master Hyper 212
Gigabyte X99-SOC Champion | BIOS version F23c
Corsair Vengeance LPX 4x8GB @ 2400 | Timings 20-18-18-40 (Needs Sorting)
Sapphire Radeon RX 580 Nitro+ 4GB
Sapphire Radeon RX 570 Pulse 4GB
SeaSonic Prime Platinum 750w 80+ Platinum PSU
All machines running F@H v8.5.5
WU's Not Completing
Post by FireFox-89 »
Afternoon people,
I've had this issue for a few days now but with work I didn't have the enthusiasm to find out why but most of the WU's my RX 590 gets don't complete, sometimes I get the ''Bad Work Unit'' error or nothing at all which what just happened. Sometimes I get as high as 80% complete and sometimes barely a few percent.
Luna is running driver version 20.7.2 which is a BETA but I've had the issues with version 20.4.2 WHQL as well.
15:48:30:WU00:FS01:0x22:*********************** Log Started 2020-07-18T15:48:29Z ***********************
15:48:30:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
15:48:30:WU00:FS01:0x22:       Core: Core22
15:48:30:WU00:FS01:0x22:       Type: 0x22
15:48:30:WU00:FS01:0x22:    Version: 0.0.11
15:48:30:WU00:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:48:30:WU00:FS01:0x22:  Copyright: 2020 foldingathome.org
15:48:30:WU00:FS01:0x22:   Homepage: https://foldingathome.org/
15:48:30:WU00:FS01:0x22:       Date: Jun 26 2020
15:48:30:WU00:FS01:0x22:       Time: 19:49:16
15:48:30:WU00:FS01:0x22:   Revision: 22010df8a4db48db1b35d33e666b64d8ce48689d
15:48:30:WU00:FS01:0x22:     Branch: core22-0.0.11
15:48:30:WU00:FS01:0x22:   Compiler: Visual C++ 2015
15:48:30:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
15:48:30:WU00:FS01:0x22:   Platform: win32 10
15:48:30:WU00:FS01:0x22:       Bits: 64
15:48:30:WU00:FS01:0x22:       Mode: Release
15:48:30:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
15:48:30:WU00:FS01:0x22:             <peastman@stanford.edu>
15:48:30:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 9996 -checkpoint 15
15:48:30:WU00:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
15:48:30:WU00:FS01:0x22:************************************ libFAH ************************************
15:48:30:WU00:FS01:0x22:       Time: 19:47:12
15:48:30:WU00:FS01:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
15:48:30:WU00:FS01:0x22:     Branch: HEAD
15:48:30:WU00:FS01:0x22:************************************ CBang *************************************
15:48:30:WU00:FS01:0x22:       Time: 19:46:11
15:48:30:WU00:FS01:0x22:   Revision: f8529962055b0e7bde23e429f5072ff758089dee
15:48:30:WU00:FS01:0x22:     Branch: master
15:48:30:WU00:FS01:0x22:************************************ System ************************************
15:48:30:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
15:48:30:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
15:48:30:WU00:FS01:0x22:       CPUs: 8
15:48:30:WU00:FS01:0x22:     Memory: 15.96GiB
15:48:30:WU00:FS01:0x22:Free Memory: 10.27GiB
15:48:30:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
15:48:30:WU00:FS01:0x22: OS Version: 6.2
15:48:30:WU00:FS01:0x22:Has Battery: false
15:48:30:WU00:FS01:0x22: On Battery: false
15:48:30:WU00:FS01:0x22: UTC Offset: 1
15:48:30:WU00:FS01:0x22:        PID: 11760
15:48:30:WU00:FS01:0x22:        CWD: C:\Users\Luna\AppData\Roaming\FAHClient\work
15:48:30:WU00:FS01:0x22:********************************************************************************
15:48:30:WU00:FS01:0x22:Project: 11760 (Run 0, Clone 2579, Gen 4)
15:48:30:WU00:FS01:0x22:Unit: 0x0000000c031532b95f10fbc67814363f
15:48:30:WU00:FS01:0x22:Digital signatures verified
15:48:30:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
15:48:30:WU00:FS01:0x22:Version 0.0.11
15:48:30:WU00:FS01:0x22:  Checkpoint write interval: 100000 steps (5%) [20 total]
15:48:30:WU00:FS01:0x22:  JSON viewer frame write interval: 20000 steps (1%) [100 total]
15:48:30:WU00:FS01:0x22:  XTC frame write interval: 50000 steps (2.5%) [40 total]
15:48:30:WU00:FS01:0x22:  Global context and integrator variables write interval: disabled
15:48:50:WU00:FS01:0x22:Completed 0 out of 2000000 steps (0%)
15:49:34:WU01:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
15:50:59:WU00:FS01:0x22:Completed 20000 out of 2000000 steps (1%)
15:51:50:WU01:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
15:53:05:WU00:FS01:0x22:Completed 40000 out of 2000000 steps (2%)
15:54:08:WU01:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
15:55:16:WU00:FS01:0x22:An exception occurred at step 59988: Particle coordinate is nan
15:55:16:WU00:FS01:0x22:Max number of attempts to resume from last checkpoint (2) reached. Aborting.
15:55:16:WU00:FS01:0x22:ERROR:114: Max number of attempts to resume from last checkpoint reached.
15:55:16:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
15:55:16:WU00:FS01:0x22:Saving result file positions.xtc
15:55:16:WU00:FS01:0x22:Saving result file science.log
15:55:16:WU00:FS01:0x22:Saving result file state.xml
15:55:18:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
15:55:18:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
15:55:18:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:11760 run:0 clone:2579 gen:4 core:0x22 unit:0x0000000c031532b95f10fbc67814363f
15:55:18:WU00:FS01:Uploading 4.98MiB to 3.21.50.185
15:55:18:WU00:FS01:Connecting to 3.21.50.185:8080
15:55:19:WU02:FS01:Connecting to assign1.foldingathome.org:80
15:55:19:WARNING:WU02:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
15:55:19:WU02:FS01:Connecting to assign2.foldingathome.org:80
15:55:19:WARNING:WU02:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
15:55:19:WU02:FS01:Connecting to assign3.foldingathome.org:80
15:55:19:WARNING:WU02:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
15:55:19:WU02:FS01:Connecting to assign4.foldingathome.org:80
15:55:20:WARNING:WU02:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
15:55:20:ERROR:WU02:FS01:Exception: Could not get an assignment
15:55:20:WU02:FS01:Connecting to assign1.foldingathome.org:80
15:55:20:WARNING:WU02:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
15:55:20:WU02:FS01:Connecting to assign2.foldingathome.org:80
15:55:20:WARNING:WU02:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
15:55:20:WU02:FS01:Connecting to assign3.foldingathome.org:80
15:55:21:WU02:FS01:Assigned to work server 3.21.50.185
15:55:21:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 3.21.50.185
15:55:21:WU02:FS01:Connecting to 3.21.50.185:8080
15:55:22:WU02:FS01:Downloading 6.18MiB
15:55:24:WU00:FS01:Upload 52.72%
15:55:27:WU02:FS01:Download complete
15:55:27:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11760 run:0 clone:5685 gen:0 core:0x22 unit:0x00000001031532b95f10fbc5e9cca389
15:55:27:WU02:FS01:Starting
15:55:27:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Luna\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 9536 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
15:55:27:WU02:FS01:Started FahCore on PID 8468
15:55:27:WU02:FS01:Core PID:9644
15:55:27:WU02:FS01:FahCore 0x22 started
15:55:27:WU02:FS01:0x22:*********************** Log Started 2020-07-18T15:55:27Z ***********************
15:55:27:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
15:55:27:WU02:FS01:0x22:       Core: Core22
15:55:27:WU02:FS01:0x22:       Type: 0x22
15:55:27:WU02:FS01:0x22:    Version: 0.0.11
15:55:27:WU02:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:55:27:WU02:FS01:0x22:  Copyright: 2020 foldingathome.org
15:55:27:WU02:FS01:0x22:   Homepage: https://foldingathome.org/
15:55:27:WU02:FS01:0x22:       Date: Jun 26 2020
15:55:27:WU02:FS01:0x22:       Time: 19:49:16
15:55:27:WU02:FS01:0x22:   Revision: 22010df8a4db48db1b35d33e666b64d8ce48689d
15:55:27:WU02:FS01:0x22:     Branch: core22-0.0.11
15:55:27:WU02:FS01:0x22:   Compiler: Visual C++ 2015
15:55:27:WU02:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
15:55:27:WU02:FS01:0x22:   Platform: win32 10
15:55:27:WU02:FS01:0x22:       Bits: 64
15:55:27:WU02:FS01:0x22:       Mode: Release
15:55:27:WU02:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
15:55:27:WU02:FS01:0x22:             <peastman@stanford.edu>
15:55:27:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 706 -lifeline 8468 -checkpoint 15
15:55:27:WU02:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
15:55:27:WU02:FS01:0x22:************************************ libFAH ************************************
15:55:27:WU02:FS01:0x22:       Time: 19:47:12
15:55:27:WU02:FS01:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
15:55:27:WU02:FS01:0x22:     Branch: HEAD
15:55:27:WU02:FS01:0x22:************************************ CBang *************************************
15:55:27:WU02:FS01:0x22:       Time: 19:46:11
15:55:27:WU02:FS01:0x22:   Revision: f8529962055b0e7bde23e429f5072ff758089dee
15:55:27:WU02:FS01:0x22:     Branch: master
15:55:27:WU02:FS01:0x22:************************************ System ************************************
15:55:27:WU02:FS01:0x22:        CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
15:55:27:WU02:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
15:55:27:WU02:FS01:0x22:       CPUs: 8
15:55:27:WU02:FS01:0x22:     Memory: 15.96GiB
15:55:27:WU02:FS01:0x22:Free Memory: 10.60GiB
15:55:27:WU02:FS01:0x22:    Threads: WINDOWS_THREADS
15:55:27:WU02:FS01:0x22: OS Version: 6.2
15:55:27:WU02:FS01:0x22:Has Battery: false
15:55:27:WU02:FS01:0x22: On Battery: false
15:55:27:WU02:FS01:0x22: UTC Offset: 1
15:55:27:WU02:FS01:0x22:        PID: 9644
15:55:27:WU02:FS01:0x22:        CWD: C:\Users\Luna\AppData\Roaming\FAHClient\work
15:55:27:WU02:FS01:0x22:********************************************************************************
15:55:27:WU02:FS01:0x22:Project: 11760 (Run 0, Clone 5685, Gen 0)
15:55:27:WU02:FS01:0x22:Unit: 0x00000001031532b95f10fbc5e9cca389
15:55:27:WU02:FS01:0x22:Reading tar file core.xml
15:55:27:WU02:FS01:0x22:Reading tar file integrator.xml
15:55:27:WU02:FS01:0x22:Reading tar file state.xml
15:55:27:WU02:FS01:0x22:Reading tar file system.xml
15:55:28:WU02:FS01:0x22:Digital signatures verified
15:55:28:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
15:55:28:WU02:FS01:0x22:Version 0.0.11
15:55:28:WU02:FS01:0x22:  Checkpoint write interval: 100000 steps (5%) [20 total]
15:55:28:WU02:FS01:0x22:  JSON viewer frame write interval: 20000 steps (1%) [100 total]
15:55:28:WU02:FS01:0x22:  XTC frame write interval: 50000 steps (2.5%) [40 total]
15:55:28:WU02:FS01:0x22:  Global context and integrator variables write interval: disabled
15:55:28:WU00:FS01:Upload complete
15:55:29:WU00:FS01:Server responded WORK_ACK (400)
15:55:29:WU00:FS01:Cleaning up
15:55:47:WU02:FS01:0x22:Completed 0 out of 2000000 steps (0%)
Do you even fold bro?
Re: WU's Not Completing
As always, the first 200 lines of your log show how your PC is configured and are essential to informed help.
viewtopic.php?f=24&t=26036
Second, is the RX 590 overclocked, factory or otherwise? If overclocked beyond factory specs at least reduce to those if not to reference values.
FireFox-89
Terra - Active
Anubis - Active
Joe_H wrote:Second, is the RX 590 overclocked, factory or otherwise? If overclocked beyond factory specs at least reduce to those if not to reference values.
No, completely stock also regarding the first 200 lines I thought I had done that. I'll have to wait for it to do it again now since I closed the program.
FireFox-89 wrote:I'll have to wait for it to do it again now since I closed the program.
See my signature block below. The files are on your disk
