I noticed some bad work units while checking the log, what they have in common is the fact that they belong to projects numbers starting with 144 and have this message: Called setPositions() on a Context with the wrong number of positions
The hardware is a Gigabyte GTX 1050 TI and it's power limited to 72.9% (minimum possible for this model) the fans run at 40% (higher than the default fan curve) and the temperature is 48-50 degrees Celsius.
Here is the log, I tried to select all the needed parts:
04:20:29:WU01:FS01:Connecting to assign1.foldingathome.org:80
04:20:29:WU01:FS01:Assigned to work server 3.133.76.19
04:20:29:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GP107 [GeForce GTX 1050
Ti] 2138 from 3.133.76.19
04:20:29:WU01:FS01:Connecting to 3.133.76.19:8080
04:20:41:WU01:FS01:Downloading 19.85MiB
04:20:47:WU01:FS01:Download 58.88%
04:20:50:WU01:FS01:Download complete
04:20:50:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14448 run:0
clone:863 gen:66 core:0x22 unit:0x0000007303854c135ea7b88f6c18f7bc
04:21:15:WU00:FS00:0xa7:Completed 40000 out of 250000 steps (16%)
04:22:25:WU00:FS00:0xa7:Completed 42500 out of 250000 steps (17%)
04:23:36:WU00:FS00:0xa7:Completed 45000 out of 250000 steps (18%)
04:24:18:WU02:FS01:0x22:Completed 2000000 out of 2000000 steps (100%)
04:24:18:WU02:FS01:0x22:Average performance: 15.0654 ns/day
04:24:21:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
04:24:21:WU02:FS01:0x22:Saving result file checkpointState.xml
04:24:22:WU02:FS01:0x22:Saving result file positions.xtc
04:24:24:WU02:FS01:0x22:Saving result file science.log
04:24:25:WU02:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
04:24:25:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
04:24:25:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:11742 run:0
clone:9368 gen:158 core:0x22 unit:0x000000fc8ca304f15e6bc4d68dc46be8
04:24:25:WU02:FS01:Uploading 12.57MiB to 140.163.4.241
04:24:25:WU01:FS01:Starting
04:24:25:WU02:FS01:Connecting to 140.163.4.241:8080
04:24:25:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:
\Users\Test\AppData\Roaming\FAHClient
\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -
version 706 -lifeline 7876 -checkpoint 30 -gpu-vendor nvidia -opencl-platform 0 -opencl-device
0 -cuda-device 0 -gpu 0
04:24:25:WU01:FS01:Started FahCore on PID 4980
04:24:25:WU01:FS01:Core PID:7564
04:24:25:WU01:FS01:FahCore 0x22 started
04:24:26:WU01:FS01:0x22:*********************** Log Started 2020-07-01T04:24:25Z
04:24:26:WU01:FS01:0x22:*************************** Core22 Folding@home Core
04:24:26:WU01:FS01:0x22: Core: Core22
04:24:26:WU01:FS01:0x22: Type: 0x22
04:24:26:WU01:FS01:0x22: Version: 0.0.10
04:24:26:WU01:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:24:26:WU01:FS01:0x22: Copyright: 2020 foldingathome.org
04:24:26:WU01:FS01:0x22: Homepage: https://foldingathome.org/
04:24:26:WU01:FS01:0x22: Date: Jun 16 2020
04:24:26:WU01:FS01:0x22: Time: 14:33:22
04:24:26:WU01:FS01:0x22: Revision: 147051aad40bcbec7d4b25105bbedfab425f1dc2
04:24:26:WU01:FS01:0x22: Branch: core22-0.0.10
04:24:26:WU01:FS01:0x22: Compiler: Visual C++ 2015
04:24:26:WU01:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew
/MT
04:24:26:WU01:FS01:0x22: Platform: win32 10
04:24:26:WU01:FS01:0x22: Bits: 64
04:24:26:WU01:FS01:0x22: Mode: Release
04:24:26:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter
Eastman
04:24:26:WU01:FS01:0x22: <peastman@stanford.edu>
04:24:26:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 4980 -
checkpoint 30
04:24:26:WU01:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -
cuda-device
04:24:26:WU01:FS01:0x22: 0 -gpu 0
04:24:26:WU01:FS01:0x22:************************************ libFAH
04:24:26:WU01:FS01:0x22: Date: Jun 15 2020
04:24:26:WU01:FS01:0x22: Time: 18:05:04
04:24:26:WU01:FS01:0x22: Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
04:24:26:WU01:FS01:0x22: Branch: HEAD
/MT
04:24:26:WU01:FS01:0x22:************************************ CBang
04:24:26:WU01:FS01:0x22: Time: 14:31:33
04:24:26:WU01:FS01:0x22: Revision: 75fcee0b8e713cb47f5191a3689d5f4f07244c7f
/MT
04:24:26:WU01:FS01:0x22:************************************ System
04:24:26:WU01:FS01:0x22: CPU: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
04:24:26:WU01:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
04:24:26:WU01:FS01:0x22: CPUs: 12
04:24:26:WU01:FS01:0x22: Memory: 7.92GiB
04:24:26:WU01:FS01:0x22:Free Memory: 5.94GiB
04:24:26:WU01:FS01:0x22: Threads: WINDOWS_THREADS
04:24:26:WU01:FS01:0x22: OS Version: 6.2
04:24:26:WU01:FS01:0x22:Has Battery: false
04:24:26:WU01:FS01:0x22: On Battery: false
04:24:26:WU01:FS01:0x22: UTC Offset: 3
04:24:26:WU01:FS01:0x22: PID: 7564
04:24:26:WU01:FS01:0x22: CWD: C:\Users\Test\AppData\Roaming\FAHClient\work
04:24:26:WU01:FS01:0x22:**********************************************************************
04:24:26:WU01:FS01:0x22:Project: 14448 (Run 0, Clone 863, Gen 66)
04:24:26:WU01:FS01:0x22:Unit: 0x0000007303854c135ea7b88f6c18f7bc
04:24:26:WU01:FS01:0x22:Reading tar file core.xml
04:24:26:WU01:FS01:0x22:Reading tar file integrator.xml
04:24:26:WU01:FS01:0x22:Reading tar file state.xml
04:24:27:WU01:FS01:0x22:Reading tar file system.xml
04:24:29:WU01:FS01:0x22:Digital signatures verified
04:24:29:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
04:24:29:WU01:FS01:0x22:Version 0.0.10
04:24:29:WU01:FS01:0x22: Checkpoint write interval: 100000 steps (5%) [20 total]
04:24:29:WU01:FS01:0x22: JSON viewer frame write interval: 20000 steps (1%) [100 total]
04:24:29:WU01:FS01:0x22: XTC frame write interval: 20000 steps (1%) [100 total]
04:24:29:WU01:FS01:0x22: Global context and integrator variables write interval: disabled
04:24:31:WU02:FS01:Upload 20.38%
04:24:37:WU02:FS01:Upload 44.73%
04:24:43:WU02:FS01:Upload 66.60%
04:24:45:WU00:FS00:0xa7:Completed 47500 out of 250000 steps (19%)
04:24:49:WU02:FS01:Upload 90.46%
04:24:52:WU01:FS01:0x22:ERROR:exception: Called setPositions() on a Context with the wrong number of positions
04:24:52:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
04:24:52:WU01:FS01:0x22:Saving result file science.log
04:24:52:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
04:24:53:WU02:FS01:Upload complete
04:24:53:WU02:FS01:Server responded WORK_ACK (400)
04:24:53:WU02:FS01:Final credit estimate, 44813.00 points
04:24:53:WU02:FS01:Cleaning up
04:24:53:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
04:24:53:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:14448 run:0
04:24:53:WU01:FS01:Uploading 2.45KiB to 3.133.76.19
04:24:53:WU01:FS01:Connecting to 3.133.76.19:8080
04:24:53:WU02:FS01:Connecting to assign1.foldingathome.org:80
04:24:53:WU01:FS01:Upload complete
04:24:53:WU01:FS01:Server responded WORK_ACK (400)
04:24:53:WU01:FS01:Cleaning up
04:24:54:WU02:FS01:Assigned to work server 206.223.170.146
04:24:54:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GP107 [GeForce GTX 1050
Ti] 2138 from 206.223.170.146
04:24:54:WU02:FS01:Connecting to 206.223.170.146:8080
04:24:54:ERROR:WU02:FS01:Exception: Server did not assign work unit
04:24:54:WU02:FS01:Connecting to assign1.foldingathome.org:80
04:24:55:WU02:FS01:Assigned to work server 3.133.76.19
04:24:55:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GP107 [GeForce GTX 1050
04:24:55:WU02:FS01:Connecting to 3.133.76.19:8080
04:25:05:WU02:FS01:Downloading 17.43MiB
04:25:11:WU02:FS01:Download 68.84%
04:25:13:WU02:FS01:Download complete
04:25:13:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:14469 run:0
clone:360 gen:51 core:0x22 unit:0x0000005103854c135eb9852f854699fe
04:25:13:WU02:FS01:Starting
04:25:13:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:
\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -
04:25:13:WU02:FS01:Started FahCore on PID 7896
04:25:13:WU02:FS01:Core PID:2452
04:25:13:WU02:FS01:FahCore 0x22 started
04:25:14:WU02:FS01:0x22:*********************** Log Started 2020-07-01T04:25:13Z
04:25:14:WU02:FS01:0x22:*************************** Core22 Folding@home Core
04:25:14:WU02:FS01:0x22: Core: Core22
04:25:14:WU02:FS01:0x22: Type: 0x22
04:25:14:WU02:FS01:0x22: Version: 0.0.10
04:25:14:WU02:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:25:14:WU02:FS01:0x22: Copyright: 2020 foldingathome.org
04:25:14:WU02:FS01:0x22: Homepage: https://foldingathome.org/
04:25:14:WU02:FS01:0x22: Date: Jun 16 2020
04:25:14:WU02:FS01:0x22: Time: 14:33:22
04:25:14:WU02:FS01:0x22: Revision: 147051aad40bcbec7d4b25105bbedfab425f1dc2
04:25:14:WU02:FS01:0x22: Branch: core22-0.0.10
04:25:14:WU02:FS01:0x22: Compiler: Visual C++ 2015
04:25:14:WU02:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew
/MT
04:25:14:WU02:FS01:0x22: Platform: win32 10
04:25:14:WU02:FS01:0x22: Bits: 64
04:25:14:WU02:FS01:0x22: Mode: Release
04:25:14:WU02:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter
Eastman
04:25:14:WU02:FS01:0x22: <peastman@stanford.edu>
04:25:14:WU02:FS01:0x22: Args: -dir 02 -suffix 01 -version 706 -lifeline 7896 -
checkpoint 30
04:25:14:WU02:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -
cuda-device
04:25:14:WU02:FS01:0x22: 0 -gpu 0
04:25:14:WU02:FS01:0x22:************************************ libFAH
04:25:14:WU02:FS01:0x22: Date: Jun 15 2020
04:25:14:WU02:FS01:0x22: Time: 18:05:04
04:25:14:WU02:FS01:0x22: Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
04:25:14:WU02:FS01:0x22: Branch: HEAD
/MT
04:25:14:WU02:FS01:0x22:************************************ CBang
04:25:14:WU02:FS01:0x22: Time: 14:31:33
04:25:14:WU02:FS01:0x22: Revision: 75fcee0b8e713cb47f5191a3689d5f4f07244c7f
/MT
04:25:14:WU02:FS01:0x22:************************************ System
04:25:14:WU02:FS01:0x22: CPU: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
04:25:14:WU02:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
04:25:14:WU02:FS01:0x22: CPUs: 12
04:25:14:WU02:FS01:0x22: Memory: 7.92GiB
04:25:14:WU02:FS01:0x22:Free Memory: 5.96GiB
04:25:14:WU02:FS01:0x22: Threads: WINDOWS_THREADS
04:25:14:WU02:FS01:0x22: OS Version: 6.2
04:25:14:WU02:FS01:0x22:Has Battery: false
04:25:14:WU02:FS01:0x22: On Battery: false
04:25:14:WU02:FS01:0x22: UTC Offset: 3
04:25:14:WU02:FS01:0x22: PID: 2452
04:25:14:WU02:FS01:0x22: CWD: C:\Users\Test\AppData\Roaming\FAHClient\work
04:25:14:WU02:FS01:0x22:**********************************************************************
04:25:14:WU02:FS01:0x22:Project: 14469 (Run 0, Clone 360, Gen 51)
04:25:14:WU02:FS01:0x22:Unit: 0x0000005103854c135eb9852f854699fe
04:25:14:WU02:FS01:0x22:Reading tar file core.xml
04:25:14:WU02:FS01:0x22:Reading tar file integrator.xml
04:25:14:WU02:FS01:0x22:Reading tar file state.xml
04:25:15:WU02:FS01:0x22:Reading tar file system.xml
04:25:16:WU02:FS01:0x22:Digital signatures verified
04:25:16:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
04:25:16:WU02:FS01:0x22:Version 0.0.10
04:25:17:WU02:FS01:0x22: Checkpoint write interval: 100000 steps (5%) [20 total]
04:25:17:WU02:FS01:0x22: JSON viewer frame write interval: 20000 steps (1%) [100 total]
04:25:17:WU02:FS01:0x22: XTC frame write interval: 20000 steps (1%) [100 total]
04:25:17:WU02:FS01:0x22: Global context and integrator variables write interval: disabled
04:25:36:WU02:FS01:0x22:ERROR:exception: Called setPositions() on a Context with the wrong number of positions
04:25:36:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
04:25:36:WU02:FS01:0x22:Saving result file science.log
04:25:36:WU02:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
04:25:36:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
04:25:36:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:14469 run:0
04:25:36:WU02:FS01:Uploading 2.45KiB to 3.133.76.19
04:25:36:WU02:FS01:Connecting to 3.133.76.19:8080
04:25:37:WU01:FS01:Connecting to assign1.foldingathome.org:80
04:25:37:WU02:FS01:Upload complete
04:25:37:WU02:FS01:Server responded WORK_ACK (400)
04:25:37:WU02:FS01:Cleaning up
04:25:37:WU01:FS01:Assigned to work server 3.133.76.19
04:25:37:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP107 [GeForce GTX 1050
04:25:37:WU01:FS01:Connecting to 3.133.76.19:8080
04:25:45:WU01:FS01:Downloading 17.90MiB
04:25:51:WU01:FS01:Download 67.39%
04:25:54:WU00:FS00:0xa7:Completed 50000 out of 250000 steps (20%)
04:25:55:WU01:FS01:Download complete
04:25:56:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14466 run:0
clone:791 gen:50 core:0x22 unit:0x0000004d03854c135eb9853052c4201e
04:25:56:WU01:FS01:Starting
04:25:56:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:
04:25:56:WU01:FS01:Started FahCore on PID 8276
04:25:56:WU01:FS01:Core PID:8352
04:25:56:WU01:FS01:FahCore 0x22 started
04:25:56:WU01:FS01:0x22:*********************** Log Started 2020-07-01T04:25:56Z
04:25:56:WU01:FS01:0x22:*************************** Core22 Folding@home Core
04:25:56:WU01:FS01:0x22: Core: Core22
04:25:56:WU01:FS01:0x22: Type: 0x22
04:25:56:WU01:FS01:0x22: Version: 0.0.10
04:25:56:WU01:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:25:56:WU01:FS01:0x22: Copyright: 2020 foldingathome.org
04:25:56:WU01:FS01:0x22: Homepage: https://foldingathome.org/
04:25:56:WU01:FS01:0x22: Date: Jun 16 2020
04:25:56:WU01:FS01:0x22: Time: 14:33:22
04:25:56:WU01:FS01:0x22: Revision: 147051aad40bcbec7d4b25105bbedfab425f1dc2
04:25:56:WU01:FS01:0x22: Branch: core22-0.0.10
04:25:56:WU01:FS01:0x22: Compiler: Visual C++ 2015
04:25:56:WU01:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew
/MT
04:25:56:WU01:FS01:0x22: Platform: win32 10
04:25:56:WU01:FS01:0x22: Bits: 64
04:25:56:WU01:FS01:0x22: Mode: Release
04:25:56:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter
Eastman
04:25:56:WU01:FS01:0x22: <peastman@stanford.edu>
04:25:56:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 8276 -
checkpoint 30
04:25:56:WU01:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -
cuda-device
04:25:56:WU01:FS01:0x22: 0 -gpu 0
04:25:56:WU01:FS01:0x22:************************************ libFAH
04:25:56:WU01:FS01:0x22: Date: Jun 15 2020
04:25:56:WU01:FS01:0x22: Time: 18:05:04
04:25:56:WU01:FS01:0x22: Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
04:25:56:WU01:FS01:0x22: Branch: HEAD
/MT
04:25:56:WU01:FS01:0x22:************************************ CBang
04:25:56:WU01:FS01:0x22: Time: 14:31:33
04:25:56:WU01:FS01:0x22: Revision: 75fcee0b8e713cb47f5191a3689d5f4f07244c7f
/MT
04:25:56:WU01:FS01:0x22:************************************ System
04:25:56:WU01:FS01:0x22: CPU: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
04:25:56:WU01:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
04:25:56:WU01:FS01:0x22: CPUs: 12
04:25:56:WU01:FS01:0x22: Memory: 7.92GiB
04:25:56:WU01:FS01:0x22:Free Memory: 5.95GiB
04:25:56:WU01:FS01:0x22: Threads: WINDOWS_THREADS
04:25:56:WU01:FS01:0x22: OS Version: 6.2
04:25:56:WU01:FS01:0x22:Has Battery: false
04:25:56:WU01:FS01:0x22: On Battery: false
04:25:56:WU01:FS01:0x22: UTC Offset: 3
04:25:56:WU01:FS01:0x22: PID: 8352
04:25:56:WU01:FS01:0x22: CWD: C:\Users\Test\AppData\Roaming\FAHClient\work
04:25:56:WU01:FS01:0x22:**********************************************************************
04:25:56:WU01:FS01:0x22:Project: 14466 (Run 0, Clone 791, Gen 50)
04:25:56:WU01:FS01:0x22:Unit: 0x0000004d03854c135eb9853052c4201e
04:25:56:WU01:FS01:0x22:Reading tar file core.xml
04:25:56:WU01:FS01:0x22:Reading tar file integrator.xml
04:25:56:WU01:FS01:0x22:Reading tar file state.xml
04:25:57:WU01:FS01:0x22:Reading tar file system.xml
04:25:59:WU01:FS01:0x22:Digital signatures verified
04:25:59:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
04:25:59:WU01:FS01:0x22:Version 0.0.10
04:25:59:WU01:FS01:0x22: Checkpoint write interval: 100000 steps (5%) [20 total]
04:25:59:WU01:FS01:0x22: JSON viewer frame write interval: 20000 steps (1%) [100 total]
04:25:59:WU01:FS01:0x22: XTC frame write interval: 20000 steps (1%) [100 total]
04:25:59:WU01:FS01:0x22: Global context and integrator variables write interval: disabled
04:26:19:WU01:FS01:0x22:ERROR:exception: Called setPositions() on a Context with the wrong number of positions
04:26:19:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
04:26:19:WU01:FS01:0x22:Saving result file science.log
04:26:19:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
04:26:20:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
04:26:20:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:14466 run:0
04:26:20:WU01:FS01:Uploading 2.45KiB to 3.133.76.19
04:26:20:WU01:FS01:Connecting to 3.133.76.19:8080
04:26:20:WU02:FS01:Connecting to assign1.foldingathome.org:80
04:26:20:WU01:FS01:Upload complete
04:26:20:WU01:FS01:Server responded WORK_ACK (400)
04:26:20:WU01:FS01:Cleaning up
04:26:21:WU02:FS01:Assigned to work server 3.133.76.19
04:26:21:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GP107 [GeForce GTX 1050
04:26:21:WU02:FS01:Connecting to 3.133.76.19:8080
04:26:29:WU02:FS01:Downloading 18.72MiB
04:26:35:WU02:FS01:Download 51.42%
04:26:40:WU02:FS01:Download complete
04:26:40:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:14456 run:0
clone:275 gen:50 core:0x22 unit:0x0000005403854c135eb39a2f4cadfca6
04:26:41:WU02:FS01:Starting
04:26:41:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:
04:26:41:WU02:FS01:Started FahCore on PID 6356
04:26:41:WU02:FS01:Core PID:2976
04:26:41:WU02:FS01:FahCore 0x22 started
04:26:41:WU02:FS01:0x22:*********************** Log Started 2020-07-01T04:26:41Z
04:26:41:WU02:FS01:0x22:*************************** Core22 Folding@home Core
04:26:41:WU02:FS01:0x22: Core: Core22
04:26:41:WU02:FS01:0x22: Type: 0x22
04:26:41:WU02:FS01:0x22: Version: 0.0.10
04:26:41:WU02:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:26:41:WU02:FS01:0x22: Copyright: 2020 foldingathome.org
04:26:41:WU02:FS01:0x22: Homepage: https://foldingathome.org/
04:26:41:WU02:FS01:0x22: Date: Jun 16 2020
04:26:41:WU02:FS01:0x22: Time: 14:33:22
04:26:41:WU02:FS01:0x22: Revision: 147051aad40bcbec7d4b25105bbedfab425f1dc2
04:26:41:WU02:FS01:0x22: Branch: core22-0.0.10
04:26:41:WU02:FS01:0x22: Compiler: Visual C++ 2015
04:26:41:WU02:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew
/MT
04:26:41:WU02:FS01:0x22: Platform: win32 10
04:26:41:WU02:FS01:0x22: Bits: 64
04:26:41:WU02:FS01:0x22: Mode: Release
04:26:41:WU02:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter
Eastman
04:26:41:WU02:FS01:0x22: <peastman@stanford.edu>
04:26:41:WU02:FS01:0x22: Args: -dir 02 -suffix 01 -version 706 -lifeline 6356 -
checkpoint 30
04:26:41:WU02:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -
cuda-device
04:26:41:WU02:FS01:0x22: 0 -gpu 0
04:26:41:WU02:FS01:0x22:************************************ libFAH
04:26:41:WU02:FS01:0x22: Date: Jun 15 2020
04:26:41:WU02:FS01:0x22: Time: 18:05:04
04:26:41:WU02:FS01:0x22: Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
04:26:41:WU02:FS01:0x22: Branch: HEAD
/MT
04:26:41:WU02:FS01:0x22:************************************ CBang
04:26:41:WU02:FS01:0x22: Time: 14:31:33
04:26:41:WU02:FS01:0x22: Revision: 75fcee0b8e713cb47f5191a3689d5f4f07244c7f
/MT
04:26:41:WU02:FS01:0x22:************************************ System
04:26:41:WU02:FS01:0x22: CPU: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
04:26:41:WU02:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
04:26:41:WU02:FS01:0x22: CPUs: 12
04:26:41:WU02:FS01:0x22: Memory: 7.92GiB
04:26:41:WU02:FS01:0x22:Free Memory: 5.97GiB
04:26:41:WU02:FS01:0x22: Threads: WINDOWS_THREADS
04:26:41:WU02:FS01:0x22: OS Version: 6.2
04:26:41:WU02:FS01:0x22:Has Battery: false
04:26:41:WU02:FS01:0x22: On Battery: false
04:26:41:WU02:FS01:0x22: UTC Offset: 3
04:26:41:WU02:FS01:0x22: PID: 2976
04:26:41:WU02:FS01:0x22: CWD: C:\Users\Test\AppData\Roaming\FAHClient\work
04:26:41:WU02:FS01:0x22:**********************************************************************
04:26:41:WU02:FS01:0x22:Project: 14456 (Run 0, Clone 275, Gen 50)
04:26:41:WU02:FS01:0x22:Unit: 0x0000005403854c135eb39a2f4cadfca6
04:26:41:WU02:FS01:0x22:Reading tar file core.xml
04:26:41:WU02:FS01:0x22:Reading tar file integrator.xml
04:26:41:WU02:FS01:0x22:Reading tar file state.xml
04:26:43:WU02:FS01:0x22:Reading tar file system.xml
04:26:44:WU02:FS01:0x22:Digital signatures verified
04:26:44:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
04:26:44:WU02:FS01:0x22:Version 0.0.10
04:26:44:WU02:FS01:0x22: Checkpoint write interval: 100000 steps (5%) [20 total]
04:26:44:WU02:FS01:0x22: JSON viewer frame write interval: 20000 steps (1%) [100 total]
04:26:44:WU02:FS01:0x22: XTC frame write interval: 20000 steps (1%) [100 total]
04:26:44:WU02:FS01:0x22: Global context and integrator variables write interval: disabled
04:27:03:WU00:FS00:0xa7:Completed 52500 out of 250000 steps (21%)
04:27:05:WU02:FS01:0x22:ERROR:exception: Called setPositions() on a Context with the wrong number of positions
04:27:05:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
04:27:05:WU02:FS01:0x22:Saving result file science.log
04:27:05:WU02:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
04:27:05:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
04:27:05:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:14456 run:0
04:27:05:WU02:FS01:Uploading 2.45KiB to 3.133.76.19
04:27:05:WU02:FS01:Connecting to 3.133.76.19:8080
04:27:06:WU01:FS01:Connecting to assign1.foldingathome.org:80
04:27:06:WU02:FS01:Upload complete
04:27:06:WU02:FS01:Server responded WORK_ACK (400)
04:27:06:WU02:FS01:Cleaning up
04:27:06:WU01:FS01:Assigned to work server 18.188.125.154
04:27:06:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP107 [GeForce GTX 1050
Ti] 2138 from 18.188.125.154
04:27:06:WU01:FS01:Connecting to 18.188.125.154:8080
04:27:10:WU01:FS01:Downloading 9.37MiB
04:27:15:WU01:FS01:Download complete
If you need more parts of the log or more details about the hardware just say so and I will provide them.
Thank you.
