FAH Stats Android App
WatsOnTV
Post by WatsOnTV »
Hi there fellow folders!
I've gone ahead and created an android app to check your folding stats. You can search different donors by their name or ID, teams by their name or ID and view information about a given project.
You can see your total points, rank, completed work units, etc.
I use stats directly from F@H, not from other sources so my stats update within 10 minutes, where other stats update within 3 hours. I'd love it if you could check it out! Link in the comments below.
If you have any questions, comments, suggestions please let me know and I will get back to you ASAP :D :D
WatsOnTV
Re: FAH Stats Android App
Post by WatsOnTV »
Ichbin3
Hardware configuration: MSI H81M, G3240, RTX 2080Ti_Rev-A@220W, Ubuntu 18.04
Post by Ichbin3 »
For what do you need this?
- read phone status and identity
WatsOnTV
Post by WatsOnTV »
Ichbin3 wrote:For what do you need this?
Hi! Thanks for asking. I use the app instance ID for my own analytics, to count how many requests are made by each person.
Ichbin3
Post by Ichbin3 »
Thanks for your answer.
Hm. And for what do you need this?
WatsOnTV
Post by WatsOnTV »
Ichbin3 wrote:Thanks for your answer.
I gather this information purely out of interest.
I just thought of a different way to implement this which does not require the access phone status and identity permission. I've put an update on the app store which should be live in a few hours.
Thanks for helping to improve this app!
