Hi all.
I've been running this software for a little bit now, and a new issue that I don't notice similar elsewhere, and I haven't seen before. I've downloaded work (Project 14251), my client tells me it's ready, and ETA til completion is 2 hours 18 minutes. 0.00% completed after much more than 24 hours, a couple resets and a good slap on the computer, no dice. No settings have changed on my end, so anyone have thoughts? Or is there a way I can return the work unit assuming the issue lies therein?
As for things I've already done, I've never selected "On Idle", priority is set to slightly higher, normally it runs with or without the screen doing stuff (blank screen saver, using computer, turn off monitor). GPU is working fine, perhaps running a little cooler than normal under load, and work has been performed since my last driver update...
Device Not Folding
Re: Device Not Folding
Can you post your FAH logfile?
Welcome to the F@H Forum dustball72,
If you require guidance for posting your log file, please view this topic: viewtopic.php?f=24&t=26036
dustball72
Unfortunately, the verbosity was higher than requested, but here's a rather long log file.
*********************** Log Started 2020-06-12T18:53:59Z ***********************
18:53:59:************************* Folding@home Client *************************
18:53:59: Website: https://foldingathome.org/
18:53:59: Copyright: (c) 2009-2018 foldingathome.org
18:53:59: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:53:59: Args:
18:53:59: Config: C:\********
18:53:59:******************************** Build ********************************
18:53:59: Version: 7.5.1
18:53:59: Date: May 11 2018
18:53:59: Time: 13:06:32
18:53:59: Repository: Git
18:53:59: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
18:53:59: Branch: master
18:53:59: Compiler: Visual C++ 2008
18:53:59: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:53:59: Platform: win32 10
18:53:59: Bits: 32
18:53:59: Mode: Release
18:53:59:******************************* System ********************************
18:53:59: CPU: AMD Ryzen 5 3600 6-Core Processor
18:53:59: CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
18:53:59: CPUs: 12
18:53:59: Memory: 15.95GiB
18:53:59: Free Memory: 12.66GiB
18:53:59: Threads: WINDOWS_THREADS
18:53:59: OS Version: 6.2
18:53:59: Has Battery: false
18:53:59: On Battery: false
18:53:59: UTC Offset: -4
18:53:59: PID: 8948
18:53:59: CWD: C:\********
18:53:59: OS: Windows 10 Enterprise
18:53:59: OS Arch: AMD64
18:53:59: GPUs: 1
18:53:59: GPU 0: Bus:7 Slot:0 Func:0 NVIDIA:7 TU106 [GeForce RTX 2060 Super]
18:53:59: CUDA Device 0: Platform:0 Device:0 Bus:7 Slot:0 Compute:7.5 Driver:11.0
18:53:59:OpenCL Device 0: Platform:0 Device:0 Bus:7 Slot:0 Compute:1.2 Driver:446.14
18:53:59: Win32 Service: false
18:53:59:***********************************************************************
18:53:59:<config>
18:53:59: <service-description v='Folding@home Client'/>
18:53:59: <service-restart v='true'/>
18:53:59: <service-restart-delay v='5000'/>
18:53:59:
18:53:59: <!-- Client Control -->
18:53:59: <client-threads v='6'/>
18:53:59: <cycle-rate v='4'/>
18:53:59: <cycles v='-1'/>
18:53:59: <data-directory v='.'/>
18:53:59: <disable-sleep-when-active v='true'/>
18:53:59: <exec-directory v='C:\Program Files (x86)\FAHClient'/>
18:53:59: <exit-when-done v='false'/>
18:53:59: <fold-anon v='false'/>
18:53:59: <open-web-control v='false'/>
18:53:59:
18:53:59: <!-- Configuration -->
18:53:59: <config-rotate v='true'/>
18:53:59: <config-rotate-dir v='configs'/>
18:53:59: <config-rotate-max v='16'/>
18:53:59:
18:53:59: <!-- Debugging -->
18:53:59: <assignment-servers>
18:53:59: assign1.foldingathome.org:8080 assign2.foldingathome.org:80
18:53:59: </assignment-servers>
18:53:59: <auth-as v='true'/>
18:53:59: <capture-directory v='capture'/>
18:53:59: <capture-on-error v='false'/>
18:53:59: <capture-packets v='false'/>
18:53:59: <capture-requests v='false'/>
18:53:59: <capture-responses v='false'/>
18:53:59: <capture-sockets v='false'/>
18:53:59: <core-exec v='FahCore_$type'/>
18:53:59: <core-wrapper-exec v='FAHCoreWrapper'/>
18:53:59: <debug-sockets v='false'/>
18:53:59: <exception-locations v='true'/>
18:53:59: <stack-traces v='false'/>
18:53:59:
18:53:59: <!-- Error Handling -->
18:53:59: <max-slot-errors v='10'/>
18:53:59: <max-unit-errors v='5'/>
18:53:59:
18:53:59: <!-- Folding Core -->
18:53:59: <checkpoint v='4'/>
18:53:59: <core-dir v='cores'/>
18:53:59: <core-priority v='low'/>
18:53:59: <cpu-affinity v='false'/>
18:53:59: <cpu-usage v='100'/>
18:53:59: <gpu-usage v='100'/>
18:53:59: <no-assembly v='false'/>
18:53:59:
18:53:59: <!-- Folding Slot Configuration -->
18:53:59: <cause v='ANY'/>
18:53:59: <client-subtype v='STDCLI'/>
18:53:59: <client-type v='normal'/>
18:53:59: <cpu-species v='X86_AMD'/>
18:53:59: <cpu-type v='AMD64'/>
18:53:59: <cpus v='-1'/>
18:53:59: <disable-viz v='false'/>
18:53:59: <gpu v='true'/>
18:53:59: <max-packet-size v='normal'/>
18:53:59: <os-species v='WIN_8'/>
18:53:59: <os-type v='WIN32'/>
18:53:59: <project-key v='0'/>
18:53:59: <smp v='true'/>
18:53:59:
18:53:59: <!-- GUI -->
18:53:59: <gui-enabled v='true'/>
18:53:59:
18:53:59: <!-- HTTP Server -->
18:53:59: <allow v='127.0.0.1'/>
18:53:59: <connection-timeout v='60'/>
18:53:59: <deny v='0/0'/>
18:53:59: <http-addresses v='0:7396'/>
18:53:59: <https-addresses v=''/>
18:53:59: <max-connect-time v='900'/>
18:53:59: <max-connections v='800'/>
18:53:59: <max-request-length v='52428800'/>
18:53:59: <min-connect-time v='300'/>
18:53:59:
18:53:59: <!-- Logging -->
18:53:59: <log v='log.txt'/>
18:53:59: <log-color v='false'/>
18:53:59: <log-crlf v='true'/>
18:53:59: <log-date v='false'/>
18:53:59: <log-date-periodically v='21600'/>
18:53:59: <log-domain v='false'/>
18:53:59: <log-header v='true'/>
18:53:59: <log-level v='true'/>
18:53:59: <log-no-info-header v='true'/>
18:53:59: <log-redirect v='false'/>
18:53:59: <log-rotate v='true'/>
18:53:59: <log-rotate-dir v='logs'/>
18:53:59: <log-rotate-max v='16'/>
18:53:59: <log-short-level v='false'/>
18:53:59: <log-simple-domains v='true'/>
18:53:59: <log-thread-id v='false'/>
18:53:59: <log-thread-prefix v='true'/>
18:53:59: <log-time v='true'/>
18:53:59: <log-to-screen v='true'/>
18:53:59: <log-truncate v='false'/>
18:53:59: <verbosity v='4'/>
18:53:59:
18:53:59: <!-- Network -->
18:53:59: <proxy v=':8080'/>
18:53:59: <proxy-enable v='false'/>
18:53:59: <proxy-pass v=''/>
18:53:59: <proxy-user v=''/>
18:53:59:
18:53:59: <!-- Process Control -->
18:53:59: <child v='false'/>
18:53:59: <daemon v='false'/>
18:53:59: <pid v='false'/>
18:53:59: <pid-file v='Folding@home Client.pid'/>
18:53:59: <respawn v='false'/>
18:53:59: <service v='false'/>
18:53:59:
18:53:59: <!-- Remote Command Server -->
18:53:59: <command-address v='0.0.0.0'/>
18:53:59: <command-allow-no-pass v='127.0.0.1'/>
18:53:59: <command-deny-no-pass v='0/0'/>
18:53:59: <command-enable v='true'/>
18:53:59: <command-port v='36330'/>
18:53:59:
18:53:59: <!-- Slot Control -->
18:53:59: <idle v='false'/>
18:53:59: <max-shutdown-wait v='60'/>
18:53:59: <pause-on-battery v='false'/>
18:53:59: <pause-on-start v='false'/>
18:53:59: <paused v='false'/>
18:53:59: <power v='FULL'/>
18:53:59:
18:53:59: <!-- User Information -->
18:53:59: <machine-id v='0'/>
18:53:59: <passkey v='********************************'/>
18:53:59: <team v='********'/>
18:53:59: <user v='********'/>
18:53:59:
18:53:59: <!-- Web Server -->
18:53:59: <web-allow v='127.0.0.1'/>
18:53:59: <web-deny v='0/0'/>
18:53:59: <web-enable v='true'/>
18:53:59:
18:53:59: <!-- Web Server Sessions -->
18:53:59: <session-cookie v='sid'/>
18:53:59: <session-lifetime v='86400'/>
18:53:59: <session-timeout v='3600'/>
18:53:59:
18:53:59: <!-- Work Unit Control -->
18:53:59: <dump-after-deadline v='true'/>
18:53:59: <max-queue v='16'/>
18:53:59: <max-units v='0'/>
18:53:59: <next-unit-percentage v='99'/>
18:53:59: <stall-detection-enabled v='false'/>
18:53:59: <stall-percent v='5'/>
18:53:59: <stall-timeout v='1800'/>
18:53:59:
18:53:59: <!-- Folding Slots -->
18:53:59: <slot id='1' type='GPU'/>
18:53:59:</config>
18:53:59:Trying to access database...
18:53:59:Successfully acquired database lock
18:53:59:Enabled folding slot 01: READY gpu:0:TU106 [GeForce RTX 2060 Super]
18:53:59:WU00:FS01:Starting
18:53:59:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Test\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 8948 -checkpoint 4 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
18:53:59:WU00:FS01:Started FahCore on PID 13120
18:54:00:WU00:FS01:Core PID:13208
18:54:00:WU00:FS01:FahCore 0x22 started
18:54:00:WU00:FS01:0x22:*********************** Log Started 2020-06-12T18:54:00Z ***********************
18:54:00:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
18:54:00:WU00:FS01:0x22: Type: 0x22
18:54:00:WU00:FS01:0x22: Core: Core22
18:54:00:WU00:FS01:0x22: Website: https://foldingathome.org/
18:54:00:WU00:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
18:54:00:WU00:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
18:54:00:WU00:FS01:0x22: <rafal.wiewiora@choderalab.org>
18:54:00:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 705 -lifeline 13120 -checkpoint 4
18:54:00:WU00:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
18:54:00:WU00:FS01:0x22: 0 -gpu 0
18:54:00:WU00:FS01:0x22: Config: <none>
18:54:00:WU00:FS01:0x22:************************************ Build *************************************
18:54:00:WU00:FS01:0x22: Version: 0.0.5
18:54:00:WU00:FS01:0x22: Date: Apr 22 2020
18:54:00:WU00:FS01:0x22: Time: 04:42:59
18:54:00:WU00:FS01:0x22: Repository: Git
18:54:00:WU00:FS01:0x22: Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
18:54:00:WU00:FS01:0x22: Branch: HEAD
18:54:00:WU00:FS01:0x22: Compiler: Visual C++ 2008
18:54:00:WU00:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:54:00:WU00:FS01:0x22: Platform: win32 10
18:54:00:WU00:FS01:0x22: Bits: 64
18:54:00:WU00:FS01:0x22: Mode: Release
18:54:00:WU00:FS01:0x22:************************************ System ************************************
18:54:00:WU00:FS01:0x22: CPU: AMD Ryzen 5 3600 6-Core Processor
18:54:00:WU00:FS01:0x22: CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
18:54:00:WU00:FS01:0x22: CPUs: 12
18:54:00:WU00:FS01:0x22: Memory: 15.95GiB
18:54:00:WU00:FS01:0x22:Free Memory: 12.36GiB
18:54:00:WU00:FS01:0x22: Threads: WINDOWS_THREADS
18:54:00:WU00:FS01:0x22: OS Version: 6.2
18:54:00:WU00:FS01:0x22:Has Battery: false
18:54:00:WU00:FS01:0x22: On Battery: false
18:54:00:WU00:FS01:0x22: UTC Offset: -4
18:54:00:WU00:FS01:0x22: PID: 13208
18:54:00:WU00:FS01:0x22: CWD: C:\********
18:54:00:WU00:FS01:0x22: OS: Windows 10 Pro
18:54:00:WU00:FS01:0x22: OS Arch: AMD64
18:54:00:WU00:FS01:0x22:********************************************************************************
18:54:00:WU00:FS01:0x22:Project: 14251 (Run 80, Clone 0, Gen 86)
18:54:00:WU00:FS01:0x22:Unit: 0x0000008acedfaa925eab0323a506ba42
18:54:00:WU00:FS01:0x22:Reading tar file core.xml
18:54:00:WU00:FS01:0x22:Reading tar file integrator.xml
18:54:00:WU00:FS01:0x22:Reading tar file state.xml
18:55:30:FS01:Shutting core down
18:55:30:WU00:FS01:0x22:WARNING:Console control signal 1 on PID 13208
18:55:30:WU00:FS01:0x22:Exiting, please wait. . .
18:56:01:Removing old file 'configs/config-20200608-020755.xml'
18:56:01:Saving configuration to config.xml
18:56:01:<config>
18:56:01: <!-- Folding Core -->
18:56:01: <checkpoint v='4'/>
18:56:01: <core-priority v='low'/>
18:56:01:
18:56:01: <!-- Logging -->
18:56:01: <verbosity v='4'/>
18:56:01:
18:56:01: <!-- Network -->
18:56:01: <proxy v=':8080'/>
18:56:01:
18:56:01: <!-- Slot Control -->
18:56:01: <pause-on-battery v='false'/>
18:56:01: <power v='full'/>
18:56:01:
18:56:01: <!-- User Information -->
18:56:01: <passkey v='********************************'/>
18:56:01: <team v='********'/>
18:56:01: <user v='********'/>
18:56:01:
18:56:01: <!-- Folding Slots -->
18:56:01: <slot id='1' type='GPU'/>
18:56:01:</config>
******************************* Date: 2020-06-13 *******************************
01:20:50:FS01:Paused
01:20:50:WARNING:FS01:Killing WU00
01:20:50:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
01:21:20:Removing old file 'configs/config-20200608-041601.xml'
01:21:20:Saving configuration to config.xml
01:21:20:<config>
01:21:20: <!-- Folding Core -->
01:21:20: <checkpoint v='4'/>
01:21:20: <core-priority v='low'/>
01:21:20:
01:21:20: <!-- Logging -->
01:21:20: <verbosity v='4'/>
01:21:20:
01:21:20: <!-- Network -->
01:21:20: <proxy v=':8080'/>
01:21:20:
01:21:20: <!-- Slot Control -->
01:21:20: <pause-on-battery v='false'/>
01:21:20: <power v='full'/>
01:21:20:
01:21:20: <!-- User Information -->
01:21:20: <passkey v='********************************'/>
01:21:20: <team v='********'/>
01:21:20: <user v='********'/>
01:21:20:
01:21:20: <!-- Folding Slots -->
01:21:20: <slot id='1' type='GPU'>
01:21:20: <paused v='true'/>
01:21:20: </slot>
01:21:20:</config>
06:12:18:FS01:Unpaused
06:12:18:WU00:FS01:Starting
06:12:18:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Test\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 8948 -checkpoint 4 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
06:12:18:WU00:FS01:Started FahCore on PID 8388
06:12:18:WU00:FS01:Core PID:11020
06:12:18:WU00:FS01:FahCore 0x22 started
06:12:19:WU00:FS01:0x22:*********************** Log Started 2020-06-13T06:12:18Z ***********************
06:12:19:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
06:12:19:WU00:FS01:0x22: Type: 0x22
06:12:19:WU00:FS01:0x22: Core: Core22
06:12:19:WU00:FS01:0x22: Website: https://foldingathome.org/
06:12:19:WU00:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
06:12:19:WU00:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
06:12:19:WU00:FS01:0x22: <rafal.wiewiora@choderalab.org>
06:12:19:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 705 -lifeline 8388 -checkpoint 4
06:12:19:WU00:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
06:12:19:WU00:FS01:0x22: 0 -gpu 0
06:12:19:WU00:FS01:0x22: Config: <none>
06:12:19:WU00:FS01:0x22:************************************ Build *************************************
06:12:19:WU00:FS01:0x22: Version: 0.0.5
06:12:19:WU00:FS01:0x22: Date: Apr 22 2020
06:12:19:WU00:FS01:0x22: Time: 04:42:59
06:12:19:WU00:FS01:0x22: Repository: Git
06:12:19:WU00:FS01:0x22: Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
06:12:19:WU00:FS01:0x22: Branch: HEAD
06:12:19:WU00:FS01:0x22: Compiler: Visual C++ 2008
06:12:19:WU00:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
06:12:19:WU00:FS01:0x22: Platform: win32 10
06:12:19:WU00:FS01:0x22: Bits: 64
06:12:19:WU00:FS01:0x22: Mode: Release
06:12:19:WU00:FS01:0x22:************************************ System ************************************
06:12:19:WU00:FS01:0x22: CPU: AMD Ryzen 5 3600 6-Core Processor
06:12:19:WU00:FS01:0x22: CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
06:12:19:WU00:FS01:0x22: CPUs: 12
06:12:19:WU00:FS01:0x22: Memory: 15.95GiB
06:12:19:WU00:FS01:0x22:Free Memory: 10.55GiB
06:12:19:WU00:FS01:0x22: Threads: WINDOWS_THREADS
06:12:19:WU00:FS01:0x22: OS Version: 6.2
06:12:19:WU00:FS01:0x22:Has Battery: false
06:12:19:WU00:FS01:0x22: On Battery: false
06:12:19:WU00:FS01:0x22: UTC Offset: -4
06:12:19:WU00:FS01:0x22: PID: 11020
06:12:19:WU00:FS01:0x22: CWD: C:\********
06:12:19:WU00:FS01:0x22: OS: Windows 10 Pro
06:12:19:WU00:FS01:0x22: OS Arch: AMD64
06:12:19:WU00:FS01:0x22:********************************************************************************
06:12:19:WU00:FS01:0x22:Project: 14251 (Run 80, Clone 0, Gen 86)
06:12:19:WU00:FS01:0x22:Unit: 0x0000008acedfaa925eab0323a506ba42
06:12:19:WU00:FS01:0x22:Reading tar file core.xml
06:12:19:WU00:FS01:0x22:Reading tar file integrator.xml
06:12:19:WU00:FS01:0x22:Reading tar file state.xml
06:13:07:Removing old file 'configs/config-20200608-135834.xml'
06:13:07:Saving configuration to config.xml
06:13:07:<config>
06:13:07: <!-- Folding Core -->
06:13:07: <checkpoint v='4'/>
06:13:07: <core-priority v='low'/>
06:13:07:
06:13:07: <!-- Logging -->
06:13:07: <verbosity v='4'/>
06:13:07:
06:13:07: <!-- Network -->
06:13:07: <proxy v=':8080'/>
06:13:07:
06:13:07: <!-- Slot Control -->
06:13:07: <pause-on-battery v='false'/>
06:13:07: <power v='full'/>
06:13:07:
06:13:07: <!-- User Information -->
06:13:07: <passkey v='********************************'/>
06:13:07: <team v='********'/>
06:13:07: <user v='********'/>
06:13:07:
06:13:07: <!-- Folding Slots -->
06:13:07: <slot id='1' type='GPU'/>
06:13:07:</config>
******************************* Date: 2020-06-14 *******************************
01:17:56:2:127.0.0.1 GET /ping?_=1592097476608&callback=jQuery19008691151951425211_1592097476607
01:17:57:3:127.0.0.1 GET /?nocache=0.7350117786119006
01:17:58:4:127.0.0.1 GET /css/normalize.css
01:17:58:5:127.0.0.1 GET /css/main.css
01:17:58:6:127.0.0.1 GET /js/jquery-1.10.2.min.js
01:17:58:7:127.0.0.1 GET /js/libs/jquery.selectbox-0.2.js
01:17:58:8:127.0.0.1 GET /js/intercom.min.js
01:17:58:9:127.0.0.1 GET /js/main.js
01:17:58:9:127.0.0.1:New Web connection
01:17:59:10:127.0.0.1 GET /images/mail.png
01:17:59:11:127.0.0.1 GET /images/facebook.png
01:17:59:12:127.0.0.1 GET /images/twitter.png
01:17:59:13:127.0.0.1 GET /images/report-bug.png
01:17:59:14:127.0.0.1 GET /images/template/bg.jpg
01:17:59:15:127.0.0.1 GET /images/template/logo_folding_home.png
01:17:59:16:127.0.0.1 GET /images/template/button_bg.png
01:17:59:17:127.0.0.1 GET /images/template/input_radio.png
01:17:59:18:127.0.0.1 GET /api/updates/set?_=1592097478629&sid=7d60954cefebbe100eb36e38ec10fe74&update_id=0&update_path=/api/basic&update_rate=1
01:17:59:19:127.0.0.1 GET /api/updates/set?_=1592097478630&sid=7d60954cefebbe100eb36e38ec10fe74&update_id=1&update_path=/api/slots&update_rate=1
01:17:59:20:127.0.0.1 GET /api/configured?_=1592097478631&sid=7d60954cefebbe100eb36e38ec10fe74
01:17:59:21:127.0.0.1 GET /images/template/select-icons.png
01:18:00:22:127.0.0.1 GET /api/updates?_=1592097478632&sid=7d60954cefebbe100eb36e38ec10fe74
01:18:00:23:127.0.0.1 GET /images/template/ui-bg-slider.png
01:18:00:24:127.0.0.1 GET /images/template/ui-progress-bg.png
01:18:01:22:127.0.0.1 GET /images/template/ui-icon-slider.png
01:18:01:25:127.0.0.1 GET /images/template/anim_arrow.gif
01:18:02:26:127.0.0.1 GET /api/updates?_=1592097478635&sid=7d60954cefebbe100eb36e38ec10fe74
01:18:03:27:127.0.0.1 GET /api/updates?_=1592097478636&sid=7d60954cefebbe100eb36e38ec10fe74
01:18:05:27:127.0.0.1 GET /api/updates?_=1592097478637&sid=7d60954cefebbe100eb36e38ec10fe74
01:18:10:27:127.0.0.1 GET /api/updates?_=1592097478638&sid=7d60954cefebbe100eb36e38ec10fe74
01:18:15:27:127.0.0.1 GET /api/updates?_=1592097478639&sid=7d60954cefebbe100eb36e38ec10fe74
01:18:20:27:127.0.0.1 GET /api/updates?_=1592097478640&sid=7d60954cefebbe100eb36e38ec10fe74
01:18:25:26:127.0.0.1 GET /api/updates?_=1592097478641&sid=7d60954cefebbe100eb36e38ec10fe74
01:18:30:27:127.0.0.1 GET /api/updates?_=1592097478642&sid=7d60954cefebbe100eb36e38ec10fe74
01:18:35:26:127.0.0.1 GET /api/updates?_=1592097478643&sid=7d60954cefebbe100eb36e38ec10fe74
01:18:40:27:127.0.0.1 GET /api/updates?_=1592097478644&sid=7d60954cefebbe100eb36e38ec10fe74
01:18:45:27:127.0.0.1 GET /api/updates?_=1592097478645&sid=7d60954cefebbe100eb36e38ec10fe74
01:18:50:27:127.0.0.1 GET /api/updates?_=1592097478646&sid=7d60954cefebbe100eb36e38ec10fe74
01:18:55:27:127.0.0.1 GET /api/updates?_=1592097478647&sid=7d60954cefebbe100eb36e38ec10fe74
01:19:00:27:127.0.0.1 GET /api/updates?_=1592097478648&sid=7d60954cefebbe100eb36e38ec10fe74
01:23:32:29:127.0.0.1 GET /ping?_=1592097811847&callback=jQuery190016457565205310698_1592097811846
01:23:33:30:127.0.0.1 GET /?nocache=0.7688610995654126
01:23:33:31:127.0.0.1 GET /api/updates/set?_=1592097813386&sid=7d60954cefebbe100eb36e38ec10fe74&update_id=0&update_path=/api/basic&update_rate=1
01:23:34:32:127.0.0.1 GET /api/updates/set?_=1592097813387&sid=7d60954cefebbe100eb36e38ec10fe74&update_id=1&update_path=/api/slots&update_rate=1
01:23:34:33:127.0.0.1 GET /api/configured?_=1592097813388&sid=7d60954cefebbe100eb36e38ec10fe74
01:23:34:34:127.0.0.1 GET /api/updates?_=1592097813389&sid=7d60954cefebbe100eb36e38ec10fe74
01:23:35:34:127.0.0.1 GET /api/updates?_=1592097813392&sid=7d60954cefebbe100eb36e38ec10fe74
01:23:37:35:127.0.0.1 GET /api/updates?_=1592097813393&sid=7d60954cefebbe100eb36e38ec10fe74
01:23:40:35:127.0.0.1 GET /api/updates?_=1592097813394&sid=7d60954cefebbe100eb36e38ec10fe74
01:23:45:35:127.0.0.1 GET /api/updates?_=1592097813395&sid=7d60954cefebbe100eb36e38ec10fe74
01:23:50:35:127.0.0.1 GET /api/updates?_=1592097813396&sid=7d60954cefebbe100eb36e38ec10fe74
01:23:55:35:127.0.0.1 GET /api/updates?_=1592097813397&sid=7d60954cefebbe100eb36e38ec10fe74
01:24:00:35:127.0.0.1 GET /api/updates?_=1592097813398&sid=7d60954cefebbe100eb36e38ec10fe74
01:24:06:35:127.0.0.1 GET /api/updates?_=1592097813399&sid=7d60954cefebbe100eb36e38ec10fe74
01:24:07:36:127.0.0.1 GET /api/updates?_=1592097813400&sid=7d60954cefebbe100eb36e38ec10fe74
01:24:16:35:127.0.0.1 GET /api/updates?_=1592097813401&sid=7d60954cefebbe100eb36e38ec10fe74
01:24:21:35:127.0.0.1 GET /api/updates?_=1592097813402&sid=7d60954cefebbe100eb36e38ec10fe74
01:24:26:35:127.0.0.1 GET /api/updates?_=1592097813403&sid=7d60954cefebbe100eb36e38ec10fe74
01:24:31:35:127.0.0.1 GET /api/updates?_=1592097813404&sid=7d60954cefebbe100eb36e38ec10fe74
01:24:36:35:127.0.0.1 GET /api/updates?_=1592097813405&sid=7d60954cefebbe100eb36e38ec10fe74
01:24:38:37:127.0.0.1 GET /api/updates?_=1592097813406&sid=7d60954cefebbe100eb36e38ec10fe74
01:24:41:35:127.0.0.1 GET /api/updates?_=1592097813407&sid=7d60954cefebbe100eb36e38ec10fe74
01:38:56:FS01:Paused
01:38:56:FS01:Shutting core down
01:38:57:WU00:FS01:0x22:WARNING:Console control signal 1 on PID 11020
01:38:57:WU00:FS01:0x22:Exiting, please wait. . .
01:39:14:Removing old file 'configs/config-20200608-182900.xml'
01:39:14:Saving configuration to config.xml
01:39:14:<config>
01:39:14: <!-- Folding Core -->
01:39:14: <checkpoint v='4'/>
01:39:14: <core-priority v='low'/>
01:39:14:
01:39:14: <!-- Logging -->
01:39:14: <verbosity v='4'/>
01:39:14:
01:39:14: <!-- Network -->
01:39:14: <proxy v=':8080'/>
01:39:14:
01:39:14: <!-- Slot Control -->
01:39:14: <pause-on-battery v='false'/>
01:39:14: <power v='full'/>
01:39:14:
01:39:14: <!-- User Information -->
01:39:14: <passkey v='********************************'/>
01:39:14: <team v='********'/>
01:39:14: <user v='********'/>
01:39:14:
01:39:14: <!-- Folding Slots -->
01:39:14: <slot id='1' type='GPU'>
01:39:14: <paused v='true'/>
01:39:14: </slot>
01:39:14:</config>
01:39:57:WARNING:FS01:Killing WU00
01:39:57:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
05:32:15:FS01:Unpaused
05:32:15:WU00:FS01:Starting
05:32:15:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Test\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 8948 -checkpoint 4 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
05:32:15:WU00:FS01:Started FahCore on PID 13084
05:32:15:WU00:FS01:Core PID:120
05:32:15:WU00:FS01:FahCore 0x22 started
05:32:15:WU00:FS01:0x22:*********************** Log Started 2020-06-14T05:32:15Z ***********************
05:32:15:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
05:32:15:WU00:FS01:0x22: Type: 0x22
05:32:15:WU00:FS01:0x22: Core: Core22
05:32:15:WU00:FS01:0x22: Website: https://foldingathome.org/
05:32:15:WU00:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
05:32:15:WU00:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
05:32:15:WU00:FS01:0x22: <rafal.wiewiora@choderalab.org>
05:32:15:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 705 -lifeline 13084 -checkpoint 4
05:32:15:WU00:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
05:32:15:WU00:FS01:0x22: 0 -gpu 0
05:32:15:WU00:FS01:0x22: Config: <none>
05:32:15:WU00:FS01:0x22:************************************ Build *************************************
05:32:15:WU00:FS01:0x22: Version: 0.0.5
05:32:15:WU00:FS01:0x22: Date: Apr 22 2020
05:32:15:WU00:FS01:0x22: Time: 04:42:59
05:32:15:WU00:FS01:0x22: Repository: Git
05:32:15:WU00:FS01:0x22: Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
05:32:15:WU00:FS01:0x22: Branch: HEAD
05:32:15:WU00:FS01:0x22: Compiler: Visual C++ 2008
05:32:15:WU00:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
05:32:15:WU00:FS01:0x22: Platform: win32 10
05:32:15:WU00:FS01:0x22: Bits: 64
05:32:15:WU00:FS01:0x22: Mode: Release
05:32:15:WU00:FS01:0x22:************************************ System ************************************
05:32:15:WU00:FS01:0x22: CPU: AMD Ryzen 5 3600 6-Core Processor
05:32:15:WU00:FS01:0x22: CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
05:32:15:WU00:FS01:0x22: CPUs: 12
05:32:15:WU00:FS01:0x22: Memory: 15.95GiB
05:32:15:WU00:FS01:0x22:Free Memory: 12.91GiB
05:32:15:WU00:FS01:0x22: Threads: WINDOWS_THREADS
05:32:15:WU00:FS01:0x22: OS Version: 6.2
05:32:15:WU00:FS01:0x22:Has Battery: false
05:32:15:WU00:FS01:0x22: On Battery: false
05:32:15:WU00:FS01:0x22: UTC Offset: -4
05:32:15:WU00:FS01:0x22: PID: 120
05:32:15:WU00:FS01:0x22: CWD: C:\********
05:32:15:WU00:FS01:0x22: OS: Windows 10 Pro
05:32:15:WU00:FS01:0x22: OS Arch: AMD64
05:32:15:WU00:FS01:0x22:********************************************************************************
05:32:15:WU00:FS01:0x22:Project: 14251 (Run 80, Clone 0, Gen 86)
05:32:15:WU00:FS01:0x22:Unit: 0x0000008acedfaa925eab0323a506ba42
05:32:15:WU00:FS01:0x22:Reading tar file core.xml
05:32:15:WU00:FS01:0x22:Reading tar file integrator.xml
05:32:15:WU00:FS01:0x22:Reading tar file state.xml
05:33:04:Removing old file 'configs/config-20200608-192152.xml'
05:33:04:Saving configuration to config.xml
05:33:04:<config>
05:33:04: <!-- Folding Core -->
05:33:04: <checkpoint v='4'/>
05:33:04: <core-priority v='low'/>
05:33:04:
05:33:04: <!-- Logging -->
05:33:04: <verbosity v='4'/>
05:33:04:
05:33:04: <!-- Network -->
05:33:04: <proxy v=':8080'/>
05:33:04:
05:33:04: <!-- Slot Control -->
05:33:04: <pause-on-battery v='false'/>
05:33:04: <power v='full'/>
05:33:04:
05:33:04: <!-- User Information -->
05:33:04: <passkey v='********************************'/>
05:33:04: <team v='********'/>
05:33:04: <user v='********'/>
05:33:04:
05:33:04: <!-- Folding Slots -->
05:33:04: <slot id='1' type='GPU'/>
05:33:04:</config>
05:35:24:Removing old file 'configs/config-20200608-192354.xml'
05:35:24:Saving configuration to config.xml
05:35:24:<config>
05:35:24: <!-- Folding Core -->
05:35:24: <checkpoint v='4'/>
05:35:24: <core-priority v='low'/>
05:35:24:
05:35:24: <!-- Logging -->
05:35:24: <verbosity v='5'/>
05:35:24:
05:35:24: <!-- Network -->
05:35:24: <proxy v=':8080'/>
05:35:24:
05:35:24: <!-- Slot Control -->
05:35:24: <pause-on-battery v='false'/>
05:35:24: <power v='full'/>
05:35:24:
05:35:24: <!-- User Information -->
05:35:24: <passkey v='********************************'/>
05:35:24: <team v='********'/>
05:35:24: <user v='********'/>
05:35:24:
05:35:24: <!-- Folding Slots -->
05:35:24: <slot id='1' type='GPU'/>
05:35:24:</config>
05:36:07:Removing old file 'configs/config-20200610-124939.xml'
05:36:07:Saving configuration to config.xml
05:36:07:<config>
05:36:07: <!-- Folding Core -->
05:36:07: <checkpoint v='4'/>
05:36:07: <core-priority v='low'/>
05:36:07:
05:36:07: <!-- Logging -->
05:36:07: <verbosity v='5'/>
05:36:07:
05:36:07: <!-- Network -->
05:36:07: <proxy v=':8080'/>
05:36:07:
05:36:07: <!-- Slot Control -->
05:36:07: <pause-on-battery v='false'/>
05:36:07: <power v='full'/>
05:36:07:
05:36:07: <!-- User Information -->
05:36:07: <passkey v='********************************'/>
05:36:07: <team v='********'/>
05:36:07: <user v='********'/>
05:36:07:
05:36:07: <!-- Folding Slots -->
05:36:07: <slot id='1' type='GPU'/>
05:36:07:</config>
Reason: added Code tags to log
setting verbosity back to 3 is sure going to help read all that.
18:53:59:</config>
You only have a GPU slot defined, you can add a CPU slot for more Points.
Something is killing your GPU Work Units, but there is so much junk in your log, I can't see any idea why.
I would have to recommend you write down your Name, Team Number, and Passkey and Uninstall Version: 7.5.1 including data.
Then download the latest client, 7.6.13 last I looked, and re-enter your info. If it does not ask, you didn't choose to delete data.
https://foldingathome.org/start-folding/
if you want to be thorough, you can download the latest driver from Nvidia as well, but you seem to have the latest I do.
https://www.nvidia.com/en-us/drivers/results/159887/
I might have had better advice but you have added a great deal of unfamiliar lines. Leave verbosity alone, please.
PantherX gave a link on how to post a log file, putting it between {code} and {/code} sure helps. Use square braces, not the curly braces I use. If I use square braces they 'work'.
You are struggling to make it difficult to help, we are struggling to help anyway.
18:53:59:</config>
Are you using any anti-malware software, virus scanner, ... that might interfer?
The log lines state
Hard to tell what is killing the process, but since a user on Discord reported that his FAHClient.exe was recently blocked by bitdefender.
I could also imagine anti-malware removing files from %appdata%\FAHClient\work folders (which is needed by FAHCore_xyz.exe) and causing FAH to "clean up"...
The log lines state
01:39:57:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)I could also imagine anti-malware removing files from %appdata%\FAHClient\work folders (which is needed by FAHCore_xyz.exe) and causing FAH to "clean up"...
