Renoir GPU (AMD Ryzen 4900HS) Support
sendentaryvince
Post by sendentaryvince »
Hi,
Please add support for Renoir GPUs.
*********************** Log Started 2020-05-27T19:54:38Z ***********************
19:54:38:Trying to access database...
19:54:38:Successfully acquired database lock
19:54:38:Read GPUs.txt
19:54:38:Enabled folding slot 00: READY cpu:14
19:54:39:ERROR:FS02:OpenCL GPU not found for 'opencl-index' = 1 with vendor ID = 0x10de, please correct this by removing the manually configured 'opencl-index' option.
19:54:39:ERROR:FS02:CUDA device not found for 'cuda-index' = 1, please correct this by removing the manually configured 'cuda-index' option.
19:54:39:Enabled folding slot 02: READY gpu:0:TU106M [GeForce RTX 2060 Mobile / Max-Q] 4550
19:54:39:Enabled folding slot 03: READY gpu:1:Renoir []
19:54:39:****************************** FAHClient ******************************
19:54:39:        Version: 7.6.13
19:54:39:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:54:39:      Copyright: 2020 foldingathome.org
19:54:39:       Homepage: https://foldingathome.org/
19:54:39:           Date: Apr 27 2020
19:54:39:           Time: 21:21:01
19:54:39:       Revision: 5a652817f46116b6e135503af97f18e094414e3b
19:54:39:         Branch: master
19:54:39:       Compiler: Visual C++ 2008
19:54:39:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:54:39:       Platform: win32 10
19:54:39:           Bits: 32
19:54:39:           Mode: Release
19:54:39:           Args: --open-web-control
19:54:39:         Config: C:\Users\vince\AppData\Roaming\FAHClient\config.xml
19:54:39:******************************** CBang ********************************
19:54:39:           Date: Apr 24 2020
19:54:39:           Time: 17:07:55
19:54:39:       Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
19:54:39:           Bits: 32
19:54:39:******************************* System ********************************
19:54:39:            CPU: AMD Ryzen 9 4900HS with Radeon Graphics
19:54:39:         CPU ID: AuthenticAMD Family 23 Model 96 Stepping 1
19:54:39:           CPUs: 16
19:54:39:         Memory: 15.42GiB
19:54:39:    Free Memory: 12.17GiB
19:54:39:        Threads: WINDOWS_THREADS
19:54:39:     OS Version: 6.2
19:54:39:    Has Battery: true
19:54:39:     On Battery: false
19:54:39:     UTC Offset: 10
19:54:39:            PID: 16904
19:54:39:            CWD: C:\Users\vince\AppData\Roaming\FAHClient
19:54:39:  Win32 Service: false
19:54:39:             OS: Windows 10 Home
19:54:39:        OS Arch: AMD64
19:54:39:           GPUs: 2
19:54:39:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 TU106M [GeForce RTX 2060 Mobile /
19:54:39:                 Max-Q] 4550
19:54:39:          GPU 1: Bus:4 Slot:0 Func:0 UNKNOWN_ENUM:0 Renoir []
19:54:39:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:11.0
19:54:39:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:445.87
19:54:39:OpenCL Device 1: Platform:1 Device:0 Bus:4 Slot:0 Compute:1.2 Driver:3004.4
19:54:39:******************************* libFAH ********************************
19:54:39:           Date: Apr 15 2020
19:54:39:           Time: 14:53:14
19:54:39:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
19:54:39:           Bits: 32
19:54:39:***********************************************************************
19:54:39:<config>
19:54:39:  <!-- HTTP Server -->
19:54:39:  <allow v='192.168.1.0/24'/>
19:54:39:
19:54:39:  <!-- Network -->
19:54:39:  <proxy v=':8080'/>
19:54:39:
19:54:39:  <!-- Remote Command Server -->
19:54:39:  <password v='*****'/>
19:54:39:
19:54:39:  <!-- Slot Control -->
19:54:39:  <power v='FULL'/>
19:54:39:
19:54:39:  <!-- User Information -->
19:54:39:  <passkey v='*****'/>
19:54:39:  <user v='Vincent_Caballo'/>
19:54:39:
19:54:39:  <!-- Folding Slots -->
19:54:39:  <slot id='0' type='CPU'/>
19:54:39:  <slot id='2' type='GPU'>
19:54:39:    <cuda-index v='1'/>
19:54:39:    <gpu-index v='0'/>
19:54:39:    <opencl-index v='1'/>
19:54:39:  </slot>
19:54:39:  <slot id='3' type='GPU'>
19:54:39:    <gpu-index v='1'/>
19:54:39:    <opencl-index v='0'/>
19:54:39:  </slot>
19:54:39:</config>
19:54:39:WU05:FS03:Starting
19:54:39:WU05:FS03:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\vince\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 05 -suffix 01 -version 706 -lifeline 16904 -checkpoint 15 -opencl-platform 1 -opencl-device 0 -gpu 0
19:54:39:WU05:FS03:Started FahCore on PID 17188
19:54:39:WU05:FS03:Core PID:12704
19:54:39:WU05:FS03:FahCore 0xa7 started
19:54:39:WU00:FS00:Starting
19:54:39:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\vince\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 16904 -checkpoint 15 -np 14
19:54:39:WU00:FS00:Started FahCore on PID 15924
19:54:39:WU00:FS00:Core PID:17436
19:54:39:WU00:FS00:FahCore 0xa7 started
19:54:40:WU06:FS02:Connecting to assign1.foldingathome.org:80
19:54:40:WU05:FS03:0xa7:*********************** Log Started 2020-05-27T19:54:39Z ***********************
19:54:40:WU05:FS03:0xa7:************************** Gromacs Folding@home Core ***************************
19:54:40:WU05:FS03:0xa7:       Type: 0xa7
19:54:40:WU05:FS03:0xa7:       Core: Gromacs
19:54:40:WU05:FS03:0xa7:       Args: -dir 05 -suffix 01 -version 706 -lifeline 17188 -checkpoint 15
19:54:40:WU05:FS03:0xa7:             -opencl-platform 1 -opencl-device 0 -gpu 0
19:54:40:WU05:FS03:0xa7:************************************ CBang *************************************
19:54:40:WU05:FS03:0xa7:       Date: Oct 26 2019
19:54:40:WU05:FS03:0xa7:       Time: 01:38:25
19:54:40:WU05:FS03:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
19:54:40:WU05:FS03:0xa7:     Branch: master
19:54:40:WU05:FS03:0xa7:   Compiler: Visual C++ 2008
19:54:40:WU05:FS03:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:54:40:WU05:FS03:0xa7:   Platform: win32 10
19:54:40:WU05:FS03:0xa7:       Bits: 64
19:54:40:WU05:FS03:0xa7:       Mode: Release
19:54:40:WU05:FS03:0xa7:************************************ System ************************************
19:54:40:WU05:FS03:0xa7:        CPU: AMD Ryzen 9 4900HS with Radeon Graphics
19:54:40:WU05:FS03:0xa7:     CPU ID: AuthenticAMD Family 23 Model 96 Stepping 1
19:54:40:WU05:FS03:0xa7:       CPUs: 16
19:54:40:WU05:FS03:0xa7:     Memory: 15.42GiB
19:54:40:WU05:FS03:0xa7:Free Memory: 12.05GiB
19:54:40:WU05:FS03:0xa7:    Threads: WINDOWS_THREADS
19:54:40:WU05:FS03:0xa7: OS Version: 6.2
19:54:40:WU05:FS03:0xa7:Has Battery: true
19:54:40:WU05:FS03:0xa7: On Battery: false
19:54:40:WU05:FS03:0xa7: UTC Offset: 10
19:54:40:WU05:FS03:0xa7:        PID: 12704
19:54:40:WU05:FS03:0xa7:        CWD: C:\Users\vince\AppData\Roaming\FAHClient\work
19:54:40:WU05:FS03:0xa7:******************************** Build - libFAH ********************************
19:54:40:WU05:FS03:0xa7:    Version: 0.0.18
19:54:40:WU05:FS03:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:54:40:WU05:FS03:0xa7:  Copyright: 2019 foldingathome.org
19:54:40:WU05:FS03:0xa7:   Homepage: https://foldingathome.org/
19:54:40:WU05:FS03:0xa7:       Time: 01:52:30
19:54:40:WU05:FS03:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
19:54:40:WU05:FS03:0xa7:************************************ Build *************************************
19:54:40:WU00:FS00:0xa7:*********************** Log Started 2020-05-27T19:54:39Z ***********************
19:54:40:WU05:FS03:0xa7:       SIMD: avx_256
19:54:40:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
19:54:40:WU05:FS03:0xa7:********************************************************************************
19:54:40:WU00:FS00:0xa7:       Type: 0xa7
19:54:40:WU05:FS03:0xa7:Project: 14818 (Run 2565, Clone 0, Gen 47)
19:54:40:WU00:FS00:0xa7:       Core: Gromacs
19:54:40:WU05:FS03:0xa7:Unit: 0x000000352879986c5ea8dad586add399
19:54:40:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 15924 -checkpoint 15 -np
19:54:40:WU05:FS03:0xa7:Digital signatures verified
19:54:40:WU00:FS00:0xa7:             14
19:54:40:WU05:FS03:0xa7:Calling: mdrun -s frame47.tpr -o frame47.trr -cpt 15 -nt 1
19:54:40:WU00:FS00:0xa7:************************************ CBang *************************************
19:54:40:WU05:FS03:0xa7:Steps: first=0 total=250000
19:54:40:WU00:FS00:0xa7:       Date: Oct 26 2019
19:54:40:WU00:FS00:0xa7:       Time: 01:38:25
19:54:40:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
19:54:40:WU00:FS00:0xa7:     Branch: master
19:54:40:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
19:54:40:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:54:40:WU00:FS00:0xa7:   Platform: win32 10
19:54:40:WU00:FS00:0xa7:       Bits: 64
19:54:40:WU00:FS00:0xa7:       Mode: Release
19:54:40:WU00:FS00:0xa7:************************************ System ************************************
19:54:40:WU00:FS00:0xa7:        CPU: AMD Ryzen 9 4900HS with Radeon Graphics
19:54:40:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 96 Stepping 1
19:54:40:WU00:FS00:0xa7:       CPUs: 16
19:54:40:WU00:FS00:0xa7:     Memory: 15.42GiB
19:54:40:WU00:FS00:0xa7:Free Memory: 12.03GiB
19:54:40:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
19:54:40:WU00:FS00:0xa7: OS Version: 6.2
19:54:40:WU00:FS00:0xa7:Has Battery: true
19:54:40:WU00:FS00:0xa7: On Battery: false
19:54:40:WU00:FS00:0xa7: UTC Offset: 10
19:54:40:WU00:FS00:0xa7:        PID: 17436
19:54:40:WU00:FS00:0xa7:        CWD: C:\Users\vince\AppData\Roaming\FAHClient\work
19:54:40:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
19:54:40:WU00:FS00:0xa7:    Version: 0.0.18
19:54:40:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:54:40:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
19:54:40:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
19:54:40:WU00:FS00:0xa7:       Time: 01:52:30
19:54:40:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
19:54:40:WU00:FS00:0xa7:************************************ Build *************************************
19:54:40:WU00:FS00:0xa7:       SIMD: avx_256
19:54:40:WU00:FS00:0xa7:********************************************************************************
19:54:40:WU00:FS00:0xa7:Project: 14806 (Run 1541, Clone 0, Gen 0)
19:54:40:WU00:FS00:0xa7:Unit: 0x0000000003159d0b5ec017105d34c15e
19:54:40:WU00:FS00:0xa7:Digital signatures verified
19:54:40:WU00:FS00:0xa7:Reducing thread count from 14 to 13 to avoid domain decomposition with large prime factor 7
19:54:40:WU00:FS00:0xa7:Reducing thread count from 13 to 12 to avoid domain decomposition by a prime number > 3
19:54:40:WU00:FS00:0xa7:Calling: mdrun -s frame0.tpr -o frame0.trr -cpi state.cpt -cpt 15 -nt 12
19:54:40:WU00:FS00:0xa7:ERROR:Guru Meditation #17a61648eb6b6093.db2fee285da4338b (25442.26830) '00/01/pullx.xvg'
19:54:40:WU00:FS00:0xa7:WARNING:Unexpected exit() call
19:54:40:WU00:FS00:0xa7:WARNING:Unexpected exit from science code
19:54:40:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
19:54:40:WU00:FS00:0xa7:Saving result file dhdl.xvg
19:54:40:WU00:FS00:0xa7:Saving result file frame0.trr
19:54:40:WU00:FS00:0xa7:Saving result file md.log
19:54:40:WU00:FS00:0xa7:Saving result file pullf.xvg
19:54:40:WU00:FS00:0xa7:ERROR:Guru Meditation #7dffd6954743c980.3a2dce290ddc31a (12000.12663) '00/01/pullf.xvg'
19:54:41:WU05:FS03:0xa7:Completed 1 out of 250000 steps (0%)
19:54:42:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
19:54:42:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
19:54:42:WU01:FS00:Starting
19:54:42:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\vince\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 16904 -checkpoint 15
Re: Renoir GPU (AMD Ryzen 4900HS) Support
What happens is that the first volunteer with a new GPU (that would be you) tells us the Device ID. I use GPU-Z to see the Device ID.
Then someone enters this in a server and the server generates a new GPUs.txt file which should automatically download. (If it does not, once they tell you it is updated on the server, just delete your copy and it will download)
19:54:39: </slot>
19:54:39: </slot>
I also think you or the software have mixed up the GPUs. I think gpu-index 0 should be opencl-index 0 and gpu-index 1 should be opencl- index 1
Nvidia's driver should be 445.87, and AMD's should be3004.4.
sendentaryvince
Yep, I actually made the changes manually to the GPU.txt config adding Renoir after doing fahclient --lspci and getting the information there. My bad for the FAHClient config, I messed up that one but I corrected it now.
I'm folding on the Renoir but its quite slow, maybe because its not supported yet? Or that's just how fast the integrated GPU can do?
If something is "folding on the Renoir", you have probably ended up with a misconfiguration that has resulted in a slot that appears as a GPU slot, but is actually processing CPU WUs instead on your CPU. We have seen this before when people have added in an entry for an unsupported GPU.
Expanding out your image to see it in full, and that is exactly what is happening. Project 14365 is a CPU project, it is not using the Renoir IGP.
Set the folding on that WU to Finish, and remove the slot after it has completed and uploaded.
Once someone has a chance to add this GPU, you will need to download a new copy of GPUs.txt and restart FAHClient. Easiest would be with a reboot. Then you can set up a GPU slot for the Renoir.
Reason: fixed autocorrect word mis-choice
I've added this GPU. You get to beta test it. Let us know what you find.
Your copy of GPUs.txt is not the master, until you give them the Device ID, they can't update the master on the server.
Besides the Device ID , you could give us a more recent Log to study.
Joe_H's "died" is also undoubtedly 'tried' we do not execute volunteers!
sendentaryvince
Joe_H wrote:If something is "folding on the Renoir", you have probably ended up with a misconfiguration that has resulted in a slot that appears as a GPU slot, but is actually processing CPU WUs instead on your CPU. We have seen this before when people have died in an entry for an unsupported GPU.
Yes, you're right. It is working out of an a7 core which I read only does avx_256
19:43:36:ERROR:FS02:OpenCL GPU not found for 'opencl-index' = 1 with vendor ID = 0x1002, please correct this by removing the manually configured 'opencl-index' option.
19:43:36:Adding folding slot 02: READY gpu:1:Renoir [Radeon Vega 8 Mobile]
19:43:36:Removing old file 'configs/config-20200528-071938.xml'
19:43:36:Saving configuration to config.xml
19:43:36:<config>
19:43:36:  <!-- HTTP Server -->
19:43:36:  <allow v='192.168.1.0/24'/>
19:43:36:
19:43:36:  <!-- Network -->
19:43:36:  <proxy v=':8080'/>
19:43:36:
19:43:36:  <!-- Remote Command Server -->
19:43:36:  <password v='*****'/>
19:43:36:
19:43:36:  <!-- Slot Control -->
19:43:36:  <power v='FULL'/>
19:43:36:
19:43:36:  <!-- User Information -->
19:43:36:  <passkey v='*****'/>
19:43:36:  <user v='Vincent_Caballo'/>
19:43:36:
19:43:36:  <!-- Folding Slots -->
19:43:36:  <slot id='0' type='CPU'>
19:43:36:    <paused v='true'/>
19:43:36:  </slot>
19:43:36:  <slot id='1' type='GPU'>
19:43:36:    <cuda-index v='0'/>
19:43:36:    <gpu-index v='0'/>
19:43:36:    <opencl-index v='0'/>
19:43:36:  </slot>
19:43:36:  <slot id='2' type='GPU'>
19:43:36:    <gpu-index v='1'/>
19:43:36:    <opencl-index v='1'/>
19:43:36:  </slot>
19:43:36:</config>
19:43:36:WU02:FS02:Connecting to assign1.foldingathome.org:80
19:43:37:WU02:FS02:Assigned to work server 155.247.164.214
19:43:37:WU02:FS02:Requesting new work unit for slot 02: READY gpu:1:Renoir [Radeon Vega 8 Mobile] from 155.247.164.214
19:43:37:WU02:FS02:Connecting to 155.247.164.214:8080
19:43:38:WU02:FS02:Downloading 2.79MiB
19:43:40:WU02:FS02:Download complete
19:43:40:WU02:FS02:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:14827 run:847 clone:0 gen:57 core:0xa7 unit:0x0000003e9bf7a4d65ea6650b953338c1
19:43:40:WU02:FS02:Starting
19:43:40:WU02:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\vince\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 40748 -checkpoint 15 -opencl-device 1 -gpu 1
19:43:40:WU02:FS02:Started FahCore on PID 42308
19:43:40:WU02:FS02:Core PID:25676
19:43:40:WU02:FS02:FahCore 0xa7 started
19:43:41:WU02:FS02:0xa7:*********************** Log Started 2020-05-28T19:43:40Z ***********************
19:43:41:WU02:FS02:0xa7:************************** Gromacs Folding@home Core ***************************
19:43:41:WU02:FS02:0xa7:       Type: 0xa7
19:43:41:WU02:FS02:0xa7:       Core: Gromacs
19:43:41:WU02:FS02:0xa7:       Args: -dir 02 -suffix 01 -version 706 -lifeline 42308 -checkpoint 15
19:43:41:WU02:FS02:0xa7:             -opencl-device 1 -gpu 1
19:43:41:WU02:FS02:0xa7:************************************ CBang *************************************
19:43:41:WU02:FS02:0xa7:       Date: Oct 26 2019
19:43:41:WU02:FS02:0xa7:       Time: 01:38:25
19:43:41:WU02:FS02:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
19:43:41:WU02:FS02:0xa7:     Branch: master
19:43:41:WU02:FS02:0xa7:   Compiler: Visual C++ 2008
19:43:41:WU02:FS02:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:43:41:WU02:FS02:0xa7:   Platform: win32 10
19:43:41:WU02:FS02:0xa7:       Bits: 64
19:43:41:WU02:FS02:0xa7:       Mode: Release
19:43:41:WU02:FS02:0xa7:************************************ System ************************************
19:43:41:WU02:FS02:0xa7:        CPU: AMD Ryzen 9 4900HS with Radeon Graphics
19:43:41:WU02:FS02:0xa7:     CPU ID: AuthenticAMD Family 23 Model 96 Stepping 1
19:43:41:WU02:FS02:0xa7:       CPUs: 16
19:43:41:WU02:FS02:0xa7:     Memory: 15.42GiB
19:43:41:WU02:FS02:0xa7:Free Memory: 7.68GiB
19:43:41:WU02:FS02:0xa7:    Threads: WINDOWS_THREADS
19:43:41:WU02:FS02:0xa7: OS Version: 6.2
19:43:41:WU02:FS02:0xa7:Has Battery: true
19:43:41:WU02:FS02:0xa7: On Battery: false
19:43:41:WU02:FS02:0xa7: UTC Offset: 10
19:43:41:WU02:FS02:0xa7:        PID: 25676
19:43:41:WU02:FS02:0xa7:        CWD: C:\Users\vince\AppData\Roaming\FAHClient\work
19:43:41:WU02:FS02:0xa7:******************************** Build - libFAH ********************************
19:43:41:WU02:FS02:0xa7:    Version: 0.0.18
19:43:41:WU02:FS02:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:43:41:WU02:FS02:0xa7:  Copyright: 2019 foldingathome.org
19:43:41:WU02:FS02:0xa7:   Homepage: https://foldingathome.org/
19:43:41:WU02:FS02:0xa7:       Time: 01:52:30
19:43:41:WU02:FS02:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
19:43:41:WU02:FS02:0xa7:************************************ Build *************************************
19:43:41:WU02:FS02:0xa7:       SIMD: avx_256
19:43:41:WU02:FS02:0xa7:********************************************************************************
19:43:41:WU02:FS02:0xa7:Project: 14827 (Run 847, Clone 0, Gen 57)
19:43:41:WU02:FS02:0xa7:Unit: 0x0000003e9bf7a4d65ea6650b953338c1
19:43:41:WU02:FS02:0xa7:Reading tar file core.xml
19:43:41:WU02:FS02:0xa7:Reading tar file frame57.tpr
19:43:41:WU02:FS02:0xa7:Digital signatures verified
19:43:41:WU02:FS02:0xa7:Calling: mdrun -s frame57.tpr -o frame57.trr -cpt 15 -nt 1
19:43:41:WU02:FS02:0xa7:Steps: first=0 total=250000
19:43:41:WU02:FS02:0xa7:Completed 1 out of 250000 steps (0%)
19:43:49:ERROR:WU00:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
19:43:49:WU00:FS01:Connecting to assign1.foldingathome.org:80
19:43:50:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
19:43:50:WU00:FS01:Connecting to assign2.foldingathome.org:80
19:43:50:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
19:43:50:WU00:FS01:Connecting to assign3.foldingathome.org:80
19:43:51:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
19:43:51:WU00:FS01:Connecting to assign4.foldingathome.org:80
19:43:52:WU00:FS01:Assigned to work server 140.163.4.231
19:43:52:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:TU106M [GeForce RTX 2060 Mobile / Max-Q] 4550 from 140.163.4.231
19:43:52:WU00:FS01:Connecting to 140.163.4.231:8080
19:44:14:Removing old file 'configs/config-20200528-191119.xml'
19:44:14:Saving configuration to config.xml
19:44:14:<config>
19:44:14:  <!-- HTTP Server -->
19:44:14:  <allow v='192.168.1.0/24'/>
19:44:14:
19:44:14:  <!-- Network -->
19:44:14:  <proxy v=':8080'/>
19:44:14:
19:44:14:  <!-- Remote Command Server -->
19:44:14:  <password v='*****'/>
19:44:14:
19:44:14:  <!-- Slot Control -->
19:44:14:  <power v='FULL'/>
19:44:14:
19:44:14:  <!-- User Information -->
19:44:14:  <passkey v='*****'/>
19:44:14:  <user v='Vincent_Caballo'/>
19:44:14:
19:44:14:  <!-- Folding Slots -->
19:44:14:  <slot id='0' type='CPU'>
19:44:14:    <paused v='true'/>
19:44:14:  </slot>
19:44:14:  <slot id='1' type='GPU'>
19:44:14:    <cuda-index v='0'/>
19:44:14:    <gpu-index v='0'/>
19:44:14:    <opencl-index v='0'/>
19:44:14:  </slot>
19:44:14:  <slot id='2' type='GPU'>
19:44:14:    <gpu-index v='1'/>
19:44:14:    <opencl-index v='1'/>
19:44:14:  </slot>
19:44:14:</config>
19:45:01:ERROR:WU00:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
19:45:01:WU00:FS01:Connecting to assign1.foldingathome.org:80
19:45:02:WU00:FS01:Assigned to work server 3.133.76.19
19:45:02:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:TU106M [GeForce RTX 2060 Mobile / Max-Q] 4550 from 3.133.76.19
19:45:02:WU00:FS01:Connecting to 3.133.76.19:8080
19:46:22:WU00:FS01:Downloading 19.29MiB
19:46:28:WU00:FS01:Download 27.22%
19:46:34:WU00:FS01:Download 71.28%
19:46:38:WU00:FS01:Download complete
19:46:38:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14462 run:0 clone:267 gen:23 core:0x22 unit:0x0000002503854c135eb39e432588c832
19:46:38:WU00:FS01:Starting
19:46:38:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\vince\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 40748 -checkpoint 15 -gpu-vendor nvidia -opencl-device 0 -cuda-device 0 -gpu 0
19:46:38:WU00:FS01:Started FahCore on PID 38756
19:46:39:WU00:FS01:Core PID:38872
19:46:39:WU00:FS01:FahCore 0x22 started
19:46:40:WU00:FS01:0x22:*********************** Log Started 2020-05-28T19:46:39Z ***********************
19:46:40:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
19:46:40:WU00:FS01:0x22:       Type: 0x22
19:46:40:WU00:FS01:0x22:       Core: Core22
19:46:40:WU00:FS01:0x22:    Website: https://foldingathome.org/
19:46:40:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
19:46:40:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
19:46:40:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
19:46:40:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 38756 -checkpoint 15
19:46:40:WU00:FS01:0x22:             -gpu-vendor nvidia -opencl-device 0 -cuda-device 0 -gpu 0
19:46:40:WU00:FS01:0x22:     Config: <none>
19:46:40:WU00:FS01:0x22:************************************ Build *************************************
19:46:40:WU00:FS01:0x22:    Version: 0.0.5
19:46:40:WU00:FS01:0x22:       Date: Apr 22 2020
19:46:40:WU00:FS01:0x22:       Time: 04:42:59
19:46:40:WU00:FS01:0x22: Repository: Git
19:46:40:WU00:FS01:0x22:   Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
19:46:40:WU00:FS01:0x22:     Branch: HEAD
19:46:40:WU00:FS01:0x22:   Compiler: Visual C++ 2008
19:46:40:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:46:40:WU00:FS01:0x22:   Platform: win32 10
19:46:40:WU00:FS01:0x22:       Bits: 64
19:46:40:WU00:FS01:0x22:       Mode: Release
19:46:40:WU00:FS01:0x22:************************************ System ************************************
19:46:40:WU00:FS01:0x22:        CPU: AMD Ryzen 9 4900HS with Radeon Graphics
19:46:40:WU00:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 96 Stepping 1
19:46:40:WU00:FS01:0x22:       CPUs: 16
19:46:40:WU00:FS01:0x22:     Memory: 15.42GiB
19:46:40:WU00:FS01:0x22:Free Memory: 7.79GiB
19:46:40:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
19:46:40:WU00:FS01:0x22: OS Version: 6.2
19:46:40:WU00:FS01:0x22:Has Battery: true
19:46:40:WU00:FS01:0x22: On Battery: false
19:46:40:WU00:FS01:0x22: UTC Offset: 10
19:46:40:WU00:FS01:0x22:        PID: 38872
19:46:40:WU00:FS01:0x22:        CWD: C:\Users\vince\AppData\Roaming\FAHClient\work
19:46:40:WU00:FS01:0x22:         OS: Windows 10 Home
19:46:40:WU00:FS01:0x22:    OS Arch: AMD64
19:46:40:WU00:FS01:0x22:********************************************************************************
19:46:40:WU00:FS01:0x22:Project: 14462 (Run 0, Clone 267, Gen 23)
19:46:40:WU00:FS01:0x22:Unit: 0x0000002503854c135eb39e432588c832
19:46:40:WU00:FS01:0x22:Reading tar file core.xml
19:46:40:WU00:FS01:0x22:Reading tar file integrator.xml
19:46:40:WU00:FS01:0x22:Reading tar file state.xml
19:46:40:WU00:FS01:0x22:Reading tar file system.xml
19:46:40:WU00:FS01:0x22:Digital signatures verified
19:46:40:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
19:46:40:WU00:FS01:0x22:Version 0.0.5
19:47:00:WU00:FS01:0x22:Completed 0 out of 2000000 steps (0%)
19:47:00:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
19:47:36:WU02:FS02:0xa7:Completed 2500 out of 250000 steps (1%)
19:50:35:WU00:FS01:0x22:Completed 20000 out of 2000000 steps (1%)
19:51:48:WU02:FS02:0xa7:Completed 5000 out of 250000 steps (2%)
19:54:13:WU00:FS01:0x22:Completed 40000 out of 2000000 steps (2%)
19:55:56:WU02:FS02:0xa7:Completed 7500 out of 250000 steps (3%)
19:57:52:WU00:FS01:0x22:Completed 60000 out of 2000000 steps (3%)
20:00:04:WU02:FS02:0xa7:Completed 10000 out of 250000 steps (4%)
20:01:30:WU00:FS01:0x22:Completed 80000 out of 2000000 steps (4%)
20:04:11:WU02:FS02:0xa7:Completed 12500 out of 250000 steps (5%)
20:05:08:WU00:FS01:0x22:Completed 100000 out of 2000000 steps (5%)
20:08:20:WU02:FS02:0xa7:Completed 15000 out of 250000 steps (6%)
JimboPalmer wrote:Your copy of GPUs.txt is not the master, until you give them the Device ID, they can't update the master on the server.
This is what I got from fahclient --lspci
0x1002:0x1636:4:0:0:Advanced Micro Devices, Inc. [AMD/ATI]:AMD Radeon(TM) Graphics
sendentaryvince
bruce wrote:I've added this GPU. You get to beta test it. Let us know what you find.
I've restarted the client, removed the GPUs.txt file but I'm not seeing the GPU. I also removed the GPUs.txt and rebooted my machine but still not seeing the new GPU.
*********************** Log Started 2020-05-28T20:18:09Z ***********************
20:18:09:Trying to access database...
20:18:09:Successfully acquired database lock
20:18:09:Downloading GPUs.txt from assign1.foldingathome.org:80
20:18:09:Connecting to assign1.foldingathome.org:80
20:18:10:Read GPUs.txt
20:18:10:Enabled folding slot 00: PAUSED cpu:15 (by user)
20:18:10:Enabled folding slot 01: PAUSED gpu:0:TU106M [GeForce RTX 2060 Mobile / Max-Q] 4550 (by user)
20:18:10:****************************** FAHClient ******************************
20:18:10:        Version: 7.6.13
20:18:10:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:18:10:      Copyright: 2020 foldingathome.org
20:18:10:       Homepage: https://foldingathome.org/
20:18:10:           Date: Apr 27 2020
20:18:10:           Time: 21:21:01
20:18:10:       Revision: 5a652817f46116b6e135503af97f18e094414e3b
20:18:10:         Branch: master
20:18:10:       Compiler: Visual C++ 2008
20:18:10:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:18:10:       Platform: win32 10
20:18:10:           Bits: 32
20:18:10:           Mode: Release
20:18:10:         Config: C:\Users\vince\AppData\Roaming\FAHClient\config.xml
20:18:10:******************************** CBang ********************************
20:18:10:           Date: Apr 24 2020
20:18:10:           Time: 17:07:55
20:18:10:       Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
20:18:10:           Bits: 32
20:18:10:******************************* System ********************************
20:18:10:            CPU: AMD Ryzen 9 4900HS with Radeon Graphics
20:18:10:         CPU ID: AuthenticAMD Family 23 Model 96 Stepping 1
20:18:10:           CPUs: 16
20:18:10:         Memory: 15.42GiB
20:18:10:    Free Memory: 11.35GiB
20:18:10:        Threads: WINDOWS_THREADS
20:18:10:     OS Version: 6.2
20:18:10:    Has Battery: true
20:18:10:     On Battery: false
20:18:10:     UTC Offset: 10
20:18:10:            PID: 18700
20:18:10:            CWD: C:\Users\vince\AppData\Roaming\FAHClient
20:18:10:  Win32 Service: false
20:18:10:             OS: Windows 10 Home
20:18:10:        OS Arch: AMD64
20:18:10:           GPUs: 1
20:18:10:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 TU106M [GeForce RTX 2060 Mobile /
20:18:10:                 Max-Q] 4550
20:18:10:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:11.0
20:18:10:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:445.87
20:18:10:OpenCL Device 1: Platform:1 Device:0 Bus:4 Slot:0 Compute:1.2 Driver:3004.4
20:18:10:******************************* libFAH ********************************
20:18:10:           Date: Apr 15 2020
20:18:10:           Time: 14:53:14
20:18:10:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
20:18:10:           Bits: 32
20:18:10:***********************************************************************
20:18:10:<config>
20:18:10:  <!-- HTTP Server -->
20:18:10:  <allow v='192.168.1.0/24'/>
20:18:10:
20:18:10:  <!-- Network -->
20:18:10:  <proxy v=':8080'/>
20:18:10:
20:18:10:  <!-- Remote Command Server -->
20:18:10:  <password v='*****'/>
20:18:10:
20:18:10:  <!-- Slot Control -->
20:18:10:  <power v='FULL'/>
20:18:10:
20:18:10:  <!-- User Information -->
20:18:10:  <passkey v='*****'/>
20:18:10:  <user v='Vincent_Caballo'/>
20:18:10:
20:18:10:  <!-- Folding Slots -->
20:18:10:  <slot id='0' type='CPU'>
20:18:10:    <paused v='true'/>
20:18:10:  </slot>
20:18:10:  <slot id='1' type='GPU'>
20:18:10:    <cuda-index v='0'/>
20:18:10:    <gpu-index v='0'/>
20:18:10:    <opencl-index v='0'/>
20:18:10:  </slot>
20:18:10:</config>
20:18:12:2:127.0.0.1:New Web session
20:18:13:7:127.0.0.1:New Web session
20:18:22:13:127.0.0.1:New Web session
20:18:23:19:127.0.0.1:New Web session
20:18:25:24:127.0.0.1:New Web session
20:18:26:31:127.0.0.1:New Web session
20:18:27:32:127.0.0.1:New Web session
20:18:50:42:127.0.0.1:New Web session
sendentaryvince
Looks like its running on GPU now. It's on a 0x22 core. I just manually uploaded the gpus.txt file from: https://apps.foldingathome.org/GPUs.txt and then restarted my client.
Thanks for your help!
21:01:12:Adding folding slot 02: READY gpu:1:Renoir [Ryzen 4900HS mobile]
21:01:12:Removing old file 'configs/config-20200528-194123.xml'
21:01:12:Saving configuration to config.xml
21:01:12:<config>
21:01:12:  <!-- HTTP Server -->
21:01:12:  <allow v='192.168.1.0/24'/>
21:01:12:
21:01:12:  <!-- Network -->
21:01:12:  <proxy v=':8080'/>
21:01:12:
21:01:12:  <!-- Remote Command Server -->
21:01:12:  <password v='*****'/>
21:01:12:
21:01:12:  <!-- Slot Control -->
21:01:12:  <power v='FULL'/>
21:01:12:
21:01:12:  <!-- User Information -->
21:01:12:  <passkey v='*****'/>
21:01:12:  <user v='Vincent_Caballo'/>
21:01:12:
21:01:12:  <!-- Folding Slots -->
21:01:12:  <slot id='0' type='CPU'>
21:01:12:    <paused v='true'/>
21:01:12:  </slot>
21:01:12:  <slot id='1' type='GPU'>
21:01:12:    <cuda-index v='0'/>
21:01:12:    <gpu-index v='0'/>
21:01:12:    <opencl-index v='0'/>
21:01:12:  </slot>
21:01:12:  <slot id='2' type='GPU'>
21:01:12:    <gpu-index v='1'/>
21:01:12:  </slot>
21:01:12:</config>
21:01:13:WU02:FS02:Connecting to assign1.foldingathome.org:80
21:01:13:WU02:FS02:Assigned to work server 128.252.203.10
21:01:13:WU02:FS02:Requesting new work unit for slot 02: READY gpu:1:Renoir [Ryzen 4900HS mobile] from 128.252.203.10
21:01:13:WU02:FS02:Connecting to 128.252.203.10:8080
21:01:34:WARNING:WU02:FS02:WorkServer connection failed on port 8080 trying 80
21:01:34:WU02:FS02:Connecting to 128.252.203.10:80
21:01:48:Removing old file 'configs/config-20200528-194209.xml'
21:01:48:Saving configuration to config.xml
21:01:48:<config>
21:01:48:  <!-- HTTP Server -->
21:01:48:  <allow v='192.168.1.0/24'/>
21:01:48:
21:01:48:  <!-- Network -->
21:01:48:  <proxy v=':8080'/>
21:01:48:
21:01:48:  <!-- Remote Command Server -->
21:01:48:  <password v='*****'/>
21:01:48:
21:01:48:  <!-- Slot Control -->
21:01:48:  <power v='FULL'/>
21:01:48:
21:01:48:  <!-- User Information -->
21:01:48:  <passkey v='*****'/>
21:01:48:  <user v='Vincent_Caballo'/>
21:01:48:
21:01:48:  <!-- Folding Slots -->
21:01:48:  <slot id='0' type='CPU'>
21:01:48:    <paused v='true'/>
21:01:48:  </slot>
21:01:48:  <slot id='1' type='GPU'>
21:01:48:    <cuda-index v='0'/>
21:01:48:    <gpu-index v='0'/>
21:01:48:    <opencl-index v='0'/>
21:01:48:  </slot>
21:01:48:  <slot id='2' type='GPU'>
21:01:48:    <gpu-index v='1'/>
21:01:48:  </slot>
21:01:48:</config>
21:02:28:WU02:FS02:Downloading 29.69MiB
21:02:34:WU02:FS02:Download 17.68%
21:02:40:WU02:FS02:Download 39.57%
21:02:46:WU02:FS02:Download 60.62%
21:02:46:13:127.0.0.1:New Web session
21:02:52:WU02:FS02:Download 81.03%
21:02:54:FS01:Unpaused
21:02:54:WU00:FS01:Starting
21:02:54:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\vince\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 12636 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
21:02:54:WU00:FS01:Started FahCore on PID 11848
21:02:54:WU00:FS01:Core PID:20872
21:02:54:WU00:FS01:FahCore 0x22 started
21:02:55:WU00:FS01:0x22:*********************** Log Started 2020-05-28T21:02:54Z ***********************
21:02:55:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
21:02:55:WU00:FS01:0x22:       Type: 0x22
21:02:55:WU00:FS01:0x22:       Core: Core22
21:02:55:WU00:FS01:0x22:    Website: https://foldingathome.org/
21:02:55:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
21:02:55:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
21:02:55:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
21:02:55:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 11848 -checkpoint 15
21:02:55:WU00:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
21:02:55:WU00:FS01:0x22:             0 -gpu 0
21:02:55:WU00:FS01:0x22:     Config: <none>
21:02:55:WU00:FS01:0x22:************************************ Build *************************************
21:02:55:WU00:FS01:0x22:    Version: 0.0.5
21:02:55:WU00:FS01:0x22:       Date: Apr 22 2020
21:02:55:WU00:FS01:0x22:       Time: 04:42:59
21:02:55:WU00:FS01:0x22: Repository: Git
21:02:55:WU00:FS01:0x22:   Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
21:02:55:WU00:FS01:0x22:     Branch: HEAD
21:02:55:WU00:FS01:0x22:   Compiler: Visual C++ 2008
21:02:55:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:02:55:WU00:FS01:0x22:   Platform: win32 10
21:02:55:WU00:FS01:0x22:       Bits: 64
21:02:55:WU00:FS01:0x22:       Mode: Release
21:02:55:WU00:FS01:0x22:************************************ System ************************************
21:02:55:WU00:FS01:0x22:        CPU: AMD Ryzen 9 4900HS with Radeon Graphics
21:02:55:WU00:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 96 Stepping 1
21:02:55:WU00:FS01:0x22:       CPUs: 16
21:02:55:WU00:FS01:0x22:     Memory: 15.42GiB
21:02:55:WU00:FS01:0x22:Free Memory: 9.45GiB
21:02:55:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
21:02:55:WU00:FS01:0x22: OS Version: 6.2
21:02:55:WU00:FS01:0x22:Has Battery: true
21:02:55:WU00:FS01:0x22: On Battery: false
21:02:55:WU00:FS01:0x22: UTC Offset: 10
21:02:55:WU00:FS01:0x22:        PID: 20872
21:02:55:WU00:FS01:0x22:        CWD: C:\Users\vince\AppData\Roaming\FAHClient\work
21:02:55:WU00:FS01:0x22:         OS: Windows 10 Home
21:02:55:WU00:FS01:0x22:    OS Arch: AMD64
21:02:55:WU00:FS01:0x22:********************************************************************************
21:02:55:WU00:FS01:0x22:Project: 14462 (Run 0, Clone 267, Gen 23)
21:02:55:WU00:FS01:0x22:Unit: 0x0000002503854c135eb39e432588c832
21:02:55:WU00:FS01:0x22:Digital signatures verified
21:02:55:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
21:02:55:WU00:FS01:0x22:Version 0.0.5
21:02:55:WU00:FS01:0x22:  Found a checkpoint file
21:02:57:WU02:FS02:Download complete
21:02:57:WU02:FS02:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11760 run:0 clone:3828 gen:3 core:0x22 unit:0x0000001080fccb0a5e6d7d035b7b3a51
21:02:57:WU02:FS02:Starting
21:02:57:WU02:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\vince\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 12636 -checkpoint 15 -gpu-vendor amd -opencl-platform 1 -opencl-device 0 -gpu 0
21:02:57:WU02:FS02:Started FahCore on PID 3952
21:02:57:WU02:FS02:Core PID:22364
21:02:57:WU02:FS02:FahCore 0x22 started
21:02:58:FS02:Paused
21:02:58:FS02:Shutting core down
21:02:58:WU02:FS02:0x22:*********************** Log Started 2020-05-28T21:02:58Z ***********************
21:02:58:WU02:FS02:0x22:*************************** Core22 Folding@home Core ***************************
21:02:58:WU02:FS02:0x22:       Type: 0x22
21:02:58:WU02:FS02:0x22:       Core: Core22
21:02:58:WU02:FS02:0x22:    Website: https://foldingathome.org/
21:02:58:WU02:FS02:0x22:  Copyright: (c) 2009-2018 foldingathome.org
21:02:58:WU02:FS02:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
21:02:58:WU02:FS02:0x22:             <rafal.wiewiora@choderalab.org>
21:02:58:WU02:FS02:0x22:       Args: -dir 02 -suffix 01 -version 706 -lifeline 3952 -checkpoint 15
21:02:58:WU02:FS02:0x22:             -gpu-vendor amd -opencl-platform 1 -opencl-device 0 -gpu 0
21:02:58:WU02:FS02:0x22:     Config: <none>
21:02:58:WU02:FS02:0x22:************************************ Build *************************************
21:02:58:WU02:FS02:0x22:    Version: 0.0.5
21:02:58:WU02:FS02:0x22:       Date: Apr 22 2020
21:02:58:WU02:FS02:0x22:       Time: 04:42:59
21:02:58:WU02:FS02:0x22: Repository: Git
21:02:58:WU02:FS02:0x22:   Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
21:02:58:WU02:FS02:0x22:     Branch: HEAD
21:02:58:WU02:FS02:0x22:   Compiler: Visual C++ 2008
21:02:58:WU02:FS02:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:02:58:WU02:FS02:0x22:   Platform: win32 10
21:02:58:WU02:FS02:0x22:       Bits: 64
21:02:58:WU02:FS02:0x22:       Mode: Release
21:02:58:WU02:FS02:0x22:************************************ System ************************************
21:02:58:WU02:FS02:0x22:        CPU: AMD Ryzen 9 4900HS with Radeon Graphics
21:02:58:WU02:FS02:0x22:     CPU ID: AuthenticAMD Family 23 Model 96 Stepping 1
21:02:58:WU02:FS02:0x22:       CPUs: 16
21:02:58:WU02:FS02:0x22:     Memory: 15.42GiB
21:02:58:WU02:FS02:0x22:Free Memory: 9.03GiB
21:02:58:WU02:FS02:0x22:    Threads: WINDOWS_THREADS
21:02:58:WU02:FS02:0x22: OS Version: 6.2
21:02:58:WU02:FS02:0x22:Has Battery: true
21:02:58:WU02:FS02:0x22: On Battery: false
21:02:58:WU02:FS02:0x22: UTC Offset: 10
21:02:58:WU02:FS02:0x22:        PID: 22364
21:02:58:WU02:FS02:0x22:        CWD: C:\Users\vince\AppData\Roaming\FAHClient\work
21:02:58:WU02:FS02:0x22:         OS: Windows 10 Home
21:02:58:WU02:FS02:0x22:    OS Arch: AMD64
21:02:58:WU02:FS02:0x22:********************************************************************************
21:02:58:WU02:FS02:0x22:Project: 11760 (Run 0, Clone 3828, Gen 3)
21:02:58:WU02:FS02:0x22:Unit: 0x0000001080fccb0a5e6d7d035b7b3a51
21:02:58:WU02:FS02:0x22:Reading tar file core.xml
21:02:58:WU02:FS02:0x22:Reading tar file integrator.xml
21:02:58:WU02:FS02:0x22:Reading tar file state.xml
21:02:58:WU02:FS02:0x22:WARNING:Console control signal 1 on PID 22364
21:02:58:WU02:FS02:0x22:Exiting, please wait. . .
21:02:58:WU02:FS02:0x22:Reading tar file system.xml
21:02:58:WU02:FS02:0x22:Digital signatures verified
21:02:58:WU02:FS02:0x22:Folding@home GPU Core22 Folding@home Core
21:02:58:WU02:FS02:0x22:Version 0.0.5
21:02:59:FS02:Unpaused
21:03:07:WU02:FS02:0x22:Completed 0 out of 2000000 steps (0%)
21:03:07:WU02:FS02:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
21:03:07:WU02:FS02:0x22:Folding@home Core Shutdown: INTERRUPTED
21:03:07:WU02:FS02:FahCore returned: INTERRUPTED (102 = 0x66)
21:03:07:WU02:FS02:Starting
21:03:07:WU02:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\vince\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 12636 -checkpoint 15 -gpu-vendor amd -opencl-platform 1 -opencl-device 0 -gpu 0
21:03:07:WU02:FS02:Started FahCore on PID 9384
21:03:07:WU02:FS02:Core PID:11548
21:03:07:WU02:FS02:FahCore 0x22 started
21:03:08:WU02:FS02:0x22:*********************** Log Started 2020-05-28T21:03:07Z ***********************
21:03:08:WU02:FS02:0x22:*************************** Core22 Folding@home Core ***************************
21:03:08:WU02:FS02:0x22:       Type: 0x22
21:03:08:WU02:FS02:0x22:       Core: Core22
21:03:08:WU02:FS02:0x22:    Website: https://foldingathome.org/
21:03:08:WU02:FS02:0x22:  Copyright: (c) 2009-2018 foldingathome.org
21:03:08:WU02:FS02:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
21:03:08:WU02:FS02:0x22:             <rafal.wiewiora@choderalab.org>
21:03:08:WU02:FS02:0x22:       Args: -dir 02 -suffix 01 -version 706 -lifeline 9384 -checkpoint 15
21:03:08:WU02:FS02:0x22:             -gpu-vendor amd -opencl-platform 1 -opencl-device 0 -gpu 0
21:03:08:WU02:FS02:0x22:     Config: <none>
21:03:08:WU02:FS02:0x22:************************************ Build *************************************
21:03:08:WU02:FS02:0x22:    Version: 0.0.5
21:03:08:WU02:FS02:0x22:       Date: Apr 22 2020
21:03:08:WU02:FS02:0x22:       Time: 04:42:59
21:03:08:WU02:FS02:0x22: Repository: Git
21:03:08:WU02:FS02:0x22:   Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
21:03:08:WU02:FS02:0x22:     Branch: HEAD
21:03:08:WU02:FS02:0x22:   Compiler: Visual C++ 2008
21:03:08:WU02:FS02:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:03:08:WU02:FS02:0x22:   Platform: win32 10
21:03:08:WU02:FS02:0x22:       Bits: 64
21:03:08:WU02:FS02:0x22:       Mode: Release
21:03:08:WU02:FS02:0x22:************************************ System ************************************
21:03:08:WU02:FS02:0x22:        CPU: AMD Ryzen 9 4900HS with Radeon Graphics
21:03:08:WU02:FS02:0x22:     CPU ID: AuthenticAMD Family 23 Model 96 Stepping 1
21:03:08:WU02:FS02:0x22:       CPUs: 16
21:03:08:WU02:FS02:0x22:     Memory: 15.42GiB
21:03:08:WU02:FS02:0x22:Free Memory: 8.78GiB
21:03:08:WU02:FS02:0x22:    Threads: WINDOWS_THREADS
21:03:08:WU02:FS02:0x22: OS Version: 6.2
21:03:08:WU02:FS02:0x22:Has Battery: true
21:03:08:WU02:FS02:0x22: On Battery: false
21:03:08:WU02:FS02:0x22: UTC Offset: 10
21:03:08:WU02:FS02:0x22:        PID: 11548
21:03:08:WU02:FS02:0x22:        CWD: C:\Users\vince\AppData\Roaming\FAHClient\work
21:03:08:WU02:FS02:0x22:         OS: Windows 10 Home
21:03:08:WU02:FS02:0x22:    OS Arch: AMD64
21:03:08:WU02:FS02:0x22:********************************************************************************
21:03:08:WU02:FS02:0x22:Project: 11760 (Run 0, Clone 3828, Gen 3)
21:03:08:WU02:FS02:0x22:Unit: 0x0000001080fccb0a5e6d7d035b7b3a51
21:03:08:WU02:FS02:0x22:Reading tar file core.xml
21:03:08:WU02:FS02:0x22:Reading tar file integrator.xml
21:03:08:WU02:FS02:0x22:Reading tar file state.xml
21:03:08:WU02:FS02:0x22:Reading tar file system.xml
21:03:08:WU02:FS02:0x22:Digital signatures verified
21:03:08:WU02:FS02:0x22:Folding@home GPU Core22 Folding@home Core
21:03:08:WU02:FS02:0x22:Version 0.0.5
21:03:10:WU00:FS01:0x22:Completed 280000 out of 2000000 steps (14%)
21:03:10:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
21:03:16:WU02:FS02:0x22:Completed 0 out of 2000000 steps (0%)
21:03:16:WU02:FS02:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
21:03:50:Removing old file 'configs/config-20200528-194212.xml'
21:03:50:Saving configuration to config.xml
21:03:50:<config>
21:03:50:  <!-- HTTP Server -->
21:03:50:  <allow v='192.168.1.0/24'/>
21:03:50:
21:03:50:  <!-- Network -->
21:03:50:  <proxy v=':8080'/>
21:03:50:
21:03:50:  <!-- Remote Command Server -->
21:03:50:  <password v='*****'/>
21:03:50:
21:03:50:  <!-- Slot Control -->
21:03:50:  <power v='FULL'/>
21:03:50:
21:03:50:  <!-- User Information -->
21:03:50:  <passkey v='*****'/>
21:03:50:  <user v='Vincent_Caballo'/>
21:03:50:
21:03:50:  <!-- Folding Slots -->
21:03:50:  <slot id='0' type='CPU'>
21:03:50:    <paused v='true'/>
21:03:50:  </slot>
21:03:50:  <slot id='1' type='GPU'>
21:03:50:    <cuda-index v='0'/>
21:03:50:    <gpu-index v='0'/>
21:03:50:    <opencl-index v='0'/>
21:03:50:  </slot>
21:03:50:  <slot id='2' type='GPU'>
21:03:50:    <gpu-index v='1'/>
21:03:50:  </slot>
21:03:50:</config>
21:06:51:WU00:FS01:0x22:Completed 300000 out of 2000000 steps (15%)
21:09:18:WU02:FS02:0x22:Completed 20000 out of 2000000 steps (1%)
21:10:38:WU00:FS01:0x22:Completed 320000 out of 2000000 steps (16%)
21:13:19:FS02:Paused
21:13:19:FS02:Shutting core down
21:13:19:WU02:FS02:0x22:WARNING:Console control signal 1 on PID 11548
21:13:19:WU02:FS02:0x22:Exiting, please wait. . .
21:13:20:WU02:FS02:FahCore returned: INTERRUPTED (102 = 0x66)
21:14:00:Removing old file 'configs/config-20200528-194319.xml'
21:14:00:Saving configuration to config.xml
21:14:00:<config>
21:14:00:  <!-- HTTP Server -->
21:14:00:  <allow v='192.168.1.0/24'/>
21:14:00:
21:14:00:  <!-- Network -->
21:14:00:  <proxy v=':8080'/>
21:14:00:
21:14:00:  <!-- Remote Command Server -->
21:14:00:  <password v='*****'/>
21:14:00:
21:14:00:  <!-- Slot Control -->
21:14:00:  <power v='FULL'/>
21:14:00:
21:14:00:  <!-- User Information -->
21:14:00:  <passkey v='*****'/>
21:14:00:  <user v='Vincent_Caballo'/>
21:14:00:
21:14:00:  <!-- Folding Slots -->
21:14:00:  <slot id='0' type='CPU'>
21:14:00:    <paused v='true'/>
21:14:00:  </slot>
21:14:00:  <slot id='1' type='GPU'>
21:14:00:    <cuda-index v='0'/>
21:14:00:    <gpu-index v='0'/>
21:14:00:    <opencl-index v='0'/>
21:14:00:  </slot>
21:14:00:  <slot id='2' type='GPU'>
21:14:00:    <gpu-index v='1'/>
21:14:00:  </slot>
21:14:00:</config>
21:14:22:WU00:FS01:0x22:Completed 340000 out of 2000000 steps (17%)
21:14:22:FS02:Unpaused
21:14:22:WU02:FS02:Starting
21:14:22:WU02:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\vince\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 12636 -checkpoint 15 -gpu-vendor amd -opencl-platform 1 -opencl-device 0 -gpu 0
21:14:22:WU02:FS02:Started FahCore on PID 12812
21:14:22:WU02:FS02:Core PID:13116
21:14:22:WU02:FS02:FahCore 0x22 started
21:14:22:WU02:FS02:0x22:*********************** Log Started 2020-05-28T21:14:22Z ***********************
21:14:22:WU02:FS02:0x22:*************************** Core22 Folding@home Core ***************************
21:14:22:WU02:FS02:0x22:       Type: 0x22
21:14:22:WU02:FS02:0x22:       Core: Core22
21:14:22:WU02:FS02:0x22:    Website: https://foldingathome.org/
21:14:23:WU02:FS02:0x22:  Copyright: (c) 2009-2018 foldingathome.org
21:14:23:WU02:FS02:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
21:14:23:WU02:FS02:0x22:             <rafal.wiewiora@choderalab.org>
21:14:23:WU02:FS02:0x22:       Args: -dir 02 -suffix 01 -version 706 -lifeline 12812 -checkpoint 15
21:14:23:WU02:FS02:0x22:             -gpu-vendor amd -opencl-platform 1 -opencl-device 0 -gpu 0
21:14:23:WU02:FS02:0x22:     Config: <none>
21:14:23:WU02:FS02:0x22:************************************ Build *************************************
21:14:23:WU02:FS02:0x22:    Version: 0.0.5
21:14:23:WU02:FS02:0x22:       Date: Apr 22 2020
21:14:23:WU02:FS02:0x22:       Time: 04:42:59
21:14:23:WU02:FS02:0x22: Repository: Git
21:14:23:WU02:FS02:0x22:   Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
21:14:23:WU02:FS02:0x22:     Branch: HEAD
21:14:23:WU02:FS02:0x22:   Compiler: Visual C++ 2008
21:14:23:WU02:FS02:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:14:23:WU02:FS02:0x22:   Platform: win32 10
21:14:23:WU02:FS02:0x22:       Bits: 64
21:14:23:WU02:FS02:0x22:       Mode: Release
21:14:23:WU02:FS02:0x22:************************************ System ************************************
21:14:23:WU02:FS02:0x22:        CPU: AMD Ryzen 9 4900HS with Radeon Graphics
21:14:23:WU02:FS02:0x22:     CPU ID: AuthenticAMD Family 23 Model 96 Stepping 1
21:14:23:WU02:FS02:0x22:       CPUs: 16
21:14:23:WU02:FS02:0x22:     Memory: 15.42GiB
21:14:23:WU02:FS02:0x22:Free Memory: 8.46GiB
21:14:23:WU02:FS02:0x22:    Threads: WINDOWS_THREADS
21:14:23:WU02:FS02:0x22: OS Version: 6.2
21:14:23:WU02:FS02:0x22:Has Battery: true
21:14:23:WU02:FS02:0x22: On Battery: false
21:14:23:WU02:FS02:0x22: UTC Offset: 10
21:14:23:WU02:FS02:0x22:        PID: 13116
21:14:23:WU02:FS02:0x22:        CWD: C:\Users\vince\AppData\Roaming\FAHClient\work
21:14:23:WU02:FS02:0x22:         OS: Windows 10 Home
21:14:23:WU02:FS02:0x22:    OS Arch: AMD64
21:14:23:WU02:FS02:0x22:********************************************************************************
21:14:23:WU02:FS02:0x22:Project: 11760 (Run 0, Clone 3828, Gen 3)
21:14:23:WU02:FS02:0x22:Unit: 0x0000001080fccb0a5e6d7d035b7b3a51
21:14:23:WU02:FS02:0x22:Digital signatures verified
21:14:23:WU02:FS02:0x22:Folding@home GPU Core22 Folding@home Core
21:14:23:WU02:FS02:0x22:Version 0.0.5
21:14:31:WU02:FS02:0x22:Completed 0 out of 2000000 steps (0%)
21:14:31:WU02:FS02:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
21:15:01:Removing old file 'configs/config-20200528-194336.xml'
21:15:01:Saving configuration to config.xml
21:15:01:<config>
21:15:01:  <!-- HTTP Server -->
21:15:01:  <allow v='192.168.1.0/24'/>
21:15:01:
21:15:01:  <!-- Network -->
21:15:01:  <proxy v=':8080'/>
21:15:01:
21:15:01:  <!-- Remote Command Server -->
21:15:01:  <password v='*****'/>
21:15:01:
21:15:01:  <!-- Slot Control -->
21:15:01:  <power v='FULL'/>
21:15:01:
21:15:01:  <!-- User Information -->
21:15:01:  <passkey v='*****'/>
21:15:01:  <user v='Vincent_Caballo'/>
21:15:01:
21:15:01:  <!-- Folding Slots -->
21:15:01:  <slot id='0' type='CPU'>
21:15:01:    <paused v='true'/>
21:15:01:  </slot>
21:15:01:  <slot id='1' type='GPU'>
21:15:01:    <cuda-index v='0'/>
21:15:01:    <gpu-index v='0'/>
21:15:01:    <opencl-index v='0'/>
21:15:01:  </slot>
21:15:01:  <slot id='2' type='GPU'>
21:15:01:    <gpu-index v='1'/>
21:15:01:  </slot>
21:15:01:</config>
JimboPalmer wrote:Joe_H's "died" is also undoubtedly 'tried' we do not execute volunteers!
Actually was supposed to be "added", wonder what I actually typed that autocorrect went to "died". Corrected my post.
According to the results you showed in GPU-Z at the top of this topic you have a device 1002 1636. The man-readable information in the master copy of GPUs.txt says it is a Renoir [Ryzen 4900HS mobile]. If you followed the instructions given above and deleted the copy of GPUs.txt that you edited, you should see that information when you restart FAH.
If your CPU can't handle the heat of running both an AVX process on your CPU and whatever GPU driver you have for device 1002 1636, maybe it's at it's at its thermal limit. GPU-Z is going to tell you the truth. Be sure you left at least one CPU-thread to supply data to your GPU.
If you are judging by the initial estimates of progress for a new project, give it time to collect enough data to project how long it will take to complete.
20:18:10: GPUs: 1
This is the last log I see with your configuration. you have one Nvidia GPU, and an OpenCL driver for it.
You also have an OpenCL driver for an AMD GPU that F@H can't see.
The Nvidia GPU seems to point to the Nvidia driver. so that should work.
MeeLee
Post by MeeLee »
I think the CPU can do more than 10k PPD.
Would be interested in seeing CPU only PPD, and GPU only PPD on this one!
They're only the first of a line of IGPs that could be interesting to fold on.
BobWilliams757
Ryzen 2400G APU
32 GB DDR4-3200
MSI GTX 1660 Super Gaming X
Post by BobWilliams757 »
I'm real interested to see what kind of PPD average these things will end up with. They are taking an interesting approach going with the Vega 8 and bumping up clock speeds quite a bit over previous APU's.
With that memory I'm going to guesstimate PPD in the 86-90K range as an average.
When people start buying the newly supported 4266 Mhz ram it should be really interesting!
Fold them if you get them!
MeeLee
Post by MeeLee »
Yes, Ryzen CPUs are very susceptible to RAM speeds. I would imagine that also translates to IGPs, as they also use that same RAM as shared VRAM.
