Overclocked GPU Projects dropping with error. -- YES.
Joxster
Hardware configuration: Intel i7 8700K | NVIDIA GTX 1080 Ti
Post by Joxster »
Hi,
Facing an issue with the GPU projects getting dropped with the error code: BAD_WORK_UNIT (114 = 0x72). Please see the log below. Is this a known issue? Is there something wrong on my end?
*********************** Log Started 2020-05-05T20:08:24Z ***********************
22:47:51:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
22:47:51:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
22:47:52:ERROR:WU00:FS01:Exception: Server did not assign work unit
22:48:15:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
22:48:36:ERROR:WU00:FS01:Exception: Failed to connect to 128.252.203.10:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
22:48:53:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
22:51:23:ERROR:WU00:FS01:Exception: Server did not assign work unit
22:51:23:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
22:51:24:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
22:51:24:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
22:51:25:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
22:51:25:ERROR:WU00:FS01:Exception: Could not get an assignment
22:54:01:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
22:54:01:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
22:54:02:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
01:37:15:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
01:37:16:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
01:37:16:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
01:37:17:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
01:37:17:ERROR:WU01:FS01:Exception: Could not get an assignment
01:37:39:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
01:40:51:ERROR:WU01:FS01:Exception: Transfer failed
01:40:52:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
01:40:53:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
01:40:53:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
01:41:15:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
01:41:36:ERROR:WU01:FS01:Exception: Failed to connect to 128.252.203.10:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
01:42:29:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
01:42:30:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
01:42:30:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
01:42:31:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
01:42:31:ERROR:WU01:FS01:Exception: Could not get an assignment
01:45:06:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
01:45:07:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
01:45:29:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
01:45:51:ERROR:WU01:FS01:Exception: Failed to connect to 3.133.76.19:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
01:49:21:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
01:49:21:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
01:49:43:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
01:50:04:ERROR:WU01:FS01:Exception: Failed to connect to 3.133.76.19:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
01:56:12:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
01:56:34:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
01:57:50:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
02:07:18:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
02:07:19:ERROR:WU01:FS01:Exception: Server did not assign work unit
******************************* Date: 2020-05-06 *******************************
02:25:14:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
02:25:18:ERROR:WU01:FS01:Exception: Server did not assign work unit
02:54:38:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
03:15:23:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
03:15:24:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
03:15:25:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
03:15:25:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
03:15:26:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
03:15:26:ERROR:WU02:FS01:Exception: Could not get an assignment
03:15:26:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
03:15:45:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
03:16:06:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 3.133.76.19:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
04:57:23:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
04:57:24:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
04:57:46:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
04:58:07:ERROR:WU01:FS01:Exception: Failed to connect to 128.252.203.10:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
04:58:29:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
04:59:39:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
04:59:40:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
04:59:40:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
04:59:41:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
04:59:41:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
04:59:41:ERROR:WU01:FS01:Exception: Could not get an assignment
05:01:17:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
05:01:17:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:01:19:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
05:01:41:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
05:02:02:ERROR:WU01:FS01:Exception: Failed to connect to 128.252.203.10:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
05:03:54:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
05:03:55:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:03:55:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
05:03:56:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:03:56:ERROR:WU01:FS01:Exception: Could not get an assignment
05:08:30:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
05:08:51:ERROR:WU01:FS01:Exception: Failed to connect to 3.133.76.19:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
05:15:00:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
05:15:00:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:15:01:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
05:15:01:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:15:01:ERROR:WU01:FS01:Exception: Could not get an assignment
05:26:05:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
05:26:27:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
05:26:48:ERROR:WU01:FS01:Exception: Failed to connect to 3.133.76.19:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
05:44:02:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
05:44:03:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:44:03:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
05:44:04:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:44:04:ERROR:WU01:FS01:Exception: Could not get an assignment
06:13:33:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
06:41:59:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
06:42:00:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
06:42:00:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
06:42:01:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
06:42:01:ERROR:WU01:FS01:Exception: Could not get an assignment
06:43:36:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
06:43:37:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
06:43:37:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
06:43:38:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
06:43:38:ERROR:WU01:FS01:Exception: Could not get an assignment
06:46:15:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
06:46:16:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
06:46:17:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
06:46:17:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
06:46:17:ERROR:WU01:FS01:Exception: Could not get an assignment
06:50:28:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
06:50:28:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
06:51:18:ERROR:WU01:FS01:Exception: Server did not assign work unit
06:57:19:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
06:57:25:ERROR:WU01:FS01:Exception: Server did not assign work unit
07:08:25:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
07:08:25:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
07:08:26:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
07:08:26:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
07:08:26:ERROR:WU01:FS01:Exception: Could not get an assignment
07:13:40:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
07:13:40:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
07:13:41:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
07:13:41:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
07:13:41:ERROR:WU01:FS01:Exception: Could not get an assignment
07:15:17:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
07:15:17:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
07:16:43:ERROR:WU01:FS01:Exception: Server did not assign work unit
07:18:15:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
07:18:36:ERROR:WU01:FS01:Exception: Failed to connect to 128.252.203.10:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
07:22:08:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
07:22:09:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
07:22:09:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
07:22:10:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
07:22:10:ERROR:WU01:FS01:Exception: Could not get an assignment
07:28:59:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
07:29:00:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
07:29:01:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
07:29:01:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
07:29:01:ERROR:WU01:FS01:Exception: Could not get an assignment
07:40:05:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
07:40:06:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
07:40:06:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
07:40:07:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
07:40:07:ERROR:WU01:FS01:Exception: Could not get an assignment
07:58:02:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
07:58:03:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
07:58:46:ERROR:WU01:FS01:Exception: Server did not assign work unit
08:27:04:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
08:27:05:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
08:27:05:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
08:27:31:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
09:21:41:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
09:21:41:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
09:21:49:ERROR:WU00:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
09:21:50:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
09:21:50:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
09:21:51:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
09:21:51:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
09:21:51:ERROR:WU00:FS01:Exception: Could not get an assignment
09:22:02:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
09:22:53:ERROR:WU00:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
09:23:11:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
09:23:32:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
09:32:13:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
09:32:13:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
09:32:14:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
09:32:14:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
09:32:15:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
09:32:15:ERROR:WU01:FS01:Exception: Could not get an assignment
09:32:15:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
09:32:16:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
09:32:17:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
09:32:17:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
09:32:17:ERROR:WU01:FS01:Exception: Could not get an assignment
09:32:34:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
09:33:16:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
09:33:41:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
09:34:53:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
09:34:53:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
09:34:54:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
09:35:15:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
09:35:38:ERROR:WU01:FS01:Exception: Server did not assign work unit
09:37:51:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
09:38:12:ERROR:WU01:FS01:Exception: Failed to connect to 128.252.203.10:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:41:44:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
09:41:45:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
09:41:45:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
09:41:46:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
09:41:46:ERROR:WU01:FS01:Exception: Could not get an assignment
09:48:36:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
09:48:36:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
09:48:37:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
09:48:37:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
09:48:37:ERROR:WU01:FS01:Exception: Could not get an assignment
Cheers
HaloJones
Re: GPU Projects dropping with error
Post by HaloJones »
We need to see how your system is configured because 9/10 there is an error in either the drivers or the configuration. If you can restart the computer and then grab the beginning of the logfile in
%APPDATA\fahclient
the file is log.txt.
single 1070
Joxster
Post by Joxster »
HaloJones wrote:We need to see how your system is configured because 9/10 there is an error in either the drivers or the configuration. If you can restart the computer and then grab the beginning of the logfile in
%APPDATA\fahclient
Thank you for your response. Followed your instructions, and below is the logfile output.
*********************** Log Started 2020-05-06T13:18:11Z ***********************
13:18:11:****************************** FAHClient ******************************
13:18:11:        Version: 7.6.9
13:18:11:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:18:11:      Copyright: 2020 foldingathome.org
13:18:11:       Homepage: https://foldingathome.org/
13:18:11:           Date: Apr 17 2020
13:18:11:           Time: 11:13:06
13:18:11:       Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
13:18:11:         Branch: master
13:18:11:       Compiler: Visual C++ 2008
13:18:11:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
13:18:11:       Platform: win32 10
13:18:11:           Bits: 32
13:18:11:           Mode: Release
13:18:11:         Config: C:\Users\Jox\AppData\Roaming\FAHClient\config.xml
13:18:11:******************************** CBang ********************************
13:18:11:           Time: 11:10:09
13:18:11:       Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
13:18:11:           Bits: 32
13:18:11:******************************* System ********************************
13:18:11:            CPU: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
13:18:11:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
13:18:11:           CPUs: 12
13:18:11:         Memory: 15.94GiB
13:18:11:    Free Memory: 12.47GiB
13:18:11:        Threads: WINDOWS_THREADS
13:18:11:     OS Version: 6.2
13:18:11:    Has Battery: false
13:18:11:     On Battery: false
13:18:11:     UTC Offset: 2
13:18:11:            PID: 16104
13:18:11:            CWD: C:\Users\Jox\AppData\Roaming\FAHClient
13:18:11:             OS: Windows 10 Home
13:18:11:        OS Arch: AMD64
13:18:11:           GPUs: 1
13:18:11:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:8 GP102 [GeForce GTX 1080 Ti] 11380
13:18:11:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:11.0
13:18:11:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:445.87
13:18:11:  Win32 Service: false
13:18:11:******************************* libFAH ********************************
13:18:11:           Date: Apr 15 2020
13:18:11:           Time: 14:53:14
13:18:11:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
13:18:11:           Bits: 32
13:18:11:***********************************************************************
13:18:11:<config>
13:18:11:  <!-- Network -->
13:18:11:  <proxy v=':8080'/>
13:18:11:
13:18:11:  <!-- Slot Control -->
13:18:11:  <pause-on-battery v='false'/>
13:18:11:
13:18:11:  <!-- User Information -->
13:18:11:  <passkey v='*****'/>
13:18:11:  <team v='54196'/>
13:18:11:  <user v='Joxster'/>
13:18:11:
13:18:11:  <!-- Folding Slots -->
13:18:11:  <slot id='0' type='CPU'>
13:18:11:    <paused v='true'/>
13:18:11:  </slot>
13:18:11:  <slot id='1' type='GPU'/>
13:18:11:</config>
13:18:11:Trying to access database...
13:18:11:Successfully acquired database lock
13:18:11:Enabled folding slot 00: PAUSED cpu:10 (by user)
13:18:11:Enabled folding slot 01: READY gpu:0:GP102 [GeForce GTX 1080 Ti] 11380
13:18:11:WU00:FS01:Connecting to 65.254.110.245:80
13:18:12:WU00:FS01:Assigned to work server 52.224.109.74
13:18:12:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GP102 [GeForce GTX 1080 Ti] 11380 from 52.224.109.74
13:18:12:WU00:FS01:Connecting to 52.224.109.74:8080
13:18:18:WU00:FS01:Downloading 161.41MiB
13:18:24:WU00:FS01:Download 9.49%
Cheers
Joxster
Post by Joxster »
Just to let you know, I left my PC on overnight with only the GPU slot folding, and this morning it shows the status of the GPU slot as "Failed". All of the WUs it downloaded during the night had also failed.
Post by foldy »
Can you install latest FahClient 7.6.13?
HaloJones
Post by HaloJones »
config looks alright. Is the card running stock?
definitely install the latest client, it should help you get work and then if that work fails we can see more detail as to why. At the moment, all we can really see is that you'r enot getting assigned work which is a common problem I'm afraid.
single 1070
Joxster
Post by Joxster »
foldy wrote:Can you install latest FahClient 7.6.13?
HaloJones wrote:definitely install the latest client, it should help you get work and then if that work fails we can see more detail as to why.
I was not even aware that there was a new client. Downloaded and installed 7.6.13 earlier, and the GPU seems to be folding fine now. No errors so far :)
HaloJones wrote:config looks alright. Is the card running stock? At the moment, all we can really see is that you'r enot getting assigned work which is a common problem I'm afraid.
Yes, the card is running stock, and the config hasn't changed since I started folding at the beginning of March, so I was quite sure that the config wasn't the issue. Also, I am aware about the lack of WUs, so no complaints about that, just that the WUs which were getting assigned were dropping, and that seems to be fixed with the new client now.
Thank you both for your help!
Cheers
Joxster
Post by Joxster »
Joxster wrote:The GPU seems to be folding fine now. No errors so far :)
The WUs which were getting assigned were dropping, and that seems to be fixed with the new client now.
Spoke too soon. I see the issue happening still. Current logs below. :e(
09:24:19:WU00:FS01:Connecting to assign2.foldingathome.org:80
09:24:19:WU00:FS01:Assigned to work server 13.82.98.119
09:24:19:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GP102 [GeForce GTX 1080 Ti] 11380 from 13.82.98.119
09:24:19:WU00:FS01:Connecting to 13.82.98.119:8080
09:25:07:WU00:FS01:Downloading 161.39MiB
09:25:13:WU00:FS01:Download 10.92%
09:25:19:WU00:FS01:Download 25.06%
09:25:25:WU00:FS01:Download 40.16%
09:25:31:WU00:FS01:Download 54.95%
09:25:37:WU00:FS01:Download 70.29%
09:25:43:WU00:FS01:Download 84.73%
09:25:49:WU00:FS01:Download 99.61%
09:25:49:WU00:FS01:Download complete
09:25:49:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13876 run:0 clone:1607 gen:68 core:0x22 unit:0x000000580d5262775e7cf10a0b37665d
09:25:49:WU00:FS01:Starting
09:25:49:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Jox\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 16736 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
09:25:49:WU00:FS01:Started FahCore on PID 15316
09:25:49:WU00:FS01:Core PID:18908
09:25:49:WU00:FS01:FahCore 0x22 started
09:25:49:WU00:FS01:0x22:*********************** Log Started 2020-05-07T09:25:49Z ***********************
09:25:49:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
09:25:49:WU00:FS01:0x22:       Type: 0x22
09:25:49:WU00:FS01:0x22:       Core: Core22
09:25:49:WU00:FS01:0x22:    Website: https://foldingathome.org/
09:25:49:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
09:25:49:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
09:25:49:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
09:25:49:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 15316 -checkpoint 15
09:25:49:WU00:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
09:25:49:WU00:FS01:0x22:             0 -gpu 0
09:25:49:WU00:FS01:0x22:     Config: <none>
09:25:49:WU00:FS01:0x22:************************************ Build *************************************
09:25:49:WU00:FS01:0x22:    Version: 0.0.5
09:25:49:WU00:FS01:0x22:       Date: Apr 22 2020
09:25:49:WU00:FS01:0x22:       Time: 04:42:59
09:25:49:WU00:FS01:0x22: Repository: Git
09:25:49:WU00:FS01:0x22:   Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
09:25:49:WU00:FS01:0x22:     Branch: HEAD
09:25:49:WU00:FS01:0x22:   Compiler: Visual C++ 2008
09:25:49:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
09:25:49:WU00:FS01:0x22:   Platform: win32 10
09:25:49:WU00:FS01:0x22:       Bits: 64
09:25:49:WU00:FS01:0x22:       Mode: Release
09:25:49:WU00:FS01:0x22:************************************ System ************************************
09:25:49:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
09:25:49:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
09:25:49:WU00:FS01:0x22:       CPUs: 12
09:25:49:WU00:FS01:0x22:     Memory: 15.94GiB
09:25:49:WU00:FS01:0x22:Free Memory: 9.24GiB
09:25:49:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
09:25:49:WU00:FS01:0x22: OS Version: 6.2
09:25:50:WU00:FS01:0x22:Has Battery: false
09:25:50:WU00:FS01:0x22: On Battery: false
09:25:50:WU00:FS01:0x22: UTC Offset: 2
09:25:50:WU00:FS01:0x22:        PID: 18908
09:25:50:WU00:FS01:0x22:        CWD: C:\Users\Jox\AppData\Roaming\FAHClient\work
09:25:50:WU00:FS01:0x22:         OS: Windows 10 Home
09:25:50:WU00:FS01:0x22:    OS Arch: AMD64
09:25:50:WU00:FS01:0x22:********************************************************************************
09:25:50:WU00:FS01:0x22:Project: 13876 (Run 0, Clone 1607, Gen 68)
09:25:50:WU00:FS01:0x22:Unit: 0x000000580d5262775e7cf10a0b37665d
09:25:50:WU00:FS01:0x22:Reading tar file core.xml
09:25:50:WU00:FS01:0x22:Reading tar file integrator.xml
09:25:50:WU00:FS01:0x22:Reading tar file state.xml
09:25:50:WU00:FS01:0x22:Reading tar file system.xml
09:25:50:WU00:FS01:0x22:Digital signatures verified
09:25:50:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
09:25:50:WU00:FS01:0x22:Version 0.0.5
09:26:35:WU00:FS01:0x22:Completed 0 out of 1000000 steps (0%)
09:26:35:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
09:28:27:WU00:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
09:29:58:WU00:FS01:0x22:ERROR:exception: clWaitForEvents
09:29:58:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
09:29:58:WU00:FS01:0x22:Saving result file checkpt.crc
09:29:58:WU00:FS01:0x22:Saving result file science.log
09:29:58:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
09:29:58:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
09:29:58:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:13876 run:0 clone:1607 gen:68 core:0x22 unit:0x000000580d5262775e7cf10a0b37665d
09:29:58:WU00:FS01:Uploading 10.00KiB to 13.82.98.119
09:29:58:WU00:FS01:Connecting to 13.82.98.119:8080
09:29:59:WU00:FS01:Upload complete
09:29:59:WU00:FS01:Server responded WORK_ACK (400)
09:29:59:WU00:FS01:Cleaning up
09:29:59:WU01:FS01:Connecting to assign1.foldingathome.org:80
09:29:59:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
09:29:59:WU01:FS01:Connecting to assign2.foldingathome.org:80
09:30:00:WU01:FS01:Assigned to work server 18.188.125.154
09:30:00:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP102 [GeForce GTX 1080 Ti] 11380 from 18.188.125.154
09:30:00:WU01:FS01:Connecting to 18.188.125.154:8080
09:30:01:WU01:FS01:Downloading 6.56MiB
09:30:04:WU01:FS01:Download complete
09:30:04:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13404 run:89 clone:41 gen:0 core:0x22 unit:0x0000000012bc7d9a5eb3a3996825c96f
09:30:04:WU01:FS01:Starting
09:30:04:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Jox\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 16736 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
09:30:04:WU01:FS01:Started FahCore on PID 19572
09:30:04:WU01:FS01:Core PID:416
09:30:04:WU01:FS01:FahCore 0x22 started
09:30:05:WU01:FS01:0x22:*********************** Log Started 2020-05-07T09:30:04Z ***********************
09:30:05:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
09:30:05:WU01:FS01:0x22:       Type: 0x22
09:30:05:WU01:FS01:0x22:       Core: Core22
09:30:05:WU01:FS01:0x22:    Website: https://foldingathome.org/
09:30:05:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
09:30:05:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
09:30:05:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
09:30:05:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 19572 -checkpoint 15
09:30:05:WU01:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
09:30:05:WU01:FS01:0x22:             0 -gpu 0
09:30:05:WU01:FS01:0x22:     Config: <none>
09:30:05:WU01:FS01:0x22:************************************ Build *************************************
09:30:05:WU01:FS01:0x22:    Version: 0.0.5
09:30:05:WU01:FS01:0x22:       Date: Apr 22 2020
09:30:05:WU01:FS01:0x22:       Time: 04:42:59
09:30:05:WU01:FS01:0x22: Repository: Git
09:30:05:WU01:FS01:0x22:   Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
09:30:05:WU01:FS01:0x22:     Branch: HEAD
09:30:05:WU01:FS01:0x22:   Compiler: Visual C++ 2008
09:30:05:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
09:30:05:WU01:FS01:0x22:   Platform: win32 10
09:30:05:WU01:FS01:0x22:       Bits: 64
09:30:05:WU01:FS01:0x22:       Mode: Release
09:30:05:WU01:FS01:0x22:************************************ System ************************************
09:30:05:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
09:30:05:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
09:30:05:WU01:FS01:0x22:       CPUs: 12
09:30:05:WU01:FS01:0x22:     Memory: 15.94GiB
09:30:05:WU01:FS01:0x22:Free Memory: 9.30GiB
09:30:05:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
09:30:05:WU01:FS01:0x22: OS Version: 6.2
09:30:05:WU01:FS01:0x22:Has Battery: false
09:30:05:WU01:FS01:0x22: On Battery: false
09:30:05:WU01:FS01:0x22: UTC Offset: 2
09:30:05:WU01:FS01:0x22:        PID: 416
09:30:05:WU01:FS01:0x22:        CWD: C:\Users\Jox\AppData\Roaming\FAHClient\work
09:30:05:WU01:FS01:0x22:         OS: Windows 10 Home
09:30:05:WU01:FS01:0x22:    OS Arch: AMD64
09:30:05:WU01:FS01:0x22:********************************************************************************
09:30:05:WU01:FS01:0x22:Project: 13404 (Run 89, Clone 41, Gen 0)
09:30:05:WU01:FS01:0x22:Unit: 0x0000000012bc7d9a5eb3a3996825c96f
09:30:05:WU01:FS01:0x22:Reading tar file core.xml
09:30:05:WU01:FS01:0x22:Reading tar file integrator.xml
09:30:05:WU01:FS01:0x22:Reading tar file state.xml
09:30:05:WU01:FS01:0x22:Reading tar file system.xml
09:30:05:WU01:FS01:0x22:Digital signatures verified
09:30:05:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
09:30:05:WU01:FS01:0x22:Version 0.0.5
09:30:12:WU01:FS01:0x22:Completed 0 out of 1000000 steps (0%)
09:30:12:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
09:32:06:WU01:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
09:33:58:WU01:FS01:0x22:Completed 20000 out of 1000000 steps (2%)
09:35:51:WU01:FS01:0x22:Completed 30000 out of 1000000 steps (3%)
09:37:44:WU01:FS01:0x22:Completed 40000 out of 1000000 steps (4%)
09:39:38:WU01:FS01:0x22:Completed 50000 out of 1000000 steps (5%)
09:41:32:WU01:FS01:0x22:Completed 60000 out of 1000000 steps (6%)
09:43:24:WU01:FS01:0x22:Completed 70000 out of 1000000 steps (7%)
09:45:17:WU01:FS01:0x22:Completed 80000 out of 1000000 steps (8%)
09:47:08:WU01:FS01:0x22:Completed 90000 out of 1000000 steps (9%)
09:48:58:WU01:FS01:0x22:Completed 100000 out of 1000000 steps (10%)
09:50:48:WU01:FS01:0x22:Completed 110000 out of 1000000 steps (11%)
09:52:38:WU01:FS01:0x22:Completed 120000 out of 1000000 steps (12%)
09:54:29:WU01:FS01:0x22:Completed 130000 out of 1000000 steps (13%)
09:56:21:WU01:FS01:0x22:Completed 140000 out of 1000000 steps (14%)
09:58:12:WU01:FS01:0x22:Completed 150000 out of 1000000 steps (15%)
10:00:03:WU01:FS01:0x22:Completed 160000 out of 1000000 steps (16%)
10:01:54:WU01:FS01:0x22:Completed 170000 out of 1000000 steps (17%)
10:03:46:WU01:FS01:0x22:Completed 180000 out of 1000000 steps (18%)
10:05:37:WU01:FS01:0x22:Completed 190000 out of 1000000 steps (19%)
10:07:28:WU01:FS01:0x22:Completed 200000 out of 1000000 steps (20%)
10:09:18:WU01:FS01:0x22:Completed 210000 out of 1000000 steps (21%)
10:11:09:WU01:FS01:0x22:Completed 220000 out of 1000000 steps (22%)
10:13:01:WU01:FS01:0x22:Completed 230000 out of 1000000 steps (23%)
10:14:57:WU01:FS01:0x22:Completed 240000 out of 1000000 steps (24%)
10:16:50:WU01:FS01:0x22:Completed 250000 out of 1000000 steps (25%)
10:18:47:WU01:FS01:0x22:Completed 260000 out of 1000000 steps (26%)
10:18:50:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
10:20:40:WU01:FS01:0x22:Completed 270000 out of 1000000 steps (27%)
10:22:33:WU01:FS01:0x22:Completed 280000 out of 1000000 steps (28%)
10:24:31:WU01:FS01:0x22:Completed 290000 out of 1000000 steps (29%)
10:26:32:WU01:FS01:0x22:Completed 300000 out of 1000000 steps (30%)
10:28:24:WU01:FS01:0x22:Completed 310000 out of 1000000 steps (31%)
10:30:16:WU01:FS01:0x22:Completed 320000 out of 1000000 steps (32%)
10:32:08:WU01:FS01:0x22:Completed 330000 out of 1000000 steps (33%)
10:34:01:WU01:FS01:0x22:Completed 340000 out of 1000000 steps (34%)
10:35:53:WU01:FS01:0x22:Completed 350000 out of 1000000 steps (35%)
10:37:45:WU01:FS01:0x22:Completed 360000 out of 1000000 steps (36%)
10:39:38:WU01:FS01:0x22:Completed 370000 out of 1000000 steps (37%)
10:41:30:WU01:FS01:0x22:Completed 380000 out of 1000000 steps (38%)
10:43:22:WU01:FS01:0x22:Completed 390000 out of 1000000 steps (39%)
10:45:13:WU01:FS01:0x22:Completed 400000 out of 1000000 steps (40%)
10:47:04:WU01:FS01:0x22:Completed 410000 out of 1000000 steps (41%)
10:48:57:WU01:FS01:0x22:Completed 420000 out of 1000000 steps (42%)
10:50:49:WU01:FS01:0x22:Completed 430000 out of 1000000 steps (43%)
10:52:41:WU01:FS01:0x22:Completed 440000 out of 1000000 steps (44%)
10:54:33:WU01:FS01:0x22:Completed 450000 out of 1000000 steps (45%)
10:56:26:WU01:FS01:0x22:Completed 460000 out of 1000000 steps (46%)
10:58:18:WU01:FS01:0x22:Completed 470000 out of 1000000 steps (47%)
11:00:10:WU01:FS01:0x22:Completed 480000 out of 1000000 steps (48%)
11:02:03:WU01:FS01:0x22:Completed 490000 out of 1000000 steps (49%)
11:03:55:WU01:FS01:0x22:Completed 500000 out of 1000000 steps (50%)
11:05:46:WU01:FS01:0x22:Completed 510000 out of 1000000 steps (51%)
11:07:39:WU01:FS01:0x22:Completed 520000 out of 1000000 steps (52%)
11:09:29:WU01:FS01:0x22:Completed 530000 out of 1000000 steps (53%)
11:11:19:WU01:FS01:0x22:Completed 540000 out of 1000000 steps (54%)
11:13:08:WU01:FS01:0x22:Completed 550000 out of 1000000 steps (55%)
11:14:58:WU01:FS01:0x22:Completed 560000 out of 1000000 steps (56%)
11:16:48:WU01:FS01:0x22:Completed 570000 out of 1000000 steps (57%)
11:18:38:WU01:FS01:0x22:Completed 580000 out of 1000000 steps (58%)
11:20:28:WU01:FS01:0x22:Completed 590000 out of 1000000 steps (59%)
11:22:17:WU01:FS01:0x22:Completed 600000 out of 1000000 steps (60%)
11:24:07:WU01:FS01:0x22:Completed 610000 out of 1000000 steps (61%)
11:25:57:WU01:FS01:0x22:Completed 620000 out of 1000000 steps (62%)
11:27:46:WU01:FS01:0x22:Completed 630000 out of 1000000 steps (63%)
11:29:36:WU01:FS01:0x22:Completed 640000 out of 1000000 steps (64%)
11:31:26:WU01:FS01:0x22:Completed 650000 out of 1000000 steps (65%)
11:33:20:WU01:FS01:0x22:Completed 660000 out of 1000000 steps (66%)
11:35:15:WU01:FS01:0x22:Completed 670000 out of 1000000 steps (67%)
11:37:10:WU01:FS01:0x22:Completed 680000 out of 1000000 steps (68%)
11:39:05:WU01:FS01:0x22:Completed 690000 out of 1000000 steps (69%)
11:41:03:WU01:FS01:0x22:Completed 700000 out of 1000000 steps (70%)
11:43:09:WU01:FS01:0x22:Completed 710000 out of 1000000 steps (71%)
11:45:09:WU01:FS01:0x22:Completed 720000 out of 1000000 steps (72%)
11:47:02:WU01:FS01:0x22:Completed 730000 out of 1000000 steps (73%)
11:48:54:WU01:FS01:0x22:Completed 740000 out of 1000000 steps (74%)
11:50:46:WU01:FS01:0x22:Completed 750000 out of 1000000 steps (75%)
11:52:43:WU01:FS01:0x22:Completed 760000 out of 1000000 steps (76%)
11:54:39:WU01:FS01:0x22:Completed 770000 out of 1000000 steps (77%)
11:56:36:WU01:FS01:0x22:Completed 780000 out of 1000000 steps (78%)
11:58:34:WU01:FS01:0x22:Completed 790000 out of 1000000 steps (79%)
12:00:30:WU01:FS01:0x22:Completed 800000 out of 1000000 steps (80%)
12:02:23:WU01:FS01:0x22:Completed 810000 out of 1000000 steps (81%)
12:04:18:WU01:FS01:0x22:Completed 820000 out of 1000000 steps (82%)
12:06:15:WU01:FS01:0x22:Completed 830000 out of 1000000 steps (83%)
12:08:08:WU01:FS01:0x22:Completed 840000 out of 1000000 steps (84%)
12:10:01:WU01:FS01:0x22:Completed 850000 out of 1000000 steps (85%)
12:11:55:WU01:FS01:0x22:Completed 860000 out of 1000000 steps (86%)
12:13:51:WU01:FS01:0x22:Completed 870000 out of 1000000 steps (87%)
12:15:49:WU01:FS01:0x22:Completed 880000 out of 1000000 steps (88%)
12:17:45:WU01:FS01:0x22:Completed 890000 out of 1000000 steps (89%)
12:19:39:WU01:FS01:0x22:Completed 900000 out of 1000000 steps (90%)
12:21:33:WU01:FS01:0x22:Completed 910000 out of 1000000 steps (91%)
12:23:25:WU01:FS01:0x22:Completed 920000 out of 1000000 steps (92%)
12:25:18:WU01:FS01:0x22:Completed 930000 out of 1000000 steps (93%)
12:27:10:WU01:FS01:0x22:Completed 940000 out of 1000000 steps (94%)
12:29:03:WU01:FS01:0x22:Completed 950000 out of 1000000 steps (95%)
12:30:55:WU01:FS01:0x22:Completed 960000 out of 1000000 steps (96%)
12:32:49:WU01:FS01:0x22:Completed 970000 out of 1000000 steps (97%)
12:34:43:WU01:FS01:0x22:Completed 980000 out of 1000000 steps (98%)
12:36:42:WU01:FS01:0x22:Completed 990000 out of 1000000 steps (99%)
12:36:43:WU00:FS01:Connecting to assign1.foldingathome.org:80
12:36:44:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
12:36:44:WU00:FS01:Connecting to assign2.foldingathome.org:80
12:36:44:WU00:FS01:Assigned to work server 3.133.76.19
12:36:44:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GP102 [GeForce GTX 1080 Ti] 11380 from 3.133.76.19
12:36:44:WU00:FS01:Connecting to 3.133.76.19:8080
12:37:41:WU00:FS01:Downloading 20.50MiB
12:37:47:WU00:FS01:Download 7.32%
12:37:53:WU00:FS01:Download 42.67%
12:37:57:WU00:FS01:Download complete
12:37:57:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14445 run:0 clone:1335 gen:1 core:0x22 unit:0x0000000203854c135ea7b8914b7ee23c
12:38:44:WU01:FS01:0x22:Completed 1000000 out of 1000000 steps (100%)
12:38:45:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
12:38:45:WU01:FS01:0x22:Saving result file checkpointState.xml
12:38:45:WU01:FS01:0x22:Saving result file checkpt.crc
12:38:45:WU01:FS01:0x22:Saving result file globals.csv
12:38:45:WU01:FS01:0x22:Saving result file positions.xtc
12:38:45:WU01:FS01:0x22:Saving result file science.log
12:38:45:WU01:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
12:38:46:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
12:38:46:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:13404 run:89 clone:41 gen:0 core:0x22 unit:0x0000000012bc7d9a5eb3a3996825c96f
12:38:46:WU01:FS01:Uploading 4.90MiB to 18.188.125.154
12:38:46:WU01:FS01:Connecting to 18.188.125.154:8080
12:38:46:WU00:FS01:Starting
12:38:46:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Jox\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 16736 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
12:38:46:WU00:FS01:Started FahCore on PID 13948
12:38:46:WU00:FS01:Core PID:9744
12:38:46:WU00:FS01:FahCore 0x22 started
12:38:47:WU00:FS01:0x22:*********************** Log Started 2020-05-07T12:38:46Z ***********************
12:38:47:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
12:38:47:WU00:FS01:0x22:       Type: 0x22
12:38:47:WU00:FS01:0x22:       Core: Core22
12:38:47:WU00:FS01:0x22:    Website: https://foldingathome.org/
12:38:47:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
12:38:47:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
12:38:47:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
12:38:47:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 13948 -checkpoint 15
12:38:47:WU00:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
12:38:47:WU00:FS01:0x22:             0 -gpu 0
12:38:47:WU00:FS01:0x22:     Config: <none>
12:38:47:WU00:FS01:0x22:************************************ Build *************************************
12:38:47:WU00:FS01:0x22:    Version: 0.0.5
12:38:47:WU00:FS01:0x22:       Date: Apr 22 2020
12:38:47:WU00:FS01:0x22:       Time: 04:42:59
12:38:47:WU00:FS01:0x22: Repository: Git
12:38:47:WU00:FS01:0x22:   Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
12:38:47:WU00:FS01:0x22:     Branch: HEAD
12:38:47:WU00:FS01:0x22:   Compiler: Visual C++ 2008
12:38:47:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:38:47:WU00:FS01:0x22:   Platform: win32 10
12:38:47:WU00:FS01:0x22:       Bits: 64
12:38:47:WU00:FS01:0x22:       Mode: Release
12:38:47:WU00:FS01:0x22:************************************ System ************************************
12:38:47:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
12:38:47:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
12:38:47:WU00:FS01:0x22:       CPUs: 12
12:38:47:WU00:FS01:0x22:     Memory: 15.94GiB
12:38:47:WU00:FS01:0x22:Free Memory: 9.33GiB
12:38:47:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
12:38:47:WU00:FS01:0x22: OS Version: 6.2
12:38:47:WU00:FS01:0x22:Has Battery: false
12:38:47:WU00:FS01:0x22: On Battery: false
12:38:47:WU00:FS01:0x22: UTC Offset: 2
12:38:47:WU00:FS01:0x22:        PID: 9744
12:38:47:WU00:FS01:0x22:        CWD: C:\Users\Jox\AppData\Roaming\FAHClient\work
12:38:47:WU00:FS01:0x22:         OS: Windows 10 Home
12:38:47:WU00:FS01:0x22:    OS Arch: AMD64
12:38:47:WU00:FS01:0x22:********************************************************************************
12:38:47:WU00:FS01:0x22:Project: 14445 (Run 0, Clone 1335, Gen 1)
12:38:47:WU00:FS01:0x22:Unit: 0x0000000203854c135ea7b8914b7ee23c
12:38:47:WU00:FS01:0x22:Reading tar file core.xml
12:38:47:WU00:FS01:0x22:Reading tar file integrator.xml
12:38:47:WU00:FS01:0x22:Reading tar file state.xml
12:38:47:WU00:FS01:0x22:Reading tar file system.xml
12:38:47:WU00:FS01:0x22:Digital signatures verified
12:38:47:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
12:38:47:WU00:FS01:0x22:Version 0.0.5
12:38:52:WU01:FS01:Upload 51.06%
12:38:57:WU01:FS01:Upload complete
12:38:57:WU01:FS01:Server responded WORK_ACK (400)
12:38:57:WU01:FS01:Final credit estimate, 171074.00 points
12:38:57:WU01:FS01:Cleaning up
12:39:01:WU00:FS01:0x22:Completed 0 out of 2000000 steps (0%)
12:39:01:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
12:40:08:WU00:FS01:0x22:ERROR:exception: clWaitForEvents
12:40:08:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
12:40:08:WU00:FS01:0x22:Saving result file checkpt.crc
12:40:08:WU00:FS01:0x22:Saving result file science.log
12:40:08:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
12:40:09:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
12:40:09:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:14445 run:0 clone:1335 gen:1 core:0x22 unit:0x0000000203854c135ea7b8914b7ee23c
12:40:09:WU00:FS01:Uploading 2.90KiB to 3.133.76.19
12:40:09:WU00:FS01:Connecting to 3.133.76.19:8080
12:40:09:WU01:FS01:Connecting to assign1.foldingathome.org:80
12:40:10:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
12:40:10:WU01:FS01:Connecting to assign2.foldingathome.org:80
12:40:10:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
12:40:10:WU01:FS01:Connecting to assign3.foldingathome.org:80
12:40:11:WU01:FS01:Assigned to work server 13.82.98.119
12:40:11:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP102 [GeForce GTX 1080 Ti] 11380 from 13.82.98.119
12:40:11:WU01:FS01:Connecting to 13.82.98.119:8080
12:40:32:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
12:40:32:WU01:FS01:Connecting to 13.82.98.119:80
12:41:15:WU01:FS01:Downloading 70.43MiB
12:41:21:WU01:FS01:Download 11.98%
12:41:27:WU01:FS01:Download 31.24%
12:41:33:WU01:FS01:Download 51.83%
12:41:39:WU01:FS01:Download 72.77%
12:41:45:WU01:FS01:Download 94.78%
12:41:46:WU01:FS01:Download complete
12:41:46:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14432 run:0 clone:923 gen:36 core:0x22 unit:0x000000380d5262775e8b4d5c30f8e7a1
12:41:46:WU01:FS01:Starting
12:41:46:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Jox\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 16736 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
12:41:46:WU01:FS01:Started FahCore on PID 19112
12:41:46:WU01:FS01:Core PID:8132
12:41:46:WU01:FS01:FahCore 0x22 started
12:41:46:WARNING:WU00:FS01:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
12:41:46:WU00:FS01:Trying to send results to collection server
12:41:46:WU00:FS01:Uploading 2.90KiB to 3.21.157.11
12:41:46:WU00:FS01:Connecting to 3.21.157.11:8080
12:41:47:WU01:FS01:0x22:*********************** Log Started 2020-05-07T12:41:46Z ***********************
12:41:47:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
12:41:47:WU01:FS01:0x22:       Type: 0x22
12:41:47:WU01:FS01:0x22:       Core: Core22
12:41:47:WU01:FS01:0x22:    Website: https://foldingathome.org/
12:41:47:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
12:41:47:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
12:41:47:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
12:41:47:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 19112 -checkpoint 15
12:41:47:WU01:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
12:41:47:WU01:FS01:0x22:             0 -gpu 0
12:41:47:WU01:FS01:0x22:     Config: <none>
12:41:47:WU01:FS01:0x22:************************************ Build *************************************
12:41:47:WU01:FS01:0x22:    Version: 0.0.5
12:41:47:WU01:FS01:0x22:       Date: Apr 22 2020
12:41:47:WU01:FS01:0x22:       Time: 04:42:59
12:41:47:WU01:FS01:0x22: Repository: Git
12:41:47:WU01:FS01:0x22:   Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
12:41:47:WU01:FS01:0x22:     Branch: HEAD
12:41:47:WU01:FS01:0x22:   Compiler: Visual C++ 2008
12:41:47:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:41:47:WU01:FS01:0x22:   Platform: win32 10
12:41:47:WU01:FS01:0x22:       Bits: 64
12:41:47:WU01:FS01:0x22:       Mode: Release
12:41:47:WU01:FS01:0x22:************************************ System ************************************
12:41:47:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
12:41:47:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
12:41:47:WU01:FS01:0x22:       CPUs: 12
12:41:47:WU01:FS01:0x22:     Memory: 15.94GiB
12:41:47:WU01:FS01:0x22:Free Memory: 9.34GiB
12:41:47:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
12:41:47:WU01:FS01:0x22: OS Version: 6.2
12:41:47:WU01:FS01:0x22:Has Battery: false
12:41:47:WU01:FS01:0x22: On Battery: false
12:41:47:WU01:FS01:0x22: UTC Offset: 2
12:41:47:WU01:FS01:0x22:        PID: 8132
12:41:47:WU01:FS01:0x22:        CWD: C:\Users\Jox\AppData\Roaming\FAHClient\work
12:41:47:WU01:FS01:0x22:         OS: Windows 10 Home
12:41:47:WU01:FS01:0x22:    OS Arch: AMD64
12:41:47:WU01:FS01:0x22:********************************************************************************
12:41:47:WU01:FS01:0x22:Project: 14432 (Run 0, Clone 923, Gen 36)
12:41:47:WU01:FS01:0x22:Unit: 0x000000380d5262775e8b4d5c30f8e7a1
12:41:47:WU01:FS01:0x22:Reading tar file core.xml
12:41:47:WU01:FS01:0x22:Reading tar file integrator.xml
12:41:47:WU01:FS01:0x22:Reading tar file state.xml
12:41:47:WU01:FS01:0x22:Reading tar file system.xml
12:41:47:WU00:FS01:Upload complete
12:41:47:WU01:FS01:0x22:Digital signatures verified
12:41:47:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
12:41:47:WU01:FS01:0x22:Version 0.0.5
12:41:47:WU00:FS01:Server responded WORK_ACK (400)
12:41:47:WU00:FS01:Cleaning up
12:41:55:WU01:FS01:0x22:Completed 0 out of 2000000 steps (0%)
12:41:55:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
12:43:48:WU01:FS01:0x22:Completed 20000 out of 2000000 steps (1%)
12:44:30:WU01:FS01:0x22:ERROR:exception: clWaitForEvents
12:44:30:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
12:44:30:WU01:FS01:0x22:Saving result file checkpt.crc
12:44:30:WU01:FS01:0x22:Saving result file science.log
12:44:30:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
12:44:31:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
12:44:31:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:14432 run:0 clone:923 gen:36 core:0x22 unit:0x000000380d5262775e8b4d5c30f8e7a1
12:44:31:WU01:FS01:Uploading 10.00KiB to 13.82.98.119
12:44:31:WU01:FS01:Connecting to 13.82.98.119:8080
12:44:31:WU00:FS01:Connecting to assign1.foldingathome.org:80
12:44:31:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
12:44:31:WU00:FS01:Connecting to assign2.foldingathome.org:80
12:44:32:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
12:44:32:WU00:FS01:Connecting to assign3.foldingathome.org:80
12:44:32:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
12:44:32:WU00:FS01:Connecting to assign4.foldingathome.org:80
12:44:33:WU00:FS01:Assigned to work server 128.252.203.10
12:44:33:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GP102 [GeForce GTX 1080 Ti] 11380 from 128.252.203.10
12:44:33:WU00:FS01:Connecting to 128.252.203.10:8080
12:44:46:WU01:FS01:Upload complete
12:44:46:WU01:FS01:Server responded WORK_ACK (400)
12:44:46:WU01:FS01:Cleaning up
12:45:00:ERROR:WU00:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
Cheers
HaloJones
Post by HaloJones »
So it completed a 13404 but dropped 13876, 14445, 14432
13404 is 58330 atoms,
13876 is 159142 atoms,
14445 is 216707 atoms,
14432 is 148633 atoms
Not saying there's enough evidence to be proof but your card successfully ran a small unit and failed on three largish ones. Can you try downclocking the card by 200MHz and just see whether that makes any difference.
single 1070
Joxster
Post by Joxster »
HaloJones wrote:So it completed a 13404 but dropped 13876, 14445, 14432
I turned the GPU core clock down by 200Mhz, but it just dropped another project. Any other ideas mate?
HaloJones
Post by HaloJones »
you could try lowering the memory clock. but the fact that it works with some and not others suggests the software is set up ok.
the fact is that fah is tough self-checking compute software. that means that hardware that can do simple things (like games) may fail. It's like how back in the day we used to use Prime95 to test our overclocked cpus - if it could pass Prime95 then it was stable. if it couldn't, then it wasn't.
when fah is running, use something like afterburner to monitor the temperatures, voltages, etc. I've lost a fair number of cards to fah because it pushes them so much harder than any other kind of software.
single 1070
Joxster
Post by Joxster »
HaloJones wrote:you could try lowering the memory clock. but the fact that it works with some and not others suggests the software is set up ok.
I wouldn't lower the memory clock, as I don't think that has any bearing here. Yeah, I'm well versed with Prime95. The GPU equivalent test of Prime95 should be FurMark I guess, and I ran a GPU stress test on FurMark with absolutely no issues. Steady FPS & temperatures.
I keep CPUID HWMonitor open at all times when the FAH client is running, and keep checking on temps, voltages, clocks etc. There are no anomalies found. At full load on the GPU while its folding, the temperature does not cross 78C, which is nowhere close to the limit of my card, the voltage is stable and normal.
I would like to believe that my GPU is not failing. Looks like the powers that be just don't want me to be folding with my GPU, lol :P
Cheers
Joxster wrote:...The GPU equivalent test of Prime95 should be FurMark I guess, and I ran a GPU stress test on FurMark with absolutely no issues. Steady FPS & temperatures...
Please note that just like how folding is more stressful than Prime95 on the CPU, folding on the GPU is more stressful than FurMark.
The suggestion to lower the memory frequencies was part of troubleshooting to eliminate all possibilities so see what else is left. It's a choice that you make :)
vtankovich
Post by vtankovich »
I've noticed that I have a small chance to get an error when I try to use the GPU while it's folding - games or even highres video playing or a lot of "heavy" tabs open at the same time.
FAH is significantly more stressful that FurMark or most anything else you might find. Remove all overclocking and let it run for a while and let us know what happens. There's a reason why FAH does not support overclocking. Our FAHCore is intentionally a benchmark exceeding other benchmarks.
After you demonstrate that your non-overclocked GPU is capable of running FAH WUs, you may consider increasing the shader clock rate very slightly. Don't bother to increase memory clocks. It just generates more heat and makes rather small increases in performance.
