Please whitelist AMD Radeon HD 5870
Farge
Post by Farge »
Hello,
please add to the whitelist the following card:
AMD Radeon HD 5870 (https://www.techpowerup.com/gpu-specs/r ... -5870.c253)
From GPU-Z:
Name: AMD Radeon HD 5800 Series
Device ID : 1002 6898 - 1002 0B00
From drivers:
Revision ID: 00
FAH log:
*********************** Log Started 2020-05-02T09:02:29Z ***********************
09:02:29:****************************** FAHClient ******************************
09:02:29:        Version: 7.6.9
09:02:29:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:02:29:      Copyright: 2020 foldingathome.org
09:02:29:       Homepage: https://foldingathome.org/
09:02:29:           Date: Apr 17 2020
09:02:29:           Time: 11:13:06
09:02:29:       Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
09:02:29:         Branch: master
09:02:29:       Compiler: Visual C++ 2008
09:02:29:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
09:02:29:       Platform: win32 10
09:02:29:           Bits: 32
09:02:29:           Mode: Release
09:02:29:           Args: --open-web-control
09:02:29:         Config: C:\Users\Enrico\AppData\Roaming\FAHClient\config.xml
09:02:29:******************************** CBang ********************************
09:02:29:           Time: 11:10:09
09:02:29:       Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
09:02:29:           Bits: 32
09:02:29:******************************* System ********************************
09:02:29:            CPU: Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz
09:02:29:         CPU ID: GenuineIntel Family 6 Model 30 Stepping 5
09:02:29:           CPUs: 8
09:02:29:         Memory: 16.00GiB
09:02:29:    Free Memory: 11.13GiB
09:02:29:        Threads: WINDOWS_THREADS
09:02:29:     OS Version: 6.1
09:02:29:    Has Battery: false
09:02:29:     On Battery: false
09:02:29:     UTC Offset: 2
09:02:29:            PID: 11592
09:02:29:            CWD: C:\Users\Enrico\AppData\Roaming\FAHClient
09:02:29:             OS: Windows 7 Enterprise
09:02:29:        OS Arch: AMD64
09:02:29:           GPUs: 1
09:02:29:          GPU 0: Bus:1 Slot:0 Func:0 AMD:5 Cypress [Radeon HD 5800/6800]
09:02:29:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
09:02:29:                 specified module could not be found.
09:02:29:
09:02:29:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:1800.8
09:02:29:  Win32 Service: false
09:02:29:******************************* libFAH ********************************
09:02:29:           Date: Apr 15 2020
09:02:29:           Time: 14:53:14
09:02:29:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
09:02:29:           Bits: 32
09:02:29:***********************************************************************
09:02:29:<config>
09:02:29:  <!-- Folding Slot Configuration -->
09:02:29:  <cause v='COVID_19'/>
09:02:29:
09:02:29:  <!-- Network -->
09:02:29:  <proxy v=':8080'/>
09:02:29:
09:02:29:  <!-- User Information -->
09:02:29:  <passkey v='*****'/>
09:02:29:  <user v='Farge'/>
09:02:29:
09:02:29:  <!-- Folding Slots -->
09:02:29:  <slot id='0' type='CPU'>
09:02:29:    <paused v='true'/>
09:02:29:  </slot>
09:02:29:  <slot id='1' type='GPU'/>
09:02:29:</config>
09:02:29:Trying to access database...
09:02:29:Successfully acquired database lock
09:02:29:Enabled folding slot 00: PAUSED cpu:6 (by user)
09:02:29:Enabled folding slot 01: READY gpu:0:Cypress [Radeon HD 5800/6800]
09:02:29:WU00:FS01:Connecting to 65.254.110.245:80
09:02:30:WU00:FS01:Assigned to work server 192.0.2.1
09:02:30:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress [Radeon HD 5800/6800] from 192.0.2.1
09:02:30:WU00:FS01:Connecting to 192.0.2.1:8080
09:02:35:17:127.0.0.1:New Web session
09:02:51:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
09:02:51:WU00:FS01:Connecting to 192.0.2.1:80
09:03:13:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:03:13:WU00:FS01:Connecting to 65.254.110.245:80
09:03:14:WU00:FS01:Assigned to work server 192.0.2.1
09:03:14:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress [Radeon HD 5800/6800] from 192.0.2.1
09:03:14:WU00:FS01:Connecting to 192.0.2.1:8080
09:03:17:FS00:Unpaused
09:03:17:WU01:FS00:Connecting to 65.254.110.245:80
09:03:18:WU01:FS00:Assigned to work server 155.247.164.213
09:03:18:WU01:FS00:Requesting new work unit for slot 00: READY cpu:6 from 155.247.164.213
09:03:18:WU01:FS00:Connecting to 155.247.164.213:8080
09:03:18:WU01:FS00:Downloading 2.80MiB
09:03:19:WU01:FS00:Download complete
09:03:19:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14824 run:724 clone:2 gen:10 core:0xa7 unit:0x0000000c9bf7a4d55ea344bd17c63af0
09:03:20:WU01:FS00:Starting
09:03:20:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Enrico\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 11592 -checkpoint 15 -np 6
09:03:20:WU01:FS00:Started FahCore on PID 5716
09:03:20:WU01:FS00:Core PID:8428
09:03:20:WU01:FS00:FahCore 0xa7 started
09:03:20:WU01:FS00:0xa7:*********************** Log Started 2020-05-02T09:03:20Z ***********************
09:03:20:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
09:03:20:WU01:FS00:0xa7:       Type: 0xa7
09:03:20:WU01:FS00:0xa7:       Core: Gromacs
09:03:20:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 5716 -checkpoint 15 -np 6
09:03:20:WU01:FS00:0xa7:************************************ CBang *************************************
09:03:20:WU01:FS00:0xa7:       Date: Oct 26 2019
09:03:20:WU01:FS00:0xa7:       Time: 01:38:35
09:03:20:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
09:03:20:WU01:FS00:0xa7:     Branch: master
09:03:20:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
09:03:20:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
09:03:20:WU01:FS00:0xa7:   Platform: win32 10
09:03:20:WU01:FS00:0xa7:       Bits: 64
09:03:20:WU01:FS00:0xa7:       Mode: Release
09:03:20:WU01:FS00:0xa7:************************************ System ************************************
09:03:20:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz
09:03:20:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 30 Stepping 5
09:03:20:WU01:FS00:0xa7:       CPUs: 8
09:03:20:WU01:FS00:0xa7:     Memory: 16.00GiB
09:03:20:WU01:FS00:0xa7:Free Memory: 10.48GiB
09:03:20:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
09:03:20:WU01:FS00:0xa7: OS Version: 6.1
09:03:20:WU01:FS00:0xa7:Has Battery: false
09:03:20:WU01:FS00:0xa7: On Battery: false
09:03:20:WU01:FS00:0xa7: UTC Offset: 2
09:03:20:WU01:FS00:0xa7:        PID: 8428
09:03:20:WU01:FS00:0xa7:        CWD: C:\Users\Enrico\AppData\Roaming\FAHClient\work
09:03:20:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
09:03:20:WU01:FS00:0xa7:    Version: 0.0.18
09:03:20:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:03:20:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
09:03:20:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
09:03:20:WU01:FS00:0xa7:       Time: 01:52:44
09:03:20:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
09:03:20:WU01:FS00:0xa7:************************************ Build *************************************
09:03:20:WU01:FS00:0xa7:       SIMD: sse2
09:03:20:WU01:FS00:0xa7:********************************************************************************
09:03:20:WU01:FS00:0xa7:Project: 14824 (Run 724, Clone 2, Gen 10)
09:03:20:WU01:FS00:0xa7:Unit: 0x0000000c9bf7a4d55ea344bd17c63af0
09:03:20:WU01:FS00:0xa7:Reading tar file core.xml
09:03:20:WU01:FS00:0xa7:Reading tar file frame10.tpr
09:03:20:WU01:FS00:0xa7:Digital signatures verified
09:03:20:WU01:FS00:0xa7:Calling: mdrun -s frame10.tpr -o frame10.trr -cpt 15 -nt 6
09:03:21:WU01:FS00:0xa7:Steps: first=0 total=250000
09:03:23:WU01:FS00:0xa7:Completed 1 out of 250000 steps (0%)
09:03:30:Saving configuration to config.xml
09:03:30:<config>
09:03:30:  <!-- Folding Slot Configuration -->
09:03:30:  <cause v='COVID_19'/>
09:03:30:
09:03:30:  <!-- Network -->
09:03:30:  <proxy v=':8080'/>
09:03:30:
09:03:30:  <!-- User Information -->
09:03:30:  <passkey v='*****'/>
09:03:30:  <user v='Farge'/>
09:03:30:
09:03:30:  <!-- Folding Slots -->
09:03:30:  <slot id='0' type='CPU'/>
09:03:30:  <slot id='1' type='GPU'/>
09:03:30:</config>
09:03:35:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
09:03:35:WU00:FS01:Connecting to 192.0.2.1:80
09:03:39:FS00:Shutting core down
09:03:39:WU01:FS00:0xa7:WARNING:Console control signal 1 on PID 8428
09:03:39:WU01:FS00:0xa7:Exiting, please wait. . .
09:03:40:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
09:03:41:WU01:FS00:Starting
09:03:41:WARNING:WU01:FS00:Changed SMP threads from 6 to 3 this can cause some work units to fail
09:03:41:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Enrico\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 11592 -checkpoint 15 -np 3
09:03:41:WU01:FS00:Started FahCore on PID 4236
09:03:41:WU01:FS00:Core PID:10524
09:03:41:WU01:FS00:FahCore 0xa7 started
09:03:41:WU01:FS00:0xa7:*********************** Log Started 2020-05-02T09:03:41Z ***********************
09:03:41:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
09:03:41:WU01:FS00:0xa7:       Type: 0xa7
09:03:41:WU01:FS00:0xa7:       Core: Gromacs
09:03:41:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 4236 -checkpoint 15 -np 3
09:03:41:WU01:FS00:0xa7:************************************ CBang *************************************
09:03:41:WU01:FS00:0xa7:       Date: Oct 26 2019
09:03:41:WU01:FS00:0xa7:       Time: 01:38:35
09:03:41:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
09:03:41:WU01:FS00:0xa7:     Branch: master
09:03:41:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
09:03:41:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
09:03:41:WU01:FS00:0xa7:   Platform: win32 10
09:03:41:WU01:FS00:0xa7:       Bits: 64
09:03:41:WU01:FS00:0xa7:       Mode: Release
09:03:41:WU01:FS00:0xa7:************************************ System ************************************
09:03:41:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz
09:03:41:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 30 Stepping 5
09:03:41:WU01:FS00:0xa7:       CPUs: 8
09:03:41:WU01:FS00:0xa7:     Memory: 16.00GiB
09:03:41:WU01:FS00:0xa7:Free Memory: 10.50GiB
09:03:41:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
09:03:41:WU01:FS00:0xa7: OS Version: 6.1
09:03:41:WU01:FS00:0xa7:Has Battery: false
09:03:41:WU01:FS00:0xa7: On Battery: false
09:03:41:WU01:FS00:0xa7: UTC Offset: 2
09:03:41:WU01:FS00:0xa7:        PID: 10524
09:03:41:WU01:FS00:0xa7:        CWD: C:\Users\Enrico\AppData\Roaming\FAHClient\work
09:03:41:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
09:03:41:WU01:FS00:0xa7:    Version: 0.0.18
09:03:41:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:03:41:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
09:03:41:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
09:03:41:WU01:FS00:0xa7:       Time: 01:52:44
09:03:41:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
09:03:41:WU01:FS00:0xa7:************************************ Build *************************************
09:03:41:WU01:FS00:0xa7:       SIMD: sse2
09:03:41:WU01:FS00:0xa7:********************************************************************************
09:03:41:WU01:FS00:0xa7:Project: 14824 (Run 724, Clone 2, Gen 10)
09:03:41:WU01:FS00:0xa7:Unit: 0x0000000c9bf7a4d55ea344bd17c63af0
09:03:41:WU01:FS00:0xa7:Digital signatures verified
09:03:41:WU01:FS00:0xa7:Calling: mdrun -s frame10.tpr -o frame10.trr -cpi state.cpt -cpt 15 -nt 3
09:03:41:WU01:FS00:0xa7:Steps: first=0 total=250000
09:03:42:WU01:FS00:0xa7:Completed 224 out of 250000 steps (0%)
09:03:49:FS00:Shutting core down
09:03:49:WU01:FS00:0xa7:WARNING:Console control signal 1 on PID 10524
09:03:49:WU01:FS00:0xa7:Exiting, please wait. . .
09:03:49:WU01:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
09:03:50:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
09:03:55:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:04:13:WU00:FS01:Connecting to 65.254.110.245:80
09:04:14:WU00:FS01:Assigned to work server 192.0.2.1
09:04:14:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress [Radeon HD 5800/6800] from 192.0.2.1
09:04:14:WU00:FS01:Connecting to 192.0.2.1:8080
09:04:36:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
09:04:36:WU00:FS01:Connecting to 192.0.2.1:80
09:04:41:WU01:FS00:Starting
09:04:41:WARNING:WU01:FS00:Changed SMP threads from 3 to 6 this can cause some work units to fail
09:04:41:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Enrico\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 11592 -checkpoint 15 -np 6
09:04:41:WU01:FS00:Started FahCore on PID 11600
09:04:41:WU01:FS00:Core PID:11180
09:04:41:WU01:FS00:FahCore 0xa7 started
09:04:41:WU01:FS00:0xa7:*********************** Log Started 2020-05-02T09:04:41Z ***********************
09:04:41:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
09:04:41:WU01:FS00:0xa7:       Type: 0xa7
09:04:41:WU01:FS00:0xa7:       Core: Gromacs
09:04:41:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 11600 -checkpoint 15 -np
09:04:41:WU01:FS00:0xa7:             6
09:04:41:WU01:FS00:0xa7:************************************ CBang *************************************
09:04:41:WU01:FS00:0xa7:       Date: Oct 26 2019
09:04:41:WU01:FS00:0xa7:       Time: 01:38:35
09:04:41:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
09:04:41:WU01:FS00:0xa7:     Branch: master
09:04:41:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
09:04:41:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
09:04:41:WU01:FS00:0xa7:   Platform: win32 10
09:04:41:WU01:FS00:0xa7:       Bits: 64
09:04:41:WU01:FS00:0xa7:       Mode: Release
09:04:41:WU01:FS00:0xa7:************************************ System ************************************
09:04:41:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz
09:04:41:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 30 Stepping 5
09:04:41:WU01:FS00:0xa7:       CPUs: 8
09:04:41:WU01:FS00:0xa7:     Memory: 16.00GiB
09:04:41:WU01:FS00:0xa7:Free Memory: 10.50GiB
09:04:41:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
09:04:41:WU01:FS00:0xa7: OS Version: 6.1
09:04:41:WU01:FS00:0xa7:Has Battery: false
09:04:41:WU01:FS00:0xa7: On Battery: false
09:04:41:WU01:FS00:0xa7: UTC Offset: 2
09:04:41:WU01:FS00:0xa7:        PID: 11180
09:04:41:WU01:FS00:0xa7:        CWD: C:\Users\Enrico\AppData\Roaming\FAHClient\work
09:04:41:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
09:04:41:WU01:FS00:0xa7:    Version: 0.0.18
09:04:41:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:04:41:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
09:04:41:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
09:04:41:WU01:FS00:0xa7:       Time: 01:52:44
09:04:41:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
09:04:41:WU01:FS00:0xa7:************************************ Build *************************************
09:04:41:WU01:FS00:0xa7:       SIMD: sse2
09:04:41:WU01:FS00:0xa7:********************************************************************************
09:04:41:WU01:FS00:0xa7:Project: 14824 (Run 724, Clone 2, Gen 10)
09:04:41:WU01:FS00:0xa7:Unit: 0x0000000c9bf7a4d55ea344bd17c63af0
09:04:41:WU01:FS00:0xa7:Digital signatures verified
09:04:41:WU01:FS00:0xa7:Calling: mdrun -s frame10.tpr -o frame10.trr -cpi state.cpt -cpt 15 -nt 6
09:04:42:WU01:FS00:0xa7:Steps: first=0 total=250000
09:04:43:WU01:FS00:0xa7:Completed 286 out of 250000 steps (0%)
09:04:57:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:05:51:WU00:FS01:Connecting to 65.254.110.245:80
09:05:51:WU00:FS01:Assigned to work server 192.0.2.1
09:05:51:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress [Radeon HD 5800/6800] from 192.0.2.1
09:05:51:WU00:FS01:Connecting to 192.0.2.1:8080
09:06:11:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
09:06:11:WU00:FS01:Connecting to 192.0.2.1:80
09:06:32:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:07:43:WU01:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
09:08:28:WU00:FS01:Connecting to 65.254.110.245:80
09:08:28:WU00:FS01:Assigned to work server 192.0.2.1
09:08:28:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress [Radeon HD 5800/6800] from 192.0.2.1
09:08:28:WU00:FS01:Connecting to 192.0.2.1:8080
09:08:49:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
09:08:49:WU00:FS01:Connecting to 192.0.2.1:80
09:09:09:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:09:17:FS00:Shutting core down
09:09:17:WU01:FS00:0xa7:WARNING:Console control signal 1 on PID 11180
09:09:17:WU01:FS00:0xa7:Exiting, please wait. . .
09:09:18:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
09:09:18:WU01:FS00:Starting
09:09:18:WARNING:WU01:FS00:Changed SMP threads from 6 to 7 this can cause some work units to fail
09:09:18:WARNING:WU01:FS00:AS lowered CPUs from 7 to 6
09:09:18:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Enrico\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 11592 -checkpoint 15 -np 6
09:09:18:WU01:FS00:Started FahCore on PID 8036
09:09:18:WU01:FS00:Core PID:4684
09:09:18:WU01:FS00:FahCore 0xa7 started
09:09:18:WU01:FS00:0xa7:*********************** Log Started 2020-05-02T09:09:18Z ***********************
09:09:18:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
09:09:18:WU01:FS00:0xa7:       Type: 0xa7
09:09:18:WU01:FS00:0xa7:       Core: Gromacs
09:09:18:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 8036 -checkpoint 15 -np 6
09:09:18:WU01:FS00:0xa7:************************************ CBang *************************************
09:09:18:WU01:FS00:0xa7:       Date: Oct 26 2019
09:09:18:WU01:FS00:0xa7:       Time: 01:38:35
09:09:18:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
09:09:18:WU01:FS00:0xa7:     Branch: master
09:09:18:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
09:09:18:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
09:09:18:WU01:FS00:0xa7:   Platform: win32 10
09:09:18:WU01:FS00:0xa7:       Bits: 64
09:09:18:WU01:FS00:0xa7:       Mode: Release
09:09:18:WU01:FS00:0xa7:************************************ System ************************************
09:09:18:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz
09:09:18:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 30 Stepping 5
09:09:18:WU01:FS00:0xa7:       CPUs: 8
09:09:18:WU01:FS00:0xa7:     Memory: 16.00GiB
09:09:18:WU01:FS00:0xa7:Free Memory: 9.92GiB
09:09:18:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
09:09:18:WU01:FS00:0xa7: OS Version: 6.1
09:09:18:WU01:FS00:0xa7:Has Battery: false
09:09:18:WU01:FS00:0xa7: On Battery: false
09:09:18:WU01:FS00:0xa7: UTC Offset: 2
09:09:18:WU01:FS00:0xa7:        PID: 4684
09:09:18:WU01:FS00:0xa7:        CWD: C:\Users\Enrico\AppData\Roaming\FAHClient\work
09:09:18:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
09:09:18:WU01:FS00:0xa7:    Version: 0.0.18
09:09:18:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:09:18:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
09:09:18:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
09:09:18:WU01:FS00:0xa7:       Time: 01:52:44
09:09:18:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
09:09:18:WU01:FS00:0xa7:************************************ Build *************************************
09:09:18:WU01:FS00:0xa7:       SIMD: sse2
09:09:18:WU01:FS00:0xa7:********************************************************************************
09:09:18:WU01:FS00:0xa7:Project: 14824 (Run 724, Clone 2, Gen 10)
09:09:18:WU01:FS00:0xa7:Unit: 0x0000000c9bf7a4d55ea344bd17c63af0
09:09:18:WU01:FS00:0xa7:Digital signatures verified
09:09:18:WU01:FS00:0xa7:Calling: mdrun -s frame10.tpr -o frame10.trr -cpi state.cpt -cpt 15 -nt 6
09:09:18:WU01:FS00:0xa7:Steps: first=0 total=250000
09:09:19:WU01:FS00:0xa7:Completed 3521 out of 250000 steps (1%)
09:09:36:Saving configuration to config.xml
09:09:36:<config>
09:09:36:  <!-- Folding Slot Configuration -->
09:09:36:  <cause v='COVID_19'/>
09:09:36:
09:09:36:  <!-- Network -->
09:09:36:  <proxy v=':8080'/>
09:09:36:
09:09:36:  <!-- Slot Control -->
09:09:36:  <power v='full'/>
09:09:36:
09:09:36:  <!-- User Information -->
09:09:36:  <passkey v='*****'/>
09:09:36:  <user v='Farge'/>
09:09:36:
09:09:36:  <!-- Folding Slots -->
09:09:36:  <slot id='0' type='CPU'/>
09:09:36:  <slot id='1' type='GPU'/>
09:09:36:</config>
09:09:55:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
09:11:16:WU01:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
09:12:42:WU00:FS01:Connecting to 65.254.110.245:80
09:12:42:WU00:FS01:Assigned to work server 192.0.2.1
09:12:42:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress [Radeon HD 5800/6800] from 192.0.2.1
09:12:42:WU00:FS01:Connecting to 192.0.2.1:8080
09:13:03:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
09:13:03:WU00:FS01:Connecting to 192.0.2.1:80
09:13:23:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:14:32:WU01:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
09:17:52:WU01:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
09:19:33:WU00:FS01:Connecting to 65.254.110.245:80
09:19:34:WU00:FS01:Assigned to work server 192.0.2.1
09:19:34:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress [Radeon HD 5800/6800] from 192.0.2.1
09:19:34:WU00:FS01:Connecting to 192.0.2.1:8080
09:19:54:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
09:19:54:WU00:FS01:Connecting to 192.0.2.1:80
09:20:15:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:21:10:WU01:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
09:24:30:WU01:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
09:28:06:WU01:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
09:30:39:WU00:FS01:Connecting to 65.254.110.245:80
09:30:39:WU00:FS01:Assigned to work server 192.0.2.1
09:30:39:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress [Radeon HD 5800/6800] from 192.0.2.1
09:30:39:WU00:FS01:Connecting to 192.0.2.1:8080
09:30:59:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
09:30:59:WU00:FS01:Connecting to 192.0.2.1:80
09:31:20:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:31:35:WU01:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
09:35:05:WU01:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
09:38:39:WU01:FS00:0xa7:Completed 25000 out of 250000 steps (10%)
09:42:08:WU01:FS00:0xa7:Completed 27500 out of 250000 steps (11%)
09:45:38:WU01:FS00:0xa7:Completed 30000 out of 250000 steps (12%)
09:48:36:WU00:FS01:Connecting to 65.254.110.245:80
09:48:36:WU00:FS01:Assigned to work server 192.0.2.1
09:48:36:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress [Radeon HD 5800/6800] from 192.0.2.1
09:48:36:WU00:FS01:Connecting to 192.0.2.1:8080
09:48:53:WU01:FS00:0xa7:Completed 32500 out of 250000 steps (13%)
09:48:56:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
09:48:56:WU00:FS01:Connecting to 192.0.2.1:80
09:49:17:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:52:08:WU01:FS00:0xa7:Completed 35000 out of 250000 steps (14%)
09:55:22:WU01:FS00:0xa7:Completed 37500 out of 250000 steps (15%)
09:58:35:WU01:FS00:0xa7:Completed 40000 out of 250000 steps (16%)
10:01:52:WU01:FS00:0xa7:Completed 42500 out of 250000 steps (17%)
10:05:08:WU01:FS00:0xa7:Completed 45000 out of 250000 steps (18%)
10:08:22:WU01:FS00:0xa7:Completed 47500 out of 250000 steps (19%)
10:11:39:WU01:FS00:0xa7:Completed 50000 out of 250000 steps (20%)
10:14:52:WU01:FS00:0xa7:Completed 52500 out of 250000 steps (21%)
10:17:38:WU00:FS01:Connecting to 65.254.110.245:80
10:17:38:WU00:FS01:Assigned to work server 192.0.2.1
10:17:38:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress [Radeon HD 5800/6800] from 192.0.2.1
10:17:38:WU00:FS01:Connecting to 192.0.2.1:8080
10:17:58:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
10:17:58:WU00:FS01:Connecting to 192.0.2.1:80
10:18:19:WU01:FS00:0xa7:Completed 55000 out of 250000 steps (22%)
10:18:19:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
10:21:46:WU01:FS00:0xa7:Completed 57500 out of 250000 steps (23%)
10:25:00:WU01:FS00:0xa7:Completed 60000 out of 250000 steps (24%)
10:28:18:WU01:FS00:0xa7:Completed 62500 out of 250000 steps (25%)
10:31:37:WU01:FS00:0xa7:Completed 65000 out of 250000 steps (26%)
10:34:58:WU01:FS00:0xa7:Completed 67500 out of 250000 steps (27%)
10:38:23:WU01:FS00:0xa7:Completed 70000 out of 250000 steps (28%)
10:41:44:WU01:FS00:0xa7:Completed 72500 out of 250000 steps (29%)
10:45:08:WU01:FS00:0xa7:Completed 75000 out of 250000 steps (30%)
10:48:25:WU01:FS00:0xa7:Completed 77500 out of 250000 steps (31%)
10:51:41:WU01:FS00:0xa7:Completed 80000 out of 250000 steps (32%)
10:54:55:WU01:FS00:0xa7:Completed 82500 out of 250000 steps (33%)
10:58:10:WU01:FS00:0xa7:Completed 85000 out of 250000 steps (34%)
11:01:24:WU01:FS00:0xa7:Completed 87500 out of 250000 steps (35%)
11:04:37:WU00:FS01:Connecting to 65.254.110.245:80
11:04:37:WU00:FS01:Assigned to work server 192.0.2.1
11:04:37:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress [Radeon HD 5800/6800] from 192.0.2.1
11:04:37:WU00:FS01:Connecting to 192.0.2.1:8080
11:04:39:WU01:FS00:0xa7:Completed 90000 out of 250000 steps (36%)
11:04:57:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
11:04:57:WU00:FS01:Connecting to 192.0.2.1:80
11:05:18:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
11:07:53:WU01:FS00:0xa7:Completed 92500 out of 250000 steps (37%)
11:11:10:WU01:FS00:0xa7:Completed 95000 out of 250000 steps (38%)
11:14:28:WU01:FS00:0xa7:Completed 97500 out of 250000 steps (39%)
11:17:47:WU01:FS00:0xa7:Completed 100000 out of 250000 steps (40%)
11:21:02:WU01:FS00:0xa7:Completed 102500 out of 250000 steps (41%)
11:24:19:WU01:FS00:0xa7:Completed 105000 out of 250000 steps (42%)
11:27:39:WU01:FS00:0xa7:Completed 107500 out of 250000 steps (43%)
11:30:58:WU01:FS00:0xa7:Completed 110000 out of 250000 steps (44%)
11:34:12:WU01:FS00:0xa7:Completed 112500 out of 250000 steps (45%)
11:37:27:WU01:FS00:0xa7:Completed 115000 out of 250000 steps (46%)
11:40:43:WU01:FS00:0xa7:Completed 117500 out of 250000 steps (47%)
11:43:58:WU01:FS00:0xa7:Completed 120000 out of 250000 steps (48%)
11:47:12:WU01:FS00:0xa7:Completed 122500 out of 250000 steps (49%)
11:50:27:WU01:FS00:0xa7:Completed 125000 out of 250000 steps (50%)
11:53:41:WU01:FS00:0xa7:Completed 127500 out of 250000 steps (51%)
11:56:55:WU01:FS00:0xa7:Completed 130000 out of 250000 steps (52%)
12:00:11:WU01:FS00:0xa7:Completed 132500 out of 250000 steps (53%)
12:03:24:WU01:FS00:0xa7:Completed 135000 out of 250000 steps (54%)
12:06:39:WU01:FS00:0xa7:Completed 137500 out of 250000 steps (55%)
12:09:53:WU01:FS00:0xa7:Completed 140000 out of 250000 steps (56%)
12:13:07:WU01:FS00:0xa7:Completed 142500 out of 250000 steps (57%)
12:16:23:WU01:FS00:0xa7:Completed 145000 out of 250000 steps (58%)
12:19:43:WU01:FS00:0xa7:Completed 147500 out of 250000 steps (59%)
12:20:37:WU00:FS01:Connecting to 65.254.110.245:80
12:20:38:WU00:FS01:Assigned to work server 192.0.2.1
12:20:38:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress [Radeon HD 5800/6800] from 192.0.2.1
12:20:38:WU00:FS01:Connecting to 192.0.2.1:8080
12:20:58:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
12:20:58:WU00:FS01:Connecting to 192.0.2.1:80
12:21:19:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
12:22:57:WU01:FS00:0xa7:Completed 150000 out of 250000 steps (60%)
12:26:12:WU01:FS00:0xa7:Completed 152500 out of 250000 steps (61%)
12:29:29:WU01:FS00:0xa7:Completed 155000 out of 250000 steps (62%)
12:32:46:WU01:FS00:0xa7:Completed 157500 out of 250000 steps (63%)
12:36:09:WU01:FS00:0xa7:Completed 160000 out of 250000 steps (64%)
12:39:30:WU01:FS00:0xa7:Completed 162500 out of 250000 steps (65%)
12:42:44:WU01:FS00:0xa7:Completed 165000 out of 250000 steps (66%)
12:45:59:WU01:FS00:0xa7:Completed 167500 out of 250000 steps (67%)
12:49:14:WU01:FS00:0xa7:Completed 170000 out of 250000 steps (68%)
12:52:29:WU01:FS00:0xa7:Completed 172500 out of 250000 steps (69%)
12:55:44:WU01:FS00:0xa7:Completed 175000 out of 250000 steps (70%)
12:59:03:WU01:FS00:0xa7:Completed 177500 out of 250000 steps (71%)
13:02:16:WU01:FS00:0xa7:Completed 180000 out of 250000 steps (72%)
13:05:32:WU01:FS00:0xa7:Completed 182500 out of 250000 steps (73%)
13:08:47:WU01:FS00:0xa7:Completed 185000 out of 250000 steps (74%)
13:12:01:WU01:FS00:0xa7:Completed 187500 out of 250000 steps (75%)
13:15:17:WU01:FS00:0xa7:Completed 190000 out of 250000 steps (76%)
13:18:38:WU01:FS00:0xa7:Completed 192500 out of 250000 steps (77%)
13:21:52:WU01:FS00:0xa7:Completed 195000 out of 250000 steps (78%)
13:25:08:WU01:FS00:0xa7:Completed 197500 out of 250000 steps (79%)
13:28:23:WU01:FS00:0xa7:Completed 200000 out of 250000 steps (80%)
13:31:37:WU01:FS00:0xa7:Completed 202500 out of 250000 steps (81%)
13:34:52:WU01:FS00:0xa7:Completed 205000 out of 250000 steps (82%)
13:38:07:WU01:FS00:0xa7:Completed 207500 out of 250000 steps (83%)
13:41:21:WU01:FS00:0xa7:Completed 210000 out of 250000 steps (84%)
13:44:36:WU01:FS00:0xa7:Completed 212500 out of 250000 steps (85%)
13:47:51:WU01:FS00:0xa7:Completed 215000 out of 250000 steps (86%)
13:51:05:WU01:FS00:0xa7:Completed 217500 out of 250000 steps (87%)
13:54:20:WU01:FS00:0xa7:Completed 220000 out of 250000 steps (88%)
13:57:35:WU01:FS00:0xa7:Completed 222500 out of 250000 steps (89%)
14:00:49:WU01:FS00:0xa7:Completed 225000 out of 250000 steps (90%)
14:04:05:WU01:FS00:0xa7:Completed 227500 out of 250000 steps (91%)
14:07:19:WU01:FS00:0xa7:Completed 230000 out of 250000 steps (92%)
14:10:34:WU01:FS00:0xa7:Completed 232500 out of 250000 steps (93%)
14:13:50:WU01:FS00:0xa7:Completed 235000 out of 250000 steps (94%)
14:17:16:WU01:FS00:0xa7:Completed 237500 out of 250000 steps (95%)
14:20:49:WU01:FS00:0xa7:Completed 240000 out of 250000 steps (96%)
14:23:37:WU00:FS01:Connecting to 65.254.110.245:80
14:23:38:WU00:FS01:Assigned to work server 192.0.2.1
14:23:38:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress [Radeon HD 5800/6800] from 192.0.2.1
14:23:38:WU00:FS01:Connecting to 192.0.2.1:8080
14:23:58:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
14:23:58:WU00:FS01:Connecting to 192.0.2.1:80
14:24:18:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
14:24:22:WU01:FS00:0xa7:Completed 242500 out of 250000 steps (97%)
14:27:50:WU01:FS00:0xa7:Completed 245000 out of 250000 steps (98%)
14:31:14:WU01:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
14:31:15:WU02:FS00:Connecting to 65.254.110.245:80
14:31:15:WU02:FS00:Assigned to work server 155.247.164.213
14:31:15:WU02:FS00:Requesting new work unit for slot 00: RUNNING cpu:7 from 155.247.164.213
14:31:15:WU02:FS00:Connecting to 155.247.164.213:8080
14:31:16:WU02:FS00:Downloading 2.82MiB
14:31:17:WU02:FS00:Download complete
14:31:17:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:14724 run:2162 clone:1 gen:19 core:0xa7 unit:0x000000169bf7a4d55ea2cf57bb5da941
14:34:12:FS00:Paused
14:34:12:FS01:Paused
14:34:12:FS00:Shutting core down
14:34:13:WU01:FS00:0xa7:WARNING:Console control signal 1 on PID 4684
14:34:13:WU01:FS00:0xa7:Exiting, please wait. . .
14:34:13:WU01:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
14:34:14:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
14:34:14:FS00:Unpaused
14:34:14:FS00:Finishing
14:34:14:FS01:Unpaused
14:34:14:FS01:Finishing
14:34:14:WU00:FS01:Connecting to 65.254.110.245:80
14:34:14:WU01:FS00:Starting
14:34:14:WARNING:WU01:FS00:AS lowered CPUs from 7 to 6
14:34:14:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Enrico\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 11592 -checkpoint 15 -np 6
14:34:14:WU01:FS00:Started FahCore on PID 14472
14:34:14:WU01:FS00:Core PID:6236
14:34:14:WU01:FS00:FahCore 0xa7 started
14:34:15:WU00:FS01:Assigned to work server 192.0.2.1
14:34:15:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress [Radeon HD 5800/6800] from 192.0.2.1
14:34:15:WU00:FS01:Connecting to 192.0.2.1:8080
14:34:15:WU01:FS00:0xa7:*********************** Log Started 2020-05-02T14:34:14Z ***********************
14:34:15:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
14:34:15:WU01:FS00:0xa7:       Type: 0xa7
14:34:15:WU01:FS00:0xa7:       Core: Gromacs
14:34:15:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 14472 -checkpoint 15 -np
14:34:15:WU01:FS00:0xa7:             6
14:34:15:WU01:FS00:0xa7:************************************ CBang *************************************
14:34:15:WU01:FS00:0xa7:       Date: Oct 26 2019
14:34:15:WU01:FS00:0xa7:       Time: 01:38:35
14:34:15:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
14:34:15:WU01:FS00:0xa7:     Branch: master
14:34:15:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
14:34:15:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:34:15:WU01:FS00:0xa7:   Platform: win32 10
14:34:15:WU01:FS00:0xa7:       Bits: 64
14:34:15:WU01:FS00:0xa7:       Mode: Release
14:34:15:WU01:FS00:0xa7:************************************ System ************************************
14:34:15:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz
14:34:15:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 30 Stepping 5
14:34:15:WU01:FS00:0xa7:       CPUs: 8
14:34:15:WU01:FS00:0xa7:     Memory: 16.00GiB
14:34:15:WU01:FS00:0xa7:Free Memory: 7.79GiB
14:34:15:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
14:34:15:WU01:FS00:0xa7: OS Version: 6.1
14:34:15:WU01:FS00:0xa7:Has Battery: false
14:34:15:WU01:FS00:0xa7: On Battery: false
14:34:15:WU01:FS00:0xa7: UTC Offset: 2
14:34:15:WU01:FS00:0xa7:        PID: 6236
14:34:15:WU01:FS00:0xa7:        CWD: C:\Users\Enrico\AppData\Roaming\FAHClient\work
14:34:15:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
14:34:15:WU01:FS00:0xa7:    Version: 0.0.18
14:34:15:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:34:15:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
14:34:15:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
14:34:15:WU01:FS00:0xa7:       Time: 01:52:44
14:34:15:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
14:34:15:WU01:FS00:0xa7:************************************ Build *************************************
14:34:15:WU01:FS00:0xa7:       SIMD: sse2
14:34:15:WU01:FS00:0xa7:********************************************************************************
14:34:15:WU01:FS00:0xa7:Project: 14824 (Run 724, Clone 2, Gen 10)
14:34:15:WU01:FS00:0xa7:Unit: 0x0000000c9bf7a4d55ea344bd17c63af0
14:34:15:WU01:FS00:0xa7:Digital signatures verified
14:34:15:WU01:FS00:0xa7:Calling: mdrun -s frame10.tpr -o frame10.trr -cpi state.cpt -cpt 15 -nt 6
14:34:15:WU01:FS00:0xa7:Steps: first=0 total=250000
14:34:16:WU01:FS00:0xa7:Completed 249525 out of 250000 steps (99%)
14:34:35:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
14:34:35:WU00:FS01:Connecting to 192.0.2.1:80
14:34:53:WU01:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
14:34:55:WU01:FS00:0xa7:Saving result file ..\logfile_01.txt
14:34:55:WU01:FS00:0xa7:Saving result file dhdl.xvg
14:34:55:WU01:FS00:0xa7:Saving result file frame10.trr
14:34:55:WU01:FS00:0xa7:Saving result file md.log
14:34:55:WU01:FS00:0xa7:Saving result file pullf.xvg
14:34:55:WU01:FS00:0xa7:Saving result file pullx.xvg
14:34:55:WU01:FS00:0xa7:Saving result file science.log
14:34:55:WU01:FS00:0xa7:Saving result file traj_comp.xtc
14:34:55:WU01:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
14:34:55:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
14:34:55:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:14824 run:724 clone:2 gen:10 core:0xa7 unit:0x0000000c9bf7a4d55ea344bd17c63af0
14:34:55:WU01:FS00:Uploading 6.82MiB to 155.247.164.213
14:34:55:WU01:FS00:Connecting to 155.247.164.213:8080
14:34:55:WU02:FS00:Starting
14:34:55:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Enrico\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 11592 -checkpoint 15 -np 7
14:34:55:WU02:FS00:Started FahCore on PID 2236
14:34:55:WU02:FS00:Core PID:14656
14:34:55:WU02:FS00:FahCore 0xa7 started
14:34:56:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
14:34:56:WU02:FS00:0xa7:*********************** Log Started 2020-05-02T14:34:56Z ***********************
14:34:56:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
14:34:56:WU02:FS00:0xa7:       Type: 0xa7
14:34:56:WU02:FS00:0xa7:       Core: Gromacs
14:34:56:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 706 -lifeline 2236 -checkpoint 15 -np 7
14:34:56:WU02:FS00:0xa7:************************************ CBang *************************************
14:34:56:WU02:FS00:0xa7:       Date: Oct 26 2019
14:34:56:WU02:FS00:0xa7:       Time: 01:38:35
14:34:56:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
14:34:56:WU02:FS00:0xa7:     Branch: master
14:34:56:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
14:34:56:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:34:56:WU02:FS00:0xa7:   Platform: win32 10
14:34:56:WU02:FS00:0xa7:       Bits: 64
14:34:56:WU02:FS00:0xa7:       Mode: Release
14:34:56:WU02:FS00:0xa7:************************************ System ************************************
14:34:56:WU02:FS00:0xa7:        CPU: Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz
14:34:56:WU02:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 30 Stepping 5
14:34:56:WU02:FS00:0xa7:       CPUs: 8
14:34:56:WU02:FS00:0xa7:     Memory: 16.00GiB
14:34:56:WU02:FS00:0xa7:Free Memory: 7.82GiB
14:34:56:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
14:34:56:WU02:FS00:0xa7: OS Version: 6.1
14:34:56:WU02:FS00:0xa7:Has Battery: false
14:34:56:WU02:FS00:0xa7: On Battery: false
14:34:56:WU02:FS00:0xa7: UTC Offset: 2
14:34:56:WU02:FS00:0xa7:        PID: 14656
14:34:56:WU02:FS00:0xa7:        CWD: C:\Users\Enrico\AppData\Roaming\FAHClient\work
14:34:56:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
14:34:56:WU02:FS00:0xa7:    Version: 0.0.18
14:34:56:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:34:56:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
14:34:56:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
14:34:56:WU02:FS00:0xa7:       Time: 01:52:44
14:34:56:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
14:34:56:WU02:FS00:0xa7:************************************ Build *************************************
14:34:56:WU02:FS00:0xa7:       SIMD: sse2
14:34:56:WU02:FS00:0xa7:********************************************************************************
14:34:56:WU02:FS00:0xa7:Project: 14724 (Run 2162, Clone 1, Gen 19)
14:34:56:WU02:FS00:0xa7:Unit: 0x000000169bf7a4d55ea2cf57bb5da941
14:34:56:WU02:FS00:0xa7:Reading tar file core.xml
14:34:56:WU02:FS00:0xa7:Reading tar file frame19.tpr
14:34:56:WU02:FS00:0xa7:Digital signatures verified
14:34:56:WU02:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
14:34:56:WU02:FS00:0xa7:Calling: mdrun -s frame19.tpr -o frame19.trr -cpt 15 -nt 6
14:34:56:WU02:FS00:0xa7:Steps: first=0 total=250000
14:34:57:WU02:FS00:0xa7:Completed 1 out of 250000 steps (0%)
14:35:01:WU01:FS00:Upload 9.16%
14:35:07:WU01:FS00:Upload 19.24%
14:35:13:WU01:FS00:Upload 30.23%
14:35:19:WU01:FS00:Upload 40.30%
14:35:25:WU01:FS00:Upload 50.38%
14:35:31:WU01:FS00:Upload 60.46%
14:35:37:WU01:FS00:Upload 70.53%
14:35:43:WU01:FS00:Upload 81.52%
14:35:49:WU01:FS00:Upload 91.60%
14:35:51:WU00:FS01:Connecting to 65.254.110.245:80
14:35:52:WU00:FS01:Assigned to work server 192.0.2.1
14:35:52:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress [Radeon HD 5800/6800] from 192.0.2.1
14:35:52:WU00:FS01:Connecting to 192.0.2.1:8080
14:35:54:WU01:FS00:Upload complete
14:35:54:WU01:FS00:Server responded WORK_ACK (400)
14:35:54:WU01:FS00:Final credit estimate, 2934.00 points
14:35:54:WU01:FS00:Cleaning up
14:36:12:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
14:36:12:WU00:FS01:Connecting to 192.0.2.1:80
14:36:33:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
14:36:33:FS00:Paused
14:36:33:FS00:Shutting core down
14:36:33:WU02:FS00:0xa7:WARNING:Console control signal 1 on PID 14656
14:36:33:WU02:FS00:0xa7:Exiting, please wait. . .
14:36:34:WU02:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
14:36:34:WU02:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
14:36:51:FS00:Unpaused
14:36:51:FS00:Finishing
14:36:51:WU02:FS00:Starting
14:36:51:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Enrico\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 11592 -checkpoint 15 -np 7
14:36:51:WU02:FS00:Started FahCore on PID 16056
14:36:51:WU02:FS00:Core PID:13408
14:36:51:WU02:FS00:FahCore 0xa7 started
14:36:51:WU02:FS00:0xa7:*********************** Log Started 2020-05-02T14:36:51Z ***********************
14:36:51:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
14:36:51:WU02:FS00:0xa7:       Type: 0xa7
14:36:51:WU02:FS00:0xa7:       Core: Gromacs
14:36:51:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 706 -lifeline 16056 -checkpoint 15 -np
14:36:51:WU02:FS00:0xa7:             7
14:36:51:WU02:FS00:0xa7:************************************ CBang *************************************
14:36:51:WU02:FS00:0xa7:       Date: Oct 26 2019
14:36:51:WU02:FS00:0xa7:       Time: 01:38:35
14:36:51:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
14:36:51:WU02:FS00:0xa7:     Branch: master
14:36:51:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
14:36:51:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:36:51:WU02:FS00:0xa7:   Platform: win32 10
14:36:51:WU02:FS00:0xa7:       Bits: 64
14:36:51:WU02:FS00:0xa7:       Mode: Release
14:36:51:WU02:FS00:0xa7:************************************ System ************************************
14:36:51:WU02:FS00:0xa7:        CPU: Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz
14:36:51:WU02:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 30 Stepping 5
14:36:51:WU02:FS00:0xa7:       CPUs: 8
14:36:51:WU02:FS00:0xa7:     Memory: 16.00GiB
14:36:51:WU02:FS00:0xa7:Free Memory: 7.91GiB
14:36:51:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
14:36:51:WU02:FS00:0xa7: OS Version: 6.1
14:36:51:WU02:FS00:0xa7:Has Battery: false
14:36:51:WU02:FS00:0xa7: On Battery: false
14:36:51:WU02:FS00:0xa7: UTC Offset: 2
14:36:51:WU02:FS00:0xa7:        PID: 13408
14:36:51:WU02:FS00:0xa7:        CWD: C:\Users\Enrico\AppData\Roaming\FAHClient\work
14:36:51:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
14:36:51:WU02:FS00:0xa7:    Version: 0.0.18
14:36:51:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:36:51:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
14:36:51:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
14:36:51:WU02:FS00:0xa7:       Time: 01:52:44
14:36:51:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
14:36:51:WU02:FS00:0xa7:************************************ Build *************************************
14:36:51:WU02:FS00:0xa7:       SIMD: sse2
14:36:51:WU02:FS00:0xa7:********************************************************************************
14:36:51:WU02:FS00:0xa7:Project: 14724 (Run 2162, Clone 1, Gen 19)
14:36:51:WU02:FS00:0xa7:Unit: 0x000000169bf7a4d55ea2cf57bb5da941
14:36:51:WU02:FS00:0xa7:Digital signatures verified
14:36:51:WU02:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
14:36:51:WU02:FS00:0xa7:Calling: mdrun -s frame19.tpr -o frame19.trr -cpi state.cpt -cpt 15 -nt 6
14:36:51:WU02:FS00:0xa7:Steps: first=0 total=250000
14:36:52:WU02:FS00:0xa7:Completed 1245 out of 250000 steps (0%)
14:37:01:FS00:Paused
14:37:01:FS01:Paused
14:37:01:FS00:Shutting core down
14:37:01:WU02:FS00:0xa7:WARNING:Console control signal 1 on PID 13408
14:37:01:WU02:FS00:0xa7:Exiting, please wait. . .
14:37:01:WU02:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
14:37:02:WU02:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
14:37:07:FS01:Unpaused
14:37:07:WU00:FS01:Connecting to 65.254.110.245:80
14:37:08:WU00:FS01:Assigned to work server 192.0.2.1
14:37:08:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress [Radeon HD 5800/6800] from 192.0.2.1
14:37:08:WU00:FS01:Connecting to 192.0.2.1:8080
14:37:29:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
14:37:29:WU00:FS01:Connecting to 192.0.2.1:80
14:37:50:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
14:37:59:Saving configuration to config.xml
14:37:59:<config>
14:37:59:  <!-- Folding Slot Configuration -->
14:37:59:  <cause v='COVID_19'/>
14:37:59:
14:37:59:  <!-- Network -->
14:37:59:  <proxy v=':8080'/>
14:37:59:
14:37:59:  <!-- Slot Control -->
14:37:59:  <power v='full'/>
14:37:59:
14:37:59:  <!-- User Information -->
14:37:59:  <passkey v='*****'/>
14:37:59:  <user v='Farge'/>
14:37:59:
14:37:59:  <!-- Folding Slots -->
14:37:59:  <slot id='0' type='CPU'>
14:37:59:    <paused v='true'/>
14:37:59:  </slot>
14:37:59:  <slot id='1' type='GPU'/>
14:37:59:</config>
14:38:44:WU00:FS01:Connecting to 65.254.110.245:80
14:38:45:WU00:FS01:Assigned to work server 192.0.2.1
14:38:45:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress [Radeon HD 5800/6800] from 192.0.2.1
14:38:45:WU00:FS01:Connecting to 192.0.2.1:8080
14:39:06:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
14:39:06:WU00:FS01:Connecting to 192.0.2.1:80
14:39:27:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
14:41:21:WU00:FS01:Connecting to 65.254.110.245:80
14:41:22:WU00:FS01:Assigned to work server 192.0.2.1
14:41:22:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress [Radeon HD 5800/6800] from 192.0.2.1
14:41:22:WU00:FS01:Connecting to 192.0.2.1:8080
14:41:43:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
14:41:43:WU00:FS01:Connecting to 192.0.2.1:80
14:42:04:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
14:45:36:WU00:FS01:Connecting to 65.254.110.245:80
14:45:36:WU00:FS01:Assigned to work server 192.0.2.1
14:45:36:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress [Radeon HD 5800/6800] from 192.0.2.1
14:45:36:WU00:FS01:Connecting to 192.0.2.1:8080
14:45:58:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
14:45:58:WU00:FS01:Connecting to 192.0.2.1:80
14:46:19:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
14:52:27:WU00:FS01:Connecting to 65.254.110.245:80
14:52:28:WU00:FS01:Assigned to work server 192.0.2.1
14:52:28:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress [Radeon HD 5800/6800] from 192.0.2.1
14:52:28:WU00:FS01:Connecting to 192.0.2.1:8080
14:52:49:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
14:52:49:WU00:FS01:Connecting to 192.0.2.1:80
14:53:11:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
******************************* Date: 2020-05-02 *******************************
15:03:33:WU00:FS01:Connecting to 65.254.110.245:80
15:03:33:WU00:FS01:Assigned to work server 192.0.2.1
15:03:33:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress [Radeon HD 5800/6800] from 192.0.2.1
15:03:33:WU00:FS01:Connecting to 192.0.2.1:8080
15:03:55:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
15:03:55:WU00:FS01:Connecting to 192.0.2.1:80
15:04:17:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
15:21:29:WU00:FS01:Connecting to 65.254.110.245:80
15:21:30:WU00:FS01:Assigned to work server 192.0.2.1
15:21:30:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress [Radeon HD 5800/6800] from 192.0.2.1
15:21:30:WU00:FS01:Connecting to 192.0.2.1:8080
15:21:51:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
15:21:51:WU00:FS01:Connecting to 192.0.2.1:80
15:22:13:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
15:50:32:WU00:FS01:Connecting to 65.254.110.245:80
15:50:32:WU00:FS01:Assigned to work server 192.0.2.1
15:50:32:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress [Radeon HD 5800/6800] from 192.0.2.1
15:50:32:WU00:FS01:Connecting to 192.0.2.1:8080
15:50:54:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
15:50:54:WU00:FS01:Connecting to 192.0.2.1:80
15:51:16:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
16:37:31:WU00:FS01:Connecting to 65.254.110.245:80
16:37:32:WU00:FS01:Assigned to work server 192.0.2.1
16:37:32:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress [Radeon HD 5800/6800] from 192.0.2.1
16:37:32:WU00:FS01:Connecting to 192.0.2.1:8080
16:37:54:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
16:37:54:WU00:FS01:Connecting to 192.0.2.1:80
16:38:16:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
17:53:31:WU00:FS01:Connecting to 65.254.110.245:80
17:53:32:WU00:FS01:Assigned to work server 192.0.2.1
17:53:33:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress [Radeon HD 5800/6800] from 192.0.2.1
17:53:33:WU00:FS01:Connecting to 192.0.2.1:8080
17:53:55:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
17:53:55:WU00:FS01:Connecting to 192.0.2.1:80
17:54:17:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
There's already a similar entry in gpu.txt I've found here https://apps.foldingathome.org/GPUs.txt but I'm still not getting WUs so maybe there's something different
Thank you
Enrico
Re: Please whitelist AMD Radeon 5870
Welcome to the F@H Forum Farge,
Please note that the GPU is already whitelisted:
0x1002:0x6898:1:2:Cypress [Radeon HD 5800/6800]
Also, your system has detected it:
09:02:29: GPUs: 1
I am not sure as to why it is behaving as if the system is unsupported as it is connecting to a non-existent Server instead of the actual Assignment Server:
It needs the species changed from 2 to 5. Not sure why it was ever set to 2 in the first place, that would have been for an older series card than the HD 5800.
_r2w_ben
Post by _r2w_ben »
GPUs.txt from Apr 7:
0x1002:0x6898:1:5:Cypress [Radeon HD 5800/6800]
0x1002:0x6899:1:5:Cypress Pro [Radeon HD 5800/6850]
0x1002:0x689b:1:5:EG Cypress [Radeon HD 6800 Series]
A version I downloaded earlier today:
0x1002:0x6899:1:5:Cypress PRO [Radeon HD 5850]
0x1002:0x689b:1:2:Cypress PRO [Radeon HD 6800 Series]
It looks like someone changed two Cypress variants from 5 to 2. Perhaps this was done because they mentioned 6800, which are actually Barts and don't have double precision.
Apr 7:
0x1002:0x6738:1:4:Barts XT [Radeon HD 6800 Series]
0x1002:0x6739:1:4:Barts PRO [Radeon HD 6800 Series]
0x1002:0x673e:1:4:Barts LE [Radeon HD 6700 Series]
Now:
0x1002:0x6738:::Barts XT [Radeon HD 6870]
0x1002:0x6739:::Barts PRO [Radeon HD 6850]
0x1002:0x673e:::Barts LE [Radeon HD 6790]
These have better labels and went from species 4 to unsupported.
Farge
Post by Farge »
_r2w_ben wrote:GPUs.txt from Apr 7:
Hi, can this entry
be changed back to 5 ?
From what I understand this would be enough for my card to start receiving WUs again.
My FAH version is 7.6.9 (upgraded from previous one)
Thank you
Re: Please whitelist AMD Radeon HD 5870
Post by muziqaz »
There might have been a reason for that, as those GPUs are of ancient design, and have been known to cause issues or not fold at all with latest crop of GPU projects.
Technically 5800/6800 series support DP and OpenCL1.2, but how much of that OCL 1.2 support comes from driver shortcuts and not real hardware support?
FAH Omega tester
Whitelisted as a 5.
Farge
Post by Farge »
Hi Bruce,
thank you. Now the connection to the servers succeeds but I receive another message, from log file:
12:15:59:WU02:FS00:Starting
12:15:59:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Enrico\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 16856 -checkpoint 15 -np 7
12:15:59:WU02:FS00:Started FahCore on PID 17340
12:15:59:WU02:FS00:Core PID:9984
12:15:59:WU02:FS00:FahCore 0xa7 started
12:16:00:WU02:FS00:0xa7:*********************** Log Started 2020-05-05T12:16:00Z ***********************
12:16:00:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
12:16:00:WU02:FS00:0xa7:       Type: 0xa7
12:16:00:WU02:FS00:0xa7:       Core: Gromacs
12:16:00:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 706 -lifeline 17340 -checkpoint 15 -np
12:16:00:WU02:FS00:0xa7:             7
12:16:00:WU02:FS00:0xa7:************************************ CBang *************************************
12:16:00:WU02:FS00:0xa7:       Date: Oct 26 2019
12:16:00:WU02:FS00:0xa7:       Time: 01:38:35
12:16:00:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
12:16:00:WU02:FS00:0xa7:     Branch: master
12:16:00:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
12:16:00:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:16:00:WU02:FS00:0xa7:   Platform: win32 10
12:16:00:WU02:FS00:0xa7:       Bits: 64
12:16:00:WU02:FS00:0xa7:       Mode: Release
12:16:00:WU02:FS00:0xa7:************************************ System ************************************
12:16:00:WU02:FS00:0xa7:        CPU: Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz
12:16:00:WU02:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 30 Stepping 5
12:16:00:WU02:FS00:0xa7:       CPUs: 8
12:16:00:WU02:FS00:0xa7:     Memory: 16.00GiB
12:16:00:WU02:FS00:0xa7:Free Memory: 8.40GiB
12:16:00:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
12:16:00:WU02:FS00:0xa7: OS Version: 6.1
12:16:00:WU02:FS00:0xa7:Has Battery: false
12:16:00:WU02:FS00:0xa7: On Battery: false
12:16:00:WU02:FS00:0xa7: UTC Offset: 2
12:16:00:WU02:FS00:0xa7:        PID: 9984
12:16:00:WU02:FS00:0xa7:        CWD: C:\Users\Enrico\AppData\Roaming\FAHClient\work
12:16:00:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
12:16:00:WU02:FS00:0xa7:    Version: 0.0.18
12:16:00:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:16:00:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
12:16:00:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
12:16:00:WU02:FS00:0xa7:       Time: 01:52:44
12:16:00:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
12:16:00:WU02:FS00:0xa7:************************************ Build *************************************
12:16:00:WU02:FS00:0xa7:       SIMD: sse2
12:16:00:WU02:FS00:0xa7:********************************************************************************
12:16:00:WU02:FS00:0xa7:Project: 14724 (Run 2162, Clone 1, Gen 19)
12:16:00:WU02:FS00:0xa7:Unit: 0x000000169bf7a4d55ea2cf57bb5da941
12:16:00:WU02:FS00:0xa7:Digital signatures verified
12:16:00:WU02:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
12:16:00:WU02:FS00:0xa7:Calling: mdrun -s frame19.tpr -o frame19.trr -cpi state.cpt -cpt 15 -nt 6
12:16:00:WU02:FS00:0xa7:Steps: first=0 total=250000
12:16:01:WU02:FS00:0xa7:Completed 1415 out of 250000 steps (0%)
12:16:08:ERROR:WU00:FS01:Exception: Server did not assign work unit
12:16:10:WU00:FS01:Connecting to 65.254.110.245:80
12:16:10:WU00:FS01:Assigned to work server 13.82.98.119
12:16:11:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress [Radeon HD 5800/6800] from 13.82.98.119
12:16:11:WU00:FS01:Connecting to 13.82.98.119:8080
12:16:14:FS00:Finishing
12:16:31:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
12:16:31:WU00:FS01:Connecting to 13.82.98.119:80
12:16:35:Saving configuration to config.xml
12:16:35:<config>
12:16:35:  <!-- Folding Slot Configuration -->
12:16:35:  <cause v='COVID_19'/>
12:16:35:
12:16:35:  <!-- Network -->
12:16:35:  <proxy v=':8080'/>
12:16:35:
12:16:35:  <!-- Slot Control -->
12:16:35:  <power v='full'/>
12:16:35:
12:16:35:  <!-- User Information -->
12:16:35:  <passkey v='*****'/>
12:16:35:  <user v='Farge'/>
12:16:35:
12:16:35:  <!-- Folding Slots -->
12:16:35:  <slot id='0' type='CPU'/>
12:16:35:  <slot id='1' type='GPU'/>
12:16:35:</config>
12:17:05:ERROR:WU00:FS01:Exception: Server did not assign work unit
12:17:25:WU02:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
12:17:47:WU00:FS01:Connecting to 65.254.110.245:80
12:17:48:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
12:17:48:WU00:FS01:Connecting to 18.218.241.186:80
12:17:48:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
12:17:48:WU00:FS01:Connecting to 65.254.110.245:80
12:17:49:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
12:17:49:WU00:FS01:Connecting to 18.218.241.186:80
12:17:49:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
12:17:49:ERROR:WU00:FS01:Exception: Could not get an assignment
12:20:25:WU00:FS01:Connecting to 65.254.110.245:80
12:20:25:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
12:20:25:WU00:FS01:Connecting to 18.218.241.186:80
12:20:26:WU00:FS01:Assigned to work server 13.82.98.119
12:20:26:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress [Radeon HD 5800/6800] from 13.82.98.119
12:20:26:WU00:FS01:Connecting to 13.82.98.119:8080
12:20:38:WU02:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
12:20:46:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
12:20:46:WU00:FS01:Connecting to 13.82.98.119:80
12:21:57:ERROR:WU00:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
I don't know if this can be considered a temporary problem or not?
Post by muziqaz »
Farge wrote:Hi Bruce,
12:16:35:<config>
12:16:35:
12:16:35:
12:16:35:
12:16:35:
12:16:35:</config>
That is typical no work available/servers overloaded messages ;)
Sit tight and you might receive a WU
FAH Omega tester
Farge
Post by Farge »
It's working!
Thank you again for your support
Cheers
