This started happening a few days ago; I have two different machines where I have the "open-web-control" option removed since I use the advanced control panel instead. However, every time I restart the FAH on both rigs, the web control still pops up and the option returns back under the expert tab. This happens whether I remove the entire option or set it to false. Both clients are on 7.6.9, Win 10, Nvidia GPUs if that matters.
Any ideas on how to fix this?
Clients not saving extra client options
Re: Clients not saving extra client options
If your starting from the start menu option you need to get rid of the open web control part of the shortcut(right click-properties edit out open web control).
anandhanju
Can you try with open-web-control value set to False (case sensitive)?
That worked, thank you! Can't believe I forgot to check that first.Rel25917 wrote:If your starting from the start menu option you need to get rid of the open web control part of the shortcut(right click-properties edit out open web control).
