Improving performance on multi-core hardware (basic)
richmintz
Post by richmintz »
Excuse my terminology, I'm relatively unfamiliar with Windows, but I'll try to be precise:
I have two new computers folding, a desktop and laptop. The desktop is performing MUCH better than the laptop, and I don't know why the gap is so high. Just want to make sure I shouldn't be tuning anything on the laptop.
What most seems to be underperforming is the laptop CPU.
Desktop CPU: i5-9400F, 6 cores
Running 7.6.13 beta (because 7.6.9 wouldn't pick up the GPU)
Roughly 125K steps an hour (default FAH settings, CPU threads set to -1)
When folding at full power, CPU at 100% on all 6 cores [but I can still use the computer for other things with almost no noticeable impact on my user experience]
Desktop GPU: Nvidia GTX 1660 Ti
Roughly 350K steps an hour (default FAH settings, all I did was add the GPU slot)
Laptop CPU: i7-10510U, 4 physical/8 logical cores
Running 7.6.9
Roughly 40K steps an hour
When folding at full power, CPU utilization under 15% always, and 6 of the 8 cores are always parked
[I understand what "parked" means, but given that Windows does this automatically I don't want to override it without clear guidance from you.]
Tried explicitly setting FAH CPU cores to 8, I briefly saw all 8 cores utilized and CPU up at 100%, walked away, came back to the desk again a few min later and it was back down to 2 cores and ~10%
Right now CPU cores are set to 4 (and it's showing
<cpus v='4'/>
in the log). Seems to have no effect.
Laptop GPU: Nvidia MX250
Roughly 30K steps an hour
Will post the tail end of the laptop log below, stripping out some of the junk.
richmintz
Re: Improving performance on multi-core hardware (basic)
Post by richmintz »
Laptop log:
23:08:38:WU01:FS01:0x22:************************************ Build *************************************
23:08:38:WU01:FS01:0x22:    Version: 0.0.5
23:08:38:WU01:FS01:0x22:       Date: Apr 22 2020
23:08:38:WU01:FS01:0x22:       Time: 04:42:59
23:08:38:WU01:FS01:0x22: Repository: Git
23:08:38:WU01:FS01:0x22:   Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
23:08:38:WU01:FS01:0x22:     Branch: HEAD
23:08:38:WU01:FS01:0x22:   Compiler: Visual C++ 2008
23:08:38:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:08:38:WU01:FS01:0x22:   Platform: win32 10
23:08:38:WU01:FS01:0x22:       Bits: 64
23:08:38:WU01:FS01:0x22:       Mode: Release
23:08:38:WU01:FS01:0x22:************************************ System ************************************
23:08:38:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i7-10510U CPU @ 1.80GHz
23:08:38:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 12
23:08:38:WU01:FS01:0x22:       CPUs: 8
23:08:38:WU01:FS01:0x22:     Memory: 7.79GiB
23:08:38:WU01:FS01:0x22:Free Memory: 4.59GiB
23:08:38:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
23:08:38:WU01:FS01:0x22: OS Version: 6.2
23:08:38:WU01:FS01:0x22:Has Battery: true
23:08:38:WU01:FS01:0x22: On Battery: false
23:08:38:WU01:FS01:0x22: UTC Offset: -4
23:08:38:WU01:FS01:0x22:        PID: 11568
23:08:38:WU01:FS01:0x22:        CWD: C:\Users\richm\AppData\Roaming\FAHClient\work
23:08:38:WU01:FS01:0x22:         OS: Windows 10 Home
23:08:38:WU01:FS01:0x22:    OS Arch: AMD64
23:08:38:WU01:FS01:0x22:********************************************************************************
23:08:38:WU01:FS01:0x22:Project: 14434 (Run 0, Clone 1419, Gen 32)
23:08:38:WU01:FS01:0x22:Unit: 0x0000002d0d5262775e8b4d556eb58101
23:08:38:WU01:FS01:0x22:Digital signatures verified
23:08:38:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
23:08:38:WU01:FS01:0x22:Version 0.0.5
23:08:39:WU01:FS01:0x22:  Found a checkpoint file
23:08:39:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
23:08:39:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
23:08:50:WU01:FS01:0x22:Completed 600000 out of 2000000 steps (30%)
23:08:50:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
23:09:09:Removing old file 'configs/config-20200429-180953.xml'
23:09:09:Saving configuration to config.xml
23:09:09:<config>
23:09:09:  <!-- Network -->
23:09:09:  <proxy v=':8080'/>
23:09:09:
23:09:09:  <!-- Slot Control -->
23:09:09:  <power v='full'/>
23:09:09:
23:09:09:  <!-- User Information -->
23:09:09:  <passkey v='*****'/>
23:09:09:  <team v='245954'/>
23:09:09:  <user v='Rich_Mintz'/>
23:09:09:
23:09:09:  <!-- Folding Slots -->
23:09:09:  <slot id='0' type='CPU'/>
23:09:09:  <slot id='1' type='GPU'/>
23:09:09:</config>
23:09:18:WU00:FS00:Starting
23:09:18:WARNING:WU00:FS00:Changed SMP threads from 3 to 7 this can cause some work units to fail
23:09:18:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\richm\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 13008 -checkpoint 15 -np 7
23:09:18:WU00:FS00:Started FahCore on PID 8372
23:09:18:WU00:FS00:Core PID:10964
23:09:18:WU00:FS00:FahCore 0xa7 started
23:09:18:WU00:FS00:0xa7:*********************** Log Started 2020-05-01T23:09:18Z ***********************
23:09:18:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
23:09:18:WU00:FS00:0xa7:       Type: 0xa7
23:09:18:WU00:FS00:0xa7:       Core: Gromacs
23:09:18:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 8372 -checkpoint 15 -np 7
23:09:18:WU00:FS00:0xa7:************************************ CBang *************************************
23:09:18:WU00:FS00:0xa7:       Date: Oct 26 2019
23:09:18:WU00:FS00:0xa7:       Time: 01:38:25
23:09:18:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
23:09:18:WU00:FS00:0xa7:     Branch: master
23:09:18:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
23:09:18:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:09:18:WU00:FS00:0xa7:   Platform: win32 10
23:09:18:WU00:FS00:0xa7:       Bits: 64
23:09:18:WU00:FS00:0xa7:       Mode: Release
23:09:18:WU00:FS00:0xa7:************************************ System ************************************
23:09:18:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-10510U CPU @ 1.80GHz
23:09:18:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 12
23:09:18:WU00:FS00:0xa7:       CPUs: 8
23:09:18:WU00:FS00:0xa7:     Memory: 7.79GiB
23:09:18:WU00:FS00:0xa7:Free Memory: 4.14GiB
23:09:18:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
23:09:18:WU00:FS00:0xa7: OS Version: 6.2
23:09:18:WU00:FS00:0xa7:Has Battery: true
23:09:18:WU00:FS00:0xa7: On Battery: false
23:09:18:WU00:FS00:0xa7: UTC Offset: -4
23:09:18:WU00:FS00:0xa7:        PID: 10964
23:09:18:WU00:FS00:0xa7:        CWD: C:\Users\richm\AppData\Roaming\FAHClient\work
23:09:18:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
23:09:18:WU00:FS00:0xa7:    Version: 0.0.18
23:09:18:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:09:18:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
23:09:18:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
23:09:18:WU00:FS00:0xa7:       Time: 01:52:30
23:09:18:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
23:09:18:WU00:FS00:0xa7:************************************ Build *************************************
23:09:18:WU00:FS00:0xa7:       SIMD: avx_256
23:09:18:WU00:FS00:0xa7:********************************************************************************
23:09:18:WU00:FS00:0xa7:Project: 13850 (Run 0, Clone 29566, Gen 87)
23:09:18:WU00:FS00:0xa7:Unit: 0x00000067287234c95e788ed2366f4577
23:09:18:WU00:FS00:0xa7:Digital signatures verified
23:09:18:WU00:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
23:09:18:WU00:FS00:0xa7:Calling: mdrun -s frame87.tpr -o frame87.trr -x frame87.xtc -e frame87.edr -cpi state.cpt -cpt 15 -nt 6
23:09:18:WU00:FS00:0xa7:Steps: first=43500000 total=500000
23:09:21:WU00:FS00:0xa7:Completed 10402 out of 500000 steps (2%)
23:15:04:FS00:Shutting core down
23:15:04:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 10964
23:15:04:WU00:FS00:0xa7:Exiting, please wait. . .
23:15:05:FS01:Shutting core down
23:15:05:WU01:FS01:0x22:WARNING:Console control signal 1 on PID 11568
23:15:05:WU01:FS01:0x22:Exiting, please wait. . .
23:15:05:WU01:FS01:0x22:Folding@home Core Shutdown: INTERRUPTED
23:15:08:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
23:15:12:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
23:15:13:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
23:15:13:WU00:FS00:Starting
23:15:13:WARNING:WU00:FS00:Changed SMP threads from 7 to 3 this can cause some work units to fail
23:15:13:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\richm\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 13008 -checkpoint 15 -np 3
23:15:13:WU00:FS00:Started FahCore on PID 3352
23:15:13:WU00:FS00:Core PID:2652
23:15:13:WU00:FS00:FahCore 0xa7 started
23:15:13:WU00:FS00:0xa7:*********************** Log Started 2020-05-01T23:15:13Z ***********************
23:15:13:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
23:15:14:WU00:FS00:0xa7:       Type: 0xa7
23:15:14:WU00:FS00:0xa7:       Core: Gromacs
23:15:14:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 3352 -checkpoint 15 -np 3
23:15:14:WU00:FS00:0xa7:************************************ CBang *************************************
23:15:14:WU00:FS00:0xa7:       Date: Oct 26 2019
23:15:14:WU00:FS00:0xa7:       Time: 01:38:25
23:15:14:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
23:15:14:WU00:FS00:0xa7:     Branch: master
23:15:14:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
23:15:14:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:15:14:WU00:FS00:0xa7:   Platform: win32 10
23:15:14:WU00:FS00:0xa7:       Bits: 64
23:15:14:WU00:FS00:0xa7:       Mode: Release
23:15:14:WU00:FS00:0xa7:************************************ System ************************************
23:15:14:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-10510U CPU @ 1.80GHz
23:15:14:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 12
23:15:14:WU00:FS00:0xa7:       CPUs: 8
23:15:14:WU00:FS00:0xa7:     Memory: 7.79GiB
23:15:14:WU00:FS00:0xa7:Free Memory: 4.53GiB
23:15:14:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
23:15:14:WU00:FS00:0xa7: OS Version: 6.2
23:15:14:WU00:FS00:0xa7:Has Battery: true
23:15:14:WU00:FS00:0xa7: On Battery: false
23:15:14:WU00:FS00:0xa7: UTC Offset: -4
23:15:14:WU00:FS00:0xa7:        PID: 2652
23:15:14:WU00:FS00:0xa7:        CWD: C:\Users\richm\AppData\Roaming\FAHClient\work
23:15:14:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
23:15:14:WU00:FS00:0xa7:    Version: 0.0.18
23:15:14:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:15:14:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
23:15:14:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
23:15:14:WU00:FS00:0xa7:       Time: 01:52:30
23:15:14:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
23:15:14:WU00:FS00:0xa7:************************************ Build *************************************
23:15:14:WU00:FS00:0xa7:       SIMD: avx_256
23:15:14:WU00:FS00:0xa7:********************************************************************************
23:15:14:WU00:FS00:0xa7:Project: 13850 (Run 0, Clone 29566, Gen 87)
23:15:14:WU00:FS00:0xa7:Unit: 0x00000067287234c95e788ed2366f4577
23:15:14:WU00:FS00:0xa7:Digital signatures verified
23:15:14:WU00:FS00:0xa7:Calling: mdrun -s frame87.tpr -o frame87.trr -x frame87.xtc -e frame87.edr -cpi state.cpt -cpt 15 -nt 3
23:15:14:WU00:FS00:0xa7:Steps: first=43500000 total=500000
23:15:15:Removing old file 'configs/config-20200429-181018.xml'
23:15:15:Saving configuration to config.xml
23:15:15:<config>
23:15:15:  <!-- Network -->
23:15:15:  <proxy v=':8080'/>
23:15:15:
23:15:15:  <!-- User Information -->
23:15:15:  <passkey v='*****'/>
23:15:15:  <team v='245954'/>
23:15:15:  <user v='Rich_Mintz'/>
23:15:15:
23:15:15:  <!-- Folding Slots -->
23:15:15:  <slot id='0' type='CPU'/>
23:15:15:  <slot id='1' type='GPU'/>
23:15:15:</config>
23:15:22:WU00:FS00:0xa7:Completed 11822 out of 500000 steps (2%)
23:17:27:FS00:Shutting core down
23:17:27:WU01:FS01:Starting
23:17:27:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\richm\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -d
ir 01 -suffix 01 -version 706 -lifeline 13008 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
23:17:27:WU01:FS01:Started FahCore on PID 8236
23:17:27:WU01:FS01:Core PID:8784
23:17:27:WU01:FS01:FahCore 0x22 started
23:17:27:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 2652
23:17:27:WU00:FS00:0xa7:Exiting, please wait. . .
23:17:27:WU01:FS01:0x22:*********************** Log Started 2020-05-01T23:17:27Z ***********************
23:17:27:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
23:17:27:WU01:FS01:0x22:       Type: 0x22
23:17:27:WU01:FS01:0x22:       Core: Core22
23:17:27:WU01:FS01:0x22:    Website: https://foldingathome.org/
23:17:27:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
23:17:27:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
23:17:27:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
23:17:27:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 8236 -checkpoint 15
23:17:27:WU01:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
23:17:27:WU01:FS01:0x22:             0 -gpu 0
23:17:27:WU01:FS01:0x22:     Config: <none>
23:17:27:WU01:FS01:0x22:************************************ Build *************************************
23:17:27:WU01:FS01:0x22:    Version: 0.0.5
23:17:27:WU01:FS01:0x22:       Date: Apr 22 2020
23:17:27:WU01:FS01:0x22:       Time: 04:42:59
23:17:27:WU01:FS01:0x22: Repository: Git
23:17:27:WU01:FS01:0x22:   Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
23:17:27:WU01:FS01:0x22:     Branch: HEAD
23:17:27:WU01:FS01:0x22:   Compiler: Visual C++ 2008
23:17:27:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:17:27:WU01:FS01:0x22:   Platform: win32 10
23:17:27:WU01:FS01:0x22:       Bits: 64
23:17:27:WU01:FS01:0x22:       Mode: Release
23:17:27:WU01:FS01:0x22:************************************ System ************************************
23:17:27:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i7-10510U CPU @ 1.80GHz
23:17:27:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 12
23:17:27:WU01:FS01:0x22:       CPUs: 8
23:17:27:WU01:FS01:0x22:     Memory: 7.79GiB
23:17:27:WU01:FS01:0x22:Free Memory: 4.35GiB
23:17:27:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
23:17:27:WU01:FS01:0x22: OS Version: 6.2
23:17:27:WU01:FS01:0x22:Has Battery: true
23:17:27:WU01:FS01:0x22: On Battery: false
23:17:27:WU01:FS01:0x22: UTC Offset: -4
23:17:27:WU01:FS01:0x22:        PID: 8784
23:17:27:WU01:FS01:0x22:        CWD: C:\Users\richm\AppData\Roaming\FAHClient\work
23:17:27:WU01:FS01:0x22:         OS: Windows 10 Home
23:17:27:WU01:FS01:0x22:    OS Arch: AMD64
23:17:27:WU01:FS01:0x22:********************************************************************************
23:17:27:WU01:FS01:0x22:Project: 14434 (Run 0, Clone 1419, Gen 32)
23:17:27:WU01:FS01:0x22:Unit: 0x0000002d0d5262775e8b4d556eb58101
23:17:27:WU01:FS01:0x22:Digital signatures verified
23:17:27:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
23:17:27:WU01:FS01:0x22:Version 0.0.5
23:17:28:WU01:FS01:0x22:  Found a checkpoint file
23:17:28:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
23:17:28:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
23:17:29:WU00:FS00:Starting
23:17:29:WARNING:WU00:FS00:Changed SMP threads from 3 to 7 this can cause some work units to fail
23:17:29:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\richm\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 13008 -checkpoint 15 -np 7
23:17:29:WU00:FS00:Started FahCore on PID 1332
23:17:29:WU00:FS00:Core PID:2716
23:17:29:WU00:FS00:FahCore 0xa7 started
23:17:29:WU00:FS00:0xa7:*********************** Log Started 2020-05-01T23:17:29Z ***********************
23:17:29:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
23:17:29:WU00:FS00:0xa7:       Type: 0xa7
23:17:29:WU00:FS00:0xa7:       Core: Gromacs
23:17:29:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 1332 -checkpoint 15 -np 7
23:17:29:WU00:FS00:0xa7:************************************ CBang *************************************
23:17:29:WU00:FS00:0xa7:       Date: Oct 26 2019
23:17:29:WU00:FS00:0xa7:       Time: 01:38:25
23:17:29:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
23:17:29:WU00:FS00:0xa7:     Branch: master
23:17:29:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
23:17:29:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:17:29:WU00:FS00:0xa7:   Platform: win32 10
23:17:29:WU00:FS00:0xa7:       Bits: 64
23:17:29:WU00:FS00:0xa7:       Mode: Release
23:17:29:WU00:FS00:0xa7:************************************ System ************************************
23:17:29:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-10510U CPU @ 1.80GHz
23:17:29:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 12
23:17:29:WU00:FS00:0xa7:       CPUs: 8
23:17:29:WU00:FS00:0xa7:     Memory: 7.79GiB
23:17:29:WU00:FS00:0xa7:Free Memory: 4.30GiB
23:17:29:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
23:17:29:WU00:FS00:0xa7: OS Version: 6.2
23:17:29:WU00:FS00:0xa7:Has Battery: true
23:17:29:WU00:FS00:0xa7: On Battery: false
23:17:29:WU00:FS00:0xa7: UTC Offset: -4
23:17:29:WU00:FS00:0xa7:        PID: 2716
23:17:29:WU00:FS00:0xa7:        CWD: C:\Users\richm\AppData\Roaming\FAHClient\work
23:17:29:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
23:17:29:WU00:FS00:0xa7:    Version: 0.0.18
23:17:29:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:17:29:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
23:17:29:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
23:17:29:WU00:FS00:0xa7:       Time: 01:52:30
23:17:29:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
23:17:29:WU00:FS00:0xa7:************************************ Build *************************************
23:17:29:WU00:FS00:0xa7:       SIMD: avx_256
23:17:29:WU00:FS00:0xa7:********************************************************************************
23:17:29:WU00:FS00:0xa7:Project: 13850 (Run 0, Clone 29566, Gen 87)
23:17:29:WU00:FS00:0xa7:Unit: 0x00000067287234c95e788ed2366f4577
23:17:29:WU00:FS00:0xa7:Digital signatures verified
23:17:29:WU00:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
23:17:29:WU00:FS00:0xa7:Calling: mdrun -s frame87.tpr -o frame87.trr -x frame87.xtc -e frame87.edr -cpi state.cpt -cpt 15 -nt 6
23:17:29:WU00:FS00:0xa7:Steps: first=43500000 total=500000
23:17:32:WU00:FS00:0xa7:Completed 13172 out of 500000 steps (2%)
23:18:11:WU01:FS01:0x22:Completed 600000 out of 2000000 steps (30%)
23:18:11:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
23:18:18:Removing old file 'configs/config-20200429-181348.xml'
23:18:18:Saving configuration to config.xml
23:18:18:<config>
23:18:18:  <!-- Network -->
23:18:18:  <proxy v=':8080'/>
23:18:18:
23:18:18:  <!-- Slot Control -->
23:18:18:  <power v='full'/>
23:18:18:
23:18:18:  <!-- User Information -->
23:18:18:  <passkey v='*****'/>
23:18:18:  <team v='245954'/>
23:18:18:  <user v='Rich_Mintz'/>
23:18:18:
23:18:18:  <!-- Folding Slots -->
23:18:18:  <slot id='0' type='CPU'/>
23:18:18:  <slot id='1' type='GPU'/>
23:18:18:</config>
23:24:57:FS00:Shutting core down
23:24:58:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 2716
23:24:58:WU00:FS00:0xa7:Exiting, please wait. . .
23:25:25:Removing old file 'configs/config-20200429-181422.xml'
23:25:25:Saving configuration to config.xml
23:25:25:<config>
23:25:25:  <!-- Network -->
23:25:25:  <proxy v=':8080'/>
23:25:25:
23:25:25:  <!-- Slot Control -->
23:25:25:  <power v='medium'/>
23:25:25:
23:25:25:  <!-- User Information -->
23:25:25:  <passkey v='*****'/>
23:25:25:  <team v='245954'/>
23:25:25:  <user v='Rich_Mintz'/>
23:25:25:
23:25:25:  <!-- Folding Slots -->
23:25:25:  <slot id='0' type='CPU'/>
23:25:25:  <slot id='1' type='GPU'/>
23:25:25:</config>
23:25:31:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
23:25:31:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
23:25:31:WU00:FS00:Starting
23:25:31:WARNING:WU00:FS00:Changed SMP threads from 7 to 6 this can cause some work units to fail
23:25:32:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\richm\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 13008 -checkpoint 15 -np 6
23:25:32:WU00:FS00:Started FahCore on PID 5288
23:25:32:WU00:FS00:Core PID:13744
23:25:32:WU00:FS00:FahCore 0xa7 started
23:25:35:WU00:FS00:0xa7:*********************** Log Started 2020-05-01T23:25:35Z ***********************
23:25:35:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
23:25:35:WU00:FS00:0xa7:       Type: 0xa7
23:25:35:WU00:FS00:0xa7:       Core: Gromacs
23:25:35:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 5288 -checkpoint 15 -np 6
23:25:35:WU00:FS00:0xa7:************************************ CBang *************************************
23:25:35:WU00:FS00:0xa7:       Date: Oct 26 2019
23:25:35:WU00:FS00:0xa7:       Time: 01:38:25
23:25:36:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
23:25:36:WU00:FS00:0xa7:     Branch: master
23:25:36:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
23:25:36:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:25:36:WU00:FS00:0xa7:   Platform: win32 10
23:25:36:WU00:FS00:0xa7:       Bits: 64
23:25:36:WU00:FS00:0xa7:       Mode: Release
23:25:36:WU00:FS00:0xa7:************************************ System ************************************
23:25:36:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-10510U CPU @ 1.80GHz
23:25:36:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 12
23:25:36:WU00:FS00:0xa7:       CPUs: 8
23:25:36:WU00:FS00:0xa7:     Memory: 7.79GiB
23:25:36:WU00:FS00:0xa7:Free Memory: 3.88GiB
23:25:36:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
23:25:36:WU00:FS00:0xa7: OS Version: 6.2
23:25:36:WU00:FS00:0xa7:Has Battery: true
23:25:36:WU00:FS00:0xa7: On Battery: false
23:25:36:WU00:FS00:0xa7: UTC Offset: -4
23:25:36:WU00:FS00:0xa7:        PID: 13744
23:25:36:WU00:FS00:0xa7:        CWD: C:\Users\richm\AppData\Roaming\FAHClient\work
23:25:36:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
23:25:36:WU00:FS00:0xa7:    Version: 0.0.18
23:25:36:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:25:36:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
23:25:36:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
23:25:36:WU00:FS00:0xa7:       Date: Oct 26 2019
23:25:36:WU00:FS00:0xa7:       Time: 01:52:30
23:25:36:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
23:25:37:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
23:25:37:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:25:37:WU00:FS00:0xa7:   Platform: win32 10
23:25:37:WU00:FS00:0xa7:       Bits: 64
23:25:37:WU00:FS00:0xa7:       Mode: Release
23:25:37:WU00:FS00:0xa7:************************************ Build *************************************
23:25:37:WU00:FS00:0xa7:       SIMD: avx_256
23:25:37:WU00:FS00:0xa7:********************************************************************************
23:25:37:WU00:FS00:0xa7:Project: 13850 (Run 0, Clone 29566, Gen 87)
23:25:37:WU00:FS00:0xa7:Unit: 0x00000067287234c95e788ed2366f4577
23:25:37:WU00:FS00:0xa7:Digital signatures verified
23:25:37:WU00:FS00:0xa7:Calling: mdrun -s frame87.tpr -o frame87.trr -x frame87.xtc -e frame87.edr -cpi state.cpt -cpt 15 -nt 6
23:25:38:WU00:FS00:0xa7:Steps: first=43500000 total=500000
23:26:09:Removing old file 'configs/config-20200430-023206.xml'
23:26:09:Saving configuration to config.xml
23:26:09:<config>
23:26:09:  <!-- Network -->
23:26:09:  <proxy v=':8080'/>
23:26:09:
23:26:09:  <!-- Slot Control -->
23:26:09:  <power v='medium'/>
23:26:09:
23:26:09:  <!-- User Information -->
23:26:09:  <passkey v='*****'/>
23:26:09:  <team v='245954'/>
23:26:09:  <user v='Rich_Mintz'/>
23:26:09:
23:26:09:  <!-- Folding Slots -->
23:26:09:  <slot id='0' type='CPU'>
23:26:09:    <cpus v='6'/>
23:26:09:  </slot>
23:26:09:  <slot id='1' type='GPU'/>
23:26:09:</config>
23:26:14:WU00:FS00:0xa7:Completed 13982 out of 500000 steps (2%)
23:26:26:Removing old file 'configs/config-20200430-025125.xml'
23:26:26:Saving configuration to config.xml
23:26:26:<config>
23:26:26:  <!-- Network -->
23:26:26:  <proxy v=':8080'/>
23:26:26:
23:26:26:  <!-- Slot Control -->
23:26:26:  <power v='medium'/>
23:26:26:
23:26:26:  <!-- User Information -->
23:26:26:  <passkey v='*****'/>
23:26:26:  <team v='245954'/>
23:26:26:  <user v='Rich_Mintz'/>
23:26:26:
23:26:26:  <!-- Folding Slots -->
23:26:26:  <slot id='0' type='CPU'>
23:26:26:    <cpus v='6'/>
23:26:26:  </slot>
23:26:26:  <slot id='1' type='GPU'/>
23:26:26:</config>
23:27:00:Removing old file 'configs/config-20200430-231428.xml'
23:27:00:Saving configuration to config.xml
23:27:00:<config>
23:27:00:  <!-- Network -->
23:27:00:  <proxy v=':8080'/>
23:27:00:
23:27:00:  <!-- Slot Control -->
23:27:00:  <power v='medium'/>
23:27:00:
23:27:00:  <!-- User Information -->
23:27:00:  <passkey v='*****'/>
23:27:00:  <team v='245954'/>
23:27:00:  <user v='Rich_Mintz'/>
23:27:00:
23:27:00:  <!-- Folding Slots -->
23:27:00:  <slot id='0' type='CPU'>
23:27:00:    <cpus v='8'/>
23:27:00:  </slot>
23:27:00:  <slot id='1' type='GPU'/>
23:27:00:</config>
23:27:00:FS00:Shutting core down
23:27:01:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 13744
23:27:01:WU00:FS00:0xa7:Exiting, please wait. . .
23:27:17:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
23:27:18:WU00:FS00:Starting
23:27:18:WARNING:WU00:FS00:Changed SMP threads from 6 to 8 this can cause some work units to fail
23:27:18:WARNING:WU00:FS00:AS lowered CPUs from 8 to 7
23:27:18:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\richm\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 13008 -checkpoint 15 -np 7
23:27:18:WU00:FS00:Started FahCore on PID 5700
23:27:19:WU00:FS00:Core PID:10052
23:27:19:WU00:FS00:FahCore 0xa7 started
23:27:21:WU00:FS00:0xa7:*********************** Log Started 2020-05-01T23:27:21Z ***********************
23:27:21:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
23:27:21:WU00:FS00:0xa7:       Type: 0xa7
23:27:21:WU00:FS00:0xa7:       Core: Gromacs
23:27:21:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 5700 -checkpoint 15 -np 7
23:27:21:WU00:FS00:0xa7:************************************ CBang *************************************
23:27:22:WU00:FS00:0xa7:       Date: Oct 26 2019
23:27:22:WU00:FS00:0xa7:       Time: 01:38:25
23:27:22:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
23:27:22:WU00:FS00:0xa7:     Branch: master
23:27:22:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
23:27:22:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:27:22:WU00:FS00:0xa7:   Platform: win32 10
23:27:22:WU00:FS00:0xa7:       Bits: 64
23:27:22:WU00:FS00:0xa7:       Mode: Release
23:27:22:WU00:FS00:0xa7:************************************ System ************************************
23:27:22:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-10510U CPU @ 1.80GHz
23:27:22:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 12
23:27:22:WU00:FS00:0xa7:       CPUs: 8
23:27:22:WU00:FS00:0xa7:     Memory: 7.79GiB
23:27:22:WU00:FS00:0xa7:Free Memory: 4.06GiB
23:27:22:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
23:27:22:WU00:FS00:0xa7: OS Version: 6.2
23:27:22:WU00:FS00:0xa7:Has Battery: true
23:27:22:WU00:FS00:0xa7: On Battery: false
23:27:22:WU00:FS00:0xa7: UTC Offset: -4
23:27:23:WU00:FS00:0xa7:        PID: 10052
23:27:23:WU00:FS00:0xa7:        CWD: C:\Users\richm\AppData\Roaming\FAHClient\work
23:27:23:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
23:27:23:WU00:FS00:0xa7:    Version: 0.0.18
23:27:23:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:27:23:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
23:27:23:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
23:27:23:WU00:FS00:0xa7:       Date: Oct 26 2019
23:27:23:WU00:FS00:0xa7:       Time: 01:52:30
23:27:23:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
23:27:23:WU00:FS00:0xa7:     Branch: master
23:27:23:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
23:27:23:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:27:23:WU00:FS00:0xa7:   Platform: win32 10
23:27:23:WU00:FS00:0xa7:       Bits: 64
23:27:23:WU00:FS00:0xa7:       Mode: Release
23:27:23:WU00:FS00:0xa7:************************************ Build *************************************
23:27:23:WU00:FS00:0xa7:       SIMD: avx_256
23:27:23:WU00:FS00:0xa7:********************************************************************************
23:27:23:WU00:FS00:0xa7:Project: 13850 (Run 0, Clone 29566, Gen 87)
23:27:23:WU00:FS00:0xa7:Unit: 0x00000067287234c95e788ed2366f4577
23:27:23:WU00:FS00:0xa7:Digital signatures verified
23:27:23:WU00:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
23:27:23:WU00:FS00:0xa7:Calling: mdrun -s frame87.tpr -o frame87.trr -x frame87.xtc -e frame87.edr -cpi state.cpt -cpt 15 -nt 6
23:27:24:WU00:FS00:0xa7:Steps: first=43500000 total=500000
23:27:27:Removing old file 'configs/config-20200430-231731.xml'
23:27:27:Saving configuration to config.xml
23:27:27:<config>
23:27:27:  <!-- Network -->
23:27:27:  <proxy v=':8080'/>
23:27:27:
23:27:27:  <!-- Slot Control -->
23:27:27:  <power v='medium'/>
23:27:27:
23:27:27:  <!-- User Information -->
23:27:27:  <passkey v='*****'/>
23:27:27:  <team v='245954'/>
23:27:27:  <user v='Rich_Mintz'/>
23:27:27:
23:27:27:  <!-- Folding Slots -->
23:27:27:  <slot id='0' type='CPU'>
23:27:27:    <cpus v='8'/>
23:27:27:  </slot>
23:27:27:  <slot id='1' type='GPU'/>
23:27:27:</config>
23:27:58:WU00:FS00:0xa7:Completed 14012 out of 500000 steps (2%)
23:29:29:Removing old file 'configs/config-20200501-005709.xml'
23:29:32:Saving configuration to config.xml
23:29:35:<config>
23:29:35:  <!-- Network -->
23:29:35:  <proxy v=':8080'/>
23:29:35:
23:29:35:  <!-- Slot Control -->
23:29:35:  <power v='full'/>
23:29:35:
23:29:35:  <!-- User Information -->
23:29:35:  <passkey v='*****'/>
23:29:35:  <team v='245954'/>
23:29:35:  <user v='Rich_Mintz'/>
23:29:35:
23:29:35:  <!-- Folding Slots -->
23:29:35:  <slot id='0' type='CPU'>
23:29:35:    <cpus v='8'/>
23:29:35:  </slot>
23:29:35:  <slot id='1' type='GPU'/>
23:29:35:</config>
23:29:39:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
23:30:39:FS01:Shutting core down
23:30:47:WU01:FS01:0x22:WARNING:Console control signal 1 on PID 8784
23:30:48:WU01:FS01:0x22:Exiting, please wait. . .
23:31:19:WU01:FS01:0x22:Folding@home Core Shutdown: INTERRUPTED
23:31:31:Removing old file 'configs/config-20200501-011729.xml'
23:31:31:Saving configuration to config.xml
23:31:31:<config>
23:31:31:  <!-- Network -->
23:31:31:  <proxy v=':8080'/>
23:31:31:
23:31:31:  <!-- User Information -->
23:31:31:  <passkey v='*****'/>
23:31:31:  <team v='245954'/>
23:31:31:  <user v='Rich_Mintz'/>
23:31:31:
23:31:31:  <!-- Folding Slots -->
23:31:31:  <slot id='0' type='CPU'>
23:31:31:    <cpus v='8'/>
23:31:31:  </slot>
23:31:31:  <slot id='1' type='GPU'/>
23:31:31:</config>
23:31:40:WARNING:FS01:Killing WU01
23:31:40:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
23:34:08:WU00:FS00:0xa7:Completed 15000 out of 500000 steps (3%)
23:40:23:WU00:FS00:0xa7:Completed 20000 out of 500000 steps (4%)
23:41:34:8:127.0.0.1:New Web session
23:46:24:WU00:FS00:0xa7:Completed 25000 out of 500000 steps (5%)
23:46:26:WU01:FS01:Starting
23:46:26:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\richm\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 13008 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
23:46:26:WU01:FS01:Started FahCore on PID 1740
23:46:26:WU01:FS01:Core PID:13620
23:46:26:WU01:FS01:FahCore 0x22 started
23:46:27:WU01:FS01:0x22:*********************** Log Started 2020-05-01T23:46:26Z ***********************
23:46:27:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
23:46:27:WU01:FS01:0x22:       Type: 0x22
23:46:27:WU01:FS01:0x22:       Core: Core22
23:46:27:WU01:FS01:0x22:    Website: https://foldingathome.org/
23:46:27:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
23:46:27:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
23:46:27:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
23:46:27:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 1740 -checkpoint 15
23:46:27:WU01:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
23:46:27:WU01:FS01:0x22:             0 -gpu 0
23:46:27:WU01:FS01:0x22:     Config: <none>
23:46:27:WU01:FS01:0x22:************************************ Build *************************************
23:46:27:WU01:FS01:0x22:    Version: 0.0.5
23:46:27:WU01:FS01:0x22:       Date: Apr 22 2020
23:46:27:WU01:FS01:0x22:       Time: 04:42:59
23:46:27:WU01:FS01:0x22: Repository: Git
23:46:27:WU01:FS01:0x22:   Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
23:46:27:WU01:FS01:0x22:     Branch: HEAD
23:46:27:WU01:FS01:0x22:   Compiler: Visual C++ 2008
23:46:27:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:46:27:WU01:FS01:0x22:   Platform: win32 10
23:46:27:WU01:FS01:0x22:       Bits: 64
23:46:27:WU01:FS01:0x22:       Mode: Release
23:46:27:WU01:FS01:0x22:************************************ System ************************************
23:46:27:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i7-10510U CPU @ 1.80GHz
23:46:27:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 12
23:46:27:WU01:FS01:0x22:       CPUs: 8
23:46:27:WU01:FS01:0x22:     Memory: 7.79GiB
23:46:27:WU01:FS01:0x22:Free Memory: 3.50GiB
23:46:27:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
23:46:27:WU01:FS01:0x22: OS Version: 6.2
23:46:27:WU01:FS01:0x22:Has Battery: true
23:46:27:WU01:FS01:0x22: On Battery: false
23:46:27:WU01:FS01:0x22: UTC Offset: -4
23:46:27:WU01:FS01:0x22:        PID: 13620
23:46:27:WU01:FS01:0x22:        CWD: C:\Users\richm\AppData\Roaming\FAHClient\work
23:46:27:WU01:FS01:0x22:         OS: Windows 10 Home
23:46:27:WU01:FS01:0x22:    OS Arch: AMD64
23:46:27:WU01:FS01:0x22:********************************************************************************
23:46:27:WU01:FS01:0x22:Project: 14434 (Run 0, Clone 1419, Gen 32)
23:46:27:WU01:FS01:0x22:Unit: 0x0000002d0d5262775e8b4d556eb58101
23:46:27:WU01:FS01:0x22:Digital signatures verified
23:46:27:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
23:46:27:WU01:FS01:0x22:Version 0.0.5
23:46:28:WU01:FS01:0x22:  Found a checkpoint file
23:46:46:Removing old file 'configs/config-20200501-134848.xml'
23:46:46:Saving configuration to config.xml
23:46:46:<config>
23:46:46:  <!-- Network -->
23:46:46:  <proxy v=':8080'/>
23:46:46:
23:46:46:  <!-- Slot Control -->
23:46:46:  <power v='full'/>
23:46:46:
23:46:46:  <!-- User Information -->
23:46:46:  <passkey v='*****'/>
23:46:46:  <team v='245954'/>
23:46:46:  <user v='Rich_Mintz'/>
23:46:46:
23:46:46:  <!-- Folding Slots -->
23:46:46:  <slot id='0' type='CPU'>
23:46:46:    <cpus v='8'/>
23:46:46:  </slot>
23:46:46:  <slot id='1' type='GPU'/>
23:46:46:</config>
23:47:07:WU01:FS01:0x22:Completed 600000 out of 2000000 steps (30%)
23:47:08:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
23:53:57:Removing old file 'configs/config-20200501-145459.xml'
23:53:57:Saving configuration to config.xml
23:53:57:<config>
23:53:57:  <!-- Network -->
23:53:57:  <proxy v=':8080'/>
23:53:57:
23:53:57:  <!-- Slot Control -->
23:53:57:  <power v='full'/>
23:53:57:
23:53:57:  <!-- User Information -->
23:53:57:  <passkey v='*****'/>
23:53:57:  <team v='245954'/>
23:53:57:  <user v='Rich_Mintz'/>
23:53:57:
23:53:57:  <!-- Folding Slots -->
23:53:57:  <slot id='0' type='CPU'/>
23:53:57:  <slot id='1' type='GPU'/>
23:53:57:</config>
23:53:58:FS00:Shutting core down
23:53:58:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 10052
23:53:58:WU00:FS00:0xa7:Exiting, please wait. . .
23:54:54:Removing old file 'configs/config-20200501-151014.xml'
23:54:54:Saving configuration to config.xml
23:54:55:<config>
23:54:55:  <!-- Network -->
23:54:55:  <proxy v=':8080'/>
23:54:55:
23:54:55:  <!-- Slot Control -->
23:54:55:  <power v='full'/>
23:54:55:
23:54:55:  <!-- User Information -->
23:54:55:  <passkey v='*****'/>
23:54:55:  <team v='245954'/>
23:54:55:  <user v='Rich_Mintz'/>
23:54:55:
23:54:55:  <!-- Folding Slots -->
23:54:55:  <slot id='0' type='CPU'/>
23:54:55:  <slot id='1' type='GPU'/>
23:54:55:</config>
23:54:59:WARNING:FS00:Killing WU00
23:55:01:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
23:55:01:WU00:FS00:Starting
23:55:01:WARNING:WU00:FS00:Changed SMP threads from 8 to 7 this can cause some work units to fail
23:55:01:ERROR:WU00:FS00:Failed to start core: Failed to rename 'work/00/logfile_01.txt' to 'work/00/logfile_01-20200501-235501.txt': The process cannot access the file because it is being used by another process.
23:55:01:WU00:FS00:Sending unit results: id:00 state:SEND error:FAILED project:13850 run:0 clone:29566 gen:87 core:0xa7 unit:0x00000067287234c95e788ed2366f4577
23:55:01:WU00:FS00:Connecting to 40.114.52.201:8080
23:55:02:WU02:FS00:Connecting to 65.254.110.245:80
23:55:02:WU00:FS00:Server responded WORK_ACK (400)
23:55:02:WU00:FS00:Cleaning up
23:55:02:ERROR:WU00:FS00:Exception: Failed to remove 'work/00/01/frame87.edr': The process cannot access the file because it is being used by another process.
23:55:03:ERROR:WU00:FS00:Exception: Failed to remove 'work/00/01/frame87.edr': The process cannot access the file because it is being used by another process.
23:55:03:WU02:FS00:Assigned to work server 128.252.203.2
23:55:04:WU02:FS00:Requesting new work unit for slot 00: READY cpu:7 from 128.252.203.2
23:55:04:WU02:FS00:Connecting to 128.252.203.2:8080
23:55:25:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
23:55:25:WU02:FS00:Connecting to 128.252.203.2:80
23:55:40:ERROR:WU02:FS00:Exception: Server did not assign work unit
23:55:40:WU02:FS00:Connecting to 65.254.110.245:80
23:55:41:WU02:FS00:Assigned to work server 206.223.170.146
23:55:41:WU02:FS00:Requesting new work unit for slot 00: READY cpu:7 from 206.223.170.146
23:55:41:WU02:FS00:Connecting to 206.223.170.146:8080
23:55:41:WU02:FS00:Downloading 1.37MiB
23:55:42:WU02:FS00:Download complete
23:55:42:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:14534 run:753 clone:2 gen:20 core:0xa7 unit:0x0000001acedfaa925ea34af293e72d1b
23:55:42:WU02:FS00:Starting
23:55:42:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\richm\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 13008 -checkpoint 15 -np 7
23:55:42:WU02:FS00:Started FahCore on PID 1724
23:55:42:WU02:FS00:Core PID:10524
23:55:42:WU02:FS00:FahCore 0xa7 started
23:55:47:WU02:FS00:0xa7:*********************** Log Started 2020-05-01T23:55:46Z ***********************
23:55:47:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
23:55:47:WU02:FS00:0xa7:       Type: 0xa7
23:55:47:WU02:FS00:0xa7:       Core: Gromacs
23:55:47:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 706 -lifeline 1724 -checkpoint 15 -np 7
23:55:47:WU02:FS00:0xa7:************************************ CBang *************************************
23:55:47:WU02:FS00:0xa7:       Date: Oct 26 2019
23:55:47:WU02:FS00:0xa7:       Time: 01:38:25
23:55:47:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
23:55:47:WU02:FS00:0xa7:     Branch: master
23:55:47:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
23:55:47:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:55:47:WU02:FS00:0xa7:   Platform: win32 10
23:55:47:WU02:FS00:0xa7:       Bits: 64
23:55:47:WU02:FS00:0xa7:       Mode: Release
23:55:47:WU02:FS00:0xa7:************************************ System ************************************
23:55:47:WU02:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-10510U CPU @ 1.80GHz
23:55:47:WU02:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 12
23:55:48:WU02:FS00:0xa7:       CPUs: 8
23:55:48:WU02:FS00:0xa7:     Memory: 7.79GiB
23:55:48:WU02:FS00:0xa7:Free Memory: 3.08GiB
23:55:48:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
23:55:48:WU02:FS00:0xa7: OS Version: 6.2
23:55:48:WU02:FS00:0xa7:Has Battery: true
23:55:48:WU02:FS00:0xa7: On Battery: false
23:55:48:WU02:FS00:0xa7: UTC Offset: -4
23:55:48:WU02:FS00:0xa7:        PID: 10524
23:55:48:WU02:FS00:0xa7:        CWD: C:\Users\richm\AppData\Roaming\FAHClient\work
23:55:48:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
23:55:48:WU02:FS00:0xa7:    Version: 0.0.18
23:55:48:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:55:48:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
23:55:48:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
23:55:48:WU02:FS00:0xa7:       Date: Oct 26 2019
23:55:48:WU02:FS00:0xa7:       Time: 01:52:30
23:55:48:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
23:55:48:WU02:FS00:0xa7:     Branch: master
23:55:48:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
23:55:48:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:55:48:WU02:FS00:0xa7:   Platform: win32 10
23:55:48:WU02:FS00:0xa7:       Bits: 64
23:55:48:WU02:FS00:0xa7:       Mode: Release
23:55:48:WU02:FS00:0xa7:************************************ Build *************************************
23:55:48:WU02:FS00:0xa7:       SIMD: avx_256
23:55:48:WU02:FS00:0xa7:********************************************************************************
23:55:49:WU02:FS00:0xa7:Project: 14534 (Run 753, Clone 2, Gen 20)
23:55:49:WU02:FS00:0xa7:Unit: 0x0000001acedfaa925ea34af293e72d1b
23:55:49:WU02:FS00:0xa7:Reading tar file core.xml
23:55:49:WU02:FS00:0xa7:Reading tar file frame20.tpr
23:55:50:WU02:FS00:0xa7:Digital signatures verified
23:55:50:WU02:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
23:55:50:WU02:FS00:0xa7:Calling: mdrun -s frame20.tpr -o frame20.trr -x frame20.xtc -cpt 15 -nt 6
23:55:51:WU02:FS00:0xa7:Steps: first=20000000 total=1000000
23:56:02:WU00:FS00:Cleaning up
23:56:17:WU02:FS00:0xa7:Completed 1 out of 1000000 steps (0%)
00:00:50:FS00:Shutting core down
00:00:50:WU02:FS00:0xa7:WARNING:Console control signal 1 on PID 10524
00:00:50:WU02:FS00:0xa7:Exiting, please wait. . .
00:01:00:Removing old file 'configs/config-20200501-151216.xml'
00:01:00:Saving configuration to config.xml
00:01:00:<config>
00:01:00:  <!-- Network -->
00:01:00:  <proxy v=':8080'/>
00:01:00:
00:01:00:  <!-- Slot Control -->
00:01:00:  <power v='medium'/>
00:01:00:
00:01:00:  <!-- User Information -->
00:01:00:  <passkey v='*****'/>
00:01:00:  <team v='245954'/>
00:01:00:  <user v='Rich_Mintz'/>
00:01:00:
00:01:00:  <!-- Folding Slots -->
00:01:00:  <slot id='0' type='CPU'/>
00:01:00:  <slot id='1' type='GPU'/>
00:01:00:</config>
00:01:23:WU02:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
00:01:23:WU02:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
00:01:24:WU02:FS00:Starting
00:01:24:WARNING:WU02:FS00:Changed SMP threads from 7 to 6 this can cause some work units to fail
00:01:24:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\richm\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 13008 -checkpoint 15 -np 6
00:01:24:WU02:FS00:Started FahCore on PID 14448
00:01:24:WU02:FS00:Core PID:588
00:01:24:WU02:FS00:FahCore 0xa7 started
00:01:27:WU02:FS00:0xa7:*********************** Log Started 2020-05-02T00:01:27Z ***********************
00:01:27:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
00:01:27:WU02:FS00:0xa7:       Type: 0xa7
00:01:28:WU02:FS00:0xa7:       Core: Gromacs
00:01:28:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 706 -lifeline 14448 -checkpoint 15 -np
00:01:28:WU02:FS00:0xa7:             6
00:01:28:WU02:FS00:0xa7:************************************ CBang *************************************
00:01:28:WU02:FS00:0xa7:       Date: Oct 26 2019
00:01:28:WU02:FS00:0xa7:       Time: 01:38:25
00:01:28:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
00:01:28:WU02:FS00:0xa7:     Branch: master
00:01:28:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
00:01:28:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
00:01:28:WU02:FS00:0xa7:   Platform: win32 10
00:01:28:WU02:FS00:0xa7:       Bits: 64
00:01:28:WU02:FS00:0xa7:       Mode: Release
00:01:29:WU02:FS00:0xa7:************************************ System ************************************
00:01:29:WU02:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-10510U CPU @ 1.80GHz
00:01:29:WU02:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 12
00:01:29:WU02:FS00:0xa7:       CPUs: 8
00:01:29:WU02:FS00:0xa7:     Memory: 7.79GiB
00:01:29:WU02:FS00:0xa7:Free Memory: 3.05GiB
00:01:29:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
00:01:29:WU02:FS00:0xa7: OS Version: 6.2
00:01:29:WU02:FS00:0xa7:Has Battery: true
00:01:29:WU02:FS00:0xa7: On Battery: false
00:01:29:WU02:FS00:0xa7: UTC Offset: -4
00:01:29:WU02:FS00:0xa7:        PID: 588
00:01:29:WU02:FS00:0xa7:        CWD: C:\Users\richm\AppData\Roaming\FAHClient\work
00:01:29:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
00:01:29:WU02:FS00:0xa7:    Version: 0.0.18
00:01:29:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:01:29:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
00:01:29:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
00:01:29:WU02:FS00:0xa7:       Date: Oct 26 2019
00:01:29:WU02:FS00:0xa7:       Time: 01:52:30
00:01:29:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
00:01:29:WU02:FS00:0xa7:     Branch: master
00:01:29:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
00:01:29:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
00:01:29:WU02:FS00:0xa7:   Platform: win32 10
00:01:29:WU02:FS00:0xa7:       Bits: 64
00:01:29:WU02:FS00:0xa7:       Mode: Release
00:01:29:WU02:FS00:0xa7:************************************ Build *************************************
00:01:29:WU02:FS00:0xa7:       SIMD: avx_256
00:01:29:WU02:FS00:0xa7:********************************************************************************
00:01:29:WU02:FS00:0xa7:Project: 14534 (Run 753, Clone 2, Gen 20)
00:01:29:WU02:FS00:0xa7:Unit: 0x0000001acedfaa925ea34af293e72d1b
00:01:29:WU02:FS00:0xa7:Digital signatures verified
00:01:29:WU02:FS00:0xa7:Calling: mdrun -s frame20.tpr -o frame20.trr -x frame20.xtc -cpi state.cpt -cpt 15 -nt 6
00:01:31:WU02:FS00:0xa7:Steps: first=20000000 total=1000000
00:02:07:WU02:FS00:0xa7:Completed 132 out of 1000000 steps (0%)
00:07:06:Removing old file 'configs/config-20200501-165359.xml'
00:07:06:Saving configuration to config.xml
00:07:06:<config>
00:07:06:  <!-- Folding Core -->
00:07:06:  <checkpoint v='5'/>
00:07:06:
00:07:06:  <!-- Network -->
00:07:06:  <proxy v=':8080'/>
00:07:06:
00:07:06:  <!-- Slot Control -->
00:07:06:  <power v='medium'/>
00:07:06:
00:07:06:  <!-- User Information -->
00:07:06:  <passkey v='*****'/>
00:07:06:  <team v='245954'/>
00:07:06:  <user v='Rich_Mintz'/>
00:07:06:
00:07:06:  <!-- Folding Slots -->
00:07:06:  <slot id='0' type='CPU'/>
00:07:06:  <slot id='1' type='GPU'/>
00:07:06:</config>
00:08:42:Removing old file 'configs/config-20200501-165500.xml'
00:08:42:Saving configuration to config.xml
00:08:43:<config>
00:08:43:  <!-- Folding Core -->
00:08:43:  <checkpoint v='5'/>
00:08:43:
00:08:43:  <!-- Network -->
00:08:43:  <proxy v=':8080'/>
00:08:43:
00:08:43:  <!-- Slot Control -->
00:08:43:  <power v='medium'/>
00:08:43:
00:08:43:  <!-- User Information -->
00:08:43:  <passkey v='*****'/>
00:08:43:  <team v='245954'/>
00:08:43:  <user v='Rich_Mintz'/>
00:08:43:
00:08:43:  <!-- Folding Slots -->
00:08:43:  <slot id='0' type='CPU'>
00:08:43:    <cpus v='4'/>
00:08:43:  </slot>
00:08:43:  <slot id='1' type='GPU'/>
00:08:43:</config>
00:08:43:FS00:Shutting core down
00:08:43:WU02:FS00:0xa7:WARNING:Console control signal 1 on PID 588
00:08:43:WU02:FS00:0xa7:Exiting, please wait. . .
00:09:05:WU02:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
00:09:06:WU02:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
00:09:06:WU02:FS00:Starting
00:09:06:WARNING:WU02:FS00:Changed SMP threads from 6 to 4 this can cause some work units to fail
00:09:06:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\richm\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 13008 -checkpoint 5 -np 4
00:09:06:WU02:FS00:Started FahCore on PID 12616
00:09:06:WU02:FS00:Core PID:15568
00:09:06:WU02:FS00:FahCore 0xa7 started
00:09:08:Removing old file 'configs/config-20200501-230909.xml'
00:09:08:Saving configuration to config.xml
00:09:08:<config>
00:09:08:  <!-- Folding Core -->
00:09:08:  <checkpoint v='5'/>
00:09:08:
00:09:08:  <!-- Network -->
00:09:08:  <proxy v=':8080'/>
00:09:08:
00:09:08:  <!-- Slot Control -->
00:09:08:  <power v='medium'/>
00:09:08:
00:09:08:  <!-- User Information -->
00:09:08:  <passkey v='*****'/>
00:09:08:  <team v='245954'/>
00:09:08:  <user v='Rich_Mintz'/>
00:09:08:
00:09:08:  <!-- Folding Slots -->
00:09:08:  <slot id='0' type='CPU'>
00:09:08:    <cpus v='4'/>
00:09:08:  </slot>
00:09:08:  <slot id='1' type='GPU'/>
00:09:08:</config>
00:09:10:WU02:FS00:0xa7:*********************** Log Started 2020-05-02T00:09:10Z ***********************
00:09:10:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
00:09:10:WU02:FS00:0xa7:       Type: 0xa7
00:09:10:WU02:FS00:0xa7:       Core: Gromacs
00:09:10:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 706 -lifeline 12616 -checkpoint 5 -np 4
00:09:10:WU02:FS00:0xa7:************************************ CBang *************************************
00:09:11:WU02:FS00:0xa7:       Date: Oct 26 2019
00:09:11:WU02:FS00:0xa7:       Time: 01:38:25
00:09:11:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
00:09:11:WU02:FS00:0xa7:     Branch: master
00:09:11:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
00:09:11:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
00:09:11:WU02:FS00:0xa7:   Platform: win32 10
00:09:11:WU02:FS00:0xa7:       Bits: 64
00:09:11:WU02:FS00:0xa7:       Mode: Release
00:09:12:WU02:FS00:0xa7:************************************ System ************************************
00:09:12:WU02:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-10510U CPU @ 1.80GHz
00:09:12:WU02:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 12
00:09:12:WU02:FS00:0xa7:       CPUs: 8
00:09:12:WU02:FS00:0xa7:     Memory: 7.79GiB
00:09:12:WU02:FS00:0xa7:Free Memory: 3.20GiB
00:09:12:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
00:09:12:WU02:FS00:0xa7: OS Version: 6.2
00:09:12:WU02:FS00:0xa7:Has Battery: true
00:09:12:WU02:FS00:0xa7: On Battery: false
00:09:12:WU02:FS00:0xa7: UTC Offset: -4
00:09:12:WU02:FS00:0xa7:        PID: 15568
00:09:12:WU02:FS00:0xa7:        CWD: C:\Users\richm\AppData\Roaming\FAHClient\work
00:09:13:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
00:09:13:WU02:FS00:0xa7:    Version: 0.0.18
00:09:13:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:09:14:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
00:09:14:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
00:09:14:WU02:FS00:0xa7:       Date: Oct 26 2019
00:09:14:WU02:FS00:0xa7:       Time: 01:52:30
00:09:14:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
00:09:15:WU02:FS00:0xa7:     Branch: master
00:09:15:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
00:09:15:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
00:09:16:WU02:FS00:0xa7:   Platform: win32 10
00:09:16:WU02:FS00:0xa7:       Bits: 64
00:09:16:WU02:FS00:0xa7:       Mode: Release
00:09:16:WU02:FS00:0xa7:************************************ Build *************************************
00:09:16:WU02:FS00:0xa7:       SIMD: avx_256
00:09:16:WU02:FS00:0xa7:********************************************************************************
00:09:16:WU02:FS00:0xa7:Project: 14534 (Run 753, Clone 2, Gen 20)
00:09:16:WU02:FS00:0xa7:Unit: 0x0000001acedfaa925ea34af293e72d1b
00:09:16:WU02:FS00:0xa7:Digital signatures verified
00:09:16:WU02:FS00:0xa7:Calling: mdrun -s frame20.tpr -o frame20.trr -x frame20.xtc -cpi state.cpt -cpt 5 -nt 4
00:09:20:WU02:FS00:0xa7:Steps: first=20000000 total=1000000
00:09:31:WU02:FS00:0xa7:Completed 312 out of 1000000 steps (0%)
00:10:09:Removing old file 'configs/config-20200501-231515.xml'
00:10:09:Saving configuration to config.xml
00:10:09:<config>
00:10:09:  <!-- Folding Core -->
00:10:09:  <checkpoint v='5'/>
00:10:09:  <core-priority v='low'/>
00:10:09:
00:10:09:  <!-- Network -->
00:10:09:  <proxy v=':8080'/>
00:10:09:
00:10:09:  <!-- Slot Control -->
00:10:09:  <power v='medium'/>
00:10:09:
00:10:09:  <!-- User Information -->
00:10:09:  <passkey v='*****'/>
00:10:09:  <team v='245954'/>
00:10:09:  <user v='Rich_Mintz'/>
00:10:09:
00:10:09:  <!-- Folding Slots -->
00:10:09:  <slot id='0' type='CPU'>
00:10:09:    <cpus v='4'/>
00:10:09:  </slot>
00:10:09:  <slot id='1' type='GPU'/>
00:10:09:</config>
00:51:25:WU01:FS01:0x22:Completed 620000 out of 2000000 steps (31%)
BTW, the V7.6.9 does work with a GPU, it needs a workaround which, as you have discovered, was fixed in the later Beta version.
For your desktop, this would be the ideal configuration:
CPU Slot using 4 CPUs
GPU Slot
The reason is that you have a Nvidia GPU which needs 1 CPU to feed the GPU. 5 CPUs is a prime and will automatically be reduced to 4 CPUs.
CPU Slot using 6 CPUs
GPU Slot
The reason is that you have a Nvidia GPU which needs 1 CPU to feed the GPU. 7 CPUs is a prime and will automatically be reduced to 6 CPUs.
Keep in mind that laptop cooling can have a significant impact as it would try to down-clock and limit itself. Ensure that the temperatures are within reason. Also, there are different CPU Projects and points and steps will vary between them. Comparing a laptop CPU to a desktop CPU may not be ideal due to different thermal limits and frequency speeds.
I like Panther_X's suggestions.
Here are step by step instructions for Windows 10.
If you have GPUs, F@H reserves one CPU per GPU to feed it data across the PCIE bus.
F@H has difficulty with large primes and their multiples number of CPUs.
7 is always large, 5 is sometimes large, and 3 is never large. Try to choose a number that is a multiple of 2 and/or 3.
2, 3, 4, 6 are good numbers of CPUs to choose. (_r2w_ben has advised me of more good numbers)
5 may work most of the time. Other numbers will bite you
Type the number you want, and click save.
A Work Unit will never use more CPUs than it started with, so you can lower the number on the fly, but increasing it only works on the next WU.
Now Why is the Desktop CPU faster than the Laptop?
The laptop is running an a very small power budget, The CPU only draws 15 watts TPD, and has tiny fans and bad airflow, so even at 15 Watts it may be throttled not to melt the case.
https://ark.intel.com/content/www/us/en ... 0-ghz.html
By comparison the Desktop has a 65 watt TPD power budget and a big open case with large fans to get the heat out. It will be throttled less often.
It is kludgy, but a laptop cooler may make it faster. https://www.amazon.com/dp/B01M715BCV
paulmd199
Hardware configuration: Machine 1: Gigabyte Z160MX-Gaming 5, Core i5-6500, eVGA 600 W PSU, thermaltake water 3.0120 cooling, 16GB DDR4, GPU 0: GT1030, GPU 1: GTX1050 Ti, GPU 2: GTX1660
Machine 2: Core i3 laptop (dell inspiron 1464)
Retired/spare: GT 750
Unusable: Intel HD 530
Post by paulmd199 »
To add to the subject of heat, one thing you may want to do is run a hardware monitoring program, such as Open Hardware Monitor to see what kind of temperatures you hit. Right at 90 centigrade is where CPU performance degrades.
Another way to check is by using the task manger, and seeing what speed windows is reporting. Downclocking is a telltale sign of overheating.
richmintz
Post by richmintz »
Okay, that all makes sense, thank you for your clear reply.
The issue here, as you implied, is apparently that Windows is parking/throttling CPUs on the laptop to reduce the temperature. When folding on full, this is what I get:
Core 1 - 100% - 80 deg C
Core 2 - 25% - 78 deg C
Cores 3-4 - 0 - 75 deg C
CPU Package - 80 deg C
[remember this is 4 physical cores, 8 logical processors]
When I pause folding and wait 10 minutes, temps drop, AND processors get added back, in pairs. Eventually they are all online again and the load is distributed among all 8.
Then when I turn folding back on full, core 1 and the package temp quickly get back up to 80 again AND Windows cuts back to 2 logical processors (each running, for now, at 100%). As the temp stays high, even those 2 processors start pulling back from 100%, and I assume it's because Windows is throttling them for temp reasons.
It looks like on this machine, I may get the most CPU dedicated to folding when I run at "medium" level, because the processors spend less of their time being throttled.
But more generally, this just isn't a very efficient machine for folding because its cooling is not very good. I'll do what I can -- make sure the vent area is open, keep it raised off the table for circulation, place it overnight near a window so it'll get some natural cooling.
Separately: checkpointed work apparently isn't being picked up when I return from pause or a crash. I'm checkpointing very often, but sometimes it seems that the WU is starting over not just from an earlier checkpoint save, but from zero. But that's a different topic, and I'm going to make absolutely sure it's happening before I bring it up again.
richmintz
Post by richmintz »
...and thanks to all of you, all good suggestions. Currently browsing laptop coolers.
Generally speaking, folding really likes physical cores so setting of 4 CPUs is viable. The hyper-threading does provide increased performance but nowhere near the same as an additional physical core. Thus, that can be a happy medium for you where you set it to Full and then "lock" your CPUs to 4.
richmintz
Post by richmintz »
I've done some more experimenting. (Among other things, I set the laptop on a windowsill on top of a bag of frozen peas.) When I am folding on Light, the temp stays low enough that all 8 processors are in action and I get overall 50%+ CPU utilization (and increasing). The additional CPU utilization is reflected almost immediately in a reduced ETA. (But: on Light, only the CPU is folding.)
I was folding on Medium for a while and eventually the frozen peas helped cool things down enough that processors 3 and 4 (of 8) came back online and CPU utilization doubled from 22 to 44%. But within a few minutes, that heated things up enough that they were throttled again and I was back where I started.
I think what I'm going to do with this particular machine is finish the CPU unit, turn off the CPU slot, finish the GPU unit, turn off the GPU slot, and then set it to fold only on the CPU (and leave it on Light). Maybe when my cooling mat arrives I'll reassess.
richmintz
Post by richmintz »
I did what PantherX said and capped it at 4 processors and utilization shot up from 50% to 58%+ and that seems to be holding - all temps are staying mostly below 80 deg C
Re: Improving performance on multi-core hardware (basic)
richmintz wrote:Separately: checkpointed work apparently isn't being picked up when I return from pause or a crash. I'm checkpointing very often, but sometimes it seems that the WU is starting over not just from an earlier checkpoint save, but from zero. But that's a different topic, and I'm going to make absolutely sure it's happening before I bring it up again.
One note on checkpoints, the setting in FAHControl only applies to processing of CPU WUs. The checkpoint frequency for GPU projects is set by the researcher when setting up the project to create WUs. Typically that is every 2-5% of progress on the WU.
Additionally, there is a cost to setting the CPU checkpoint frequency very frequent. One, it does reduce overall processing of the WU, and two it increases the chance that a checkpoint will be interrupted in progress .
richmintz
Post by richmintz »
On this laptop I’ve switched to Linux (elementary OS) which I forgot I had installed in parallel. Unlike windows, Linux seems perfectly happy to run a CPU WU at 100% CPU indefinitely on an idle machine without overheating. I’ll let it run overnight and see how it goes.
Thanks for the advice on checkpointing. The only reason I was checkpointing so frequently is to try to figure out whether I was really losing work, so I’ve set it back to the defaults.
richmintz
Post by richmintz »
Just confirming: in Linux, on the same hardware, it ran overnight at 100% CPU x 8 with no overheating problem. (Have since set it to 4, I forgot last night.) Windows runs hotter, apparently.
Now testing with the GPU running in parallel (if I can get an assignment).
HugoNotte
Post by HugoNotte »
TPF isn't a measure of how well your system is processing, since different WUs have different TPFs. Use PPD (points per day) as an indication of how well your computing goes and wait a little while, as PPD tends to fluctuate initially and then stabilizes as from around 5% work done.
