My donor name is SorenK17 and I have been folding since 18 April 2020 but I cannot find my stats on the page: stats foldingathome org donors
I have tried to search with:
1) Is Exactly: SorenK17
2) Starts with;: Soren. I get other donors
3) is like: nK17. I get two donos: LINK1733, kerplunk17
I can see me and my teams activity at both stats foldingathome org donor SorenK17 and stats foldingathome org team 263869
Canoot find my donor name on stats page
Re: Canoot find my donor name on stats page
Welcome to the F@H Forum SorenK17,
Please note that due to a large influx of donors, it is taking longer than normal for the Stats system to process the data. Having said that, I see this result so am not sure if that is you or not: https://stats.foldingathome.org/donor/SorenK17 Do note that the donor name isn't unique in F@H. If you want, please post your log file here so we can see how the client is configured. Guidance is provided here: viewtopic.php?f=24&t=26036
My log file:
*********************** Log Started 2020-05-01T16:20:06Z ***********************
16:20:06:****************************** FAHClient ******************************
16:20:06: Version: 7.6.9
16:20:06: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:20:06: Copyright: 2020 foldingathome.org
16:20:06: Homepage: https://foldingathome.org/
16:20:06: Date: Apr 17 2020
16:20:06: Time: 11:13:06
16:20:06: Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
16:20:06: Branch: master
16:20:06: Compiler: Visual C++ 2008
16:20:06: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
16:20:06: Platform: win32 10
16:20:06: Bits: 32
16:20:06: Mode: Release
16:20:06: Config: C:\Users\xxxx\AppData\Roaming\FAHClient\config.xml
16:20:06:******************************** CBang ********************************
16:20:06: Time: 11:10:09
16:20:06: Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
16:20:06: Bits: 32
16:20:06:******************************* System ********************************
16:20:06: CPU: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
16:20:06: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
16:20:06: CPUs: 8
16:20:06: Memory: 15.94GiB
16:20:06: Free Memory: 12.18GiB
16:20:06: Threads: WINDOWS_THREADS
16:20:06: OS Version: 6.2
16:20:06: Has Battery: false
16:20:06: On Battery: false
16:20:06: UTC Offset: 2
16:20:06: PID: 12860
16:20:06: CWD: C:\Users\xxxx\AppData\Roaming\FAHClient
16:20:06: OS: Windows 10 Enterprise
16:20:06: OS Arch: AMD64
16:20:06: GPUs: 1
16:20:06: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:3 GK104 [GeForce GTX 770] 3213
16:20:06: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:3.0 Driver:10.1
16:20:06:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:432.0
16:20:06: Win32 Service: false
16:20:06:******************************* libFAH ********************************
16:20:06: Date: Apr 15 2020
16:20:06: Time: 14:53:14
16:20:06: Revision: 216968bc7025029c841ed6e36e81a03a316890d3
16:20:06: Bits: 32
16:20:06:***********************************************************************
16:20:06:<config>
16:20:06: <!-- Network -->
16:20:06: <proxy v=':8080'/>
16:20:06:
16:20:06: <!-- User Information -->
16:20:06: <passkey v='*****'/>
16:20:06: <team v='263869'/>
16:20:06: <user v='SorenK17'/>
16:20:06:
16:20:06: <!-- Folding Slots -->
16:20:06: <slot id='0' type='CPU'/>
16:20:06:</config>
16:20:06:Trying to access database...
16:20:06:Successfully acquired database lock
16:20:06:Enabled folding slot 00: READY cpu:7
16:20:06:WU01:FS00:Starting
16:20:06:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\xxxx\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 12860 -checkpoint 15 -np 7
16:20:06:WU01:FS00:Started FahCore on PID 13220
16:20:06:WU01:FS00:Core PID:13296
16:20:06:WU01:FS00:FahCore 0xa7 started
16:20:07:WU01:FS00:0xa7:*********************** Log Started 2020-05-01T16:20:06Z ***********************
16:20:07:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
16:20:07:WU01:FS00:0xa7: Type: 0xa7
16:20:07:WU01:FS00:0xa7: Core: Gromacs
16:20:07:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 706 -lifeline 13220 -checkpoint 15 -np
16:20:07:WU01:FS00:0xa7: 7
16:20:07:WU01:FS00:0xa7:************************************ CBang *************************************
16:20:07:WU01:FS00:0xa7: Date: Oct 26 2019
16:20:07:WU01:FS00:0xa7: Time: 01:38:25
16:20:07:WU01:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
16:20:07:WU01:FS00:0xa7: Branch: master
16:20:07:WU01:FS00:0xa7: Compiler: Visual C++ 2008
16:20:07:WU01:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
16:20:07:WU01:FS00:0xa7: Platform: win32 10
16:20:07:WU01:FS00:0xa7: Bits: 64
16:20:07:WU01:FS00:0xa7: Mode: Release
16:20:07:WU01:FS00:0xa7:************************************ System ************************************
16:20:07:WU01:FS00:0xa7: CPU: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
16:20:07:WU01:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
16:20:07:WU01:FS00:0xa7: CPUs: 8
16:20:07:WU01:FS00:0xa7: Memory: 15.94GiB
16:20:07:WU01:FS00:0xa7:Free Memory: 12.09GiB
16:20:07:WU01:FS00:0xa7: Threads: WINDOWS_THREADS
16:20:07:WU01:FS00:0xa7: OS Version: 6.2
16:20:07:WU01:FS00:0xa7:Has Battery: false
16:20:07:WU01:FS00:0xa7: On Battery: false
16:20:07:WU01:FS00:0xa7: UTC Offset: 2
16:20:07:WU01:FS00:0xa7: PID: 13296
16:20:07:WU01:FS00:0xa7: CWD: C:\Users\xxxx\AppData\Roaming\FAHClient\work
16:20:07:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
16:20:07:WU01:FS00:0xa7: Version: 0.0.18
16:20:07:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:20:07:WU01:FS00:0xa7: Copyright: 2019 foldingathome.org
16:20:07:WU01:FS00:0xa7: Homepage: https://foldingathome.org/
16:20:07:WU01:FS00:0xa7: Time: 01:52:30
16:20:07:WU01:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
16:20:07:WU01:FS00:0xa7:************************************ Build *************************************
16:20:07:WU01:FS00:0xa7: SIMD: avx_256
16:20:07:WU01:FS00:0xa7:********************************************************************************
16:20:07:WU01:FS00:0xa7:Project: 16424 (Run 334, Clone 0, Gen 26)
16:20:07:WU01:FS00:0xa7:Unit: 0x0000001ea8f5c67d5e8f6b18bbc6abd2
16:20:07:WU01:FS00:0xa7:Digital signatures verified
16:20:07:WU01:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
16:20:07:WU01:FS00:0xa7:Calling: mdrun -s frame26.tpr -o frame26.trr -x frame26.xtc -cpi state.cpt -cpt 15 -nt 6
16:20:07:WU01:FS00:0xa7:Steps: first=6500000 total=250000
16:20:09:WU01:FS00:0xa7:Completed 78581 out of 250000 steps (31%)
16:23:16:WU01:FS00:0xa7:Completed 80000 out of 250000 steps (32%)
16:27:35:WU01:FS00:0xa7:Completed 82500 out of 250000 steps (33%)
16:31:52:WU01:FS00:0xa7:Completed 85000 out of 250000 steps (34%)
16:36:10:WU01:FS00:0xa7:Completed 87500 out of 250000 steps (35%)
16:40:26:WU01:FS00:0xa7:Completed 90000 out of 250000 steps (36%)
16:44:40:WU01:FS00:0xa7:Completed 92500 out of 250000 steps (37%)
16:48:56:WU01:FS00:0xa7:Completed 95000 out of 250000 steps (38%)
16:53:13:WU01:FS00:0xa7:Completed 97500 out of 250000 steps (39%)
16:57:26:WU01:FS00:0xa7:Completed 100000 out of 250000 steps (40%)
17:01:38:WU01:FS00:0xa7:Completed 102500 out of 250000 steps (41%)
17:05:54:WU01:FS00:0xa7:Completed 105000 out of 250000 steps (42%)
17:10:26:WU01:FS00:0xa7:Completed 107500 out of 250000 steps (43%)
17:14:42:WU01:FS00:0xa7:Completed 110000 out of 250000 steps (44%)
17:18:55:WU01:FS00:0xa7:Completed 112500 out of 250000 steps (45%)
17:23:10:WU01:FS00:0xa7:Completed 115000 out of 250000 steps (46%)
17:27:22:WU01:FS00:0xa7:Completed 117500 out of 250000 steps (47%)
17:31:33:WU01:FS00:0xa7:Completed 120000 out of 250000 steps (48%)
17:35:47:WU01:FS00:0xa7:Completed 122500 out of 250000 steps (49%)
17:39:58:WU01:FS00:0xa7:Completed 125000 out of 250000 steps (50%)
17:44:10:WU01:FS00:0xa7:Completed 127500 out of 250000 steps (51%)
17:48:21:WU01:FS00:0xa7:Completed 130000 out of 250000 steps (52%)
17:52:34:WU01:FS00:0xa7:Completed 132500 out of 250000 steps (53%)
17:56:45:WU01:FS00:0xa7:Completed 135000 out of 250000 steps (54%)
18:00:59:WU01:FS00:0xa7:Completed 137500 out of 250000 steps (55%)
18:05:10:WU01:FS00:0xa7:Completed 140000 out of 250000 steps (56%)
18:09:23:WU01:FS00:0xa7:Completed 142500 out of 250000 steps (57%)
18:13:35:WU01:FS00:0xa7:Completed 145000 out of 250000 steps (58%)
18:17:47:WU01:FS00:0xa7:Completed 147500 out of 250000 steps (59%)
18:22:00:WU01:FS00:0xa7:Completed 150000 out of 250000 steps (60%)
18:26:11:WU01:FS00:0xa7:Completed 152500 out of 250000 steps (61%)
18:30:23:WU01:FS00:0xa7:Completed 155000 out of 250000 steps (62%)
18:34:34:WU01:FS00:0xa7:Completed 157500 out of 250000 steps (63%)
18:38:48:WU01:FS00:0xa7:Completed 160000 out of 250000 steps (64%)
18:42:59:WU01:FS00:0xa7:Completed 162500 out of 250000 steps (65%)
18:47:11:WU01:FS00:0xa7:Completed 165000 out of 250000 steps (66%)
18:51:24:WU01:FS00:0xa7:Completed 167500 out of 250000 steps (67%)
18:55:35:WU01:FS00:0xa7:Completed 170000 out of 250000 steps (68%)
18:59:47:WU01:FS00:0xa7:Completed 172500 out of 250000 steps (69%)
19:03:58:WU01:FS00:0xa7:Completed 175000 out of 250000 steps (70%)
19:08:11:WU01:FS00:0xa7:Completed 177500 out of 250000 steps (71%)
19:12:23:WU01:FS00:0xa7:Completed 180000 out of 250000 steps (72%)
19:16:35:WU01:FS00:0xa7:Completed 182500 out of 250000 steps (73%)
19:20:49:WU01:FS00:0xa7:Completed 185000 out of 250000 steps (74%)
19:25:00:WU01:FS00:0xa7:Completed 187500 out of 250000 steps (75%)
19:29:12:WU01:FS00:0xa7:Completed 190000 out of 250000 steps (76%)
19:33:23:WU01:FS00:0xa7:Completed 192500 out of 250000 steps (77%)
19:37:36:WU01:FS00:0xa7:Completed 195000 out of 250000 steps (78%)
19:41:47:WU01:FS00:0xa7:Completed 197500 out of 250000 steps (79%)
19:45:59:WU01:FS00:0xa7:Completed 200000 out of 250000 steps (80%)
19:50:10:WU01:FS00:0xa7:Completed 202500 out of 250000 steps (81%)
19:54:23:WU01:FS00:0xa7:Completed 205000 out of 250000 steps (82%)
19:58:34:WU01:FS00:0xa7:Completed 207500 out of 250000 steps (83%)
20:02:46:WU01:FS00:0xa7:Completed 210000 out of 250000 steps (84%)
20:06:59:WU01:FS00:0xa7:Completed 212500 out of 250000 steps (85%)
20:11:10:WU01:FS00:0xa7:Completed 215000 out of 250000 steps (86%)
20:15:23:WU01:FS00:0xa7:Completed 217500 out of 250000 steps (87%)
20:19:34:WU01:FS00:0xa7:Completed 220000 out of 250000 steps (88%)
20:23:49:WU01:FS00:0xa7:Completed 222500 out of 250000 steps (89%)
20:28:00:WU01:FS00:0xa7:Completed 225000 out of 250000 steps (90%)
20:32:12:WU01:FS00:0xa7:Completed 227500 out of 250000 steps (91%)
20:35:53:FS00:Shutting core down
20:35:53:WU01:FS00:0xa7:WARNING:Console control signal 1 on PID 13296
20:35:53:WU01:FS00:0xa7:Exiting, please wait. . .
20:35:57:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
20:35:57:WU01:FS00:Starting
20:35:57:WARNING:WU01:FS00:Changed SMP threads from 7 to 3 this can cause some work units to fail
20:35:57:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\xxxx\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 12860 -checkpoint 15 -np 3
20:35:57:WU01:FS00:Started FahCore on PID 7780
20:35:57:WU01:FS00:Core PID:5016
20:35:57:WU01:FS00:FahCore 0xa7 started
20:35:57:WU01:FS00:0xa7:*********************** Log Started 2020-05-01T20:35:57Z ***********************
20:35:57:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
20:35:57:WU01:FS00:0xa7: Type: 0xa7
20:35:57:WU01:FS00:0xa7: Core: Gromacs
20:35:57:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 706 -lifeline 7780 -checkpoint 15 -np 3
20:35:57:WU01:FS00:0xa7:************************************ CBang *************************************
20:35:57:WU01:FS00:0xa7: Date: Oct 26 2019
20:35:57:WU01:FS00:0xa7: Time: 01:38:25
20:35:57:WU01:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
20:35:57:WU01:FS00:0xa7: Branch: master
20:35:57:WU01:FS00:0xa7: Compiler: Visual C++ 2008
20:35:57:WU01:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:35:57:WU01:FS00:0xa7: Platform: win32 10
20:35:57:WU01:FS00:0xa7: Bits: 64
20:35:57:WU01:FS00:0xa7: Mode: Release
20:35:57:WU01:FS00:0xa7:************************************ System ************************************
20:35:57:WU01:FS00:0xa7: CPU: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
20:35:57:WU01:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
20:35:57:WU01:FS00:0xa7: CPUs: 8
20:35:57:WU01:FS00:0xa7: Memory: 15.94GiB
20:35:57:WU01:FS00:0xa7:Free Memory: 10.07GiB
20:35:57:WU01:FS00:0xa7: Threads: WINDOWS_THREADS
20:35:57:WU01:FS00:0xa7: OS Version: 6.2
20:35:57:WU01:FS00:0xa7:Has Battery: false
20:35:57:WU01:FS00:0xa7: On Battery: false
20:35:57:WU01:FS00:0xa7: UTC Offset: 2
20:35:57:WU01:FS00:0xa7: PID: 5016
20:35:57:WU01:FS00:0xa7: CWD: C:\Users\xxxx\AppData\Roaming\FAHClient\work
20:35:57:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
20:35:57:WU01:FS00:0xa7: Version: 0.0.18
20:35:57:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:35:57:WU01:FS00:0xa7: Copyright: 2019 foldingathome.org
20:35:57:WU01:FS00:0xa7: Homepage: https://foldingathome.org/
20:35:57:WU01:FS00:0xa7: Time: 01:52:30
20:35:57:WU01:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
20:35:57:WU01:FS00:0xa7:************************************ Build *************************************
20:35:57:WU01:FS00:0xa7: SIMD: avx_256
20:35:57:WU01:FS00:0xa7:********************************************************************************
20:35:57:WU01:FS00:0xa7:Project: 16424 (Run 334, Clone 0, Gen 26)
20:35:57:WU01:FS00:0xa7:Unit: 0x0000001ea8f5c67d5e8f6b18bbc6abd2
20:35:57:WU01:FS00:0xa7:Digital signatures verified
20:35:57:WU01:FS00:0xa7:Calling: mdrun -s frame26.tpr -o frame26.trr -x frame26.xtc -cpi state.cpt -cpt 15 -nt 3
20:35:57:WU01:FS00:0xa7:Steps: first=6500000 total=250000
20:35:59:WU01:FS00:0xa7:Completed 229652 out of 250000 steps (91%)
20:36:18:Removing old file 'configs/config-20200426-110832.xml'
20:36:18:Saving configuration to config.xml
20:36:18:<config>
20:36:18: <!-- Network -->
20:36:18: <proxy v=':8080'/>
20:36:18:
20:36:18: <!-- Slot Control -->
20:36:18: <power v='light'/>
20:36:18:
20:36:18: <!-- User Information -->
20:36:18: <passkey v='*****'/>
20:36:18: <team v='263869'/>
20:36:18: <user v='SorenK17'/>
20:36:18:
20:36:18: <!-- Folding Slots -->
20:36:18: <slot id='0' type='CPU'/>
20:36:18:</config>
20:36:42:WU01:FS00:0xa7:Completed 230000 out of 250000 steps (92%)
20:41:55:WU01:FS00:0xa7:Completed 232500 out of 250000 steps (93%)
20:42:49:FS00:Shutting core down
20:42:50:WU01:FS00:0xa7:WARNING:Console control signal 1 on PID 5016
20:42:50:WU01:FS00:0xa7:Exiting, please wait. . .
20:42:51:FS00:Finishing
20:42:53:WU01:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
20:42:53:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
20:42:53:WU01:FS00:Starting
20:42:53:WARNING:WU01:FS00:Changed SMP threads from 3 to 8 this can cause some work units to fail
20:42:53:WARNING:WU01:FS00:AS lowered CPUs from 8 to 7
20:42:53:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\xxxx\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 12860 -checkpoint 15 -np 7
20:42:53:WU01:FS00:Started FahCore on PID 5664
20:42:53:WU01:FS00:Core PID:15924
20:42:53:WU01:FS00:FahCore 0xa7 started
20:42:54:WU01:FS00:0xa7:*********************** Log Started 2020-05-01T20:42:53Z ***********************
20:42:54:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
20:42:54:WU01:FS00:0xa7: Type: 0xa7
20:42:54:WU01:FS00:0xa7: Core: Gromacs
20:42:54:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 706 -lifeline 5664 -checkpoint 15 -np 7
20:42:54:WU01:FS00:0xa7:************************************ CBang *************************************
20:42:54:WU01:FS00:0xa7: Date: Oct 26 2019
20:42:54:WU01:FS00:0xa7: Time: 01:38:25
20:42:54:WU01:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
20:42:54:WU01:FS00:0xa7: Branch: master
20:42:54:WU01:FS00:0xa7: Compiler: Visual C++ 2008
20:42:54:WU01:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:42:54:WU01:FS00:0xa7: Platform: win32 10
20:42:54:WU01:FS00:0xa7: Bits: 64
20:42:54:WU01:FS00:0xa7: Mode: Release
20:42:54:WU01:FS00:0xa7:************************************ System ************************************
20:42:54:WU01:FS00:0xa7: CPU: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
20:42:54:WU01:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
20:42:54:WU01:FS00:0xa7: CPUs: 8
20:42:54:WU01:FS00:0xa7: Memory: 15.94GiB
20:42:54:WU01:FS00:0xa7:Free Memory: 10.06GiB
20:42:54:WU01:FS00:0xa7: Threads: WINDOWS_THREADS
20:42:54:WU01:FS00:0xa7: OS Version: 6.2
20:42:54:WU01:FS00:0xa7:Has Battery: false
20:42:54:WU01:FS00:0xa7: On Battery: false
20:42:54:WU01:FS00:0xa7: UTC Offset: 2
20:42:54:WU01:FS00:0xa7: PID: 15924
20:42:54:WU01:FS00:0xa7: CWD: C:\Users\xxxx\AppData\Roaming\FAHClient\work
20:42:54:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
20:42:54:WU01:FS00:0xa7: Version: 0.0.18
20:42:54:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:42:54:WU01:FS00:0xa7: Copyright: 2019 foldingathome.org
20:42:54:WU01:FS00:0xa7: Homepage: https://foldingathome.org/
20:42:54:WU01:FS00:0xa7: Time: 01:52:30
20:42:54:WU01:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
20:42:54:WU01:FS00:0xa7:************************************ Build *************************************
20:42:54:WU01:FS00:0xa7: SIMD: avx_256
20:42:54:WU01:FS00:0xa7:********************************************************************************
20:42:54:WU01:FS00:0xa7:Project: 16424 (Run 334, Clone 0, Gen 26)
20:42:54:WU01:FS00:0xa7:Unit: 0x0000001ea8f5c67d5e8f6b18bbc6abd2
20:42:54:WU01:FS00:0xa7:Digital signatures verified
20:42:54:WU01:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
20:42:54:WU01:FS00:0xa7:Calling: mdrun -s frame26.tpr -o frame26.trr -x frame26.xtc -cpi state.cpt -cpt 15 -nt 6
20:42:54:WU01:FS00:0xa7:Steps: first=6500000 total=250000
20:42:56:WU01:FS00:0xa7:Completed 232942 out of 250000 steps (93%)
20:43:04:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
20:43:25:Removing old file 'configs/config-20200426-124911.xml'
20:43:25:Saving configuration to config.xml
20:43:25:<config>
20:43:25: <!-- Network -->
20:43:25: <proxy v=':8080'/>
20:43:25:
20:43:25: <!-- Slot Control -->
20:43:25: <power v='full'/>
20:43:25:
20:43:25: <!-- User Information -->
20:43:25: <passkey v='*****'/>
20:43:25: <team v='263869'/>
20:43:25: <user v='SorenK17'/>
20:43:25:
20:43:25: <!-- Folding Slots -->
20:43:25: <slot id='0' type='CPU'/>
20:43:25:</config>
20:46:24:WU01:FS00:0xa7:Completed 235000 out of 250000 steps (94%)
20:50:42:WU01:FS00:0xa7:Completed 237500 out of 250000 steps (95%)
20:54:55:WU01:FS00:0xa7:Completed 240000 out of 250000 steps (96%)
20:59:10:WU01:FS00:0xa7:Completed 242500 out of 250000 steps (97%)
21:03:23:WU01:FS00:0xa7:Completed 245000 out of 250000 steps (98%)
21:07:36:WU01:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
21:11:48:WU01:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
21:11:53:WU01:FS00:0xa7:Saving result file ..\logfile_01.txt
21:11:53:WU01:FS00:0xa7:Saving result file frame26.trr
21:11:53:WU01:FS00:0xa7:Saving result file frame26.xtc
21:11:53:WU01:FS00:0xa7:Saving result file md.log
21:11:53:WU01:FS00:0xa7:Saving result file science.log
21:11:53:WU01:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
21:11:53:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
21:11:53:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:16424 run:334 clone:0 gen:26 core:0xa7 unit:0x0000001ea8f5c67d5e8f6b18bbc6abd2
21:11:53:WU01:FS00:Uploading 6.98MiB to 168.245.198.125
21:11:53:WU01:FS00:Connecting to 168.245.198.125:8080
21:11:59:WU01:FS00:Upload 22.39%
21:12:05:WU01:FS00:Upload 51.05%
21:12:11:WU01:FS00:Upload 79.70%
21:12:15:WU01:FS00:Upload complete
21:12:15:WU01:FS00:Server responded WORK_ACK (400)
21:12:15:WU01:FS00:Final credit estimate, 5520.00 points
21:12:15:WU01:FS00:Cleaning up
21:13:55:Removing old file 'configs/config-20200426-170331.xml'
21:13:55:Saving configuration to config.xml
21:13:55:<config>
21:13:55: <!-- Network -->
21:13:55: <proxy v=':8080'/>
21:13:55:
21:13:55: <!-- Slot Control -->
21:13:55: <power v='light'/>
21:13:55:
21:13:55: <!-- User Information -->
21:13:55: <passkey v='*****'/>
21:13:55: <team v='263869'/>
21:13:55: <user v='SorenK17'/>
21:13:55:
21:13:55: <!-- Folding Slots -->
21:13:55: <slot id='0' type='CPU'/>
21:13:55:</config>
21:13:55:WU00:FS00:Connecting to 65.254.110.245:80
21:13:55:WU00:FS00:Assigned to work server 143.89.243.111
21:13:55:WU00:FS00:Requesting new work unit for slot 00: READY cpu:3 from 143.89.243.111
21:13:55:WU00:FS00:Connecting to 143.89.243.111:8080
21:14:00:WU00:FS00:Downloading 10.27MiB
21:14:03:WU00:FS00:Download complete
21:14:04:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16500 run:0 clone:1593 gen:26 core:0xa7 unit:0x0000001e8f59f36f5e8aad325e1ec4b3
21:14:04:WU00:FS00:Starting
21:14:04:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\xxxx\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 12860 -checkpoint 15 -np 3
21:14:04:WU00:FS00:Started FahCore on PID 14412
21:14:04:WU00:FS00:Core PID:15504
21:14:04:WU00:FS00:FahCore 0xa7 started
21:14:04:WU00:FS00:0xa7:*********************** Log Started 2020-05-01T21:14:04Z ***********************
21:14:04:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
21:14:04:WU00:FS00:0xa7: Type: 0xa7
21:14:04:WU00:FS00:0xa7: Core: Gromacs
21:14:04:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 706 -lifeline 14412 -checkpoint 15 -np
21:14:04:WU00:FS00:0xa7: 3
21:14:04:WU00:FS00:0xa7:************************************ CBang *************************************
21:14:04:WU00:FS00:0xa7: Date: Oct 26 2019
21:14:04:WU00:FS00:0xa7: Time: 01:38:25
21:14:04:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
21:14:04:WU00:FS00:0xa7: Branch: master
21:14:04:WU00:FS00:0xa7: Compiler: Visual C++ 2008
21:14:04:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:14:04:WU00:FS00:0xa7: Platform: win32 10
21:14:04:WU00:FS00:0xa7: Bits: 64
21:14:04:WU00:FS00:0xa7: Mode: Release
21:14:04:WU00:FS00:0xa7:************************************ System ************************************
21:14:04:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
21:14:04:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
21:14:04:WU00:FS00:0xa7: CPUs: 8
21:14:04:WU00:FS00:0xa7: Memory: 15.94GiB
21:14:04:WU00:FS00:0xa7:Free Memory: 9.86GiB
21:14:04:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
21:14:04:WU00:FS00:0xa7: OS Version: 6.2
21:14:04:WU00:FS00:0xa7:Has Battery: false
21:14:04:WU00:FS00:0xa7: On Battery: false
21:14:04:WU00:FS00:0xa7: UTC Offset: 2
21:14:04:WU00:FS00:0xa7: PID: 15504
21:14:04:WU00:FS00:0xa7: CWD: C:\Users\xxxx\AppData\Roaming\FAHClient\work
21:14:04:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
21:14:04:WU00:FS00:0xa7: Version: 0.0.18
21:14:04:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:14:04:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
21:14:04:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
21:14:04:WU00:FS00:0xa7: Time: 01:52:30
21:14:04:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
21:14:04:WU00:FS00:0xa7:************************************ Build *************************************
21:14:04:WU00:FS00:0xa7: SIMD: avx_256
21:14:04:WU00:FS00:0xa7:********************************************************************************
21:14:04:WU00:FS00:0xa7:Project: 16500 (Run 0, Clone 1593, Gen 26)
21:14:04:WU00:FS00:0xa7:Unit: 0x0000001e8f59f36f5e8aad325e1ec4b3
21:14:04:WU00:FS00:0xa7:Reading tar file core.xml
21:14:04:WU00:FS00:0xa7:Reading tar file frame26.tpr
21:14:04:WU00:FS00:0xa7:Digital signatures verified
21:14:04:WU00:FS00:0xa7:Calling: mdrun -s frame26.tpr -o frame26.trr -x frame26.xtc -cpt 15 -nt 3
21:14:04:WU00:FS00:0xa7:Steps: first=6500000 total=250000
21:14:06:WU00:FS00:0xa7:Completed 1 out of 250000 steps (0%)
21:23:12:WU00:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
21:32:35:WU00:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
21:41:38:WU00:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
21:50:47:WU00:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
21:59:59:WU00:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
22:09:16:WU00:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
Everything seems fine and the WU has been successfully returned and credited:
https://apps.foldingathome.org/wu#proje ... e=0&gen=26
https://apps.foldingathome.org/cpu?q=SorenK17
I noticed that you were moving the sliders around a bit. What is your use case? Generally speaking, CPU folding is very low priority so you can leave it at Full without any significant impact on most applications. If temperatures/power usage are too high, I would suggest that you set the CPUs to 6 or 4 using FAHControl -> Configure -> Slots Tab -> CPU Slot -> Edit -> CPU Value is either 2, 3, 4, 6 or 8 -> OK -> Save and then you're done
Also, on the official stats, you rank will be 0 until you have reached at least 100,000 points.
I have moved the slider to find a decent level of power use and power dissipation. It gets quite warm in a small room. My use case is that I have a computer that probably have a surplus of CPU capacity when I use it normally and I therefore can share this excess with F@H. Can the CPU Value be set individually for the Folding Power Levels (Light, Medium and Full)? Currently the value is set to -1, which is the same for all three levels.
I'm on my way to 100.000 points so my stats will probably sometime here in May.
Set and linked to the slider position, no. The '-1' setting leaves the CPU usage to the software, the settings are fixed. So Full uses all CPU threads available minus any reserved for a GPU slot which is one CPU thread per GPU. Medium uses one less CPU thread, and Light uses half the available number.
What you can do is set a constant value for the CPU thread count, then the slider will not affect the usage. Change the '-1' to a value from 1 to the maximum number of CPU threads available. If you change the value the CPU folding will either restart using that value, or if the WU was downloaded at a lower value setting, continue at that number. The next WU will use the value set at the time it was downloaded.
