Is Nvidia GeForce GTX 1650 a bad graphics card?
HB9EVT
Post by HB9EVT »
Hi
A question to the GPU geeks:
In one of my notebooks is a Nvidia GeForce GTX 1650 installed. I see that the FaH Client does not use this GPU.
GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 TU117M [GeForce GTX 1650 Mobile /
I thought I have a pretty good graphics card in my notebook. But when FoH does not accept it, there will be a good reason. So my queston is (I'm just curious): What is the reason for not accepting that graphics card? Which parameters of this Graphic Card are insufficient for beeing used by FoH?
Thanks for answering my curious question.
Cheers, Pepe
Pepe
Swiss Radio Scout -- Be prepared and stay on air! -- HB9EVT
Re: Is Nvidia GeForce GTX 1650 a bad graphics card?
Welcome to Folding@Home!
I am not sure I understand your problem.
Indicates that F@H recognizes your card and wants to fold.
Sadly the current client software is not very automatic about that. If you do not mind the risk, I would try the beta software 7.6.10 https://foldingathome.org/beta/
Post by Neil-B »
If you post a more complete log including the 200 odd lines at the top which show the system configuration someone may be able to better help ... from the little you have posted the client seems to have identified your card ... from checking here https://www.techpowerup.com/gpu-specs/g ... bile.c3367 it looks as if it should fold ok.
The has been/is a shortage of WUs at the moment and it may be that your client has simply been unable to download one yet ... or there might be some configuration issue ... a more complete log will let someone check this out.
HB9EVT
Post by HB9EVT »
Hi
Thanks for your answers.
Neil-B wrote:The has been/is a shortage of WUs at the moment and it may be that your client has simply been unable to download one yet
That specific notebook is now folding for three days. In the Web Control Client is only the CPU shown but no GPU. And the CPU is folding.
(To compare: On my other notebook (with different graphics card) is CPU and GPU shown. And CPU and GPU are both folding the last days nearly non-stop.)
No difference with V7.6.10-beta.
Here is the log:
*********************** Log Started 2020-04-23T15:09:40Z ***********************
15:09:40:****************************** FAHClient ******************************
15:09:40:        Version: 7.6.10
15:09:40:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:09:40:      Copyright: 2020 foldingathome.org
15:09:40:       Homepage: https://foldingathome.org/
15:09:40:           Date: Apr 17 2020
15:09:40:           Time: 20:32:19
15:09:40:       Revision: 05835e6a32e37abf3c82dbb9d2050d906637a345
15:09:40:         Branch: master
15:09:40:       Compiler: Visual C++ 2008
15:09:40:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:09:40:       Platform: win32 10
15:09:40:           Bits: 32
15:09:40:           Mode: Release
15:09:40:           Args: --open-web-control
15:09:40:         Config: C:\Users\nb_kp\AppData\Roaming\FAHClient\config.xml
15:09:40:******************************** CBang ********************************
15:09:40:           Time: 11:10:09
15:09:40:       Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
15:09:40:           Bits: 32
15:09:40:******************************* System ********************************
15:09:40:            CPU: Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz
15:09:40:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
15:09:40:           CPUs: 12
15:09:40:         Memory: 15.84GiB
15:09:40:    Free Memory: 12.41GiB
15:09:40:        Threads: WINDOWS_THREADS
15:09:40:     OS Version: 6.2
15:09:40:    Has Battery: true
15:09:40:     On Battery: false
15:09:40:     UTC Offset: 2
15:09:40:            PID: 4996
15:09:40:            CWD: C:\Users\nb_kp\AppData\Roaming\FAHClient
15:09:40:             OS: Windows 10 Home
15:09:40:        OS Arch: AMD64
15:09:40:           GPUs: 1
15:09:40:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 TU117M [GeForce GTX 1650 Mobile /
15:09:40:                 Max-Q]
15:09:40:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:10.2
15:09:40:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:442.92
15:09:40:OpenCL Device 1: Platform:1 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:26.20
15:09:40:  Win32 Service: false
15:09:40:******************************* libFAH ********************************
15:09:40:           Date: Apr 15 2020
15:09:40:           Time: 14:53:14
15:09:40:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
15:09:40:           Bits: 32
15:09:40:***********************************************************************
15:09:40:<config>
15:09:40:  <!-- Folding Slot Configuration -->
15:09:40:  <cause v='COVID_19'/>
15:09:40:
15:09:40:  <!-- Slot Control -->
15:09:40:  <power v='FULL'/>
15:09:40:
15:09:40:  <!-- User Information -->
15:09:40:  <passkey v='*****'/>
15:09:40:  <team v='254089'/>
15:09:40:  <user v='HB9EVT'/>
15:09:40:
15:09:40:  <!-- Folding Slots -->
15:09:40:  <slot id='0' type='CPU'/>
15:09:40:</config>
15:09:40:Trying to access database...
15:09:40:Successfully acquired database lock
15:09:40:Enabled folding slot 00: READY cpu:12
15:09:40:WU00:FS00:Starting
15:09:40:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\nb_kp\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 4996 -checkpoint 15 -np 12
15:09:41:WU00:FS00:Started FahCore on PID 7340
15:09:41:WU00:FS00:Core PID:7512
15:09:41:WU00:FS00:FahCore 0xa7 started
15:09:41:WU00:FS00:0xa7:*********************** Log Started 2020-04-23T15:09:41Z ***********************
15:09:41:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
15:09:41:WU00:FS00:0xa7:       Type: 0xa7
15:09:41:WU00:FS00:0xa7:       Core: Gromacs
15:09:41:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 7340 -checkpoint 15 -np
15:09:41:WU00:FS00:0xa7:             12
15:09:41:WU00:FS00:0xa7:************************************ CBang *************************************
15:09:41:WU00:FS00:0xa7:       Date: Oct 26 2019
15:09:41:WU00:FS00:0xa7:       Time: 01:38:25
15:09:41:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
15:09:41:WU00:FS00:0xa7:     Branch: master
15:09:41:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
15:09:41:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:09:41:WU00:FS00:0xa7:   Platform: win32 10
15:09:41:WU00:FS00:0xa7:       Bits: 64
15:09:41:WU00:FS00:0xa7:       Mode: Release
15:09:41:WU00:FS00:0xa7:************************************ System ************************************
15:09:41:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz
15:09:41:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
15:09:41:WU00:FS00:0xa7:       CPUs: 12
15:09:41:WU00:FS00:0xa7:     Memory: 15.84GiB
15:09:41:WU00:FS00:0xa7:Free Memory: 12.25GiB
15:09:41:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
15:09:41:WU00:FS00:0xa7: OS Version: 6.2
15:09:41:WU00:FS00:0xa7:Has Battery: true
15:09:41:WU00:FS00:0xa7: On Battery: false
15:09:41:WU00:FS00:0xa7: UTC Offset: 2
15:09:41:WU00:FS00:0xa7:        PID: 7512
15:09:41:WU00:FS00:0xa7:        CWD: C:\Users\nb_kp\AppData\Roaming\FAHClient\work
15:09:41:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
15:09:41:WU00:FS00:0xa7:    Version: 0.0.18
15:09:41:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:09:41:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
15:09:41:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
15:09:41:WU00:FS00:0xa7:       Time: 01:52:30
15:09:41:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
15:09:41:WU00:FS00:0xa7:************************************ Build *************************************
15:09:41:WU00:FS00:0xa7:       SIMD: avx_256
15:09:41:WU00:FS00:0xa7:********************************************************************************
15:09:41:WU00:FS00:0xa7:Project: 13860 (Run 0, Clone 12459, Gen 69)
15:09:41:WU00:FS00:0xa7:Unit: 0x000000520d5a98395e731182803c02cd
15:09:41:WU00:FS00:0xa7:Digital signatures verified
15:09:41:WU00:FS00:0xa7:Calling: mdrun -s frame69.tpr -o frame69.trr -x frame69.xtc -e frame69.edr -cpi state.cpt -cpt 15 -nt 12
15:09:41:WU00:FS00:0xa7:Steps: first=8625000 total=125000
15:09:43:9:127.0.0.1:New Web session
15:09:43:WU00:FS00:0xa7:Completed 18772 out of 125000 steps (15%)
Pepe
Pepe
Post by Neil-B »
What happens when you try to add a GPU slot in advanced control? ... There have been a few issues recently with GPUs not being properly identified by the newer clients - but I'll let one of the more technical forum members walk you through checking that out - there are a good few threads that discuss "fixes" for this.
On this white field should be a cpu item, But you want to click Add.
Now click a radio button so it is for GPUs
And Click save.
HB9EVT
Post by HB9EVT »
JimboPalmer wrote:In the taskbar to the lower right of the screen, you should see a F@H molecule icon, click it (you may need to click an Up Arrow to see it ^)
Click "OK". And Click save.
(Text in red color added by Pepe)
Thank you for this excellent description. @JimboPalmer
Only one detail was different to your description. I added it in red color.
And the result:
1) My notebook changed (after a short break of 1 minute) from consuming 55W to 105W. The fan started humming. And the web control says that GPU is working on its first unit. 8-)
2) I'm calmed. My new notebook with the GeForce GTX 1650 is not bad. :D
Thanks to all who helped.
Pepe
Pepe
