FahCore_a7.exe not working
Antigotchie
Post by Antigotchie »
Greatings from Hamburg
FahCore crashes multiple time
F@H Version 7.6.9
21:02:03:WU01:FS00:0xa7:ERROR:Guru Meditation: not checked '01/01/state.cpt'
21:02:03:WU01:FS00:0xa7:WARNING:Unexpected exit() call
21:02:03:WU01:FS00:0xa7:WARNING:Unexpected exit from science code
21:02:03:WU01:FS00:0xa7:ERROR:Guru Meditation: not checked '01/01/frame13.xtc'
21:02:04:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
21:02:13:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
21:02:13:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
21:02:14:WU01:FS00:0xa7:ERROR:Guru Meditation: not checked '01/01/state.cpt'
21:02:14:WU01:FS00:0xa7:WARNING:Unexpected exit() call
21:02:14:WU01:FS00:0xa7:WARNING:Unexpected exit from science code
21:02:14:WU01:FS00:0xa7:ERROR:Guru Meditation: not checked '01/01/frame13.xtc'
21:02:19:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
21:02:19:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
21:02:26:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
21:03:14:WU01:FS00:0xa7:ERROR:Guru Meditation: not checked '01/01/state.cpt'
21:03:14:WU01:FS00:0xa7:WARNING:Unexpected exit() call
21:03:14:WU01:FS00:0xa7:WARNING:Unexpected exit from science code
21:03:14:WU01:FS00:0xa7:ERROR:Guru Meditation: not checked '01/01/frame13.xtc'
21:03:26:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
21:03:26:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
21:04:15:WU01:FS00:0xa7:ERROR:Guru Meditation: not checked '01/01/state.cpt'
21:04:15:WU01:FS00:0xa7:WARNING:Unexpected exit() call
21:04:15:WU01:FS00:0xa7:WARNING:Unexpected exit from science code
21:04:15:WU01:FS00:0xa7:ERROR:Guru Meditation: not checked '01/01/frame13.xtc'
21:05:54:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
21:05:54:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
21:05:54:WU01:FS00:0xa7:ERROR:Guru Meditation: not checked '01/01/state.cpt'
21:05:54:WU01:FS00:0xa7:WARNING:Unexpected exit() call
21:05:54:WU01:FS00:0xa7:WARNING:Unexpected exit from science code
21:05:54:WU01:FS00:0xa7:ERROR:Guru Meditation: not checked '01/01/frame13.xtc'
21:12:42:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
21:12:42:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
21:12:42:WARNING:WU01:FS00:Too many errors, failing
21:12:43:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
If you need more information let me know
For now it works, sometime i have a RAM error as well. If it happens again i will add what the message says.
Reason: change Quote tags to Code for log
Re: FahCore_a7.exe not working
Guru Meditation is another word for Corrupt image on disk. It might be caused by your RAM error or might not. I'd run extensive RAM tests or maybe just replace it. It's not a good thing to have happen. (If you're overclocking your RAM, move back withiin spec. first)
I have had Guru Meditation errors when Windows crashed for some other reason and (rarely) which I did an orderly shutdown or Reboot. I'm working on properly identifying that as a bug that can be fixed but I don't have enough information yet. Was yours a crash or a reboot or something else?
Antigotchie
No windows works fine, until 2 minutes ago.
There was a windows updatereboot.
Just try to reboote again and see what happend
Maybe this is Helping (bevore reboot)
*********************** Log Started 2020-04-21T21:56:10Z ***********************
21:56:10:****************************** FAHClient ******************************
21:56:10:        Version: 7.6.9
21:56:10:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:56:10:      Copyright: 2020 foldingathome.org
21:56:10:       Homepage: https://foldingathome.org/
21:56:10:           Date: Apr 17 2020
21:56:10:           Time: 11:13:06
21:56:10:       Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
21:56:10:         Branch: master
21:56:10:       Compiler: Visual C++ 2008
21:56:10:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:56:10:       Platform: win32 10
21:56:10:           Bits: 32
21:56:10:           Mode: Release
21:56:10:         Config: C:\Users\mathi\AppData\Roaming\FAHClient\config.xml
21:56:10:******************************** CBang ********************************
21:56:10:           Time: 11:10:09
21:56:10:       Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
21:56:10:           Bits: 32
21:56:10:******************************* System ********************************
21:56:10:            CPU: AMD Ryzen 5 2600X Six-Core Processor
21:56:10:         CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
21:56:10:           CPUs: 12
21:56:10:         Memory: 15.95GiB
21:56:10:    Free Memory: 12.37GiB
21:56:10:        Threads: WINDOWS_THREADS
21:56:10:     OS Version: 6.2
21:56:10:    Has Battery: false
21:56:10:     On Battery: false
21:56:10:     UTC Offset: 2
21:56:10:            PID: 13972
21:56:10:            CWD: C:\Users\mathi\AppData\Roaming\FAHClient
21:56:10:             OS: Windows 10 Enterprise
21:56:10:        OS Arch: AMD64
21:56:10:           GPUs: 1
21:56:10:          GPU 0: Bus:10 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
21:56:10:                 470/480/570/580/590]
21:56:10:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': Das
21:56:10:                 angegebene Modul wurde nicht gefunden.
21:56:10:
21:56:10:OpenCL Device 0: Platform:0 Device:0 Bus:10 Slot:0 Compute:1.2 Driver:3004.8
21:56:10:  Win32 Service: false
21:56:10:******************************* libFAH ********************************
21:56:10:           Date: Apr 15 2020
21:56:10:           Time: 14:53:14
21:56:10:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
21:56:10:           Bits: 32
21:56:10:***********************************************************************
21:56:10:<config>
21:56:10:  <!-- Network -->
21:56:10:  <proxy v=':8080'/>
21:56:10:
21:56:10:  <!-- Slot Control -->
21:56:10:  <power v='full'/>
21:56:10:
21:56:10:  <!-- User Information -->
21:56:10:  <team v='239199'/>
21:56:10:  <user v='Antigotchie'/>
21:56:10:
21:56:10:  <!-- Folding Slots -->
21:56:10:  <slot id='0' type='CPU'/>
21:56:10:  <slot id='1' type='GPU'/>
21:56:10:</config>
21:56:10:Trying to access database...
21:56:10:Successfully acquired database lock
21:56:10:Enabled folding slot 00: READY cpu:11
21:56:10:Enabled folding slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590]
21:56:10:WU02:FS00:Starting
21:56:10:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\mathi\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 13972 -checkpoint 15 -np 11
21:56:10:WU02:FS00:Started FahCore on PID 15052
21:56:10:WU02:FS00:Core PID:15124
21:56:10:WU02:FS00:FahCore 0xa7 started
21:56:10:WU00:FS01:Starting
21:56:10:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\mathi\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 13972 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
21:56:10:WU00:FS01:Started FahCore on PID 15148
21:56:11:WU00:FS01:Core PID:15176
21:56:11:WU00:FS01:FahCore 0x22 started
21:56:11:WU02:FS00:0xa7:*********************** Log Started 2020-04-21T21:56:10Z ***********************
21:56:11:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
21:56:11:WU02:FS00:0xa7:       Type: 0xa7
21:56:11:WU02:FS00:0xa7:       Core: Gromacs
21:56:11:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 706 -lifeline 15052 -checkpoint 15 -np
21:56:11:WU02:FS00:0xa7:             11
21:56:11:WU02:FS00:0xa7:************************************ CBang *************************************
21:56:11:WU02:FS00:0xa7:       Date: Oct 26 2019
21:56:11:WU02:FS00:0xa7:       Time: 01:38:25
21:56:11:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
21:56:11:WU02:FS00:0xa7:     Branch: master
21:56:11:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
21:56:11:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:56:11:WU02:FS00:0xa7:   Platform: win32 10
21:56:11:WU02:FS00:0xa7:       Bits: 64
21:56:11:WU02:FS00:0xa7:       Mode: Release
21:56:11:WU02:FS00:0xa7:************************************ System ************************************
21:56:11:WU02:FS00:0xa7:        CPU: AMD Ryzen 5 2600X Six-Core Processor
21:56:11:WU02:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
21:56:11:WU02:FS00:0xa7:       CPUs: 12
21:56:11:WU02:FS00:0xa7:     Memory: 15.95GiB
21:56:11:WU02:FS00:0xa7:Free Memory: 12.24GiB
21:56:11:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
21:56:11:WU02:FS00:0xa7: OS Version: 6.2
21:56:11:WU02:FS00:0xa7:Has Battery: false
21:56:11:WU02:FS00:0xa7: On Battery: false
21:56:11:WU02:FS00:0xa7: UTC Offset: 2
21:56:11:WU02:FS00:0xa7:        PID: 15124
21:56:11:WU02:FS00:0xa7:        CWD: C:\Users\mathi\AppData\Roaming\FAHClient\work
21:56:11:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
21:56:11:WU02:FS00:0xa7:    Version: 0.0.18
21:56:11:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:56:11:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
21:56:11:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
21:56:11:WU02:FS00:0xa7:       Time: 01:52:30
21:56:11:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
21:56:11:WU02:FS00:0xa7:************************************ Build *************************************
21:56:11:WU02:FS00:0xa7:       SIMD: avx_256
21:56:11:WU02:FS00:0xa7:********************************************************************************
21:56:11:WU02:FS00:0xa7:Project: 14366 (Run 943, Clone 3, Gen 38)
21:56:11:WU02:FS00:0xa7:Unit: 0x000000289bf7a4d65e84aed8a9b88463
21:56:11:WU02:FS00:0xa7:Digital signatures verified
21:56:11:WU02:FS00:0xa7:Reducing thread count from 11 to 10 to avoid domain decomposition by a prime number > 3
21:56:11:WU02:FS00:0xa7:Calling: mdrun -s frame38.tpr -o frame38.trr -cpi state.cpt -cpt 15 -nt 10
21:56:11:WU02:FS00:0xa7:ERROR:Guru Meditation #7620fa645f6a9752.1dfd9e0a2ffb3d3c (3404.3877) '02/01/pullx.xvg'
21:56:11:WU02:FS00:0xa7:WARNING:Unexpected exit() call
21:56:11:WU02:FS00:0xa7:WARNING:Unexpected exit from science code
21:56:11:WU02:FS00:0xa7:Saving result file ..\logfile_01.txt
21:56:11:WU02:FS00:0xa7:Saving result file dhdl.xvg
21:56:11:WU02:FS00:0xa7:Saving result file frame38.trr
21:56:11:WU02:FS00:0xa7:Saving result file md.log
21:56:11:WU02:FS00:0xa7:Saving result file pullf.xvg
21:56:11:WU02:FS00:0xa7:ERROR:Guru Meditation #ab95938752ec3561.2b0db8e31ef974d0 (1250.1404) '02/01/pullf.xvg'
21:56:11:WU00:FS01:0x22:*********************** Log Started 2020-04-21T21:56:11Z ***********************
21:56:11:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
21:56:11:WU00:FS01:0x22:       Type: 0x22
21:56:11:WU00:FS01:0x22:       Core: Core22
21:56:11:WU00:FS01:0x22:    Website: https://foldingathome.org/
21:56:11:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
21:56:11:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
21:56:11:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
21:56:11:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 15148 -checkpoint 15
21:56:11:WU00:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
21:56:11:WU00:FS01:0x22:     Config: <none>
21:56:11:WU00:FS01:0x22:************************************ Build *************************************
21:56:11:WU00:FS01:0x22:    Version: 0.0.2
21:56:11:WU00:FS01:0x22:       Date: Dec 6 2019
21:56:11:WU00:FS01:0x22:       Time: 21:30:31
21:56:11:WU00:FS01:0x22: Repository: Git
21:56:11:WU00:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
21:56:11:WU00:FS01:0x22:     Branch: HEAD
21:56:11:WU00:FS01:0x22:   Compiler: Visual C++ 2008
21:56:11:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:56:11:WU00:FS01:0x22:   Platform: win32 10
21:56:11:WU00:FS01:0x22:       Bits: 64
21:56:11:WU00:FS01:0x22:       Mode: Release
21:56:11:WU00:FS01:0x22:************************************ System ************************************
21:56:11:WU00:FS01:0x22:        CPU: AMD Ryzen 5 2600X Six-Core Processor
21:56:11:WU00:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
21:56:11:WU00:FS01:0x22:       CPUs: 12
21:56:11:WU00:FS01:0x22:     Memory: 15.95GiB
21:56:11:WU00:FS01:0x22:Free Memory: 12.21GiB
21:56:11:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
21:56:11:WU00:FS01:0x22: OS Version: 6.2
21:56:11:WU00:FS01:0x22:Has Battery: false
21:56:11:WU00:FS01:0x22: On Battery: false
21:56:11:WU00:FS01:0x22: UTC Offset: 2
21:56:11:WU00:FS01:0x22:        PID: 15176
21:56:11:WU00:FS01:0x22:        CWD: C:\Users\mathi\AppData\Roaming\FAHClient\work
21:56:11:WU00:FS01:0x22:         OS: Windows 10 Pro
21:56:11:WU00:FS01:0x22:    OS Arch: AMD64
21:56:11:WU00:FS01:0x22:********************************************************************************
21:56:11:WU00:FS01:0x22:Project: 11762 (Run 0, Clone 5430, Gen 22)
21:56:11:WU00:FS01:0x22:Unit: 0x0000003080fccb0a5e7113ec5673ef09
21:56:11:WU00:FS01:0x22:Digital signatures verified
21:56:11:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
21:56:11:WU00:FS01:0x22:Version 0.0.2
21:56:11:WU00:FS01:0x22:  Found a checkpoint file
21:56:17:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
21:56:17:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
21:56:17:WU02:FS00:Starting
21:56:17:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\mathi\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 13972 -checkpoint 15 -np 11
21:56:17:WU02:FS00:Started FahCore on PID 2904
21:56:17:WU02:FS00:Core PID:14292
21:56:17:WU02:FS00:FahCore 0xa7 started
21:56:18:WU02:FS00:0xa7:*********************** Log Started 2020-04-21T21:56:18Z ***********************
21:56:18:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
21:56:18:WU02:FS00:0xa7:       Type: 0xa7
21:56:18:WU02:FS00:0xa7:       Core: Gromacs
21:56:18:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 706 -lifeline 2904 -checkpoint 15 -np
21:56:18:WU02:FS00:0xa7:             11
21:56:18:WU02:FS00:0xa7:************************************ CBang *************************************
21:56:18:WU02:FS00:0xa7:       Date: Oct 26 2019
21:56:18:WU02:FS00:0xa7:       Time: 01:38:25
21:56:18:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
21:56:18:WU02:FS00:0xa7:     Branch: master
21:56:18:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
21:56:18:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:56:18:WU02:FS00:0xa7:   Platform: win32 10
21:56:18:WU02:FS00:0xa7:       Bits: 64
21:56:18:WU02:FS00:0xa7:       Mode: Release
21:56:18:WU02:FS00:0xa7:************************************ System ************************************
21:56:18:WU02:FS00:0xa7:        CPU: AMD Ryzen 5 2600X Six-Core Processor
21:56:18:WU02:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
21:56:18:WU02:FS00:0xa7:       CPUs: 12
21:56:18:WU02:FS00:0xa7:     Memory: 15.95GiB
21:56:18:WU02:FS00:0xa7:Free Memory: 11.60GiB
21:56:18:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
21:56:18:WU02:FS00:0xa7: OS Version: 6.2
21:56:18:WU02:FS00:0xa7:Has Battery: false
21:56:18:WU02:FS00:0xa7: On Battery: false
21:56:18:WU02:FS00:0xa7: UTC Offset: 2
21:56:18:WU02:FS00:0xa7:        PID: 14292
21:56:18:WU02:FS00:0xa7:        CWD: C:\Users\mathi\AppData\Roaming\FAHClient\work
21:56:18:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
21:56:18:WU02:FS00:0xa7:    Version: 0.0.18
21:56:18:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:56:18:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
21:56:18:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
21:56:18:WU02:FS00:0xa7:       Time: 01:52:30
21:56:18:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
21:56:18:WU02:FS00:0xa7:************************************ Build *************************************
21:56:18:WU02:FS00:0xa7:       SIMD: avx_256
21:56:18:WU02:FS00:0xa7:********************************************************************************
21:56:18:WU02:FS00:0xa7:Project: 14366 (Run 943, Clone 3, Gen 38)
21:56:18:WU02:FS00:0xa7:Unit: 0x000000289bf7a4d65e84aed8a9b88463
21:56:18:WU02:FS00:0xa7:Digital signatures verified
21:56:18:WU02:FS00:0xa7:Reducing thread count from 11 to 10 to avoid domain decomposition by a prime number > 3
21:56:18:WU02:FS00:0xa7:Calling: mdrun -s frame38.tpr -o frame38.trr -cpi state.cpt -cpt 15 -nt 10
21:56:18:WU02:FS00:0xa7:ERROR:Guru Meditation #7620fa645f6a9752.1dfd9e0a2ffb3d3c (3404.3877) '02/01/pullx.xvg'
21:56:18:WU02:FS00:0xa7:WARNING:Unexpected exit() call
21:56:18:WU02:FS00:0xa7:WARNING:Unexpected exit from science code
21:56:18:WU02:FS00:0xa7:Saving result file ..\logfile_01.txt
21:56:18:WU02:FS00:0xa7:Saving result file dhdl.xvg
21:56:18:WU02:FS00:0xa7:Saving result file frame38.trr
21:56:18:WU02:FS00:0xa7:Saving result file md.log
21:56:18:WU02:FS00:0xa7:Saving result file pullf.xvg
21:56:18:WU02:FS00:0xa7:ERROR:Guru Meditation #ab95938752ec3561.2b0db8e31ef974d0 (1250.1404) '02/01/pullf.xvg'
21:56:23:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
21:56:23:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
21:56:30:WU00:FS01:0x22:Completed 100000 out of 1000000 steps (10%)
21:56:30:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
21:57:17:WU02:FS00:Starting
21:57:17:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\mathi\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 13972 -checkpoint 15 -np 11
21:57:18:WU02:FS00:Started FahCore on PID 16964
21:57:18:WU02:FS00:Core PID:16988
21:57:18:WU02:FS00:FahCore 0xa7 started
21:57:18:WU02:FS00:0xa7:*********************** Log Started 2020-04-21T21:57:18Z ***********************
21:57:18:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
21:57:18:WU02:FS00:0xa7:       Type: 0xa7
21:57:18:WU02:FS00:0xa7:       Core: Gromacs
21:57:18:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 706 -lifeline 16964 -checkpoint 15 -np
21:57:18:WU02:FS00:0xa7:             11
21:57:18:WU02:FS00:0xa7:************************************ CBang *************************************
21:57:18:WU02:FS00:0xa7:       Date: Oct 26 2019
21:57:18:WU02:FS00:0xa7:       Time: 01:38:25
21:57:18:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
21:57:18:WU02:FS00:0xa7:     Branch: master
21:57:18:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
21:57:18:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:57:18:WU02:FS00:0xa7:   Platform: win32 10
21:57:18:WU02:FS00:0xa7:       Bits: 64
21:57:18:WU02:FS00:0xa7:       Mode: Release
21:57:18:WU02:FS00:0xa7:************************************ System ************************************
21:57:18:WU02:FS00:0xa7:        CPU: AMD Ryzen 5 2600X Six-Core Processor
21:57:18:WU02:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
21:57:18:WU02:FS00:0xa7:       CPUs: 12
21:57:18:WU02:FS00:0xa7:     Memory: 15.95GiB
21:57:18:WU02:FS00:0xa7:Free Memory: 11.26GiB
21:57:18:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
21:57:18:WU02:FS00:0xa7: OS Version: 6.2
21:57:18:WU02:FS00:0xa7:Has Battery: false
21:57:18:WU02:FS00:0xa7: On Battery: false
21:57:18:WU02:FS00:0xa7: UTC Offset: 2
21:57:18:WU02:FS00:0xa7:        PID: 16988
21:57:18:WU02:FS00:0xa7:        CWD: C:\Users\mathi\AppData\Roaming\FAHClient\work
21:57:18:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
21:57:18:WU02:FS00:0xa7:    Version: 0.0.18
21:57:18:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:57:18:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
21:57:18:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
21:57:18:WU02:FS00:0xa7:       Time: 01:52:30
21:57:18:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
21:57:18:WU02:FS00:0xa7:************************************ Build *************************************
21:57:18:WU02:FS00:0xa7:       SIMD: avx_256
21:57:18:WU02:FS00:0xa7:********************************************************************************
21:57:18:WU02:FS00:0xa7:Project: 14366 (Run 943, Clone 3, Gen 38)
21:57:18:WU02:FS00:0xa7:Unit: 0x000000289bf7a4d65e84aed8a9b88463
21:57:18:WU02:FS00:0xa7:Digital signatures verified
21:57:18:WU02:FS00:0xa7:Reducing thread count from 11 to 10 to avoid domain decomposition by a prime number > 3
21:57:18:WU02:FS00:0xa7:Calling: mdrun -s frame38.tpr -o frame38.trr -cpi state.cpt -cpt 15 -nt 10
21:57:18:WU02:FS00:0xa7:ERROR:Guru Meditation #7620fa645f6a9752.1dfd9e0a2ffb3d3c (3404.3877) '02/01/pullx.xvg'
21:57:18:WU02:FS00:0xa7:WARNING:Unexpected exit() call
21:57:18:WU02:FS00:0xa7:WARNING:Unexpected exit from science code
21:57:18:WU02:FS00:0xa7:Saving result file ..\logfile_01.txt
21:57:18:WU02:FS00:0xa7:Saving result file dhdl.xvg
21:57:18:WU02:FS00:0xa7:Saving result file frame38.trr
21:57:18:WU02:FS00:0xa7:Saving result file md.log
21:57:18:WU02:FS00:0xa7:Saving result file pullf.xvg
21:57:18:WU02:FS00:0xa7:ERROR:Guru Meditation #ab95938752ec3561.2b0db8e31ef974d0 (1250.1404) '02/01/pullf.xvg'
21:57:25:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
21:57:25:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
21:58:09:WU00:FS01:0x22:Completed 110000 out of 1000000 steps (11%)
21:58:18:WU02:FS00:Starting
21:58:18:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\mathi\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 13972 -checkpoint 15 -np 11
21:58:18:WU02:FS00:Started FahCore on PID 1752
21:58:18:WU02:FS00:Core PID:8788
21:58:18:WU02:FS00:FahCore 0xa7 started
21:58:18:WU02:FS00:0xa7:*********************** Log Started 2020-04-21T21:58:18Z ***********************
21:58:18:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
21:58:18:WU02:FS00:0xa7:       Type: 0xa7
21:58:18:WU02:FS00:0xa7:       Core: Gromacs
21:58:18:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 706 -lifeline 1752 -checkpoint 15 -np
21:58:18:WU02:FS00:0xa7:             11
21:58:18:WU02:FS00:0xa7:************************************ CBang *************************************
21:58:18:WU02:FS00:0xa7:       Date: Oct 26 2019
21:58:18:WU02:FS00:0xa7:       Time: 01:38:25
21:58:18:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
21:58:18:WU02:FS00:0xa7:     Branch: master
21:58:18:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
21:58:18:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:58:18:WU02:FS00:0xa7:   Platform: win32 10
21:58:18:WU02:FS00:0xa7:       Bits: 64
21:58:18:WU02:FS00:0xa7:       Mode: Release
21:58:18:WU02:FS00:0xa7:************************************ System ************************************
21:58:18:WU02:FS00:0xa7:        CPU: AMD Ryzen 5 2600X Six-Core Processor
21:58:18:WU02:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
21:58:18:WU02:FS00:0xa7:       CPUs: 12
21:58:18:WU02:FS00:0xa7:     Memory: 15.95GiB
21:58:18:WU02:FS00:0xa7:Free Memory: 11.23GiB
21:58:18:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
21:58:18:WU02:FS00:0xa7: OS Version: 6.2
21:58:18:WU02:FS00:0xa7:Has Battery: false
21:58:18:WU02:FS00:0xa7: On Battery: false
21:58:18:WU02:FS00:0xa7: UTC Offset: 2
21:58:18:WU02:FS00:0xa7:        PID: 8788
21:58:18:WU02:FS00:0xa7:        CWD: C:\Users\mathi\AppData\Roaming\FAHClient\work
21:58:18:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
21:58:18:WU02:FS00:0xa7:    Version: 0.0.18
21:58:18:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:58:18:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
21:58:18:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
21:58:18:WU02:FS00:0xa7:       Time: 01:52:30
21:58:18:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
21:58:18:WU02:FS00:0xa7:************************************ Build *************************************
21:58:18:WU02:FS00:0xa7:       SIMD: avx_256
21:58:18:WU02:FS00:0xa7:********************************************************************************
21:58:18:WU02:FS00:0xa7:Project: 14366 (Run 943, Clone 3, Gen 38)
21:58:18:WU02:FS00:0xa7:Unit: 0x000000289bf7a4d65e84aed8a9b88463
21:58:18:WU02:FS00:0xa7:Digital signatures verified
21:58:18:WU02:FS00:0xa7:Reducing thread count from 11 to 10 to avoid domain decomposition by a prime number > 3
21:58:18:WU02:FS00:0xa7:Calling: mdrun -s frame38.tpr -o frame38.trr -cpi state.cpt -cpt 15 -nt 10
21:58:18:WU02:FS00:0xa7:ERROR:Guru Meditation #7620fa645f6a9752.1dfd9e0a2ffb3d3c (3404.3877) '02/01/pullx.xvg'
21:58:18:WU02:FS00:0xa7:WARNING:Unexpected exit() call
21:58:18:WU02:FS00:0xa7:WARNING:Unexpected exit from science code
21:58:18:WU02:FS00:0xa7:Saving result file ..\logfile_01.txt
21:58:18:WU02:FS00:0xa7:Saving result file dhdl.xvg
21:58:18:WU02:FS00:0xa7:Saving result file frame38.trr
21:58:18:WU02:FS00:0xa7:Saving result file md.log
21:58:18:WU02:FS00:0xa7:Saving result file pullf.xvg
21:58:18:WU02:FS00:0xa7:ERROR:Guru Meditation #ab95938752ec3561.2b0db8e31ef974d0 (1250.1404) '02/01/pullf.xvg'
21:58:45:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
21:58:45:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
21:59:18:WU02:FS00:Starting
21:59:18:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\mathi\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 13972 -checkpoint 15 -np 11
21:59:18:WU02:FS00:Started FahCore on PID 9944
21:59:18:WU02:FS00:Core PID:9888
21:59:18:WU02:FS00:FahCore 0xa7 started
21:59:18:WU02:FS00:0xa7:*********************** Log Started 2020-04-21T21:59:18Z ***********************
21:59:18:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
21:59:18:WU02:FS00:0xa7:       Type: 0xa7
21:59:18:WU02:FS00:0xa7:       Core: Gromacs
21:59:18:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 706 -lifeline 9944 -checkpoint 15 -np
21:59:18:WU02:FS00:0xa7:             11
21:59:18:WU02:FS00:0xa7:************************************ CBang *************************************
21:59:18:WU02:FS00:0xa7:       Date: Oct 26 2019
21:59:18:WU02:FS00:0xa7:       Time: 01:38:25
21:59:18:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
21:59:18:WU02:FS00:0xa7:     Branch: master
21:59:18:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
21:59:18:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:59:18:WU02:FS00:0xa7:   Platform: win32 10
21:59:18:WU02:FS00:0xa7:       Bits: 64
21:59:18:WU02:FS00:0xa7:       Mode: Release
21:59:18:WU02:FS00:0xa7:************************************ System ************************************
21:59:18:WU02:FS00:0xa7:        CPU: AMD Ryzen 5 2600X Six-Core Processor
21:59:18:WU02:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
21:59:18:WU02:FS00:0xa7:       CPUs: 12
21:59:18:WU02:FS00:0xa7:     Memory: 15.95GiB
21:59:18:WU02:FS00:0xa7:Free Memory: 11.21GiB
21:59:18:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
21:59:18:WU02:FS00:0xa7: OS Version: 6.2
21:59:18:WU02:FS00:0xa7:Has Battery: false
21:59:18:WU02:FS00:0xa7: On Battery: false
21:59:18:WU02:FS00:0xa7: UTC Offset: 2
21:59:18:WU02:FS00:0xa7:        PID: 9888
21:59:18:WU02:FS00:0xa7:        CWD: C:\Users\mathi\AppData\Roaming\FAHClient\work
21:59:18:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
21:59:18:WU02:FS00:0xa7:    Version: 0.0.18
21:59:18:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:59:18:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
21:59:18:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
21:59:18:WU02:FS00:0xa7:       Time: 01:52:30
21:59:18:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
21:59:18:WU02:FS00:0xa7:************************************ Build *************************************
21:59:18:WU02:FS00:0xa7:       SIMD: avx_256
21:59:18:WU02:FS00:0xa7:********************************************************************************
21:59:18:WU02:FS00:0xa7:Project: 14366 (Run 943, Clone 3, Gen 38)
21:59:18:WU02:FS00:0xa7:Unit: 0x000000289bf7a4d65e84aed8a9b88463
21:59:18:WU02:FS00:0xa7:Digital signatures verified
21:59:18:WU02:FS00:0xa7:Reducing thread count from 11 to 10 to avoid domain decomposition by a prime number > 3
21:59:18:WU02:FS00:0xa7:Calling: mdrun -s frame38.tpr -o frame38.trr -cpi state.cpt -cpt 15 -nt 10
21:59:18:WU02:FS00:0xa7:ERROR:Guru Meditation #7620fa645f6a9752.1dfd9e0a2ffb3d3c (3404.3877) '02/01/pullx.xvg'
21:59:18:WU02:FS00:0xa7:WARNING:Unexpected exit() call
21:59:18:WU02:FS00:0xa7:WARNING:Unexpected exit from science code
21:59:18:WU02:FS00:0xa7:Saving result file ..\logfile_01.txt
21:59:18:WU02:FS00:0xa7:Saving result file dhdl.xvg
21:59:18:WU02:FS00:0xa7:Saving result file frame38.trr
21:59:18:WU02:FS00:0xa7:Saving result file md.log
21:59:18:WU02:FS00:0xa7:Saving result file pullf.xvg
21:59:18:WU02:FS00:0xa7:ERROR:Guru Meditation #ab95938752ec3561.2b0db8e31ef974d0 (1250.1404) '02/01/pullf.xvg'
Where is logfile_01.txt located?
One thing I noticed is that you are trying to use 11 threads, F@H calls them CPUs.
F@H hates large prime numbers, I would consider choosing 9 cpus. Here are generic directions:
If you have GPUs, F@H reserves one CPU per GPU to feed it data across the PCIE bus.
F@H has difficulty with large primes and their multiples number of CPUs.
7 is always large, 5 is sometimes large, and 3 is never large. Try to choose a number that is a multiple of 2 and/or 3.
2, 3, 4, 6, 8, 9, 12, 16, 18, 21, 24, 27, 30, 32 are good numbers of CPUs to choose. (_r2w_ben has advised me of more good numbers)
5. 10. 15, 20, 25, 28 may work most of the time. Other numbers will bite you
Type the number you want, and click save.
Windows shutdown, especially as part of an update reboot often does not leave enough time for some programs to properly exit. You have been bitten by that behavior. Shutdown sent a signal to the folding client to exit, as part of the exit the CPU folding core started to write out a checkpoint file.
The error messages on startup are the folding core process attempting to open the files associated with the checkpoint and the WU and failing. The files are either incomplete or missing.
Welcome to the F@H Forum Antigotchie,
I have noticed that you're not using a passkey. Please note that it is recommended for security reasons and bonus points to use one. Here's an article for you to review: https://foldingathome.org/support/faq/points/passkey/
