So I thought I would add it manually so I go to Configure/Slots and the CPU is there at slot 0. I click Add, check GPU, then leave the rest as is (-1 gpu-index, -1 cuda-index, -1 open-cl index) then click OK, then Save. It doesn't get added. I go back there and there is only CPU at slot 0.
So I've tried playing with the index numbers (-1,-1,0; 0,-1,-1; 1,-1,0; 0,0,0 I think) but the result is always the same i.e. it doesn't get added. Don't mind OpenCL saying Driver:2236.9. It was higher with another driver. The thing is I was using the generic latest AMD Radeon driver and since I wasn't able to add the GPU slot I thought I'd try the one directly from the Asus website (which happens to be simply an older driver with some branding whatever; I reinstalled FaH after adding this older driver i.e. I had removed the newer AMD driver, uninstalled FaH, flushing all data, then I installed this older driver, then reinstalled FaH, by default still no GPU slot), and from what I can remember the only difference in the OpenCL line is the driver version but the behavior is exactly the same i.e. the folding slot doesn't get added (it feels like it's added for a second then immediately removed...).
What remains is only the CPU slot. I don't mind just using the CPU and my contribution is quite small but I thought I'd try to put to some use the GPU too to help as much as I can with the COVID-19 research but adding the GPU slot doesn't work. Here's the relevant part of the log. Also the <!-- Folding Slot Configuration --> sections not shown here don't change or indicate nothing new (no saving) when I try to add the GPU slot.
Any idea?
Thanks for your help!
*********************** Log Started 2020-04-20T04:58:04Z ***********************
04:58:04:****************************** FAHClient ******************************
04:58:04: Version: 7.6.9
04:58:04: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:58:04: Copyright: 2020 foldingathome.org
04:58:04: Homepage: https://foldingathome.org/
04:58:04: Date: Apr 17 2020
04:58:04: Time: 11:13:06
04:58:04: Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
04:58:04: Branch: master
04:58:04: Compiler: Visual C++ 2008
04:58:04: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
04:58:04: Platform: win32 10
04:58:04: Bits: 32
04:58:04: Mode: Release
04:58:04: Args: --open-web-control
04:58:04:******************************** CBang ********************************
04:58:04: Time: 11:10:09
04:58:04: Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
04:58:04: Bits: 32
04:58:04:******************************* System ********************************
04:58:04: CPU: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
04:58:04: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
04:58:04: CPUs: 4
04:58:04: Memory: 15.97GiB
04:58:04: Free Memory: 11.83GiB
04:58:04: Threads: WINDOWS_THREADS
04:58:04: OS Version: 6.2
04:58:04: Has Battery: false
04:58:04: On Battery: false
04:58:04: UTC Offset: -4
04:58:04: PID: 6628
04:58:04: CWD: C:\Users\whatever\AppData\Roaming\FAHClient
04:58:04: OS: Windows 10 Enterprise
04:58:04: OS Arch: AMD64
04:58:04: GPUs: 0
04:58:04: CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
04:58:04: specified module could not be found.
04:58:04:
04:58:04:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:2236.9
04:58:04: Win32 Service: false
04:58:04:******************************* libFAH ********************************
04:58:04: Date: Apr 15 2020
04:58:04: Time: 14:53:14
04:58:04: Revision: 216968bc7025029c841ed6e36e81a03a316890d3
04:58:04: Bits: 32
04:58:04:***********************************************************************
