Hi,
Completely new here (on linux), but got one WU done on CPU and another started on GPU (GeForce GTX 1050). Several questions:
* Throttling. I was all excited about GPU versus CPU until I started one (GPU) and saw the temps shoot way up with 100% utilization. Is there a way to throttle the GPU workload to 25 or 50%? The FOLDING POWER slider does not seem to have that function.
* If GPU throttling is not possible, is donating time for CPU work still useful? Are there work units that really can ONLY be done one CPU? If yes, going that much slower route (for heat reasons) might still be appetizing.
GPU Throttling, CPU vs GPU donation
Re: GPU Throttling, CPU vs GPU donation
By design of how GPUs work, it's not really possible to throttle them in the same way as CPUs.
For the other questions:
- There are tools available where you can limit the clock speed of the GPU, this might be an option.
- CPU folding is definitely still useful, because CPU projects don't work on the GPU and vice versa. And as you can see on https://apps.foldingathome.org/psummary, there's plenty of work for both types
Welcome to the F@H Forum LinuxNorth,
Please note that GPU throttling isn't supported since that is a feature not implemented by the vendors yet. Thus, there's nothing that the client can do about it.
You can set the GPU slot to Finish and once the WU has folded, you can remove the GPU slot. The CPU slot can continue to fold as it also does valuable science.
If you would like, you can post your log file here so we can see if there's anything else in the configuration that you may tweak: viewtopic.php?f=61&t=26036
Thank you for those useful answers!
I use my laptop constantly for work, so I'll continue with the cooler CPU donation. It seems to be using 4 of 12 threads, which is rather convenient.
2 suggestions for the project (if anyone is reading this):
- It look me quite a while in linux to figure out that I needed to start FAHCore at the command line and how to do it. A more clear linux FAQ might help.
- The deb installations spill FAH folders all over the user's Home Folder. Maybe I did something wrong, but having everything in one FAH folder would be much better. I'll try to reinstall in a new folder or maybe make another user just for FAH.
Thank you for your efforts and answers!
You can 'throtte' your GPU by lowering the power limit or clocks.
Sorry, another silly question
-Does the viewer show real data when connected to a WU? Are they real molecules from the work unit? Real gyrations? Or is it like the SETI days (probably meaningless eye candy)?
Comment - I was correct. Folders get put all over the place in linux. I found making a new user just for folding to be a better option.
The viewer shows the current work unit, the GPU work units have a bug in core_22 that causes some of them to show a pink cube.
If the FAHViewer, in the bottom left corner, it will say either "Live" or "Demo" for the Protein field. If it's Demo, then it s a generic one. If it is a Live one, that's actually the data that the WU is generating and you can see it via the "snapshots number which increases as the WU progresses.
BTW, the F@H Team is aware of the documentation state and there are plans to up-date it.
