Problem whit my rtx 2080 ti
Driver issues associated with the Windows 10 roll-out
Thirdsepirot
Post by Thirdsepirot »
Hello.
I have a problem with the program.
Folding at home does not start my GPU.
There doesn't even seem to be an error in the log.
Please help me.
Thank you
*********************** Log Started 2020-04-18T11:44:06Z ***********************
11:44:06:****************************** FAHClient ******************************
11:44:06:        Version: 7.6.9
11:44:06:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:44:06:      Copyright: 2020 foldingathome.org
11:44:06:       Homepage: https://foldingathome.org/
11:44:06:           Date: Apr 17 2020
11:44:06:           Time: 11:13:06
11:44:06:       Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
11:44:06:         Branch: master
11:44:06:       Compiler: Visual C++ 2008
11:44:06:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:44:06:       Platform: win32 10
11:44:06:           Bits: 32
11:44:06:           Mode: Release
11:44:06:           Args: --open-web-control
11:44:06:         Config: C:\Users\Alfredo\AppData\Roaming\FAHClient\config.xml
11:44:06:******************************** CBang ********************************
11:44:06:           Time: 11:10:09
11:44:06:       Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
11:44:06:           Bits: 32
11:44:06:******************************* System ********************************
11:44:06:            CPU: Intel(R) Core(TM) i7-5930K CPU @ 3.50GHz
11:44:06:         CPU ID: GenuineIntel Family 6 Model 63 Stepping 2
11:44:06:           CPUs: 12
11:44:06:         Memory: 31.90GiB
11:44:06:    Free Memory: 22.78GiB
11:44:06:        Threads: WINDOWS_THREADS
11:44:06:     OS Version: 6.2
11:44:06:    Has Battery: false
11:44:06:     On Battery: false
11:44:06:     UTC Offset: 2
11:44:06:            PID: 52368
11:44:06:            CWD: C:\Users\Alfredo\AppData\Roaming\FAHClient
11:44:06:             OS: Windows 10 Enterprise
11:44:06:        OS Arch: AMD64
11:44:06:           GPUs: 1
11:44:06:          GPU 0: Bus:2 Slot:0 Func:0 NVIDIA:8 TU102 [GeForce RTX 2080 Ti Rev. A]
11:44:06:                 M 13448
11:44:06:  CUDA Device 0: Platform:0 Device:0 Bus:2 Slot:0 Compute:7.5 Driver:11.0
11:44:06:OpenCL Device 0: Platform:0 Device:0 Bus:2 Slot:0 Compute:1.2 Driver:445.87
11:44:06:  Win32 Service: false
11:44:06:******************************* libFAH ********************************
11:44:06:           Date: Apr 15 2020
11:44:06:           Time: 14:53:14
11:44:06:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
11:44:06:           Bits: 32
11:44:06:***********************************************************************
11:44:06:<config>
11:44:06:  <!-- Folding Slot Configuration -->
11:44:06:  <cause v='COVID_19'/>
11:44:06:
11:44:06:  <!-- Network -->
11:44:06:  <proxy v=':8080'/>
11:44:06:
11:44:06:  <!-- Slot Control -->
11:44:06:  <power v='FULL'/>
11:44:06:
11:44:06:  <!-- Folding Slots -->
11:44:06:  <slot id='0' type='CPU'>
11:44:06:    <paused v='true'/>
11:44:06:  </slot>
11:44:06:</config>
11:44:06:Trying to access database...
11:44:06:Successfully acquired database lock
11:44:06:Enabled folding slot 00: PAUSED cpu:12 (by user)
11:44:07:3:127.0.0.1:New Web session
11:44:23:FS00:Unpaused
11:44:23:WU00:FS00:Starting
11:44:23:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Alfredo\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 52368 -checkpoint 15 -np 12
11:44:23:WU00:FS00:Started FahCore on PID 42740
11:44:23:WU00:FS00:Core PID:55608
11:44:23:WU00:FS00:FahCore 0xa7 started
11:44:24:WU00:FS00:0xa7:*********************** Log Started 2020-04-18T11:44:23Z ***********************
11:44:24:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
11:44:24:WU00:FS00:0xa7:       Type: 0xa7
11:44:24:WU00:FS00:0xa7:       Core: Gromacs
11:44:24:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 42740 -checkpoint 15 -np
11:44:24:WU00:FS00:0xa7:             12
11:44:24:WU00:FS00:0xa7:************************************ CBang *************************************
11:44:24:WU00:FS00:0xa7:       Date: Oct 26 2019
11:44:24:WU00:FS00:0xa7:       Time: 01:38:25
11:44:24:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
11:44:24:WU00:FS00:0xa7:     Branch: master
11:44:24:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
11:44:24:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:44:24:WU00:FS00:0xa7:   Platform: win32 10
11:44:24:WU00:FS00:0xa7:       Bits: 64
11:44:24:WU00:FS00:0xa7:       Mode: Release
11:44:24:WU00:FS00:0xa7:************************************ System ************************************
11:44:24:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-5930K CPU @ 3.50GHz
11:44:24:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 63 Stepping 2
11:44:24:WU00:FS00:0xa7:       CPUs: 12
11:44:24:WU00:FS00:0xa7:     Memory: 31.90GiB
11:44:24:WU00:FS00:0xa7:Free Memory: 22.73GiB
11:44:24:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
11:44:24:WU00:FS00:0xa7: OS Version: 6.2
11:44:24:WU00:FS00:0xa7:Has Battery: false
11:44:24:WU00:FS00:0xa7: On Battery: false
11:44:24:WU00:FS00:0xa7: UTC Offset: 2
11:44:24:WU00:FS00:0xa7:        PID: 55608
11:44:24:WU00:FS00:0xa7:        CWD: C:\Users\Alfredo\AppData\Roaming\FAHClient\work
11:44:24:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
11:44:24:WU00:FS00:0xa7:    Version: 0.0.18
11:44:24:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:44:24:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
11:44:24:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
11:44:24:WU00:FS00:0xa7:       Time: 01:52:30
11:44:24:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
11:44:24:WU00:FS00:0xa7:************************************ Build *************************************
11:44:24:WU00:FS00:0xa7:       SIMD: avx_256
11:44:24:WU00:FS00:0xa7:********************************************************************************
11:44:24:WU00:FS00:0xa7:Project: 13850 (Run 0, Clone 22561, Gen 30)
11:44:24:WU00:FS00:0xa7:Unit: 0x0000002d287234c95e788f51c2fc0450
11:44:24:WU00:FS00:0xa7:Digital signatures verified
11:44:24:WU00:FS00:0xa7:Calling: mdrun -s frame30.tpr -o frame30.trr -x frame30.xtc -e frame30.edr -cpi state.cpt -cpt 15 -nt 12
11:44:24:WU00:FS00:0xa7:Steps: first=15000000 total=500000
11:44:25:WU00:FS00:0xa7:Completed 162222 out of 500000 steps (32%)
11:45:07:Saving configuration to config.xml
11:45:07:<config>
11:45:07:  <!-- Folding Slot Configuration -->
11:45:07:  <cause v='COVID_19'/>
11:45:07:
11:45:07:  <!-- Network -->
11:45:07:  <proxy v=':8080'/>
11:45:07:
11:45:07:  <!-- Slot Control -->
11:45:07:  <power v='FULL'/>
11:45:07:
11:45:07:  <!-- Folding Slots -->
11:45:07:  <slot id='0' type='CPU'/>
11:45:07:</config>
11:45:18:WU00:FS00:0xa7:Completed 165000 out of 500000 steps (33%)
11:45:36:14:127.0.0.1:New Web session
11:46:52:WU00:FS00:0xa7:Completed 170000 out of 500000 steps (34%)
11:48:23:WU00:FS00:0xa7:Completed 175000 out of 500000 steps (35%)
11:49:52:WU00:FS00:0xa7:Completed 180000 out of 500000 steps (36%)
11:51:22:WU00:FS00:0xa7:Completed 185000 out of 500000 steps (37%)
11:52:18:FS00:Paused
11:52:18:FS00:Shutting core down
11:52:18:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 55608
11:52:18:WU00:FS00:0xa7:Exiting, please wait. . .
11:52:19:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
11:52:19:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
11:53:15:Saving configuration to config.xml
11:53:15:<config>
11:53:15:  <!-- Folding Slot Configuration -->
11:53:15:  <cause v='COVID_19'/>
11:53:15:
11:53:15:  <!-- Network -->
11:53:15:  <proxy v=':8080'/>
11:53:15:
11:53:15:  <!-- Slot Control -->
11:53:15:  <power v='FULL'/>
11:53:15:
11:53:15:  <!-- Folding Slots -->
11:53:15:  <slot id='0' type='CPU'>
11:53:15:    <paused v='true'/>
11:53:15:  </slot>
11:53:15:</config>
11:56:50:25:127.0.0.1:New Web session
11:56:58:FS00:Unpaused
11:56:58:WU00:FS00:Starting
11:56:59:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Alfredo\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 52368 -checkpoint 15 -np 12
11:56:59:WU00:FS00:Started FahCore on PID 55796
11:56:59:WU00:FS00:Core PID:52752
11:56:59:WU00:FS00:FahCore 0xa7 started
11:56:59:WU00:FS00:0xa7:*********************** Log Started 2020-04-18T11:56:59Z ***********************
11:56:59:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
11:56:59:WU00:FS00:0xa7:       Type: 0xa7
11:56:59:WU00:FS00:0xa7:       Core: Gromacs
11:56:59:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 55796 -checkpoint 15 -np
11:56:59:WU00:FS00:0xa7:             12
11:56:59:WU00:FS00:0xa7:************************************ CBang *************************************
11:56:59:WU00:FS00:0xa7:       Date: Oct 26 2019
11:56:59:WU00:FS00:0xa7:       Time: 01:38:25
11:56:59:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
11:56:59:WU00:FS00:0xa7:     Branch: master
11:56:59:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
11:56:59:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:56:59:WU00:FS00:0xa7:   Platform: win32 10
11:56:59:WU00:FS00:0xa7:       Bits: 64
11:56:59:WU00:FS00:0xa7:       Mode: Release
11:56:59:WU00:FS00:0xa7:************************************ System ************************************
11:56:59:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-5930K CPU @ 3.50GHz
11:56:59:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 63 Stepping 2
11:56:59:WU00:FS00:0xa7:       CPUs: 12
11:56:59:WU00:FS00:0xa7:     Memory: 31.90GiB
11:56:59:WU00:FS00:0xa7:Free Memory: 22.87GiB
11:56:59:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
11:56:59:WU00:FS00:0xa7: OS Version: 6.2
11:56:59:WU00:FS00:0xa7:Has Battery: false
11:56:59:WU00:FS00:0xa7: On Battery: false
11:56:59:WU00:FS00:0xa7: UTC Offset: 2
11:56:59:WU00:FS00:0xa7:        PID: 52752
11:56:59:WU00:FS00:0xa7:        CWD: C:\Users\Alfredo\AppData\Roaming\FAHClient\work
11:56:59:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
11:56:59:WU00:FS00:0xa7:    Version: 0.0.18
11:56:59:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:56:59:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
11:56:59:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
11:56:59:WU00:FS00:0xa7:       Time: 01:52:30
11:56:59:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
11:56:59:WU00:FS00:0xa7:************************************ Build *************************************
11:56:59:WU00:FS00:0xa7:       SIMD: avx_256
11:56:59:WU00:FS00:0xa7:********************************************************************************
11:56:59:WU00:FS00:0xa7:Project: 13850 (Run 0, Clone 22561, Gen 30)
11:56:59:WU00:FS00:0xa7:Unit: 0x0000002d287234c95e788f51c2fc0450
11:56:59:WU00:FS00:0xa7:Digital signatures verified
11:56:59:WU00:FS00:0xa7:Calling: mdrun -s frame30.tpr -o frame30.trr -x frame30.xtc -e frame30.edr -cpi state.cpt -cpt 15 -nt 12
11:56:59:WU00:FS00:0xa7:Steps: first=15000000 total=500000
11:57:01:WU00:FS00:0xa7:Completed 188102 out of 500000 steps (37%)
11:57:19:Saving configuration to config.xml
11:57:19:<config>
11:57:19:  <!-- Folding Slot Configuration -->
11:57:19:  <cause v='COVID_19'/>
11:57:19:
11:57:19:  <!-- Network -->
11:57:19:  <proxy v=':8080'/>
11:57:19:
11:57:19:  <!-- Slot Control -->
11:57:19:  <power v='FULL'/>
11:57:19:
11:57:19:  <!-- Folding Slots -->
11:57:19:  <slot id='0' type='CPU'/>
11:57:19:</config>
11:57:36:WU00:FS00:0xa7:Completed 190000 out of 500000 steps (38%)
11:59:10:WU00:FS00:0xa7:Completed 195000 out of 500000 steps (39%)
12:00:43:WU00:FS00:0xa7:Completed 200000 out of 500000 steps (40%)
12:02:13:WU00:FS00:0xa7:Completed 205000 out of 500000 steps (41%)
12:03:47:WU00:FS00:0xa7:Completed 210000 out of 500000 steps (42%)
12:05:17:WU00:FS00:0xa7:Completed 215000 out of 500000 steps (43%)
12:06:52:WU00:FS00:0xa7:Completed 220000 out of 500000 steps (44%)
12:08:32:WU00:FS00:0xa7:Completed 225000 out of 500000 steps (45%)
12:10:13:WU00:FS00:0xa7:Completed 230000 out of 500000 steps (46%)
12:11:44:WU00:FS00:0xa7:Completed 235000 out of 500000 steps (47%)
12:13:15:WU00:FS00:0xa7:Completed 240000 out of 500000 steps (48%)
12:14:47:WU00:FS00:0xa7:Completed 245000 out of 500000 steps (49%)
12:16:17:WU00:FS00:0xa7:Completed 250000 out of 500000 steps (50%)
12:17:49:WU00:FS00:0xa7:Completed 255000 out of 500000 steps (51%)
12:19:33:WU00:FS00:0xa7:Completed 260000 out of 500000 steps (52%)
12:21:03:WU00:FS00:0xa7:Completed 265000 out of 500000 steps (53%)
12:22:36:WU00:FS00:0xa7:Completed 270000 out of 500000 steps (54%)
12:24:24:WU00:FS00:0xa7:Completed 275000 out of 500000 steps (55%)
12:26:06:WU00:FS00:0xa7:Completed 280000 out of 500000 steps (56%)
12:27:36:WU00:FS00:0xa7:Completed 285000 out of 500000 steps (57%)
12:29:08:WU00:FS00:0xa7:Completed 290000 out of 500000 steps (58%)
12:30:43:WU00:FS00:0xa7:Completed 295000 out of 500000 steps (59%)
12:32:26:WU00:FS00:0xa7:Completed 300000 out of 500000 steps (60%)
12:33:57:WU00:FS00:0xa7:Completed 305000 out of 500000 steps (61%)
12:35:30:WU00:FS00:0xa7:Completed 310000 out of 500000 steps (62%)
12:37:04:WU00:FS00:0xa7:Completed 315000 out of 500000 steps (63%)
12:38:35:WU00:FS00:0xa7:Completed 320000 out of 500000 steps (64%)
12:40:07:WU00:FS00:0xa7:Completed 325000 out of 500000 steps (65%)
Re: Problem whit my rtx 2080 ti
Welcome to the F@H Forum Thirdsepirot,
I would suggest that you:
Manually download the GPUs.txt file from here: https://apps.foldingathome.org/GPUs.txt (right-click save as GPUs.txt)
Exit the client
Copy the GPUs.txt file from the Downloads folder to %AppData%\FAHClient
Reboot your system
Start up the client and ensure that you can see your GPU in the log file
Add a GPU slot from FAHControl -> Configure -> Slots tab -> Add -> GPU -> OK -> Save
Let us know if that works or not :)
Thirdsepirot
Yea..
Sorry if i didn't indroduce myself.. But It works!
Thank You so much!
