Mac 10.14.6 need to start FAHClient manually
Hopbackguy
Post by Hopbackguy »
I'm a new user, installed the latest package for MacOS last night. It installed fine, asked for my admin password. But I couldn't configure the client as FAHClient was not running, even after a reboot (I checked the Activity Monitor). It's in /usr/local/bin , and the plist file is in /library/launchdaemons.
In the end I started it by opening a terminal window and using the command "sudo /usr/local/bin/fahclient". It then connected to the FAHcontrol app and also to the configuration web page in Safari using the local loopback address.
What am I missing - why will it not start automatically? I don't have the MacOS firewall turned on. I do run Malwarebytes Premium.
Any suggestions welcome, though it's running fine - just not automatically.
Re: Mac 10.14.6 need to start FAHClient manually
Welcome to the F@H Forum Hopbackguy,
Can you please post your log file. Ensure that you have copied the System configuration which is present at the start of the log file: viewtopic.php?f=61&t=26036 :)
The default paths running FAHClient from the command line places things non-default locations for the WUs, folding cores, work files, and the like. The correct paths can be specified on on the command line though.
If you could check the Console log to see what messages are generated when launchtl should be starting up the background FAHClient process, that may help in figuring out what is not working.
Do you have Malwarebytes Premium running continuous scans? I and others have run into problems with that in the past. So I only do periodic scans with it. Try pausing and seeing if that makes a difference.
Hopbackguy
PantherX wrote:Welcome to the F@H Forum Hopbackguy,
Well, I went to /Library/Application Support/FAHClient but the folder was empty. I guess this may be because as another reply by Joe_H below says, starting FAHClient in the terminal window as I've done will be using non-standard paths for things. Not good. I have copied the log file using FAHControl, but as you see it seems to start from the time I started it manually, which worked.
*********************** Log Started 2020-04-18T16:47:27Z ***********************
16:47:27:****************************** FAHClient ******************************
16:47:27:    Version: 7.6.8
16:47:27:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:47:27:  Copyright: 2020 foldingathome.org
16:47:27:   Homepage: https://foldingathome.org/
16:47:27:       Date: Apr 15 2020
16:47:27:       Time: 14:45:05
16:47:27:   Revision: 34a6e026f7032e19bfa748ef56985f8e9fb09c99
16:47:27:     Branch: master
16:47:27:   Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
16:47:27:    Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
16:47:27:             -Wno-unused-local-typedefs -stdlib=libc++
16:47:27:   Platform: darwin 19.2.0
16:47:27:       Bits: 64
16:47:27:       Mode: Release
16:47:27:     Config: /Users/Mike/config.xml
16:47:27:******************************** CBang ********************************
16:47:27:       Time: 14:43:05
16:47:27:   Revision: 640ed4bc1084ddf2aa9cfa32aa9a2470dc8b7857
16:47:27:             -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
16:47:27:       Bits: 64
16:47:27:******************************* System ********************************
16:47:27:        CPU: Intel(R) Core(TM) i5-4570 CPU @ 3.20GHz
16:47:27:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
16:47:27:       CPUs: 4
16:47:27:     Memory: 8.00GiB
16:47:27:Free Memory: 28.83MiB
16:47:27:    Threads: POSIX_THREADS
16:47:27: OS Version: 10.14
16:47:27:Has Battery: false
16:47:27: On Battery: false
16:47:27: UTC Offset: 1
16:47:27:        PID: 1067
16:47:27:        CWD: /Users/Mike
16:47:27:         OS: Darwin 18.7.0 x86_64
16:47:27:    OS Arch: AMD64
16:47:27:       GPUs: 1
16:47:27:      GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:3 GK107M [GeForce GT 755M Mac Ed]
16:47:27:       CUDA: Not detected: Failed to open dynamic library 'libcuda.dylib':
16:47:27:             dlopen(libcuda.dylib, 1): image not found
16:47:27:     OpenCL: Not detected: Failed to open dynamic library 'libOpenCL.dylib':
16:47:27:             dlopen(libOpenCL.dylib, 1): image not found
16:47:27:******************************* libFAH ********************************
16:47:27:       Time: 14:43:28
16:47:27:   Revision: 216968bc7025029c841ed6e36e81a03a316890d3
16:47:27:       Bits: 64
16:47:27:***********************************************************************
16:47:27:<config>
16:47:27:  <!-- Folding Slot Configuration -->
16:47:27:  <cause v='COVID_19'/>
16:47:27:
16:47:27:  <!-- Network -->
16:47:27:  <proxy v=':8080'/>
16:47:27:
16:47:27:  <!-- Slot Control -->
16:47:27:  <power v='full'/>
16:47:27:
16:47:27:  <!-- User Information -->
16:47:27:  <passkey v='*****'/>
16:47:27:  <user v='Hopbackguy'/>
16:47:27:
16:47:27:  <!-- Folding Slots -->
16:47:27:  <slot id='0' type='CPU'>
16:47:27:    <cpus v='1'/>
16:47:27:  </slot>
16:47:27:</config>
16:47:27:Trying to access database...
16:47:27:Successfully acquired database lock
16:47:27:Enabled folding slot 00: READY cpu:1
16:47:27:WU01:FS00:Starting
16:47:27:WU01:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper /Users/Mike/cores/cores.foldingathome.org/v7/osx/64bit/avx/Core_a7.fah/FahCore_a7 -dir 01 -suffix 01 -version 706 -lifeline 1067 -checkpoint 15 -np 1
16:47:27:WU01:FS00:Started FahCore on PID 1068
16:47:27:WU01:FS00:Core PID:1069
16:47:27:WU01:FS00:FahCore 0xa7 started
16:47:27:WU01:FS00:0xa7:*********************** Log Started 2020-04-18T16:47:27Z ***********************
16:47:27:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
16:47:27:WU01:FS00:0xa7:       Type: 0xa7
16:47:27:WU01:FS00:0xa7:       Core: Gromacs
16:47:27:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 1068 -checkpoint 15 -np 1
16:47:27:WU01:FS00:0xa7:************************************ CBang *************************************
16:47:27:WU01:FS00:0xa7:       Date: Oct 26 2019
16:47:27:WU01:FS00:0xa7:       Time: 03:00:53
16:47:27:WU01:FS00:0xa7:   Revision: 3b1c887e9f30a608262e0d62833b273e843f7c1b
16:47:27:WU01:FS00:0xa7:     Branch: master
16:47:27:WU01:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
16:47:27:WU01:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
16:47:27:WU01:FS00:0xa7:             -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
16:47:27:WU01:FS00:0xa7:   Platform: darwin 19.0.0
16:47:27:WU01:FS00:0xa7:       Bits: 64
16:47:27:WU01:FS00:0xa7:       Mode: Release
16:47:27:WU01:FS00:0xa7:************************************ System ************************************
16:47:27:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-4570 CPU @ 3.20GHz
16:47:27:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
16:47:27:WU01:FS00:0xa7:       CPUs: 4
16:47:27:WU01:FS00:0xa7:     Memory: 8.00GiB
16:47:27:WU01:FS00:0xa7:Free Memory: 30.14MiB
16:47:27:WU01:FS00:0xa7:    Threads: POSIX_THREADS
16:47:27:WU01:FS00:0xa7: OS Version: 10.14
16:47:27:WU01:FS00:0xa7:Has Battery: false
16:47:27:WU01:FS00:0xa7: On Battery: false
16:47:27:WU01:FS00:0xa7: UTC Offset: 1
16:47:27:WU01:FS00:0xa7:        PID: 1069
16:47:27:WU01:FS00:0xa7:        CWD: /Users/Mike/work
16:47:27:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
16:47:27:WU01:FS00:0xa7:    Version: 0.0.18
16:47:27:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:47:27:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
16:47:27:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
16:47:27:WU01:FS00:0xa7:       Time: 03:06:33
16:47:27:WU01:FS00:0xa7:   Revision: fcc08f30b8997509aaba3a213354c363f474e056
16:47:27:WU01:FS00:0xa7:************************************ Build *************************************
16:47:27:WU01:FS00:0xa7:       SIMD: avx_256
16:47:27:WU01:FS00:0xa7:********************************************************************************
16:47:27:WU01:FS00:0xa7:Project: 13861 (Run 0, Clone 26867, Gen 15)
16:47:27:WU01:FS00:0xa7:Unit: 0x000000110d5a98395e9405dafe90602a
16:47:27:WU01:FS00:0xa7:Digital signatures verified
16:47:27:WU01:FS00:0xa7:Calling: mdrun -s frame15.tpr -o frame15.trr -x frame15.xtc -e frame15.edr -cpi state.cpt -cpt 15 -nt 1
16:47:27:WU01:FS00:0xa7:Steps: first=1875000 total=125000
16:47:28:3:127.0.0.1:New Web session
16:47:28:WU01:FS00:0xa7:Completed 9152 out of 125000 steps (7%)
16:49:31:WU01:FS00:0xa7:Completed 10000 out of 125000 steps (8%)
16:52:27:WU01:FS00:0xa7:Completed 11250 out of 125000 steps (9%)
16:55:22:WU01:FS00:0xa7:Completed 12500 out of 125000 steps (10%)
16:58:17:WU01:FS00:0xa7:Completed 13750 out of 125000 steps (11%)
17:01:10:WU01:FS00:0xa7:Completed 15000 out of 125000 steps (12%)
17:04:05:WU01:FS00:0xa7:Completed 16250 out of 125000 steps (13%)
17:06:59:WU01:FS00:0xa7:Completed 17500 out of 125000 steps (14%)
17:09:52:WU01:FS00:0xa7:Completed 18750 out of 125000 steps (15%)
17:12:45:WU01:FS00:0xa7:Completed 20000 out of 125000 steps (16%)
17:15:38:WU01:FS00:0xa7:Completed 21250 out of 125000 steps (17%)
17:18:33:WU01:FS00:0xa7:Completed 22500 out of 125000 steps (18%)
17:21:26:WU01:FS00:0xa7:Completed 23750 out of 125000 steps (19%)
17:24:20:WU01:FS00:0xa7:Completed 25000 out of 125000 steps (20%)
17:27:16:WU01:FS00:0xa7:Completed 26250 out of 125000 steps (21%)
17:30:10:WU01:FS00:0xa7:Completed 27500 out of 125000 steps (22%)
17:33:05:WU01:FS00:0xa7:Completed 28750 out of 125000 steps (23%)
17:35:57:WU01:FS00:0xa7:Completed 30000 out of 125000 steps (24%)
17:38:50:WU01:FS00:0xa7:Completed 31250 out of 125000 steps (25%)
17:41:42:WU01:FS00:0xa7:Completed 32500 out of 125000 steps (26%)
17:44:37:WU01:FS00:0xa7:Completed 33750 out of 125000 steps (27%)
17:47:33:WU01:FS00:0xa7:Completed 35000 out of 125000 steps (28%)
17:50:28:WU01:FS00:0xa7:Completed 36250 out of 125000 steps (29%)
17:53:22:WU01:FS00:0xa7:Completed 37500 out of 125000 steps (30%)
17:56:16:WU01:FS00:0xa7:Completed 38750 out of 125000 steps (31%)
17:59:10:WU01:FS00:0xa7:Completed 40000 out of 125000 steps (32%)
18:02:04:WU01:FS00:0xa7:Completed 41250 out of 125000 steps (33%)
18:04:59:WU01:FS00:0xa7:Completed 42500 out of 125000 steps (34%)
18:07:51:WU01:FS00:0xa7:Completed 43750 out of 125000 steps (35%)
18:10:43:WU01:FS00:0xa7:Completed 45000 out of 125000 steps (36%)
18:13:35:WU01:FS00:0xa7:Completed 46250 out of 125000 steps (37%)
18:16:28:WU01:FS00:0xa7:Completed 47500 out of 125000 steps (38%)
18:19:22:WU01:FS00:0xa7:Completed 48750 out of 125000 steps (39%)
18:22:14:WU01:FS00:0xa7:Completed 50000 out of 125000 steps (40%)
18:25:05:WU01:FS00:0xa7:Completed 51250 out of 125000 steps (41%)
18:27:56:WU01:FS00:0xa7:Completed 52500 out of 125000 steps (42%)
18:30:47:WU01:FS00:0xa7:Completed 53750 out of 125000 steps (43%)
18:33:40:WU01:FS00:0xa7:Completed 55000 out of 125000 steps (44%)
18:36:31:WU01:FS00:0xa7:Completed 56250 out of 125000 steps (45%)
18:39:22:WU01:FS00:0xa7:Completed 57500 out of 125000 steps (46%)
18:42:13:WU01:FS00:0xa7:Completed 58750 out of 125000 steps (47%)
18:45:05:WU01:FS00:0xa7:Completed 60000 out of 125000 steps (48%)
18:48:00:WU01:FS00:0xa7:Completed 61250 out of 125000 steps (49%)
18:50:51:WU01:FS00:0xa7:Completed 62500 out of 125000 steps (50%)
18:53:42:WU01:FS00:0xa7:Completed 63750 out of 125000 steps (51%)
18:56:34:WU01:FS00:0xa7:Completed 65000 out of 125000 steps (52%)
18:59:28:WU01:FS00:0xa7:Completed 66250 out of 125000 steps (53%)
19:02:20:WU01:FS00:0xa7:Completed 67500 out of 125000 steps (54%)
19:05:15:WU01:FS00:0xa7:Completed 68750 out of 125000 steps (55%)
19:08:06:WU01:FS00:0xa7:Completed 70000 out of 125000 steps (56%)
19:10:57:WU01:FS00:0xa7:Completed 71250 out of 125000 steps (57%)
19:13:48:WU01:FS00:0xa7:Completed 72500 out of 125000 steps (58%)
19:16:39:WU01:FS00:0xa7:Completed 73750 out of 125000 steps (59%)
19:19:32:WU01:FS00:0xa7:Completed 75000 out of 125000 steps (60%)
19:22:24:WU01:FS00:0xa7:Completed 76250 out of 125000 steps (61%)
19:25:15:WU01:FS00:0xa7:Completed 77500 out of 125000 steps (62%)
19:28:06:WU01:FS00:0xa7:Completed 78750 out of 125000 steps (63%)
19:30:57:WU01:FS00:0xa7:Completed 80000 out of 125000 steps (64%)
19:33:50:WU01:FS00:0xa7:Completed 81250 out of 125000 steps (65%)
19:36:42:WU01:FS00:0xa7:Completed 82500 out of 125000 steps (66%)
19:39:33:WU01:FS00:0xa7:Completed 83750 out of 125000 steps (67%)
19:42:26:WU01:FS00:0xa7:Completed 85000 out of 125000 steps (68%)
19:45:20:WU01:FS00:0xa7:Completed 86250 out of 125000 steps (69%)
19:48:14:WU01:FS00:0xa7:Completed 87500 out of 125000 steps (70%)
19:51:07:WU01:FS00:0xa7:Completed 88750 out of 125000 steps (71%)
19:53:59:WU01:FS00:0xa7:Completed 90000 out of 125000 steps (72%)
19:56:52:WU01:FS00:0xa7:Completed 91250 out of 125000 steps (73%)
19:59:44:WU01:FS00:0xa7:Completed 92500 out of 125000 steps (74%)
20:02:37:WU01:FS00:0xa7:Completed 93750 out of 125000 steps (75%)
20:05:28:WU01:FS00:0xa7:Completed 95000 out of 125000 steps (76%)
20:08:19:WU01:FS00:0xa7:Completed 96250 out of 125000 steps (77%)
20:11:10:WU01:FS00:0xa7:Completed 97500 out of 125000 steps (78%)
20:14:02:WU01:FS00:0xa7:Completed 98750 out of 125000 steps (79%)
20:16:53:WU01:FS00:0xa7:Completed 100000 out of 125000 steps (80%)
20:19:46:WU01:FS00:0xa7:Completed 101250 out of 125000 steps (81%)
20:22:37:WU01:FS00:0xa7:Completed 102500 out of 125000 steps (82%)
20:25:28:WU01:FS00:0xa7:Completed 103750 out of 125000 steps (83%)
20:28:19:WU01:FS00:0xa7:Completed 105000 out of 125000 steps (84%)
20:31:11:WU01:FS00:0xa7:Completed 106250 out of 125000 steps (85%)
20:34:04:WU01:FS00:0xa7:Completed 107500 out of 125000 steps (86%)
20:36:55:WU01:FS00:0xa7:Completed 108750 out of 125000 steps (87%)
20:39:48:WU01:FS00:0xa7:Completed 110000 out of 125000 steps (88%)
20:42:42:WU01:FS00:0xa7:Completed 111250 out of 125000 steps (89%)
20:45:34:WU01:FS00:0xa7:Completed 112500 out of 125000 steps (90%)
20:48:26:WU01:FS00:0xa7:Completed 113750 out of 125000 steps (91%)
20:51:18:WU01:FS00:0xa7:Completed 115000 out of 125000 steps (92%)
20:54:09:WU01:FS00:0xa7:Completed 116250 out of 125000 steps (93%)
20:57:00:WU01:FS00:0xa7:Completed 117500 out of 125000 steps (94%)
20:59:52:WU01:FS00:0xa7:Completed 118750 out of 125000 steps (95%)
21:02:45:WU01:FS00:0xa7:Completed 120000 out of 125000 steps (96%)
21:05:36:WU01:FS00:0xa7:Completed 121250 out of 125000 steps (97%)
21:08:27:WU01:FS00:0xa7:Completed 122500 out of 125000 steps (98%)
21:11:18:WU01:FS00:0xa7:Completed 123750 out of 125000 steps (99%)
21:11:19:WU00:FS00:Connecting to 65.254.110.245:80
21:11:20:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
21:11:20:WU00:FS00:Connecting to 18.218.241.186:80
21:11:20:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:11:20:WU00:FS00:Connecting to 65.254.110.245:80
21:11:21:WU00:FS00:Assigned to work server 155.247.164.214
21:11:21:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:1 from 155.247.164.214
21:11:21:WU00:FS00:Connecting to 155.247.164.214:8080
21:11:21:WU00:FS00:Downloading 2.83MiB
21:11:24:WU00:FS00:Download complete
21:11:24:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14363 run:244 clone:0 gen:61 core:0xa7 unit:0x000000419bf7a4d65e7c8685f8928c64
21:14:09:WU01:FS00:0xa7:Completed 125000 out of 125000 steps (100%)
21:14:12:WU01:FS00:0xa7:Saving result file ../logfile_01.txt
21:14:12:WU01:FS00:0xa7:Saving result file frame15.edr
21:14:12:WU01:FS00:0xa7:Saving result file frame15.trr
21:14:12:WU01:FS00:0xa7:Saving result file frame15.xtc
21:14:12:WU01:FS00:0xa7:Saving result file md.log
21:14:12:WU01:FS00:0xa7:Saving result file science.log
21:14:12:WU01:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
21:14:13:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
21:14:13:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13861 run:0 clone:26867 gen:15 core:0xa7 unit:0x000000110d5a98395e9405dafe90602a
21:14:13:WU01:FS00:Uploading 5.27MiB to 13.90.152.57
21:14:13:WU01:FS00:Connecting to 13.90.152.57:8080
21:14:13:WU00:FS00:Starting
21:14:13:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper /Users/Mike/cores/cores.foldingathome.org/v7/osx/64bit/avx/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 706 -lifeline 1067 -checkpoint 15 -np 1
21:14:13:WU00:FS00:Started FahCore on PID 24389
21:14:13:WU00:FS00:Core PID:24390
21:14:13:WU00:FS00:FahCore 0xa7 started
21:14:13:WU00:FS00:0xa7:*********************** Log Started 2020-04-18T21:14:13Z ***********************
21:14:13:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
21:14:13:WU00:FS00:0xa7:       Type: 0xa7
21:14:13:WU00:FS00:0xa7:       Core: Gromacs
21:14:13:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 24389 -checkpoint 15 -np
21:14:13:WU00:FS00:0xa7:             1
21:14:13:WU00:FS00:0xa7:************************************ CBang *************************************
21:14:13:WU00:FS00:0xa7:       Date: Oct 26 2019
21:14:13:WU00:FS00:0xa7:       Time: 03:00:53
21:14:13:WU00:FS00:0xa7:   Revision: 3b1c887e9f30a608262e0d62833b273e843f7c1b
21:14:13:WU00:FS00:0xa7:     Branch: master
21:14:13:WU00:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
21:14:13:WU00:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
21:14:13:WU00:FS00:0xa7:             -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
21:14:13:WU00:FS00:0xa7:   Platform: darwin 19.0.0
21:14:13:WU00:FS00:0xa7:       Bits: 64
21:14:13:WU00:FS00:0xa7:       Mode: Release
21:14:13:WU00:FS00:0xa7:************************************ System ************************************
21:14:13:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-4570 CPU @ 3.20GHz
21:14:13:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
21:14:13:WU00:FS00:0xa7:       CPUs: 4
21:14:13:WU00:FS00:0xa7:     Memory: 8.00GiB
21:14:13:WU00:FS00:0xa7:Free Memory: 522.62MiB
21:14:13:WU00:FS00:0xa7:    Threads: POSIX_THREADS
21:14:13:WU00:FS00:0xa7: OS Version: 10.14
21:14:13:WU00:FS00:0xa7:Has Battery: false
21:14:13:WU00:FS00:0xa7: On Battery: false
21:14:13:WU00:FS00:0xa7: UTC Offset: 1
21:14:13:WU00:FS00:0xa7:        PID: 24390
21:14:13:WU00:FS00:0xa7:        CWD: /Users/Mike/work
21:14:13:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
21:14:13:WU00:FS00:0xa7:    Version: 0.0.18
21:14:13:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:14:13:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
21:14:13:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
21:14:13:WU00:FS00:0xa7:       Time: 03:06:33
21:14:13:WU00:FS00:0xa7:   Revision: fcc08f30b8997509aaba3a213354c363f474e056
21:14:13:WU00:FS00:0xa7:************************************ Build *************************************
21:14:13:WU00:FS00:0xa7:       SIMD: avx_256
21:14:13:WU00:FS00:0xa7:********************************************************************************
21:14:13:WU00:FS00:0xa7:Project: 14363 (Run 244, Clone 0, Gen 61)
21:14:13:WU00:FS00:0xa7:Unit: 0x000000419bf7a4d65e7c8685f8928c64
21:14:13:WU00:FS00:0xa7:Reading tar file core.xml
21:14:13:WU00:FS00:0xa7:Reading tar file frame61.tpr
21:14:13:WU00:FS00:0xa7:Digital signatures verified
21:14:13:WU00:FS00:0xa7:Calling: mdrun -s frame61.tpr -o frame61.trr -cpt 15 -nt 1
21:14:13:WU00:FS00:0xa7:Steps: first=0 total=250000
21:14:15:WU00:FS00:0xa7:Completed 1 out of 250000 steps (0%)
21:14:27:WU01:FS00:Upload 4.74%
21:14:33:WU01:FS00:Upload 59.29%
21:14:45:WU01:FS00:Upload complete
21:14:45:WU01:FS00:Server responded WORK_ACK (400)
21:14:45:WU01:FS00:Final credit estimate, 1169.00 points
21:14:45:WU01:FS00:Cleaning up
21:19:26:WU00:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
21:24:37:WU00:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
21:29:50:WU00:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
21:35:01:WU00:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
21:40:15:WU00:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
21:45:31:WU00:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
21:50:42:WU00:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
21:56:03:WU00:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
22:01:25:WU00:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
22:06:47:WU00:FS00:0xa7:Completed 25000 out of 250000 steps (10%)
22:12:08:WU00:FS00:0xa7:Completed 27500 out of 250000 steps (11%)
22:17:28:WU00:FS00:0xa7:Completed 30000 out of 250000 steps (12%)
22:22:47:WU00:FS00:0xa7:Completed 32500 out of 250000 steps (13%)
22:28:07:WU00:FS00:0xa7:Completed 35000 out of 250000 steps (14%)
22:33:29:WU00:FS00:0xa7:Completed 37500 out of 250000 steps (15%)
22:38:50:WU00:FS00:0xa7:Completed 40000 out of 250000 steps (16%)
22:44:16:WU00:FS00:0xa7:Completed 42500 out of 250000 steps (17%)
******************************* Date: 2020-04-18 *******************************
22:49:36:WU00:FS00:0xa7:Completed 45000 out of 250000 steps (18%)
22:54:56:WU00:FS00:0xa7:Completed 47500 out of 250000 steps (19%)
23:00:20:WU00:FS00:0xa7:Completed 50000 out of 250000 steps (20%)
23:05:41:WU00:FS00:0xa7:Completed 52500 out of 250000 steps (21%)
23:11:51:WU00:FS00:0xa7:Completed 55000 out of 250000 steps (22%)
23:50:47:WARNING:WU00:FS00:Detected clock skew (38 mins 45 secs), I/O delay, laptop hibernation or other slowdown noted, adjusting time estimates
23:50:47:WARNING:WU00:FS00:FahCore returned: WU_STALLED (127 = 0x7f)
23:50:47:WU00:FS00:Starting
23:50:47:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper /Users/Mike/cores/cores.foldingathome.org/v7/osx/64bit/avx/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 706 -lifeline 1067 -checkpoint 15 -np 1
23:50:47:WU00:FS00:Started FahCore on PID 33578
23:50:47:WU00:FS00:Core PID:33579
23:50:47:WU00:FS00:FahCore 0xa7 started
23:50:48:WU00:FS00:0xa7:*********************** Log Started 2020-04-18T23:50:48Z ***********************
23:50:48:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
23:50:48:WU00:FS00:0xa7:       Type: 0xa7
23:50:48:WU00:FS00:0xa7:       Core: Gromacs
23:50:48:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 33578 -checkpoint 15 -np
23:50:48:WU00:FS00:0xa7:             1
23:50:48:WU00:FS00:0xa7:************************************ CBang *************************************
23:50:48:WU00:FS00:0xa7:       Date: Oct 26 2019
23:50:48:WU00:FS00:0xa7:       Time: 03:00:53
23:50:48:WU00:FS00:0xa7:   Revision: 3b1c887e9f30a608262e0d62833b273e843f7c1b
23:50:48:WU00:FS00:0xa7:     Branch: master
23:50:48:WU00:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
23:50:48:WU00:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
23:50:48:WU00:FS00:0xa7:             -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
23:50:48:WU00:FS00:0xa7:   Platform: darwin 19.0.0
23:50:48:WU00:FS00:0xa7:       Bits: 64
23:50:48:WU00:FS00:0xa7:       Mode: Release
23:50:48:WU00:FS00:0xa7:************************************ System ************************************
23:50:48:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-4570 CPU @ 3.20GHz
23:50:48:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
23:50:48:WU00:FS00:0xa7:       CPUs: 4
23:50:48:WU00:FS00:0xa7:     Memory: 8.00GiB
23:50:48:WU00:FS00:0xa7:Free Memory: 74.01MiB
23:50:48:WU00:FS00:0xa7:    Threads: POSIX_THREADS
23:50:48:WU00:FS00:0xa7: OS Version: 10.14
23:50:48:WU00:FS00:0xa7:Has Battery: false
23:50:48:WU00:FS00:0xa7: On Battery: false
23:50:48:WU00:FS00:0xa7: UTC Offset: 1
23:50:48:WU00:FS00:0xa7:        PID: 33579
23:50:48:WU00:FS00:0xa7:        CWD: /Users/Mike/work
23:50:48:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
23:50:48:WU00:FS00:0xa7:    Version: 0.0.18
23:50:48:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:50:48:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
23:50:48:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
23:50:48:WU00:FS00:0xa7:       Time: 03:06:33
23:50:48:WU00:FS00:0xa7:   Revision: fcc08f30b8997509aaba3a213354c363f474e056
23:50:48:WU00:FS00:0xa7:************************************ Build *************************************
23:50:48:WU00:FS00:0xa7:       SIMD: avx_256
23:50:48:WU00:FS00:0xa7:********************************************************************************
23:50:48:WU00:FS00:0xa7:Project: 14363 (Run 244, Clone 0, Gen 61)
23:50:48:WU00:FS00:0xa7:Unit: 0x000000419bf7a4d65e7c8685f8928c64
23:50:48:WU00:FS00:0xa7:Digital signatures verified
23:50:48:WU00:FS00:0xa7:Calling: mdrun -s frame61.tpr -o frame61.trr -cpi state.cpt -cpt 15 -nt 1
23:50:48:WU00:FS00:0xa7:Steps: first=0 total=250000
23:50:48:WU00:FS00:0xa7:Completed 49501 out of 250000 steps (19%)
23:52:00:WU00:FS00:0xa7:Completed 50000 out of 250000 steps (20%)
23:57:26:WU00:FS00:0xa7:Completed 52500 out of 250000 steps (21%)
00:02:48:WU00:FS00:0xa7:Completed 55000 out of 250000 steps (22%)
00:39:19:WARNING:WU00:FS00:Detected clock skew (34 mins 22 secs), I/O delay, laptop hibernation or other slowdown noted, adjusting time estimates
00:39:19:WARNING:WU00:FS00:FahCore returned: WU_STALLED (127 = 0x7f)
00:39:19:WU00:FS00:Starting
00:39:19:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper /Users/Mike/cores/cores.foldingathome.org/v7/osx/64bit/avx/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 706 -lifeline 1067 -checkpoint 15 -np 1
00:39:19:WU00:FS00:Started FahCore on PID 34775
00:39:19:WU00:FS00:Core PID:34776
00:39:19:WU00:FS00:FahCore 0xa7 started
00:39:20:WARNING:WU00:FS00:FahCore returned: BAD_FRAME_CHECKSUM (112 = 0x70)
00:39:20:WARNING:WU00:FS00:Fatal error, dumping
00:39:20:WU00:FS00:Sending unit results: id:00 state:SEND error:DUMPED project:14363 run:244 clone:0 gen:61 core:0xa7 unit:0x000000419bf7a4d65e7c8685f8928c64
00:39:20:WU00:FS00:Uploading 2.01MiB to 155.247.164.214
00:39:20:WU00:FS00:Connecting to 155.247.164.214:8080
00:39:20:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
00:39:20:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 155.247.164.214:80: Network is unreachable
00:39:20:WU00:FS00:Trying to send results to collection server
00:39:20:WU00:FS00:Uploading 2.01MiB to 52.224.109.74
00:39:20:WU00:FS00:Connecting to 52.224.109.74:8080
00:39:20:ERROR:WU00:FS00:Exception: Failed to connect to 52.224.109.74:80: Network is unreachable
00:39:20:WU01:FS00:Connecting to 65.254.110.245:80
00:39:21:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
00:39:21:WU01:FS00:Connecting to 18.218.241.186:80
00:39:44:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
00:39:44:WU01:FS00:Connecting to 65.254.110.245:80
00:39:45:WU00:FS00:Upload complete
00:39:45:WU00:FS00:Server responded WORK_QUIT (404)
00:39:45:WARNING:WU00:FS00:Server did not like results, dumping
00:39:45:WU00:FS00:Cleaning up
00:39:45:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
00:39:45:WU01:FS00:Connecting to 18.218.241.186:80
00:39:46:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
00:39:46:ERROR:WU01:FS00:Exception: Could not get an assignment
00:39:46:WU01:FS00:Connecting to 65.254.110.245:80
00:39:46:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
00:39:46:WU01:FS00:Connecting to 18.218.241.186:80
00:39:47:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
00:39:47:WU01:FS00:Connecting to 65.254.110.245:80
00:39:47:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
00:39:47:WU01:FS00:Connecting to 18.218.241.186:80
00:39:48:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
00:39:48:ERROR:WU01:FS00:Exception: Could not get an assignment
00:41:08:WU01:FS00:Connecting to 65.254.110.245:80
00:41:08:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': Failed to connect to 65.254.110.245:80: Network is down
00:41:08:WU01:FS00:Connecting to 18.218.241.186:80
00:41:08:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': Failed to connect to 18.218.241.186:80: Network is down
00:41:08:ERROR:WU01:FS00:Exception: Could not get an assignment
02:41:54:ERROR:WU01:FS00:Exception: Could not get IP address for assign1.foldingathome.org: nodename nor servname provided, or not known
02:41:54:ERROR:WU01:FS00:Exception: Could not get IP address for assign2.foldingathome.org: nodename nor servname provided, or not known
02:41:54:ERROR:WU01:FS00:Exception: Could not get IP address for assign3.foldingathome.org: nodename nor servname provided, or not known
02:41:54:ERROR:WU01:FS00:Exception: Could not get IP address for assign4.foldingathome.org: nodename nor servname provided, or not known
02:41:54:WARNING:WU01:FS00:Exception: Failed to find any IP addresses for assignment servers
02:41:54:ERROR:WU01:FS00:Exception: Could not get an assignment
03:59:13:ERROR:WU01:FS00:Exception: Could not get IP address for assign1.foldingathome.org: nodename nor servname provided, or not known
03:59:13:ERROR:WU01:FS00:Exception: Could not get IP address for assign2.foldingathome.org: nodename nor servname provided, or not known
03:59:13:ERROR:WU01:FS00:Exception: Could not get IP address for assign3.foldingathome.org: nodename nor servname provided, or not known
03:59:13:ERROR:WU01:FS00:Exception: Could not get IP address for assign4.foldingathome.org: nodename nor servname provided, or not known
03:59:13:WARNING:WU01:FS00:Exception: Failed to find any IP addresses for assignment servers
03:59:13:ERROR:WU01:FS00:Exception: Could not get an assignment
******************************* Date: 2020-04-19 *******************************
06:00:17:ERROR:WU01:FS00:Exception: Could not get IP address for assign1.foldingathome.org: nodename nor servname provided, or not known
06:00:17:ERROR:WU01:FS00:Exception: Could not get IP address for assign2.foldingathome.org: nodename nor servname provided, or not known
06:00:17:ERROR:WU01:FS00:Exception: Could not get IP address for assign3.foldingathome.org: nodename nor servname provided, or not known
06:00:17:ERROR:WU01:FS00:Exception: Could not get IP address for assign4.foldingathome.org: nodename nor servname provided, or not known
06:00:17:WARNING:WU01:FS00:Exception: Failed to find any IP addresses for assignment servers
06:00:17:ERROR:WU01:FS00:Exception: Could not get an assignment
06:45:00:ERROR:WU01:FS00:Exception: Could not get IP address for assign1.foldingathome.org: nodename nor servname provided, or not known
06:45:00:ERROR:WU01:FS00:Exception: Could not get IP address for assign2.foldingathome.org: nodename nor servname provided, or not known
06:45:00:ERROR:WU01:FS00:Exception: Could not get IP address for assign3.foldingathome.org: nodename nor servname provided, or not known
06:45:00:ERROR:WU01:FS00:Exception: Could not get IP address for assign4.foldingathome.org: nodename nor servname provided, or not known
06:45:00:WARNING:WU01:FS00:Exception: Failed to find any IP addresses for assignment servers
06:45:00:ERROR:WU01:FS00:Exception: Could not get an assignment
06:56:05:ERROR:WU01:FS00:Exception: Could not get IP address for assign1.foldingathome.org: nodename nor servname provided, or not known
06:56:05:ERROR:WU01:FS00:Exception: Could not get IP address for assign2.foldingathome.org: nodename nor servname provided, or not known
06:56:05:ERROR:WU01:FS00:Exception: Could not get IP address for assign3.foldingathome.org: nodename nor servname provided, or not known
06:56:05:ERROR:WU01:FS00:Exception: Could not get IP address for assign4.foldingathome.org: nodename nor servname provided, or not known
06:56:05:WARNING:WU01:FS00:Exception: Failed to find any IP addresses for assignment servers
06:56:05:ERROR:WU01:FS00:Exception: Could not get an assignment
07:14:02:WU01:FS00:Connecting to 65.254.110.245:80
07:14:03:WU01:FS00:Assigned to work server 40.114.52.201
07:14:03:WU01:FS00:Requesting new work unit for slot 00: READY cpu:1 from 40.114.52.201
07:14:03:WU01:FS00:Connecting to 40.114.52.201:8080
07:14:03:ERROR:WU01:FS00:Exception: Server did not assign work unit
07:43:04:WU01:FS00:Connecting to 65.254.110.245:80
07:43:04:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
07:43:04:WU01:FS00:Connecting to 18.218.241.186:80
07:43:05:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
07:43:05:WU01:FS00:Connecting to 65.254.110.245:80
07:43:05:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
07:43:05:WU01:FS00:Connecting to 18.218.241.186:80
07:43:06:WU01:FS00:Assigned to work server 155.247.164.213
07:43:06:WU01:FS00:Requesting new work unit for slot 00: READY cpu:1 from 155.247.164.213
07:43:06:WU01:FS00:Connecting to 155.247.164.213:8080
07:43:27:WU01:FS00:Downloading 136.50KiB
07:43:28:WU01:FS00:Download complete
07:43:28:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14641 run:1068 clone:0 gen:6 core:0xa7 unit:0x000000089bf7a4d55e8b9fa4fd1e82ca
07:43:28:WU01:FS00:Starting
07:43:28:WU01:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper /Users/Mike/cores/cores.foldingathome.org/v7/osx/64bit/avx/Core_a7.fah/FahCore_a7 -dir 01 -suffix 01 -version 706 -lifeline 1067 -checkpoint 15 -np 1
07:43:28:WU01:FS00:Started FahCore on PID 39065
07:43:28:WU01:FS00:Core PID:39066
07:43:28:WU01:FS00:FahCore 0xa7 started
07:43:28:WU01:FS00:0xa7:*********************** Log Started 2020-04-19T07:43:28Z ***********************
07:43:28:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
07:43:28:WU01:FS00:0xa7:       Type: 0xa7
07:43:28:WU01:FS00:0xa7:       Core: Gromacs
07:43:28:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 39065 -checkpoint 15 -np
07:43:28:WU01:FS00:0xa7:             1
07:43:28:WU01:FS00:0xa7:************************************ CBang *************************************
07:43:28:WU01:FS00:0xa7:       Date: Oct 26 2019
07:43:28:WU01:FS00:0xa7:       Time: 03:00:53
07:43:28:WU01:FS00:0xa7:   Revision: 3b1c887e9f30a608262e0d62833b273e843f7c1b
07:43:28:WU01:FS00:0xa7:     Branch: master
07:43:28:WU01:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
07:43:28:WU01:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
07:43:28:WU01:FS00:0xa7:             -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
07:43:28:WU01:FS00:0xa7:   Platform: darwin 19.0.0
07:43:28:WU01:FS00:0xa7:       Bits: 64
07:43:28:WU01:FS00:0xa7:       Mode: Release
07:43:28:WU01:FS00:0xa7:************************************ System ************************************
07:43:28:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-4570 CPU @ 3.20GHz
07:43:28:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
07:43:28:WU01:FS00:0xa7:       CPUs: 4
07:43:28:WU01:FS00:0xa7:     Memory: 8.00GiB
07:43:28:WU01:FS00:0xa7:Free Memory: 981.69MiB
07:43:28:WU01:FS00:0xa7:    Threads: POSIX_THREADS
07:43:28:WU01:FS00:0xa7: OS Version: 10.14
07:43:28:WU01:FS00:0xa7:Has Battery: false
07:43:28:WU01:FS00:0xa7: On Battery: false
07:43:28:WU01:FS00:0xa7: UTC Offset: 1
07:43:28:WU01:FS00:0xa7:        PID: 39066
07:43:28:WU01:FS00:0xa7:        CWD: /Users/Mike/work
07:43:28:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
07:43:28:WU01:FS00:0xa7:    Version: 0.0.18
07:43:28:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:43:28:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
07:43:28:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
07:43:28:WU01:FS00:0xa7:       Time: 03:06:33
07:43:28:WU01:FS00:0xa7:   Revision: fcc08f30b8997509aaba3a213354c363f474e056
07:43:28:WU01:FS00:0xa7:************************************ Build *************************************
07:43:28:WU01:FS00:0xa7:       SIMD: avx_256
07:43:28:WU01:FS00:0xa7:********************************************************************************
07:43:28:WU01:FS00:0xa7:Project: 14641 (Run 1068, Clone 0, Gen 6)
07:43:28:WU01:FS00:0xa7:Unit: 0x000000089bf7a4d55e8b9fa4fd1e82ca
07:43:28:WU01:FS00:0xa7:Reading tar file core.xml
07:43:28:WU01:FS00:0xa7:Reading tar file frame6.tpr
07:43:28:WU01:FS00:0xa7:Digital signatures verified
07:43:28:WU01:FS00:0xa7:Calling: mdrun -s frame6.tpr -o frame6.trr -cpt 15 -nt 1
07:43:28:WU01:FS00:0xa7:Steps: first=0 total=2500000
07:43:28:WU01:FS00:0xa7:Completed 1 out of 2500000 steps (0%)
07:47:21:WU01:FS00:0xa7:Completed 25000 out of 2500000 steps (1%)
07:51:14:WU01:FS00:0xa7:Completed 50000 out of 2500000 steps (2%)
07:55:07:WU01:FS00:0xa7:Completed 75000 out of 2500000 steps (3%)
07:59:01:WU01:FS00:0xa7:Completed 100000 out of 2500000 steps (4%)
08:02:55:WU01:FS00:0xa7:Completed 125000 out of 2500000 steps (5%)
08:06:48:WU01:FS00:0xa7:Completed 150000 out of 2500000 steps (6%)
08:10:46:WU01:FS00:0xa7:Completed 175000 out of 2500000 steps (7%)
08:12:56:62:127.0.0.1:New Web session
08:14:42:WU01:FS00:0xa7:Completed 200000 out of 2500000 steps (8%)
08:18:39:WU01:FS00:0xa7:Completed 225000 out of 2500000 steps (9%)
08:22:33:WU01:FS00:0xa7:Completed 250000 out of 2500000 steps (10%)
08:26:29:WU01:FS00:0xa7:Completed 275000 out of 2500000 steps (11%)
08:30:23:WU01:FS00:0xa7:Completed 300000 out of 2500000 steps (12%)
08:34:14:WU01:FS00:0xa7:Completed 325000 out of 2500000 steps (13%)
08:38:06:WU01:FS00:0xa7:Completed 350000 out of 2500000 steps (14%)
08:41:58:WU01:FS00:0xa7:Completed 375000 out of 2500000 steps (15%)
08:45:52:WU01:FS00:0xa7:Completed 400000 out of 2500000 steps (16%)
08:49:47:WU01:FS00:0xa7:Completed 425000 out of 2500000 steps (17%)
08:53:39:WU01:FS00:0xa7:Completed 450000 out of 2500000 steps (18%)
08:57:29:WU01:FS00:0xa7:Completed 475000 out of 2500000 steps (19%)
09:01:22:WU01:FS00:0xa7:Completed 500000 out of 2500000 steps (20%)
09:05:12:WU01:FS00:0xa7:Completed 525000 out of 2500000 steps (21%)
09:09:03:WU01:FS00:0xa7:Completed 550000 out of 2500000 steps (22%)
09:12:52:WU01:FS00:0xa7:Completed 575000 out of 2500000 steps (23%)
09:16:44:WU01:FS00:0xa7:Completed 600000 out of 2500000 steps (24%)
09:20:38:WU01:FS00:0xa7:Completed 625000 out of 2500000 steps (25%)
09:24:32:WU01:FS00:0xa7:Completed 650000 out of 2500000 steps (26%)
09:28:23:WU01:FS00:0xa7:Completed 675000 out of 2500000 steps (27%)
09:32:14:WU01:FS00:0xa7:Completed 700000 out of 2500000 steps (28%)
09:36:04:WU01:FS00:0xa7:Completed 725000 out of 2500000 steps (29%)
09:39:54:WU01:FS00:0xa7:Completed 750000 out of 2500000 steps (30%)
09:43:47:WU01:FS00:0xa7:Completed 775000 out of 2500000 steps (31%)
09:47:39:WU01:FS00:0xa7:Completed 800000 out of 2500000 steps (32%)
09:51:29:WU01:FS00:0xa7:Completed 825000 out of 2500000 steps (33%)
09:55:19:WU01:FS00:0xa7:Completed 850000 out of 2500000 steps (34%)
09:59:11:WU01:FS00:0xa7:Completed 875000 out of 2500000 steps (35%)
10:03:09:WU01:FS00:0xa7:Completed 900000 out of 2500000 steps (36%)
10:04:15:84:127.0.0.1:New Web session
10:04:46:Saving configuration to config.xml
10:04:46:<config>
10:04:46:  <!-- Folding Slot Configuration -->
10:04:46:  <cause v='COVID_19'/>
10:04:46:
10:04:46:  <!-- Network -->
10:04:46:  <proxy v=':8080'/>
10:04:46:
10:04:46:  <!-- Slot Control -->
10:04:46:  <power v='full'/>
10:04:46:
10:04:46:  <!-- User Information -->
10:04:46:  <passkey v='*****'/>
10:04:46:  <user v='Hopbackguy'/>
10:04:46:
10:04:46:  <!-- Folding Slots -->
10:04:46:  <slot id='0' type='CPU'>
10:04:46:    <cpus v='2'/>
10:04:46:  </slot>
10:04:46:</config>
10:04:46:FS00:Shutting core down
10:04:46:WU01:FS00:0xa7:Caught signal SIGINT(2) on PID 39066
10:04:46:WU01:FS00:0xa7:Exiting, please wait. . .
10:04:46:WU01:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
10:04:47:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
10:04:47:WU01:FS00:Starting
10:04:47:WARNING:WU01:FS00:Changed SMP threads from 1 to 2 this can cause some work units to fail
10:04:47:WARNING:WU01:FS00:AS lowered CPUs from 2 to 1
10:04:47:WU01:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper /Users/Mike/cores/cores.foldingathome.org/v7/osx/64bit/avx/Core_a7.fah/FahCore_a7 -dir 01 -suffix 01 -version 706 -lifeline 1067 -checkpoint 15 -np 1
10:04:47:WU01:FS00:Started FahCore on PID 50916
10:04:47:WU01:FS00:Core PID:50918
10:04:47:WU01:FS00:FahCore 0xa7 started
10:04:47:WU01:FS00:0xa7:*********************** Log Started 2020-04-19T10:04:47Z ***********************
10:04:47:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
10:04:47:WU01:FS00:0xa7:       Type: 0xa7
10:04:47:WU01:FS00:0xa7:       Core: Gromacs
10:04:47:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 50916 -checkpoint 15 -np
10:04:47:WU01:FS00:0xa7:             1
10:04:47:WU01:FS00:0xa7:************************************ CBang *************************************
10:04:47:WU01:FS00:0xa7:       Date: Oct 26 2019
10:04:47:WU01:FS00:0xa7:       Time: 03:00:53
10:04:47:WU01:FS00:0xa7:   Revision: 3b1c887e9f30a608262e0d62833b273e843f7c1b
10:04:47:WU01:FS00:0xa7:     Branch: master
10:04:47:WU01:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
10:04:47:WU01:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
10:04:47:WU01:FS00:0xa7:             -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
10:04:47:WU01:FS00:0xa7:   Platform: darwin 19.0.0
10:04:47:WU01:FS00:0xa7:       Bits: 64
10:04:47:WU01:FS00:0xa7:       Mode: Release
10:04:47:WU01:FS00:0xa7:************************************ System ************************************
10:04:47:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-4570 CPU @ 3.20GHz
10:04:47:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
10:04:47:WU01:FS00:0xa7:       CPUs: 4
10:04:47:WU01:FS00:0xa7:     Memory: 8.00GiB
10:04:47:WU01:FS00:0xa7:Free Memory: 554.46MiB
10:04:47:WU01:FS00:0xa7:    Threads: POSIX_THREADS
10:04:47:WU01:FS00:0xa7: OS Version: 10.14
10:04:47:WU01:FS00:0xa7:Has Battery: false
10:04:47:WU01:FS00:0xa7: On Battery: false
10:04:47:WU01:FS00:0xa7: UTC Offset: 1
10:04:47:WU01:FS00:0xa7:        PID: 50918
10:04:47:WU01:FS00:0xa7:        CWD: /Users/Mike/work
10:04:47:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
10:04:47:WU01:FS00:0xa7:    Version: 0.0.18
10:04:47:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:04:47:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
10:04:47:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
10:04:47:WU01:FS00:0xa7:       Time: 03:06:33
10:04:47:WU01:FS00:0xa7:   Revision: fcc08f30b8997509aaba3a213354c363f474e056
10:04:47:WU01:FS00:0xa7:************************************ Build *************************************
10:04:47:WU01:FS00:0xa7:       SIMD: avx_256
10:04:47:WU01:FS00:0xa7:********************************************************************************
10:04:47:WU01:FS00:0xa7:Project: 14641 (Run 1068, Clone 0, Gen 6)
10:04:47:WU01:FS00:0xa7:Unit: 0x000000089bf7a4d55e8b9fa4fd1e82ca
10:04:47:WU01:FS00:0xa7:Digital signatures verified
10:04:47:WU01:FS00:0xa7:Calling: mdrun -s frame6.tpr -o frame6.trr -cpi state.cpt -cpt 15 -nt 1
10:04:47:WU01:FS00:0xa7:Steps: first=0 total=2500000
10:04:47:WU01:FS00:0xa7:Completed 910454 out of 2500000 steps (36%)
10:05:17:Saving configuration to config.xml
10:05:17:<config>
10:05:17:  <!-- Folding Slot Configuration -->
10:05:17:  <cause v='COVID_19'/>
10:05:17:
10:05:17:  <!-- Network -->
10:05:17:  <proxy v=':8080'/>
10:05:17:
10:05:17:  <!-- Slot Control -->
10:05:17:  <power v='full'/>
10:05:17:
10:05:17:  <!-- User Information -->
10:05:17:  <passkey v='*****'/>
10:05:17:  <user v='Hopbackguy'/>
10:05:17:
10:05:17:  <!-- Folding Slots -->
10:05:17:  <slot id='0' type='CPU'>
10:05:17:    <cpus v='2'/>
10:05:17:  </slot>
10:05:17:</config>
10:07:04:WU01:FS00:0xa7:Completed 925000 out of 2500000 steps (37%)
10:10:58:WU01:FS00:0xa7:Completed 950000 out of 2500000 steps (38%)
10:14:54:WU01:FS00:0xa7:Completed 975000 out of 2500000 steps (39%)
10:18:51:WU01:FS00:0xa7:Completed 1000000 out of 2500000 steps (40%)
10:22:45:WU01:FS00:0xa7:Completed 1025000 out of 2500000 steps (41%)
10:26:39:WU01:FS00:0xa7:Completed 1050000 out of 2500000 steps (42%)
10:30:32:WU01:FS00:0xa7:Completed 1075000 out of 2500000 steps (43%)
10:34:28:WU01:FS00:0xa7:Completed 1100000 out of 2500000 steps (44%)
10:38:25:WU01:FS00:0xa7:Completed 1125000 out of 2500000 steps (45%)
10:42:21:WU01:FS00:0xa7:Completed 1150000 out of 2500000 steps (46%)
10:46:18:WU01:FS00:0xa7:Completed 1175000 out of 2500000 steps (47%)
10:50:15:WU01:FS00:0xa7:Completed 1200000 out of 2500000 steps (48%)
10:54:12:WU01:FS00:0xa7:Completed 1225000 out of 2500000 steps (49%)
10:58:06:WU01:FS00:0xa7:Completed 1250000 out of 2500000 steps (50%)
11:02:01:WU01:FS00:0xa7:Completed 1275000 out of 2500000 steps (51%)
...etc
Reason: added Code tags to log
Hopbackguy
Joe_H wrote:The default paths running FAHClient from the command line places things non-default locations for the WUs, folding cores, work files, and the like. The correct paths can be specified on on the command line though.
I'm not running continuous scans with MWB , just scheduled ones twice a day, at .25am and 5.45pm. By Console log, do you mean the MacOS console log? I'll take a look at the MacOS logs.
Hopbackguy
OK, found something weird. At present, as I said yesterday, FAHClient is running ok via an open terminal window. But in my MacOS system log, I see these errors repeated every 10 seconds:
Apr 19 15:30:23 UNKNOWN com.apple.xpc.launchd[1] (org.foldingathome.fahclient[74569]): Could not find and/or execute program specified by service: 2: No such file or directory: /usr/local/bin/FAHClient
Apr 19 15:30:23 UNKNOWN com.apple.xpc.launchd[1] (org.foldingathome.fahclient[74569]): Service setup event to handle failure and will not launch until it fires.
Apr 19 15:30:23 UNKNOWN com.apple.xpc.launchd[1] (org.foldingathome.fahclient[74569]): Service exited with abnormal code: 78
Apr 19 15:30:23 UNKNOWN com.apple.xpc.launchd[1] (org.foldingathome.fahclient[74570]): Could not find and/or execute program specified by service: 2: No such file or directory: /usr/local/bin/FAHClient
Apr 19 15:30:23 UNKNOWN com.apple.xpc.launchd[1] (org.foldingathome.fahclient[74570]): Service setup event to handle failure and will not launch until it fires.
Apr 19 15:30:23 UNKNOWN com.apple.xpc.launchd[1] (org.foldingathome.fahclient[74570]): Service exited with abnormal code: 78
Apr 19 15:30:23 UNKNOWN com.apple.xpc.launchd[1] (org.foldingathome.fahclient[74571]): Could not find and/or execute program specified by service: 2: No such file or directory: /usr/local/bin/FAHClient
Apr 19 15:30:23 UNKNOWN com.apple.xpc.launchd[1] (org.foldingathome.fahclient[74571]): Service setup event to handle failure and will not launch until it fires.
Apr 19 15:30:23 UNKNOWN com.apple.xpc.launchd[1] (org.foldingathome.fahclient[74571]): Service exited with abnormal code: 78
Apr 19 15:30:23 UNKNOWN com.apple.xpc.launchd[1] (org.foldingathome.fahclient[74572]): Could not find and/or execute program specified by service: 2: No such file or directory: /usr/local/bin/FAHClient
Apr 19 15:30:23 UNKNOWN com.apple.xpc.launchd[1] (org.foldingathome.fahclient[74572]): Service setup event to handle failure and will not launch until it fires.
Apr 19 15:30:23 UNKNOWN com.apple.xpc.launchd[1] (org.foldingathome.fahclient[74572]): Service exited with abnormal code: 78
Apr 19 15:30:23 UNKNOWN com.apple.xpc.launchd[1] (org.foldingathome.fahclient): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Odd, because /usr/local/bin/FAHClient is exactly what I'm running in the terminal window. Any idea what this means?
Could you list the the owner and permissions listed for both the directory and the files located there by doing the following in a terminal window:
ls -l /usr/local
ls -l /usr/local/bin
Hopbackguy
Joe_H wrote:Could you list the the owner and permissions listed for both the directory and the files located there by doing the following in a terminal window:
ls -l /usr/local
Here's the output:
MIKES-IMAC:~ Mike$ ls -l /usr/local
total 0
drwx------ 26 504 wheel 832 17 Apr 18:03 bin
drwxr-xr-x 3 root wheel 96 3 May 2019 include
drwxr-xr-x 9 root wheel 288 2 Mar 18:07 lib
drwxr-xr-x 3 root wheel 96 26 Sep 2018 remotedesktop
MIKES-IMAC:~ Mike$ sudo ls -l /usr/local/bin
Password:
total 22008
-rwxr-xr-x 1 root wheel 9666080 15 Apr 22:45 FAHClient
-rwxr-xr-x 1 root wheel 1548032 15 Apr 22:45 FAHCoreWrapper
-rwxr-xr-x 1 root wheel 80 20 Feb 18:25 VBoxAutostart
-rwxr-xr-x 1 root wheel 82 20 Feb 18:25 VBoxBalloonCtrl
-rwxr-xr-x 1 root wheel 80 20 Feb 18:25 VBoxBugReport
-rwxr-xr-x 1 root wheel 77 20 Feb 18:25 VBoxDTrace
-rwxr-xr-x 1 root wheel 79 20 Feb 18:25 VBoxHeadless
-rwxr-xr-x 1 root wheel 77 20 Feb 18:25 VBoxManage
-rwxr-xr-x 1 root wheel 79 20 Feb 18:25 VBoxVRDP
-rwxr-xr-x 1 root wheel 77 20 Feb 18:25 VirtualBox
-rwxr-xr-x 1 root wheel 115 20 Feb 18:25 VirtualBoxVM
lrwxr-xr-x 1 root wheel 11 11 Jul 2014 capinfos -> ./wireshark
lrwxr-xr-x 1 root wheel 11 11 Jul 2014 dftest -> ./wireshark
lrwxr-xr-x 1 root wheel 11 11 Jul 2014 dumpcap -> ./wireshark
lrwxr-xr-x 1 root wheel 11 11 Jul 2014 editcap -> ./wireshark
lrwxr-xr-x 1 root wheel 11 11 Jul 2014 mergecap -> ./wireshark
lrwxr-xr-x 1 root wheel 11 11 Jul 2014 randpkt -> ./wireshark
lrwxr-xr-x 1 root wheel 11 11 Jul 2014 rawshark -> ./wireshark
lrwxr-xr-x 1 root wheel 11 11 Jul 2014 text2pcap -> ./wireshark
lrwxr-xr-x 1 root wheel 11 11 Jul 2014 tshark -> ./wireshark
-rwxr-xr-x 1 root wheel 75 20 Feb 18:25 vbox-img
-rwxr-xr-x 1 root wheel 80 20 Feb 18:25 vboximg-mount
-rwxr-xr-x 1 root wheel 77 20 Feb 18:25 vboxwebsrv
-rwxr-xr-x 1 504 staff 431 14 Jan 2014 wireshark
MIKES-IMAC:~ Mike$
The ownership of the directory looks wrong to me, I will contact the developer who's assists with the OS X build of the client on how best to proceed.
Okay, heard back on this. Ownership of the directory /usr/local/bin should be root, not '504', launchd will refuse to run anything there otherwise asa security hole. Probable source for this happening was the installer for wireshark.
You will need to change the ownership:
sudo chown root /usr/local/bin
Finish anything you are running from the command line, it will be in the wrong place and possibly with the wrong ownership. How soon launchd will try again to start FAHClient in the background will depend, as far as I recall two instances of FAHClient will not run simultaneously.
Hopbackguy
Joe_H wrote:Okay, heard back on this. Ownership of the directory /usr/local/bin should be root, not '504', launchd will refuse to run anything there otherwise asa security hole. Probable source for this happening was the installer for wireshark.
Many thanks. I will change the ownership. I did wonder, when I looked at that directory in Finder, why it would be different to the others - root is the obvious owner. I will do the following:
Finish the current WU from th command line
Change the ownership of the directory
See if FAHClient starts and configure it anew - because presumably it will find no files in /Library/Application Support/FAHClient
Mike
Hopbackguy
Still no luck. I did the following:
- Stopped the client running in the terminal window
- Changed the ownership of /usr/local/bin to root
- Waited - Activity monitor didn't show any folding task starting. The web client page in Safari wouldn't connect, neither would FAHControl
- I rebooted
- The same - still nothing.
- I ran the uninstaller package in /Library/Applications/FAHClient and it uninstalled
- I re-installed it. Seemed to install fine.
- Nothing has changed, I still can't configure it and activity monitor doesn't show any folding related tasks. The system log still shows the same error.
Key info below:
Last login: Mon Apr 20 11:07:57 on console
Mikes-iMac:~ Mike$ sudo ls -l /usr/local
Password:
total 0
-rw-r--r-- 1 root wheel 0 25 Mar 12:13 .com.apple.installer.keep
drwx------ 26 root wheel 832 20 Apr 11:13 bin
Mikes-iMac:~ Mike$ sudo ls -l /usr/local/bin
total 22008
Apr 20 11:22:55 Mikes-iMac com.apple.xpc.launchd[1] (org.foldingathome.fahclient[2760]): Could not find and/or execute program specified by service: 2: No such file or directory: /usr/local/bin/FAHClient
Apr 20 11:22:55 Mikes-iMac com.apple.xpc.launchd[1] (org.foldingathome.fahclient[2760]): Service setup event to handle failure and will not launch until it fires.
Apr 20 11:22:55 Mikes-iMac com.apple.xpc.launchd[1] (org.foldingathome.fahclient[2760]): Service exited with abnormal code: 78
Apr 20 11:22:55 Mikes-iMac com.apple.xpc.launchd[1] (org.foldingathome.fahclient): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Getting in the right direction, the ownership on the directory is now right and the permissions need fixing up. Your system shows the following:
It should be:
drwxr-xr-x 4 root wheel 136 Apr 18 02:26 bin
Do the following to allow execute access to the user the FAHClient process will be running under:
sudo chmod g+rx,o+x /usr/local/bin
Hopbackguy
Joe_H wrote:Getting in the right direction, the ownership on the directory is now right and the permissions need fixing up. Your system shows the following:
It should be:
Thanks, I'll do that and see if it fixes it - but why would the permissions be wrong? If it's the Wireshark installation, that was six years and 4 releases of MacOS ago! Can the permissions really have been wrong for 6 years - with no other apparent problems?
I'll update here when I've tried it. Really appreciate all the help..
The directory /usr/local/bin is generally reserved for installs of additional software outside the standard items from the OS and those installed by Apple. There are standard policies for using it, Wireshark violated those by creating the directory only for its own usage.
This probably only became an issue with the install of the F@h client. Current security requirements, not sure which version of the OS they start with, keeps the launchd process from starting up background processes like FAHClient from a directory not owned by the system. In addition, the script supplied to have launchd start up that background process runs it under a restricted user account 'nobody' that has minimal privileges. So that user needs execute and lookup access to the directory and the FAHClient executable under the 'o' or other access permissions.
