GPU WU for 14415 causes crashes
ky0ko
Post by ky0ko »
I've been folding successfully with this machine for several weeks. This morning I woke up to a garbled display and a no longer running FAHClient. I am running a Ryzen 2600X with an RX Vega 56 both at stock clocks on Arch Linux, using the AMDGPU-PRO OpenCL driver (packaged as opencl-amd in the arch repositories), with kernel 5.4.31. Within seconds after starting FAHClient, the gpu crashes and my displays show only garbage, and FAHClient is killed.
Is there anything I can do to troubleshoot this? Should I just dump the WU?
FAH log
*********************** Log Started 2020-04-11T22:03:17Z ***********************
22:03:17:************************* Folding@home Client *************************
22:03:17:        Website: https://foldingathome.org/
22:03:17:      Copyright: (c) 2009-2018 foldingathome.org
22:03:17:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:03:17:           Args:
22:03:17:         Config: /home/sanae/config.xml
22:03:17:******************************** Build ********************************
22:03:17:        Version: 7.5.1
22:03:17:           Date: May 11 2018
22:03:17:           Time: 19:59:04
22:03:17:     Repository: Git
22:03:17:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
22:03:17:         Branch: master
22:03:17:       Compiler: GNU 6.3.0 20170516
22:03:17:        Options: -std=gnu++98 -O3 -funroll-loops
22:03:17:       Platform: linux2 4.14.0-3-amd64
22:03:17:           Bits: 64
22:03:17:           Mode: Release
22:03:17:******************************* System ********************************
22:03:17:            CPU: AMD Ryzen 5 2600X Six-Core Processor
22:03:17:         CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
22:03:17:           CPUs: 12
22:03:17:         Memory: 15.57GiB
22:03:17:    Free Memory: 5.17GiB
22:03:17:        Threads: POSIX_THREADS
22:03:17:     OS Version: 5.4
22:03:17:    Has Battery: false
22:03:17:     On Battery: false
22:03:17:     UTC Offset: -7
22:03:17:            PID: 12969
22:03:17:            CWD: /home/sanae
22:03:17:             OS: Linux 5.4.31-0-lts x86_64
22:03:17:        OS Arch: AMD64
22:03:17:           GPUs: 1
22:03:17:          GPU 0: Bus:11 Slot:0 Func:0 AMD:5 Vega 10 XL/XT [Radeon RX Vega 56/64]
22:03:17:           CUDA: Not detected: Failed to open dynamic library 'libcuda.so':
22:03:17:                 libcuda.so: cannot open shared object file: No such file or
22:03:17:                 directory
22:03:17:OpenCL Device 0: Platform:0 Device:0 Bus:11 Slot:0 Compute:2.0 Driver:3004.6
22:03:17:***********************************************************************
22:03:17:<config>
22:03:17:  <!-- Network -->
22:03:17:  <proxy v=':8080'/>
22:03:17:
22:03:17:  <!-- Slot Control -->
22:03:17:  <power v='full'/>
22:03:17:
22:03:17:  <!-- User Information -->
22:03:17:  <passkey v='********************************'/>
22:03:17:  <team v='236565'/>
22:03:17:  <user v='ky0ko'/>
22:03:17:
22:03:17:  <!-- Folding Slots -->
22:03:17:  <slot id='0' type='CPU'/>
22:03:17:  <slot id='1' type='GPU'/>
22:03:17:</config>
22:03:17:Trying to access database...
22:03:17:Successfully acquired database lock
22:03:17:Enabled folding slot 00: READY cpu:11
22:03:17:Enabled folding slot 01: READY gpu:0:Vega 10 XL/XT [Radeon RX Vega 56/64]
22:03:17:WU00:FS01:Starting
22:03:17:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /home/sanae/cores/cores.foldingathome.org/v7/lin/64bit/Core_22.fah/FahCore_22 -dir 00 -suffix 01 -version 705 -lifeline 12969 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
22:03:17:WU00:FS01:Started FahCore on PID 12993
22:03:17:WU00:FS01:Core PID:12997
22:03:17:WU00:FS01:FahCore 0x22 started
22:03:17:WU01:FS00:Starting
22:03:17:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /home/sanae/cores/cores.foldingathome.org/v7/lin/64bit/avx/Core_a7.fah/FahCore_a7 -dir 01 -suffix 01 -version 705 -lifeline 12969 -checkpoint 15 -np 11
22:03:17:WU01:FS00:Started FahCore on PID 13000
22:03:17:WU01:FS00:Core PID:13004
22:03:17:WU01:FS00:FahCore 0xa7 started
22:03:17:WU00:FS01:0x22:*********************** Log Started 2020-04-11T22:03:17Z ***********************
22:03:17:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
22:03:17:WU00:FS01:0x22:       Type: 0x22
22:03:17:WU00:FS01:0x22:       Core: Core22
22:03:17:WU00:FS01:0x22:    Website: https://foldingathome.org/
22:03:17:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
22:03:17:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
22:03:17:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
22:03:17:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 705 -lifeline 12993 -checkpoint 15
22:03:17:WU00:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
22:03:17:WU00:FS01:0x22:     Config: <none>
22:03:17:WU00:FS01:0x22:************************************ Build *************************************
22:03:17:WU00:FS01:0x22:    Version: 0.0.2
22:03:17:WU00:FS01:0x22:       Date: Dec 6 2019
22:03:17:WU00:FS01:0x22:       Time: 21:20:17
22:03:17:WU00:FS01:0x22: Repository: Git
22:03:17:WU00:FS01:0x22:   Revision: f87d92b58abdf7e6bf2e173cfbc4dc3e837c7042
22:03:17:WU00:FS01:0x22:     Branch: core22
22:03:17:WU00:FS01:0x22:   Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
22:03:17:WU00:FS01:0x22:    Options: -std=gnu++98 -O3 -funroll-loops
22:03:17:WU00:FS01:0x22:   Platform: linux2 4.9.87-linuxkit-aufs
22:03:17:WU00:FS01:0x22:       Bits: 64
22:03:17:WU00:FS01:0x22:       Mode: Release
22:03:17:WU00:FS01:0x22:************************************ System ************************************
22:03:17:WU00:FS01:0x22:        CPU: AMD Ryzen 5 2600X Six-Core Processor
22:03:17:WU00:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
22:03:17:WU00:FS01:0x22:       CPUs: 12
22:03:17:WU00:FS01:0x22:     Memory: 15.57GiB
22:03:17:WU00:FS01:0x22:Free Memory: 5.11GiB
22:03:17:WU00:FS01:0x22:    Threads: POSIX_THREADS
22:03:17:WU00:FS01:0x22: OS Version: 5.4
22:03:17:WU00:FS01:0x22:Has Battery: false
22:03:17:WU00:FS01:0x22: On Battery: false
22:03:17:WU00:FS01:0x22: UTC Offset: -7
22:03:17:WU00:FS01:0x22:        PID: 12997
22:03:17:WU00:FS01:0x22:        CWD: /home/sanae/work
22:03:17:WU00:FS01:0x22:         OS: Linux 5.4.31-0-lts x86_64
22:03:17:WU00:FS01:0x22:    OS Arch: AMD64
22:03:17:WU00:FS01:0x22:********************************************************************************
22:03:17:WU00:FS01:0x22:Project: 14415 (Run 0, Clone 719, Gen 6)
22:03:17:WU00:FS01:0x22:Unit: 0x000000080d5262775e839e5ce79f8bf0
22:03:17:WU00:FS01:0x22:Reading tar file core.xml
22:03:17:WU00:FS01:0x22:Reading tar file integrator.xml
22:03:17:WU00:FS01:0x22:Reading tar file state.xml
22:03:17:WU00:FS01:0x22:Reading tar file system.xml
22:03:17:WU01:FS00:0xa7:*********************** Log Started 2020-04-11T22:03:17Z ***********************
22:03:17:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
22:03:17:WU01:FS00:0xa7:       Type: 0xa7
22:03:17:WU01:FS00:0xa7:       Core: Gromacs
22:03:17:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 13000 -checkpoint 15 -np
22:03:17:WU01:FS00:0xa7:             11
22:03:17:WU01:FS00:0xa7:************************************ CBang *************************************
22:03:17:WU01:FS00:0xa7:       Date: Nov 5 2019
22:03:17:WU01:FS00:0xa7:       Time: 06:06:57
22:03:17:WU01:FS00:0xa7:   Revision: 46c96f1aa8419571d83f3e63f9c99a0d602f6da9
22:03:17:WU01:FS00:0xa7:     Branch: master
22:03:17:WU01:FS00:0xa7:   Compiler: GNU 8.3.0
22:03:17:WU01:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -fno-pie -fPIC
22:03:17:WU01:FS00:0xa7:   Platform: linux2 4.19.0-5-amd64
22:03:17:WU01:FS00:0xa7:       Bits: 64
22:03:17:WU01:FS00:0xa7:       Mode: Release
22:03:17:WU01:FS00:0xa7:************************************ System ************************************
22:03:17:WU01:FS00:0xa7:        CPU: AMD Ryzen 5 2600X Six-Core Processor
22:03:17:WU01:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
22:03:17:WU01:FS00:0xa7:       CPUs: 12
22:03:17:WU01:FS00:0xa7:     Memory: 15.57GiB
22:03:17:WU01:FS00:0xa7:Free Memory: 5.07GiB
22:03:17:WU01:FS00:0xa7:    Threads: POSIX_THREADS
22:03:17:WU01:FS00:0xa7: OS Version: 5.4
22:03:17:WU01:FS00:0xa7:Has Battery: false
22:03:17:WU01:FS00:0xa7: On Battery: false
22:03:17:WU01:FS00:0xa7: UTC Offset: -7
22:03:17:WU01:FS00:0xa7:        PID: 13004
22:03:17:WU01:FS00:0xa7:        CWD: /home/sanae/work
22:03:17:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
22:03:17:WU01:FS00:0xa7:    Version: 0.0.18
22:03:17:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:03:17:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
22:03:17:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
22:03:17:WU01:FS00:0xa7:       Time: 06:13:26
22:03:17:WU01:FS00:0xa7:   Revision: 490c9aa2957b725af319379424d5c5cb36efb656
22:03:17:WU01:FS00:0xa7:************************************ Build *************************************
22:03:17:WU01:FS00:0xa7:       SIMD: avx_256
22:03:17:WU01:FS00:0xa7:********************************************************************************
22:03:17:WU01:FS00:0xa7:Project: 14625 (Run 1271, Clone 4, Gen 5)
22:03:17:WU01:FS00:0xa7:Unit: 0x000000059bf7a4d65e88df0038db82b5
22:03:17:WU01:FS00:0xa7:Digital signatures verified
22:03:17:WU01:FS00:0xa7:Reducing thread count from 11 to 10 to avoid domain decomposition by a prime number > 3
22:03:17:WU01:FS00:0xa7:Calling: mdrun -s frame5.tpr -o frame5.trr -cpi state.cpt -cpt 15 -nt 10
22:03:17:WU01:FS00:0xa7:Steps: first=0 total=250000
22:03:18:WU00:FS01:0x22:Digital signatures verified
22:03:18:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
22:03:18:WU00:FS01:0x22:Version 0.0.2
22:03:18:WU01:FS00:0xa7:Completed 30119 out of 250000 steps (12%)
22:04:11:WU01:FS00:0xa7:Completed 32500 out of 250000 steps (13%)
22:04:24:Caught signal SIGTERM(15) on PID 12969
22:04:24:Exiting, please wait. . .
22:04:24:WU00:FS01:0x22:Caught signal SIGTERM(15) on PID 12997
22:04:24:WU00:FS01:0x22:Exiting, please wait. . .
22:04:24:WU01:FS00:0xa7:Caught signal SIGTERM(15) on PID 13004
22:04:24:WU01:FS00:0xa7:Exiting, please wait. . .
22:04:24:WU01:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
Core log
       Type: 0x22
       Core: Core22
     Config: <none>
    Version: 0.0.2
       Date: Dec 6 2019
       Time: 21:20:17
 Repository: Git
     Branch: core22
       Bits: 64
       Mode: Release
       CPUs: 12
     Memory: 15.57GiB
 OS Version: 5.4
Has Battery: false
 On Battery: false
 UTC Offset: -7
        PID: 12997
    OS Arch: AMD64
Version 0.0.2
WARNING:Next signal will force exit
clinfo output
sanae@akarui ~/fah> clinfo
  Platform Name                                   AMD Accelerated Parallel Processing
  Platform Vendor                                 Advanced Micro Devices, Inc.
  Platform Version                                OpenCL 2.1 AMD-APP (3004.6)
  Platform Extensions                             cl_khr_icd cl_amd_event_callback cl_amd_offline_devices
  Platform Host timer resolution                  1ns
  Platform Extensions function suffix             AMD
  Device Name                                     gfx900
  Device Vendor                                   Advanced Micro Devices, Inc.
  Device Version                                  OpenCL 2.0 AMD-APP (3004.6)
  Driver Version                                  3004.6 (PAL,HSAIL)
  Device OpenCL C Version                         OpenCL C 2.0
  Device Board Name (AMD)                         Radeon RX Vega
  Device Topology (AMD)                           PCI-E, 0b:00.0
  Max compute units                               56
  SIMD per compute unit (AMD)                     4
  SIMD width (AMD)                                16
  SIMD instruction width (AMD)                    1
  Max clock frequency                             1590MHz
  Graphics IP (AMD)                               9.0
    Max number of sub-devices                     56
    Supported affinity domains                    (n/a)
  Max work item sizes                             1024x1024x1024
  Preferred work group size (AMD)                 256
  Max work group size (AMD)                       1024
  Preferred work group size multiple              64
  Wavefront width (AMD)                           64
    char                                                 4 / 4
    short                                                2 / 2
    half                                                 1 / 1        (cl_khr_fp16)
  Half-precision Floating-point support           (cl_khr_fp16)
    Denormals                                     No
    Infinity and NANs                             No
    Round to nearest                              No
    Round to zero                                 No
    Round to infinity                             No
    IEEE754-2008 fused multiply-add               No
    Denormals                                     No
  Global memory size                              8573157376 (7.984GiB)
  Global free memory (AMD)                        8306688 (7.922GiB)
  Global memory channels (AMD)                    64
  Global memory banks per channel (AMD)           4
  Global memory bank width (AMD)                  256 bytes
  Max memory allocation                           4244635648 (3.953GiB)
  Shared Virtual Memory (SVM) capabilities        (core)
    Coarse-grained buffer sharing                 Yes
    Fine-grained buffer sharing                   Yes
    Fine-grained system sharing                   No
    Atomics                                       No
  Alignment of base address                       2048 bits (256 bytes)
  Preferred alignment for atomics
    SVM                                           0 bytes
    Global                                        0 bytes
    Local                                         0 bytes
  Max size for global variable                    3820172032 (3.558GiB)
  Preferred total size of global vars             8573157376 (7.984GiB)
  Global Memory cache size                        16384 (16KiB)
  Global Memory cache line size                   64 bytes
    Max number of samplers per kernel             16
    Max size for 1D images from buffer            134217728 pixels
    Max 1D or 2D image array size                 2048 images
    Base address alignment for 2D image buffers   256 bytes
    Pitch alignment for 2D image buffers          256 pixels
    Max 2D image size                             16384x16384 pixels
    Max 3D image size                             2048x2048x2048 pixels
    Max number of read image args                 128
    Max number of write image args                64
    Max number of read/write image args           64
  Max number of pipe args                         16
  Max active pipe reservations                    16
  Max pipe packet size                            4244635648 (3.953GiB)
  Local memory size                               65536 (64KiB)
  Local memory syze per CU (AMD)                  65536 (64KiB)
  Local memory banks (AMD)                        32
  Max constant buffer size                        4244635648 (3.953GiB)
  Preferred constant buffer size (AMD)            16384 (16KiB)
  Queue properties (on host)
  Queue properties (on device)
    Out-of-order execution                        Yes
    Preferred size                                262144 (256KiB)
    Max size                                      8388608 (8MiB)
  Max queues on device                            1
  Max events on device                            1024
  Number of P2P devices (AMD)                     0
  P2P devices (AMD)                               <printDeviceInfo:147: get number of CL_DEVICE_P2P_DEVICES_AMD : error -30>
  Profiling timer offset since Epoch (AMD)        1586642702235317192ns (Sat Apr 11 15:05:02 2020)
  Execution capabilities
    Thread trace supported (AMD)                  Yes
    Number of async queues (AMD)                  4
    Max real-time compute queues (AMD)            0
    Max real-time compute units (AMD)             0
  printf() buffer size                            4194304 (4MiB)
  Built-in kernels                                (n/a)
  Device Extensions                               cl_khr_fp64 cl_amd_fp64 cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_3d_image_writes cl_khr_byte_addressable_store cl_khr_fp16 cl_khr_gl_sharing cl_khr_gl_depth_images cl_amd_device_attribute_query cl_amd_vec3 cl_amd_printf cl_amd_media_ops cl_amd_media_ops2 cl_amd_popcnt cl_khr_image2d_from_buffer cl_khr_subgroups cl_khr_gl_event cl_khr_depth_images cl_khr_mipmap_image cl_khr_mipmap_image_writes cl_amd_copy_buffer_p2p
NULL platform behavior
  clGetPlatformInfo(NULL, CL_PLATFORM_NAME, ...)  AMD Accelerated Parallel Processing
  clGetDeviceIDs(NULL, CL_DEVICE_TYPE_ALL, ...)   Success [AMD]
  clCreateContext(NULL, ...) [default]            Success [AMD]
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_DEFAULT)  Success (1)
    Device Name                                   gfx900
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_GPU)  Success (1)
    Device Name                                   gfx900
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_CUSTOM)  No devices found in platform
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_ALL)  Success (1)
    Device Name                                   gfx900
ICD loader properties
  ICD loader Name                                 OpenCL ICD Loader
  ICD loader Vendor                               OCL Icd free software
  ICD loader Version                              2.2.12
  ICD loader Profile                              OpenCL 2.2
Re: GPU WU for 14415 causes crashes
I see no one has responded, if you haven't already, dump the WU. The WU itself was not bad, someone else has run it successfully. There may just be some aspect of the WU that is not working with the drivers and software setup on your system.
One question, are the interrupts to the GPU core 22 at the end of the log from something you did or from the system?
ky0ko
Post by ky0ko »
They are not from something I did. When the GPU crashes, the process gets killed, apparently regardless of how it was run. I normally run FAHClient manually in my desktop environment, but I also tried on a VT, through an SSH session, and as a system service, all with the same results.
