Folding stopped working on Linux
minta
Post by minta »
Could this have been due to putting the computer into suspend and then the folding not starting again? It has been sitting doing nothing for a couple of days but did not know what to do to get it started again.
I see this in the log:
08:29:58:WU00:FS00:Starting
08:29:58:WU00:FS00:Removing old file './work/00/logfile_01-20200408-075757.txt'
08:29:58:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 22285 -checkpoint 15
08:29:58:WU00:FS00:Started FahCore on PID 22654
08:29:58:WU00:FS00:Core PID:22658
08:29:58:WU00:FS00:FahCore 0xa7 started
08:29:58:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
What does this interrupt code number mean?
Re: Folding stopped working on Linux
Welcome to the F@H Forum minta,
Can you please post your log file. Ensure that you have copied the System configuration which is present at the start of the log file (viewtopic.php?f=106&t=26036). That will provide a bit more information as to how your system is setup.
That message can be issued when you have paused the CPU slot or when you restarted/shutdown your system.
minta
Post by minta »
Could not put all of it here due to character limit on the forum but this is first part up to 9 am this morning.
08:09:58:WU00:FS00:0xa7:ERROR:Guru Meditation #65fbf0429796a9cd.cd9117ad6199191 (1192440.1192440) '00/01/state.cpt'
08:09:58:WU00:FS00:0xa7:WARNING:Unexpected exit() call
08:09:58:WU00:FS00:0xa7:WARNING:Unexpected exit from science code
08:09:58:WU00:FS00:0xa7:Saving result file ../logfile_01.txt
08:09:58:WU00:FS00:0xa7:Saving result file frame17.edr
08:09:58:WU00:FS00:0xa7:Saving result file frame17.trr
08:09:58:WU00:FS00:0xa7:Saving result file frame17.xtc
08:09:58:WU00:FS00:0xa7:Saving result file md.log
08:09:58:WU00:FS00:0xa7:Saving result file science.log
08:09:58:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:10:57:WU00:FS00:Starting
08:10:57:WU00:FS00:Removing old file './work/00/logfile_01-20200408-005604.txt'
08:10:57:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 22285 -checkpoint 15
08:10:57:WU00:FS00:Started FahCore on PID 21932
08:10:57:WU00:FS00:Core PID:21936
08:10:57:WU00:FS00:FahCore 0xa7 started
08:10:58:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:11:57:WU00:FS00:Starting
08:11:57:WU00:FS00:Removing old file './work/00/logfile_01-20200408-005704.txt'
08:11:57:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 22285 -checkpoint 15
08:11:57:WU00:FS00:Started FahCore on PID 21961
08:11:57:WU00:FS00:Core PID:21965
08:11:57:WU00:FS00:FahCore 0xa7 started
08:11:58:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:12:57:WU00:FS00:Starting
08:12:57:WU00:FS00:Removing old file './work/00/logfile_01-20200408-005804.txt'
08:12:57:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 22285 -checkpoint 15
08:12:57:WU00:FS00:Started FahCore on PID 21984
08:12:57:WU00:FS00:Core PID:21988
08:12:57:WU00:FS00:FahCore 0xa7 started
08:12:58:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:13:57:WU00:FS00:Starting
08:13:57:WU00:FS00:Removing old file './work/00/logfile_01-20200408-005904.txt'
08:13:57:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 22285 -checkpoint 15
08:13:57:WU00:FS00:Started FahCore on PID 22031
08:13:57:WU00:FS00:Core PID:22035
08:13:57:WU00:FS00:FahCore 0xa7 started
08:13:58:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:14:57:WU00:FS00:Starting
08:14:57:WU00:FS00:Removing old file './work/00/logfile_01-20200408-010004.txt'
08:14:57:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 22285 -checkpoint 15
08:14:57:WU00:FS00:Started FahCore on PID 22074
08:14:57:WU00:FS00:Core PID:22078
08:14:57:WU00:FS00:FahCore 0xa7 started
08:14:58:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:15:57:WU00:FS00:Starting
08:15:57:WU00:FS00:Removing old file './work/00/logfile_01-20200408-010104.txt'
08:15:57:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 22285 -checkpoint 15
08:15:57:WU00:FS00:Started FahCore on PID 22109
08:15:57:WU00:FS00:Core PID:22113
08:15:57:WU00:FS00:FahCore 0xa7 started
08:15:58:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:16:57:WU00:FS00:Starting
08:16:57:WU00:FS00:Removing old file './work/00/logfile_01-20200408-010204.txt'
08:16:57:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 22285 -checkpoint 15
08:16:57:WU00:FS00:Started FahCore on PID 22139
08:16:57:WU00:FS00:Core PID:22142
08:16:57:WU00:FS00:FahCore 0xa7 started
08:16:58:WU00:FS00:0xa7:*********************** Log Started 2020-04-08T08:16:57Z ***********************
08:16:58:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
08:16:58:WU00:FS00:0xa7:       Type: 0xa7
08:16:58:WU00:FS00:0xa7:       Core: Gromacs
08:16:58:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 22139 -checkpoint 15
08:16:58:WU00:FS00:0xa7:************************************ CBang *************************************
08:16:58:WU00:FS00:0xa7:       Date: Nov 5 2019
08:16:58:WU00:FS00:0xa7:       Time: 05:57:01
08:16:58:WU00:FS00:0xa7:   Revision: 46c96f1aa8419571d83f3e63f9c99a0d602f6da9
08:16:58:WU00:FS00:0xa7:     Branch: master
08:16:58:WU00:FS00:0xa7:   Compiler: GNU 8.3.0
08:16:58:WU00:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -fno-pie -fPIC
08:16:58:WU00:FS00:0xa7:   Platform: linux2 4.19.0-5-amd64
08:16:58:WU00:FS00:0xa7:       Bits: 64
08:16:58:WU00:FS00:0xa7:       Mode: Release
08:16:58:WU00:FS00:0xa7:************************************ System ************************************
08:16:58:WU00:FS00:0xa7:        CPU: AMD A4-3300 APU with Radeon(tm) HD Graphics
08:16:58:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 18 Model 1 Stepping 0
08:16:58:WU00:FS00:0xa7:       CPUs: 2
08:16:58:WU00:FS00:0xa7:     Memory: 7.28GiB
08:16:58:WU00:FS00:0xa7:Free Memory: 1010.03MiB
08:16:58:WU00:FS00:0xa7:    Threads: POSIX_THREADS
08:16:58:WU00:FS00:0xa7: OS Version: 4.15
08:16:58:WU00:FS00:0xa7:Has Battery: false
08:16:58:WU00:FS00:0xa7: On Battery: false
08:16:58:WU00:FS00:0xa7: UTC Offset: 1
08:16:58:WU00:FS00:0xa7:        PID: 22142
08:16:58:WU00:FS00:0xa7:        CWD: /var/lib/fahclient/work
08:16:58:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
08:16:58:WU00:FS00:0xa7:    Version: 0.0.18
08:16:58:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:16:58:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
08:16:58:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
08:16:58:WU00:FS00:0xa7:       Time: 06:13:26
08:16:58:WU00:FS00:0xa7:   Revision: 490c9aa2957b725af319379424d5c5cb36efb656
08:16:58:WU00:FS00:0xa7:************************************ Build *************************************
08:16:58:WU00:FS00:0xa7:       SIMD: sse2
08:16:58:WU00:FS00:0xa7:********************************************************************************
08:16:58:WU00:FS00:0xa7:Project: 13850 (Run 0, Clone 3063, Gen 17)
08:16:58:WU00:FS00:0xa7:Unit: 0x00000018287234c95e725915594716bd
08:16:58:WU00:FS00:0xa7:Digital signatures verified
08:16:58:WU00:FS00:0xa7:Calling: mdrun -s frame17.tpr -o frame17.trr -x frame17.xtc -e frame17.edr -cpi state.cpt -cpt 15 -nt 1
08:16:58:WU00:FS00:0xa7:ERROR:Guru Meditation #65fbf0429796a9cd.cd9117ad6199191 (1192440.1192440) '00/01/state.cpt'
08:16:58:WU00:FS00:0xa7:WARNING:Unexpected exit() call
08:16:58:WU00:FS00:0xa7:WARNING:Unexpected exit from science code
08:16:58:WU00:FS00:0xa7:Saving result file ../logfile_01.txt
08:16:58:WU00:FS00:0xa7:Saving result file frame17.edr
08:16:58:WU00:FS00:0xa7:Saving result file frame17.trr
08:16:58:WU00:FS00:0xa7:Saving result file frame17.xtc
08:16:58:WU00:FS00:0xa7:Saving result file md.log
08:16:58:WU00:FS00:0xa7:Saving result file science.log
08:16:58:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:17:15:FS00:Finishing
08:17:23:FS00:Paused
08:17:24:FS00:Unpaused
08:17:57:WU00:FS00:Starting
08:17:57:WU00:FS00:Removing old file './work/00/logfile_01-20200408-010304.txt'
08:17:57:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 22285 -checkpoint 15
08:17:57:WU00:FS00:Started FahCore on PID 22169
08:17:57:WU00:FS00:Core PID:22173
08:17:57:WU00:FS00:FahCore 0xa7 started
08:17:58:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:18:57:WU00:FS00:Starting
08:18:57:WU00:FS00:Removing old file './work/00/logfile_01-20200408-010404.txt'
08:18:57:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 22285 -checkpoint 15
08:18:57:WU00:FS00:Started FahCore on PID 22223
08:18:57:WU00:FS00:Core PID:22227
08:18:57:WU00:FS00:FahCore 0xa7 started
08:18:58:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:19:57:WU00:FS00:Starting
08:19:57:WU00:FS00:Removing old file './work/00/logfile_01-20200408-074716.txt'
08:19:57:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 22285 -checkpoint 15
08:19:57:WU00:FS00:Started FahCore on PID 22259
08:19:58:WU00:FS00:Core PID:22263
08:19:58:WU00:FS00:FahCore 0xa7 started
08:19:58:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:20:58:WU00:FS00:Starting
08:20:58:WU00:FS00:Removing old file './work/00/logfile_01-20200408-074856.txt'
08:20:58:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 22285 -checkpoint 15
08:20:58:WU00:FS00:Started FahCore on PID 22318
08:20:58:WU00:FS00:Core PID:22322
08:20:58:WU00:FS00:FahCore 0xa7 started
08:20:58:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:21:58:WU00:FS00:Starting
08:21:58:WU00:FS00:Removing old file './work/00/logfile_01-20200408-074956.txt'
08:21:58:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 22285 -checkpoint 15
08:21:58:WU00:FS00:Started FahCore on PID 22350
08:21:58:WU00:FS00:Core PID:22354
08:21:58:WU00:FS00:FahCore 0xa7 started
08:21:58:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:22:58:WU00:FS00:Starting
08:22:58:WU00:FS00:Removing old file './work/00/logfile_01-20200408-075056.txt'
08:22:58:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 22285 -checkpoint 15
08:22:58:WU00:FS00:Started FahCore on PID 22393
08:22:58:WU00:FS00:Core PID:22397
08:22:58:WU00:FS00:FahCore 0xa7 started
08:22:58:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:23:58:WU00:FS00:Starting
08:23:58:WU00:FS00:Removing old file './work/00/logfile_01-20200408-075156.txt'
08:23:58:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 22285 -checkpoint 15
08:23:58:WU00:FS00:Started FahCore on PID 22446
08:23:58:WU00:FS00:Core PID:22450
08:23:58:WU00:FS00:FahCore 0xa7 started
08:23:58:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:24:58:WU00:FS00:Starting
08:24:58:WU00:FS00:Removing old file './work/00/logfile_01-20200408-075257.txt'
08:24:58:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 22285 -checkpoint 15
08:24:58:WU00:FS00:Started FahCore on PID 22491
08:24:58:WU00:FS00:Core PID:22495
08:24:58:WU00:FS00:FahCore 0xa7 started
08:24:58:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:25:58:WU00:FS00:Starting
08:25:58:WU00:FS00:Removing old file './work/00/logfile_01-20200408-075357.txt'
08:25:58:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 22285 -checkpoint 15
08:25:58:WU00:FS00:Started FahCore on PID 22522
08:25:58:WU00:FS00:Core PID:22526
08:25:58:WU00:FS00:FahCore 0xa7 started
08:25:58:WU00:FS00:0xa7:*********************** Log Started 2020-04-08T08:25:58Z ***********************
08:25:58:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
08:25:58:WU00:FS00:0xa7:       Type: 0xa7
08:25:58:WU00:FS00:0xa7:       Core: Gromacs
08:25:58:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 22522 -checkpoint 15
08:25:58:WU00:FS00:0xa7:************************************ CBang *************************************
08:25:58:WU00:FS00:0xa7:       Date: Nov 5 2019
08:25:58:WU00:FS00:0xa7:       Time: 05:57:01
08:25:58:WU00:FS00:0xa7:   Revision: 46c96f1aa8419571d83f3e63f9c99a0d602f6da9
08:25:58:WU00:FS00:0xa7:     Branch: master
08:25:58:WU00:FS00:0xa7:   Compiler: GNU 8.3.0
08:25:58:WU00:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -fno-pie -fPIC
08:25:58:WU00:FS00:0xa7:   Platform: linux2 4.19.0-5-amd64
08:25:58:WU00:FS00:0xa7:       Bits: 64
08:25:58:WU00:FS00:0xa7:       Mode: Release
08:25:58:WU00:FS00:0xa7:************************************ System ************************************
08:25:58:WU00:FS00:0xa7:        CPU: AMD A4-3300 APU with Radeon(tm) HD Graphics
08:25:58:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 18 Model 1 Stepping 0
08:25:58:WU00:FS00:0xa7:       CPUs: 2
08:25:58:WU00:FS00:0xa7:     Memory: 7.28GiB
08:25:58:WU00:FS00:0xa7:Free Memory: 1.11GiB
08:25:58:WU00:FS00:0xa7:    Threads: POSIX_THREADS
08:25:58:WU00:FS00:0xa7: OS Version: 4.15
08:25:58:WU00:FS00:0xa7:Has Battery: false
08:25:58:WU00:FS00:0xa7: On Battery: false
08:25:58:WU00:FS00:0xa7: UTC Offset: 1
08:25:58:WU00:FS00:0xa7:        PID: 22526
08:25:58:WU00:FS00:0xa7:        CWD: /var/lib/fahclient/work
08:25:58:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
08:25:58:WU00:FS00:0xa7:    Version: 0.0.18
08:25:58:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:25:58:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
08:25:58:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
08:25:58:WU00:FS00:0xa7:       Time: 06:13:26
08:25:58:WU00:FS00:0xa7:   Revision: 490c9aa2957b725af319379424d5c5cb36efb656
08:25:58:WU00:FS00:0xa7:************************************ Build *************************************
08:25:58:WU00:FS00:0xa7:       SIMD: sse2
08:25:58:WU00:FS00:0xa7:********************************************************************************
08:25:58:WU00:FS00:0xa7:Project: 13850 (Run 0, Clone 3063, Gen 17)
08:25:58:WU00:FS00:0xa7:Unit: 0x00000018287234c95e725915594716bd
08:25:58:WU00:FS00:0xa7:Digital signatures verified
08:25:58:WU00:FS00:0xa7:Calling: mdrun -s frame17.tpr -o frame17.trr -x frame17.xtc -e frame17.edr -cpi state.cpt -cpt 15 -nt 1
08:25:58:WU00:FS00:0xa7:ERROR:Guru Meditation #65fbf0429796a9cd.cd9117ad6199191 (1192440.1192440) '00/01/state.cpt'
08:25:58:WU00:FS00:0xa7:WARNING:Unexpected exit() call
08:25:58:WU00:FS00:0xa7:WARNING:Unexpected exit from science code
08:25:58:WU00:FS00:0xa7:Saving result file ../logfile_01.txt
08:25:58:WU00:FS00:0xa7:Saving result file frame17.edr
08:25:58:WU00:FS00:0xa7:Saving result file frame17.trr
08:25:58:WU00:FS00:0xa7:Saving result file frame17.xtc
08:25:58:WU00:FS00:0xa7:Saving result file md.log
08:25:58:WU00:FS00:0xa7:Saving result file science.log
08:25:58:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:26:58:WU00:FS00:Starting
08:26:58:WU00:FS00:Removing old file './work/00/logfile_01-20200408-075457.txt'
08:26:58:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 22285 -checkpoint 15
08:26:58:WU00:FS00:Started FahCore on PID 22553
08:26:58:WU00:FS00:Core PID:22557
08:26:58:WU00:FS00:FahCore 0xa7 started
08:26:58:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:27:58:WU00:FS00:Starting
08:27:58:WU00:FS00:Removing old file './work/00/logfile_01-20200408-075557.txt'
08:27:58:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 22285 -checkpoint 15
08:27:58:WU00:FS00:Started FahCore on PID 22582
08:27:58:WU00:FS00:Core PID:22586
08:27:58:WU00:FS00:FahCore 0xa7 started
08:27:58:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:28:58:WU00:FS00:Starting
08:28:58:WU00:FS00:Removing old file './work/00/logfile_01-20200408-075657.txt'
08:28:58:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 22285 -checkpoint 15
08:28:58:WU00:FS00:Started FahCore on PID 22625
08:28:58:WU00:FS00:Core PID:22629
08:28:58:WU00:FS00:FahCore 0xa7 started
08:28:58:WU00:FS00:0xa7:*********************** Log Started 2020-04-08T08:28:58Z ***********************
08:28:58:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
08:28:58:WU00:FS00:0xa7:       Type: 0xa7
08:28:58:WU00:FS00:0xa7:       Core: Gromacs
08:28:58:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 22625 -checkpoint 15
08:28:58:WU00:FS00:0xa7:************************************ CBang *************************************
08:28:58:WU00:FS00:0xa7:       Date: Nov 5 2019
08:28:58:WU00:FS00:0xa7:       Time: 05:57:01
08:28:58:WU00:FS00:0xa7:   Revision: 46c96f1aa8419571d83f3e63f9c99a0d602f6da9
08:28:58:WU00:FS00:0xa7:     Branch: master
08:28:58:WU00:FS00:0xa7:   Compiler: GNU 8.3.0
08:28:58:WU00:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -fno-pie -fPIC
08:28:58:WU00:FS00:0xa7:   Platform: linux2 4.19.0-5-amd64
08:28:58:WU00:FS00:0xa7:       Bits: 64
08:28:58:WU00:FS00:0xa7:       Mode: Release
08:28:58:WU00:FS00:0xa7:************************************ System ************************************
08:28:58:WU00:FS00:0xa7:        CPU: AMD A4-3300 APU with Radeon(tm) HD Graphics
08:28:58:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 18 Model 1 Stepping 0
08:28:58:WU00:FS00:0xa7:       CPUs: 2
08:28:58:WU00:FS00:0xa7:     Memory: 7.28GiB
08:28:58:WU00:FS00:0xa7:Free Memory: 1020.96MiB
08:28:58:WU00:FS00:0xa7:    Threads: POSIX_THREADS
08:28:58:WU00:FS00:0xa7: OS Version: 4.15
08:28:58:WU00:FS00:0xa7:Has Battery: false
08:28:58:WU00:FS00:0xa7: On Battery: false
08:28:58:WU00:FS00:0xa7: UTC Offset: 1
08:28:58:WU00:FS00:0xa7:        PID: 22629
08:28:58:WU00:FS00:0xa7:        CWD: /var/lib/fahclient/work
08:28:58:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
08:28:58:WU00:FS00:0xa7:    Version: 0.0.18
08:28:58:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:28:58:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
08:28:58:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
08:28:58:WU00:FS00:0xa7:       Time: 06:13:26
08:28:58:WU00:FS00:0xa7:   Revision: 490c9aa2957b725af319379424d5c5cb36efb656
08:28:58:WU00:FS00:0xa7:************************************ Build *************************************
08:28:58:WU00:FS00:0xa7:       SIMD: sse2
08:28:58:WU00:FS00:0xa7:********************************************************************************
08:28:58:WU00:FS00:0xa7:Project: 13850 (Run 0, Clone 3063, Gen 17)
08:28:58:WU00:FS00:0xa7:Unit: 0x00000018287234c95e725915594716bd
08:28:58:WU00:FS00:0xa7:Digital signatures verified
08:28:58:WU00:FS00:0xa7:Calling: mdrun -s frame17.tpr -o frame17.trr -x frame17.xtc -e frame17.edr -cpi state.cpt -cpt 15 -nt 1
08:28:58:WU00:FS00:0xa7:ERROR:Guru Meditation #65fbf0429796a9cd.cd9117ad6199191 (1192440.1192440) '00/01/state.cpt'
08:28:58:WU00:FS00:0xa7:WARNING:Unexpected exit() call
08:28:58:WU00:FS00:0xa7:WARNING:Unexpected exit from science code
08:28:58:WU00:FS00:0xa7:Saving result file ../logfile_01.txt
08:28:58:WU00:FS00:0xa7:Saving result file frame17.edr
08:28:58:WU00:FS00:0xa7:Saving result file frame17.trr
08:28:58:WU00:FS00:0xa7:Saving result file frame17.xtc
08:28:58:WU00:FS00:0xa7:Saving result file md.log
08:28:58:WU00:FS00:0xa7:Saving result file science.log
08:28:59:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:30:58:WU00:FS00:Starting
08:30:58:WU00:FS00:Removing old file './work/00/logfile_01-20200408-075857.txt'
08:30:58:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 22285 -checkpoint 15
08:30:58:WU00:FS00:Started FahCore on PID 22703
08:30:58:WU00:FS00:Core PID:22707
08:30:58:WU00:FS00:FahCore 0xa7 started
08:30:58:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:31:58:WU00:FS00:Starting
08:31:58:WU00:FS00:Removing old file './work/00/logfile_01-20200408-075957.txt'
08:31:58:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 22285 -checkpoint 15
08:31:58:WU00:FS00:Started FahCore on PID 22738
08:31:58:WU00:FS00:Core PID:22742
08:31:58:WU00:FS00:FahCore 0xa7 started
08:31:59:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:32:58:WU00:FS00:Starting
08:32:58:WU00:FS00:Removing old file './work/00/logfile_01-20200408-080057.txt'
08:32:58:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 22285 -checkpoint 15
08:32:58:WU00:FS00:Started FahCore on PID 22781
08:32:58:WU00:FS00:Core PID:22785
08:32:58:WU00:FS00:FahCore 0xa7 started
08:32:59:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:33:58:WU00:FS00:Starting
08:33:58:WU00:FS00:Removing old file './work/00/logfile_01-20200408-080157.txt'
08:33:58:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 22285 -checkpoint 15
08:33:58:WU00:FS00:Started FahCore on PID 22806
08:33:58:WU00:FS00:Core PID:22810
08:33:58:WU00:FS00:FahCore 0xa7 started
08:33:59:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:34:58:WU00:FS00:Starting
08:34:58:WU00:FS00:Removing old file './work/00/logfile_01-20200408-080257.txt'
08:34:58:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 22285 -checkpoint 15
08:34:58:WU00:FS00:Started FahCore on PID 22840
08:34:58:WU00:FS00:Core PID:22844
08:34:58:WU00:FS00:FahCore 0xa7 started
08:34:59:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:35:58:WU00:FS00:Starting
08:35:58:WU00:FS00:Removing old file './work/00/logfile_01-20200408-080357.txt'
08:35:58:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 22285 -checkpoint 15
08:35:58:WU00:FS00:Started FahCore on PID 22900
08:35:58:WU00:FS00:Core PID:22904
08:35:58:WU00:FS00:FahCore 0xa7 started
08:35:59:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:36:58:WU00:FS00:Starting
08:36:58:WU00:FS00:Removing old file './work/00/logfile_01-20200408-080457.txt'
08:36:58:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 22285 -checkpoint 15
08:36:58:WU00:FS00:Started FahCore on PID 22928
08:36:58:WU00:FS00:Core PID:22932
08:36:58:WU00:FS00:FahCore 0xa7 started
08:36:59:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:37:58:WU00:FS00:Starting
08:37:58:WU00:FS00:Removing old file './work/00/logfile_01-20200408-080557.txt'
08:37:58:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 22285 -checkpoint 15
08:37:58:WU00:FS00:Started FahCore on PID 22961
08:37:58:WU00:FS00:Core PID:22965
08:37:58:WU00:FS00:FahCore 0xa7 started
08:37:59:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:38:58:WU00:FS00:Starting
08:38:58:WU00:FS00:Removing old file './work/00/logfile_01-20200408-080657.txt'
08:38:58:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 22285 -checkpoint 15
08:38:58:WU00:FS00:Started FahCore on PID 22998
08:38:58:WU00:FS00:Core PID:23002
08:38:58:WU00:FS00:FahCore 0xa7 started
08:38:59:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:39:58:WU00:FS00:Starting
08:39:58:WU00:FS00:Removing old file './work/00/logfile_01-20200408-080757.txt'
08:39:58:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 22285 -checkpoint 15
08:39:58:WU00:FS00:Started FahCore on PID 23026
08:39:58:WU00:FS00:Core PID:23030
08:39:58:WU00:FS00:FahCore 0xa7 started
08:39:59:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:40:58:WU00:FS00:Starting
08:40:58:WU00:FS00:Removing old file './work/00/logfile_01-20200408-080857.txt'
08:40:58:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 22285 -checkpoint 15
08:40:58:WU00:FS00:Started FahCore on PID 23069
08:40:58:WU00:FS00:Core PID:23073
08:40:58:WU00:FS00:FahCore 0xa7 started
08:40:59:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:41:58:WU00:FS00:Starting
08:41:58:WU00:FS00:Removing old file './work/00/logfile_01-20200408-080957.txt'
08:41:58:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 22285 -checkpoint 15
08:41:58:WU00:FS00:Started FahCore on PID 23101
08:41:58:WU00:FS00:Core PID:23105
08:41:58:WU00:FS00:FahCore 0xa7 started
08:41:59:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:42:58:WU00:FS00:Starting
08:42:58:WU00:FS00:Removing old file './work/00/logfile_01-20200408-081057.txt'
08:42:58:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 22285 -checkpoint 15
08:42:58:WU00:FS00:Started FahCore on PID 23119
08:42:58:WU00:FS00:Core PID:23123
08:42:58:WU00:FS00:FahCore 0xa7 started
08:42:59:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:43:58:WU00:FS00:Starting
08:43:58:WU00:FS00:Removing old file './work/00/logfile_01-20200408-081157.txt'
08:43:58:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 22285 -checkpoint 15
08:43:58:WU00:FS00:Started FahCore on PID 23156
08:43:58:WU00:FS00:Core PID:23160
08:43:58:WU00:FS00:FahCore 0xa7 started
08:43:59:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:44:58:WU00:FS00:Starting
08:44:58:WU00:FS00:Removing old file './work/00/logfile_01-20200408-081257.txt'
08:44:58:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 22285 -checkpoint 15
08:44:58:WU00:FS00:Started FahCore on PID 23201
08:44:58:WU00:FS00:Core PID:23205
08:44:58:WU00:FS00:FahCore 0xa7 started
08:44:59:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:45:58:WU00:FS00:Starting
08:45:58:WU00:FS00:Removing old file './work/00/logfile_01-20200408-081357.txt'
08:45:58:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 22285 -checkpoint 15
08:45:58:WU00:FS00:Started FahCore on PID 23232
08:45:58:WU00:FS00:Core PID:23236
08:45:58:WU00:FS00:FahCore 0xa7 started
08:45:59:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:46:59:WU00:FS00:Starting
08:46:59:WU00:FS00:Removing old file './work/00/logfile_01-20200408-081457.txt'
08:46:59:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 22285 -checkpoint 15
08:46:59:WU00:FS00:Started FahCore on PID 23257
08:46:59:WU00:FS00:Core PID:23261
08:46:59:WU00:FS00:FahCore 0xa7 started
08:46:59:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:47:59:WU00:FS00:Starting
08:47:59:WU00:FS00:Removing old file './work/00/logfile_01-20200408-081557.txt'
08:47:59:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 22285 -checkpoint 15
08:47:59:WU00:FS00:Started FahCore on PID 23294
08:47:59:WU00:FS00:Core PID:23298
08:47:59:WU00:FS00:FahCore 0xa7 started
08:47:59:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:48:59:WU00:FS00:Starting
08:48:59:WU00:FS00:Removing old file './work/00/logfile_01-20200408-081657.txt'
08:48:59:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 22285 -checkpoint 15
08:48:59:WU00:FS00:Started FahCore on PID 23321
08:48:59:WU00:FS00:Core PID:23325
08:48:59:WU00:FS00:FahCore 0xa7 started
08:48:59:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:49:59:WU00:FS00:Starting
08:49:59:WU00:FS00:Removing old file './work/00/logfile_01-20200408-081757.txt'
08:49:59:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 22285 -checkpoint 15
08:49:59:WU00:FS00:Started FahCore on PID 23348
08:49:59:WU00:FS00:Core PID:23352
08:49:59:WU00:FS00:FahCore 0xa7 started
08:49:59:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:50:59:WU00:FS00:Starting
08:50:59:WU00:FS00:Removing old file './work/00/logfile_01-20200408-081857.txt'
08:50:59:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 22285 -checkpoint 15
08:50:59:WU00:FS00:Started FahCore on PID 23369
08:50:59:WU00:FS00:Core PID:23373
08:50:59:WU00:FS00:FahCore 0xa7 started
08:50:59:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:51:59:WU00:FS00:Starting
08:51:59:WU00:FS00:Removing old file './work/00/logfile_01-20200408-081957.txt'
08:51:59:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 22285 -checkpoint 15
08:51:59:WU00:FS00:Started FahCore on PID 23395
08:51:59:WU00:FS00:Core PID:23399
08:51:59:WU00:FS00:FahCore 0xa7 started
08:51:59:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:52:59:WU00:FS00:Starting
08:52:59:WU00:FS00:Removing old file './work/00/logfile_01-20200408-082058.txt'
08:52:59:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 22285 -checkpoint 15
08:52:59:WU00:FS00:Started FahCore on PID 23429
08:52:59:WU00:FS00:Core PID:23433
08:52:59:WU00:FS00:FahCore 0xa7 started
08:52:59:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:53:59:WU00:FS00:Starting
08:53:59:WU00:FS00:Removing old file './work/00/logfile_01-20200408-082158.txt'
08:53:59:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 22285 -checkpoint 15
08:53:59:WU00:FS00:Started FahCore on PID 23454
08:53:59:WU00:FS00:Core PID:23458
08:53:59:WU00:FS00:FahCore 0xa7 started
08:53:59:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:54:59:WU00:FS00:Starting
08:54:59:WU00:FS00:Removing old file './work/00/logfile_01-20200408-082258.txt'
08:54:59:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 22285 -checkpoint 15
08:54:59:WU00:FS00:Started FahCore on PID 23488
08:54:59:WU00:FS00:Core PID:23492
08:54:59:WU00:FS00:FahCore 0xa7 started
08:54:59:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:55:59:WU00:FS00:Starting
08:55:59:WU00:FS00:Removing old file './work/00/logfile_01-20200408-082358.txt'
08:55:59:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 22285 -checkpoint 15
08:55:59:WU00:FS00:Started FahCore on PID 23523
08:55:59:WU00:FS00:Core PID:23527
08:55:59:WU00:FS00:FahCore 0xa7 started
08:55:59:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:56:59:WU00:FS00:Starting
08:56:59:WU00:FS00:Removing old file './work/00/logfile_01-20200408-082458.txt'
08:56:59:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 22285 -checkpoint 15
08:56:59:WU00:FS00:Started FahCore on PID 23553
08:56:59:WU00:FS00:Core PID:23557
08:56:59:WU00:FS00:FahCore 0xa7 started
08:56:59:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:57:59:WU00:FS00:Starting
08:57:59:WU00:FS00:Removing old file './work/00/logfile_01-20200408-082558.txt'
08:57:59:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 22285 -checkpoint 15
08:57:59:WU00:FS00:Started FahCore on PID 23579
08:57:59:WU00:FS00:Core PID:23583
08:57:59:WU00:FS00:FahCore 0xa7 started
08:57:59:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:58:59:WU00:FS00:Starting
08:58:59:WU00:FS00:Removing old file './work/00/logfile_01-20200408-082658.txt'
08:58:59:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 22285 -checkpoint 15
08:58:59:WU00:FS00:Started FahCore on PID 23617
08:58:59:WU00:FS00:Core PID:23621
08:58:59:WU00:FS00:FahCore 0xa7 started
08:59:00:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:59:59:WU00:FS00:Starting
08:59:59:WU00:FS00:Removing old file './work/00/logfile_01-20200408-082758.txt'
08:59:59:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 22285 -checkpoint 15
08:59:59:WU00:FS00:Started FahCore on PID 23648
08:59:59:WU00:FS00:Core PID:23652
08:59:59:WU00:FS00:FahCore 0xa7 started
HaloJones
Post by HaloJones »
you need to turn off all the Power Management so the system "Never" goes to sleep
4070 super
minta
Post by minta »
HaloJones wrote:you need to turn off all the Power Management so the system "Never" goes to sleep
Sorry, but can't do that because I regularly put the system into suspend to save power at night or at other times.
Then you need to Pause folding first before the system will go into hibernate. From what is posted, there as a Guru Meditation message, and it concerns opening the checkpoint file. That points to the file being corrupted, either the client was interrupted in writing it out, or as a sign of filesystem corruption.
The WU will not restart, the client should dump it after a few errors, but due to a bug in the Linux version my not. If not dumped on its own, you will need to delete the WU. Pause the client, delete the folder ./work/00 in the CWD listed by the client. Then resume folding.
minta
Post by minta »
Okay, so it appears this is no good for my system. I would need something that can work with the fact that I use suspend. My job is not to manage any "guru meditation' nonsense. If it can't resume then it needs to be changed so that this is possible. I don't have time to implement manual workarounds like .. delete folder blah blah, resume client/folding especially without proper instructions. If there is a limitation or known issue around suspending then it needs to be documented in the download page on the website.
Darth_Peter_dualxeon
Hardware configuration: EVGA SR-2 motherboard
2x Xeon x5670 CPU
64 GB ECC DDR3
Nvidia RTX 2070
Post by Darth_Peter_dualxeon »
I would suggest not to pause but to "finish" the folding.
if you click finish then it will do all the current workunits, not ask for new, and then you can shutdown the system,
(I once had a stupid situation that somehow it didn't see the GPU once restarted from the suspend.)
And, saving power and helping the folding team are two opposite ideas.
Usually one starts the folding, when the computer would be idle otherwise, instead of sleeping the system.
Yes, I'm using the computer to heat my room at night. It's not that loud. Maybe a way higher electricity bill these months, but who cares...
mat2
Post by mat2 »
I have faced a similar issue (see viewtopic.php?f=106&t=32011 ) and have written a small script that may help You. It automatically pauses FAH execution on suspend/hibernate and resumes it after the computer is woken up (if it was folding previously). It can be used until the FAH client / core is fixed.
#!/bin/bash
# Automatically pause Folding@Home client on suspend/hibernate and unpause it
# after the computer is woken up (if it was folding previously).
# Assumes systemd.
# Copyright 2020 Mateusz Jończyk
# License: Creative Commons Zero
# Save this file as /lib/systemd/system-sleep/fah_sleep and make it executable
# Assumes only one folding slot is present. Unused folding slots can be deleted
# in FAHControl -> Configure -> Slots
STATE_FILE=/run/fah_status.txt
PORT=36330
if [ "$1" = 'pre' ]; then
        (echo -e 'slot-info\npause'; sleep 10) | telnet localhost $PORT > $STATE_FILE
else
        if cat $STATE_FILE | grep 'RUNNING'; then
                echo 'unpause' | telnet localhost $PORT
        elif cat $STATE_FILE | grep 'FINISHING'; then
                echo 'finish' | telnet localhost $PORT
        fi
fi
