stats
stats
I cant find my stats. I get a work_ack and then a file clean up in the log. I go to check my stats and i am not showing anything. Its been almost 4 days. Am i doing something wrong? I have went to other pages other than the fah stats page and still cant find myself. I think the other pages just show the top people.
any help would be appreciated
this is the page i have been trying to check https://stats.foldingathome.org/jbzy3000
Re: stats
Re: stats
I guess what i am saying is i put in my information on that page and it comes up with nothing found. I have had multiple successful wu completed. A forum member posted that he found me, but it was yesterday and I didnt read all the thread because i was going over the other information that was added to my other question. I missed his response. I did ask what site he used to find my stats. I just ordered all the stuff the other members suggested. My apologies if I was to vague. I followed the steps the from the searches i made, but none of it worked for me. I just want to verifyI am not wasting wu. im a total newb to this process.
Re: stats
If you post the first 200 lines or so of your log (see link above) it might give enough information for someone to assist you.
Re: stats
According to what I see at https://apps.foldingathome.org/cpu I see two returns so far today:
Hi jbzy3000 (team 0), Your WU (P11781 R0 C29 G33) was added to the stats database on Tue, 07 Apr 2020 21:27:28 GMT for 16615 points of credit.
Hi jbzy3000 (team 0), Your WU (P11779 R0 C3751 G53) was added to the stats database on Tue, 07 Apr 2020 06:44:45 GMT for 7608 points of credit.
After those credits enter the Stats system (probably later today) you should be able to find yourself listed in the official Statistics.
Re: stats
gpu 0
this is one that just finished and it is starting a new one. I actually believe this says it is accepted, but not sure how to check. I have been running 24/7 so there are quite a few
17:26:31:WU00:FS00:Started FahCore on PID 22672
17:26:31:WU00:FS00:Core PID:19188
17:26:31:WU00:FS00:FahCore 0x22 started
17:26:31:WU00:FS00:0x22:*********************** Log Started 2020-04-07T17:26:31Z ***********************
17:26:31:WU00:FS00:0x22:*************************** Core22 Folding@home Core ***************************
17:26:31:WU00:FS00:0x22: Type: 0x22
17:26:31:WU00:FS00:0x22: Core: Core22
17:26:31:WU00:FS00:0x22: Website: https://foldingathome.org/
17:26:31:WU00:FS00:0x22: Copyright: (c) 2009-2018 foldingathome.org
17:26:31:WU00:FS00:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
17:26:31:WU00:FS00:0x22: <rafal.wiewiora@choderalab.org>
17:26:31:WU00:FS00:0x22: Args: -dir 00 -suffix 01 -version 705 -lifeline 22672 -checkpoint 15
17:26:31:WU00:FS00:0x22: -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device
17:26:31:WU00:FS00:0x22: 0 -gpu 0
17:26:31:WU00:FS00:0x22: Config: <none>
17:26:31:WU00:FS00:0x22:************************************ Build *************************************
17:26:31:WU00:FS00:0x22: Version: 0.0.2
17:26:31:WU00:FS00:0x22: Date: Dec 6 2019
17:26:31:WU00:FS00:0x22: Time: 21:30:31
17:26:31:WU00:FS00:0x22: Repository: Git
17:26:31:WU00:FS00:0x22: Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
17:26:31:WU00:FS00:0x22: Branch: HEAD
17:26:31:WU00:FS00:0x22: Compiler: Visual C++ 2008
17:26:31:WU00:FS00:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:26:31:WU00:FS00:0x22: Platform: win32 10
17:26:31:WU00:FS00:0x22: Bits: 64
17:26:31:WU00:FS00:0x22: Mode: Release
17:26:31:WU00:FS00:0x22:************************************ System ************************************
17:26:31:WU00:FS00:0x22: CPU: AMD Ryzen 5 2600 Six-Core Processor
17:26:31:WU00:FS00:0x22: CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
17:26:31:WU00:FS00:0x22: CPUs: 12
17:26:31:WU00:FS00:0x22: Memory: 15.95GiB
17:26:31:WU00:FS00:0x22:Free Memory: 10.01GiB
17:26:31:WU00:FS00:0x22: Threads: WINDOWS_THREADS
17:26:31:WU00:FS00:0x22: OS Version: 6.2
17:26:31:WU00:FS00:0x22:Has Battery: false
17:26:31:WU00:FS00:0x22: On Battery: false
17:26:31:WU00:FS00:0x22: UTC Offset: -4
17:26:31:WU00:FS00:0x22: PID: 19188
17:26:31:WU00:FS00:0x22: CWD: C:\Users\Jarrod\AppData\Roaming\FAHClient\work
17:26:31:WU00:FS00:0x22: OS: Windows 10 Home
17:26:31:WU00:FS00:0x22: OS Arch: AMD64
17:26:31:WU00:FS00:0x22:********************************************************************************
17:26:31:WU00:FS00:0x22:Project: 11761 (Run 0, Clone 5218, Gen 24)
17:26:31:WU00:FS00:0x22:Unit: 0x0000002f80fccb0a5e6fb8f763f49acd
17:26:31:WU00:FS00:0x22:Reading tar file core.xml
17:26:31:WU00:FS00:0x22:Reading tar file integrator.xml
17:26:31:WU00:FS00:0x22:Reading tar file state.xml
17:26:31:WU00:FS00:0x22:Reading tar file system.xml
17:26:32:WU00:FS00:0x22:Digital signatures verified
17:26:32:WU00:FS00:0x22:Folding@home GPU Core22 Folding@home Core
17:26:32:WU00:FS00:0x22:Version 0.0.2
17:26:37:WU02:FS00:Upload 10.30%
17:26:41:WU00:FS00:0x22:Completed 0 out of 2000000 steps (0%)
17:26:41:WU00:FS00:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
17:26:43:WU02:FS00:Upload 20.93%
17:26:49:WU02:FS00:Upload 31.68%
17:26:55:WU02:FS00:Upload 42.99%
17:27:01:WU02:FS00:Upload 53.52%
17:27:07:WU02:FS00:Upload 61.32%
17:27:13:WU02:FS00:Upload 71.62%
17:27:19:WU02:FS00:Upload 84.52%
17:27:25:WU02:FS00:Upload 95.49%
17:27:28:WU02:FS00:Upload complete
17:27:28:WU02:FS00:Server responded WORK_ACK (400)
17:27:28:WU02:FS00:Final credit estimate, 51635.00 points
17:27:28:WU02:FS00:Cleaning up
Re: stats
What is wierd is that I don't find "jbzy3000" when searching on https://stats.foldingathome.org/donors ...
Re: stats
ok thanks i saved this link. This link worked. The others i went to didnt even show me as a donor. Thanks again. These are from a couple days ago. So it will take a while to catchup. I had my name set as anonymous. So last weeks work i have no clue, hope they went through as well. Thanks Guys I just could not find a site that said anything i was doing was working.bollix47 wrote:According to what I see at https://apps.foldingathome.org/cpu I see two returns so far today:
have a great day
