Error Message CPU
Lasky
Hardware configuration: AMD Threadripper 24 Cores 4100 GHZ
NVIDIA GeForce RTX 2080 Super NVIDIA TU104 3.072 Shader Einheiten 8 GB GDDR6 256 Bit aktive Watercooling DirectX 12.1 OpenGL 4.5 DLSS Upscaling G-Sync PCIe 3.0 x16 4K VR 7680 x 4320
128 GB DDR4 3200 MHZ
Error Message CPU
Post by Lasky »
Hi folks, F@H shows me error messages on the CPU during the calculation.
what could be the reason ?
20:34:25:WU00:FS00:Starting
20:34:25:WARNING:WU00:FS00:AS lowered CPUs from 15 to 14
20:34:25:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\tobfu\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 12164 -checkpoint 15 -np 14
20:34:26:WU00:FS00:Started FahCore on PID 11684
20:34:26:WU00:FS00:Core PID:12016
20:34:26:WU00:FS00:FahCore 0xa7 started
20:34:27:WU00:FS00:0xa7:*********************** Log Started 2020-04-06T20:34:27Z ***********************
20:34:27:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
20:34:27:WU00:FS00:0xa7:       Type: 0xa7
20:34:27:WU00:FS00:0xa7:       Core: Gromacs
20:34:27:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 11684 -checkpoint 15 -np
20:34:27:WU00:FS00:0xa7:             14
20:34:27:WU00:FS00:0xa7:************************************ CBang *************************************
20:34:27:WU00:FS00:0xa7:       Date: Oct 26 2019
20:34:27:WU00:FS00:0xa7:       Time: 01:38:25
20:34:27:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
20:34:27:WU00:FS00:0xa7:     Branch: master
20:34:27:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
20:34:27:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:34:27:WU00:FS00:0xa7:   Platform: win32 10
20:34:27:WU00:FS00:0xa7:       Bits: 64
20:34:27:WU00:FS00:0xa7:       Mode: Release
20:34:27:WU00:FS00:0xa7:************************************ System ************************************
20:34:27:WU00:FS00:0xa7:        CPU: AMD Ryzen 7 1700 Eight-Core Processor
20:34:27:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
20:34:27:WU00:FS00:0xa7:       CPUs: 16
20:34:27:WU00:FS00:0xa7:     Memory: 7.94GiB
20:34:27:WU00:FS00:0xa7:Free Memory: 4.18GiB
20:34:27:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
20:34:27:WU00:FS00:0xa7: OS Version: 6.2
20:34:27:WU00:FS00:0xa7:Has Battery: false
20:34:27:WU00:FS00:0xa7: On Battery: false
20:34:27:WU00:FS00:0xa7: UTC Offset: 2
20:34:27:WU00:FS00:0xa7:        PID: 12016
20:34:27:WU00:FS00:0xa7:        CWD: C:\Users\tobfu\AppData\Roaming\FAHClient\work
20:34:27:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
20:34:27:WU00:FS00:0xa7:    Version: 0.0.18
20:34:27:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:34:27:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
20:34:27:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
20:34:27:WU00:FS00:0xa7:       Time: 01:52:30
20:34:27:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
20:34:27:WU00:FS00:0xa7:************************************ Build *************************************
20:34:27:WU00:FS00:0xa7:       SIMD: avx_256
20:34:27:WU00:FS00:0xa7:********************************************************************************
20:34:27:WU00:FS00:0xa7:Project: 14613 (Run 307, Clone 7, Gen 13)
20:34:27:WU00:FS00:0xa7:Unit: 0x0000000e9bf7a4d65e848f76039ce2ba
20:34:27:WU00:FS00:0xa7:Digital signatures verified
20:34:27:WU00:FS00:0xa7:Reducing thread count from 14 to 13 to avoid domain decomposition with large prime factor 7
20:34:27:WU00:FS00:0xa7:Reducing thread count from 13 to 12 to avoid domain decomposition by a prime number > 3
20:34:27:WU00:FS00:0xa7:Calling: mdrun -s frame13.tpr -o frame13.trr -cpi state.cpt -cpt 15 -nt 12
20:34:27:WU00:FS00:0xa7:ERROR:Guru Meditation #82a41b8b217c78d3.8bb50143827eb3f9 (3110.3729) '00/01/pullx.xvg'
20:34:27:WU00:FS00:0xa7:WARNING:Unexpected exit() call
20:34:27:WU00:FS00:0xa7:WARNING:Unexpected exit from science code
20:34:27:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
20:34:27:WU00:FS00:0xa7:Saving result file dhdl.xvg
20:34:27:WU00:FS00:0xa7:ERROR:Guru Meditation #649e1bf13139c145.db32afef6e57c029 (48408.48918) '00/01/dhdl.xvg'
20:34:29:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
20:34:29:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
20:35:25:WU00:FS00:Starting
20:35:25:WARNING:WU00:FS00:AS lowered CPUs from 15 to 14
20:35:25:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\tobfu\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 12164 -checkpoint 15 -np 14
20:35:26:WU00:FS00:Started FahCore on PID 3000
20:35:26:WU00:FS00:Core PID:15128
20:35:26:WU00:FS00:FahCore 0xa7 started
20:35:26:WU00:FS00:0xa7:*********************** Log Started 2020-04-06T20:35:26Z ***********************
20:35:26:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
20:35:26:WU00:FS00:0xa7:       Type: 0xa7
20:35:26:WU00:FS00:0xa7:       Core: Gromacs
20:35:26:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 3000 -checkpoint 15 -np
20:35:27:WU00:FS00:0xa7:             14
20:35:27:WU00:FS00:0xa7:************************************ CBang *************************************
20:35:27:WU00:FS00:0xa7:       Date: Oct 26 2019
20:35:27:WU00:FS00:0xa7:       Time: 01:38:25
20:35:27:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
20:35:27:WU00:FS00:0xa7:     Branch: master
20:35:27:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
20:35:27:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:35:27:WU00:FS00:0xa7:   Platform: win32 10
20:35:27:WU00:FS00:0xa7:       Bits: 64
20:35:27:WU00:FS00:0xa7:       Mode: Release
20:35:27:WU00:FS00:0xa7:************************************ System ************************************
20:35:27:WU00:FS00:0xa7:        CPU: AMD Ryzen 7 1700 Eight-Core Processor
20:35:27:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
20:35:27:WU00:FS00:0xa7:       CPUs: 16
20:35:27:WU00:FS00:0xa7:     Memory: 7.94GiB
20:35:27:WU00:FS00:0xa7:Free Memory: 4.18GiB
20:35:27:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
20:35:27:WU00:FS00:0xa7: OS Version: 6.2
20:35:27:WU00:FS00:0xa7:Has Battery: false
20:35:27:WU00:FS00:0xa7: On Battery: false
20:35:27:WU00:FS00:0xa7: UTC Offset: 2
20:35:27:WU00:FS00:0xa7:        PID: 15128
20:35:27:WU00:FS00:0xa7:        CWD: C:\Users\tobfu\AppData\Roaming\FAHClient\work
20:35:27:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
20:35:27:WU00:FS00:0xa7:    Version: 0.0.18
20:35:27:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:35:27:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
20:35:27:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
20:35:27:WU00:FS00:0xa7:       Time: 01:52:30
20:35:27:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
20:35:27:WU00:FS00:0xa7:************************************ Build *************************************
20:35:27:WU00:FS00:0xa7:       SIMD: avx_256
20:35:27:WU00:FS00:0xa7:********************************************************************************
20:35:27:WU00:FS00:0xa7:Project: 14613 (Run 307, Clone 7, Gen 13)
20:35:27:WU00:FS00:0xa7:Unit: 0x0000000e9bf7a4d65e848f76039ce2ba
20:35:27:WU00:FS00:0xa7:Digital signatures verified
20:35:27:WU00:FS00:0xa7:Reducing thread count from 14 to 13 to avoid domain decomposition with large prime factor 7
20:35:27:WU00:FS00:0xa7:Reducing thread count from 13 to 12 to avoid domain decomposition by a prime number > 3
20:35:27:WU00:FS00:0xa7:Calling: mdrun -s frame13.tpr -o frame13.trr -cpi state.cpt -cpt 15 -nt 12
20:35:27:WU00:FS00:0xa7:ERROR:Guru Meditation #82a41b8b217c78d3.8bb50143827eb3f9 (3110.3729) '00/01/pullx.xvg'
20:35:27:WU00:FS00:0xa7:WARNING:Unexpected exit() call
20:35:27:WU00:FS00:0xa7:WARNING:Unexpected exit from science code
20:35:27:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
20:35:27:WU00:FS00:0xa7:Saving result file dhdl.xvg
20:35:27:WU00:FS00:0xa7:ERROR:Guru Meditation #649e1bf13139c145.db32afef6e57c029 (48408.48918) '00/01/dhdl.xvg'
20:35:29:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
20:35:29:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
20:35:47:WU01:FS01:0x22:Completed 100000 out of 2000000 steps (5%)
20:36:25:WU00:FS00:Starting
20:36:25:WARNING:WU00:FS00:AS lowered CPUs from 15 to 14
20:36:25:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\tobfu\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 12164 -checkpoint 15 -np 14
20:36:26:WU00:FS00:Started FahCore on PID 1596
20:36:26:WU00:FS00:Core PID:1820
20:36:26:WU00:FS00:FahCore 0xa7 started
20:36:26:WU00:FS00:0xa7:*********************** Log Started 2020-04-06T20:36:26Z ***********************
20:36:26:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
20:36:26:WU00:FS00:0xa7:       Type: 0xa7
20:36:27:WU00:FS00:0xa7:       Core: Gromacs
20:36:27:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 1596 -checkpoint 15 -np
20:36:27:WU00:FS00:0xa7:             14
20:36:27:WU00:FS00:0xa7:************************************ CBang *************************************
20:36:27:WU00:FS00:0xa7:       Date: Oct 26 2019
20:36:27:WU00:FS00:0xa7:       Time: 01:38:25
20:36:27:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
20:36:27:WU00:FS00:0xa7:     Branch: master
20:36:27:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
20:36:27:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:36:27:WU00:FS00:0xa7:   Platform: win32 10
20:36:27:WU00:FS00:0xa7:       Bits: 64
20:36:27:WU00:FS00:0xa7:       Mode: Release
20:36:27:WU00:FS00:0xa7:************************************ System ************************************
20:36:27:WU00:FS00:0xa7:        CPU: AMD Ryzen 7 1700 Eight-Core Processor
20:36:27:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
20:36:27:WU00:FS00:0xa7:       CPUs: 16
20:36:27:WU00:FS00:0xa7:     Memory: 7.94GiB
20:36:27:WU00:FS00:0xa7:Free Memory: 4.18GiB
20:36:27:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
20:36:27:WU00:FS00:0xa7: OS Version: 6.2
20:36:27:WU00:FS00:0xa7:Has Battery: false
20:36:27:WU00:FS00:0xa7: On Battery: false
20:36:27:WU00:FS00:0xa7: UTC Offset: 2
20:36:27:WU00:FS00:0xa7:        PID: 1820
20:36:27:WU00:FS00:0xa7:        CWD: C:\Users\tobfu\AppData\Roaming\FAHClient\work
20:36:27:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
20:36:27:WU00:FS00:0xa7:    Version: 0.0.18
20:36:27:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:36:27:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
20:36:27:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
20:36:27:WU00:FS00:0xa7:       Time: 01:52:30
20:36:27:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
20:36:27:WU00:FS00:0xa7:************************************ Build *************************************
20:36:27:WU00:FS00:0xa7:       SIMD: avx_256
20:36:27:WU00:FS00:0xa7:********************************************************************************
20:36:27:WU00:FS00:0xa7:Project: 14613 (Run 307, Clone 7, Gen 13)
20:36:27:WU00:FS00:0xa7:Unit: 0x0000000e9bf7a4d65e848f76039ce2ba
20:36:27:WU00:FS00:0xa7:Digital signatures verified
20:36:27:WU00:FS00:0xa7:Reducing thread count from 14 to 13 to avoid domain decomposition with large prime factor 7
20:36:27:WU00:FS00:0xa7:Reducing thread count from 13 to 12 to avoid domain decomposition by a prime number > 3
20:36:27:WU00:FS00:0xa7:Calling: mdrun -s frame13.tpr -o frame13.trr -cpi state.cpt -cpt 15 -nt 12
20:36:27:WU00:FS00:0xa7:ERROR:Guru Meditation #82a41b8b217c78d3.8bb50143827eb3f9 (3110.3729) '00/01/pullx.xvg'
20:36:27:WU00:FS00:0xa7:WARNING:Unexpected exit() call
20:36:27:WU00:FS00:0xa7:WARNING:Unexpected exit from science code
20:36:27:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
20:36:27:WU00:FS00:0xa7:Saving result file dhdl.xvg
20:36:27:WU00:FS00:0xa7:ERROR:Guru Meditation #649e1bf13139c145.db32afef6e57c029 (48408.48918) '00/01/dhdl.xvg'
20:36:29:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
20:36:29:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
20:37:25:WU00:FS00:Starting
20:37:25:WARNING:WU00:FS00:AS lowered CPUs from 15 to 14
20:37:25:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\tobfu\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 12164 -checkpoint 15 -np 14
20:37:26:WU00:FS00:Started FahCore on PID 2588
20:37:26:WU00:FS00:Core PID:3912
20:37:26:WU00:FS00:FahCore 0xa7 started
20:37:27:WU00:FS00:0xa7:*********************** Log Started 2020-04-06T20:37:26Z ***********************
20:37:27:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
20:37:27:WU00:FS00:0xa7:       Type: 0xa7
20:37:27:WU00:FS00:0xa7:       Core: Gromacs
20:37:27:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 2588 -checkpoint 15 -np
20:37:27:WU00:FS00:0xa7:             14
20:37:27:WU00:FS00:0xa7:************************************ CBang *************************************
20:37:27:WU00:FS00:0xa7:       Date: Oct 26 2019
20:37:27:WU00:FS00:0xa7:       Time: 01:38:25
20:37:27:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
20:37:27:WU00:FS00:0xa7:     Branch: master
20:37:27:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
20:37:27:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:37:27:WU00:FS00:0xa7:   Platform: win32 10
20:37:27:WU00:FS00:0xa7:       Bits: 64
20:37:27:WU00:FS00:0xa7:       Mode: Release
20:37:27:WU00:FS00:0xa7:************************************ System ************************************
20:37:27:WU00:FS00:0xa7:        CPU: AMD Ryzen 7 1700 Eight-Core Processor
20:37:27:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
20:37:27:WU00:FS00:0xa7:       CPUs: 16
20:37:27:WU00:FS00:0xa7:     Memory: 7.94GiB
20:37:27:WU00:FS00:0xa7:Free Memory: 3.71GiB
20:37:27:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
20:37:27:WU00:FS00:0xa7: OS Version: 6.2
20:37:27:WU00:FS00:0xa7:Has Battery: false
20:37:27:WU00:FS00:0xa7: On Battery: false
20:37:27:WU00:FS00:0xa7: UTC Offset: 2
20:37:27:WU00:FS00:0xa7:        PID: 3912
20:37:27:WU00:FS00:0xa7:        CWD: C:\Users\tobfu\AppData\Roaming\FAHClient\work
20:37:27:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
20:37:27:WU00:FS00:0xa7:    Version: 0.0.18
20:37:27:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:37:27:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
20:37:27:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
20:37:27:WU00:FS00:0xa7:       Time: 01:52:30
20:37:27:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
20:37:27:WU00:FS00:0xa7:************************************ Build *************************************
20:37:27:WU00:FS00:0xa7:       SIMD: avx_256
20:37:27:WU00:FS00:0xa7:********************************************************************************
20:37:27:WU00:FS00:0xa7:Project: 14613 (Run 307, Clone 7, Gen 13)
20:37:27:WU00:FS00:0xa7:Unit: 0x0000000e9bf7a4d65e848f76039ce2ba
20:37:27:WU00:FS00:0xa7:Digital signatures verified
20:37:27:WU00:FS00:0xa7:Reducing thread count from 14 to 13 to avoid domain decomposition with large prime factor 7
20:37:27:WU00:FS00:0xa7:Reducing thread count from 13 to 12 to avoid domain decomposition by a prime number > 3
20:37:27:WU00:FS00:0xa7:Calling: mdrun -s frame13.tpr -o frame13.trr -cpi state.cpt -cpt 15 -nt 12
20:37:27:WU00:FS00:0xa7:ERROR:Guru Meditation #82a41b8b217c78d3.8bb50143827eb3f9 (3110.3729) '00/01/pullx.xvg'
20:37:27:WU00:FS00:0xa7:WARNING:Unexpected exit() call
20:37:27:WU00:FS00:0xa7:WARNING:Unexpected exit from science code
20:37:27:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
20:37:27:WU00:FS00:0xa7:Saving result file dhdl.xvg
20:37:27:WU00:FS00:0xa7:ERROR:Guru Meditation #649e1bf13139c145.db32afef6e57c029 (48408.48918) '00/01/dhdl.xvg'
20:37:29:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
20:37:29:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
20:37:29:WARNING:WU00:FS00:Too many errors, failing
20:37:29:WU00:FS00:Sending unit results: id:00 state:SEND error:FAILED project:14613 run:307 clone:7 gen:13 core:0xa7 unit:0x0000000e9bf7a4d65e848f76039ce2ba
20:37:29:WU00:FS00:Connecting to 155.247.164.214:8080
20:37:29:WU00:FS00:Server responded WORK_ACK (400)
20:37:29:WU00:FS00:Cleaning up
20:37:29:WU02:FS00:Connecting to 65.254.110.245:8080
20:37:30:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:37:30:WU02:FS00:Connecting to 18.218.241.186:80
20:37:30:WU02:FS00:Assigned to work server 128.252.203.10
20:37:30:WU02:FS00:Requesting new work unit for slot 00: READY cpu:15 from 128.252.203.10
20:37:30:WU02:FS00:Connecting to 128.252.203.10:8080
20:37:50:WU01:FS01:0x22:Completed 120000 out of 2000000 steps (6%)
20:37:57:ERROR:WU02:FS00:Exception: Server did not assign work unit
20:37:57:WU02:FS00:Connecting to 65.254.110.245:8080
20:37:58:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:37:58:WU02:FS00:Connecting to 18.218.241.186:80
20:37:58:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:37:58:ERROR:WU02:FS00:Exception: Could not get an assignment
20:38:57:WU02:FS00:Connecting to 65.254.110.245:8080
20:38:58:WU02:FS00:Assigned to work server 13.90.152.57
20:38:58:WU02:FS00:Requesting new work unit for slot 00: READY cpu:15 from 13.90.152.57
20:38:58:WU02:FS00:Connecting to 13.90.152.57:8080
20:38:58:ERROR:WU02:FS00:Exception: Server did not assign work unit
20:39:52:WU01:FS01:0x22:Completed 140000 out of 2000000 steps (7%)
20:40:34:WU02:FS00:Connecting to 65.254.110.245:8080
20:40:35:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:40:35:WU02:FS00:Connecting to 18.218.241.186:80
20:40:35:WU02:FS00:Assigned to work server 13.82.98.119
20:40:35:WU02:FS00:Requesting new work unit for slot 00: READY cpu:15 from 13.82.98.119
20:40:35:WU02:FS00:Connecting to 13.82.98.119:8080
20:40:36:WU02:FS00:Downloading 7.46MiB
20:40:39:WU02:FS00:Download complete
20:40:39:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:13871 run:0 clone:1539 gen:33 core:0xa7 unit:0x000000280d5262775e791b794a3cfb56
20:40:39:WU02:FS00:Starting
20:40:39:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\tobfu\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 12164 -checkpoint 15 -np 15
20:40:39:WU02:FS00:Started FahCore on PID 16544
20:40:40:WU02:FS00:Core PID:2000
20:40:40:WU02:FS00:FahCore 0xa7 started
20:40:40:WU02:FS00:0xa7:*********************** Log Started 2020-04-06T20:40:40Z ***********************
20:40:40:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
20:40:40:WU02:FS00:0xa7:       Type: 0xa7
20:40:40:WU02:FS00:0xa7:       Core: Gromacs
20:40:40:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 16544 -checkpoint 15 -np
20:40:40:WU02:FS00:0xa7:             15
20:40:40:WU02:FS00:0xa7:************************************ CBang *************************************
20:40:40:WU02:FS00:0xa7:       Date: Oct 26 2019
20:40:40:WU02:FS00:0xa7:       Time: 01:38:25
20:40:40:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
20:40:40:WU02:FS00:0xa7:     Branch: master
20:40:40:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
20:40:40:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:40:40:WU02:FS00:0xa7:   Platform: win32 10
20:40:40:WU02:FS00:0xa7:       Bits: 64
20:40:40:WU02:FS00:0xa7:       Mode: Release
20:40:40:WU02:FS00:0xa7:************************************ System ************************************
20:40:40:WU02:FS00:0xa7:        CPU: AMD Ryzen 7 1700 Eight-Core Processor
20:40:40:WU02:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
20:40:40:WU02:FS00:0xa7:       CPUs: 16
20:40:40:WU02:FS00:0xa7:     Memory: 7.94GiB
20:40:40:WU02:FS00:0xa7:Free Memory: 3.70GiB
20:40:40:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
20:40:40:WU02:FS00:0xa7: OS Version: 6.2
20:40:40:WU02:FS00:0xa7:Has Battery: false
20:40:40:WU02:FS00:0xa7: On Battery: false
20:40:40:WU02:FS00:0xa7: UTC Offset: 2
20:40:40:WU02:FS00:0xa7:        PID: 2000
20:40:40:WU02:FS00:0xa7:        CWD: C:\Users\tobfu\AppData\Roaming\FAHClient\work
20:40:40:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
20:40:40:WU02:FS00:0xa7:    Version: 0.0.18
20:40:40:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:40:40:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
20:40:40:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
20:40:40:WU02:FS00:0xa7:       Time: 01:52:30
20:40:40:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
20:40:40:WU02:FS00:0xa7:************************************ Build *************************************
20:40:40:WU02:FS00:0xa7:       SIMD: avx_256
20:40:40:WU02:FS00:0xa7:********************************************************************************
20:40:40:WU02:FS00:0xa7:Project: 13871 (Run 0, Clone 1539, Gen 33)
20:40:40:WU02:FS00:0xa7:Unit: 0x000000280d5262775e791b794a3cfb56
20:40:40:WU02:FS00:0xa7:Reading tar file core.xml
20:40:40:WU02:FS00:0xa7:Reading tar file frame33.tpr
20:40:40:WU02:FS00:0xa7:Digital signatures verified
20:40:40:WU02:FS00:0xa7:Calling: mdrun -s frame33.tpr -o frame33.trr -x frame33.xtc -e frame33.edr -cpt 15 -nt 15
20:40:40:WU02:FS00:0xa7:Steps: first=4125000 total=125000
20:40:45:WU02:FS00:0xa7:Completed 1 out of 125000 steps (0%)
[/quote]
Re: Error Message CPU
The Guru Meditation error messages usually indicate that the folding core had trouble opening one or more files in its work folder. The file was either corrupted, locked by being open for another process, or an actual filesystem fault. Since it eventually failed after too many errors, it uploaded an error report and cleaned out the work directory. So now not able to check the files for the problem.
Folding@Home uses a science package called GROMACS, and GROMACS hates 'large' prime numbers and multiples of large prime numbers. 7 is always large, sometimes 5 is large, 3 never is.
[I am making the rest of this up, you did not post the configuration portion of your log, so I am guessing]
Your Ryzen 7 1700 has 16 threads, F@H calls them CPUs. and 16 is ideal, 2 x 2 x2 x 2, no large primes.
But I am guessing you have a GPU that F@H saw, so it reserved one CPU for it leaving 15.
Sadly 15 is 3 x 5 so it lowered it to 14. Sadly 14 is 2 x 7, so it lowered it to 13, which is prime so it lowered it to 12.
About then it crashed.
I recommend setting it to 12 yourself, and I am going to post generic instructions below for Windows. (I am guessing you have Windows)
If you have GPUs, F@H reserves one CPU per GPU to feed it data across the PCIE bus.
F@H has difficulty with large primes and their multiples number of CPUs.
7 is always large, 5 is sometimes large, and 3 is never large. Try to choose a number that is a multiple of 2 and/or 3.
2, 3, 4, 6, 8, 9, 12, 16. are good numbers of CPUs to choose.
5. 10. 15 may work most of the time. Other numbers will bite you
Type the number you want, and click save. (I suggest 12)
If that does not help, post the first 200 lines of the Logs, so we can see what F@H thinks your PC looks like.
[edit: Joe_H's advice looks better than my advice]
Lasky
Post by Lasky »
wow your analysis is right, that's it...i'm gonna bring that number down to 12...
12 = 12 threads is right ? what happens with the other 3 threads ? are they still used or do they fall out ?
uyaem
Post by uyaem »
If you really want to max the machine out, you could open another CPU slot with 3, as 3 is never large.
Could also go 8/6 for a total of 14 used threads.
PS: From the point of view of FAH, a "CPU" is a thread. I believe the terminology was chosen long before "hyperthreading" was around.
Lasky
Post by Lasky »
uyaem wrote:If you really want to max the machine out, you could open another CPU slot with 3, as 3 is never large.
PS: From the point of view of FAH, a "core" is a thread. I believe the terminology was chosen long before "hyperthreading" was around.
F@H sees 1 core as 2 threads...
i have 8 core, 15 threads + 1 thread for the GPU...
uyaem
Post by uyaem »
Lasky wrote:F@H sees 1 core as 2 threads...
Just to clarify if we have just a misunderstanding or if one of us is wrong. ;)
I have an i7-2600k, which is 4 cores 8 threads.
If I were configuring FAH manually, I'd have to set the CPUs setting in FAHControl to 6 if I wanted to use 6 threads. Correct?
PS: I edited my previous posting, I meant "CPUs", referring to the label in the UI, not "cores" as you quoted originally. :)
Lasky
Post by Lasky »
correctly detected, 6 = 6 threads, 15 = 15 thread, 12 = 12 threads...
this is what he shows you in your browser
