Radeon HD 7350 Fails to Fold
FL_Folder
Post by FL_Folder »
Running on Win-10-1903 Pro, updated drivers, log shows "An existing connection was forcibly closed by the remote host" and "An established connection was aborted by the software in your host machine"
Can I assume I'm missing a config setting somewhere?
FL_Folder
Re: Radeon HD 7350 Fails to Fold
Post by FL_Folder »
System Info suggests: Failed to open NVCUDA.DLL
Is this related?
ipkh
Post by ipkh »
Please post at least the first 200 lines of the log.
AMD cards don't have Cuda so that doesn't seem likely.
Unfortunately the HD 7350 does not support hardware double precision and all active FAH projects now require that support.
