Radeon HD 6570 not connecting
Sven2186
Post by Sven2186 »
Log shows attempting to connect to 192.0.2.1 ports 8080 and 80, connection fails. I have read similar posts and the issue may be my how my device is identified and it is unable to pull WUs. I am running an AMD Radeon HD6750 PCI id: 1002-6759 from GPU-Z. I have attempted removing the slot and readding it as well as connection resets and computer restart. Please advise if I can get this up an running. I know its not a lot of power but every bit helps.
Re: Radeon HD 6570 not connecting
The HD 6570 is no longer supported for GPU folding. It does not support Double Precision calculations that are needed for a small part of the WU processing.
You can still contribute by doing folding on your system's CPU.
https://www.techpowerup.com/gpu-specs/r ... -6570.c277
You can see no Double Precision floating point math.
