Problem with WU 14541
hell_alex92
Post by hell_alex92 »
Hey guys, I've been folding about 115 WUs in the past 2 weeks, every WU were fine until today. All of a sudden WU 14541 is causing trouble with the program.. nothing OCed, no new Drivers, just a simple Computer start like every day.
Here is the Log:
*********************** Log Started 2020-03-31T10:59:05Z ***********************
10:59:05:WU00:FS01:Connecting to 65.254.110.245:8080
10:59:06:WU00:FS01:Assigned to work server 13.82.98.119
10:59:06:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Vega 10 XL/XT [Radeon RX Vega 56/64] from 13.82.98.119
10:59:06:WU00:FS01:Connecting to 13.82.98.119:8080
10:59:07:WU00:FS01:Downloading 11.57MiB
10:59:11:WU00:FS01:Download complete
10:59:11:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14541 run:0 clone:1133 gen:2 core:0x22 unit:0x000000030d5262775e7d25221ad83738
10:59:11:WU00:FS01:Starting
10:59:11:WU00:FS01:Running FahCore: D:\FAHClient/FAHCoreWrapper.exe C:\Users\[Name]\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 3948 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
10:59:11:WU00:FS01:Started FahCore on PID 9188
10:59:11:WU00:FS01:Core PID:4948
10:59:11:WU00:FS01:FahCore 0x22 started
10:59:12:WU00:FS01:0x22:*********************** Log Started 2020-03-31T10:59:11Z ***********************
10:59:12:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
10:59:12:WU00:FS01:0x22:       Type: 0x22
10:59:12:WU00:FS01:0x22:       Core: Core22
10:59:12:WU00:FS01:0x22:    Website: https://foldingathome.org/
10:59:12:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
10:59:12:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
10:59:12:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
10:59:12:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 705 -lifeline 9188 -checkpoint 15
10:59:12:WU00:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
10:59:12:WU00:FS01:0x22:     Config: <none>
10:59:12:WU00:FS01:0x22:************************************ Build *************************************
10:59:12:WU00:FS01:0x22:    Version: 0.0.2
10:59:12:WU00:FS01:0x22:       Date: Dec 6 2019
10:59:12:WU00:FS01:0x22:       Time: 21:30:31
10:59:12:WU00:FS01:0x22: Repository: Git
10:59:12:WU00:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
10:59:12:WU00:FS01:0x22:     Branch: HEAD
10:59:12:WU00:FS01:0x22:   Compiler: Visual C++ 2008
10:59:12:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:59:12:WU00:FS01:0x22:   Platform: win32 10
10:59:12:WU00:FS01:0x22:       Bits: 64
10:59:12:WU00:FS01:0x22:       Mode: Release
10:59:12:WU00:FS01:0x22:************************************ System ************************************
10:59:12:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i7-7700K CPU @ 4.20GHz
10:59:12:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
10:59:12:WU00:FS01:0x22:       CPUs: 8
10:59:12:WU00:FS01:0x22:     Memory: 15.95GiB
10:59:12:WU00:FS01:0x22:Free Memory: 12.62GiB
10:59:12:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
10:59:12:WU00:FS01:0x22: OS Version: 6.2
10:59:12:WU00:FS01:0x22:Has Battery: false
10:59:12:WU00:FS01:0x22: On Battery: false
10:59:12:WU00:FS01:0x22: UTC Offset: 2
10:59:12:WU00:FS01:0x22:        PID: 4948
10:59:12:WU00:FS01:0x22:        CWD: C:\Users\[Name]\AppData\Roaming\FAHClient\work
10:59:12:WU00:FS01:0x22:         OS: Windows 10 Pro
10:59:12:WU00:FS01:0x22:    OS Arch: AMD64
10:59:12:WU00:FS01:0x22:********************************************************************************
10:59:12:WU00:FS01:0x22:Project: 14541 (Run 0, Clone 1133, Gen 2)
10:59:12:WU00:FS01:0x22:Unit: 0x000000030d5262775e7d25221ad83738
10:59:12:WU00:FS01:0x22:Reading tar file core.xml
10:59:12:WU00:FS01:0x22:Reading tar file integrator.xml
10:59:12:WU00:FS01:0x22:Reading tar file state.xml
10:59:12:WU00:FS01:0x22:Reading tar file system.xml
10:59:12:WU00:FS01:0x22:Digital signatures verified
10:59:12:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
10:59:12:WU00:FS01:0x22:Version 0.0.2
10:59:21:WU00:FS01:0x22:Completed 0 out of 8000000 steps (0%)
10:59:21:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
11:01:29:WU00:FS01:0x22:Completed 80000 out of 8000000 steps (1%)
11:03:30:WU00:FS01:0x22:Completed 160000 out of 8000000 steps (2%)
11:04:54:WU00:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
11:04:54:WU00:FS01:0x22:Following exception occured: Particle coordinate is nan
11:05:29:WU00:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
11:05:29:WU00:FS01:0x22:Following exception occured: Particle coordinate is nan
11:06:29:WU00:FS01:0x22:Completed 240000 out of 8000000 steps (3%)
11:08:37:WU00:FS01:0x22:Completed 320000 out of 8000000 steps (4%)
11:10:55:WU00:FS01:0x22:Completed 400000 out of 8000000 steps (5%)
11:13:52:WU00:FS01:0x22:Completed 480000 out of 8000000 steps (6%)
11:15:56:WU00:FS01:0x22:Completed 560000 out of 8000000 steps (7%)
11:18:00:WU00:FS01:0x22:Completed 640000 out of 8000000 steps (8%)
11:20:04:WU00:FS01:0x22:Completed 720000 out of 8000000 steps (9%)
11:22:07:WU00:FS01:0x22:Completed 800000 out of 8000000 steps (10%)
11:24:12:WU00:FS01:0x22:Completed 880000 out of 8000000 steps (11%)
11:26:16:WU00:FS01:0x22:Completed 960000 out of 8000000 steps (12%)
11:28:21:WU00:FS01:0x22:Completed 1040000 out of 8000000 steps (13%)
11:30:25:WU00:FS01:0x22:Completed 1120000 out of 8000000 steps (14%)
11:32:29:WU00:FS01:0x22:Completed 1200000 out of 8000000 steps (15%)
11:34:33:WU00:FS01:0x22:Completed 1280000 out of 8000000 steps (16%)
11:36:37:WU00:FS01:0x22:Completed 1360000 out of 8000000 steps (17%)
11:37:27:WU00:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
11:37:27:WU00:FS01:0x22:Following exception occured: Particle coordinate is nan
11:37:27:WU00:FS01:0x22:ERROR:114: Max Retries Reached
11:37:27:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
11:37:27:WU00:FS01:0x22:Saving result file badstate-0.xml
11:37:27:WU00:FS01:0x22:Saving result file badstate-1.xml
11:37:27:WU00:FS01:0x22:Saving result file badstate-2.xml
11:37:27:WU00:FS01:0x22:Saving result file checkpointState.xml
11:37:27:WU00:FS01:0x22:Saving result file checkpt.crc
11:37:27:WU00:FS01:0x22:Saving result file positions.xtc
11:37:27:WU00:FS01:0x22:Saving result file science.log
11:37:27:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
11:37:29:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
11:37:29:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:14541 run:0 clone:1133 gen:2 core:0x22 unit:0x000000030d5262775e7d25221ad83738
11:37:29:WU00:FS01:Uploading 15.44MiB to 13.82.98.119
11:37:29:WU00:FS01:Connecting to 13.82.98.119:8080
11:37:29:WU02:FS01:Connecting to 65.254.110.245:8080
11:37:29:WU02:FS01:Assigned to work server 13.82.98.119
11:37:29:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Vega 10 XL/XT [Radeon RX Vega 56/64] from 13.82.98.119
11:37:29:WU02:FS01:Connecting to 13.82.98.119:8080
11:37:30:WU02:FS01:Downloading 11.57MiB
11:37:35:WU00:FS01:Upload 19.43%
11:37:35:WU02:FS01:Download complete
11:37:35:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:14541 run:0 clone:782 gen:5 core:0x22 unit:0x000000080d5262775e7d25231a700244
11:37:35:WU02:FS01:Starting
11:37:35:WU02:FS01:Running FahCore: D:\FAHClient/FAHCoreWrapper.exe C:\Users\[Name]\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 705 -lifeline 3948 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
11:37:35:WU02:FS01:Started FahCore on PID 1084
11:37:35:WU02:FS01:Core PID:8536
11:37:35:WU02:FS01:FahCore 0x22 started
11:37:36:WU02:FS01:0x22:*********************** Log Started 2020-03-31T11:37:36Z ***********************
11:37:36:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
11:37:36:WU02:FS01:0x22:       Type: 0x22
11:37:36:WU02:FS01:0x22:       Core: Core22
11:37:36:WU02:FS01:0x22:    Website: https://foldingathome.org/
11:37:36:WU02:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
11:37:36:WU02:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
11:37:36:WU02:FS01:0x22:             <rafal.wiewiora@choderalab.org>
11:37:36:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 705 -lifeline 1084 -checkpoint 15
11:37:36:WU02:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
11:37:36:WU02:FS01:0x22:     Config: <none>
11:37:36:WU02:FS01:0x22:************************************ Build *************************************
11:37:36:WU02:FS01:0x22:    Version: 0.0.2
11:37:36:WU02:FS01:0x22:       Date: Dec 6 2019
11:37:36:WU02:FS01:0x22:       Time: 21:30:31
11:37:36:WU02:FS01:0x22: Repository: Git
11:37:36:WU02:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
11:37:36:WU02:FS01:0x22:     Branch: HEAD
11:37:36:WU02:FS01:0x22:   Compiler: Visual C++ 2008
11:37:36:WU02:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:37:36:WU02:FS01:0x22:   Platform: win32 10
11:37:36:WU02:FS01:0x22:       Bits: 64
11:37:36:WU02:FS01:0x22:       Mode: Release
11:37:36:WU02:FS01:0x22:************************************ System ************************************
11:37:36:WU02:FS01:0x22:        CPU: Intel(R) Core(TM) i7-7700K CPU @ 4.20GHz
11:37:36:WU02:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
11:37:36:WU02:FS01:0x22:       CPUs: 8
11:37:36:WU02:FS01:0x22:     Memory: 15.95GiB
11:37:36:WU02:FS01:0x22:Free Memory: 12.42GiB
11:37:36:WU02:FS01:0x22:    Threads: WINDOWS_THREADS
11:37:36:WU02:FS01:0x22: OS Version: 6.2
11:37:36:WU02:FS01:0x22:Has Battery: false
11:37:36:WU02:FS01:0x22: On Battery: false
11:37:36:WU02:FS01:0x22: UTC Offset: 2
11:37:36:WU02:FS01:0x22:        PID: 8536
11:37:36:WU02:FS01:0x22:        CWD: C:\Users\[Name]\AppData\Roaming\FAHClient\work
11:37:36:WU02:FS01:0x22:         OS: Windows 10 Pro
11:37:36:WU02:FS01:0x22:    OS Arch: AMD64
11:37:36:WU02:FS01:0x22:********************************************************************************
11:37:36:WU02:FS01:0x22:Project: 14541 (Run 0, Clone 782, Gen 5)
11:37:36:WU02:FS01:0x22:Unit: 0x000000080d5262775e7d25231a700244
11:37:36:WU02:FS01:0x22:Reading tar file core.xml
11:37:36:WU02:FS01:0x22:Reading tar file integrator.xml
11:37:36:WU02:FS01:0x22:Reading tar file state.xml
11:37:36:WU02:FS01:0x22:Reading tar file system.xml
11:37:36:WU02:FS01:0x22:Digital signatures verified
11:37:36:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
11:37:36:WU02:FS01:0x22:Version 0.0.2
11:37:41:WU00:FS01:Upload 42.51%
11:37:44:WU02:FS01:0x22:Completed 0 out of 8000000 steps (0%)
11:37:44:WU02:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
11:37:47:WU00:FS01:Upload 63.96%
11:37:53:WU00:FS01:Upload 75.70%
11:37:59:WU00:FS01:Upload 95.54%
11:38:00:WU00:FS01:Upload complete
11:38:00:WU00:FS01:Server responded WORK_ACK (400)
11:38:00:WU00:FS01:Cleaning up
11:38:46:WU02:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
11:38:46:WU02:FS01:0x22:Following exception occured: Particle coordinate is nan
11:39:50:WU02:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
11:39:50:WU02:FS01:0x22:Following exception occured: Particle coordinate is nan
11:41:32:WU02:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
11:41:32:WU02:FS01:0x22:Following exception occured: Particle coordinate is nan
11:41:32:WU02:FS01:0x22:ERROR:114: Max Retries Reached
11:41:32:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
11:41:32:WU02:FS01:0x22:Saving result file badstate-0.xml
11:41:32:WU02:FS01:0x22:Saving result file badstate-1.xml
11:41:32:WU02:FS01:0x22:Saving result file badstate-2.xml
11:41:33:WU02:FS01:0x22:Saving result file checkpointState.xml
11:41:33:WU02:FS01:0x22:Saving result file checkpt.crc
11:41:33:WU02:FS01:0x22:Saving result file positions.xtc
11:41:33:WU02:FS01:0x22:Saving result file science.log
11:41:33:WU02:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
11:41:33:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
11:41:33:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:14541 run:0 clone:782 gen:5 core:0x22 unit:0x000000080d5262775e7d25231a700244
11:41:33:WU02:FS01:Uploading 13.45MiB to 13.82.98.119
11:41:33:WU02:FS01:Connecting to 13.82.98.119:8080
11:41:33:WU00:FS01:Connecting to 65.254.110.245:8080
11:41:34:WU00:FS01:Assigned to work server 13.82.98.119
11:41:34:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Vega 10 XL/XT [Radeon RX Vega 56/64] from 13.82.98.119
11:41:34:WU00:FS01:Connecting to 13.82.98.119:8080
11:41:34:WU00:FS01:Downloading 11.57MiB
11:41:39:WU02:FS01:Upload 22.31%
11:41:39:WU00:FS01:Download complete
11:41:39:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14541 run:0 clone:294 gen:21 core:0x22 unit:0x0000001a0d5262775e7d25235ea19bbf
11:41:39:WU00:FS01:Starting
11:41:39:WU00:FS01:Running FahCore: D:\FAHClient/FAHCoreWrapper.exe C:\Users\[Name]\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 3948 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
11:41:39:WU00:FS01:Started FahCore on PID 5456
11:41:39:WU00:FS01:Core PID:8656
11:41:39:WU00:FS01:FahCore 0x22 started
11:41:40:WU00:FS01:0x22:*********************** Log Started 2020-03-31T11:41:40Z ***********************
11:41:40:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
11:41:40:WU00:FS01:0x22:       Type: 0x22
11:41:40:WU00:FS01:0x22:       Core: Core22
11:41:40:WU00:FS01:0x22:    Website: https://foldingathome.org/
11:41:40:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
11:41:40:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
11:41:40:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
11:41:40:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 705 -lifeline 5456 -checkpoint 15
11:41:40:WU00:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
11:41:40:WU00:FS01:0x22:     Config: <none>
11:41:40:WU00:FS01:0x22:************************************ Build *************************************
11:41:40:WU00:FS01:0x22:    Version: 0.0.2
11:41:40:WU00:FS01:0x22:       Date: Dec 6 2019
11:41:40:WU00:FS01:0x22:       Time: 21:30:31
11:41:40:WU00:FS01:0x22: Repository: Git
11:41:40:WU00:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
11:41:40:WU00:FS01:0x22:     Branch: HEAD
11:41:40:WU00:FS01:0x22:   Compiler: Visual C++ 2008
11:41:40:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:41:40:WU00:FS01:0x22:   Platform: win32 10
11:41:40:WU00:FS01:0x22:       Bits: 64
11:41:40:WU00:FS01:0x22:       Mode: Release
11:41:40:WU00:FS01:0x22:************************************ System ************************************
11:41:40:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i7-7700K CPU @ 4.20GHz
11:41:40:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
11:41:40:WU00:FS01:0x22:       CPUs: 8
11:41:40:WU00:FS01:0x22:     Memory: 15.95GiB
11:41:40:WU00:FS01:0x22:Free Memory: 12.44GiB
11:41:40:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
11:41:40:WU00:FS01:0x22: OS Version: 6.2
11:41:40:WU00:FS01:0x22:Has Battery: false
11:41:40:WU00:FS01:0x22: On Battery: false
11:41:40:WU00:FS01:0x22: UTC Offset: 2
11:41:40:WU00:FS01:0x22:        PID: 8656
11:41:40:WU00:FS01:0x22:        CWD: C:\Users\[Name]\AppData\Roaming\FAHClient\work
11:41:40:WU00:FS01:0x22:         OS: Windows 10 Pro
11:41:40:WU00:FS01:0x22:    OS Arch: AMD64
11:41:40:WU00:FS01:0x22:********************************************************************************
11:41:40:WU00:FS01:0x22:Project: 14541 (Run 0, Clone 294, Gen 21)
11:41:40:WU00:FS01:0x22:Unit: 0x0000001a0d5262775e7d25235ea19bbf
11:41:40:WU00:FS01:0x22:Reading tar file core.xml
11:41:40:WU00:FS01:0x22:Reading tar file integrator.xml
11:41:40:WU00:FS01:0x22:Reading tar file state.xml
11:41:40:WU00:FS01:0x22:Reading tar file system.xml
11:41:40:WU00:FS01:0x22:Digital signatures verified
11:41:40:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
11:41:40:WU00:FS01:0x22:Version 0.0.2
11:41:45:WU02:FS01:Upload 48.33%
11:41:48:WU00:FS01:0x22:Completed 0 out of 8000000 steps (0%)
11:41:48:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
11:41:51:WU02:FS01:Upload 74.82%
11:41:57:WU02:FS01:Upload complete
11:41:57:WU02:FS01:Server responded WORK_ACK (400)
11:41:57:WU02:FS01:Cleaning up
11:43:54:WU00:FS01:0x22:Completed 80000 out of 8000000 steps (1%)
11:45:58:WU00:FS01:0x22:Completed 160000 out of 8000000 steps (2%)
11:48:02:WU00:FS01:0x22:Completed 240000 out of 8000000 steps (3%)
11:50:07:WU00:FS01:0x22:Completed 320000 out of 8000000 steps (4%)
11:52:11:WU00:FS01:0x22:Completed 400000 out of 8000000 steps (5%)
11:54:18:WU00:FS01:0x22:Completed 480000 out of 8000000 steps (6%)
11:56:24:WU00:FS01:0x22:Completed 560000 out of 8000000 steps (7%)
11:58:29:WU00:FS01:0x22:Completed 640000 out of 8000000 steps (8%)
12:00:33:WU00:FS01:0x22:Completed 720000 out of 8000000 steps (9%)
12:02:36:WU00:FS01:0x22:Completed 800000 out of 8000000 steps (10%)
12:04:41:WU00:FS01:0x22:Completed 880000 out of 8000000 steps (11%)
12:06:47:WU00:FS01:0x22:Completed 960000 out of 8000000 steps (12%)
12:08:52:WU00:FS01:0x22:Completed 1040000 out of 8000000 steps (13%)
12:10:56:WU00:FS01:0x22:Completed 1120000 out of 8000000 steps (14%)
12:13:01:WU00:FS01:0x22:Completed 1200000 out of 8000000 steps (15%)
12:15:06:WU00:FS01:0x22:Completed 1280000 out of 8000000 steps (16%)
12:17:10:WU00:FS01:0x22:Completed 1360000 out of 8000000 steps (17%)
12:19:15:WU00:FS01:0x22:Completed 1440000 out of 8000000 steps (18%)
12:19:31:WU00:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
12:19:31:WU00:FS01:0x22:Following exception occured: Potential energy error of 50.0457, threshold of 10
12:19:31:WU00:FS01:0x22:Reference Potential Energy: -301851 | Given Potential Energy: -301901
12:22:38:WU00:FS01:0x22:Completed 1520000 out of 8000000 steps (19%)
12:24:42:WU00:FS01:0x22:Completed 1600000 out of 8000000 steps (20%)
12:26:48:WU00:FS01:0x22:Completed 1680000 out of 8000000 steps (21%)
12:28:54:WU00:FS01:0x22:Completed 1760000 out of 8000000 steps (22%)
12:30:57:WU00:FS01:0x22:Completed 1840000 out of 8000000 steps (23%)
12:33:03:WU00:FS01:0x22:Completed 1920000 out of 8000000 steps (24%)
12:35:07:WU00:FS01:0x22:Completed 2000000 out of 8000000 steps (25%)
12:37:12:WU00:FS01:0x22:Completed 2080000 out of 8000000 steps (26%)
12:39:17:WU00:FS01:0x22:Completed 2160000 out of 8000000 steps (27%)
12:41:22:WU00:FS01:0x22:Completed 2240000 out of 8000000 steps (28%)
12:43:27:WU00:FS01:0x22:Completed 2320000 out of 8000000 steps (29%)
12:45:30:WU00:FS01:0x22:Completed 2400000 out of 8000000 steps (30%)
12:47:34:WU00:FS01:0x22:Completed 2480000 out of 8000000 steps (31%)
12:49:39:WU00:FS01:0x22:Completed 2560000 out of 8000000 steps (32%)
12:51:43:WU00:FS01:0x22:Completed 2640000 out of 8000000 steps (33%)
12:53:48:WU00:FS01:0x22:Completed 2720000 out of 8000000 steps (34%)
12:55:52:WU00:FS01:0x22:Completed 2800000 out of 8000000 steps (35%)
12:57:56:WU00:FS01:0x22:Completed 2880000 out of 8000000 steps (36%)
12:59:58:WU00:FS01:0x22:Completed 2960000 out of 8000000 steps (37%)
13:02:10:WU00:FS01:0x22:Completed 3040000 out of 8000000 steps (38%)
13:04:15:WU00:FS01:0x22:Completed 3120000 out of 8000000 steps (39%)
13:06:19:WU00:FS01:0x22:Completed 3200000 out of 8000000 steps (40%)
13:08:24:WU00:FS01:0x22:Completed 3280000 out of 8000000 steps (41%)
13:10:28:WU00:FS01:0x22:Completed 3360000 out of 8000000 steps (42%)
13:12:29:WU00:FS01:0x22:Completed 3440000 out of 8000000 steps (43%)
13:14:31:WU00:FS01:0x22:Completed 3520000 out of 8000000 steps (44%)
13:16:39:WU00:FS01:0x22:Completed 3600000 out of 8000000 steps (45%)
13:18:42:WU00:FS01:0x22:Completed 3680000 out of 8000000 steps (46%)
13:20:47:WU00:FS01:0x22:Completed 3760000 out of 8000000 steps (47%)
13:22:52:WU00:FS01:0x22:Completed 3840000 out of 8000000 steps (48%)
13:24:58:WU00:FS01:0x22:Completed 3920000 out of 8000000 steps (49%)
13:27:02:WU00:FS01:0x22:Completed 4000000 out of 8000000 steps (50%)
13:29:08:WU00:FS01:0x22:Completed 4080000 out of 8000000 steps (51%)
13:31:12:WU00:FS01:0x22:Completed 4160000 out of 8000000 steps (52%)
13:33:15:WU00:FS01:0x22:Completed 4240000 out of 8000000 steps (53%)
13:35:21:WU00:FS01:0x22:Completed 4320000 out of 8000000 steps (54%)
13:37:25:WU00:FS01:0x22:Completed 4400000 out of 8000000 steps (55%)
13:39:30:WU00:FS01:0x22:Completed 4480000 out of 8000000 steps (56%)
13:41:35:WU00:FS01:0x22:Completed 4560000 out of 8000000 steps (57%)
13:43:39:WU00:FS01:0x22:Completed 4640000 out of 8000000 steps (58%)
13:45:44:WU00:FS01:0x22:Completed 4720000 out of 8000000 steps (59%)
13:47:47:WU00:FS01:0x22:Completed 4800000 out of 8000000 steps (60%)
13:49:52:WU00:FS01:0x22:Completed 4880000 out of 8000000 steps (61%)
13:51:56:WU00:FS01:0x22:Completed 4960000 out of 8000000 steps (62%)
13:54:00:WU00:FS01:0x22:Completed 5040000 out of 8000000 steps (63%)
13:56:05:WU00:FS01:0x22:Completed 5120000 out of 8000000 steps (64%)
13:58:08:WU00:FS01:0x22:Completed 5200000 out of 8000000 steps (65%)
14:00:13:WU00:FS01:0x22:Completed 5280000 out of 8000000 steps (66%)
14:02:17:WU00:FS01:0x22:Completed 5360000 out of 8000000 steps (67%)
14:04:21:WU00:FS01:0x22:Completed 5440000 out of 8000000 steps (68%)
14:06:24:WU00:FS01:0x22:Completed 5520000 out of 8000000 steps (69%)
14:08:28:WU00:FS01:0x22:Completed 5600000 out of 8000000 steps (70%)
14:10:33:WU00:FS01:0x22:Completed 5680000 out of 8000000 steps (71%)
14:12:38:WU00:FS01:0x22:Completed 5760000 out of 8000000 steps (72%)
14:14:42:WU00:FS01:0x22:Completed 5840000 out of 8000000 steps (73%)
14:16:49:WU00:FS01:0x22:Completed 5920000 out of 8000000 steps (74%)
14:18:52:WU00:FS01:0x22:Completed 6000000 out of 8000000 steps (75%)
14:20:57:WU00:FS01:0x22:Completed 6080000 out of 8000000 steps (76%)
14:23:00:WU00:FS01:0x22:Completed 6160000 out of 8000000 steps (77%)
14:25:03:WU00:FS01:0x22:Completed 6240000 out of 8000000 steps (78%)
14:27:07:WU00:FS01:0x22:Completed 6320000 out of 8000000 steps (79%)
14:29:10:WU00:FS01:0x22:Completed 6400000 out of 8000000 steps (80%)
14:31:15:WU00:FS01:0x22:Completed 6480000 out of 8000000 steps (81%)
14:33:18:WU00:FS01:0x22:Completed 6560000 out of 8000000 steps (82%)
14:35:22:WU00:FS01:0x22:Completed 6640000 out of 8000000 steps (83%)
14:37:26:WU00:FS01:0x22:Completed 6720000 out of 8000000 steps (84%)
14:39:30:WU00:FS01:0x22:Completed 6800000 out of 8000000 steps (85%)
14:41:37:WU00:FS01:0x22:Completed 6880000 out of 8000000 steps (86%)
14:43:42:WU00:FS01:0x22:Completed 6960000 out of 8000000 steps (87%)
14:45:47:WU00:FS01:0x22:Completed 7040000 out of 8000000 steps (88%)
14:47:51:WU00:FS01:0x22:Completed 7120000 out of 8000000 steps (89%)
14:49:54:WU00:FS01:0x22:Completed 7200000 out of 8000000 steps (90%)
14:49:55:WU03:FS01:Connecting to 65.254.110.245:8080
14:49:56:WU03:FS01:Assigned to work server 13.82.98.119
14:49:56:WU03:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:Vega 10 XL/XT [Radeon RX Vega 56/64] from 13.82.98.119
14:49:56:WU03:FS01:Connecting to 13.82.98.119:8080
14:49:56:WU03:FS01:Downloading 11.57MiB
14:50:01:WU03:FS01:Download complete
14:50:01:WU03:FS01:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:14541 run:0 clone:155 gen:13 core:0x22 unit:0x000000130d5262775e7d2523ce0a2bc1
14:51:57:WU00:FS01:0x22:Completed 7280000 out of 8000000 steps (91%)
14:54:02:WU00:FS01:0x22:Completed 7360000 out of 8000000 steps (92%)
14:56:05:WU00:FS01:0x22:Completed 7440000 out of 8000000 steps (93%)
14:58:09:WU00:FS01:0x22:Completed 7520000 out of 8000000 steps (94%)
15:00:12:WU00:FS01:0x22:Completed 7600000 out of 8000000 steps (95%)
15:02:16:WU00:FS01:0x22:Completed 7680000 out of 8000000 steps (96%)
15:04:25:WU00:FS01:0x22:Completed 7760000 out of 8000000 steps (97%)
15:06:30:WU00:FS01:0x22:Completed 7840000 out of 8000000 steps (98%)
15:08:35:WU00:FS01:0x22:Completed 7920000 out of 8000000 steps (99%)
15:10:41:WU00:FS01:0x22:Completed 8000000 out of 8000000 steps (100%)
15:10:42:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
15:10:42:WU00:FS01:0x22:Saving result file badstate-0.xml
15:10:43:WU00:FS01:0x22:Saving result file checkpointState.xml
15:10:43:WU00:FS01:0x22:Saving result file checkpt.crc
15:10:43:WU00:FS01:0x22:Saving result file positions.xtc
15:10:43:WU00:FS01:0x22:Saving result file science.log
15:10:43:WU00:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
15:10:43:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
15:10:43:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:14541 run:0 clone:294 gen:21 core:0x22 unit:0x0000001a0d5262775e7d25235ea19bbf
15:10:43:WU00:FS01:Uploading 24.02MiB to 13.82.98.119
15:10:43:WU00:FS01:Connecting to 13.82.98.119:8080
15:10:43:WU03:FS01:Starting
15:10:43:WU03:FS01:Running FahCore: D:\FAHClient/FAHCoreWrapper.exe C:\Users\[Name]\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 03 -suffix 01 -version 705 -lifeline 3948 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
15:10:43:WU03:FS01:Started FahCore on PID 6488
15:10:43:WU03:FS01:Core PID:10060
15:10:43:WU03:FS01:FahCore 0x22 started
15:10:44:WU03:FS01:0x22:*********************** Log Started 2020-03-31T15:10:44Z ***********************
15:10:44:WU03:FS01:0x22:*************************** Core22 Folding@home Core ***************************
15:10:44:WU03:FS01:0x22:       Type: 0x22
15:10:44:WU03:FS01:0x22:       Core: Core22
15:10:44:WU03:FS01:0x22:    Website: https://foldingathome.org/
15:10:44:WU03:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
15:10:44:WU03:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
15:10:44:WU03:FS01:0x22:             <rafal.wiewiora@choderalab.org>
15:10:44:WU03:FS01:0x22:       Args: -dir 03 -suffix 01 -version 705 -lifeline 6488 -checkpoint 15
15:10:44:WU03:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
15:10:44:WU03:FS01:0x22:     Config: <none>
15:10:44:WU03:FS01:0x22:************************************ Build *************************************
15:10:44:WU03:FS01:0x22:    Version: 0.0.2
15:10:44:WU03:FS01:0x22:       Date: Dec 6 2019
15:10:44:WU03:FS01:0x22:       Time: 21:30:31
15:10:44:WU03:FS01:0x22: Repository: Git
15:10:44:WU03:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
15:10:44:WU03:FS01:0x22:     Branch: HEAD
15:10:44:WU03:FS01:0x22:   Compiler: Visual C++ 2008
15:10:44:WU03:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:10:44:WU03:FS01:0x22:   Platform: win32 10
15:10:44:WU03:FS01:0x22:       Bits: 64
15:10:44:WU03:FS01:0x22:       Mode: Release
15:10:44:WU03:FS01:0x22:************************************ System ************************************
15:10:44:WU03:FS01:0x22:        CPU: Intel(R) Core(TM) i7-7700K CPU @ 4.20GHz
15:10:44:WU03:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
15:10:44:WU03:FS01:0x22:       CPUs: 8
15:10:44:WU03:FS01:0x22:     Memory: 15.95GiB
15:10:44:WU03:FS01:0x22:Free Memory: 12.27GiB
15:10:44:WU03:FS01:0x22:    Threads: WINDOWS_THREADS
15:10:44:WU03:FS01:0x22: OS Version: 6.2
15:10:44:WU03:FS01:0x22:Has Battery: false
15:10:44:WU03:FS01:0x22: On Battery: false
15:10:44:WU03:FS01:0x22: UTC Offset: 2
15:10:44:WU03:FS01:0x22:        PID: 10060
15:10:44:WU03:FS01:0x22:        CWD: C:\Users\[Name]\AppData\Roaming\FAHClient\work
15:10:44:WU03:FS01:0x22:         OS: Windows 10 Pro
15:10:44:WU03:FS01:0x22:    OS Arch: AMD64
15:10:44:WU03:FS01:0x22:********************************************************************************
15:10:44:WU03:FS01:0x22:Project: 14541 (Run 0, Clone 155, Gen 13)
15:10:44:WU03:FS01:0x22:Unit: 0x000000130d5262775e7d2523ce0a2bc1
15:10:44:WU03:FS01:0x22:Reading tar file core.xml
15:10:44:WU03:FS01:0x22:Reading tar file integrator.xml
15:10:44:WU03:FS01:0x22:Reading tar file state.xml
15:10:44:WU03:FS01:0x22:Reading tar file system.xml
15:10:45:WU03:FS01:0x22:Digital signatures verified
15:10:45:WU03:FS01:0x22:Folding@home GPU Core22 Folding@home Core
15:10:45:WU03:FS01:0x22:Version 0.0.2
15:10:49:WU00:FS01:Upload 12.49%
15:10:52:WU03:FS01:0x22:Completed 0 out of 8000000 steps (0%)
15:10:52:WU03:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
15:10:55:WU00:FS01:Upload 25.76%
15:11:01:WU00:FS01:Upload 37.22%
15:11:07:WU00:FS01:Upload 51.53%
15:11:13:WU00:FS01:Upload 65.58%
15:11:19:WU00:FS01:Upload 78.33%
15:11:25:WU00:FS01:Upload 93.17%
15:11:28:WU00:FS01:Upload complete
15:11:28:WU00:FS01:Server responded WORK_ACK (400)
15:11:28:WU00:FS01:Final credit estimate, 79827.00 points
15:11:28:WU00:FS01:Cleaning up
15:12:58:WU03:FS01:0x22:Completed 80000 out of 8000000 steps (1%)
15:14:38:WU03:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
15:14:38:WU03:FS01:0x22:Following exception occured: Particle coordinate is nan
15:16:12:WU03:FS01:0x22:Completed 160000 out of 8000000 steps (2%)
15:18:16:WU03:FS01:0x22:Completed 240000 out of 8000000 steps (3%)
15:20:24:WU03:FS01:0x22:Completed 320000 out of 8000000 steps (4%)
15:22:29:WU03:FS01:0x22:Completed 400000 out of 8000000 steps (5%)
15:24:36:WU03:FS01:0x22:Completed 480000 out of 8000000 steps (6%)
15:26:43:WU03:FS01:0x22:Completed 560000 out of 8000000 steps (7%)
15:28:48:WU03:FS01:0x22:Completed 640000 out of 8000000 steps (8%)
15:30:55:WU03:FS01:0x22:Completed 720000 out of 8000000 steps (9%)
15:33:01:WU03:FS01:0x22:Completed 800000 out of 8000000 steps (10%)
15:35:08:WU03:FS01:0x22:Completed 880000 out of 8000000 steps (11%)
15:37:14:WU03:FS01:0x22:Completed 960000 out of 8000000 steps (12%)
15:39:20:WU03:FS01:0x22:Completed 1040000 out of 8000000 steps (13%)
15:41:27:WU03:FS01:0x22:Completed 1120000 out of 8000000 steps (14%)
15:43:32:WU03:FS01:0x22:Completed 1200000 out of 8000000 steps (15%)
15:45:39:WU03:FS01:0x22:Completed 1280000 out of 8000000 steps (16%)
15:47:45:WU03:FS01:0x22:Completed 1360000 out of 8000000 steps (17%)
15:49:55:WU03:FS01:0x22:Completed 1440000 out of 8000000 steps (18%)
15:52:04:WU03:FS01:0x22:Completed 1520000 out of 8000000 steps (19%)
15:54:09:WU03:FS01:0x22:Completed 1600000 out of 8000000 steps (20%)
15:56:16:WU03:FS01:0x22:Completed 1680000 out of 8000000 steps (21%)
15:58:22:WU03:FS01:0x22:Completed 1760000 out of 8000000 steps (22%)
16:00:28:WU03:FS01:0x22:Completed 1840000 out of 8000000 steps (23%)
16:02:34:WU03:FS01:0x22:Completed 1920000 out of 8000000 steps (24%)
16:04:39:WU03:FS01:0x22:Completed 2000000 out of 8000000 steps (25%)
16:06:45:WU03:FS01:0x22:Completed 2080000 out of 8000000 steps (26%)
16:08:52:WU03:FS01:0x22:Completed 2160000 out of 8000000 steps (27%)
16:10:57:WU03:FS01:0x22:Completed 2240000 out of 8000000 steps (28%)
16:13:00:WU03:FS01:0x22:Completed 2320000 out of 8000000 steps (29%)
16:15:02:WU03:FS01:0x22:Completed 2400000 out of 8000000 steps (30%)
16:17:06:WU03:FS01:0x22:Completed 2480000 out of 8000000 steps (31%)
16:19:10:WU03:FS01:0x22:Completed 2560000 out of 8000000 steps (32%)
16:21:13:WU03:FS01:0x22:Completed 2640000 out of 8000000 steps (33%)
16:23:17:WU03:FS01:0x22:Completed 2720000 out of 8000000 steps (34%)
16:25:21:WU03:FS01:0x22:Completed 2800000 out of 8000000 steps (35%)
16:27:24:WU03:FS01:0x22:Completed 2880000 out of 8000000 steps (36%)
16:29:27:WU03:FS01:0x22:Completed 2960000 out of 8000000 steps (37%)
16:31:29:WU03:FS01:0x22:Completed 3040000 out of 8000000 steps (38%)
16:33:32:WU03:FS01:0x22:Completed 3120000 out of 8000000 steps (39%)
16:35:33:WU03:FS01:0x22:Completed 3200000 out of 8000000 steps (40%)
16:36:32:WU03:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
16:36:32:WU03:FS01:0x22:Following exception occured: Particle coordinate is nan
16:36:44:WU03:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
16:36:44:WU03:FS01:0x22:Following exception occured: Particle coordinate is nan
16:36:44:WU03:FS01:0x22:ERROR:114: Max Retries Reached
16:36:44:WU03:FS01:0x22:Saving result file ..\logfile_01.txt
16:36:44:WU03:FS01:0x22:Saving result file badstate-0.xml
16:36:44:WU03:FS01:0x22:Saving result file badstate-1.xml
16:36:44:WU03:FS01:0x22:Saving result file badstate-2.xml
16:36:44:WU03:FS01:0x22:Saving result file checkpointState.xml
16:36:44:WU03:FS01:0x22:Saving result file checkpt.crc
16:36:44:WU03:FS01:0x22:Saving result file positions.xtc
16:36:45:WU03:FS01:0x22:Saving result file science.log
16:36:45:WU03:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
16:36:45:WARNING:WU03:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
16:36:45:WU03:FS01:Sending unit results: id:03 state:SEND error:FAULTY project:14541 run:0 clone:155 gen:13 core:0x22 unit:0x000000130d5262775e7d2523ce0a2bc1
16:36:45:WU03:FS01:Uploading 18.59MiB to 13.82.98.119
16:36:45:WU03:FS01:Connecting to 13.82.98.119:8080
16:36:45:WU00:FS01:Connecting to 65.254.110.245:8080
16:36:46:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:36:46:WU00:FS01:Connecting to 18.218.241.186:80
16:36:47:WU00:FS01:Assigned to work server 13.82.98.119
16:36:47:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Vega 10 XL/XT [Radeon RX Vega 56/64] from 13.82.98.119
16:36:47:WU00:FS01:Connecting to 13.82.98.119:8080
16:36:48:WU00:FS01:Downloading 11.57MiB
16:36:51:WU03:FS01:Upload 16.14%
16:36:54:WU00:FS01:Download 97.76%
16:36:54:WU00:FS01:Download complete
16:36:55:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14541 run:0 clone:438 gen:6 core:0x22 unit:0x0000000a0d5262775e7d252377199acc
16:36:55:WU00:FS01:Starting
16:36:55:WU00:FS01:Running FahCore: D:\FAHClient/FAHCoreWrapper.exe C:\Users\[Name]\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 3948 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
16:36:55:WU00:FS01:Started FahCore on PID 10268
16:36:55:WU00:FS01:Core PID:5328
16:36:55:WU00:FS01:FahCore 0x22 started
16:36:56:WU00:FS01:0x22:*********************** Log Started 2020-03-31T16:36:56Z ***********************
16:36:56:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
16:36:56:WU00:FS01:0x22:       Type: 0x22
16:36:56:WU00:FS01:0x22:       Core: Core22
16:36:56:WU00:FS01:0x22:    Website: https://foldingathome.org/
16:36:56:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
16:36:56:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
16:36:56:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
16:36:56:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 705 -lifeline 10268 -checkpoint 15
16:36:56:WU00:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
16:36:56:WU00:FS01:0x22:     Config: <none>
16:36:56:WU00:FS01:0x22:************************************ Build *************************************
16:36:56:WU00:FS01:0x22:    Version: 0.0.2
16:36:56:WU00:FS01:0x22:       Date: Dec 6 2019
16:36:56:WU00:FS01:0x22:       Time: 21:30:31
16:36:56:WU00:FS01:0x22: Repository: Git
16:36:56:WU00:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
16:36:56:WU00:FS01:0x22:     Branch: HEAD
16:36:56:WU00:FS01:0x22:   Compiler: Visual C++ 2008
16:36:56:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
16:36:56:WU00:FS01:0x22:   Platform: win32 10
16:36:56:WU00:FS01:0x22:       Bits: 64
16:36:56:WU00:FS01:0x22:       Mode: Release
16:36:56:WU00:FS01:0x22:************************************ System ************************************
16:36:56:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i7-7700K CPU @ 4.20GHz
16:36:56:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
16:36:56:WU00:FS01:0x22:       CPUs: 8
16:36:56:WU00:FS01:0x22:     Memory: 15.95GiB
16:36:56:WU00:FS01:0x22:Free Memory: 12.35GiB
16:36:56:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
16:36:56:WU00:FS01:0x22: OS Version: 6.2
16:36:56:WU00:FS01:0x22:Has Battery: false
16:36:56:WU00:FS01:0x22: On Battery: false
16:36:56:WU00:FS01:0x22: UTC Offset: 2
16:36:56:WU00:FS01:0x22:        PID: 5328
16:36:56:WU00:FS01:0x22:        CWD: C:\Users\[Name]\AppData\Roaming\FAHClient\work
16:36:56:WU00:FS01:0x22:         OS: Windows 10 Pro
16:36:56:WU00:FS01:0x22:    OS Arch: AMD64
16:36:56:WU00:FS01:0x22:********************************************************************************
16:36:56:WU00:FS01:0x22:Project: 14541 (Run 0, Clone 438, Gen 6)
16:36:56:WU00:FS01:0x22:Unit: 0x0000000a0d5262775e7d252377199acc
16:36:56:WU00:FS01:0x22:Reading tar file core.xml
16:36:56:WU00:FS01:0x22:Reading tar file integrator.xml
16:36:56:WU00:FS01:0x22:Reading tar file state.xml
16:36:56:WU00:FS01:0x22:Reading tar file system.xml
16:36:56:WU00:FS01:0x22:Digital signatures verified
16:36:56:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
16:36:56:WU00:FS01:0x22:Version 0.0.2
16:36:57:WU03:FS01:Upload 30.59%
16:37:03:WU03:FS01:Upload 49.08%
16:37:04:WU00:FS01:0x22:Completed 0 out of 8000000 steps (0%)
16:37:04:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
16:37:09:WU03:FS01:Upload 66.90%
16:37:15:WU03:FS01:Upload 85.05%
16:37:20:WU03:FS01:Upload complete
16:37:20:WU03:FS01:Server responded WORK_ACK (400)
16:37:20:WU03:FS01:Cleaning up
16:39:06:WU00:FS01:0x22:Completed 80000 out of 8000000 steps (1%)
16:41:10:WU00:FS01:0x22:Completed 160000 out of 8000000 steps (2%)
16:43:12:WU00:FS01:0x22:Completed 240000 out of 8000000 steps (3%)
16:45:14:WU00:FS01:0x22:Completed 320000 out of 8000000 steps (4%)
16:47:16:WU00:FS01:0x22:Completed 400000 out of 8000000 steps (5%)
16:49:18:WU00:FS01:0x22:Completed 480000 out of 8000000 steps (6%)
16:51:21:WU00:FS01:0x22:Completed 560000 out of 8000000 steps (7%)
16:53:22:WU00:FS01:0x22:Completed 640000 out of 8000000 steps (8%)
16:55:24:WU00:FS01:0x22:Completed 720000 out of 8000000 steps (9%)
16:57:26:WU00:FS01:0x22:Completed 800000 out of 8000000 steps (10%)
******************************* Date: 2020-03-31 *******************************
16:59:28:WU00:FS01:0x22:Completed 880000 out of 8000000 steps (11%)
17:01:30:WU00:FS01:0x22:Completed 960000 out of 8000000 steps (12%)
17:03:32:WU00:FS01:0x22:Completed 1040000 out of 8000000 steps (13%)
17:05:34:WU00:FS01:0x22:Completed 1120000 out of 8000000 steps (14%)
17:07:39:WU00:FS01:0x22:Completed 1200000 out of 8000000 steps (15%)
17:09:50:WU00:FS01:0x22:Completed 1280000 out of 8000000 steps (16%)
17:11:54:WU00:FS01:0x22:Completed 1360000 out of 8000000 steps (17%)
17:13:59:WU00:FS01:0x22:Completed 1440000 out of 8000000 steps (18%)
17:16:02:WU00:FS01:0x22:Completed 1520000 out of 8000000 steps (19%)
17:18:12:WU00:FS01:0x22:Completed 1600000 out of 8000000 steps (20%)
17:20:26:WU00:FS01:0x22:Completed 1680000 out of 8000000 steps (21%)
17:22:41:WU00:FS01:0x22:Completed 1760000 out of 8000000 steps (22%)
17:24:52:WU00:FS01:0x22:Completed 1840000 out of 8000000 steps (23%)
17:27:00:WU00:FS01:0x22:Completed 1920000 out of 8000000 steps (24%)
17:29:03:WU00:FS01:0x22:Completed 2000000 out of 8000000 steps (25%)
17:31:18:WU00:FS01:0x22:Completed 2080000 out of 8000000 steps (26%)
17:33:23:WU00:FS01:0x22:Completed 2160000 out of 8000000 steps (27%)
17:35:26:WU00:FS01:0x22:Completed 2240000 out of 8000000 steps (28%)
17:37:30:WU00:FS01:0x22:Completed 2320000 out of 8000000 steps (29%)
17:39:33:WU00:FS01:0x22:Completed 2400000 out of 8000000 steps (30%)
17:41:36:WU00:FS01:0x22:Completed 2480000 out of 8000000 steps (31%)
17:43:24:WU00:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
17:43:24:WU00:FS01:0x22:Following exception occured: Particle coordinate is nan
17:44:56:WU00:FS01:0x22:Completed 2560000 out of 8000000 steps (32%)
17:47:00:WU00:FS01:0x22:Completed 2640000 out of 8000000 steps (33%)
17:49:04:WU00:FS01:0x22:Completed 2720000 out of 8000000 steps (34%)
17:51:07:WU00:FS01:0x22:Completed 2800000 out of 8000000 steps (35%)
17:53:11:WU00:FS01:0x22:Completed 2880000 out of 8000000 steps (36%)
17:55:16:WU00:FS01:0x22:Completed 2960000 out of 8000000 steps (37%)
17:57:19:WU00:FS01:0x22:Completed 3040000 out of 8000000 steps (38%)
17:59:23:WU00:FS01:0x22:Completed 3120000 out of 8000000 steps (39%)
18:01:26:WU00:FS01:0x22:Completed 3200000 out of 8000000 steps (40%)
18:03:29:WU00:FS01:0x22:Completed 3280000 out of 8000000 steps (41%)
18:05:33:WU00:FS01:0x22:Completed 3360000 out of 8000000 steps (42%)
18:07:37:WU00:FS01:0x22:Completed 3440000 out of 8000000 steps (43%)
18:09:51:WU00:FS01:0x22:Completed 3520000 out of 8000000 steps (44%)
18:12:04:WU00:FS01:0x22:Completed 3600000 out of 8000000 steps (45%)
18:14:22:WU00:FS01:0x22:Completed 3680000 out of 8000000 steps (46%)
18:16:54:WU00:FS01:0x22:Completed 3760000 out of 8000000 steps (47%)
18:19:21:WU00:FS01:0x22:Completed 3840000 out of 8000000 steps (48%)
18:21:55:WU00:FS01:0x22:Completed 3920000 out of 8000000 steps (49%)
18:23:57:WU00:FS01:0x22:Completed 4000000 out of 8000000 steps (50%)
18:25:59:WU00:FS01:0x22:Completed 4080000 out of 8000000 steps (51%)
18:28:04:WU00:FS01:0x22:Completed 4160000 out of 8000000 steps (52%)
18:30:07:WU00:FS01:0x22:Completed 4240000 out of 8000000 steps (53%)
18:32:13:WU00:FS01:0x22:Completed 4320000 out of 8000000 steps (54%)
18:34:16:WU00:FS01:0x22:Completed 4400000 out of 8000000 steps (55%)
18:36:20:WU00:FS01:0x22:Completed 4480000 out of 8000000 steps (56%)
18:38:25:WU00:FS01:0x22:Completed 4560000 out of 8000000 steps (57%)
18:40:29:WU00:FS01:0x22:Completed 4640000 out of 8000000 steps (58%)
18:42:34:WU00:FS01:0x22:Completed 4720000 out of 8000000 steps (59%)
18:44:37:WU00:FS01:0x22:Completed 4800000 out of 8000000 steps (60%)
18:46:40:WU00:FS01:0x22:Completed 4880000 out of 8000000 steps (61%)
18:48:45:WU00:FS01:0x22:Completed 4960000 out of 8000000 steps (62%)
18:50:48:WU00:FS01:0x22:Completed 5040000 out of 8000000 steps (63%)
18:52:53:WU00:FS01:0x22:Completed 5120000 out of 8000000 steps (64%)
18:54:55:WU00:FS01:0x22:Completed 5200000 out of 8000000 steps (65%)
18:57:00:WU00:FS01:0x22:Completed 5280000 out of 8000000 steps (66%)
18:59:04:WU00:FS01:0x22:Completed 5360000 out of 8000000 steps (67%)
19:01:07:WU00:FS01:0x22:Completed 5440000 out of 8000000 steps (68%)
19:03:12:WU00:FS01:0x22:Completed 5520000 out of 8000000 steps (69%)
19:05:15:WU00:FS01:0x22:Completed 5600000 out of 8000000 steps (70%)
19:07:19:WU00:FS01:0x22:Completed 5680000 out of 8000000 steps (71%)
19:09:24:WU00:FS01:0x22:Completed 5760000 out of 8000000 steps (72%)
19:11:26:WU00:FS01:0x22:Completed 5840000 out of 8000000 steps (73%)
19:13:31:WU00:FS01:0x22:Completed 5920000 out of 8000000 steps (74%)
19:14:01:WU00:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
19:14:01:WU00:FS01:0x22:Following exception occured: Particle coordinate is nan
19:16:34:WU00:FS01:0x22:Completed 6000000 out of 8000000 steps (75%)
19:18:38:WU00:FS01:0x22:Completed 6080000 out of 8000000 steps (76%)
19:20:43:WU00:FS01:0x22:Completed 6160000 out of 8000000 steps (77%)
19:22:46:WU00:FS01:0x22:Completed 6240000 out of 8000000 steps (78%)
19:24:50:WU00:FS01:0x22:Completed 6320000 out of 8000000 steps (79%)
19:26:31:WU00:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
19:26:31:WU00:FS01:0x22:Following exception occured: Particle coordinate is nan
19:26:31:WU00:FS01:0x22:ERROR:114: Max Retries Reached
19:26:31:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
19:26:31:WU00:FS01:0x22:Saving result file badstate-0.xml
19:26:31:WU00:FS01:0x22:Saving result file badstate-1.xml
19:26:31:WU00:FS01:0x22:Saving result file badstate-2.xml
19:26:31:WU00:FS01:0x22:Saving result file checkpointState.xml
19:26:31:WU00:FS01:0x22:Saving result file checkpt.crc
19:26:31:WU00:FS01:0x22:Saving result file positions.xtc
19:26:31:WU00:FS01:0x22:Saving result file science.log
19:26:31:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
19:26:31:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
19:26:31:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:14541 run:0 clone:438 gen:6 core:0x22 unit:0x0000000a0d5262775e7d252377199acc
19:26:31:WU00:FS01:Uploading 23.72MiB to 13.82.98.119
19:26:31:WU00:FS01:Connecting to 13.82.98.119:8080
19:26:32:WU02:FS01:Connecting to 65.254.110.245:8080
19:26:32:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
19:26:32:WU02:FS01:Connecting to 18.218.241.186:80
19:26:33:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
19:26:33:ERROR:WU02:FS01:Exception: Could not get an assignment
19:26:33:WU02:FS01:Connecting to 65.254.110.245:8080
19:26:34:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
19:26:34:WU02:FS01:Connecting to 18.218.241.186:80
19:26:34:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
19:26:34:ERROR:WU02:FS01:Exception: Could not get an assignment
19:26:37:WU00:FS01:Upload 12.38%
19:26:43:WU00:FS01:Upload 21.87%
19:26:49:WU00:FS01:Upload 36.36%
19:26:56:WU00:FS01:Upload 46.64%
19:27:02:WU00:FS01:Upload 61.65%
19:27:08:WU00:FS01:Upload 74.83%
19:27:14:WU00:FS01:Upload 90.11%
19:27:18:WU00:FS01:Upload complete
19:27:18:WU00:FS01:Server responded WORK_ACK (400)
19:27:18:WU00:FS01:Cleaning up
19:27:33:WU02:FS01:Connecting to 65.254.110.245:8080
19:27:34:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
19:27:34:WU02:FS01:Connecting to 18.218.241.186:80
19:27:34:WU02:FS01:Assigned to work server 13.82.98.119
19:27:34:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Vega 10 XL/XT [Radeon RX Vega 56/64] from 13.82.98.119
19:27:34:WU02:FS01:Connecting to 13.82.98.119:8080
19:27:35:WU02:FS01:Downloading 11.57MiB
19:27:40:WU02:FS01:Download complete
19:27:40:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:14541 run:0 clone:181 gen:22 core:0x22 unit:0x0000001f0d5262775e7d252313e93450
19:27:40:WU02:FS01:Starting
19:27:40:WU02:FS01:Running FahCore: D:\FAHClient/FAHCoreWrapper.exe C:\Users\[Name]\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 705 -lifeline 3948 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
19:27:40:WU02:FS01:Started FahCore on PID 3924
19:27:40:WU02:FS01:Core PID:10084
19:27:40:WU02:FS01:FahCore 0x22 started
19:27:41:WU02:FS01:0x22:*********************** Log Started 2020-03-31T19:27:41Z ***********************
19:27:41:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
19:27:41:WU02:FS01:0x22:       Type: 0x22
19:27:41:WU02:FS01:0x22:       Core: Core22
19:27:41:WU02:FS01:0x22:    Website: https://foldingathome.org/
19:27:41:WU02:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
19:27:41:WU02:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
19:27:41:WU02:FS01:0x22:             <rafal.wiewiora@choderalab.org>
19:27:41:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 705 -lifeline 3924 -checkpoint 15
19:27:41:WU02:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
19:27:41:WU02:FS01:0x22:     Config: <none>
19:27:41:WU02:FS01:0x22:************************************ Build *************************************
19:27:41:WU02:FS01:0x22:    Version: 0.0.2
19:27:41:WU02:FS01:0x22:       Date: Dec 6 2019
19:27:41:WU02:FS01:0x22:       Time: 21:30:31
19:27:41:WU02:FS01:0x22: Repository: Git
19:27:41:WU02:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
19:27:41:WU02:FS01:0x22:     Branch: HEAD
19:27:41:WU02:FS01:0x22:   Compiler: Visual C++ 2008
19:27:41:WU02:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:27:41:WU02:FS01:0x22:   Platform: win32 10
19:27:41:WU02:FS01:0x22:       Bits: 64
19:27:41:WU02:FS01:0x22:       Mode: Release
19:27:41:WU02:FS01:0x22:************************************ System ************************************
19:27:41:WU02:FS01:0x22:        CPU: Intel(R) Core(TM) i7-7700K CPU @ 4.20GHz
19:27:41:WU02:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
19:27:41:WU02:FS01:0x22:       CPUs: 8
19:27:41:WU02:FS01:0x22:     Memory: 15.95GiB
19:27:41:WU02:FS01:0x22:Free Memory: 12.48GiB
19:27:41:WU02:FS01:0x22:    Threads: WINDOWS_THREADS
19:27:41:WU02:FS01:0x22: OS Version: 6.2
19:27:41:WU02:FS01:0x22:Has Battery: false
19:27:41:WU02:FS01:0x22: On Battery: false
19:27:41:WU02:FS01:0x22: UTC Offset: 2
19:27:41:WU02:FS01:0x22:        PID: 10084
19:27:41:WU02:FS01:0x22:        CWD: C:\Users\[Name]\AppData\Roaming\FAHClient\work
19:27:41:WU02:FS01:0x22:         OS: Windows 10 Pro
19:27:41:WU02:FS01:0x22:    OS Arch: AMD64
19:27:41:WU02:FS01:0x22:********************************************************************************
19:27:41:WU02:FS01:0x22:Project: 14541 (Run 0, Clone 181, Gen 22)
19:27:41:WU02:FS01:0x22:Unit: 0x0000001f0d5262775e7d252313e93450
19:27:41:WU02:FS01:0x22:Reading tar file core.xml
19:27:41:WU02:FS01:0x22:Reading tar file integrator.xml
19:27:41:WU02:FS01:0x22:Reading tar file state.xml
19:27:41:WU02:FS01:0x22:Reading tar file system.xml
19:27:41:WU02:FS01:0x22:Digital signatures verified
19:27:41:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
19:27:41:WU02:FS01:0x22:Version 0.0.2
19:27:49:WU02:FS01:0x22:Completed 0 out of 8000000 steps (0%)
19:27:49:WU02:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
19:29:51:WU02:FS01:0x22:Completed 80000 out of 8000000 steps (1%)
19:31:54:WU02:FS01:0x22:Completed 160000 out of 8000000 steps (2%)
19:34:01:WU02:FS01:0x22:Completed 240000 out of 8000000 steps (3%)
19:36:16:WU02:FS01:0x22:Completed 320000 out of 8000000 steps (4%)
19:38:23:WU02:FS01:0x22:Completed 400000 out of 8000000 steps (5%)
19:40:27:WU02:FS01:0x22:Completed 480000 out of 8000000 steps (6%)
19:42:30:WU02:FS01:0x22:Completed 560000 out of 8000000 steps (7%)
19:44:31:WU02:FS01:0x22:Completed 640000 out of 8000000 steps (8%)
19:46:39:WU02:FS01:0x22:Completed 720000 out of 8000000 steps (9%)
I hope you can help me as I don't want to waste electricity on a WU that isn't working for my GPU.
Re: Problem with WU 14541
The WU has been credited with partial credits and Faulty status. No one else has attempted to fold it yet ...
hell_alex92
toTOW wrote:The WU has been credited with partial credits and Faulty status. No one else has attempted to fold it yet ...
Hello Sir, first of all thank you for your reply!
Second of all: as you could see, it worked for one WU (with little Error)
I don't know if that is a good sign of a partially broken WU or supreme hardware :D
EDIT: I have to mention I am still getting assigned to that WU. Is there a way around that? I've read to change the machine ID, but I don't know exactly how to do that.
It's the same project, but not the same WU (Run, Clone and Gen are different) ...
Post by muziqaz »
What GPU are you running. and driver version
This project has been known to be quite slow in Windows, and it demands 2 CPU threads all the time as well.
Thanks
FAH Omega tester
Does you card come with a factory overclock from the reference card? If so, try reducing the clock back to the reference speed. Video RAM speed also can be reduced with little impact on folding speed, and gives a little more thermal headroom for other components on the card.
hell_alex92
muziqaz wrote:What GPU are you running. and driver version
Thanks
it's a AMD Radeon Vega 64 on Driver 20.3.1 - with a CPU config of 6 threads max. and GPU is set to standard -1
CPU is a i7-7700K @ 4.2GHz (4-core / 8-threads)
Joe_H wrote:Does you card come with a factory overclock from the reference card? If so, try reducing the clock back to the reference speed. Video RAM speed also can be reduced with little impact on folding speed, and gives a little more thermal headroom for other components on the card.
it's a factory OC Version (ROG Strix OC). that means I need to Underclock it? it really only happens ad WU 14541, I folded 14543 (run:0 clone:1922 gen:8 core:0x22 unit:0x0000000880fccb045e7fc1bdcea06201) without any error overnight and I'm folding 14543 (project:14543 run:0 clone:1880 gen:10 core:0x22 unit:0x0000000a80fccb045e7fc1bdb71d427c) right now (with only one WU_STALLED error)
Post by muziqaz »
Yeah, ASUS is not the best manufacturer for AMD card, I'm afraid. If you downclock your GPU and VRAM a bit, to see if anything changes. You will not lose much of the performance.
Also, on a side unrelated note, driver 20.3.1: does it cause your computer to crash when GPU folding and browsing internet with Chrome? Mine does that, that's why I'm on 19.12.1 driver.
FAH Omega tester
Different projects will have differing stresses on the function of the GPU. So a clock speed that is stable for one project may be marginal for another. In this case the 14541 WU is simulating a system with just under 24k atoms, 14543 has a bit over 76k atoms. They may also be using different functions of the OpenMM code that the GPU folding core is based on.
The WU_STALLED error my also have been an indication of a condition that nearly errored out, but the calculations managed to continue.
P.S. We consider any clock speed over the reference speed as being overclocked. A bit off here or there will not show up in video, but in the heavily used floating point calculations of folding, that results in errors.
hell_alex92
I don't know what to say.. really :D Logs from Today, starting off with WU 14541 (Run 0, Clone 1263, Gen 11)
11:23:49:WU01:FS01:Starting
11:23:49:WU01:FS01:Running FahCore: D:\FAHClient/FAHCoreWrapper.exe C:\Users\[Name]\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 12148 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
11:23:49:WU01:FS01:Started FahCore on PID 2448
11:23:49:WU01:FS01:Core PID:12616
11:23:49:WU01:FS01:FahCore 0x22 started
11:23:50:WU01:FS01:0x22:*********************** Log Started 2020-04-01T11:23:50Z ***********************
11:23:50:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
11:23:50:WU01:FS01:0x22:       Type: 0x22
11:23:50:WU01:FS01:0x22:       Core: Core22
11:23:50:WU01:FS01:0x22:    Website: https://foldingathome.org/
11:23:50:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
11:23:50:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
11:23:50:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
11:23:50:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 705 -lifeline 2448 -checkpoint 15
11:23:51:WU01:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
11:23:51:WU01:FS01:0x22:     Config: <none>
11:23:51:WU01:FS01:0x22:************************************ Build *************************************
11:23:51:WU01:FS01:0x22:    Version: 0.0.2
11:23:51:WU01:FS01:0x22:       Date: Dec 6 2019
11:23:51:WU01:FS01:0x22:       Time: 21:30:31
11:23:51:WU01:FS01:0x22: Repository: Git
11:23:51:WU01:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
11:23:51:WU01:FS01:0x22:     Branch: HEAD
11:23:51:WU01:FS01:0x22:   Compiler: Visual C++ 2008
11:23:51:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:23:51:WU01:FS01:0x22:   Platform: win32 10
11:23:51:WU01:FS01:0x22:       Bits: 64
11:23:51:WU01:FS01:0x22:       Mode: Release
11:23:51:WU01:FS01:0x22:************************************ System ************************************
11:23:51:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i7-7700K CPU @ 4.20GHz
11:23:51:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
11:23:51:WU01:FS01:0x22:       CPUs: 8
11:23:51:WU01:FS01:0x22:     Memory: 15.95GiB
11:23:51:WU01:FS01:0x22:Free Memory: 11.92GiB
11:23:51:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
11:23:51:WU01:FS01:0x22: OS Version: 6.2
11:23:51:WU01:FS01:0x22:Has Battery: false
11:23:51:WU01:FS01:0x22: On Battery: false
11:23:51:WU01:FS01:0x22: UTC Offset: 2
11:23:51:WU01:FS01:0x22:        PID: 12616
11:23:51:WU01:FS01:0x22:        CWD: C:\Users\[Name]\AppData\Roaming\FAHClient\work
11:23:51:WU01:FS01:0x22:         OS: Windows 10 Pro
11:23:51:WU01:FS01:0x22:    OS Arch: AMD64
11:23:51:WU01:FS01:0x22:********************************************************************************
11:23:51:WU01:FS01:0x22:Project: 14541 (Run 0, Clone 1263, Gen 11)
11:23:51:WU01:FS01:0x22:Unit: 0x0000000d0d5262775e7d252308a9a709
11:23:51:WU01:FS01:0x22:Reading tar file core.xml
11:23:51:WU01:FS01:0x22:Reading tar file integrator.xml
11:23:51:WU01:FS01:0x22:Reading tar file state.xml
11:23:51:WU01:FS01:0x22:Reading tar file system.xml
11:23:51:WU01:FS01:0x22:Digital signatures verified
11:23:51:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
11:23:51:WU01:FS01:0x22:Version 0.0.2
11:23:58:WU01:FS01:0x22:Completed 0 out of 8000000 steps (0%)
11:23:58:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
11:26:55:WU01:FS01:0x22:Completed 80000 out of 8000000 steps (1%)
11:29:49:WU01:FS01:0x22:Completed 160000 out of 8000000 steps (2%)
11:31:47:WU01:FS01:0x22:Completed 240000 out of 8000000 steps (3%)
11:34:24:WU01:FS01:0x22:Completed 320000 out of 8000000 steps (4%)
11:36:21:WU01:FS01:0x22:Completed 400000 out of 8000000 steps (5%)
11:38:59:WU01:FS01:0x22:Completed 480000 out of 8000000 steps (6%)
11:41:41:WU01:FS01:0x22:Completed 560000 out of 8000000 steps (7%)
11:44:25:WU01:FS01:0x22:Completed 640000 out of 8000000 steps (8%)
11:47:07:WU01:FS01:0x22:Completed 720000 out of 8000000 steps (9%)
11:49:51:WU01:FS01:0x22:Completed 800000 out of 8000000 steps (10%)
11:52:32:WU01:FS01:0x22:Completed 880000 out of 8000000 steps (11%)
11:55:16:WU01:FS01:0x22:Completed 960000 out of 8000000 steps (12%)
11:57:57:WU01:FS01:0x22:Completed 1040000 out of 8000000 steps (13%)
12:00:41:WU01:FS01:0x22:Completed 1120000 out of 8000000 steps (14%)
12:03:22:WU01:FS01:0x22:Completed 1200000 out of 8000000 steps (15%)
12:06:07:WU01:FS01:0x22:Completed 1280000 out of 8000000 steps (16%)
12:08:51:WU01:FS01:0x22:Completed 1360000 out of 8000000 steps (17%)
12:11:33:WU01:FS01:0x22:Completed 1440000 out of 8000000 steps (18%)
12:14:17:WU01:FS01:0x22:Completed 1520000 out of 8000000 steps (19%)
12:16:59:WU01:FS01:0x22:Completed 1600000 out of 8000000 steps (20%)
12:19:44:WU01:FS01:0x22:Completed 1680000 out of 8000000 steps (21%)
12:22:27:WU01:FS01:0x22:Completed 1760000 out of 8000000 steps (22%)
12:24:49:WU01:FS01:0x22:Completed 1840000 out of 8000000 steps (23%)
12:26:55:WU01:FS01:0x22:Completed 1920000 out of 8000000 steps (24%)
12:29:02:WU01:FS01:0x22:Completed 2000000 out of 8000000 steps (25%)
12:31:08:WU01:FS01:0x22:Completed 2080000 out of 8000000 steps (26%)
12:33:13:WU01:FS01:0x22:Completed 2160000 out of 8000000 steps (27%)
12:35:18:WU01:FS01:0x22:Completed 2240000 out of 8000000 steps (28%)
12:37:26:WU01:FS01:0x22:Completed 2320000 out of 8000000 steps (29%)
12:38:50:WU01:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
12:38:50:WU01:FS01:0x22:Following exception occured: Particle coordinate is nan
12:40:08:WU01:FS01:0x22:Completed 2400000 out of 8000000 steps (30%)
12:42:14:WU01:FS01:0x22:Completed 2480000 out of 8000000 steps (31%)
12:44:21:WU01:FS01:0x22:Completed 2560000 out of 8000000 steps (32%)
12:46:29:WU01:FS01:0x22:Completed 2640000 out of 8000000 steps (33%)
12:48:35:WU01:FS01:0x22:Completed 2720000 out of 8000000 steps (34%)
12:50:41:WU01:FS01:0x22:Completed 2800000 out of 8000000 steps (35%)
12:52:48:WU01:FS01:0x22:Completed 2880000 out of 8000000 steps (36%)
12:55:03:WU01:FS01:0x22:Completed 2960000 out of 8000000 steps (37%)
12:57:07:WU01:FS01:0x22:Completed 3040000 out of 8000000 steps (38%)
12:59:12:WU01:FS01:0x22:Completed 3120000 out of 8000000 steps (39%)
13:01:17:WU01:FS01:0x22:Completed 3200000 out of 8000000 steps (40%)
13:03:23:WU01:FS01:0x22:Completed 3280000 out of 8000000 steps (41%)
13:05:30:WU01:FS01:0x22:Completed 3360000 out of 8000000 steps (42%)
13:07:34:WU01:FS01:0x22:Completed 3440000 out of 8000000 steps (43%)
13:09:40:WU01:FS01:0x22:Completed 3520000 out of 8000000 steps (44%)
13:11:45:WU01:FS01:0x22:Completed 3600000 out of 8000000 steps (45%)
13:13:51:WU01:FS01:0x22:Completed 3680000 out of 8000000 steps (46%)
13:15:57:WU01:FS01:0x22:Completed 3760000 out of 8000000 steps (47%)
13:18:02:WU01:FS01:0x22:Completed 3840000 out of 8000000 steps (48%)
13:20:09:WU01:FS01:0x22:Completed 3920000 out of 8000000 steps (49%)
13:21:06:WU01:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
13:21:06:WU01:FS01:0x22:Following exception occured: Particle coordinate is nan
13:22:23:WU01:FS01:0x22:Completed 4000000 out of 8000000 steps (50%)
13:24:29:WU01:FS01:0x22:Completed 4080000 out of 8000000 steps (51%)
13:26:36:WU01:FS01:0x22:Completed 4160000 out of 8000000 steps (52%)
13:28:41:WU01:FS01:0x22:Completed 4240000 out of 8000000 steps (53%)
13:30:47:WU01:FS01:0x22:Completed 4320000 out of 8000000 steps (54%)
13:32:51:WU01:FS01:0x22:Completed 4400000 out of 8000000 steps (55%)
13:34:58:WU01:FS01:0x22:Completed 4480000 out of 8000000 steps (56%)
13:37:04:WU01:FS01:0x22:Completed 4560000 out of 8000000 steps (57%)
13:39:09:WU01:FS01:0x22:Completed 4640000 out of 8000000 steps (58%)
13:41:16:WU01:FS01:0x22:Completed 4720000 out of 8000000 steps (59%)
13:43:22:WU01:FS01:0x22:Completed 4800000 out of 8000000 steps (60%)
13:45:28:WU01:FS01:0x22:Completed 4880000 out of 8000000 steps (61%)
13:47:33:WU01:FS01:0x22:Completed 4960000 out of 8000000 steps (62%)
13:49:39:WU01:FS01:0x22:Completed 5040000 out of 8000000 steps (63%)
13:51:45:WU01:FS01:0x22:Completed 5120000 out of 8000000 steps (64%)
13:53:50:WU01:FS01:0x22:Completed 5200000 out of 8000000 steps (65%)
13:55:58:WU01:FS01:0x22:Completed 5280000 out of 8000000 steps (66%)
13:58:04:WU01:FS01:0x22:Completed 5360000 out of 8000000 steps (67%)
14:00:09:WU01:FS01:0x22:Completed 5440000 out of 8000000 steps (68%)
14:02:16:WU01:FS01:0x22:Completed 5520000 out of 8000000 steps (69%)
14:04:21:WU01:FS01:0x22:Completed 5600000 out of 8000000 steps (70%)
14:06:17:WU01:FS01:0x22:Completed 5680000 out of 8000000 steps (71%)
14:08:04:WU01:FS01:0x22:Completed 5760000 out of 8000000 steps (72%)
14:09:51:WU01:FS01:0x22:Completed 5840000 out of 8000000 steps (73%)
14:11:38:WU01:FS01:0x22:Completed 5920000 out of 8000000 steps (74%)
14:13:25:WU01:FS01:0x22:Completed 6000000 out of 8000000 steps (75%)
14:15:13:WU01:FS01:0x22:Completed 6080000 out of 8000000 steps (76%)
14:17:00:WU01:FS01:0x22:Completed 6160000 out of 8000000 steps (77%)
14:18:47:WU01:FS01:0x22:Completed 6240000 out of 8000000 steps (78%)
14:20:35:WU01:FS01:0x22:Completed 6320000 out of 8000000 steps (79%)
14:22:22:WU01:FS01:0x22:Completed 6400000 out of 8000000 steps (80%)
14:24:09:WU01:FS01:0x22:Completed 6480000 out of 8000000 steps (81%)
******************************* Date: 2020-04-01 *******************************
14:25:57:WU01:FS01:0x22:Completed 6560000 out of 8000000 steps (82%)
14:27:44:WU01:FS01:0x22:Completed 6640000 out of 8000000 steps (83%)
14:29:32:WU01:FS01:0x22:Completed 6720000 out of 8000000 steps (84%)
14:31:18:WU01:FS01:0x22:Completed 6800000 out of 8000000 steps (85%)
14:33:05:WU01:FS01:0x22:Completed 6880000 out of 8000000 steps (86%)
14:34:52:WU01:FS01:0x22:Completed 6960000 out of 8000000 steps (87%)
14:36:38:WU01:FS01:0x22:Completed 7040000 out of 8000000 steps (88%)
14:38:26:WU01:FS01:0x22:Completed 7120000 out of 8000000 steps (89%)
14:40:13:WU01:FS01:0x22:Completed 7200000 out of 8000000 steps (90%)
14:41:59:WU01:FS01:0x22:Completed 7280000 out of 8000000 steps (91%)
14:43:47:WU01:FS01:0x22:Completed 7360000 out of 8000000 steps (92%)
14:45:07:WU01:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
14:45:07:WU01:FS01:0x22:Following exception occured: Particle coordinate is nan
14:45:07:WU01:FS01:0x22:ERROR:114: Max Retries Reached
14:45:07:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
14:45:07:WU01:FS01:0x22:Saving result file badstate-0.xml
14:45:07:WU01:FS01:0x22:Saving result file badstate-1.xml
14:45:07:WU01:FS01:0x22:Saving result file badstate-2.xml
14:45:07:WU01:FS01:0x22:Saving result file checkpointState.xml
14:45:07:WU01:FS01:0x22:Saving result file checkpt.crc
14:45:07:WU01:FS01:0x22:Saving result file positions.xtc
14:45:07:WU01:FS01:0x22:Saving result file science.log
14:45:07:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
14:45:08:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
14:45:08:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:14541 run:0 clone:1263 gen:11 core:0x22 unit:0x0000000d0d5262775e7d252308a9a709
it nearly run to the end but at 92% it decided to die.
going on with WU 14541 (Run 0, Clone 1144, Gen 13)
14:45:08:WU00:FS01:Starting
14:45:08:WU00:FS01:Running FahCore: D:\FAHClient/FAHCoreWrapper.exe C:\Users\[Name]\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 12148 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
14:45:08:WU00:FS01:Started FahCore on PID 11792
14:45:08:WU00:FS01:Core PID:6440
14:45:08:WU00:FS01:FahCore 0x22 started
14:45:09:WU00:FS01:0x22:*********************** Log Started 2020-04-01T14:45:09Z ***********************
14:45:09:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
14:45:09:WU00:FS01:0x22:       Type: 0x22
14:45:09:WU00:FS01:0x22:       Core: Core22
14:45:09:WU00:FS01:0x22:    Website: https://foldingathome.org/
14:45:09:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
14:45:09:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
14:45:09:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
14:45:09:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 705 -lifeline 11792 -checkpoint 15
14:45:09:WU00:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
14:45:09:WU00:FS01:0x22:     Config: <none>
14:45:09:WU00:FS01:0x22:************************************ Build *************************************
14:45:09:WU00:FS01:0x22:    Version: 0.0.2
14:45:09:WU00:FS01:0x22:       Date: Dec 6 2019
14:45:09:WU00:FS01:0x22:       Time: 21:30:31
14:45:09:WU00:FS01:0x22: Repository: Git
14:45:09:WU00:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
14:45:09:WU00:FS01:0x22:     Branch: HEAD
14:45:09:WU00:FS01:0x22:   Compiler: Visual C++ 2008
14:45:09:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:45:09:WU00:FS01:0x22:   Platform: win32 10
14:45:09:WU00:FS01:0x22:       Bits: 64
14:45:09:WU00:FS01:0x22:       Mode: Release
14:45:09:WU00:FS01:0x22:************************************ System ************************************
14:45:09:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i7-7700K CPU @ 4.20GHz
14:45:09:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
14:45:09:WU00:FS01:0x22:       CPUs: 8
14:45:09:WU00:FS01:0x22:     Memory: 15.95GiB
14:45:09:WU00:FS01:0x22:Free Memory: 11.46GiB
14:45:09:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
14:45:09:WU00:FS01:0x22: OS Version: 6.2
14:45:09:WU00:FS01:0x22:Has Battery: false
14:45:09:WU00:FS01:0x22: On Battery: false
14:45:09:WU00:FS01:0x22: UTC Offset: 2
14:45:09:WU00:FS01:0x22:        PID: 6440
14:45:09:WU00:FS01:0x22:        CWD: C:\Users\[Name]\AppData\Roaming\FAHClient\work
14:45:09:WU00:FS01:0x22:         OS: Windows 10 Pro
14:45:09:WU00:FS01:0x22:    OS Arch: AMD64
14:45:09:WU00:FS01:0x22:********************************************************************************
14:45:09:WU00:FS01:0x22:Project: 14541 (Run 0, Clone 1144, Gen 13)
14:45:09:WU00:FS01:0x22:Unit: 0x0000000e0d5262775e7d252220679968
14:45:09:WU00:FS01:0x22:Reading tar file core.xml
14:45:09:WU00:FS01:0x22:Reading tar file integrator.xml
14:45:09:WU00:FS01:0x22:Reading tar file state.xml
14:45:09:WU00:FS01:0x22:Reading tar file system.xml
14:45:09:WU00:FS01:0x22:Digital signatures verified
14:45:09:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
14:45:09:WU00:FS01:0x22:Version 0.0.2
14:45:14:WU00:FS01:0x22:Completed 0 out of 8000000 steps (0%)
14:45:14:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
14:47:01:WU00:FS01:0x22:Completed 80000 out of 8000000 steps (1%)
14:48:49:WU00:FS01:0x22:Completed 160000 out of 8000000 steps (2%)
14:50:36:WU00:FS01:0x22:Completed 240000 out of 8000000 steps (3%)
14:51:19:WU00:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
14:51:19:WU00:FS01:0x22:Following exception occured: Particle coordinate is nan
14:51:21:WU00:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
14:51:21:WU00:FS01:0x22:Following exception occured: Particle coordinate is nan
14:51:36:WU00:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
14:51:36:WU00:FS01:0x22:Following exception occured: Particle coordinate is nan
14:51:36:WU00:FS01:0x22:ERROR:114: Max Retries Reached
14:51:36:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
14:51:36:WU00:FS01:0x22:Saving result file badstate-0.xml
14:51:36:WU00:FS01:0x22:Saving result file badstate-1.xml
14:51:36:WU00:FS01:0x22:Saving result file badstate-2.xml
14:51:36:WU00:FS01:0x22:Saving result file checkpointState.xml
14:51:36:WU00:FS01:0x22:Saving result file checkpt.crc
14:51:36:WU00:FS01:0x22:Saving result file positions.xtc
14:51:36:WU00:FS01:0x22:Saving result file science.log
14:51:36:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
14:51:36:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
14:51:36:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:14541 run:0 clone:1144 gen:13 core:0x22 unit:0x0000000e0d5262775e7d252220679968
after 3% it won't go further and Downloaded WU 14543 (Run 0, Clone 1877, Gen 8) straight away
14:52:57:WU01:FS01:Starting
14:52:57:WU01:FS01:Running FahCore: D:\FAHClient/FAHCoreWrapper.exe C:\Users\[Name]\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 12148 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
14:52:57:WU01:FS01:Started FahCore on PID 13416
14:52:57:WU01:FS01:Core PID:4728
14:52:57:WU01:FS01:FahCore 0x22 started
14:52:57:WU01:FS01:0x22:*********************** Log Started 2020-04-01T14:52:57Z ***********************
14:52:57:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
14:52:57:WU01:FS01:0x22:       Type: 0x22
14:52:57:WU01:FS01:0x22:       Core: Core22
14:52:57:WU01:FS01:0x22:    Website: https://foldingathome.org/
14:52:57:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
14:52:57:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
14:52:57:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
14:52:57:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 705 -lifeline 13416 -checkpoint 15
14:52:57:WU01:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
14:52:57:WU01:FS01:0x22:     Config: <none>
14:52:57:WU01:FS01:0x22:************************************ Build *************************************
14:52:57:WU01:FS01:0x22:    Version: 0.0.2
14:52:57:WU01:FS01:0x22:       Date: Dec 6 2019
14:52:57:WU01:FS01:0x22:       Time: 21:30:31
14:52:57:WU01:FS01:0x22: Repository: Git
14:52:57:WU01:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
14:52:57:WU01:FS01:0x22:     Branch: HEAD
14:52:57:WU01:FS01:0x22:   Compiler: Visual C++ 2008
14:52:57:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:52:57:WU01:FS01:0x22:   Platform: win32 10
14:52:57:WU01:FS01:0x22:       Bits: 64
14:52:57:WU01:FS01:0x22:       Mode: Release
14:52:57:WU01:FS01:0x22:************************************ System ************************************
14:52:57:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i7-7700K CPU @ 4.20GHz
14:52:57:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
14:52:57:WU01:FS01:0x22:       CPUs: 8
14:52:57:WU01:FS01:0x22:     Memory: 15.95GiB
14:52:57:WU01:FS01:0x22:Free Memory: 11.48GiB
14:52:57:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
14:52:57:WU01:FS01:0x22: OS Version: 6.2
14:52:57:WU01:FS01:0x22:Has Battery: false
14:52:57:WU01:FS01:0x22: On Battery: false
14:52:57:WU01:FS01:0x22: UTC Offset: 2
14:52:57:WU01:FS01:0x22:        PID: 4728
14:52:57:WU01:FS01:0x22:        CWD: C:\Users\[Name]\AppData\Roaming\FAHClient\work
14:52:57:WU01:FS01:0x22:         OS: Windows 10 Pro
14:52:57:WU01:FS01:0x22:    OS Arch: AMD64
14:52:57:WU01:FS01:0x22:********************************************************************************
14:52:57:WU01:FS01:0x22:Project: 14543 (Run 0, Clone 1877, Gen 8)
14:52:57:WU01:FS01:0x22:Unit: 0x0000000880fccb045e7fc1bd76d30bf0
14:52:57:WU01:FS01:0x22:Reading tar file core.xml
14:52:57:WU01:FS01:0x22:Reading tar file integrator.xml
14:52:57:WU01:FS01:0x22:Reading tar file state.xml
14:52:58:WU01:FS01:0x22:Reading tar file system.xml
14:52:58:WU01:FS01:0x22:Digital signatures verified
14:52:58:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
14:52:58:WU01:FS01:0x22:Version 0.0.2
14:53:06:WU01:FS01:0x22:Completed 0 out of 4000000 steps (0%)
14:53:06:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
14:55:20:WU01:FS01:0x22:Completed 40000 out of 4000000 steps (1%)
14:57:37:WU01:FS01:0x22:Completed 80000 out of 4000000 steps (2%)
14:59:52:WU01:FS01:0x22:Completed 120000 out of 4000000 steps (3%)
15:02:09:WU01:FS01:0x22:Completed 160000 out of 4000000 steps (4%)
15:04:23:WU01:FS01:0x22:Completed 200000 out of 4000000 steps (5%)
15:06:39:WU01:FS01:0x22:Completed 240000 out of 4000000 steps (6%)
15:08:55:WU01:FS01:0x22:Completed 280000 out of 4000000 steps (7%)
15:11:12:WU01:FS01:0x22:Completed 320000 out of 4000000 steps (8%)
15:13:28:WU01:FS01:0x22:Completed 360000 out of 4000000 steps (9%)
15:15:42:WU01:FS01:0x22:Completed 400000 out of 4000000 steps (10%)
15:17:58:WU01:FS01:0x22:Completed 440000 out of 4000000 steps (11%)
15:20:14:WU01:FS01:0x22:Completed 480000 out of 4000000 steps (12%)
15:22:30:WU01:FS01:0x22:Completed 520000 out of 4000000 steps (13%)
15:24:47:WU01:FS01:0x22:Completed 560000 out of 4000000 steps (14%)
15:27:01:WU01:FS01:0x22:Completed 600000 out of 4000000 steps (15%)
15:29:17:WU01:FS01:0x22:Completed 640000 out of 4000000 steps (16%)
15:31:34:WU01:FS01:0x22:Completed 680000 out of 4000000 steps (17%)
15:33:50:WU01:FS01:0x22:Completed 720000 out of 4000000 steps (18%)
15:36:06:WU01:FS01:0x22:Completed 760000 out of 4000000 steps (19%)
15:38:20:WU01:FS01:0x22:Completed 800000 out of 4000000 steps (20%)
15:40:37:WU01:FS01:0x22:Completed 840000 out of 4000000 steps (21%)
15:42:53:WU01:FS01:0x22:Completed 880000 out of 4000000 steps (22%)
15:45:09:WU01:FS01:0x22:Completed 920000 out of 4000000 steps (23%)
15:47:25:WU01:FS01:0x22:Completed 960000 out of 4000000 steps (24%)
15:49:39:WU01:FS01:0x22:Completed 1000000 out of 4000000 steps (25%)
15:51:55:WU01:FS01:0x22:Completed 1040000 out of 4000000 steps (26%)
15:54:11:WU01:FS01:0x22:Completed 1080000 out of 4000000 steps (27%)
15:56:27:WU01:FS01:0x22:Completed 1120000 out of 4000000 steps (28%)
15:58:43:WU01:FS01:0x22:Completed 1160000 out of 4000000 steps (29%)
16:00:58:WU01:FS01:0x22:Completed 1200000 out of 4000000 steps (30%)
16:03:15:WU01:FS01:0x22:Completed 1240000 out of 4000000 steps (31%)
16:05:31:WU01:FS01:0x22:Completed 1280000 out of 4000000 steps (32%)
16:07:47:WU01:FS01:0x22:Completed 1320000 out of 4000000 steps (33%)
16:10:03:WU01:FS01:0x22:Completed 1360000 out of 4000000 steps (34%)
16:12:18:WU01:FS01:0x22:Completed 1400000 out of 4000000 steps (35%)
16:14:34:WU01:FS01:0x22:Completed 1440000 out of 4000000 steps (36%)
16:16:50:WU01:FS01:0x22:Completed 1480000 out of 4000000 steps (37%)
16:19:07:WU01:FS01:0x22:Completed 1520000 out of 4000000 steps (38%)
16:21:23:WU01:FS01:0x22:Completed 1560000 out of 4000000 steps (39%)
16:23:37:WU01:FS01:0x22:Completed 1600000 out of 4000000 steps (40%)
16:25:53:WU01:FS01:0x22:Completed 1640000 out of 4000000 steps (41%)
16:28:10:WU01:FS01:0x22:Completed 1680000 out of 4000000 steps (42%)
16:30:26:WU01:FS01:0x22:Completed 1720000 out of 4000000 steps (43%)
16:32:42:WU01:FS01:0x22:Completed 1760000 out of 4000000 steps (44%)
16:34:57:WU01:FS01:0x22:Completed 1800000 out of 4000000 steps (45%)
16:37:13:WU01:FS01:0x22:Completed 1840000 out of 4000000 steps (46%)
16:39:29:WU01:FS01:0x22:Completed 1880000 out of 4000000 steps (47%)
16:41:47:WU01:FS01:0x22:Completed 1920000 out of 4000000 steps (48%)
16:44:03:WU01:FS01:0x22:Completed 1960000 out of 4000000 steps (49%)
16:46:17:WU01:FS01:0x22:Completed 2000000 out of 4000000 steps (50%)
16:48:33:WU01:FS01:0x22:Completed 2040000 out of 4000000 steps (51%)
16:50:48:WU01:FS01:0x22:Completed 2080000 out of 4000000 steps (52%)
16:53:03:WU01:FS01:0x22:Completed 2120000 out of 4000000 steps (53%)
16:55:18:WU01:FS01:0x22:Completed 2160000 out of 4000000 steps (54%)
16:57:31:WU01:FS01:0x22:Completed 2200000 out of 4000000 steps (55%)
16:59:47:WU01:FS01:0x22:Completed 2240000 out of 4000000 steps (56%)
17:02:02:WU01:FS01:0x22:Completed 2280000 out of 4000000 steps (57%)
17:04:17:WU01:FS01:0x22:Completed 2320000 out of 4000000 steps (58%)
17:06:32:WU01:FS01:0x22:Completed 2360000 out of 4000000 steps (59%)
17:08:45:WU01:FS01:0x22:Completed 2400000 out of 4000000 steps (60%)
17:11:00:WU01:FS01:0x22:Completed 2440000 out of 4000000 steps (61%)
17:13:16:WU01:FS01:0x22:Completed 2480000 out of 4000000 steps (62%)
17:15:31:WU01:FS01:0x22:Completed 2520000 out of 4000000 steps (63%)
17:17:46:WU01:FS01:0x22:Completed 2560000 out of 4000000 steps (64%)
17:19:59:WU01:FS01:0x22:Completed 2600000 out of 4000000 steps (65%)
17:22:14:WU01:FS01:0x22:Completed 2640000 out of 4000000 steps (66%)
17:24:29:WU01:FS01:0x22:Completed 2680000 out of 4000000 steps (67%)
17:26:45:WU01:FS01:0x22:Completed 2720000 out of 4000000 steps (68%)
17:29:00:WU01:FS01:0x22:Completed 2760000 out of 4000000 steps (69%)
17:31:13:WU01:FS01:0x22:Completed 2800000 out of 4000000 steps (70%)
17:33:28:WU01:FS01:0x22:Completed 2840000 out of 4000000 steps (71%)
17:35:43:WU01:FS01:0x22:Completed 2880000 out of 4000000 steps (72%)
17:37:58:WU01:FS01:0x22:Completed 2920000 out of 4000000 steps (73%)
17:40:13:WU01:FS01:0x22:Completed 2960000 out of 4000000 steps (74%)
17:42:26:WU01:FS01:0x22:Completed 3000000 out of 4000000 steps (75%)
17:44:41:WU01:FS01:0x22:Completed 3040000 out of 4000000 steps (76%)
17:46:56:WU01:FS01:0x22:Completed 3080000 out of 4000000 steps (77%)
17:49:11:WU01:FS01:0x22:Completed 3120000 out of 4000000 steps (78%)
17:51:26:WU01:FS01:0x22:Completed 3160000 out of 4000000 steps (79%)
17:53:39:WU01:FS01:0x22:Completed 3200000 out of 4000000 steps (80%)
17:55:54:WU01:FS01:0x22:Completed 3240000 out of 4000000 steps (81%)
17:58:09:WU01:FS01:0x22:Completed 3280000 out of 4000000 steps (82%)
18:00:24:WU01:FS01:0x22:Completed 3320000 out of 4000000 steps (83%)
18:02:39:WU01:FS01:0x22:Completed 3360000 out of 4000000 steps (84%)
18:04:52:WU01:FS01:0x22:Completed 3400000 out of 4000000 steps (85%)
18:07:07:WU01:FS01:0x22:Completed 3440000 out of 4000000 steps (86%)
18:09:22:WU01:FS01:0x22:Completed 3480000 out of 4000000 steps (87%)
18:11:37:WU01:FS01:0x22:Completed 3520000 out of 4000000 steps (88%)
18:13:52:WU01:FS01:0x22:Completed 3560000 out of 4000000 steps (89%)
18:16:05:WU01:FS01:0x22:Completed 3600000 out of 4000000 steps (90%)
18:18:20:WU01:FS01:0x22:Completed 3640000 out of 4000000 steps (91%)
18:20:35:WU01:FS01:0x22:Completed 3680000 out of 4000000 steps (92%)
18:22:50:WU01:FS01:0x22:Completed 3720000 out of 4000000 steps (93%)
18:25:05:WU01:FS01:0x22:Completed 3760000 out of 4000000 steps (94%)
18:27:18:WU01:FS01:0x22:Completed 3800000 out of 4000000 steps (95%)
18:29:35:WU01:FS01:0x22:Completed 3840000 out of 4000000 steps (96%)
18:31:50:WU01:FS01:0x22:Completed 3880000 out of 4000000 steps (97%)
18:34:06:WU01:FS01:0x22:Completed 3920000 out of 4000000 steps (98%)
18:36:22:WU01:FS01:0x22:Completed 3960000 out of 4000000 steps (99%)
18:38:36:WU01:FS01:0x22:Completed 4000000 out of 4000000 steps (100%)
18:38:38:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
18:38:38:WU01:FS01:0x22:Saving result file checkpointState.xml
18:38:38:WU01:FS01:0x22:Saving result file checkpt.crc
18:38:38:WU01:FS01:0x22:Saving result file positions.xtc
18:38:38:WU01:FS01:0x22:Saving result file science.log
18:38:38:WU01:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
18:38:39:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
18:38:39:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:14543 run:0 clone:1877 gen:8 core:0x22 unit:0x0000000880fccb045e7fc1bd76d30bf0
as you can see, no problems here. it finished smoothly and downloaded AGAIN a 14541 (Run 0, Clone 288, Gen 20)
18:38:39:WU00:FS01:Starting
18:38:39:WU00:FS01:Running FahCore: D:\FAHClient/FAHCoreWrapper.exe C:\Users\[Name]\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 12148 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
18:38:39:WU00:FS01:Started FahCore on PID 10864
18:38:39:WU00:FS01:Core PID:6564
18:38:39:WU00:FS01:FahCore 0x22 started
18:38:40:WU00:FS01:0x22:*********************** Log Started 2020-04-01T18:38:40Z ***********************
18:38:40:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
18:38:40:WU00:FS01:0x22:       Type: 0x22
18:38:40:WU00:FS01:0x22:       Core: Core22
18:38:40:WU00:FS01:0x22:    Website: https://foldingathome.org/
18:38:40:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
18:38:40:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
18:38:40:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
18:38:40:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 705 -lifeline 10864 -checkpoint 15
18:38:40:WU00:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
18:38:40:WU00:FS01:0x22:     Config: <none>
18:38:40:WU00:FS01:0x22:************************************ Build *************************************
18:38:40:WU00:FS01:0x22:    Version: 0.0.2
18:38:40:WU00:FS01:0x22:       Date: Dec 6 2019
18:38:40:WU00:FS01:0x22:       Time: 21:30:31
18:38:40:WU00:FS01:0x22: Repository: Git
18:38:40:WU00:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
18:38:40:WU00:FS01:0x22:     Branch: HEAD
18:38:40:WU00:FS01:0x22:   Compiler: Visual C++ 2008
18:38:40:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:38:40:WU00:FS01:0x22:   Platform: win32 10
18:38:40:WU00:FS01:0x22:       Bits: 64
18:38:40:WU00:FS01:0x22:       Mode: Release
18:38:40:WU00:FS01:0x22:************************************ System ************************************
18:38:40:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i7-7700K CPU @ 4.20GHz
18:38:40:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
18:38:40:WU00:FS01:0x22:       CPUs: 8
18:38:40:WU00:FS01:0x22:     Memory: 15.95GiB
18:38:40:WU00:FS01:0x22:Free Memory: 10.78GiB
18:38:40:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
18:38:40:WU00:FS01:0x22: OS Version: 6.2
18:38:40:WU00:FS01:0x22:Has Battery: false
18:38:40:WU00:FS01:0x22: On Battery: false
18:38:40:WU00:FS01:0x22: UTC Offset: 2
18:38:40:WU00:FS01:0x22:        PID: 6564
18:38:40:WU00:FS01:0x22:        CWD: C:\Users\[Name]\AppData\Roaming\FAHClient\work
18:38:40:WU00:FS01:0x22:         OS: Windows 10 Pro
18:38:40:WU00:FS01:0x22:    OS Arch: AMD64
18:38:40:WU00:FS01:0x22:********************************************************************************
18:38:40:WU00:FS01:0x22:Project: 14541 (Run 0, Clone 288, Gen 20)
18:38:40:WU00:FS01:0x22:Unit: 0x0000001c0d5262775e7d2523e263b976
18:38:40:WU00:FS01:0x22:Reading tar file core.xml
18:38:40:WU00:FS01:0x22:Reading tar file integrator.xml
18:38:40:WU00:FS01:0x22:Reading tar file state.xml
18:38:40:WU00:FS01:0x22:Reading tar file system.xml
18:38:40:WU00:FS01:0x22:Digital signatures verified
18:38:40:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
18:38:40:WU00:FS01:0x22:Version 0.0.2
18:38:45:WU00:FS01:0x22:Completed 0 out of 8000000 steps (0%)
18:38:45:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
18:40:32:WU00:FS01:0x22:Completed 80000 out of 8000000 steps (1%)
18:42:19:WU00:FS01:0x22:Completed 160000 out of 8000000 steps (2%)
18:44:04:WU00:FS01:0x22:Completed 240000 out of 8000000 steps (3%)
18:45:51:WU00:FS01:0x22:Completed 320000 out of 8000000 steps (4%)
18:47:36:WU00:FS01:0x22:Completed 400000 out of 8000000 steps (5%)
18:49:23:WU00:FS01:0x22:Completed 480000 out of 8000000 steps (6%)
18:51:10:WU00:FS01:0x22:Completed 560000 out of 8000000 steps (7%)
18:51:37:WU00:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
18:51:37:WU00:FS01:0x22:Following exception occured: Particle coordinate is nan
18:53:37:WU00:FS01:0x22:Completed 640000 out of 8000000 steps (8%)
18:55:25:WU00:FS01:0x22:Completed 720000 out of 8000000 steps (9%)
18:57:11:WU00:FS01:0x22:Completed 800000 out of 8000000 steps (10%)
18:58:59:WU00:FS01:0x22:Completed 880000 out of 8000000 steps (11%)
19:00:47:WU00:FS01:0x22:Completed 960000 out of 8000000 steps (12%)
This one is currently running (until the next error occures)
muziqaz wrote:Yeah, ASUS is not the best manufacturer for AMD card, I'm afraid. If you downclock your GPU and VRAM a bit, to see if anything changes. You will not lose much of the performance.
it crashed with 20.2.X but not with 20.3.1 and only sporadicly while watching YT or even a local Video.
Joe_H wrote:Different projects will have differing stresses on the function of the GPU. So a clock speed that is stable for one project may be marginal for another. In this case the 14541 WU is simulating a system with just under 24k atoms, 14543 has a bit over 76k atoms. They may also be using different functions of the OpenMM code that the GPU folding core is based on.
is there a way to determine the reference clock speed?
Post by muziqaz »
What is your HBM running at?
Mine is at 945Mhz with what seems to be 950mV. This is Liquid Edition though, but I doubt its memory has been touched.
So try that.
Now core clock, mine obviously again boosts higher due to being under water. If you could tell your clocks when under load and voltages under load, I might be able to suggest something :)
FAH Omega tester
hell_alex92
Post by hell_alex92 »
muziqaz wrote:What is your HBM running at?
So try that.
I assume HBM (which is the Memory) is running at 950Mhz (according to Afterburner) which should be at 945Mhz (according to GPU-Z) <- Downgraded with Afterburner
Core Clock is running at 1630MHz (Afterburner) which is default (GPU-Z)
GPU Voltage is at 1200mV (default) (idk know where to see "under load" as it's not monitoring that)
Memory Voltage is at 1100mV (default) (idk know where to see "under load" as it's not monitoring that)
Memory Clock is at 1900MHz (from the 1890MHz default settings from the ASUS GPU Tweak II App)
Post by muziqaz »
I always found Afterburner not working well with AMD cards, never used ASUS tweak utilities either (but that's just me old timer living in BIOS world.
What I meant' under load is when you are folding, open AMD adrenalin drivers, go to global wattman (if that still exists in 20.3.1), and see what it is reporting for GPU clocks (HBM and GPU core). HBM is memory speed.
Also I run Balanced profile in Adrenalin drivers, but ASUS being ASUS, they might have their own "stable" profile running.
For starters if you set HBM to 945Mhz with 1000mV, that might get things towards stable area. 1100mV for HBM is kinda high. Mine always self destruct with anything above 950Mhz and 950mV.
For GPU clock I remember having 1600Mhz at 1100mV stable. But 1150mV might be preferable.
With Vega64 less is more :)
Also all the ASUS/MSI Afterburner utilities are trying to instill their own settings, so I always never used them. Always relied on AMD wattman. With 20.3.1 they should have fixed their wattman to the point where you can rely on it as well :) When it is working its amazing feature :)
FAH Omega tester
hell_alex92
muziqaz wrote:I always found Afterburner not working well with AMD cards, never used ASUS tweak utilities either (but that's just me old timer living in BIOS world.
I tried, but I can't find the mV settings. Neither in the Radeon Settings Program, nor in Afterburner/GPU Tweak Monitors.
I Underclocked and Undervolted it to your specs, I hope it won't blow up my rig :D (Do you mind sending me a tool for voltage monitoring?)
EDIT: ok wow. the GPU clock mV were all the time in front of me. I guess I'm blind. :D
GPU Voltage is jumping between 1100 and 1131 mV (Setting is 1150), but still no sign of Mem Clock mV (set to 1000)
Post by muziqaz »
If your adrenalin wattman profile is on auto, then everything will be clocking automatically.
There should be Manual or Custom profile with which you are given an option to set everything manually. AMD 20.3.1 layout is different compared to my 19.12.1, so I cannot advise you specifically where and what to set up :)
FAH Omega tester
