GPUs are ready but not working
Lars TeePunkt
Post by Lars TeePunkt »
Hello my friends.
I started to help a bit yesterday.
The CPU are working all night long, but the GPU are doing nothing. I tryed to fix it by my own, but after couples of hours i stopped it and went to bed.
What am I doing wrong?
I installed some "new" gpu drivers and also the "useless" cuda for my amd cards. :D
https://ibb.co/VmwqQb8
*********************** Log Started 2020-03-28T12:39:06Z ***********************
12:39:06:************************* Folding@home Client *************************
12:39:06:      Website: https://foldingathome.org/
12:39:06:    Copyright: (c) 2009-2018 foldingathome.org
12:39:06:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:39:06:         Args:
12:39:06:       Config: C:\Users\Lars\AppData\Roaming\FAHClient\config.xml
12:39:06:******************************** Build ********************************
12:39:06:      Version: 7.5.1
12:39:06:         Date: May 11 2018
12:39:06:         Time: 13:06:32
12:39:06:   Repository: Git
12:39:06:     Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
12:39:06:       Branch: master
12:39:06:     Compiler: Visual C++ 2008
12:39:06:      Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:39:06:     Platform: win32 10
12:39:06:         Bits: 32
12:39:06:         Mode: Release
12:39:06:******************************* System ********************************
12:39:06:          CPU: AMD Phenom(tm) II X6 1100T Processor
12:39:06:       CPU ID: AuthenticAMD Family 16 Model 10 Stepping 0
12:39:06:         CPUs: 6
12:39:06:       Memory: 16.00GiB
12:39:06:  Free Memory: 13.26GiB
12:39:06:      Threads: WINDOWS_THREADS
12:39:06:   OS Version: 6.2
12:39:06:  Has Battery: false
12:39:06:   On Battery: false
12:39:06:   UTC Offset: 1
12:39:06:          PID: 1444
12:39:06:          CWD: C:\Users\Lars\AppData\Roaming\FAHClient
12:39:06:           OS: Windows 10 Home
12:39:06:      OS Arch: AMD64
12:39:06:         GPUs: 2
12:39:06:        GPU 0: Bus:7 Slot:0 Func:0 AMD:4 Barts XT [Radeon HD 6800 Series]
12:39:06:        GPU 1: Bus:2 Slot:0 Func:0 AMD:4 Barts XT [Radeon HD 6800 Series]
12:39:06:         CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': Das
12:39:06:               angegebene Modul wurde nicht gefunden.
12:39:06:
12:39:06:Win32 Service: false
12:39:06:***********************************************************************
12:39:06:<config>
12:39:06:  <!-- Folding Core -->
12:39:06:  <checkpoint v='10'/>
12:39:06:
12:39:06:  <!-- Folding Slot Configuration -->
12:39:06:  <extra-core-args v='true'/>
12:39:06:
12:39:06:  <!-- Logging -->
12:39:06:  <verbosity v='2'/>
12:39:06:
12:39:06:  <!-- Network -->
12:39:06:  <proxy v=':8080'/>
12:39:06:
12:39:06:  <!-- Slot Control -->
12:39:06:  <pause-on-battery v='false'/>
12:39:06:  <power v='FULL'/>
12:39:06:
12:39:06:  <!-- User Information -->
12:39:06:  <passkey v='********************************'/>
12:39:06:  <team v='7'/>
12:39:06:  <user v='Lars_TeePunkt'/>
12:39:06:
12:39:06:  <!-- Folding Slots -->
12:39:06:  <slot id='0' type='CPU'/>
12:39:06:  <slot id='1' type='GPU'/>
12:39:06:  <slot id='2' type='GPU'/>
12:39:06:</config>
12:39:06:Trying to access database...
12:39:06:Enabled folding slot 00: READY cpu:4
12:39:06:Enabled folding slot 01: READY gpu:0:Barts XT [Radeon HD 6800 Series]
12:39:06:Enabled folding slot 02: READY gpu:1:Barts XT [Radeon HD 6800 Series]
12:39:06:ERROR:No compute devices matched GPU #0 AMD:4 Barts XT [Radeon HD 6800 Series].  You may need to update your graphics drivers.
12:39:06:ERROR:No compute devices matched GPU #1 AMD:4 Barts XT [Radeon HD 6800 Series].  You may need to update your graphics drivers.
12:39:06:WU03:FS00:Starting
12:39:06:WU03:FS00:Core PID:6232
12:39:06:WU03:FS00:FahCore 0xa7 started
12:39:07:WU03:FS00:0xa7:*********************** Log Started 2020-03-28T12:39:06Z ***********************
12:39:07:WU03:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
12:39:07:WU03:FS00:0xa7:       Type: 0xa7
12:39:07:WU03:FS00:0xa7:       Core: Gromacs
12:39:07:WU03:FS00:0xa7:       Args: -dir 03 -suffix 01 -version 705 -lifeline 8636 -checkpoint 10 -np 4
12:39:07:WU03:FS00:0xa7:             true
12:39:07:WU03:FS00:0xa7:************************************ CBang *************************************
12:39:07:WU03:FS00:0xa7:       Date: Oct 26 2019
12:39:07:WU03:FS00:0xa7:       Time: 01:38:35
12:39:07:WU03:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
12:39:07:WU03:FS00:0xa7:     Branch: master
12:39:07:WU03:FS00:0xa7:   Compiler: Visual C++ 2008
12:39:07:WU03:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:39:07:WU03:FS00:0xa7:   Platform: win32 10
12:39:07:WU03:FS00:0xa7:       Bits: 64
12:39:07:WU03:FS00:0xa7:       Mode: Release
12:39:07:WU03:FS00:0xa7:************************************ System ************************************
12:39:07:WU03:FS00:0xa7:        CPU: AMD Phenom(tm) II X6 1100T Processor
12:39:07:WU03:FS00:0xa7:     CPU ID: AuthenticAMD Family 16 Model 10 Stepping 0
12:39:07:WU03:FS00:0xa7:       CPUs: 6
12:39:07:WU03:FS00:0xa7:     Memory: 16.00GiB
12:39:07:WU03:FS00:0xa7:Free Memory: 13.24GiB
12:39:07:WU03:FS00:0xa7:    Threads: WINDOWS_THREADS
12:39:07:WU03:FS00:0xa7: OS Version: 6.2
12:39:07:WU03:FS00:0xa7:Has Battery: false
12:39:07:WU03:FS00:0xa7: On Battery: false
12:39:07:WU03:FS00:0xa7: UTC Offset: 1
12:39:07:WU03:FS00:0xa7:        PID: 6232
12:39:07:WU03:FS00:0xa7:        CWD: C:\Users\Lars\AppData\Roaming\FAHClient\work
12:39:07:WU03:FS00:0xa7:******************************** Build - libFAH ********************************
12:39:07:WU03:FS00:0xa7:    Version: 0.0.18
12:39:07:WU03:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:39:07:WU03:FS00:0xa7:  Copyright: 2019 foldingathome.org
12:39:07:WU03:FS00:0xa7:   Homepage: https://foldingathome.org/
12:39:07:WU03:FS00:0xa7:       Time: 01:52:44
12:39:07:WU03:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
12:39:07:WU03:FS00:0xa7:************************************ Build *************************************
12:39:07:WU03:FS00:0xa7:       SIMD: sse2
12:39:07:WU03:FS00:0xa7:********************************************************************************
12:39:07:WU03:FS00:0xa7:Project: 14182 (Run 0, Clone 256, Gen 19)
12:39:07:WU03:FS00:0xa7:Unit: 0x000000170002894b5dae091eb9c62a3e
12:39:07:WU03:FS00:0xa7:Digital signatures verified
12:39:07:WU03:FS00:0xa7:Calling: mdrun -s frame19.tpr -o frame19.trr -cpi state.cpt -cpt 10 -nt 4
12:39:08:WU03:FS00:0xa7:Steps: first=47500000 total=2500000
12:39:08:WU03:FS00:0xa7:Completed 1237282 out of 2500000 steps (49%)
12:39:08:WU01:FS02:Assigned to work server 192.0.2.1
12:39:08:WU01:FS02:Requesting new work unit for slot 02: READY gpu:1:Barts XT [Radeon HD 6800 Series] from 192.0.2.1
12:39:08:WU00:FS01:Assigned to work server 192.0.2.1
12:39:08:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Barts XT [Radeon HD 6800 Series] from 192.0.2.1
12:39:29:WARNING:WU01:FS02:WorkServer connection failed on port 8080 trying 80
12:39:29:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
12:39:51:ERROR:WU01:FS02:Exception: Failed to connect to 192.0.2.1:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
12:39:51:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
12:39:51:WU00:FS01:Assigned to work server 192.0.2.1
12:39:51:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Barts XT [Radeon HD 6800 Series] from 192.0.2.1
12:39:51:WU01:FS02:Assigned to work server 192.0.2.1
12:39:51:WU01:FS02:Requesting new work unit for slot 02: READY gpu:1:Barts XT [Radeon HD 6800 Series] from 192.0.2.1
12:40:13:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
12:40:13:WARNING:WU01:FS02:WorkServer connection failed on port 8080 trying 80
12:40:34:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
12:40:34:ERROR:WU01:FS02:Exception: Failed to connect to 192.0.2.1:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
12:40:52:WU00:FS01:Assigned to work server 192.0.2.1
12:40:52:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Barts XT [Radeon HD 6800 Series] from 192.0.2.1
12:40:52:WU01:FS02:Assigned to work server 192.0.2.1
12:40:52:WU01:FS02:Requesting new work unit for slot 02: READY gpu:1:Barts XT [Radeon HD 6800 Series] from 192.0.2.1
12:41:13:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
12:41:13:WARNING:WU01:FS02:WorkServer connection failed on port 8080 trying 80
12:41:34:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
12:41:34:ERROR:WU01:FS02:Exception: Failed to connect to 192.0.2.1:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
12:42:29:WU00:FS01:Assigned to work server 192.0.2.1
12:42:29:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Barts XT [Radeon HD 6800 Series] from 192.0.2.1
12:42:29:WU01:FS02:Assigned to work server 192.0.2.1
12:42:29:WU01:FS02:Requesting new work unit for slot 02: READY gpu:1:Barts XT [Radeon HD 6800 Series] from 192.0.2.1
12:42:50:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
12:42:50:WARNING:WU01:FS02:WorkServer connection failed on port 8080 trying 80
12:43:11:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
12:43:11:ERROR:WU01:FS02:Exception: Failed to connect to 192.0.2.1:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
12:44:32:WU03:FS00:0xa7:Completed 1250000 out of 2500000 steps (50%)
12:45:06:WU00:FS01:Assigned to work server 192.0.2.1
12:45:06:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Barts XT [Radeon HD 6800 Series] from 192.0.2.1
12:45:06:WU01:FS02:Assigned to work server 192.0.2.1
12:45:06:WU01:FS02:Requesting new work unit for slot 02: READY gpu:1:Barts XT [Radeon HD 6800 Series] from 192.0.2.1
12:45:27:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
12:45:27:WARNING:WU01:FS02:WorkServer connection failed on port 8080 trying 80
12:45:48:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
12:45:49:ERROR:WU01:FS02:Exception: Failed to connect to 192.0.2.1:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
12:49:20:WU00:FS01:Assigned to work server 192.0.2.1
12:49:20:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Barts XT [Radeon HD 6800 Series] from 192.0.2.1
12:49:21:WU01:FS02:Assigned to work server 192.0.2.1
12:49:21:WU01:FS02:Requesting new work unit for slot 02: READY gpu:1:Barts XT [Radeon HD 6800 Series] from 192.0.2.1
12:49:41:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
12:49:42:WARNING:WU01:FS02:WorkServer connection failed on port 8080 trying 80
12:50:02:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
12:50:03:ERROR:WU01:FS02:Exception: Failed to connect to 192.0.2.1:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
12:50:21:FS01:Paused
12:50:27:FS01:Unpaused
12:50:28:WU00:FS01:Assigned to work server 192.0.2.1
12:50:28:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Barts XT [Radeon HD 6800 Series] from 192.0.2.1
12:50:49:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
12:51:10:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
12:52:05:WU00:FS01:Assigned to work server 192.0.2.1
12:52:05:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Barts XT [Radeon HD 6800 Series] from 192.0.2.1
12:52:26:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
12:52:47:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
12:54:34:WU03:FS00:0xa7:Completed 1275000 out of 2500000 steps (51%)
12:54:42:WU00:FS01:Assigned to work server 192.0.2.1
12:54:42:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Barts XT [Radeon HD 6800 Series] from 192.0.2.1
12:55:03:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
12:55:19:Removing old file 'configs/config-20200327-215149.xml'
12:55:19:Saving configuration to config.xml
12:55:19:<config>
12:55:19:  <!-- Folding Core -->
12:55:19:  <checkpoint v='10'/>
12:55:19:
12:55:19:  <!-- Folding Slot Configuration -->
12:55:19:  <extra-core-args v='true'/>
12:55:19:
12:55:19:  <!-- Network -->
12:55:19:  <proxy v=':8080'/>
12:55:19:
12:55:19:  <!-- Slot Control -->
12:55:19:  <pause-on-battery v='false'/>
12:55:19:  <power v='FULL'/>
12:55:19:
12:55:19:  <!-- User Information -->
12:55:19:  <passkey v='********************************'/>
12:55:19:  <team v='7'/>
12:55:19:  <user v='Lars_TeePunkt'/>
12:55:19:
12:55:19:  <!-- Folding Slots -->
12:55:19:  <slot id='0' type='CPU'/>
12:55:19:  <slot id='1' type='GPU'/>
12:55:19:  <slot id='2' type='GPU'/>
12:55:19:</config>
12:55:22:Removing old file 'configs/config-20200327-215250.xml'
12:55:22:Saving configuration to config.xml
12:55:22:<config>
12:55:22:  <!-- Folding Core -->
12:55:22:  <checkpoint v='10'/>
12:55:22:
12:55:22:  <!-- Folding Slot Configuration -->
12:55:22:  <extra-core-args v='true'/>
12:55:22:
12:55:22:  <!-- Network -->
12:55:22:  <proxy v=':8080'/>
12:55:22:
12:55:22:  <!-- Slot Control -->
12:55:22:  <pause-on-battery v='false'/>
12:55:22:  <power v='FULL'/>
12:55:22:
12:55:22:  <!-- User Information -->
12:55:22:  <passkey v='********************************'/>
12:55:22:  <team v='7'/>
12:55:22:  <user v='Lars_TeePunkt'/>
12:55:22:
12:55:22:  <!-- Folding Slots -->
12:55:22:  <slot id='0' type='CPU'/>
12:55:22:  <slot id='1' type='GPU'/>
12:55:22:  <slot id='2' type='GPU'/>
12:55:22:</config>
12:55:24:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
12:56:11:WU01:FS02:Connecting to 65.254.110.245:8080
12:56:12:WU01:FS02:Assigned to work server 192.0.2.1
12:56:12:WU01:FS02:Requesting new work unit for slot 02: READY gpu:1:Barts XT [Radeon HD 6800 Series] from 192.0.2.1
12:56:12:WU01:FS02:Connecting to 192.0.2.1:8080
12:56:33:WARNING:WU01:FS02:WorkServer connection failed on port 8080 trying 80
12:56:33:WU01:FS02:Connecting to 192.0.2.1:80
12:56:54:ERROR:WU01:FS02:Exception: Failed to connect to 192.0.2.1:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
12:58:56:WU00:FS01:Connecting to 65.254.110.245:8080
12:58:56:WU00:FS01:Assigned to work server 192.0.2.1
12:58:56:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Barts XT [Radeon HD 6800 Series] from 192.0.2.1
12:58:56:WU00:FS01:Connecting to 192.0.2.1:8080
12:59:17:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
12:59:17:WU00:FS01:Connecting to 192.0.2.1:80
12:59:39:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
13:04:11:WU03:FS00:0xa7:Completed 1300000 out of 2500000 steps (52%)
13:05:47:WU00:FS01:Connecting to 65.254.110.245:8080
13:05:48:WU00:FS01:Assigned to work server 192.0.2.1
13:05:48:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Barts XT [Radeon HD 6800 Series] from 192.0.2.1
13:05:48:WU00:FS01:Connecting to 192.0.2.1:8080
13:06:09:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
13:06:09:WU00:FS01:Connecting to 192.0.2.1:80
13:06:30:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
13:07:17:WU01:FS02:Connecting to 65.254.110.245:8080
13:07:17:WU01:FS02:Assigned to work server 192.0.2.1
13:07:17:WU01:FS02:Requesting new work unit for slot 02: READY gpu:1:Barts XT [Radeon HD 6800 Series] from 192.0.2.1
13:07:17:WU01:FS02:Connecting to 192.0.2.1:8080
13:07:38:WARNING:WU01:FS02:WorkServer connection failed on port 8080 trying 80
13:07:38:WU01:FS02:Connecting to 192.0.2.1:80
13:08:00:ERROR:WU01:FS02:Exception: Failed to connect to 192.0.2.1:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
13:13:58:WU03:FS00:0xa7:Completed 1325000 out of 2500000 steps (53%)
amd 1100T @3.2ghz
16gb DDRAM
2 x HD 6870 @CF
Win 10 64 bit
Lars
G3WGV
Hardware configuration: A mishmash of systems little and large, ranging from an Udoo X86 Ultra up to a new beast completed 2020-03-25 with a Ryzen 9 3950X CPU & RTX 2070 GPU. F@H seems to like the 2070!
Re: GPUs are ready but not working
Post by G3WGV »
I don't think you are doing anything wrong. There are numerous threads on this forum saying that with the recent big influx of new clients the servers are struggling to match supply to demand. After a fairly busy time 24-48 hours ago, my GPUs haven't had any WUs assigned for the past 15 hours or so but have instead been quite busy doing CPU WUs.
Leave your system on and the work will come when it can.
John.
Radio Amateur, light aircraft owner/pilot, computer nerd, mountaineer, organist (sort of) and, now, folder.
foldinghomealone2
Post by foldinghomealone2 »
Welcome to folding.
There are zillions of threads - including on the main page - that the WU servers are overloaded.
Best is to restart client or your PC and hope the best.
PS
Wenn du in einem deutschsprachigen Team falten willst kann ich nur empfehlen:
https://extreme.pcgameshardware.de/fold ... 70335-a/28
Da wird dir auch geholfen, wenn du Fragen hast.
Post by Neil-B »
The logs look as it you are trying to contact from 192.0.2.1 which seems a bit odd (but so do many things) … It may not just be the overloaded servers issue rather more a case of trying to contact a non existent server? … I am sure someone more technically able than I will be able to advise further.
Yujah
Post by Yujah »
Lars TeePunkt wrote: 12:39:06: GPUs: 2
The first bit of quoted log should as far I know always be followed by a bit noting an OpenCL device which it doesn't for you and as such, and also as per the second quoted bit of log, you may not have OpenCL set up... but the third bit of quoted log (a reserved, unroutable IP address) is what you get when F@h says "sorry, your GPU is unsupported due to missing double-precision".
I.e., also see viewtopic.php?f=61&t=33428#p318893
When I look at BARTS at the Techpowerup database, e.g. https://www.techpowerup.com/gpu-specs/r ... -6870.c256, indeed I don't see FP64 support even for a 6870; maybe a 69xx would have it. You'd ideally look up your exact card there, but, no, I can sort of assure you at this point that your GPUs are not going to be supported; are too old to have OpenCL DP.
I'm not a Windows user myself, but that might in fact be the reason there's no OpenCL mention for your card(s) in the first place; maybe the current Windows driver doesn't even bother making OpenCL available on what are now old cards...
Lars TeePunkt
Hello and thank you all for your fast reply!
It seems they are just too old. I looked at the requirements of the Client At the mainpage and thought i could use them but that was my fault, nvm.
I have no idea why he is trying to Connect to something dead, its the normal configuration After 3 Times installing, deleting the slots and create new ones.
Altough thanks for the Hyperlink into a german forum. I didnt found one in Hurry yesterday.
Thanks a Lot and may god bless you.
Lars
Yes, the oldest AMD cards that can currently fold are from the HD 5800 and HD 6900 series. All the rest of those series do not support DP. For later series, since on of the low and mid level many cards are still Terascale based, those cards do not support DP and can not be used. GPUs based on GCN or later can, except for nest point:
Many of the mobile versions of these GPUs do not support DP, even when the desktop one does.
They may shows up as "Supported" as they were usable until last year. It will take a bit of time to find them all and change them to be marked as unsupported.
