Radeon HD 8800M on Macbook Pro doing nothing
MaxxTc
Post by MaxxTc »
Hey Folks,
I have an old Macbook Pro (2015) with Ubuntu on it. The CPUs are folding well, but the GPU only throws errors. I think the right drivers are installed, because the GPU is showing up in the system info of Client Advanced Control. But every time I get a WU it looks like this:
07:40:32:WU00:FS01:0x22:Project: 11778 (Run 0, Clone 5618, Gen 10)
07:40:32:WU00:FS01:0x22:Unit: 0x0000000e287234c95e7432776ea6ce9b
07:40:32:WU00:FS01:0x22:Reading tar file core.xml
07:40:32:WU00:FS01:0x22:Reading tar file integrator.xml
07:40:32:WU00:FS01:0x22:Reading tar file state.xml
07:40:32:WU00:FS01:0x22:Reading tar file system.xml
07:40:32:WU00:FS01:0x22:Digital signatures verified
07:40:32:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
07:40:32:WU00:FS01:0x22:Version 0.0.2
07:40:32:WU00:FS01:0x22:ERROR:126: Bad platformId size.
07:40:32:WU00:FS01:0x22:Saving result file ../logfile_01.txt
07:40:32:WU00:FS01:0x22:Saving result file science.log
07:40:32:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
07:40:33:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
07:40:33:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:11778 run:0 clone:5618 gen:10 core:0x22 unit:0x0000000e287234c95e7432776ea6ce9b
07:40:33:WU00:FS01:Uploading 7.50KiB to 40.114.52.201
07:40:33:WU00:FS01:Connecting to 40.114.52.201:8080
07:40:55:WU00:FS01:Upload complete
07:40:55:WU00:FS01:Server responded WORK_ACK (400)
07:40:55:WU00:FS01:Cleaning up
jonault
Re: Radeon HD 8800M on Macbook Pro doing nothing
Post by jonault »
Which video drivers do you have installed? AIUI, you need the proprietary drivers from AMD, not the open source drivers.
I see several possibilities. One is that you may be missing part of the necessary OpenCL. Exactly what you need may depend on which version of Ubuntu and the source of the drivers you installed. Two is that you have the wrong kind of video driver.
What you need for Ubuntu to be usable for GPU folding is the following:
AMD proprietary video drivers
OpenCL support package for AMD
possibly the OpenCL dev kit package
Someone posted an How To for AMD and Ubuntu within the last few days, see if you can find it with a search.
Last possibility is that the 8800M in the MacBook Pro does not support Double Precision. This is a possibility as AMD released several different chips/GPUs labeled as 8800M ad not all of them support for DP, and some do.
MaxxTc
Post by MaxxTc »
OpenCL is running:
  Platform Name                                   Clover
  Platform Vendor                                 Mesa
  Platform Version                                OpenCL 1.1 Mesa 20.1.0-devel (git-050ec8f 2020-03-23 bionic-oibaf-ppa)
  Platform Extensions                             cl_khr_icd
  Platform Extensions function suffix             MESA
  Device Name                                     AMD VERDE (DRM 2.50.0, 5.3.0-42-generic, LLVM 9.0.1)
  Device Vendor                                   AMD
  Device Version                                  OpenCL 1.1 Mesa 20.1.0-devel (git-050ec8f 2020-03-23 bionic-oibaf-ppa)
  Driver Version                                  20.1.0-devel
  Device OpenCL C Version                         OpenCL C 1.1
  Max compute units                               10
  Max clock frequency                             800MHz
  Max work item sizes                             256x256x256
  Preferred work group size multiple              64
    char                                                16 / 16
    short                                                8 / 8
    int                                                  4 / 4
    long                                                 2 / 2
    half                                                 8 / 8        (cl_khr_fp16)
    float                                                4 / 4
    double                                               2 / 2        (cl_khr_fp64)
  Half-precision Floating-point support           (cl_khr_fp16)
    Denormals                                     No
    Round to zero                                 No
    Round to infinity                             No
    IEEE754-2008 fused multiply-add               No
    Denormals                                     No
    Round to zero                                 No
    Correctly-rounded divide and sqrt operations  No
  Global memory size                              2147483648 (2GiB)
  Max memory allocation                           1503238553 (1.4GiB)
  Alignment of base address                       32768 bits (4096 bytes)
  Global Memory cache type                        None
  Image support                                   No
  Local memory size                               32768 (32KiB)
  Max number of constant args                     16
  Max constant buffer size                        1503238553 (1.4GiB)
  Queue properties
  Profiling timer resolution                      0ns
  Execution capabilities
  Device Extensions                               cl_khr_byte_addressable_store cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_fp64 cl_khr_fp16
NULL platform behavior
  clGetPlatformInfo(NULL, CL_PLATFORM_NAME, ...)  Clover
  clGetDeviceIDs(NULL, CL_DEVICE_TYPE_ALL, ...)   Success [MESA]
  clCreateContext(NULL, ...) [default]            Success [MESA]
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_DEFAULT)  Success (1)
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_GPU)  Success (1)
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_CUSTOM)  No devices found in platform
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_ALL)  Success (1)
ICD loader properties
  ICD loader Name                                 OpenCL ICD Loader
  ICD loader Vendor                               OCL Icd free software
  ICD loader Version                              2.2.11
  ICD loader Profile                              OpenCL 2.1
How can I see which driver is loaded?
Welcome to Folding@Home!
The MacBook Pro 2015 I find has a different Graphics chip in it.
https://www.techpowerup.com/gpu-specs/r ... tion.c2730
You did not give us the first 200 lines of your log, where we could see the configuration of your PC from it's point of view. viewtopic.php?f=24&t=26036
I am skeptical you will get it to work as you seem determined not to tell us what you have (13", 15", ?) or what it knows (configuration portion of log)
It is nice you got the CPU portion to work.
[Edit from you last post, it will not work, F@H needs OpenCL 1.2 support, and your specs list Device OpenCL C Version OpenCL C 1.1]
MaxxTc
Post by MaxxTc »
Thank you for your answers. I have a 15" Macbook pro. Here iare the first loglines. I will check the OpenCL thing!
*********************** Log Started 2020-03-28T07:41:41Z ***********************
07:41:41:Started thread 1 on PID 1752
07:41:41:************************* Folding@home Client *************************
07:41:41:        Website: https://foldingathome.org/
07:41:41:      Copyright: (c) 2009-2018 foldingathome.org
07:41:41:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:41:41:           Args: --child --lifeline 1749 /etc/fahclient/config.xml --run-as root
07:41:41:                 --pid-file=/var/run/fahclient.pid --daemon
07:41:41:         Config: /etc/fahclient/config.xml
07:41:41:******************************** Build ********************************
07:41:41:        Version: 7.5.1
07:41:41:           Date: May 11 2018
07:41:41:           Time: 19:59:04
07:41:41:     Repository: Git
07:41:41:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
07:41:41:         Branch: master
07:41:41:       Compiler: GNU 6.3.0 20170516
07:41:41:        Options: -std=gnu++98 -O3 -funroll-loops
07:41:41:       Platform: linux2 4.14.0-3-amd64
07:41:41:           Bits: 64
07:41:41:           Mode: Release
07:41:41:******************************* System ********************************
07:41:41:            CPU: Intel(R) Core(TM) i7-4870HQ CPU @ 2.50GHz
07:41:41:         CPU ID: GenuineIntel Family 6 Model 70 Stepping 1
07:41:41:           CPUs: 8
07:41:41:         Memory: 15.52GiB
07:41:41:    Free Memory: 14.29GiB
07:41:41:        Threads: POSIX_THREADS
07:41:41:     OS Version: 5.3
07:41:41:    Has Battery: true
07:41:41:     On Battery: false
07:41:41:     UTC Offset: 1
07:41:41:            PID: 1752
07:41:41:            CWD: /var/lib/fahclient
07:41:41:             OS: Linux 5.3.0-42-generic x86_64
07:41:41:        OS Arch: AMD64
07:41:41:           GPUs: 1
07:41:41:          GPU 0: Bus:1 Slot:0 Func:0 AMD:5 [Radeon HD 8800M Series]
07:41:41:           CUDA: Not detected: Failed to open dynamic library 'libcuda.so':
07:41:41:                 libcuda.so: cannot open shared object file: No such file or
07:41:41:                 directory
07:41:41:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:1.1 Driver:20.1
07:41:41:***********************************************************************
07:41:41:<config>
07:41:41:  <!-- Client Control -->
07:41:41:  <client-threads v='6'/>
07:41:41:  <cycle-rate v='4'/>
07:41:41:  <cycles v='-1'/>
07:41:41:  <data-directory v='.'/>
07:41:41:  <disable-sleep-when-active v='true'/>
07:41:41:  <exec-directory v='/usr/bin'/>
07:41:41:  <exit-when-done v='false'/>
07:41:41:  <fold-anon v='false'/>
07:41:41:  <idle-seconds v='300'/>
07:41:41:  <open-web-control v='false'/>
07:41:41:
07:41:41:  <!-- Configuration -->
07:41:41:  <config-rotate v='true'/>
07:41:41:  <config-rotate-dir v='configs'/>
07:41:41:  <config-rotate-max v='16'/>
07:41:41:
07:41:41:  <!-- Debugging -->
07:41:41:  <assignment-servers>
07:41:41:    assign1.foldingathome.org:8080 assign2.foldingathome.org:80
07:41:41:  </assignment-servers>
07:41:41:  <auth-as v='true'/>
07:41:41:  <capture-directory v='capture'/>
07:41:41:  <capture-on-error v='false'/>
07:41:41:  <capture-packets v='false'/>
07:41:41:  <capture-requests v='false'/>
07:41:41:  <capture-responses v='false'/>
07:41:41:  <capture-sockets v='false'/>
07:41:41:  <core-exec v='FahCore_$type'/>
07:41:41:  <core-wrapper-exec v='FAHCoreWrapper'/>
07:41:41:  <debug-sockets v='false'/>
07:41:41:  <exception-locations v='true'/>
07:41:41:  <stack-traces v='false'/>
07:41:41:
07:41:41:  <!-- Error Handling -->
07:41:41:  <max-slot-errors v='10'/>
07:41:41:  <max-unit-errors v='5'/>
07:41:41:
07:41:41:  <!-- Folding Core -->
07:41:41:  <checkpoint v='15'/>
07:41:41:  <core-dir v='cores'/>
07:41:41:  <core-priority v='idle'/>
07:41:41:  <cpu-affinity v='false'/>
07:41:41:  <cpu-usage v='100'/>
07:41:41:  <gpu-usage v='100'/>
07:41:41:  <no-assembly v='false'/>
07:41:41:
07:41:41:  <!-- Folding Slot Configuration -->
07:41:41:  <cause v='ANY'/>
07:41:41:  <client-subtype v='LINUX'/>
07:41:41:  <client-type v='advanced'/>
07:41:41:  <cpu-species v='X86_PENTIUM_II'/>
07:41:41:  <cpu-type v='AMD64'/>
07:41:41:  <cpus v='-1'/>
07:41:41:  <disable-viz v='false'/>
07:41:41:  <gpu v='true'/>
07:41:41:  <max-packet-size v='normal'/>
07:41:41:  <os-species v='UNKNOWN'/>
07:41:41:  <os-type v='LINUX'/>
07:41:41:  <project-key v='0'/>
07:41:41:  <smp v='true'/>
07:41:41:
07:41:41:  <!-- GUI -->
07:41:41:  <gui-enabled v='true'/>
07:41:41:
07:41:41:  <!-- HTTP Server -->
07:41:41:  <allow v='127.0.0.1 0.0.0.0/0 192.168.0.0/24'/>
07:41:41:  <connection-timeout v='60'/>
07:41:41:  <deny v='0/0'/>
07:41:41:  <http-addresses v='0:7396'/>
07:41:41:  <https-addresses v=''/>
07:41:41:  <max-connect-time v='900'/>
07:41:41:  <max-connections v='800'/>
07:41:41:  <max-request-length v='52428800'/>
07:41:41:  <min-connect-time v='300'/>
07:41:41:
07:41:41:  <!-- Logging -->
07:41:41:  <log v='log.txt'/>
07:41:41:  <log-color v='true'/>
07:41:41:  <log-crlf v='false'/>
07:41:41:  <log-date v='false'/>
07:41:41:  <log-date-periodically v='21600'/>
07:41:41:  <log-domain v='false'/>
07:41:41:  <log-header v='true'/>
07:41:41:  <log-level v='true'/>
07:41:41:  <log-no-info-header v='true'/>
07:41:41:  <log-redirect v='false'/>
07:41:41:  <log-rotate v='true'/>
07:41:41:  <log-rotate-dir v='logs'/>
07:41:41:  <log-rotate-max v='16'/>
07:41:41:  <log-short-level v='false'/>
07:41:41:  <log-simple-domains v='true'/>
07:41:41:  <log-thread-id v='false'/>
07:41:41:  <log-thread-prefix v='true'/>
07:41:41:  <log-time v='true'/>
07:41:41:  <log-to-screen v='true'/>
07:41:41:  <log-truncate v='false'/>
07:41:41:  <verbosity v='5'/>
07:41:41:
07:41:41:  <!-- Network -->
07:41:41:  <proxy v=':8080'/>
07:41:41:  <proxy-enable v='false'/>
07:41:41:  <proxy-pass v=''/>
07:41:41:  <proxy-user v=''/>
07:41:41:
07:41:41:  <!-- Process Control -->
07:41:41:  <child v='true'/>
07:41:41:  <daemon v='true'/>
07:41:41:  <fork v='false'/>
07:41:41:  <pid v='false'/>
07:41:41:  <pid-file v='/var/run/fahclient.pid'/>
07:41:41:  <respawn v='false'/>
07:41:41:  <service v='false'/>
07:41:41:
07:41:41:  <!-- Remote Command Server -->
07:41:41:  <command-address v='0.0.0.0'/>
07:41:41:  <command-allow-no-pass v='127.0.0.1'/>
07:41:41:  <command-deny-no-pass v='0/0'/>
07:41:41:  <command-enable v='true'/>
07:41:41:  <command-port v='36330'/>
07:41:41:  <password v='************'/>
07:41:41:
07:41:41:  <!-- Slot Control -->
07:41:41:  <idle v='false'/>
07:41:41:  <max-shutdown-wait v='60'/>
07:41:41:  <pause-on-battery v='true'/>
07:41:41:  <pause-on-start v='false'/>
07:41:41:  <paused v='false'/>
07:41:41:  <power v='full'/>
07:41:41:
07:41:41:  <!-- User Information -->
07:41:41:  <machine-id v='0'/>
07:41:41:  <passkey v='********************************'/>
07:41:41:  <team v='52737'/>
07:41:41:  <user v='Christian_Loerner'/>
07:41:41:
07:41:41:  <!-- Web Server -->
07:41:41:  <web-allow v='127.0.0.1'/>
07:41:41:  <web-deny v='0/0'/>
07:41:41:  <web-enable v='true'/>
07:41:41:
07:41:41:  <!-- Web Server Sessions -->
07:41:41:  <session-cookie v='sid'/>
07:41:41:  <session-lifetime v='86400'/>
07:41:41:  <session-timeout v='3600'/>
07:41:41:
07:41:41:  <!-- Work Unit Control -->
07:41:41:  <dump-after-deadline v='true'/>
07:41:41:  <max-queue v='16'/>
07:41:41:  <max-units v='0'/>
07:41:41:  <next-unit-percentage v='99'/>
07:41:41:  <stall-detection-enabled v='false'/>
07:41:41:  <stall-percent v='5'/>
07:41:41:  <stall-timeout v='1800'/>
07:41:41:
07:41:41:  <!-- Folding Slots -->
07:41:41:  <slot id='0' type='CPU'/>
07:41:41:  <slot id='1' type='GPU'/>
07:41:41:</config>
07:41:41:Switching to user root
07:41:41:Trying to access database...
07:41:41:Successfully acquired database lock
07:41:41:Enabled folding slot 00: READY cpu:7
07:41:41:Enabled folding slot 01: READY gpu:0:[Radeon HD 8800M Series]
07:41:41:Started thread 5 on PID 1752
07:41:41:Started thread 7 on PID 1752
07:41:41:Started thread 9 on PID 1752
07:41:41:Started thread 10 on PID 1752
07:41:41:Started thread 6 on PID 1752
07:41:41:Started thread 8 on PID 1752
07:41:41:WU01:FS00:Starting
07:41:41:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/avx/Core_a7.fah/FahCore_a7 -dir 01 -suffix 01 -version 705 -lifeline 1752 -checkpoint 15 -np 7
07:41:41:WU01:FS00:Started FahCore on PID 1802
07:41:41:Started thread 11 on PID 1752
07:41:41:WU01:FS00:Core PID:1806
07:41:41:WU01:FS00:FahCore 0xa7 started
07:41:41:WU00:FS01:Connecting to 65.254.110.245:8080
07:41:41:WU01:FS00:0xa7:*********************** Log Started 2020-03-28T07:41:41Z ***********************
07:41:41:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
07:41:41:WU01:FS00:0xa7:       Type: 0xa7
07:41:41:WU01:FS00:0xa7:       Core: Gromacs
07:41:41:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 1802 -checkpoint 15 -np 7
07:41:41:WU01:FS00:0xa7:************************************ CBang *************************************
07:41:41:WU01:FS00:0xa7:       Date: Nov 5 2019
07:41:41:WU01:FS00:0xa7:       Time: 06:06:57
07:41:41:WU01:FS00:0xa7:   Revision: 46c96f1aa8419571d83f3e63f9c99a0d602f6da9
07:41:41:WU01:FS00:0xa7:     Branch: master
07:41:41:WU01:FS00:0xa7:   Compiler: GNU 8.3.0
07:41:41:WU01:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -fno-pie -fPIC
07:41:41:WU01:FS00:0xa7:   Platform: linux2 4.19.0-5-amd64
07:41:41:WU01:FS00:0xa7:       Bits: 64
07:41:41:WU01:FS00:0xa7:       Mode: Release
07:41:41:WU01:FS00:0xa7:************************************ System ************************************
07:41:41:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-4870HQ CPU @ 2.50GHz
07:41:41:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 70 Stepping 1
07:41:41:WU01:FS00:0xa7:       CPUs: 8
07:41:41:WU01:FS00:0xa7:     Memory: 15.52GiB
07:41:41:WU01:FS00:0xa7:Free Memory: 14.27GiB
07:41:41:WU01:FS00:0xa7:    Threads: POSIX_THREADS
07:41:41:WU01:FS00:0xa7: OS Version: 5.3
07:41:41:WU01:FS00:0xa7:Has Battery: true
07:41:41:WU01:FS00:0xa7: On Battery: false
07:41:41:WU01:FS00:0xa7: UTC Offset: 1
07:41:41:WU01:FS00:0xa7:        PID: 1806
07:41:41:WU01:FS00:0xa7:        CWD: /var/lib/fahclient/work
07:41:41:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
07:41:41:WU01:FS00:0xa7:    Version: 0.0.18
07:41:41:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:41:41:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
07:41:41:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
07:41:41:WU01:FS00:0xa7:       Time: 06:13:26
07:41:41:WU01:FS00:0xa7:   Revision: 490c9aa2957b725af319379424d5c5cb36efb656
07:41:41:WU01:FS00:0xa7:************************************ Build *************************************
07:41:41:WU01:FS00:0xa7:       SIMD: avx_256
07:41:41:WU01:FS00:0xa7:********************************************************************************
The report showing OpenCL running has this line:
That shows that you are running the open source Mesa drivers, not the AMD drivers. The AMD drivers would be available from their support site, or there may be a download from a repository for Ubuntu. Whether the AMD driver and its OpenCL support package will change the OpenCL level to 1.2 I don't know.
