My server crashed. Lost WU. what to do?
mhmediaonline
Hardware configuration: (1) Intel NUC
CPU: Intel(R) Celeron(R) CPU N2820 @ 2.13GHz
CPU ID: GenuineIntel Family 6 Model 55 Stepping 3
CPUs: 2
Memory: 3.74GiB
Free Memory: 1.41GiB
Threads: POSIX_THREADS
OS Version: 4.19
(2) HP XW8400
CPU: Intel(R) Xeon(R) CPU 5150 @ 2.66GHz
CPU ID: GenuineIntel Family 6 Model 15 Stepping 11
CPUs: 4
Memory: 31.42GiB
Free Memory: 30.77GiB
05:03:24:WU01:FS00:0xa7: OS Version: 4.19
Post by mhmediaonline »
Hi, i was about 0.5% into a newly-downloaded WU when my server crashed and took my SSD with it. I've had to do a complete reinstall of Linux so basically i lost all trace of the WU.
I've now setup FAH from scratch using a saved config file and it's waiting for a WU. How long will it be before FAH realises nothing's happened with the lost WU and hopefully send me another?
Re: My server crashed. Lost WU. what to do?
Post by Neil-B »
The WU you had will have a Time Out attached to it - when no response received by then it will be reissued .. Don't stress over the loss of the WU as these things happen.
Your new install should pick up a WU as soon as it can get a slot on the assignment servers (fairly loaded at the moment) - the fact that there is a WU in limbo shouldn't impact that (iirc).
Anyway, you should make sure that such crash doesn't happen again ...
Post by Neil-B »
Reminds me of the car salesman who suggested to my brother that he might not want to "write this one off" after he totalled his car and had to buy a new one :)
