Passkey and points
psjrg
Passkey and points
Post by psjrg »
Hi
If I have been using an identity without a passkey, will it reset my points (effectively make it a separate identitiy from the unpasskeyed version?)
I hope my questions is clear enough. I wasn't sure how to phrase it.
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
RAM: 24 GB DDR4
Re: Passkey and points
Post by Jesse_V »
Nope, the points should go under the same username and team number that you had before. Those won't reset or go away. The points never reset or go down.
psjrg
Post by psjrg »
Thanks. When I initially entered the passkey it showed my in-client points total go from 800,000 to 0. Perhaps i'll see if that corrects itself over time. I haven't done folding in about 10 years.
Jesse_V
CPU: i7-6700k
RAM: 24 GB DDR4
Post by Jesse_V »
psjrg wrote:Thanks. When I initially entered the passkey it showed my in-client points total go from 800,000 to 0. Perhaps i'll see if that corrects itself over time. I haven't done folding in about 10 years.
The in-client points are just an estimation. It should correct itself with the next workunit. The server should give you the proper amount of points depending on how quickly you return the workunit. Note that you can get bonus points from the passkey once you complete 10 workunits with an 80% successful return rate.
Welcome back to F@h!
jonault
Post by jonault »
When you enter a passkey, the web client stops showing you the points you earned before you started using the passkey. You don't lose the points, they just are not displayed any longer. If you click on the stats link, you will see the total including the non-passkey points.
psjrg
Post by psjrg »
Thanks all. Sounds like I have nothing to worry about.
