Connected, Loading,but never does load
Bill-PSI
Post by Bill-PSI »
All it says is "connected" and "loading" for several days. I've rebooted, and it will start a different WU, but then it finishes and goes back to "loading."
Is there a way to avoid and/or bypass the WU, even though I've no idea what it is?
Thx.
HaloJones
Re: Connected, Loading,but never does load
Post by HaloJones »
open fahcontrol, select log out of the three tabs. cut the contents, particularly the beginning, and paste it into a reply using
 at the beginning and
at the end. We can do nothing without more information
single 1070
Bill-PSI
Post by Bill-PSI »
I didn't know how to get you more info, so thanks for that.
I just downloaded a later version than I had installed, so will see if that helps.
Bill-PSI
Post by Bill-PSI »
OK, the latest version did not fix.Now I have "connecting: trying" and "protein: demo"
01:17:43:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
01:17:43:WU00:FS00:0xa7:    Version: 0.0.18
01:17:43:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:17:43:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
01:17:43:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
01:17:43:WU00:FS00:0xa7:       Date: Oct 26 2019
01:17:43:WU00:FS00:0xa7:       Time: 01:52:30
01:17:43:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
01:17:43:WU00:FS00:0xa7:     Branch: master
01:17:43:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
01:17:43:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
01:17:43:WU00:FS00:0xa7:   Platform: win32 10
01:17:43:WU00:FS00:0xa7:       Bits: 64
01:17:43:WU00:FS00:0xa7:       Mode: Release
01:17:43:WU00:FS00:0xa7:************************************ Build *************************************
01:17:43:WU00:FS00:0xa7:       SIMD: avx_256
01:17:43:WU00:FS00:0xa7:********************************************************************************
01:17:43:WU00:FS00:0xa7:Project: 14328 (Run 1, Clone 5779, Gen 16)
01:17:43:WU00:FS00:0xa7:Unit: 0x000000139bf7a4d65e6d12d853a8caaf
01:17:43:WU00:FS00:0xa7:Digital signatures verified
01:17:43:WU00:FS00:0xa7:Calling: mdrun -s frame16.tpr -o frame16.trr -cpi state.cpt -cpt 15 -nt 1
01:17:43:WU00:FS00:0xa7:Steps: first=4000000 total=250000
01:17:44:WU00:FS00:0xa7:Completed 58432 out of 250000 steps (23%)
01:18:27:Removing old file 'configs/config-20160304-071437.xml'
01:18:27:Saving configuration to config.xml
01:18:27:<config>
01:18:27:  <!-- Folding Slot Configuration -->
01:18:27:  <cause v='CANCER'/>
01:18:27:
01:18:27:  <!-- Slot Control -->
01:18:27:  <power v='MEDIUM'/>
01:18:27:
01:18:27:  <!-- User Information -->
01:18:27:  <passkey v='********************************'/>
01:18:27:  <team v='15394'/>
01:18:27:  <user v='Bill-PSI'/>
01:18:27:
01:18:27:  <!-- Folding Slots -->
01:18:27:  <slot id='0' type='CPU'/>
01:18:27:</config>
01:20:44:WU00:FS00:0xa7:Completed 60000 out of 250000 steps (24%)
01:25:24:WU00:FS00:0xa7:Completed 62500 out of 250000 steps (25%)
01:30:57:WU00:FS00:0xa7:Completed 65000 out of 250000 steps (26%)
01:37:26:WU00:FS00:0xa7:Completed 67500 out of 250000 steps (27%)
01:43:39:WU00:FS00:0xa7:Completed 70000 out of 250000 steps (28%)
01:50:25:WU00:FS00:0xa7:Completed 72500 out of 250000 steps (29%)
01:56:27:WU00:FS00:0xa7:Completed 75000 out of 250000 steps (30%)
02:02:42:WU00:FS00:0xa7:Completed 77500 out of 250000 steps (31%)
02:08:49:WU00:FS00:0xa7:Completed 80000 out of 250000 steps (32%)
02:14:57:WU00:FS00:0xa7:Completed 82500 out of 250000 steps (33%)
02:21:02:WU00:FS00:0xa7:Completed 85000 out of 250000 steps (34%)
02:27:01:WU00:FS00:0xa7:Completed 87500 out of 250000 steps (35%)
02:33:44:WU00:FS00:0xa7:Completed 90000 out of 250000 steps (36%)
02:38:23:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:38:39:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
02:38:55:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:39:11:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:39:27:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:39:43:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:39:56:WU00:FS00:0xa7:Completed 92500 out of 250000 steps (37%)
02:39:59:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:40:15:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:40:31:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:40:47:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:41:03:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:41:19:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:41:35:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:41:51:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:42:07:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:42:23:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:42:39:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:42:55:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:43:11:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:43:27:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:43:43:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:43:59:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:44:15:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:44:31:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:44:47:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:45:03:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
02:45:19:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:45:35:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:45:45:WU00:FS00:0xa7:Completed 95000 out of 250000 steps (38%)
02:45:51:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:46:07:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
02:46:23:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:46:39:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:46:55:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:47:11:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:47:27:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:47:43:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:47:59:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:48:15:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
02:51:35:WU00:FS00:0xa7:Completed 97500 out of 250000 steps (39%)
02:57:15:WU00:FS00:0xa7:Completed 100000 out of 250000 steps (40%)
03:03:09:WU00:FS00:0xa7:Completed 102500 out of 250000 steps (41%)
03:08:47:WU00:FS00:0xa7:Completed 105000 out of 250000 steps (42%)
03:14:15:WU00:FS00:0xa7:Completed 107500 out of 250000 steps (43%)
03:19:53:WU00:FS00:0xa7:Completed 110000 out of 250000 steps (44%)
03:25:39:WU00:FS00:0xa7:Completed 112500 out of 250000 steps (45%)
03:31:27:WU00:FS00:0xa7:Completed 115000 out of 250000 steps (46%)
03:37:23:WU00:FS00:0xa7:Completed 117500 out of 250000 steps (47%)
03:44:29:WU00:FS00:0xa7:Completed 120000 out of 250000 steps (48%)
03:50:50:WU00:FS00:0xa7:Completed 122500 out of 250000 steps (49%)
03:56:57:WU00:FS00:0xa7:Completed 125000 out of 250000 steps (50%)
04:03:15:WU00:FS00:0xa7:Completed 127500 out of 250000 steps (51%)
04:09:23:WU00:FS00:0xa7:Completed 130000 out of 250000 steps (52%)
04:15:26:WU00:FS00:0xa7:Completed 132500 out of 250000 steps (53%)
04:21:38:WU00:FS00:0xa7:Completed 135000 out of 250000 steps (54%)
04:27:33:WU00:FS00:0xa7:Completed 137500 out of 250000 steps (55%)
04:33:26:WU00:FS00:0xa7:Completed 140000 out of 250000 steps (56%)
04:39:38:WU00:FS00:0xa7:Completed 142500 out of 250000 steps (57%)
04:46:11:WU00:FS00:0xa7:Completed 145000 out of 250000 steps (58%)
04:52:07:WU00:FS00:0xa7:Completed 147500 out of 250000 steps (59%)
04:58:24:WU00:FS00:0xa7:Completed 150000 out of 250000 steps (60%)
05:04:35:WU00:FS00:0xa7:Completed 152500 out of 250000 steps (61%)
05:10:47:WU00:FS00:0xa7:Completed 155000 out of 250000 steps (62%)
05:16:54:WU00:FS00:0xa7:Completed 157500 out of 250000 steps (63%)
******************************* Date: 2020-03-23 *******************************
05:23:18:WU00:FS00:0xa7:Completed 160000 out of 250000 steps (64%)
05:29:21:WU00:FS00:0xa7:Completed 162500 out of 250000 steps (65%)
05:35:26:WU00:FS00:0xa7:Completed 165000 out of 250000 steps (66%)
05:41:50:WU00:FS00:0xa7:Completed 167500 out of 250000 steps (67%)
05:48:19:WU00:FS00:0xa7:Completed 170000 out of 250000 steps (68%)
05:54:26:WU00:FS00:0xa7:Completed 172500 out of 250000 steps (69%)
06:01:24:WU00:FS00:0xa7:Completed 175000 out of 250000 steps (70%)
06:08:11:WU00:FS00:0xa7:Completed 177500 out of 250000 steps (71%)
06:14:04:WU00:FS00:0xa7:Completed 180000 out of 250000 steps (72%)
06:19:54:WU00:FS00:0xa7:Completed 182500 out of 250000 steps (73%)
06:25:46:WU00:FS00:0xa7:Completed 185000 out of 250000 steps (74%)
06:27:16:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:27:32:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:27:48:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:28:04:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:28:20:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:28:36:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:28:52:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:29:08:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:29:24:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:29:40:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
06:29:56:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:30:12:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:30:28:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
06:30:44:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:31:00:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:31:16:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:31:32:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:31:42:WU00:FS00:0xa7:Completed 187500 out of 250000 steps (75%)
06:31:48:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:32:04:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:32:20:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:32:36:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:32:52:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:33:08:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:33:24:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:33:40:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:33:56:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:34:12:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:34:28:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:34:44:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:35:00:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:35:16:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:35:32:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:35:48:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:36:04:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
06:36:20:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:36:36:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:36:52:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:37:08:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:37:24:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
06:37:34:WU00:FS00:0xa7:Completed 190000 out of 250000 steps (76%)
06:37:40:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:37:56:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:38:12:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:38:28:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:38:44:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:39:00:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:39:16:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:39:32:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:39:48:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:40:04:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:40:20:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:40:36:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
06:40:52:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
06:41:08:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:41:24:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:41:40:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:41:56:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:42:12:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:42:28:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:42:44:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:43:00:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:43:16:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
06:43:32:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:43:35:WU00:FS00:0xa7:Completed 192500 out of 250000 steps (77%)
06:43:48:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
06:44:04:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:44:20:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
06:44:36:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
06:44:52:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:45:08:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:45:24:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:45:40:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:45:56:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:46:12:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:46:28:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:46:44:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:47:00:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:47:16:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:47:32:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:47:48:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:48:04:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:48:20:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:48:36:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:48:52:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:49:08:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:49:24:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
06:49:30:WU00:FS00:0xa7:Completed 195000 out of 250000 steps (78%)
06:49:40:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:49:56:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:50:12:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:50:28:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:50:44:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:51:00:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:51:16:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:51:32:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:51:48:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:52:04:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:52:20:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:52:36:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:52:52:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:53:08:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:53:24:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:53:40:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:53:56:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:54:12:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:54:28:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:54:44:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:55:00:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:55:16:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:55:18:WU00:FS00:0xa7:Completed 197500 out of 250000 steps (79%)
06:55:32:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
06:55:48:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:56:04:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
06:56:20:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:56:36:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:56:52:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:57:08:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
07:01:20:WU00:FS00:0xa7:Completed 200000 out of 250000 steps (80%)
07:07:38:WU00:FS00:0xa7:Completed 202500 out of 250000 steps (81%)
07:14:20:WU00:FS00:0xa7:Completed 205000 out of 250000 steps (82%)
07:20:19:WU00:FS00:0xa7:Completed 207500 out of 250000 steps (83%)
07:26:16:WU00:FS00:0xa7:Completed 210000 out of 250000 steps (84%)
07:32:45:WU00:FS00:0xa7:Completed 212500 out of 250000 steps (85%)
07:39:17:WU00:FS00:0xa7:Completed 215000 out of 250000 steps (86%)
07:45:17:WU00:FS00:0xa7:Completed 217500 out of 250000 steps (87%)
07:51:04:WU00:FS00:0xa7:Completed 220000 out of 250000 steps (88%)
07:56:51:WU00:FS00:0xa7:Completed 222500 out of 250000 steps (89%)
08:02:45:WU00:FS00:0xa7:Completed 225000 out of 250000 steps (90%)
08:08:37:WU00:FS00:0xa7:Completed 227500 out of 250000 steps (91%)
08:14:42:WU00:FS00:0xa7:Completed 230000 out of 250000 steps (92%)
08:21:24:WU00:FS00:0xa7:Completed 232500 out of 250000 steps (93%)
08:27:27:WU00:FS00:0xa7:Completed 235000 out of 250000 steps (94%)
08:33:13:WU00:FS00:0xa7:Completed 237500 out of 250000 steps (95%)
08:39:11:WU00:FS00:0xa7:Completed 240000 out of 250000 steps (96%)
08:45:09:WU00:FS00:0xa7:Completed 242500 out of 250000 steps (97%)
08:50:02:WU00:FS00:0xa7:Completed 245000 out of 250000 steps (98%)
08:54:56:WU00:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
08:54:57:WU01:FS00:Connecting to 65.254.110.245:8080
08:54:57:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
08:54:57:WU01:FS00:Connecting to 18.218.241.186:80
08:54:58:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
08:54:58:ERROR:WU01:FS00:Exception: Could not get an assignment
08:54:58:WU01:FS00:Connecting to 65.254.110.245:8080
08:54:58:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
08:54:58:WU01:FS00:Connecting to 18.218.241.186:80
08:55:58:WU01:FS00:Connecting to 65.254.110.245:8080
08:55:58:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
08:55:58:WU01:FS00:Connecting to 18.218.241.186:80
08:55:58:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
08:55:58:ERROR:WU01:FS00:Exception: Could not get an assignment
08:57:35:WU01:FS00:Connecting to 65.254.110.245:8080
08:57:35:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
08:57:35:WU01:FS00:Connecting to 18.218.241.186:80
08:57:36:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
08:57:36:ERROR:WU01:FS00:Exception: Could not get an assignment
08:59:52:WU00:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
08:59:54:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
08:59:54:WU00:FS00:0xa7:Saving result file frame16.trr
08:59:55:WU00:FS00:0xa7:Saving result file md.log
08:59:55:WU00:FS00:0xa7:Saving result file science.log
08:59:55:WU00:FS00:0xa7:Saving result file traj_comp.xtc
08:59:55:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
08:59:56:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
08:59:56:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14328 run:1 clone:5779 gen:16 core:0xa7 unit:0x000000139bf7a4d65e6d12d853a8caaf
08:59:56:WU00:FS00:Uploading 4.96MiB to 155.247.164.214
08:59:56:WU00:FS00:Connecting to 155.247.164.214:8080
08:59:57:WARNING:WU00:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 119
08:59:57:WU00:FS00:Trying to send results to collection server
08:59:57:WU00:FS00:Uploading 4.96MiB to 155.247.166.220
08:59:57:WU00:FS00:Connecting to 155.247.166.220:8080
09:00:05:WU00:FS00:Upload complete
09:00:05:WU00:FS00:Server responded WORK_QUIT (404)
09:00:05:WARNING:WU00:FS00:Server did not like results, dumping
09:00:05:WU00:FS00:Cleaning up
09:00:12:WU01:FS00:Connecting to 65.254.110.245:8080
09:00:13:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
09:00:13:WU01:FS00:Connecting to 18.218.241.186:80
09:00:13:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
09:00:13:ERROR:WU01:FS00:Exception: Could not get an assignment
09:04:27:WU01:FS00:Connecting to 65.254.110.245:8080
09:04:27:WU01:FS00:Assigned to work server 40.114.52.201
09:04:27:WU01:FS00:Requesting new work unit for slot 00: READY cpu:3 from 40.114.52.201
09:04:27:WU01:FS00:Connecting to 40.114.52.201:8080
09:04:48:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
09:04:48:WU01:FS00:Connecting to 40.114.52.201:80
09:05:09:ERROR:WU01:FS00:Exception: Failed to connect to 40.114.52.201:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:11:18:WU01:FS00:Connecting to 65.254.110.245:8080
09:11:18:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
09:11:18:WU01:FS00:Connecting to 18.218.241.186:80
09:11:18:WU01:FS00:Assigned to work server 40.114.52.201
09:11:18:WU01:FS00:Requesting new work unit for slot 00: READY cpu:3 from 40.114.52.201
09:11:18:WU01:FS00:Connecting to 40.114.52.201:8080
09:11:39:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
09:11:39:WU01:FS00:Connecting to 40.114.52.201:80
09:12:00:ERROR:WU01:FS00:Exception: Failed to connect to 40.114.52.201:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:22:24:WU01:FS00:Connecting to 65.254.110.245:8080
09:22:24:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
09:22:24:WU01:FS00:Connecting to 18.218.241.186:80
09:22:24:WU01:FS00:Assigned to work server 40.114.52.201
09:22:24:WU01:FS00:Requesting new work unit for slot 00: READY cpu:3 from 40.114.52.201
09:22:24:WU01:FS00:Connecting to 40.114.52.201:8080
09:22:45:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
09:22:45:WU01:FS00:Connecting to 40.114.52.201:80
09:23:06:ERROR:WU01:FS00:Exception: Failed to connect to 40.114.52.201:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:40:20:WU01:FS00:Connecting to 65.254.110.245:8080
09:40:21:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
09:40:21:WU01:FS00:Connecting to 18.218.241.186:80
09:40:21:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
09:40:21:ERROR:WU01:FS00:Exception: Could not get an assignment
10:09:23:WU01:FS00:Connecting to 65.254.110.245:8080
10:09:23:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:09:23:WU01:FS00:Connecting to 18.218.241.186:80
10:09:23:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:09:23:ERROR:WU01:FS00:Exception: Could not get an assignment
10:56:22:WU01:FS00:Connecting to 65.254.110.245:8080
10:56:22:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:56:22:WU01:FS00:Connecting to 18.218.241.186:80
10:56:22:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:56:22:ERROR:WU01:FS00:Exception: Could not get an assignment
12:12:22:WU01:FS00:Connecting to 65.254.110.245:8080
12:12:23:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
12:12:23:WU01:FS00:Connecting to 18.218.241.186:80
12:12:23:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
12:12:23:ERROR:WU01:FS00:Exception: Could not get an assignment
14:15:22:WU01:FS00:Connecting to 65.254.110.245:8080
14:15:22:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:15:22:WU01:FS00:Connecting to 18.218.241.186:80
14:15:22:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:15:22:ERROR:WU01:FS00:Exception: Could not get an assignment
16:39:11:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
16:39:27:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
16:39:43:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
16:39:59:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
16:40:15:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
16:40:31:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
16:40:47:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
16:41:03:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
16:41:19:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
16:41:35:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
16:41:51:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
16:42:07:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
16:42:23:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
16:42:39:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
16:42:55:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
16:43:11:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
16:43:27:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
16:43:43:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
16:43:59:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
16:44:15:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
16:44:31:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
16:44:47:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
16:45:03:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
16:45:19:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
16:45:35:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
16:45:51:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
16:46:07:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
16:46:23:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
16:46:39:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
16:46:55:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
16:47:11:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
16:47:27:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
16:47:43:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
16:47:59:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
16:48:15:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
16:48:31:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
16:48:47:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
16:49:03:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:34:22:WU01:FS00:Connecting to 65.254.110.245:8080
17:34:23:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:34:23:WU01:FS00:Connecting to 18.218.241.186:80
17:34:23:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:34:23:ERROR:WU01:FS00:Exception: Could not get an assignment
17:36:30:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:36:46:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:37:02:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:37:18:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:37:34:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:37:50:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:38:06:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
17:38:22:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
17:38:38:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
17:38:54:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:39:10:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:39:26:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
17:39:42:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
17:39:58:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:40:14:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
17:40:30:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
17:40:46:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
17:41:02:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
17:41:18:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:41:34:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:41:50:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:42:06:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:42:22:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:42:38:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:42:54:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:43:10:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
17:43:26:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
17:43:42:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
17:43:58:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
17:44:14:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:44:30:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
17:44:46:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:45:02:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:45:18:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
17:45:34:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:45:50:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
17:46:06:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
17:46:22:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
17:46:38:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:46:54:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:47:10:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
17:47:26:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
17:47:42:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
17:47:58:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:48:14:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:48:30:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:48:46:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:49:02:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:49:18:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
17:49:34:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
17:49:50:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:50:06:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:50:22:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:50:38:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:50:54:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
17:51:10:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:51:26:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
17:51:42:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:51:58:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:52:14:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
17:52:30:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:52:46:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
17:53:02:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:53:18:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:53:34:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:53:50:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
17:54:06:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:54:22:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:54:38:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:54:54:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:55:10:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:55:26:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:55:42:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:55:58:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:56:14:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
17:56:30:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
17:56:46:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:57:02:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
17:57:18:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:57:34:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:57:50:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:58:06:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
17:58:22:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:58:38:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
17:58:54:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:59:10:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:59:26:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
17:59:42:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
17:59:58:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
18:00:14:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
18:00:30:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
18:00:46:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
18:01:02:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
18:01:18:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
18:01:34:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
18:01:50:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
18:02:06:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
18:02:22:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
18:02:38:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
18:02:54:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
18:03:10:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
18:03:26:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
18:03:42:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
18:03:58:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
18:04:14:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
18:04:30:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
18:04:46:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
18:05:02:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
18:05:18:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
18:05:34:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
18:05:50:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
18:06:06:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
18:06:22:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
19:20:39:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
19:20:55:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
19:21:11:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:21:27:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:21:43:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
19:21:59:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
19:22:15:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
19:22:31:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
19:22:47:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:23:03:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:23:19:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
19:23:35:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:23:51:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:24:07:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:24:23:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:24:39:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:24:55:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:25:11:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
19:25:27:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:25:43:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:25:59:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
19:26:15:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:26:31:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:26:47:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:27:03:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
19:27:19:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:27:35:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:27:51:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:28:07:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:28:23:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:28:39:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:28:55:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:29:11:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:29:27:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:29:43:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:29:59:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
19:30:15:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:30:31:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:30:47:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
19:31:03:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
19:31:19:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:31:35:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
19:31:51:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
19:32:07:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
19:32:23:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
19:32:39:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:32:55:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:33:11:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:33:27:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:33:43:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:33:59:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:34:15:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:34:31:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
19:34:47:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
19:35:03:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:35:19:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:35:35:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
19:35:51:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
19:36:07:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
19:36:23:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
19:36:39:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:36:55:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
19:37:11:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:37:27:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
19:37:43:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
19:37:59:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:38:15:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:38:31:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:38:47:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:39:03:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:39:19:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:39:35:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
19:39:51:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
19:40:07:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
19:40:23:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
19:40:39:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:40:55:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:41:11:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:41:27:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:41:43:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:41:59:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:42:15:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:42:31:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:42:47:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:43:03:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
19:43:19:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:43:35:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
19:43:51:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
19:44:07:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:44:23:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
19:44:39:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
20:54:40:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
20:54:56:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
20:55:12:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
20:55:28:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
20:55:44:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
20:56:00:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
20:56:16:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
20:56:32:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
20:56:48:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
Reason: added Code tags to log
That sounds like you are trying to open the FAHViewer. I don't recall seeing "protein: demo" ever in FAHControl or the Web Control. You did not show the very beginning of the log, so it which OS you are using is not apparent. The viewer is known to not work on Windows.
The 10053 and 10054 messages can be ignored, they just come from Web Control and FAHViewer not closing their connections properly.
What is shown is that there a Core_A7 WU being processed.
The FAH Viewer is not essential to helping with the research. (It's fine if you don't run it.) Pay attention to what webcontrol or fahcontrol tells you you're doing.
Yes, FAHViewer has bugs which are on the list for a future revision of the downloaded software, but I don't anticipate that to be available until we grow our server capabiiles and research projects to match the demands put on them by those who are trying to help. We've upscaled 20X in 10 days and the demand for resources grows faster than we can provide them.
Bill-PSI
Post by Bill-PSI »
That's what I see when the screen saver kicks in. Used to show progress, etc.
The entire log file was larger than 60k, so I had to cut something, and I thought you said to cut the beginning. :-)
As long as FAH is processing and doing real work, I'm OK.
Yes, I have Windows, and FAH has been working for many many years and on many versions of Windows.
Here is the beginning of the log file:
*********************** Log Started 2020-03-22T23:21:28Z ***********************
23:21:28:************************* Folding@home Client *************************
23:21:28:        Website: https://foldingathome.org/
23:21:28:      Copyright: (c) 2009-2018 foldingathome.org
23:21:28:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:21:28:           Args: --open-web-control
23:21:28:         Config: C:\Users\Bill\AppData\Roaming\FAHClient\config.xml
23:21:28:******************************** Build ********************************
23:21:28:        Version: 7.5.1
23:21:28:           Date: May 11 2018
23:21:28:           Time: 13:06:32
23:21:28:     Repository: Git
23:21:28:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
23:21:28:         Branch: master
23:21:28:       Compiler: Visual C++ 2008
23:21:28:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:21:28:       Platform: win32 10
23:21:28:           Bits: 32
23:21:28:           Mode: Release
23:21:28:******************************* System ********************************
23:21:28:            CPU: Intel(R) Xeon(R) CPU E5-1607 v3 @ 3.10GHz
23:21:28:         CPU ID: GenuineIntel Family 6 Model 63 Stepping 2
23:21:28:           CPUs: 4
23:21:28:         Memory: 47.92GiB
23:21:28:    Free Memory: 32.80GiB
23:21:28:        Threads: WINDOWS_THREADS
23:21:28:     OS Version: 6.1
23:21:28:    Has Battery: false
23:21:28:     On Battery: false
23:21:28:     UTC Offset: -7
23:21:28:            PID: 155268
23:21:28:            CWD: C:\Users\Bill\AppData\Roaming\FAHClient
23:21:28:             OS: Windows 7 Professional
23:21:28:        OS Arch: AMD64
23:21:28:           GPUs: 1
23:21:28:          GPU 0: Bus:2 Slot:0 Func:0 AMD:5 Oland GL [FirePro W2100]
23:21:28:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
23:21:28:                 specified module could not be found.
23:21:28:
23:21:28:OpenCL Device 0: Platform:0 Device:0 Bus:2 Slot:0 Compute:1.2 Driver:2117.13
23:21:28:  Win32 Service: false
23:21:28:***********************************************************************
23:21:28:<config>
23:21:28:  <!-- Folding Slot Configuration -->
23:21:28:  <cause v='CANCER'/>
23:21:28:
23:21:28:  <!-- Slot Control -->
23:21:28:  <power v='LIGHT'/>
23:21:28:
23:21:28:  <!-- User Information -->
23:21:28:  <passkey v='********************************'/>
23:21:28:  <team v='15394'/>
23:21:28:  <user v='Bill-PSI'/>
23:21:28:
23:21:28:  <!-- Folding Slots -->
23:21:28:  <slot id='0' type='CPU'/>
23:21:28:</config>
23:21:28:Trying to access database...
23:21:29:Upgrading database schema from version 13 to 16
23:21:29:Successfully acquired database lock
23:21:29:Enabled folding slot 00: READY cpu:1
23:21:31:WU00:FS00:Connecting to 65.254.110.245:8080
23:21:32:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
23:21:32:WU00:FS00:Connecting to 18.218.241.186:80
23:21:33:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
23:21:33:ERROR:WU00:FS00:Exception: Could not get an assignment
23:21:33:WU00:FS00:Connecting to 65.254.110.245:8080
23:21:34:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
23:21:34:WU00:FS00:Connecting to 18.218.241.186:80
23:21:34:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
23:21:34:ERROR:WU00:FS00:Exception: Could not get an assignment
23:21:39:16:127.0.0.1:New Web connection
23:22:33:WU00:FS00:Connecting to 65.254.110.245:8080
23:22:34:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
23:22:34:WU00:FS00:Connecting to 18.218.241.186:80
23:22:34:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
23:22:34:ERROR:WU00:FS00:Exception: Could not get an assignment
23:24:11:WU00:FS00:Connecting to 65.254.110.245:8080
23:24:11:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
23:24:11:WU00:FS00:Connecting to 18.218.241.186:80
23:24:11:WU00:FS00:Assigned to work server 155.247.164.214
23:24:11:WU00:FS00:Requesting new work unit for slot 00: READY cpu:1 from 155.247.164.214
23:24:11:WU00:FS00:Connecting to 155.247.164.214:8080
23:24:14:WU00:FS00:Downloading 1.53MiB
23:24:15:WU00:FS00:Download complete
23:24:15:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14328 run:1 clone:5779 gen:16 core:0xa7 unit:0x000000139bf7a4d65e6d12d853a8caaf
23:24:15:WU00:FS00:Starting
23:24:15:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Bill\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 155268 -checkpoint 15 -np 1
23:24:17:WU00:FS00:Started FahCore on PID 158736
23:24:20:WU00:FS00:Core PID:159616
23:24:20:WU00:FS00:FahCore 0xa7 started
23:24:20:WU00:FS00:0xa7:*********************** Log Started 2020-03-22T23:24:20Z ***********************
23:24:20:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
23:24:20:WU00:FS00:0xa7:       Type: 0xa7
23:24:20:WU00:FS00:0xa7:       Core: Gromacs
23:24:20:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 158736 -checkpoint 15 -np
23:24:20:WU00:FS00:0xa7:             1
23:24:20:WU00:FS00:0xa7:************************************ CBang *************************************
23:24:20:WU00:FS00:0xa7:       Date: Oct 26 2019
23:24:20:WU00:FS00:0xa7:       Time: 01:38:25
23:24:20:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
23:24:20:WU00:FS00:0xa7:     Branch: master
23:24:20:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
23:24:20:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:24:20:WU00:FS00:0xa7:   Platform: win32 10
23:24:20:WU00:FS00:0xa7:       Bits: 64
23:24:20:WU00:FS00:0xa7:       Mode: Release
23:24:20:WU00:FS00:0xa7:************************************ System ************************************
23:24:20:WU00:FS00:0xa7:        CPU: Intel(R) Xeon(R) CPU E5-1607 v3 @ 3.10GHz
23:24:20:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 63 Stepping 2
23:24:20:WU00:FS00:0xa7:       CPUs: 4
23:24:20:WU00:FS00:0xa7:     Memory: 47.92GiB
23:24:20:WU00:FS00:0xa7:Free Memory: 32.50GiB
23:24:20:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
23:24:20:WU00:FS00:0xa7: OS Version: 6.1
23:24:20:WU00:FS00:0xa7:Has Battery: false
23:24:20:WU00:FS00:0xa7: On Battery: false
23:24:20:WU00:FS00:0xa7: UTC Offset: -7
23:24:20:WU00:FS00:0xa7:        PID: 159616
23:24:20:WU00:FS00:0xa7:        CWD: C:\Users\Bill\AppData\Roaming\FAHClient\work
23:24:20:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
23:24:20:WU00:FS00:0xa7:    Version: 0.0.18
23:24:20:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:24:20:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
23:24:20:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
23:24:20:WU00:FS00:0xa7:       Time: 01:52:30
23:24:20:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
23:24:20:WU00:FS00:0xa7:************************************ Build *************************************
23:24:20:WU00:FS00:0xa7:       SIMD: avx_256
23:24:20:WU00:FS00:0xa7:********************************************************************************
23:24:20:WU00:FS00:0xa7:Project: 14328 (Run 1, Clone 5779, Gen 16)
23:24:20:WU00:FS00:0xa7:Unit: 0x000000139bf7a4d65e6d12d853a8caaf
23:24:20:WU00:FS00:0xa7:Reading tar file core.xml
23:24:20:WU00:FS00:0xa7:Reading tar file frame16.tpr
23:24:20:WU00:FS00:0xa7:Digital signatures verified
23:24:20:WU00:FS00:0xa7:Calling: mdrun -s frame16.tpr -o frame16.trr -cpt 15 -nt 1
23:24:20:WU00:FS00:0xa7:Steps: first=4000000 total=250000
23:24:21:WU00:FS00:0xa7:Completed 1 out of 250000 steps (0%)
23:27:02:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
23:29:14:WU00:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
23:29:44:FS00:Shutting core down
23:29:44:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 159616
23:29:44:WU00:FS00:0xa7:Exiting, please wait. . .
23:29:47:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
23:29:47:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
23:29:47:WU00:FS00:Starting
23:29:47:WARNING:WU00:FS00:Changed SMP threads from 1 to 4 this can cause some work units to fail
23:29:47:WARNING:WU00:FS00:AS lowered CPUs from 4 to 1
23:29:47:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Bill\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 155268 -checkpoint 15 -np 1
23:29:49:WU00:FS00:Started FahCore on PID 161236
23:29:51:WU00:FS00:Core PID:158944
23:29:51:WU00:FS00:FahCore 0xa7 started
23:29:51:WU00:FS00:0xa7:*********************** Log Started 2020-03-22T23:29:51Z ***********************
23:29:51:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
23:29:51:WU00:FS00:0xa7:       Type: 0xa7
23:29:51:WU00:FS00:0xa7:       Core: Gromacs
23:29:51:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 161236 -checkpoint 15 -np
23:29:51:WU00:FS00:0xa7:             1
23:29:51:WU00:FS00:0xa7:************************************ CBang *************************************
23:29:51:WU00:FS00:0xa7:       Date: Oct 26 2019
23:29:51:WU00:FS00:0xa7:       Time: 01:38:25
23:29:51:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
23:29:51:WU00:FS00:0xa7:     Branch: master
23:29:51:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
23:29:51:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:29:51:WU00:FS00:0xa7:   Platform: win32 10
23:29:51:WU00:FS00:0xa7:       Bits: 64
23:29:51:WU00:FS00:0xa7:       Mode: Release
23:29:51:WU00:FS00:0xa7:************************************ System ************************************
23:29:51:WU00:FS00:0xa7:        CPU: Intel(R) Xeon(R) CPU E5-1607 v3 @ 3.10GHz
23:29:51:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 63 Stepping 2
23:29:51:WU00:FS00:0xa7:       CPUs: 4
23:29:51:WU00:FS00:0xa7:     Memory: 47.92GiB
23:29:51:WU00:FS00:0xa7:Free Memory: 32.77GiB
23:29:51:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
23:29:51:WU00:FS00:0xa7: OS Version: 6.1
23:29:51:WU00:FS00:0xa7:Has Battery: false
23:29:51:WU00:FS00:0xa7: On Battery: false
23:29:51:WU00:FS00:0xa7: UTC Offset: -7
23:29:51:WU00:FS00:0xa7:        PID: 158944
23:29:51:WU00:FS00:0xa7:        CWD: C:\Users\Bill\AppData\Roaming\FAHClient\work
23:29:51:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
23:29:51:WU00:FS00:0xa7:    Version: 0.0.18
23:29:51:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:29:51:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
23:29:51:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
23:29:51:WU00:FS00:0xa7:       Time: 01:52:30
23:29:51:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
23:29:51:WU00:FS00:0xa7:************************************ Build *************************************
23:29:51:WU00:FS00:0xa7:       SIMD: avx_256
23:29:51:WU00:FS00:0xa7:********************************************************************************
23:29:51:WU00:FS00:0xa7:Project: 14328 (Run 1, Clone 5779, Gen 16)
23:29:51:WU00:FS00:0xa7:Unit: 0x000000139bf7a4d65e6d12d853a8caaf
23:29:51:WU00:FS00:0xa7:Digital signatures verified
23:29:51:WU00:FS00:0xa7:Calling: mdrun -s frame16.tpr -o frame16.trr -cpi state.cpt -cpt 15 -nt 1
23:29:51:WU00:FS00:0xa7:Steps: first=4000000 total=250000
23:29:52:WU00:FS00:0xa7:Completed 2772 out of 250000 steps (1%)
23:30:38:Removing old file 'configs/config-20151226-020145.xml'
23:30:38:Saving configuration to config.xml
23:30:38:<config>
23:30:38:  <!-- Folding Slot Configuration -->
23:30:38:  <cause v='CANCER'/>
23:30:38:
23:30:38:  <!-- Slot Control -->
23:30:38:  <power v='full'/>
23:30:38:
23:30:38:  <!-- User Information -->
