NVIDIA Quadro M620
gsk
NVIDIA Quadro M620
Post by gsk »
Hi,
My GPU NVIDIA Quadro M620 is missing from the list.
GPU-Z and NVIDIA Control panel shows conflicting device IDs:
GPU-Z: 10DE 13B4 - 1028 07A9
NVIDIA: 10DE 13B4 07A9 1028
C:\Program Files (x86)\FAHClient>fahclient --lspci
20:43:59:INFO(1):Read GPUs.txt
0x8086:0x1903:0:4:0:Intel Corporation:Intel(R) Dynamic Platform and Thermal Framework Processor Participant
0x8086:0xa154:0:31:0:Intel Corporation:Intel(R) 100 Series/C230 Series Chipset Family LPC Controller (CM238) - A154
0x8086:0xa111:0:28:0:Intel Corporation:Intel(R) 100 Series/C230 Series Chipset Family PCI Express Root Port #2 - A111
0x8086:0xa12f:0:20:0:Intel Corporation:USB xHCI Compliant Host Controller
0x8086:0xa123:0:31:4:Intel Corporation:Intel(R) 100 Series/C230 Series Chipset Family SMBus - A123
0x168c:0x003e:2:0:0:Qualcomm Atheros:Qualcomm QCA61x4A 802.11ac Wireless Adapter
0x8086:0xa131:0:20:2:Intel Corporation:Intel(R) 100 Series/C230 Series Chipset Family Thermal subsystem - A131
0x8086:0x5910:0:0:0:Intel Corporation:PCI standard host CPU bridge
0x8086:0xa13a:0:22:0:Intel Corporation:Intel(R) Management Engine Interface
0x8086:0x591b:0:2:0:Intel Corporation:Intel(R) HD Graphics 630
0x10ec:0x525a:3:0:0:Realtek Semiconductor Co., Ltd.:Realtek PCIE CardReader
0x8086:0x15e3:0:31:6:Intel Corporation:Intel(R) Ethernet Connection (5) I219-LM
0x8086:0xa161:0:21:1:Intel Corporation:Intel(R) Serial IO I2C Host Controller - A161
0x8086:0xa112:0:28:2:Intel Corporation:Intel(R) 100 Series/C230 Series Chipset Family PCI Express Root Port #3 - A112
0x10de:0x13b4:1:0:0:NVIDIA Corporation:NVIDIA Quadro M620
0x8086:0x1901:0:1:0:Intel Corporation:PCI-to-PCI Bridge
0x8086:0xa121:0:31:2:Intel Corporation:Intel(R) 100 Series/C230 Series Chipset Family PMC - A121
0x8086:0x2822:0:23:0:Intel Corporation:Intel(R) Chipset SATA/PCIe RST Premium Controller
0x8086:0xa160:0:21:0:Intel Corporation:Intel(R) Serial IO I2C Host Controller - A160
0x8086:0xa171:0:31:3:Intel Corporation:High Definition Audio Controller
0x8086:0xa114:0:28:4:Intel Corporation:Intel(R) 100 Series/C230 Series Chipset Family PCI Express Root Port #5 - A114
*********************** Log Started 2020-03-22T20:20:28Z ***********************
20:20:28:************************* Folding@home Client *************************
20:20:28:        Website: https://foldingathome.org/
20:20:28:      Copyright: (c) 2009-2018 foldingathome.org
20:20:28:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:20:28:           Args: --open-web-control
20:20:28:         Config: C:\Users\usr\AppData\Roaming\FAHClient\config.xml
20:20:28:******************************** Build ********************************
20:20:28:        Version: 7.5.1
20:20:28:           Date: May 11 2018
20:20:28:           Time: 13:06:32
20:20:28:     Repository: Git
20:20:28:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
20:20:28:         Branch: master
20:20:28:       Compiler: Visual C++ 2008
20:20:28:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:20:28:       Platform: win32 10
20:20:28:           Bits: 32
20:20:28:           Mode: Release
20:20:28:******************************* System ********************************
20:20:28:            CPU: Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz
20:20:28:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
20:20:28:           CPUs: 8
20:20:28:         Memory: 31.88GiB
20:20:28:    Free Memory: 25.34GiB
20:20:28:        Threads: WINDOWS_THREADS
20:20:28:     OS Version: 6.2
20:20:28:    Has Battery: true
20:20:28:     On Battery: false
20:20:28:     UTC Offset: 2
20:20:28:            PID: 9424
20:20:28:            CWD: C:\Users\usr\AppData\Roaming\FAHClient
20:20:28:             OS: Windows 10 Enterprise
20:20:28:        OS Arch: AMD64
20:20:28:           GPUs: 0
20:20:28:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:5.0 Driver:10.0
20:20:28:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:26.20
20:20:28:  Win32 Service: false
20:20:28:***********************************************************************
20:20:28:<config>
20:20:28:  <!-- Network -->
20:20:28:  <proxy v=':8080'/>
20:20:28:
20:20:28:  <!-- Slot Control -->
20:20:28:  <power v='medium'/>
20:20:28:
20:20:28:  <!-- User Information -->
20:20:28:  <passkey v='********************************'/>
20:20:28:  <team v='223518'/>
20:20:28:  <user v='gsk'/>
20:20:28:
20:20:28:  <!-- Folding Slots -->
20:20:28:  <slot id='0' type='CPU'/>
20:20:28:</config>
20:20:28:Trying to access database...
20:20:28:Successfully acquired database lock
20:20:28:Enabled folding slot 00: READY cpu:7
20:20:29:WU00:FS00:Connecting to 65.254.110.245:8080
20:20:30:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:20:30:WU00:FS00:Connecting to 18.218.241.186:80
20:20:31:WU00:FS00:Assigned to work server 155.247.164.214
20:20:31:WU00:FS00:Requesting new work unit for slot 00: READY cpu:7 from 155.247.164.214
20:20:31:WU00:FS00:Connecting to 155.247.164.214:8080
20:20:39:WU00:FS00:Downloading 1.53MiB
20:20:39:WU00:FS00:Download complete
20:20:39:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14328 run:7 clone:4157 gen:40 core:0xa7 unit:0x0000002a9bf7a4d65e6d0d0d0cfbf78c
20:20:39:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah
20:20:39:WU00:FS00:Connecting to cores.foldingathome.org:80
20:20:39:ERROR:WU00:FS00:Exception: Failed reading core package header.
20:21:39:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah
20:21:39:WU00:FS00:Connecting to cores.foldingathome.org:80
20:21:39:ERROR:WU00:FS00:Exception: Failed reading core package header.
20:23:16:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah
20:23:16:WU00:FS00:Connecting to cores.foldingathome.org:80
20:23:17:ERROR:WU00:FS00:Exception: Failed reading core package header.
20:25:53:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah
20:25:53:WU00:FS00:Connecting to cores.foldingathome.org:80
20:25:54:ERROR:WU00:FS00:Exception: Failed reading core package header.
20:30:08:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah
20:30:08:WU00:FS00:Connecting to cores.foldingathome.org:80
20:30:08:ERROR:WU00:FS00:Exception: Failed reading core package header.
20:36:59:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah
20:36:59:WU00:FS00:Connecting to cores.foldingathome.org:80
20:36:59:ERROR:WU00:FS00:Exception: Failed reading core package header.
Re: NVIDIA Quadro M620
The first part of both reports match, and that is the part needed.
OpenCL is not correctly installed or the GPU is disabled (laptop with power saving features ?). Please install latest drivers downloaded from nVidia and try again.
gsk
Post by gsk »
toTOW wrote:OpenCL is not correctly installed or the GPU is disabled (laptop with power saving features ?). Please install latest drivers downloaded from nVidia and try again.
Installed 442.74 (ODE branch) driver. Sorry, I cannot use regular drivers due to other requirements. How can I check if OpenCL is now ok?
EDIT: It is a laptop. But I done all I could think off for FAH to use M620.
EDIT 2:
This line should claim the driver is 442.74
gsk
Post by gsk »
JimboPalmer wrote:20:20:28:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:26.20
Now it is.
14:27:49:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:442.74
New GPU added to the list : 13b4 - GM107GLM [Quadro M620 Mobile]
