Hy there,
since a few days I´m folding and since yesterday also with a PassKey.
As I´m currently not receiving bonus points I´m wondering why.
Can I see the number of finished WUs and the resturn rate since I use the Passkey?
If not: can anyone else see my statistics ? My username is SvenT for folding
Regards
Sven
Can I see my return rate ?
Re: Can I see my return rate ?
There are several lookups you can use on apps.foldingathome.org. The Donor Stats which list total points and WUs is here - https://stats.foldingathome.org/donors
You do need to complete 10 WUs with a passkey and turn them in before you get bonus points on all returns after that as lon as you keep up an 80% return rate.
Hey Joe,
I know these rewuirements, but where can I see what´s missing?
As mentioned I am folding since yesterday with a Passkey and Ißd like to know hom much WUs of the 10 are missing and what my return rate is.
Regards
Sven
Regards
Sven
A quick check you can do yourself would be once you have completed 10 units whether you start getting the quick return bonus. A longer self check would be to just check all your logs and see if you had any failures, these do happen sometimes through no fault of the donor but should not be common.SvenT wrote:Hey Joe,
Regards
Sven
You're probably facing the problem of having two stats accounts.
THe account with your name and no passkey is not unique and anybody can contribute to it. The account with your name+passkey is tabulated separately and they cannot be merged in the FAH stats although 3rd party stats engines probably do.
The Bonus status on the apps page I gave you a link to gives exactly that, I searched and the report is 9 WUs returned, 100%. You need one more return with the passkey.SvenT wrote:Hey Joe,
Regards
Sven
