1.) My computer is really old - does it make sense to run FAH? I was hoping to contribute even if it won't be much. The specs are:
System: Host: benni Kernel: 4.4.0-176-generic x86_64 (64 bit gcc: 5.4.0)
Desktop: MATE 1.14.1 (Gtk 3.18.9-1ubuntu3.3) Distro: Linux Mint 18 Sarah
Machine: Mobo: ASUSTeK model: M2NS-NVM v: 1.XX
Bios: Phoenix v: ASUS M2NS-NVM 0401 date: 09/28/2006
CPU: Dual core AMD model unknown (-MCP-) cache: 1024 KB
flags: (lm nx sse sse2 sse3 svm) bmips: 10448
clock speeds: max: 3100 MHz 1: 2600 MHz 2: 2600 MHz
Graphics: Card: NVIDIA C61 [GeForce 6100 nForce 405] bus-ID: 00:0d.0
Display Server: X.Org 1.18.4 drivers: nvidia (unloaded: fbdev,vesa,nouveau)
Resolution: 1920x1080@60.00hz
GLX Renderer: GeForce 6100 nForce 405/integrated/SSE2
GLX Version: 2.1.2 NVIDIA 304.135 Direct Rendering: Yes
Audio: Card NVIDIA MCP61 High Definition Audio driver: snd_hda_intel bus-ID: 00:05.0
Sound: Advanced Linux Sound Architecture v: k4.4.0-176-generic
Network: Card: NVIDIA MCP61 Ethernet driver: forcedeth port: ec00 bus-ID: 00:07.0
IF: enp0s7 state: up speed: 100 Mbps duplex: full mac: 6a:e5:e3:1d:6e:00
Drives: HDD Total Size: 160.0GB (86.8% used)
ID-1: /dev/sda model: ST3160215ACE size: 160.0GB
Partition: ID-1: / size: 19G used: 9.6G (56%) fs: ext4 dev: /dev/sda1
ID-2: /home size: 120G used: 111G (99%) fs: ext4 dev: /dev/sda6
ID-3: swap-1 size: 10.00GB used: 0.00GB (0%) fs: swap dev: /dev/sda5
RAID: No RAID devices: /proc/mdstat, md_mod kernel module present
Sensors: System Temperatures: cpu: 47.0C mobo: 41.0C gpu: 0.0:
Fan Speeds (in rpm): cpu: 1313 sys-1: 0
Info: Processes: 186 Uptime: 2:50 Memory: 3910.4/7950.9MB
Init: systemd runlevel: 5 Gcc sys: 5.4.0 Client: Shell (bash 4.3.481) inxi: 2.2.35
sudo /etc/init.d/FAHClient start
Any help is much appreciated!
