Idle GPU found
Ricorocks
Idle GPU found
Post by Ricorocks »
from log: 17:43:33:WU00:FS02:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
did Fah stop using as it became too hot? I saw this yesterday, 1 gpu 79 degrees, other idle was 41. Reboot & idle re-started, monitored for hour or two, temps 79 & 82 C.
davidcoton
Re: Idle GPU found
Post by davidcoton »
No. Temperature control was a feature with limited application, and was never enabled by default. You can safely ignore the message.
Are you using the latest client? ISTR that the message had been removed, but I may be wrong.
Re: Idle GPU found
The message is actually coming from the folding core, it is on the list for being removed. But the code for the GPU core started out with that there, and just hasn't been pulled from it yet.
Ricorocks
Re: Idle GPU found
Post by Ricorocks »
Good to hear!
