F@H OS Stats
TomJohnson
Hardware configuration: F@H Info – V8.4.9 – 12 Machines – 123 CPUs - 1,000K+ PPD; 1/5/2025
Mac Pro 14,8, 24 CPUs, 256K PPD;
Mac Pro 5,1, 24 CPUs, 496K PPD;
Mac Studio 13,1, 10 CPUs, 146K PPD;
iMac Pro 1,1, 15 CPUs, 267K PPD;
iMac 18,2, 4 CPUs, 29K PPD;
iMac 14,1, 4 CPUs, 40K PPD;
Mac Book Pro 17,1, 8 CPUs, 166K PPD;
Mac Book Pro 13,3, 8 CPUs, 57K PPD;
Mac Book Air 5,2, 4 CPUs, 23K PPD;
Mac Mini 7,1, 4 CPUs, 9K PPD;
HP Pavilion, 12 CPUs, 105K PPD;
SONY VAIO, 8 CPUs, 44K PPD.
F@H OS Stats
Post by TomJohnson »
Please fix "Bad Gateway" when going to F@H OS Stats to see how many additional Folders/CPUs/GPUs have been added to our group.
Mac Pro 14,8, 24 CPUs, 226K PPD;
iMac Pro 1,1. 15 CPUs, 267K PPD;
iMac 18,2, 4 CPUs, 29K PPD; + 7 more CPUs
Re: F@H OS Stats
Please tell your friends to stop checking their points so often. The "bad gateway" is telling you that it's too busy to accept your query.
MrFrizzy
Re: F@H OS Stats
Post by MrFrizzy »
You could also use third party sites like EOC. Here is a link to your team's stat page: https://folding.extremeoverclocking.com ... ?s=&t=1971
S1: AMD R5 3600 & Sapphire RX 5700 XT Reference @2.1GHz under water
S2: Intel Xeon E5-2620v3 & MSI GTX 1650
RX 5700 XT Project & PPD Tracking Spreadsheet
TomJohnson
Re: F@H OS Stats
These are the Stats that I was looking for - https://stats.foldingathome.org/os
Total CPUs have grown from 2,155,628 up to 8,355,996 :)
Hypocritus
Re: F@H OS Stats
Post by Hypocritus »
This is exciting news. However as of this posting the total CPU cores is showing as 2,970,711.
TomJohnson
Re: F@H OS Stats
The former OS Stats information chart format was changed overnight - https://stats.foldingathome.org/os
The bottom line is that we now have an overall substantial increase in total WU processing capacity as follows -
CPUs went from 110,685 up to 386,529, increasing by a factor of 3.5
CPU cores went from 327,712 up to 2,970,711, increasing by a factor of 9.0
TFLOPS went from 47,344 up to 473,938, increasing by a factor of 10.0
x86TFLOPS went from 98,747 up to 958,011, increasing by a factor of 9.7
Thanks to all of the F@H Family associated with this endeavor to help eradicate this current virus threat. :)
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
RAM: 24 GB DDR4
Re: F@H OS Stats
Post by Jesse_V »
TomJohnson wrote:The former OS Stats information chart format was changed overnight - https://stats.foldingathome.org/os
Do you have a screenshot? I can't even load the page right now. Are we seriously, seriously at 958 petaFLOPS?
Jonazz
Re: F@H OS Stats
Post by Jonazz »
copy paste from the page:
473.938 TFLOPS
958.011 x86 TFLOPS
What is the difference between 'normal' TFLOPS and x86 TFLOPS?
TomJohnson
Re: F@H OS Stats
Do you have a screenshot? I can't even load the page right now. Are we seriously, seriously at 958K petaFLOPS?
Yes, all of the figures quoted above were from the updated chart.
PM me with your Email address for screen shot. I cannot get screen shot to load via Img or Code from menu bar above.
This feature should be added to the menu bar.
Re: F@H OS Stats
If you can open https://foldingathome.org/support/faq/flops/ you'll get the full story.
Those who sell hardware count one simple operation (Multiply&Add) which reports the largest number but doesn't represent what's actually happening.
Most computers actually have a large set of complex operations and they don't all teke the same mount of time. That set depends on the exact hardware.
Simple representative question: Can your computer calculate a Square Root in a single OP? [Maybe, but not on an X86]
Jonazz
Re: F@H OS Stats
Post by Jonazz »
bruce wrote:If you can open https://foldingathome.org/support/faq/flops/ you'll get the full story.
Thanks for the link!
marook
Re: F@H OS Stats
Post by marook »
Why is FaH not using GPU's in MacOS?
It seems as if it's not adding it by default, and when I add the GPU manually as a slot, the workserver is listed as 192.0.2.1 every time. That is, off course, not a workserver it can connect to!
It finds my Nvidia GTX 780M GPU.
Do I need to install CUDA og OpenCL?
anandhanju
Re: F@H OS Stats
Post by anandhanju »
marook, GPU folding is not supported under MacOS at this see. See https://foldingathome.org/support/faq/i ... uirements/
Perhaps at some point in the future, this will be added into the software.
Nathan_P
Not currently folding
Re: F@H OS Stats
Post by Nathan_P »
There are issues with opencl in MacOS which prevent F@H from working, until apple fixes it there is nothing that can be done.
Re: F@H OS Stats
More correctly, Apple took 2 or 3 years to fix OpenCL and release the fix, by then few GPUs installed in current and older Mac's were usable. Most just had Intel graphics which have never been supported for folding. So there was a decision not to use their limited development resources on creating and testing a core for OS X. Recent models have included more GPUs that could be used, but now Apple has deprecated OpenCL in favor of Metal. While OpenCL is still available, that raises uncertainty over how long it will be.
