Connection Errors on new install?
scollinguk
Hi There,
I have just installed F@H on a new machine and am not connecting. I am aware of not being allocated WU units at the moment but this seems to be a different error. Can anyone help, recent logs below:
08:58:37:WU01:FS01:Connecting to 65.254.110.245:8080
08:58:37:WU01:FS01:Assigned to work server 192.0.2.1
08:58:37:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Redwood [Radeon HD 5690/5730] from 192.0.2.1
08:58:37:WU01:FS01:Connecting to 192.0.2.1:8080
08:58:58:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
08:58:58:WU01:FS01:Connecting to 192.0.2.1:80
08:59:19:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
Cheers,
Scott
Cheers,
Scott
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
Re: Connection Errors on new install?
Hi Scott,
I cannot reach this IP address either. I assume that it's related to the flood from the very sudden and rapid expansion of F@h's userbase in the past several days. The error with this server is likely related to this: viewtopic.php?f=61&t=32424
scollinguk
Hi Jesse,Jesse_V wrote:Hi Scott,
I thought it could be but 192.0.0.0 is a LAN subnet not an internet subnet so that makes me think it isnt. I also have another computer which is waiting for a WU to become available and it doesnt have this error message, it just has an error that no WU units are availalbe.
These are the reasons why i think it seems to be a configuration error rather than the problem you linked.
Cheers,
Scott
Jesse_V
CPU: i7-6700k
Ah, you're right. I thought that IP address was publicly routable but it is indeed reserved. I'm not sure how that could happen. Perhaps a DNS issue?scollinguk wrote:I thought it could be but 192.0.0.0 is a LAN subnet not an internet subnet so that makes me think it isnt. I also have another computer which is waiting for a WU to become available and it doesnt have this error message, it just has an error that no WU units are availalbe.Jesse_V wrote:Hi Scott,
scollinguk
I've actually just found this previous issue which seems to be the same: viewtopic.php?f=81&t=32042Jesse_V wrote:Ah, you're right. I thought that IP address was publicly routable but it is indeed reserved. I'm not sure how that could happen. Perhaps a DNS issue?scollinguk wrote:I thought it could be but 192.0.0.0 is a LAN subnet not an internet subnet so that makes me think it isnt. I also have another computer which is waiting for a WU to become available and it doesnt have this error message, it just has an error that no WU units are availalbe.Jesse_V wrote:Hi Scott,
It seems that by disabling the GPU slot in the F@H configuration it has removed the error (but isnt going to use the GPU for folding). I am hoping Bruce (who solved the issue on the link above) it able to see this and do the same fix though. I've got a Radeon 5870 so should hit the deadlines as its slightly more powerful that the card in the link.
Cheers,
Scott
The 5690 no longer meets the requirements, the 5870 does. If you look up your card, current minimum is OpenCL 1.2 and support for double precision calculations. There are lists of AMD and nVidia GPU's on wikipedia that are useful for quick checks on whether a card is usable.
Because of the way the GPUs.txt file was originally created and cards added, and the use of older chip series in later card series by AMD, and to a lesser extent nVidia; some cards are still listed as "supported", but are not. As we identify them and someone has a chance to update the file they get marked as unsupported. But in the meantime the server software redirects WU requests to an IP in the reserved 192.0.2.n range. From what I understand, the next version of the client will get a message documenting the reason and request the GPU be disabled for folding.
ramon.kosters
Hi.
Somehow im getting connection errors.
can someone help me ? ive forwarded the port to my pc on the security gateway
20:02:22:WU00:FS02:0x22: CPU: AMD Ryzen 7 3700X 8-Core Processor
20:02:22:WU00:FS02:0x22: CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
20:02:22:WU00:FS02:0x22: CPUs: 16
20:02:22:WU00:FS02:0x22: Memory: 31.92GiB
20:02:22:WU00:FS02:0x22:Free Memory: 23.46GiB
20:02:22:WU00:FS02:0x22: Threads: WINDOWS_THREADS
20:02:22:WU00:FS02:0x22: OS Version: 6.2
20:02:22:WU00:FS02:0x22:Has Battery: false
20:02:22:WU00:FS02:0x22: On Battery: false
20:02:22:WU00:FS02:0x22: UTC Offset: 1
20:02:22:WU00:FS02:0x22: PID: 53428
20:02:22:WU00:FS02:0x22: CWD: E:\Folding DATA\work
20:02:22:WU00:FS02:0x22: OS: Windows 10 Pro
20:02:22:WU00:FS02:0x22: OS Arch: AMD64
20:02:22:WU00:FS02:0x22:********************************************************************************
20:02:22:WU00:FS02:0x22:Project: 11756 (Run 0, Clone 2175, Gen 1)
20:02:22:WU00:FS02:0x22:Unit: 0x000000039bf7a4d55e6d76f588c989fa
20:02:22:WU00:FS02:0x22:Digital signatures verified
20:02:22:WU00:FS02:0x22:Folding@home GPU Core22 Folding@home Core
20:02:22:WU00:FS02:0x22:Version 0.0.2
20:02:22:WU00:FS02:0x22: Found a checkpoint file
20:02:34:WU00:FS02:0x22:Completed 50000 out of 1000000 steps (5%)
20:02:34:WU00:FS02:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
20:02:52:WU01:FS00:Connecting to 65.254.110.245:8080
20:02:52:WU02:FS01:Connecting to 65.254.110.245:8080
20:02:52:WU01:FS00:Assigned to work server 128.252.203.2
20:02:52:WU01:FS00:Requesting new work unit for slot 00: READY cpu:14 from 128.252.203.2
20:02:52:WU01:FS00:Connecting to 128.252.203.2:8080
20:02:53:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:02:53:WU02:FS01:Connecting to 18.218.241.186:80
20:02:53:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:02:53:ERROR:WU02:FS01:Exception: Could not get an assignment
20:03:06:WU01:FS00:Downloading 1.12MiB
20:03:07:WU01:FS00:Download complete
20:03:07:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14552 run:0 clone:410 gen:0 core:0xa7 unit:0x0000000080fccb025e7256e9f443a809
20:03:07:WU01:FS00:Starting
20:03:07:WU01:FS00:Running FahCore: E:\FAHClient/FAHCoreWrapper.exe "E:\Folding DATA\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe" -dir 01 -suffix 01 -version 704 -lifeline 65556 -checkpoint 15 -np 14
20:03:07:WU01:FS00:Started FahCore on PID 57280
20:03:07:WU01:FS00:Core PID:66472
20:03:07:WU01:FS00:FahCore 0xa7 started
20:04:03:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
20:04:18:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
20:04:18:WU00:FS02:0x22:Completed 60000 out of 1000000 steps (6%)
20:04:29:WU02:FS01:Connecting to 65.254.110.245:8080
20:04:30:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:04:30:WU02:FS01:Connecting to 18.218.241.186:80
20:04:30:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:04:30:ERROR:WU02:FS01:Exception: Could not get an assignment
20:04:31:WU01:FS00:0xa7:Completed 10000 out of 500000 steps (2%)
20:05:13:WU01:FS00:0xa7:Completed 15000 out of 500000 steps (3%)
20:05:55:WU01:FS00:0xa7:Completed 20000 out of 500000 steps (4%)
20:06:03:WU00:FS02:0x22:Completed 70000 out of 1000000 steps (7%)
20:06:35:WU01:FS00:0xa7:Completed 25000 out of 500000 steps (5%)
20:07:06:WU02:FS01:Connecting to 65.254.110.245:8080
20:07:07:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:07:07:WU02:FS01:Connecting to 18.218.241.186:80
20:07:07:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:07:07:ERROR:WU02:FS01:Exception: Could not get an assignment
20:07:16:WU01:FS00:0xa7:Completed 30000 out of 500000 steps (6%)
20:07:48:WU00:FS02:0x22:Completed 80000 out of 1000000 steps (8%)
20:07:57:WU01:FS00:0xa7:Completed 35000 out of 500000 steps (7%)
Your messages are mostly related to the heavy load on the server from all of the new persons and systems added since the weekend. It does look like you have received a CPU WU and one for a GPU. It may take a bit of time to get more WU's
You can ignore the 10053 messages, those are from Web Control not properly closing its connection, they are on the list ti be fixed in the next version of the client.
Jesse_V
CPU: i7-6700k
"No WUs available for this configuration" is a common error now due to the very fast influx of new users into Folding@home. Everyone is consuming workunits faster than they can be made available. The research teams are spinning up new servers and putting new projects (including COVID-19 work) into the queue to keep up with demand. Keep everything online and the software should pick up new work when its available. The situation should clear up over the next couple of days I think.
ramon.kosters
ok, cheers thx guys.. ill let my RIG run 24/7 to help out
petnek
- Hardware configuration: Asus 990FX Sabertooth, CPU Vishera FX-8350 not OC (Gelid Solution Tranquillo ), 2x4 GB DDR3 RAM 1600MHz (Kingston Blu), GPU Gigabyte HD6770, HDD Seagate Barracuda 7200.14 - 500GB + Samsung Spinpoint F1 320GB, FSP Raider 550W
20:04:18:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.-
As I answered 3 posts above yours, 10053 errors can be ignored.
scollinguk
Thanks, makes sense, i've removed the GPU slot and i can see its working now and also has a WU for the CPU to work on.Joe_H wrote:The 5690 no longer meets the requirements, the 5870 does. If you look up your card, current minimum is OpenCL 1.2 and support for double precision calculations. There are lists of AMD and nVidia GPU's on wikipedia that are useful for quick checks on whether a card is usable.
Cheers,
Scott
i'm curious, where are those requirements listed? i'm looking at the Folding at home windows Requirements (can't post link because new user) and it just says 4xx series and up with OpenCL compatabilityJoe_H wrote:The 5690 no longer meets the requirements, the 5870 does. If you look up your card, current minimum is OpenCL 1.2 and support for double precision calculations. There are lists of AMD and nVidia GPU's on wikipedia that are useful for quick checks on whether a card is usable.
I know the requirements (the GPU must support OpenCL 1.2 and be able to perform Double Precision floating point math (FP64) But I am not sure where they are documented.
Until 'recently' only Single Precision was required, and even still some cards that only claim OpenCL 1.1 compatibility actually have enough 1.2 features to fold.
On the desktop, this mostly rules out cards from before 2015, but some laptops will fail even up to 2017 designs.
As the software does more and better science it required the hardware to be capable of more and better science.
