New Donor having Connection Issue
TooLs_GaminG
In advanced mode, my connection continuously switches from connecting to connected every few seconds. it doesn't matter if i am on light, medium, or full folding power. is there anything i can do to fix this issue?
Re: New Donor having Connection Issue
Project is experiencing all time high new folder numbers, thus servers are being overworked.
New servers are being added, so hopefully soon it will be much easier to get new work
Thank you for your contribution
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
True, but I don't think this is related to that though. This sounds like a local problem. The connection problems are between FAHControl and FAHClient on localhost.muziqaz wrote:Project is experiencing all time high new folder numbers, thus servers are being overworked.
TooLs_GaminG, is everything else proceeding normally as far as you can tell? Making progress on the workunits and all that?
You might be correct. Might be misconfigured client, would be great to get a screenshot of fahcontrol when it is connected before disconnectionJesse_V wrote:True, but I don't think this is related to that though. This sounds like a local problem. The connection problems are between FAHControl and FAHClient on localhost.muziqaz wrote:Project is experiencing all time high new folder numbers, thus servers are being overworked.
