14:23:53:************************* Folding@home Client *************************
14:23:53: Website: https://foldingathome.org/
14:23:53: Copyright: (c) 2009-2018 foldingathome.org
14:23:53: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:23:53: Args:
14:23:53: Config: <none>
14:23:53:******************************** Build ********************************
14:23:53: Version: 7.5.1
14:23:53: Date: May 11 2018
14:23:53: Time: 13:06:32
14:23:53: Repository: Git
14:23:53: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
14:23:53: Branch: master
14:23:53: Compiler: Visual C++ 2008
14:23:53: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:23:53: Platform: win32 10
14:23:53: Bits: 32
14:23:53: Mode: Release
14:23:53:******************************* System ********************************
14:23:53: CPU: Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz
14:23:53: CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
14:23:53: CPUs: 8
14:23:53: Memory: 15.91GiB
14:23:53: Free Memory: 11.70GiB
14:23:53: Threads: WINDOWS_THREADS
14:23:53: OS Version: 6.2
14:23:53: Has Battery: true
14:23:53: On Battery: false
14:23:53: UTC Offset: -5
14:23:53: PID: 9956
14:23:53: CWD: C:\WINDOWS\system32
14:23:53: OS: Windows 10 Home
14:23:53: OS Arch: AMD64
14:23:53: GPUs: 0
14:23:53: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:5.0 Driver:9.2
14:23:53:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:2.0 Driver:20.19
14:23:53:OpenCL Device 2: Platform:1 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:399.1
14:23:53: Win32 Service: false
14:23:53:***********************************************************************
14:23:53:<config>
14:23:53: <!-- Folding Slots -->
14:23:53:</config>
14:23:53:Connecting to assign1.foldingathome.org:8080
14:23:53:Updated GPUs.txt
14:23:53:Read GPUs.txt
14:23:53:Trying to access database...
14:23:53:Successfully acquired database lock
14:23:53:Enabled folding slot 00: PAUSED cpu:3 (not configured)
14:23:53:Enabled folding slot 01: PAUSED gpu:0:GM107 [GeForce GTX 960M] (not configured)
14:23:53:ERROR:Exception: Failed to register systray icon: Unspecified error
14:24:54:Saving configuration to config.xml
14:24:54:<config>
14:24:54: <!-- Folding Slots -->
14:24:54: <slot id='0' type='CPU'/>
14:24:54: <slot id='1' type='GPU'/>
14:24:54:</config>
14:24:54:Set client configured
14:24:54:WU00:FS00:Connecting to 65.254.110.245:8080
14:24:54:WU00:FS00:Assigned to work server 155.247.164.214
14:24:54:WU00:FS00:Requesting new work unit for slot 00: READY cpu:3 from 155.247.164.214
14:24:54:WU00:FS00:Connecting to 155.247.164.214:8080
14:24:55:ERROR:WU00:FS00:Exception: 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
14:24:55:WU00:FS00:Connecting to 65.254.110.245:8080
14:24:55:WU00:FS00:Assigned to work server 155.247.164.214
14:24:55:WU00:FS00:Requesting new work unit for slot 00: READY cpu:3 from 155.247.164.214
14:24:55:WU00:FS00:Connecting to 155.247.164.214:8080
14:25:55:WU00:FS00:Connecting to 65.254.110.245:8080
14:25:55:WU00:FS00:Assigned to work server 128.252.203.9
14:25:55:WU00:FS00:Requesting new work unit for slot 00: READY cpu:3 from 128.252.203.9
14:25:55:WU00:FS00:Connecting to 128.252.203.9:8080
14:26:14:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
