GPU 1070 ti is not getting any WU's
twanariens
Post by twanariens »
Dear Sir / Madam,
After searching on the forum and reading the FAQ it seems that my Graphics Card (1070 TI) is a supported card.
But when I am trying to get a WU, it states that there are no WU's available for my configuration.
I am kinda stuck at figuring out how to help Folding.
*********************** Log Started 2020-03-14T14:27:43Z ***********************
14:27:43:************************* Folding@home Client *************************
14:27:43:        Website: https://foldingathome.org/
14:27:43:      Copyright: (c) 2009-2018 foldingathome.org
14:27:43:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:27:43:           Args: --open-web-control
14:27:43:         Config: C:\Users\Twan Ariens\AppData\Roaming\FAHClient\config.xml
14:27:43:******************************** Build ********************************
14:27:43:        Version: 7.5.1
14:27:43:           Date: May 11 2018
14:27:43:           Time: 13:06:32
14:27:43:     Repository: Git
14:27:43:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
14:27:43:         Branch: master
14:27:43:       Compiler: Visual C++ 2008
14:27:43:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:27:43:       Platform: win32 10
14:27:43:           Bits: 32
14:27:43:           Mode: Release
14:27:43:******************************* System ********************************
14:27:43:            CPU: AMD Ryzen 5 2600 Six-Core Processor
14:27:43:         CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
14:27:43:           CPUs: 12
14:27:43:         Memory: 15.93GiB
14:27:43:    Free Memory: 8.47GiB
14:27:43:        Threads: WINDOWS_THREADS
14:27:43:     OS Version: 6.2
14:27:43:    Has Battery: false
14:27:43:     On Battery: false
14:27:43:     UTC Offset: 1
14:27:43:            PID: 17300
14:27:43:            CWD: C:\Users\Twan Ariens\AppData\Roaming\FAHClient
14:27:43:             OS: Windows 10 Enterprise
14:27:43:        OS Arch: AMD64
14:27:43:           GPUs: 1
14:27:43:          GPU 0: Bus:31 Slot:0 Func:0 NVIDIA:7 GP104 [GeForce GTX 1070 Ti] 8186
14:27:43:  CUDA Device 0: Platform:0 Device:0 Bus:31 Slot:0 Compute:6.1 Driver:11.0
14:27:43:OpenCL Device 0: Platform:0 Device:0 Bus:31 Slot:0 Compute:1.2 Driver:450.12
14:27:43:  Win32 Service: false
14:27:43:***********************************************************************
14:27:43:<config>
14:27:43:  <!-- Network -->
14:27:43:  <proxy v=':8080'/>
14:27:43:
14:27:43:  <!-- Slot Control -->
14:27:43:  <power v='FULL'/>
14:27:43:
14:27:43:  <!-- User Information -->
14:27:43:  <team v='223518'/>
14:27:43:  <user v='TwanAriens'/>
14:27:43:
14:27:43:  <!-- Folding Slots -->
14:27:43:  <slot id='0' type='CPU'/>
14:27:43:  <slot id='1' type='GPU'/>
14:27:43:</config>
14:27:43:Trying to access database...
14:27:43:Successfully acquired database lock
14:27:43:Enabled folding slot 00: READY cpu:11
14:27:43:Enabled folding slot 01: READY gpu:0:GP104 [GeForce GTX 1070 Ti] 8186
14:27:43:WU03:FS00:Starting
14:27:43:WU03:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Users\Twan Ariens\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe" -dir 03 -suffix 01 -version 705 -lifeline 17300 -checkpoint 15 -np 11
14:27:43:WU03:FS00:Started FahCore on PID 19004
14:27:43:WU03:FS00:Core PID:21616
14:27:43:WU03:FS00:FahCore 0xa7 started
14:27:43:WU00:FS01:Connecting to 65.254.110.245:8080
14:27:43:WU03:FS00:0xa7:*********************** Log Started 2020-03-14T14:27:43Z ***********************
14:27:43:WU03:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
14:27:43:WU03:FS00:0xa7:       Type: 0xa7
14:27:43:WU03:FS00:0xa7:       Core: Gromacs
14:27:43:WU03:FS00:0xa7:       Args: -dir 03 -suffix 01 -version 705 -lifeline 19004 -checkpoint 15 -np
14:27:43:WU03:FS00:0xa7:             11
14:27:43:WU03:FS00:0xa7:************************************ CBang *************************************
14:27:43:WU03:FS00:0xa7:       Date: Oct 26 2019
14:27:43:WU03:FS00:0xa7:       Time: 01:38:25
14:27:43:WU03:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
14:27:43:WU03:FS00:0xa7:     Branch: master
14:27:43:WU03:FS00:0xa7:   Compiler: Visual C++ 2008
14:27:43:WU03:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:27:44:WU03:FS00:0xa7:   Platform: win32 10
14:27:44:WU03:FS00:0xa7:       Bits: 64
14:27:44:WU03:FS00:0xa7:       Mode: Release
14:27:44:WU03:FS00:0xa7:************************************ System ************************************
14:27:44:WU03:FS00:0xa7:        CPU: AMD Ryzen 5 2600 Six-Core Processor
14:27:44:WU03:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
14:27:44:WU03:FS00:0xa7:       CPUs: 12
14:27:44:WU03:FS00:0xa7:     Memory: 15.93GiB
14:27:44:WU03:FS00:0xa7:Free Memory: 8.46GiB
14:27:44:WU03:FS00:0xa7:    Threads: WINDOWS_THREADS
14:27:44:WU03:FS00:0xa7: OS Version: 6.2
14:27:44:WU03:FS00:0xa7:Has Battery: false
14:27:44:WU03:FS00:0xa7: On Battery: false
14:27:44:WU03:FS00:0xa7: UTC Offset: 1
14:27:44:WU03:FS00:0xa7:        PID: 21616
14:27:44:WU03:FS00:0xa7:        CWD: C:\Users\Twan Ariens\AppData\Roaming\FAHClient\work
14:27:44:WU03:FS00:0xa7:******************************** Build - libFAH ********************************
14:27:44:WU03:FS00:0xa7:    Version: 0.0.18
14:27:44:WU03:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:27:44:WU03:FS00:0xa7:  Copyright: 2019 foldingathome.org
14:27:44:WU03:FS00:0xa7:   Homepage: https://foldingathome.org/
14:27:44:WU03:FS00:0xa7:       Date: Oct 26 2019
14:27:44:WU03:FS00:0xa7:       Time: 01:52:30
14:27:44:WU03:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
14:27:44:WU03:FS00:0xa7:     Branch: master
14:27:44:WU03:FS00:0xa7:   Compiler: Visual C++ 2008
14:27:44:WU03:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:27:44:WU03:FS00:0xa7:************************************ Build *************************************
14:27:44:WU03:FS00:0xa7:       SIMD: avx_256
14:27:44:WU03:FS00:0xa7:********************************************************************************
14:27:44:WU03:FS00:0xa7:Project: 14402 (Run 0, Clone 4755, Gen 68)
14:27:44:WU03:FS00:0xa7:Unit: 0x0000005380fccb095dcb2a658e923b5f
14:27:44:WU03:FS00:0xa7:Digital signatures verified
14:27:44:WU03:FS00:0xa7:Reducing thread count from 11 to 10 to avoid domain decomposition by a prime number > 3
14:27:44:WU03:FS00:0xa7:Calling: mdrun -s frame68.tpr -o frame68.trr -x frame68.xtc -cpi state.cpt -cpt 15 -nt 10
14:27:44:WU03:FS00:0xa7:Steps: first=8500000 total=125000
14:27:46:WU03:FS00:0xa7:Completed 43912 out of 125000 steps (35%)
14:27:47:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:27:47:WU00:FS01:Connecting to 18.218.241.186:80
14:27:48:8:127.0.0.1:New Web connection
14:27:48:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:27:48:ERROR:WU00:FS01:Exception: Could not get an assignment
14:27:48:WU00:FS01:Connecting to 65.254.110.245:8080
14:27:49:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:27:49:WU00:FS01:Connecting to 18.218.241.186:80
14:27:49:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:27:49:ERROR:WU00:FS01:Exception: Could not get an assignment
Hope you guys could help me out so I can also contribute a bit.
HaloJones
Re: GPU 1070 ti is not getting any WU's
Post by HaloJones »
there's no work right now, be patient
4070 super
