14197 (3, 790, 3) & (1, 763, 0) - Server responded WORK_QUIT
simon-mj-carter
Post by simon-mj-carter »
Both 14197 (3, 790, 3) and 14197 (1, 763, 0) completed and uploaded, but server did not like results. What is hppening?
12:16:21:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14197 run:1 clone:763 gen:0 core:0xa7 unit:0x000000009bf7a4d55e66d1e5d3009574
12:22:20:WU00:FS00:Upload complete
12:22:20:WU00:FS00:Server responded WORK_QUIT (404)
12:22:20:WARNING:WU00:FS00:Server did not like results, dumping
12:22:20:WU00:FS00:Cleaning up
17:01:43:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14197 run:3 clone:790 gen:3 core:0xa7 unit:0x000000039bf7a4d55e66d1850b1864e9
17:07:10:WU00:FS00:Upload complete
17:07:10:WU00:FS00:Server responded WORK_QUIT (404)
17:07:10:WARNING:WU00:FS00:Server did not like results, dumping
17:07:10:WU00:FS00:Cleaning up
Re: 14197 (3, 790, 3) & (1, 763, 0) - Server responded WORK_
We notified the researcher in charge of these projects. Since it's running from a newly installer server, there's might be something wrong.
Can you post the full log surrounding the two upload ?
Empie
Project: 11741 (Run 0, Clone 1891, Gen 1) - Server responded
Post by Empie »
Hi,
Just got an "Server responded WORK_QUIT (404)" followed by "Server did not like results, dumping"
This is a GTX 1080 with no OC. System has two GTX 1080 running.
Log:
13:32:05:WU01:FS01:0x22:Completed 4950000 out of 5000000 steps (99%)
13:32:06:WU02:FS01:Connecting to 65.254.110.245:8080
13:32:06:WU02:FS01:Assigned to work server 140.163.4.241
13:32:06:WU02:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GP104 [GeForce GTX 1080] 8873 from 140.163.4.241
13:32:06:WU02:FS01:Connecting to 140.163.4.241:8080
******************************* Date: 2020-03-11 *******************************
13:33:03:WU01:FS01:0x22:Completed 5000000 out of 5000000 steps (100%)
13:33:04:WU01:FS01:0x22:Saving result file ../logfile_01.txt
13:33:04:WU01:FS01:0x22:Saving result file checkpointState.xml
13:33:04:WU01:FS01:0x22:Saving result file checkpt.crc
13:33:04:WU01:FS01:0x22:Saving result file positions.xtc
13:33:04:WU01:FS01:0x22:Saving result file science.log
13:33:04:WU01:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
13:33:05:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
13:33:05:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11737 run:0 clone:1544 gen:147 core:0x22 unit:0x000000c18ca304f15dfbe6d7d36a4d49
13:33:05:WU01:FS01:Uploading 6.50MiB to 140.163.4.241
13:33:05:WU01:FS01:Connecting to 140.163.4.241:8080
13:33:06:WU00:FS02:0x22:Completed 560000 out of 1000000 steps (56%)
13:33:08:WU02:FS01:Downloading 79.12MiB
13:33:14:WU02:FS01:Download 1.26%
13:33:20:WU02:FS01:Download 2.76%
13:33:26:WU02:FS01:Download 4.03%
13:33:32:WU02:FS01:Download 14.22%
13:33:38:WU02:FS01:Download 53.87%
13:33:44:WU02:FS01:Download 86.26%
13:33:48:WU02:FS01:Download complete
13:33:49:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11741 run:0 clone:1891 gen:1 core:0x22 unit:0x000000018ca304f15e67d867f17a85f5
13:33:49:WU02:FS01:Starting
13:33:49:WU02:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_22.fah/FahCore_22 -dir 02 -suffix 01 -version 705 -lifeline 1637 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
13:33:49:WU02:FS01:Started FahCore on PID 6596
13:33:49:WU02:FS01:Core PID:6600
13:33:49:WU02:FS01:FahCore 0x22 started
13:33:49:WU02:FS01:0x22:*********************** Log Started 2020-03-11T13:33:49Z ***********************
13:33:49:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
13:33:49:WU02:FS01:0x22:       Type: 0x22
13:33:49:WU02:FS01:0x22:       Core: Core22
13:33:49:WU02:FS01:0x22:    Website: https://foldingathome.org/
13:33:49:WU02:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
13:33:49:WU02:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
13:33:49:WU02:FS01:0x22:             <rafal.wiewiora@choderalab.org>
13:33:49:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 705 -lifeline 6596 -checkpoint 15
13:33:49:WU02:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
13:33:49:WU02:FS01:0x22:             0 -gpu 0
13:33:49:WU02:FS01:0x22:     Config: <none>
13:33:49:WU02:FS01:0x22:************************************ Build *************************************
13:33:49:WU02:FS01:0x22:    Version: 0.0.2
13:33:49:WU02:FS01:0x22:       Date: Dec 6 2019
13:33:49:WU02:FS01:0x22:       Time: 21:20:17
13:33:49:WU02:FS01:0x22: Repository: Git
13:33:49:WU02:FS01:0x22:   Revision: f87d92b58abdf7e6bf2e173cfbc4dc3e837c7042
13:33:49:WU02:FS01:0x22:     Branch: core22
13:33:49:WU02:FS01:0x22:   Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
13:33:49:WU02:FS01:0x22:    Options: -std=gnu++98 -O3 -funroll-loops
13:33:49:WU02:FS01:0x22:   Platform: linux2 4.9.87-linuxkit-aufs
13:33:49:WU02:FS01:0x22:       Bits: 64
13:33:49:WU02:FS01:0x22:       Mode: Release
13:33:49:WU02:FS01:0x22:************************************ System ************************************
13:33:49:WU02:FS01:0x22:        CPU: Intel(R) Xeon(R) CPU E5-2670 0 @ 2.60GHz
13:33:49:WU02:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 45 Stepping 7
13:33:49:WU02:FS01:0x22:       CPUs: 4
13:33:49:WU02:FS01:0x22:     Memory: 11.70GiB
13:33:49:WU02:FS01:0x22:Free Memory: 8.86GiB
13:33:49:WU02:FS01:0x22:    Threads: POSIX_THREADS
13:33:49:WU02:FS01:0x22: OS Version: 4.15
13:33:49:WU02:FS01:0x22:Has Battery: false
13:33:49:WU02:FS01:0x22: On Battery: false
13:33:49:WU02:FS01:0x22: UTC Offset: 0
13:33:49:WU02:FS01:0x22:        PID: 6600
13:33:49:WU02:FS01:0x22:        CWD: /var/lib/fahclient/work
13:33:49:WU02:FS01:0x22:         OS: Linux 4.15.0-88-generic x86_64
13:33:49:WU02:FS01:0x22:    OS Arch: AMD64
13:33:49:WU02:FS01:0x22:********************************************************************************
13:33:49:WU02:FS01:0x22:Project: 11741 (Run 0, Clone 1891, Gen 1)
13:33:49:WU02:FS01:0x22:Unit: 0x000000018ca304f15e67d867f17a85f5
13:33:49:WU02:FS01:0x22:Reading tar file core.xml
13:33:49:WU02:FS01:0x22:Reading tar file integrator.xml
13:33:49:WU02:FS01:0x22:Reading tar file state.xml
13:33:49:WU02:FS01:0x22:Reading tar file system.xml
13:33:49:WU02:FS01:0x22:Digital signatures verified
13:33:49:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
13:33:49:WU02:FS01:0x22:Version 0.0.2
13:33:57:WU01:FS01:Upload 2.89%
13:34:01:WU02:FS01:0x22:Completed 0 out of 1000000 steps (0%)
13:34:01:WU02:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
13:34:03:WU01:FS01:Upload 43.29%
13:34:10:WU01:FS01:Upload complete
13:34:10:WU01:FS01:Server responded WORK_ACK (400)
13:34:10:WU01:FS01:Final credit estimate, 70773.00 points
13:34:10:WU01:FS01:Cleaning up
13:34:12:WU00:FS02:0x22:Completed 570000 out of 1000000 steps (57%)
13:35:18:WU00:FS02:0x22:Completed 580000 out of 1000000 steps (58%)
13:35:46:WU02:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
13:36:24:WU00:FS02:0x22:Completed 590000 out of 1000000 steps (59%)
13:37:21:WU03:FS00:0xa7:Completed 90000 out of 125000 steps (72%)
13:37:30:WU00:FS02:0x22:Completed 600000 out of 1000000 steps (60%)
13:37:31:WU02:FS01:0x22:Completed 20000 out of 1000000 steps (2%)
13:38:39:WU00:FS02:0x22:Completed 610000 out of 1000000 steps (61%)
13:39:15:WU02:FS01:0x22:Completed 30000 out of 1000000 steps (3%)
13:39:45:WU00:FS02:0x22:Completed 620000 out of 1000000 steps (62%)
13:40:51:WU00:FS02:0x22:Completed 630000 out of 1000000 steps (63%)
13:41:00:WU02:FS01:0x22:Completed 40000 out of 1000000 steps (4%)
13:41:57:WU00:FS02:0x22:Completed 640000 out of 1000000 steps (64%)
13:42:44:WU02:FS01:0x22:Completed 50000 out of 1000000 steps (5%)
13:43:03:WU00:FS02:0x22:Completed 650000 out of 1000000 steps (65%)
13:44:13:WU00:FS02:0x22:Completed 660000 out of 1000000 steps (66%)
13:44:34:WU02:FS01:0x22:Completed 60000 out of 1000000 steps (6%)
13:45:19:WU00:FS02:0x22:Completed 670000 out of 1000000 steps (67%)
13:45:32:WU03:FS00:0xa7:Completed 91250 out of 125000 steps (73%)
13:46:18:WU02:FS01:0x22:Completed 70000 out of 1000000 steps (7%)
13:46:25:WU00:FS02:0x22:Completed 680000 out of 1000000 steps (68%)
13:47:32:WU00:FS02:0x22:Completed 690000 out of 1000000 steps (69%)
13:48:03:WU02:FS01:0x22:Completed 80000 out of 1000000 steps (8%)
13:48:38:WU00:FS02:0x22:Completed 700000 out of 1000000 steps (70%)
13:49:47:WU02:FS01:0x22:Completed 90000 out of 1000000 steps (9%)
13:49:47:WU00:FS02:0x22:Completed 710000 out of 1000000 steps (71%)
13:50:53:WU00:FS02:0x22:Completed 720000 out of 1000000 steps (72%)
13:51:31:WU02:FS01:0x22:Completed 100000 out of 1000000 steps (10%)
13:51:59:WU00:FS02:0x22:Completed 730000 out of 1000000 steps (73%)
13:53:05:WU00:FS02:0x22:Completed 740000 out of 1000000 steps (74%)
13:53:20:WU02:FS01:0x22:Completed 110000 out of 1000000 steps (11%)
13:53:49:WU03:FS00:0xa7:Completed 92500 out of 125000 steps (74%)
13:54:12:WU00:FS02:0x22:Completed 750000 out of 1000000 steps (75%)
13:55:04:WU02:FS01:0x22:Completed 120000 out of 1000000 steps (12%)
13:55:21:WU00:FS02:0x22:Completed 760000 out of 1000000 steps (76%)
13:56:28:WU00:FS02:0x22:Completed 770000 out of 1000000 steps (77%)
13:56:48:WU02:FS01:0x22:Completed 130000 out of 1000000 steps (13%)
13:57:34:WU00:FS02:0x22:Completed 780000 out of 1000000 steps (78%)
13:58:32:WU02:FS01:0x22:Completed 140000 out of 1000000 steps (14%)
13:58:40:WU00:FS02:0x22:Completed 790000 out of 1000000 steps (79%)
13:59:47:WU00:FS02:0x22:Completed 800000 out of 1000000 steps (80%)
14:00:17:WU02:FS01:0x22:Completed 150000 out of 1000000 steps (15%)
14:00:56:WU00:FS02:0x22:Completed 810000 out of 1000000 steps (81%)
14:01:58:WU03:FS00:0xa7:Completed 93750 out of 125000 steps (75%)
14:02:02:WU00:FS02:0x22:Completed 820000 out of 1000000 steps (82%)
14:02:06:WU02:FS01:0x22:Completed 160000 out of 1000000 steps (16%)
14:03:08:WU00:FS02:0x22:Completed 830000 out of 1000000 steps (83%)
14:03:50:WU02:FS01:0x22:Completed 170000 out of 1000000 steps (17%)
14:04:14:WU00:FS02:0x22:Completed 840000 out of 1000000 steps (84%)
14:05:21:WU00:FS02:0x22:Completed 850000 out of 1000000 steps (85%)
14:05:34:WU02:FS01:0x22:Completed 180000 out of 1000000 steps (18%)
14:06:30:WU00:FS02:0x22:Completed 860000 out of 1000000 steps (86%)
14:07:18:WU02:FS01:0x22:Completed 190000 out of 1000000 steps (19%)
14:07:36:WU00:FS02:0x22:Completed 870000 out of 1000000 steps (87%)
14:08:43:WU00:FS02:0x22:Completed 880000 out of 1000000 steps (88%)
14:09:02:WU02:FS01:0x22:Completed 200000 out of 1000000 steps (20%)
14:09:49:WU00:FS02:0x22:Completed 890000 out of 1000000 steps (89%)
14:10:15:WU03:FS00:0xa7:Completed 95000 out of 125000 steps (76%)
14:10:51:WU02:FS01:0x22:Completed 210000 out of 1000000 steps (21%)
14:10:55:WU00:FS02:0x22:Completed 900000 out of 1000000 steps (90%)
14:12:05:WU00:FS02:0x22:Completed 910000 out of 1000000 steps (91%)
14:12:36:WU02:FS01:0x22:Completed 220000 out of 1000000 steps (22%)
14:13:11:WU00:FS02:0x22:Completed 920000 out of 1000000 steps (92%)
14:14:17:WU00:FS02:0x22:Completed 930000 out of 1000000 steps (93%)
14:14:20:WU02:FS01:0x22:Completed 230000 out of 1000000 steps (23%)
14:15:23:WU00:FS02:0x22:Completed 940000 out of 1000000 steps (94%)
14:16:05:WU02:FS01:0x22:Completed 240000 out of 1000000 steps (24%)
14:16:29:WU00:FS02:0x22:Completed 950000 out of 1000000 steps (95%)
14:17:39:WU00:FS02:0x22:Completed 960000 out of 1000000 steps (96%)
14:17:49:WU02:FS01:0x22:Completed 250000 out of 1000000 steps (25%)
14:18:19:WU03:FS00:0xa7:Completed 96250 out of 125000 steps (77%)
14:18:45:WU00:FS02:0x22:Completed 970000 out of 1000000 steps (97%)
14:19:38:WU02:FS01:0x22:Completed 260000 out of 1000000 steps (26%)
14:19:51:WU00:FS02:0x22:Completed 980000 out of 1000000 steps (98%)
14:20:58:WU00:FS02:0x22:Completed 990000 out of 1000000 steps (99%)
14:20:58:WU01:FS02:Connecting to 65.254.110.245:8080
14:20:58:WU01:FS02:Assigned to work server 140.163.4.241
14:20:58:WU01:FS02:Requesting new work unit for slot 02: RUNNING gpu:1:GP104 [GeForce GTX 1080] 8873 from 140.163.4.241
14:20:58:WU01:FS02:Connecting to 140.163.4.241:8080
14:21:12:ERROR:WU01:FS02:Exception: Server did not assign work unit
14:21:12:WU01:FS02:Connecting to 65.254.110.245:8080
14:21:13:WU01:FS02:Assigned to work server 140.163.4.241
14:21:13:WU01:FS02:Requesting new work unit for slot 02: RUNNING gpu:1:GP104 [GeForce GTX 1080] 8873 from 140.163.4.241
14:21:13:WU01:FS02:Connecting to 140.163.4.241:8080
14:21:23:WU02:FS01:0x22:Completed 270000 out of 1000000 steps (27%)
14:21:33:WU01:FS02:Downloading 86.23MiB
14:21:39:WU01:FS02:Download 2.03%
14:21:45:WU01:FS02:Download 4.35%
14:21:51:WU01:FS02:Download 15.66%
14:21:57:WU01:FS02:Download 74.72%
14:22:03:WU01:FS02:Download 99.66%
14:22:03:WU01:FS02:Download complete
14:22:03:WU01:FS02:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11746 run:0 clone:1430 gen:5 core:0x22 unit:0x000000078ca304f15e67f88c22b88a97
14:22:04:WU00:FS02:0x22:Completed 1000000 out of 1000000 steps (100%)
14:22:07:WU00:FS02:0x22:Saving result file ../logfile_01.txt
14:22:07:WU00:FS02:0x22:Saving result file checkpointState.xml
14:22:08:WU00:FS02:0x22:Saving result file checkpt.crc
14:22:08:WU00:FS02:0x22:Saving result file positions.xtc
14:22:08:WU00:FS02:0x22:Saving result file science.log
14:22:08:WU00:FS02:0x22:Folding@home Core Shutdown: FINISHED_UNIT
14:22:08:WU00:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
14:22:08:WU00:FS02:Sending unit results: id:00 state:SEND error:NO_ERROR project:11744 run:0 clone:533 gen:6 core:0x22 unit:0x000000088ca304f15e67e59258d95cfe
14:22:08:WU00:FS02:Uploading 33.02MiB to 140.163.4.241
14:22:08:WU00:FS02:Connecting to 140.163.4.241:8080
14:22:08:WU01:FS02:Starting
14:22:08:WU01:FS02:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_22.fah/FahCore_22 -dir 01 -suffix 01 -version 705 -lifeline 1637 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 1 -cuda-device 1 -gpu 1
14:22:08:WU01:FS02:Started FahCore on PID 6651
14:22:08:WU01:FS02:Core PID:6655
14:22:08:WU01:FS02:FahCore 0x22 started
14:22:09:WU01:FS02:0x22:*********************** Log Started 2020-03-11T14:22:08Z ***********************
14:22:09:WU01:FS02:0x22:*************************** Core22 Folding@home Core ***************************
14:22:09:WU01:FS02:0x22:       Type: 0x22
14:22:09:WU01:FS02:0x22:       Core: Core22
14:22:09:WU01:FS02:0x22:    Website: https://foldingathome.org/
14:22:09:WU01:FS02:0x22:  Copyright: (c) 2009-2018 foldingathome.org
14:22:09:WU01:FS02:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
14:22:09:WU01:FS02:0x22:             <rafal.wiewiora@choderalab.org>
14:22:09:WU01:FS02:0x22:       Args: -dir 01 -suffix 01 -version 705 -lifeline 6651 -checkpoint 15
14:22:09:WU01:FS02:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 1 -cuda-device
14:22:09:WU01:FS02:0x22:             1 -gpu 1
14:22:09:WU01:FS02:0x22:     Config: <none>
14:22:09:WU01:FS02:0x22:************************************ Build *************************************
14:22:09:WU01:FS02:0x22:    Version: 0.0.2
14:22:09:WU01:FS02:0x22:       Date: Dec 6 2019
14:22:09:WU01:FS02:0x22:       Time: 21:20:17
14:22:09:WU01:FS02:0x22: Repository: Git
14:22:09:WU01:FS02:0x22:   Revision: f87d92b58abdf7e6bf2e173cfbc4dc3e837c7042
14:22:09:WU01:FS02:0x22:     Branch: core22
14:22:09:WU01:FS02:0x22:   Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
14:22:09:WU01:FS02:0x22:    Options: -std=gnu++98 -O3 -funroll-loops
14:22:09:WU01:FS02:0x22:   Platform: linux2 4.9.87-linuxkit-aufs
14:22:09:WU01:FS02:0x22:       Bits: 64
14:22:09:WU01:FS02:0x22:       Mode: Release
14:22:09:WU01:FS02:0x22:************************************ System ************************************
14:22:09:WU01:FS02:0x22:        CPU: Intel(R) Xeon(R) CPU E5-2670 0 @ 2.60GHz
14:22:09:WU01:FS02:0x22:     CPU ID: GenuineIntel Family 6 Model 45 Stepping 7
14:22:09:WU01:FS02:0x22:       CPUs: 4
14:22:09:WU01:FS02:0x22:     Memory: 11.70GiB
14:22:09:WU01:FS02:0x22:Free Memory: 8.30GiB
14:22:09:WU01:FS02:0x22:    Threads: POSIX_THREADS
14:22:09:WU01:FS02:0x22: OS Version: 4.15
14:22:09:WU01:FS02:0x22:Has Battery: false
14:22:09:WU01:FS02:0x22: On Battery: false
14:22:09:WU01:FS02:0x22: UTC Offset: 0
14:22:09:WU01:FS02:0x22:        PID: 6655
14:22:09:WU01:FS02:0x22:        CWD: /var/lib/fahclient/work
14:22:09:WU01:FS02:0x22:         OS: Linux 4.15.0-88-generic x86_64
14:22:09:WU01:FS02:0x22:    OS Arch: AMD64
14:22:09:WU01:FS02:0x22:********************************************************************************
14:22:09:WU01:FS02:0x22:Project: 11746 (Run 0, Clone 1430, Gen 5)
14:22:09:WU01:FS02:0x22:Unit: 0x000000078ca304f15e67f88c22b88a97
14:22:09:WU01:FS02:0x22:Reading tar file core.xml
14:22:09:WU01:FS02:0x22:Reading tar file integrator.xml
14:22:09:WU01:FS02:0x22:Reading tar file state.xml
14:22:09:WU01:FS02:0x22:Reading tar file system.xml
14:22:09:WU01:FS02:0x22:Digital signatures verified
14:22:09:WU01:FS02:0x22:Folding@home GPU Core22 Folding@home Core
14:22:09:WU01:FS02:0x22:Version 0.0.2
14:22:22:WU01:FS02:0x22:Completed 0 out of 1000000 steps (0%)
14:22:22:WU01:FS02:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
14:22:30:WU00:FS02:Upload 1.51%
14:22:36:WU00:FS02:Upload 11.55%
14:22:42:WU00:FS02:Upload 19.12%
14:22:48:WU00:FS02:Upload 32.18%
14:22:54:WU00:FS02:Upload 43.35%
14:23:00:WU00:FS02:Upload 54.33%
14:23:06:WU00:FS02:Upload 68.52%
14:23:07:WU02:FS01:0x22:Completed 280000 out of 1000000 steps (28%)
14:23:12:WU00:FS02:Upload 87.07%
14:23:19:WU00:FS02:Upload complete
14:23:19:WU00:FS02:Server responded WORK_ACK (400)
14:23:19:WU00:FS02:Final credit estimate, 67129.00 points
14:23:19:WU00:FS02:Cleaning up
14:24:21:WU01:FS02:0x22:Completed 10000 out of 1000000 steps (1%)
14:24:52:WU02:FS01:0x22:Completed 290000 out of 1000000 steps (29%)
14:26:19:WU01:FS02:0x22:Completed 20000 out of 1000000 steps (2%)
14:26:35:WU03:FS00:0xa7:Completed 97500 out of 125000 steps (78%)
14:26:36:WU02:FS01:0x22:Completed 300000 out of 1000000 steps (30%)
14:28:18:WU01:FS02:0x22:Completed 30000 out of 1000000 steps (3%)
14:28:26:WU02:FS01:0x22:Completed 310000 out of 1000000 steps (31%)
14:30:10:WU02:FS01:0x22:Completed 320000 out of 1000000 steps (32%)
14:30:16:WU01:FS02:0x22:Completed 40000 out of 1000000 steps (4%)
14:31:54:WU02:FS01:0x22:Completed 330000 out of 1000000 steps (33%)
14:32:15:WU01:FS02:0x22:Completed 50000 out of 1000000 steps (5%)
14:33:38:WU02:FS01:0x22:Completed 340000 out of 1000000 steps (34%)
14:34:19:WU01:FS02:0x22:Completed 60000 out of 1000000 steps (6%)
14:34:44:WU03:FS00:0xa7:Completed 98750 out of 125000 steps (79%)
14:35:23:WU02:FS01:0x22:Completed 350000 out of 1000000 steps (35%)
14:36:18:WU01:FS02:0x22:Completed 70000 out of 1000000 steps (7%)
14:37:11:WU02:FS01:0x22:Completed 360000 out of 1000000 steps (36%)
14:38:16:WU01:FS02:0x22:Completed 80000 out of 1000000 steps (8%)
14:38:55:WU02:FS01:0x22:Completed 370000 out of 1000000 steps (37%)
14:40:14:WU01:FS02:0x22:Completed 90000 out of 1000000 steps (9%)
14:40:39:WU02:FS01:0x22:Completed 380000 out of 1000000 steps (38%)
14:42:13:WU01:FS02:0x22:Completed 100000 out of 1000000 steps (10%)
14:42:23:WU02:FS01:0x22:Completed 390000 out of 1000000 steps (39%)
14:42:54:WU03:FS00:0xa7:Completed 100000 out of 125000 steps (80%)
14:44:07:WU02:FS01:0x22:Completed 400000 out of 1000000 steps (40%)
14:44:17:WU01:FS02:0x22:Completed 110000 out of 1000000 steps (11%)
14:45:57:WU02:FS01:0x22:Completed 410000 out of 1000000 steps (41%)
14:46:16:WU01:FS02:0x22:Completed 120000 out of 1000000 steps (12%)
14:47:41:WU02:FS01:0x22:Completed 420000 out of 1000000 steps (42%)
14:48:15:WU01:FS02:0x22:Completed 130000 out of 1000000 steps (13%)
14:49:25:WU02:FS01:0x22:Completed 430000 out of 1000000 steps (43%)
14:50:14:WU01:FS02:0x22:Completed 140000 out of 1000000 steps (14%)
14:51:07:WU03:FS00:0xa7:Completed 101250 out of 125000 steps (81%)
14:51:10:WU02:FS01:0x22:Completed 440000 out of 1000000 steps (44%)
14:52:13:WU01:FS02:0x22:Completed 150000 out of 1000000 steps (15%)
14:52:54:WU02:FS01:0x22:Completed 450000 out of 1000000 steps (45%)
14:54:17:WU01:FS02:0x22:Completed 160000 out of 1000000 steps (16%)
14:54:43:WU02:FS01:0x22:Completed 460000 out of 1000000 steps (46%)
14:56:16:WU01:FS02:0x22:Completed 170000 out of 1000000 steps (17%)
14:56:27:WU02:FS01:0x22:Completed 470000 out of 1000000 steps (47%)
14:58:11:WU02:FS01:0x22:Completed 480000 out of 1000000 steps (48%)
14:58:15:WU01:FS02:0x22:Completed 180000 out of 1000000 steps (18%)
14:59:21:WU03:FS00:0xa7:Completed 102500 out of 125000 steps (82%)
14:59:55:WU02:FS01:0x22:Completed 490000 out of 1000000 steps (49%)
15:00:13:WU01:FS02:0x22:Completed 190000 out of 1000000 steps (19%)
15:01:39:WU02:FS01:0x22:Completed 500000 out of 1000000 steps (50%)
15:02:12:WU01:FS02:0x22:Completed 200000 out of 1000000 steps (20%)
15:03:28:WU02:FS01:0x22:Completed 510000 out of 1000000 steps (51%)
15:04:16:WU01:FS02:0x22:Completed 210000 out of 1000000 steps (21%)
15:05:13:WU02:FS01:0x22:Completed 520000 out of 1000000 steps (52%)
15:06:14:WU01:FS02:0x22:Completed 220000 out of 1000000 steps (22%)
15:06:57:WU02:FS01:0x22:Completed 530000 out of 1000000 steps (53%)
15:07:34:WU03:FS00:0xa7:Completed 103750 out of 125000 steps (83%)
15:08:13:WU01:FS02:0x22:Completed 230000 out of 1000000 steps (23%)
15:08:42:WU02:FS01:0x22:Completed 540000 out of 1000000 steps (54%)
15:10:11:WU01:FS02:0x22:Completed 240000 out of 1000000 steps (24%)
15:10:26:WU02:FS01:0x22:Completed 550000 out of 1000000 steps (55%)
15:12:09:WU01:FS02:0x22:Completed 250000 out of 1000000 steps (25%)
15:12:15:WU02:FS01:0x22:Completed 560000 out of 1000000 steps (56%)
15:14:00:WU02:FS01:0x22:Completed 570000 out of 1000000 steps (57%)
15:14:14:WU01:FS02:0x22:Completed 260000 out of 1000000 steps (26%)
15:15:44:WU02:FS01:0x22:Completed 580000 out of 1000000 steps (58%)
15:15:50:WU03:FS00:0xa7:Completed 105000 out of 125000 steps (84%)
15:16:12:WU01:FS02:0x22:Completed 270000 out of 1000000 steps (27%)
15:17:29:WU02:FS01:0x22:Completed 590000 out of 1000000 steps (59%)
15:18:11:WU01:FS02:0x22:Completed 280000 out of 1000000 steps (28%)
15:19:13:WU02:FS01:0x22:Completed 600000 out of 1000000 steps (60%)
15:20:09:WU01:FS02:0x22:Completed 290000 out of 1000000 steps (29%)
15:21:03:WU02:FS01:0x22:Completed 610000 out of 1000000 steps (61%)
15:22:08:WU01:FS02:0x22:Completed 300000 out of 1000000 steps (30%)
15:22:47:WU02:FS01:0x22:Completed 620000 out of 1000000 steps (62%)
15:24:02:WU03:FS00:0xa7:Completed 106250 out of 125000 steps (85%)
15:24:12:WU01:FS02:0x22:Completed 310000 out of 1000000 steps (31%)
15:24:32:WU02:FS01:0x22:Completed 630000 out of 1000000 steps (63%)
15:26:10:WU01:FS02:0x22:Completed 320000 out of 1000000 steps (32%)
15:26:16:WU02:FS01:0x22:Completed 640000 out of 1000000 steps (64%)
15:28:01:WU02:FS01:0x22:Completed 650000 out of 1000000 steps (65%)
15:28:09:WU01:FS02:0x22:Completed 330000 out of 1000000 steps (33%)
15:29:50:WU02:FS01:0x22:Completed 660000 out of 1000000 steps (66%)
15:30:07:WU01:FS02:0x22:Completed 340000 out of 1000000 steps (34%)
15:31:35:WU02:FS01:0x22:Completed 670000 out of 1000000 steps (67%)
15:32:05:WU01:FS02:0x22:Completed 350000 out of 1000000 steps (35%)
15:32:14:WU03:FS00:0xa7:Completed 107500 out of 125000 steps (86%)
15:33:19:WU02:FS01:0x22:Completed 680000 out of 1000000 steps (68%)
15:34:09:WU01:FS02:0x22:Completed 360000 out of 1000000 steps (36%)
15:35:03:WU02:FS01:0x22:Completed 690000 out of 1000000 steps (69%)
15:36:08:WU01:FS02:0x22:Completed 370000 out of 1000000 steps (37%)
15:36:48:WU02:FS01:0x22:Completed 700000 out of 1000000 steps (70%)
15:38:06:WU01:FS02:0x22:Completed 380000 out of 1000000 steps (38%)
15:38:38:WU02:FS01:0x22:Completed 710000 out of 1000000 steps (71%)
15:40:05:WU01:FS02:0x22:Completed 390000 out of 1000000 steps (39%)
15:40:22:WU02:FS01:0x22:Completed 720000 out of 1000000 steps (72%)
15:40:26:WU03:FS00:0xa7:Completed 108750 out of 125000 steps (87%)
15:42:04:WU01:FS02:0x22:Completed 400000 out of 1000000 steps (40%)
15:42:07:WU02:FS01:0x22:Completed 730000 out of 1000000 steps (73%)
15:43:51:WU02:FS01:0x22:Completed 740000 out of 1000000 steps (74%)
15:44:08:WU01:FS02:0x22:Completed 410000 out of 1000000 steps (41%)
15:45:36:WU02:FS01:0x22:Completed 750000 out of 1000000 steps (75%)
15:46:07:WU01:FS02:0x22:Completed 420000 out of 1000000 steps (42%)
15:47:25:WU02:FS01:0x22:Completed 760000 out of 1000000 steps (76%)
15:48:06:WU01:FS02:0x22:Completed 430000 out of 1000000 steps (43%)
15:48:39:WU03:FS00:0xa7:Completed 110000 out of 125000 steps (88%)
15:49:10:WU02:FS01:0x22:Completed 770000 out of 1000000 steps (77%)
15:50:05:WU01:FS02:0x22:Completed 440000 out of 1000000 steps (44%)
15:50:54:WU02:FS01:0x22:Completed 780000 out of 1000000 steps (78%)
15:52:03:WU01:FS02:0x22:Completed 450000 out of 1000000 steps (45%)
15:52:38:WU02:FS01:0x22:Completed 790000 out of 1000000 steps (79%)
15:54:07:WU01:FS02:0x22:Completed 460000 out of 1000000 steps (46%)
15:54:23:WU02:FS01:0x22:Completed 800000 out of 1000000 steps (80%)
15:56:06:WU01:FS02:0x22:Completed 470000 out of 1000000 steps (47%)
15:56:13:WU02:FS01:0x22:Completed 810000 out of 1000000 steps (81%)
15:56:53:WU03:FS00:0xa7:Completed 111250 out of 125000 steps (89%)
15:57:57:WU02:FS01:0x22:Completed 820000 out of 1000000 steps (82%)
15:58:04:WU01:FS02:0x22:Completed 480000 out of 1000000 steps (48%)
15:59:42:WU02:FS01:0x22:Completed 830000 out of 1000000 steps (83%)
16:00:02:WU01:FS02:0x22:Completed 490000 out of 1000000 steps (49%)
16:01:26:WU02:FS01:0x22:Completed 840000 out of 1000000 steps (84%)
16:02:01:WU01:FS02:0x22:Completed 500000 out of 1000000 steps (50%)
16:03:11:WU02:FS01:0x22:Completed 850000 out of 1000000 steps (85%)
16:04:05:WU01:FS02:0x22:Completed 510000 out of 1000000 steps (51%)
16:05:01:WU02:FS01:0x22:Completed 860000 out of 1000000 steps (86%)
16:05:07:WU03:FS00:0xa7:Completed 112500 out of 125000 steps (90%)
16:06:04:WU01:FS02:0x22:Completed 520000 out of 1000000 steps (52%)
16:06:45:WU02:FS01:0x22:Completed 870000 out of 1000000 steps (87%)
16:08:03:WU01:FS02:0x22:Completed 530000 out of 1000000 steps (53%)
16:08:30:WU02:FS01:0x22:Completed 880000 out of 1000000 steps (88%)
16:10:02:WU01:FS02:0x22:Completed 540000 out of 1000000 steps (54%)
16:10:14:WU02:FS01:0x22:Completed 890000 out of 1000000 steps (89%)
16:11:58:WU02:FS01:0x22:Completed 900000 out of 1000000 steps (90%)
16:12:00:WU01:FS02:0x22:Completed 550000 out of 1000000 steps (55%)
16:13:29:WU03:FS00:0xa7:Completed 113750 out of 125000 steps (91%)
16:13:48:WU02:FS01:0x22:Completed 910000 out of 1000000 steps (91%)
16:14:04:WU01:FS02:0x22:Completed 560000 out of 1000000 steps (56%)
16:15:32:WU02:FS01:0x22:Completed 920000 out of 1000000 steps (92%)
16:16:02:WU01:FS02:0x22:Completed 570000 out of 1000000 steps (57%)
16:17:17:WU02:FS01:0x22:Completed 930000 out of 1000000 steps (93%)
16:18:01:WU01:FS02:0x22:Completed 580000 out of 1000000 steps (58%)
16:19:01:WU02:FS01:0x22:Completed 940000 out of 1000000 steps (94%)
16:19:59:WU01:FS02:0x22:Completed 590000 out of 1000000 steps (59%)
16:20:45:WU02:FS01:0x22:Completed 950000 out of 1000000 steps (95%)
16:21:45:WU03:FS00:0xa7:Completed 115000 out of 125000 steps (92%)
16:21:57:WU01:FS02:0x22:Completed 600000 out of 1000000 steps (60%)
16:22:35:WU02:FS01:0x22:Completed 960000 out of 1000000 steps (96%)
16:24:02:WU01:FS02:0x22:Completed 610000 out of 1000000 steps (61%)
16:24:20:WU02:FS01:0x22:Completed 970000 out of 1000000 steps (97%)
16:26:01:WU01:FS02:0x22:Completed 620000 out of 1000000 steps (62%)
16:26:04:WU02:FS01:0x22:Completed 980000 out of 1000000 steps (98%)
16:27:49:WU02:FS01:0x22:Completed 990000 out of 1000000 steps (99%)
16:27:50:WU00:FS01:Connecting to 65.254.110.245:8080
16:27:50:WU00:FS01:Assigned to work server 140.163.4.241
16:27:50:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GP104 [GeForce GTX 1080] 8873 from 140.163.4.241
16:27:50:WU00:FS01:Connecting to 140.163.4.241:8080
16:27:56:WU00:FS01:Downloading 79.12MiB
16:28:00:WU01:FS02:0x22:Completed 630000 out of 1000000 steps (63%)
16:28:03:WU00:FS01:Download 0.79%
16:28:09:WU00:FS01:Download 4.19%
16:28:15:WU00:FS01:Download 10.58%
16:28:21:WU00:FS01:Download 29.62%
16:28:26:ERROR:WU00:FS01:Exception: Transfer failed
16:28:26:WU00:FS01:Connecting to 65.254.110.245:8080
16:28:26:WU00:FS01:Assigned to work server 140.163.4.241
16:28:26:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GP104 [GeForce GTX 1080] 8873 from 140.163.4.241
16:28:26:WU00:FS01:Connecting to 140.163.4.241:8080
16:28:55:WU00:FS01:Downloading 29.59MiB
16:29:01:WU00:FS01:Download 100.00%
16:29:01:WU00:FS01:Download complete
16:29:01:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11743 run:0 clone:1202 gen:2 core:0x22 unit:0x000000058ca304f15e67e0f454cd98f3
16:29:33:WU02:FS01:0x22:Completed 1000000 out of 1000000 steps (100%)
16:29:38:WU02:FS01:0x22:Saving result file ../logfile_01.txt
16:29:38:WU02:FS01:0x22:Saving result file checkpointState.xml
16:29:38:WU02:FS01:0x22:Saving result file checkpt.crc
16:29:38:WU02:FS01:0x22:Saving result file positions.xtc
16:29:38:WU02:FS01:0x22:Saving result file science.log
16:29:39:WU02:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
16:29:39:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
16:29:39:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:11741 run:0 clone:1891 gen:1 core:0x22 unit:0x000000018ca304f15e67d867f17a85f5
16:29:39:WU02:FS01:Uploading 9.23MiB to 140.163.4.241
16:29:39:WU02:FS01:Connecting to 140.163.4.241:8080
16:29:39:WU00:FS01:Starting
16:29:39:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_22.fah/FahCore_22 -dir 00 -suffix 01 -version 705 -lifeline 1637 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
16:29:39:WU00:FS01:Started FahCore on PID 6759
16:29:39:WU00:FS01:Core PID:6763
16:29:39:WU00:FS01:FahCore 0x22 started
16:29:39:WU00:FS01:0x22:*********************** Log Started 2020-03-11T16:29:39Z ***********************
16:29:39:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
16:29:39:WU00:FS01:0x22:       Type: 0x22
16:29:39:WU00:FS01:0x22:       Core: Core22
16:29:39:WU00:FS01:0x22:    Website: https://foldingathome.org/
16:29:39:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
16:29:39:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
16:29:39:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
16:29:39:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 705 -lifeline 6759 -checkpoint 15
16:29:39:WU00:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
16:29:39:WU00:FS01:0x22:             0 -gpu 0
16:29:39:WU00:FS01:0x22:     Config: <none>
16:29:39:WU00:FS01:0x22:************************************ Build *************************************
16:29:39:WU00:FS01:0x22:    Version: 0.0.2
16:29:39:WU00:FS01:0x22:       Date: Dec 6 2019
16:29:39:WU00:FS01:0x22:       Time: 21:20:17
16:29:39:WU00:FS01:0x22: Repository: Git
16:29:39:WU00:FS01:0x22:   Revision: f87d92b58abdf7e6bf2e173cfbc4dc3e837c7042
16:29:39:WU00:FS01:0x22:     Branch: core22
16:29:39:WU00:FS01:0x22:   Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
16:29:39:WU00:FS01:0x22:    Options: -std=gnu++98 -O3 -funroll-loops
16:29:39:WU00:FS01:0x22:   Platform: linux2 4.9.87-linuxkit-aufs
16:29:39:WU00:FS01:0x22:       Bits: 64
16:29:39:WU00:FS01:0x22:       Mode: Release
16:29:39:WU00:FS01:0x22:************************************ System ************************************
16:29:39:WU00:FS01:0x22:        CPU: Intel(R) Xeon(R) CPU E5-2670 0 @ 2.60GHz
16:29:39:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 45 Stepping 7
16:29:39:WU00:FS01:0x22:       CPUs: 4
16:29:39:WU00:FS01:0x22:     Memory: 11.70GiB
16:29:39:WU00:FS01:0x22:Free Memory: 8.02GiB
16:29:39:WU00:FS01:0x22:    Threads: POSIX_THREADS
16:29:39:WU00:FS01:0x22: OS Version: 4.15
16:29:39:WU00:FS01:0x22:Has Battery: false
16:29:39:WU00:FS01:0x22: On Battery: false
16:29:39:WU00:FS01:0x22: UTC Offset: 0
16:29:39:WU00:FS01:0x22:        PID: 6763
16:29:39:WU00:FS01:0x22:        CWD: /var/lib/fahclient/work
16:29:39:WU00:FS01:0x22:         OS: Linux 4.15.0-88-generic x86_64
16:29:39:WU00:FS01:0x22:    OS Arch: AMD64
16:29:39:WU00:FS01:0x22:********************************************************************************
16:29:39:WU00:FS01:0x22:Project: 11743 (Run 0, Clone 1202, Gen 2)
16:29:39:WU00:FS01:0x22:Unit: 0x000000058ca304f15e67e0f454cd98f3
16:29:39:WU00:FS01:0x22:Reading tar file core.xml
16:29:39:WU00:FS01:0x22:Reading tar file integrator.xml
16:29:39:WU00:FS01:0x22:Reading tar file state.xml
16:29:39:WU00:FS01:0x22:Reading tar file system.xml
16:29:39:WU00:FS01:0x22:Digital signatures verified
16:29:39:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
16:29:39:WU00:FS01:0x22:Version 0.0.2
16:29:44:WU00:FS01:0x22:Completed 0 out of 2000000 steps (0%)
16:29:44:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
16:29:57:WU03:FS00:0xa7:Completed 116250 out of 125000 steps (93%)
16:29:58:WU01:FS02:0x22:Completed 640000 out of 1000000 steps (64%)
16:30:01:WU02:FS01:Upload 3.38%
16:30:08:WU02:FS01:Upload 50.76%
16:30:14:WU02:FS01:Upload 70.39%
16:30:24:WU02:FS01:Upload complete
16:30:24:WU02:FS01:Server responded WORK_QUIT (404)
16:30:24:WARNING:WU02:FS01:Server did not like results, dumping
16:30:24:WU02:FS01:Cleaning up
16:30:55:WU00:FS01:0x22:Completed 20000 out of 2000000 steps (1%)
16:31:57:WU01:FS02:0x22:Completed 650000 out of 1000000 steps (65%)
16:32:06:WU00:FS01:0x22:Completed 40000 out of 2000000 steps (2%)
16:33:20:WU00:FS01:0x22:Completed 60000 out of 2000000 steps (3%)
16:34:01:WU01:FS02:0x22:Completed 660000 out of 1000000 steps (66%)
16:34:31:WU00:FS01:0x22:Completed 80000 out of 2000000 steps (4%)
Edit: Checked the complete log since monday 13.31 CET and this is the first occurence of this error. Other errors in the log are connection related.
Re: Project: 11741 (Run 0, Clone 1891, Gen 1) - Server respo
The WORK_QUIT (404) report indicates that the server decided the result was corrupted in some way. There's no way to tell if when or why that happened. It might have been a problem during uploading or an undetected calculation error.
If you're system happens to be overclocked or overheating, you might reconsider its stability. If not, there's probably nothing you can do other than to watch for a similar issue in the future.
One other possibility is modification of F@h results files if you happen to be running an antivirus or other anti-malware software. Some can get false positives on the binary data present in the work files. If you are running such software, excluding the F@h data directories from such scans is recommended.
Empie
Post by Empie »
Joe_H wrote:One other possibility is modification of F@h results files if you happen to be running an antivirus or other anti-malware software. Some can get false positives on the binary data present in the work files. If you are running such software, excluding the F@h data directories from such scans is recommended.
I'm running Linux. No AV installed.
Empie
Post by Empie »
bruce wrote:The WORK_QUIT (404) report indicates that the server decided the result was corrupted in some way. There's no way to tell if when or why that happened. It might have been a problem during uploading or an undetected calculation error.
So far the system has run fine, but I only have these GPU's for about 3 weeks now. F@H is the first to push these cards to around 100%. I'll keep an eye on it. Thanks.
Empie wrote:So far the system has run fine, but I only have these GPU's for about 3 weeks now. F@H is the first to push these cards to around 100%. I'll keep an eye on it. Thanks.
That's a good thing, Right? :roll:
You might investigate methods of setting fan speeds or underclocking or (better yet) configuring power management on the GPU itself.
Empie
Post by Empie »
Sure is :)
Thanks to you both for replying this quickly. Will keep your advices in the back of my head in case it happens again. I'll keep an eye on the logs.
simon-mj-carter
14197(1, 763, 0):
******************************* Date: 2020-03-10 *******************************
09:45:17:WU01:FS00:0xa7:Completed 2475000 out of 2500000 steps (99%)
09:45:18:WU00:FS00:Connecting to 65.254.110.245:8080
09:45:19:WU00:FS00:Assigned to work server 155.247.164.213
09:45:19:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:4 from 155.247.164.213
09:45:19:WU00:FS00:Connecting to 155.247.164.213:8080
09:45:20:WU00:FS00:Downloading 1.24MiB
09:45:25:WU00:FS00:Download complete
09:45:25:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14197 run:1 clone:763 gen:0 core:0xa7 unit:0x000000009bf7a4d55e66d1e5d3009574
09:54:09:WU01:FS00:0xa7:Completed 2500000 out of 2500000 steps (100%)
09:54:10:WU01:FS00:0xa7:Saving result file ..\logfile_01.txt
09:54:10:WU01:FS00:0xa7:Saving result file frame6.trr
09:54:10:WU01:FS00:0xa7:Saving result file md.log
09:54:10:WU01:FS00:0xa7:Saving result file science.log
09:54:10:WU01:FS00:0xa7:Saving result file traj_comp.xtc
09:54:10:WU01:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
09:54:11:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
09:54:11:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:14182 run:11 clone:421 gen:6 core:0xa7 unit:0x000000070002894b5dae08b21d182155
09:54:11:WU01:FS00:Uploading 5.43MiB to 155.247.166.219
09:54:11:WU01:FS00:Connecting to 155.247.166.219:8080
09:54:11:WU00:FS00:Starting
09:54:11:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\simon\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 10344 -checkpoint 15 -np 4
09:54:11:WU00:FS00:Started FahCore on PID 39248
09:54:11:WU00:FS00:Core PID:41868
09:54:11:WU00:FS00:FahCore 0xa7 started
09:54:11:WU00:FS00:0xa7:*********************** Log Started 2020-03-10T09:54:11Z ***********************
09:54:11:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
09:54:11:WU00:FS00:0xa7:       Type: 0xa7
09:54:11:WU00:FS00:0xa7:       Core: Gromacs
09:54:11:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 39248 -checkpoint 15 -np
09:54:11:WU00:FS00:0xa7:             4
09:54:11:WU00:FS00:0xa7:************************************ CBang *************************************
09:54:11:WU00:FS00:0xa7:       Date: Oct 26 2019
09:54:11:WU00:FS00:0xa7:       Time: 01:38:25
09:54:11:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
09:54:11:WU00:FS00:0xa7:     Branch: master
09:54:11:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
09:54:11:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
09:54:11:WU00:FS00:0xa7:   Platform: win32 10
09:54:11:WU00:FS00:0xa7:       Bits: 64
09:54:11:WU00:FS00:0xa7:       Mode: Release
09:54:11:WU00:FS00:0xa7:************************************ System ************************************
09:54:11:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i3-8145U CPU @ 2.10GHz
09:54:11:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 12
09:54:11:WU00:FS00:0xa7:       CPUs: 4
09:54:11:WU00:FS00:0xa7:     Memory: 7.82GiB
09:54:11:WU00:FS00:0xa7:Free Memory: 2.85GiB
09:54:11:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
09:54:11:WU00:FS00:0xa7: OS Version: 6.2
09:54:11:WU00:FS00:0xa7:Has Battery: true
09:54:11:WU00:FS00:0xa7: On Battery: false
09:54:11:WU00:FS00:0xa7: UTC Offset: 1
09:54:11:WU00:FS00:0xa7:        PID: 41868
09:54:11:WU00:FS00:0xa7:        CWD: C:\Users\simon\AppData\Roaming\FAHClient\work
09:54:11:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
09:54:11:WU00:FS00:0xa7:    Version: 0.0.18
09:54:11:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:54:11:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
09:54:11:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
09:54:11:WU00:FS00:0xa7:       Time: 01:52:30
09:54:11:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
09:54:11:WU00:FS00:0xa7:************************************ Build *************************************
09:54:11:WU00:FS00:0xa7:       SIMD: avx_256
09:54:11:WU00:FS00:0xa7:********************************************************************************
09:54:11:WU00:FS00:0xa7:Project: 14197 (Run 1, Clone 763, Gen 0)
09:54:11:WU00:FS00:0xa7:Unit: 0x000000009bf7a4d55e66d1e5d3009574
09:54:11:WU00:FS00:0xa7:Reading tar file core.xml
09:54:11:WU00:FS00:0xa7:Reading tar file frame0.tpr
09:54:11:WU00:FS00:0xa7:Digital signatures verified
09:54:12:WU00:FS00:0xa7:Calling: mdrun -s frame0.tpr -o frame0.trr -cpt 15 -nt 4
09:54:12:WU00:FS00:0xa7:Steps: first=0 total=500000
09:54:12:WU00:FS00:0xa7:Completed 1 out of 500000 steps (0%)
09:54:18:WU01:FS00:Upload 6.90%
09:54:24:WU01:FS00:Upload 11.50%
09:54:30:WU01:FS00:Upload 17.26%
09:54:36:WU01:FS00:Upload 23.01%
09:54:42:WU01:FS00:Upload 28.76%
09:54:48:WU01:FS00:Upload 34.51%
09:54:54:WU01:FS00:Upload 40.26%
09:55:01:WU01:FS00:Upload 46.01%
09:55:07:WU01:FS00:Upload 51.77%
09:55:13:WU01:FS00:Upload 57.52%
09:55:19:WU01:FS00:Upload 63.27%
09:55:25:WU01:FS00:Upload 69.02%
09:55:31:WU01:FS00:Upload 74.77%
09:55:33:WU00:FS00:0xa7:Completed 5000 out of 500000 steps (1%)
09:55:37:WU01:FS00:Upload 80.52%
09:55:43:WU01:FS00:Upload 86.28%
09:55:49:WU01:FS00:Upload 93.18%
09:55:55:WU01:FS00:Upload 97.78%
09:55:59:WU01:FS00:Upload complete
09:55:59:WU01:FS00:Server responded WORK_ACK (400)
09:55:59:WU01:FS00:Final credit estimate, 9843.00 points
09:55:59:WU01:FS00:Cleaning up
09:56:55:WU00:FS00:0xa7:Completed 10000 out of 500000 steps (2%)
12:14:54:WU00:FS00:0xa7:Completed 495000 out of 500000 steps (99%)
12:14:57:WU01:FS00:Connecting to 65.254.110.245:8080
12:15:11:WU01:FS00:Assigned to work server 155.247.164.213
12:15:11:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:4 from 155.247.164.213
12:15:11:WU01:FS00:Connecting to 155.247.164.213:8080
12:15:15:WU01:FS00:Downloading 1.24MiB
12:15:38:WU01:FS00:Download 5.06%
12:15:48:WU01:FS00:Download 25.30%
12:16:03:WU01:FS00:Download 45.53%
12:16:14:WU01:FS00:Download 55.65%
12:16:20:WU01:FS00:Download 60.71%
12:16:20:WU00:FS00:0xa7:Completed 500000 out of 500000 steps (100%)
12:16:21:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
12:16:21:WU00:FS00:0xa7:Saving result file frame0.trr
12:16:21:WU00:FS00:0xa7:Saving result file md.log
12:16:21:WU00:FS00:0xa7:Saving result file pullf.xvg
12:16:21:WU00:FS00:0xa7:Saving result file pullx.xvg
12:16:21:WU00:FS00:0xa7:Saving result file science.log
12:16:21:WU00:FS00:0xa7:Saving result file traj_comp.xtc
12:16:21:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
12:16:21:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
12:16:21:WU00:FS00:Uploading 3.20MiB to 155.247.164.213
12:16:21:WU00:FS00:Connecting to 155.247.164.213:8080
12:16:26:WU01:FS00:Download 70.83%
12:16:28:WU00:FS00:Upload 7.82%
12:16:34:WU01:FS00:Download 75.89%
12:16:41:WU01:FS00:Download 80.95%
12:16:47:WU01:FS00:Download 91.07%
12:16:48:WU00:FS00:Upload 11.72%
12:16:49:WU01:FS00:Download complete
12:16:50:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14197 run:0 clone:374 gen:4 core:0xa7 unit:0x000000049bf7a4d55e66d22835405280
12:16:50:WU01:FS00:Starting
12:16:50:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\simon\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 10344 -checkpoint 15 -np 4
12:16:50:WU01:FS00:Started FahCore on PID 41972
12:16:50:WU01:FS00:Core PID:34940
12:16:50:WU01:FS00:FahCore 0xa7 started
12:16:50:WU01:FS00:0xa7:*********************** Log Started 2020-03-10T12:16:50Z ***********************
12:16:50:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
12:16:50:WU01:FS00:0xa7:       Type: 0xa7
12:16:50:WU01:FS00:0xa7:       Core: Gromacs
12:16:50:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 41972 -checkpoint 15 -np
12:16:50:WU01:FS00:0xa7:             4
12:16:50:WU01:FS00:0xa7:************************************ CBang *************************************
12:16:50:WU01:FS00:0xa7:       Date: Oct 26 2019
12:16:50:WU01:FS00:0xa7:       Time: 01:38:25
12:16:50:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
12:16:50:WU01:FS00:0xa7:     Branch: master
12:16:50:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
12:16:50:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:16:50:WU01:FS00:0xa7:   Platform: win32 10
12:16:50:WU01:FS00:0xa7:       Bits: 64
12:16:50:WU01:FS00:0xa7:       Mode: Release
12:16:50:WU01:FS00:0xa7:************************************ System ************************************
12:16:50:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i3-8145U CPU @ 2.10GHz
12:16:50:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 12
12:16:50:WU01:FS00:0xa7:       CPUs: 4
12:16:50:WU01:FS00:0xa7:     Memory: 7.82GiB
12:16:50:WU01:FS00:0xa7:Free Memory: 2.68GiB
12:16:50:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
12:16:50:WU01:FS00:0xa7: OS Version: 6.2
12:16:50:WU01:FS00:0xa7:Has Battery: true
12:16:50:WU01:FS00:0xa7: On Battery: false
12:16:50:WU01:FS00:0xa7: UTC Offset: 1
12:16:50:WU01:FS00:0xa7:        PID: 34940
12:16:50:WU01:FS00:0xa7:        CWD: C:\Users\simon\AppData\Roaming\FAHClient\work
12:16:50:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
12:16:50:WU01:FS00:0xa7:    Version: 0.0.18
12:16:50:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:16:50:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
12:16:50:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
12:16:50:WU01:FS00:0xa7:       Time: 01:52:30
12:16:50:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
12:16:50:WU01:FS00:0xa7:************************************ Build *************************************
12:16:50:WU01:FS00:0xa7:       SIMD: avx_256
12:16:50:WU01:FS00:0xa7:********************************************************************************
12:16:50:WU01:FS00:0xa7:Project: 14197 (Run 0, Clone 374, Gen 4)
12:16:50:WU01:FS00:0xa7:Unit: 0x000000049bf7a4d55e66d22835405280
12:16:50:WU01:FS00:0xa7:Reading tar file core.xml
12:16:50:WU01:FS00:0xa7:Reading tar file frame4.tpr
12:16:50:WU01:FS00:0xa7:Digital signatures verified
12:16:50:WU01:FS00:0xa7:Calling: mdrun -s frame4.tpr -o frame4.trr -cpt 15 -nt 4
12:16:50:WU01:FS00:0xa7:Steps: first=2000000 total=500000
12:16:51:WU01:FS00:0xa7:Completed 1 out of 500000 steps (0%)
12:16:54:WU00:FS00:Upload 17.59%
12:17:02:WU00:FS00:Upload 27.35%
12:17:08:WU00:FS00:Upload 31.26%
12:17:14:WU00:FS00:Upload 39.08%
12:17:20:WU00:FS00:Upload 46.89%
12:17:37:WU00:FS00:Upload 48.85%
12:18:07:WU01:FS00:0xa7:Completed 5000 out of 500000 steps (1%)
12:18:29:WU00:FS00:Upload 50.80%
12:18:29:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
12:18:29:WU00:FS00:Trying to send results to collection server
12:18:29:WU00:FS00:Uploading 3.20MiB to 155.247.164.214
12:18:29:WU00:FS00:Connecting to 155.247.164.214:8080
12:18:36:WU00:FS00:Upload 7.82%
12:18:48:WU00:FS00:Upload 11.72%
12:18:58:WU00:FS00:Upload 15.63%
12:19:07:WU00:FS00:Upload 21.49%
12:19:27:WU00:FS00:Upload 23.45%
12:19:29:WU01:FS00:0xa7:Completed 10000 out of 500000 steps (2%)
12:19:41:WU00:FS00:Upload 27.35%
12:19:56:WU00:FS00:Upload 29.31%
12:20:02:WU00:FS00:Upload 31.26%
12:20:10:WU00:FS00:Upload 37.12%
12:20:17:WU00:FS00:Upload 42.99%
12:20:26:WU00:FS00:Upload 46.89%
12:20:37:WU00:FS00:Upload 48.85%
12:20:47:WU00:FS00:Upload 50.80%
12:20:51:WU01:FS00:0xa7:Completed 15000 out of 500000 steps (3%)
12:21:00:WU00:FS00:Upload 52.76%
12:21:06:WU00:FS00:Upload 54.71%
12:21:12:WU00:FS00:Upload 58.62%
12:21:20:WU00:FS00:Upload 62.52%
12:21:26:WU00:FS00:Upload 64.48%
12:21:32:WU00:FS00:Upload 72.29%
12:21:42:WU00:FS00:Upload 76.20%
12:21:48:WU00:FS00:Upload 82.06%
12:21:56:WU00:FS00:Upload 87.93%
12:22:02:WU00:FS00:Upload 95.74%
12:22:09:WU00:FS00:Upload 99.65%
12:22:13:WU01:FS00:0xa7:Completed 20000 out of 500000 steps (4%)
simon-mj-carter
14197 (3, 790, 3):
12:23:36:WU01:FS00:0xa7:Completed 25000 out of 500000 steps (5%)
14:39:52:WU01:FS00:0xa7:Completed 495000 out of 500000 steps (99%)
14:39:58:WU00:FS00:Connecting to 65.254.110.245:8080
14:40:00:WU00:FS00:Assigned to work server 155.247.164.213
14:40:00:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:4 from 155.247.164.213
14:40:00:WU00:FS00:Connecting to 155.247.164.213:8080
14:40:04:WU00:FS00:Downloading 1.24MiB
14:40:10:WU00:FS00:Download 5.06%
14:40:17:WU00:FS00:Download 15.18%
14:40:24:WU00:FS00:Download 30.36%
14:40:30:WU00:FS00:Download 45.53%
14:40:37:WU00:FS00:Download 50.59%
14:40:45:WU00:FS00:Download 75.89%
14:40:50:WU00:FS00:Download complete
14:40:50:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14197 run:3 clone:790 gen:3 core:0xa7 unit:0x000000039bf7a4d55e66d1850b1864e9
14:41:14:WU01:FS00:0xa7:Completed 500000 out of 500000 steps (100%)
14:41:15:WU01:FS00:0xa7:Saving result file ..\logfile_01.txt
14:41:15:WU01:FS00:0xa7:Saving result file frame4.trr
14:41:15:WU01:FS00:0xa7:Saving result file md.log
14:41:15:WU01:FS00:0xa7:Saving result file pullf.xvg
14:41:15:WU01:FS00:0xa7:Saving result file pullx.xvg
14:41:15:WU01:FS00:0xa7:Saving result file science.log
14:41:15:WU01:FS00:0xa7:Saving result file traj_comp.xtc
14:41:15:WU01:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
14:41:15:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
14:41:15:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:14197 run:0 clone:374 gen:4 core:0xa7 unit:0x000000049bf7a4d55e66d22835405280
14:41:16:WU01:FS00:Uploading 2.63MiB to 155.247.164.213
14:41:16:WU01:FS00:Connecting to 155.247.164.213:8080
14:41:16:WU00:FS00:Starting
14:41:16:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\simon\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 10344 -checkpoint 15 -np 4
14:41:16:WU00:FS00:Started FahCore on PID 42928
14:41:16:WU00:FS00:Core PID:43224
14:41:16:WU00:FS00:FahCore 0xa7 started
14:41:16:WU00:FS00:0xa7:*********************** Log Started 2020-03-10T14:41:16Z ***********************
14:41:16:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
14:41:16:WU00:FS00:0xa7:       Type: 0xa7
14:41:16:WU00:FS00:0xa7:       Core: Gromacs
14:41:16:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 42928 -checkpoint 15 -np
14:41:16:WU00:FS00:0xa7:             4
14:41:16:WU00:FS00:0xa7:************************************ CBang *************************************
14:41:16:WU00:FS00:0xa7:       Date: Oct 26 2019
14:41:16:WU00:FS00:0xa7:       Time: 01:38:25
14:41:16:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
14:41:16:WU00:FS00:0xa7:     Branch: master
14:41:16:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
14:41:16:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:41:16:WU00:FS00:0xa7:   Platform: win32 10
14:41:16:WU00:FS00:0xa7:       Bits: 64
14:41:16:WU00:FS00:0xa7:       Mode: Release
14:41:16:WU00:FS00:0xa7:************************************ System ************************************
14:41:16:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i3-8145U CPU @ 2.10GHz
14:41:16:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 12
14:41:16:WU00:FS00:0xa7:       CPUs: 4
14:41:16:WU00:FS00:0xa7:     Memory: 7.82GiB
14:41:16:WU00:FS00:0xa7:Free Memory: 2.39GiB
14:41:16:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
14:41:16:WU00:FS00:0xa7: OS Version: 6.2
14:41:16:WU00:FS00:0xa7:Has Battery: true
14:41:16:WU00:FS00:0xa7: On Battery: false
14:41:16:WU00:FS00:0xa7: UTC Offset: 1
14:41:16:WU00:FS00:0xa7:        PID: 43224
14:41:16:WU00:FS00:0xa7:        CWD: C:\Users\simon\AppData\Roaming\FAHClient\work
14:41:16:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
14:41:16:WU00:FS00:0xa7:    Version: 0.0.18
14:41:16:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:41:16:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
14:41:16:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
14:41:16:WU00:FS00:0xa7:       Time: 01:52:30
14:41:16:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
14:41:16:WU00:FS00:0xa7:************************************ Build *************************************
14:41:16:WU00:FS00:0xa7:       SIMD: avx_256
14:41:16:WU00:FS00:0xa7:********************************************************************************
14:41:16:WU00:FS00:0xa7:Project: 14197 (Run 3, Clone 790, Gen 3)
14:41:16:WU00:FS00:0xa7:Unit: 0x000000039bf7a4d55e66d1850b1864e9
14:41:16:WU00:FS00:0xa7:Reading tar file core.xml
14:41:16:WU00:FS00:0xa7:Reading tar file frame3.tpr
14:41:16:WU00:FS00:0xa7:Digital signatures verified
14:41:16:WU00:FS00:0xa7:Calling: mdrun -s frame3.tpr -o frame3.trr -cpt 15 -nt 4
14:41:16:WU00:FS00:0xa7:Steps: first=1500000 total=500000
14:41:17:WU00:FS00:0xa7:Completed 1 out of 500000 steps (0%)
14:41:30:WU01:FS00:Upload 4.75%
14:41:37:WU01:FS00:Upload 9.49%
14:41:43:WU01:FS00:Upload 16.61%
14:41:49:WU01:FS00:Upload 23.73%
14:41:56:WU01:FS00:Upload 28.48%
14:42:03:WU01:FS00:Upload 40.34%
14:42:09:WU01:FS00:Upload 49.83%
14:42:15:WU01:FS00:Upload 56.95%
14:42:21:WU01:FS00:Upload 66.44%
14:42:27:WU01:FS00:Upload 75.94%
14:42:33:WU01:FS00:Upload 87.80%
14:42:40:WU00:FS00:0xa7:Completed 5000 out of 500000 steps (1%)
14:42:40:WU01:FS00:Upload 94.92%
14:42:46:WU01:FS00:Upload 100.00%
14:42:59:WU01:FS00:Upload complete
14:42:59:WU01:FS00:Server responded WORK_ACK (400)
14:42:59:WU01:FS00:Final credit estimate, 1375.00 points
14:42:59:WU01:FS00:Cleaning up
14:44:07:WU00:FS00:0xa7:Completed 10000 out of 500000 steps (2%)
17:00:16:WU00:FS00:0xa7:Completed 495000 out of 500000 steps (99%)
17:00:17:WU01:FS00:Connecting to 65.254.110.245:8080
17:00:18:WU01:FS00:Assigned to work server 155.247.166.219
17:00:18:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:4 from 155.247.166.219
17:00:18:WU01:FS00:Connecting to 155.247.166.219:8080
17:00:19:WU01:FS00:Downloading 1.41MiB
17:00:28:WU01:FS00:Download 4.44%
17:00:28:ERROR:WU01:FS00:Exception: Transfer failed
17:00:28:ERROR:WU01:FS00:Exception: Could not get IP address for assign1.foldingathome.org: No such host is known.
17:00:28:ERROR:WU01:FS00:Exception: Could not get IP address for assign2.foldingathome.org: No such host is known.
17:00:28:WARNING:WU01:FS00:Exception: Failed to find any IP addresses for assignment servers
17:00:28:ERROR:WU01:FS00:Exception: Could not get an assignment
17:01:28:WU01:FS00:Connecting to 65.254.110.245:8080
17:01:29:WU01:FS00:Assigned to work server 155.247.164.213
17:01:29:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:4 from 155.247.164.213
17:01:29:WU01:FS00:Connecting to 155.247.164.213:8080
17:01:31:WU01:FS00:Downloading 1.24MiB
17:01:42:WU00:FS00:0xa7:Completed 500000 out of 500000 steps (100%)
17:01:42:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
17:01:42:WU00:FS00:0xa7:Saving result file frame3.trr
17:01:42:WU00:FS00:0xa7:Saving result file md.log
17:01:42:WU00:FS00:0xa7:Saving result file pullf.xvg
17:01:42:WU00:FS00:0xa7:Saving result file pullx.xvg
17:01:42:WU00:FS00:0xa7:Saving result file science.log
17:01:42:WU00:FS00:0xa7:Saving result file traj_comp.xtc
17:01:42:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
17:01:43:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
17:01:43:WU00:FS00:Uploading 3.20MiB to 155.247.164.213
17:01:43:WU00:FS00:Connecting to 155.247.164.213:8080
17:01:51:WU00:FS00:Upload 5.86%
17:01:58:WU00:FS00:Upload 9.77%
17:02:14:WU00:FS00:Upload 11.72%
17:02:21:WU00:FS00:Upload 15.63%
17:02:34:WU00:FS00:Upload 19.53%
17:02:44:WU00:FS00:Upload 21.49%
17:02:49:WU01:FS00:Download 10.12%
17:02:55:WU01:FS00:Download 15.18%
17:02:55:ERROR:WU01:FS00:Exception: Transfer failed
17:02:55:WU00:FS00:Upload 25.39%
17:03:02:WU00:FS00:Upload 31.25%
17:03:06:WU01:FS00:Connecting to 65.254.110.245:8080
17:03:07:WU01:FS00:Assigned to work server 155.247.164.213
17:03:07:WU01:FS00:Requesting new work unit for slot 00: READY cpu:4 from 155.247.164.213
17:03:07:WU01:FS00:Connecting to 155.247.164.213:8080
17:03:15:WU00:FS00:Upload 37.11%
17:03:15:WU01:FS00:Downloading 1.24MiB
17:03:22:WU00:FS00:Upload 41.02%
17:03:27:WU01:FS00:Download 15.18%
17:03:31:WU00:FS00:Upload 46.88%
17:03:39:WU00:FS00:Upload 52.74%
17:03:51:WU00:FS00:Upload 56.65%
17:04:02:WU00:FS00:Upload 60.55%
17:04:08:WU00:FS00:Upload 62.51%
17:04:12:WU01:FS00:Download 30.36%
17:04:14:WU00:FS00:Upload 64.46%
17:04:22:WU00:FS00:Upload 66.41%
17:04:35:WU00:FS00:Upload 68.37%
17:04:43:WU00:FS00:Upload 72.27%
17:04:44:WU01:FS00:Download 40.47%
17:04:50:WU00:FS00:Upload 74.23%
17:04:52:WU01:FS00:Download 50.59%
17:04:56:WU00:FS00:Upload 78.13%
17:04:58:WU01:FS00:Download 70.83%
17:05:02:WU00:FS00:Upload 82.04%
17:05:04:WU01:FS00:Download 100.00%
17:05:04:WU01:FS00:Download complete
17:05:04:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14197 run:5 clone:550 gen:7 core:0xa7 unit:0x000000099bf7a4d55e66d1344ac56e51
17:05:04:WU01:FS00:Starting
17:05:04:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\simon\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 10344 -checkpoint 15 -np 4
17:05:04:WU01:FS00:Started FahCore on PID 36960
17:05:04:WU01:FS00:Core PID:42936
17:05:04:WU01:FS00:FahCore 0xa7 started
17:05:05:WU01:FS00:0xa7:*********************** Log Started 2020-03-10T17:05:04Z ***********************
17:05:05:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
17:05:05:WU01:FS00:0xa7:       Type: 0xa7
17:05:05:WU01:FS00:0xa7:       Core: Gromacs
17:05:05:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 36960 -checkpoint 15 -np
17:05:05:WU01:FS00:0xa7:             4
17:05:05:WU01:FS00:0xa7:************************************ CBang *************************************
17:05:05:WU01:FS00:0xa7:       Date: Oct 26 2019
17:05:05:WU01:FS00:0xa7:       Time: 01:38:25
17:05:05:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
17:05:05:WU01:FS00:0xa7:     Branch: master
17:05:05:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
17:05:05:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:05:05:WU01:FS00:0xa7:   Platform: win32 10
17:05:05:WU01:FS00:0xa7:       Bits: 64
17:05:05:WU01:FS00:0xa7:       Mode: Release
17:05:05:WU01:FS00:0xa7:************************************ System ************************************
17:05:05:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i3-8145U CPU @ 2.10GHz
17:05:05:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 12
17:05:05:WU01:FS00:0xa7:       CPUs: 4
17:05:05:WU01:FS00:0xa7:     Memory: 7.82GiB
17:05:05:WU01:FS00:0xa7:Free Memory: 2.09GiB
17:05:05:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
17:05:05:WU01:FS00:0xa7: OS Version: 6.2
17:05:05:WU01:FS00:0xa7:Has Battery: true
17:05:05:WU01:FS00:0xa7: On Battery: false
17:05:05:WU01:FS00:0xa7: UTC Offset: 1
17:05:05:WU01:FS00:0xa7:        PID: 42936
17:05:05:WU01:FS00:0xa7:        CWD: C:\Users\simon\AppData\Roaming\FAHClient\work
17:05:05:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
17:05:05:WU01:FS00:0xa7:    Version: 0.0.18
17:05:05:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:05:05:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
17:05:05:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
17:05:05:WU01:FS00:0xa7:       Time: 01:52:30
17:05:05:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
17:05:05:WU01:FS00:0xa7:************************************ Build *************************************
17:05:05:WU01:FS00:0xa7:       SIMD: avx_256
17:05:05:WU01:FS00:0xa7:********************************************************************************
17:05:05:WU01:FS00:0xa7:Project: 14197 (Run 5, Clone 550, Gen 7)
17:05:05:WU01:FS00:0xa7:Unit: 0x000000099bf7a4d55e66d1344ac56e51
17:05:05:WU01:FS00:0xa7:Reading tar file core.xml
17:05:05:WU01:FS00:0xa7:Reading tar file frame7.tpr
17:05:05:WU01:FS00:0xa7:Digital signatures verified
17:05:05:WU01:FS00:0xa7:Calling: mdrun -s frame7.tpr -o frame7.trr -cpt 15 -nt 4
17:05:05:WU01:FS00:0xa7:Steps: first=3500000 total=500000
17:05:05:WU01:FS00:0xa7:Completed 1 out of 500000 steps (0%)
17:05:10:WU00:FS00:Upload 87.90%
17:05:16:WU00:FS00:Upload 91.81%
17:05:40:WU00:FS00:Upload 95.71%
17:05:40:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
17:05:40:WU00:FS00:Trying to send results to collection server
17:05:40:WU00:FS00:Uploading 3.20MiB to 155.247.164.214
17:05:40:WU00:FS00:Connecting to 155.247.164.214:8080
17:05:46:WU00:FS00:Upload 5.86%
17:05:53:WU00:FS00:Upload 11.72%
17:05:59:WU00:FS00:Upload 17.58%
17:06:05:WU00:FS00:Upload 25.39%
17:06:12:WU00:FS00:Upload 33.21%
17:06:18:WU00:FS00:Upload 41.02%
17:06:19:WU01:FS00:0xa7:Completed 5000 out of 500000 steps (1%)
17:06:25:WU00:FS00:Upload 48.83%
17:06:31:WU00:FS00:Upload 56.65%
17:06:39:WU00:FS00:Upload 62.51%
17:06:45:WU00:FS00:Upload 70.32%
17:06:51:WU00:FS00:Upload 78.13%
17:06:57:WU00:FS00:Upload 85.95%
17:07:03:WU00:FS00:Upload 93.76%
17:07:10:WU00:FS00:Upload complete
17:07:10:WU00:FS00:Server responded WORK_QUIT (404)
17:07:10:WARNING:WU00:FS00:Server did not like results, dumping
17:07:10:WU00:FS00:Cleaning up
17:07:41:WU01:FS00:0xa7:Completed 10000 out of 500000 steps (2%)
19:21:36:WU01:FS00:0xa7:Completed 495000 out of 500000 steps (99%)
19:21:37:WU00:FS00:Connecting to 65.254.110.245:8080
19:21:43:WU00:FS00:Assigned to work server 155.247.166.219
19:21:43:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:4 from 155.247.166.219
19:21:43:WU00:FS00:Connecting to 155.247.166.219:8080
19:21:48:WU00:FS00:Downloading 1.29MiB
19:21:54:WU00:FS00:Download 82.08%
19:21:58:WU00:FS00:Download complete
19:21:58:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14317 run:1 clone:344 gen:6 core:0xa7 unit:0x000000090002894b5e63ba63d3d14395
19:22:58:WU01:FS00:0xa7:Completed 500000 out of 500000 steps (100%)
19:22:59:WU01:FS00:0xa7:Saving result file ..\logfile_01.txt
19:22:59:WU01:FS00:0xa7:Saving result file frame7.trr
19:22:59:WU01:FS00:0xa7:Saving result file md.log
19:22:59:WU01:FS00:0xa7:Saving result file pullf.xvg
19:22:59:WU01:FS00:0xa7:Saving result file pullx.xvg
19:22:59:WU01:FS00:0xa7:Saving result file science.log
19:22:59:WU01:FS00:0xa7:Saving result file traj_comp.xtc
19:22:59:WU01:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
19:22:59:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
19:22:59:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:14197 run:5 clone:550 gen:7 core:0xa7 unit:0x000000099bf7a4d55e66d1344ac56e51
19:22:59:WU01:FS00:Uploading 2.64MiB to 155.247.164.213
19:22:59:WU00:FS00:Starting
19:22:59:WU01:FS00:Connecting to 155.247.164.213:8080
19:22:59:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\simon\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 10344 -checkpoint 15 -np 4
19:22:59:WU00:FS00:Started FahCore on PID 42404
19:22:59:WU00:FS00:Core PID:44848
19:22:59:WU00:FS00:FahCore 0xa7 started
19:23:00:WU00:FS00:0xa7:*********************** Log Started 2020-03-10T19:22:59Z ***********************
19:23:00:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
19:23:00:WU00:FS00:0xa7:       Type: 0xa7
19:23:00:WU00:FS00:0xa7:       Core: Gromacs
19:23:00:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 42404 -checkpoint 15 -np
19:23:00:WU00:FS00:0xa7:             4
19:23:00:WU00:FS00:0xa7:************************************ CBang *************************************
19:23:00:WU00:FS00:0xa7:       Date: Oct 26 2019
19:23:00:WU00:FS00:0xa7:       Time: 01:38:25
19:23:00:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
19:23:00:WU00:FS00:0xa7:     Branch: master
19:23:00:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
19:23:00:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:23:00:WU00:FS00:0xa7:   Platform: win32 10
19:23:00:WU00:FS00:0xa7:       Bits: 64
19:23:00:WU00:FS00:0xa7:       Mode: Release
19:23:00:WU00:FS00:0xa7:************************************ System ************************************
19:23:00:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i3-8145U CPU @ 2.10GHz
19:23:00:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 12
19:23:00:WU00:FS00:0xa7:       CPUs: 4
19:23:00:WU00:FS00:0xa7:     Memory: 7.82GiB
19:23:00:WU00:FS00:0xa7:Free Memory: 2.16GiB
19:23:00:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
19:23:00:WU00:FS00:0xa7: OS Version: 6.2
19:23:00:WU00:FS00:0xa7:Has Battery: true
19:23:00:WU00:FS00:0xa7: On Battery: false
19:23:00:WU00:FS00:0xa7: UTC Offset: 1
19:23:00:WU00:FS00:0xa7:        PID: 44848
19:23:00:WU00:FS00:0xa7:        CWD: C:\Users\simon\AppData\Roaming\FAHClient\work
19:23:00:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
19:23:00:WU00:FS00:0xa7:    Version: 0.0.18
19:23:00:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:23:00:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
19:23:00:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
19:23:00:WU00:FS00:0xa7:       Time: 01:52:30
19:23:00:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
19:23:00:WU00:FS00:0xa7:************************************ Build *************************************
19:23:00:WU00:FS00:0xa7:       SIMD: avx_256
19:23:00:WU00:FS00:0xa7:********************************************************************************
19:23:00:WU00:FS00:0xa7:Project: 14317 (Run 1, Clone 344, Gen 6)
19:23:00:WU00:FS00:0xa7:Unit: 0x000000090002894b5e63ba63d3d14395
19:23:00:WU00:FS00:0xa7:Reading tar file core.xml
19:23:00:WU00:FS00:0xa7:Reading tar file frame6.tpr
19:23:00:WU00:FS00:0xa7:Digital signatures verified
19:23:00:WU00:FS00:0xa7:Calling: mdrun -s frame6.tpr -o frame6.trr -cpt 15 -nt 4
19:23:00:WU00:FS00:0xa7:Steps: first=3000000 total=500000
19:23:00:WU00:FS00:0xa7:Completed 1 out of 500000 steps (0%)
19:23:06:WU01:FS00:Upload 11.86%
19:23:15:WU01:FS00:Upload 18.97%
19:23:23:WU01:FS00:Upload 23.72%
19:23:32:WU01:FS00:Upload 28.46%
19:23:38:WU01:FS00:Upload 33.20%
19:23:44:WU01:FS00:Upload 40.32%
19:23:51:WU01:FS00:Upload 49.81%
19:23:57:WU01:FS00:Upload 56.92%
19:24:04:WU01:FS00:Upload 66.41%
19:24:11:WU01:FS00:Upload 75.89%
19:24:17:WU01:FS00:Upload 85.38%
19:24:23:WU01:FS00:Upload 94.87%
19:24:27:WU01:FS00:Upload complete
19:24:27:WU01:FS00:Server responded WORK_ACK (400)
19:24:27:WU01:FS00:Final credit estimate, 1407.00 points
19:24:27:WU01:FS00:Cleaning up
19:24:50:WU00:FS00:0xa7:Completed 5000 out of 500000 steps (1%)
22:41:10:WU00:FS00:0xa7:Completed 495000 out of 500000 steps (99%)
09:58:15:WU00:FS00:0xa7:Completed 15000 out of 500000 steps (3%)
09:59:37:WU00:FS00:0xa7:Completed 20000 out of 500000 steps (4%)
10:01:01:WU00:FS00:0xa7:Completed 25000 out of 500000 steps (5%)
10:02:23:WU00:FS00:0xa7:Completed 30000 out of 500000 steps (6%)
10:03:44:WU00:FS00:0xa7:Completed 35000 out of 500000 steps (7%)
10:05:05:WU00:FS00:0xa7:Completed 40000 out of 500000 steps (8%)
10:06:26:WU00:FS00:0xa7:Completed 45000 out of 500000 steps (9%)
10:07:48:WU00:FS00:0xa7:Completed 50000 out of 500000 steps (10%)
10:09:09:WU00:FS00:0xa7:Completed 55000 out of 500000 steps (11%)
10:10:31:WU00:FS00:0xa7:Completed 60000 out of 500000 steps (12%)
10:11:53:WU00:FS00:0xa7:Completed 65000 out of 500000 steps (13%)
10:13:14:WU00:FS00:0xa7:Completed 70000 out of 500000 steps (14%)
10:14:35:WU00:FS00:0xa7:Completed 75000 out of 500000 steps (15%)
10:15:56:WU00:FS00:0xa7:Completed 80000 out of 500000 steps (16%)
10:17:17:WU00:FS00:0xa7:Completed 85000 out of 500000 steps (17%)
10:18:39:WU00:FS00:0xa7:Completed 90000 out of 500000 steps (18%)
10:20:00:WU00:FS00:0xa7:Completed 95000 out of 500000 steps (19%)
10:21:22:WU00:FS00:0xa7:Completed 100000 out of 500000 steps (20%)
10:22:43:WU00:FS00:0xa7:Completed 105000 out of 500000 steps (21%)
10:24:03:WU00:FS00:0xa7:Completed 110000 out of 500000 steps (22%)
10:25:25:WU00:FS00:0xa7:Completed 115000 out of 500000 steps (23%)
10:26:47:WU00:FS00:0xa7:Completed 120000 out of 500000 steps (24%)
10:28:07:WU00:FS00:0xa7:Completed 125000 out of 500000 steps (25%)
10:29:28:WU00:FS00:0xa7:Completed 130000 out of 500000 steps (26%)
10:30:53:WU00:FS00:0xa7:Completed 135000 out of 500000 steps (27%)
10:32:15:WU00:FS00:0xa7:Completed 140000 out of 500000 steps (28%)
10:33:37:WU00:FS00:0xa7:Completed 145000 out of 500000 steps (29%)
10:34:58:WU00:FS00:0xa7:Completed 150000 out of 500000 steps (30%)
10:36:20:WU00:FS00:0xa7:Completed 155000 out of 500000 steps (31%)
10:37:41:WU00:FS00:0xa7:Completed 160000 out of 500000 steps (32%)
10:39:02:WU00:FS00:0xa7:Completed 165000 out of 500000 steps (33%)
10:40:23:WU00:FS00:0xa7:Completed 170000 out of 500000 steps (34%)
10:41:44:WU00:FS00:0xa7:Completed 175000 out of 500000 steps (35%)
10:43:05:WU00:FS00:0xa7:Completed 180000 out of 500000 steps (36%)
10:44:30:WU00:FS00:0xa7:Completed 185000 out of 500000 steps (37%)
10:45:53:WU00:FS00:0xa7:Completed 190000 out of 500000 steps (38%)
10:47:15:WU00:FS00:0xa7:Completed 195000 out of 500000 steps (39%)
10:48:36:WU00:FS00:0xa7:Completed 200000 out of 500000 steps (40%)
10:49:58:WU00:FS00:0xa7:Completed 205000 out of 500000 steps (41%)
10:51:21:WU00:FS00:0xa7:Completed 210000 out of 500000 steps (42%)
10:52:41:WU00:FS00:0xa7:Completed 215000 out of 500000 steps (43%)
10:54:07:WU00:FS00:0xa7:Completed 220000 out of 500000 steps (44%)
10:55:32:WU00:FS00:0xa7:Completed 225000 out of 500000 steps (45%)
10:56:53:WU00:FS00:0xa7:Completed 230000 out of 500000 steps (46%)
10:58:15:WU00:FS00:0xa7:Completed 235000 out of 500000 steps (47%)
10:59:37:WU00:FS00:0xa7:Completed 240000 out of 500000 steps (48%)
11:00:57:WU00:FS00:0xa7:Completed 245000 out of 500000 steps (49%)
11:02:19:WU00:FS00:0xa7:Completed 250000 out of 500000 steps (50%)
11:03:40:WU00:FS00:0xa7:Completed 255000 out of 500000 steps (51%)
11:05:12:WU00:FS00:0xa7:Completed 260000 out of 500000 steps (52%)
11:06:38:WU00:FS00:0xa7:Completed 265000 out of 500000 steps (53%)
11:08:16:WU00:FS00:0xa7:Completed 270000 out of 500000 steps (54%)
11:09:49:WU00:FS00:0xa7:Completed 275000 out of 500000 steps (55%)
11:11:23:WU00:FS00:0xa7:Completed 280000 out of 500000 steps (56%)
11:12:51:WU00:FS00:0xa7:Completed 285000 out of 500000 steps (57%)
11:14:16:WU00:FS00:0xa7:Completed 290000 out of 500000 steps (58%)
11:15:40:WU00:FS00:0xa7:Completed 295000 out of 500000 steps (59%)
11:17:06:WU00:FS00:0xa7:Completed 300000 out of 500000 steps (60%)
11:18:30:WU00:FS00:0xa7:Completed 305000 out of 500000 steps (61%)
11:19:54:WU00:FS00:0xa7:Completed 310000 out of 500000 steps (62%)
11:21:19:WU00:FS00:0xa7:Completed 315000 out of 500000 steps (63%)
11:22:44:WU00:FS00:0xa7:Completed 320000 out of 500000 steps (64%)
11:24:10:WU00:FS00:0xa7:Completed 325000 out of 500000 steps (65%)
11:25:35:WU00:FS00:0xa7:Completed 330000 out of 500000 steps (66%)
11:27:03:WU00:FS00:0xa7:Completed 335000 out of 500000 steps (67%)
11:28:28:WU00:FS00:0xa7:Completed 340000 out of 500000 steps (68%)
11:29:54:WU00:FS00:0xa7:Completed 345000 out of 500000 steps (69%)
11:31:23:WU00:FS00:0xa7:Completed 350000 out of 500000 steps (70%)
11:32:53:WU00:FS00:0xa7:Completed 355000 out of 500000 steps (71%)
11:34:30:WU00:FS00:0xa7:Completed 360000 out of 500000 steps (72%)
11:36:01:WU00:FS00:0xa7:Completed 365000 out of 500000 steps (73%)
11:37:30:WU00:FS00:0xa7:Completed 370000 out of 500000 steps (74%)
11:39:02:WU00:FS00:0xa7:Completed 375000 out of 500000 steps (75%)
11:40:41:WU00:FS00:0xa7:Completed 380000 out of 500000 steps (76%)
11:42:22:WU00:FS00:0xa7:Completed 385000 out of 500000 steps (77%)
11:44:01:WU00:FS00:0xa7:Completed 390000 out of 500000 steps (78%)
11:45:32:WU00:FS00:0xa7:Completed 395000 out of 500000 steps (79%)
11:47:07:WU00:FS00:0xa7:Completed 400000 out of 500000 steps (80%)
11:48:41:WU00:FS00:0xa7:Completed 405000 out of 500000 steps (81%)
11:50:15:WU00:FS00:0xa7:Completed 410000 out of 500000 steps (82%)
11:51:44:WU00:FS00:0xa7:Completed 415000 out of 500000 steps (83%)
11:53:14:WU00:FS00:0xa7:Completed 420000 out of 500000 steps (84%)
11:54:50:WU00:FS00:0xa7:Completed 425000 out of 500000 steps (85%)
11:56:25:WU00:FS00:0xa7:Completed 430000 out of 500000 steps (86%)
11:57:52:WU00:FS00:0xa7:Completed 435000 out of 500000 steps (87%)
11:59:18:WU00:FS00:0xa7:Completed 440000 out of 500000 steps (88%)
12:00:48:WU00:FS00:0xa7:Completed 445000 out of 500000 steps (89%)
12:02:16:WU00:FS00:0xa7:Completed 450000 out of 500000 steps (90%)
12:03:41:WU00:FS00:0xa7:Completed 455000 out of 500000 steps (91%)
12:05:03:WU00:FS00:0xa7:Completed 460000 out of 500000 steps (92%)
12:06:26:WU00:FS00:0xa7:Completed 465000 out of 500000 steps (93%)
12:07:50:WU00:FS00:0xa7:Completed 470000 out of 500000 steps (94%)
12:09:20:WU00:FS00:0xa7:Completed 475000 out of 500000 steps (95%)
12:10:42:WU00:FS00:0xa7:Completed 480000 out of 500000 steps (96%)
12:12:06:WU00:FS00:0xa7:Completed 485000 out of 500000 steps (97%)
12:13:32:WU00:FS00:0xa7:Completed 490000 out of 500000 steps (98%)
12:16:21:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14197 run:1 clone:763 gen:0 core:0xa7 unit:0x000000009bf7a4d55e66d1e5d3009574
12:22:20:WU00:FS00:Upload complete
12:22:20:WU00:FS00:Server responded WORK_QUIT (404)
12:22:20:WARNING:WU00:FS00:Server did not like results, dumping
12:22:20:WU00:FS00:Cleaning up
12:25:02:WU01:FS00:0xa7:Completed 30000 out of 500000 steps (6%)
12:26:26:WU01:FS00:0xa7:Completed 35000 out of 500000 steps (7%)
12:27:47:WU01:FS00:0xa7:Completed 40000 out of 500000 steps (8%)
12:29:09:WU01:FS00:0xa7:Completed 45000 out of 500000 steps (9%)
12:30:31:WU01:FS00:0xa7:Completed 50000 out of 500000 steps (10%)
12:31:53:WU01:FS00:0xa7:Completed 55000 out of 500000 steps (11%)
12:33:22:WU01:FS00:0xa7:Completed 60000 out of 500000 steps (12%)
12:34:49:WU01:FS00:0xa7:Completed 65000 out of 500000 steps (13%)
12:36:18:WU01:FS00:0xa7:Completed 70000 out of 500000 steps (14%)
12:37:53:WU01:FS00:0xa7:Completed 75000 out of 500000 steps (15%)
12:39:27:WU01:FS00:0xa7:Completed 80000 out of 500000 steps (16%)
12:41:02:WU01:FS00:0xa7:Completed 85000 out of 500000 steps (17%)
12:42:31:WU01:FS00:0xa7:Completed 90000 out of 500000 steps (18%)
12:44:04:WU01:FS00:0xa7:Completed 95000 out of 500000 steps (19%)
12:45:34:WU01:FS00:0xa7:Completed 100000 out of 500000 steps (20%)
12:47:05:WU01:FS00:0xa7:Completed 105000 out of 500000 steps (21%)
12:48:41:WU01:FS00:0xa7:Completed 110000 out of 500000 steps (22%)
12:50:16:WU01:FS00:0xa7:Completed 115000 out of 500000 steps (23%)
12:51:45:WU01:FS00:0xa7:Completed 120000 out of 500000 steps (24%)
12:53:13:WU01:FS00:0xa7:Completed 125000 out of 500000 steps (25%)
12:54:41:WU01:FS00:0xa7:Completed 130000 out of 500000 steps (26%)
12:56:17:WU01:FS00:0xa7:Completed 135000 out of 500000 steps (27%)
12:57:50:WU01:FS00:0xa7:Completed 140000 out of 500000 steps (28%)
12:59:22:WU01:FS00:0xa7:Completed 145000 out of 500000 steps (29%)
13:00:54:WU01:FS00:0xa7:Completed 150000 out of 500000 steps (30%)
13:02:33:WU01:FS00:0xa7:Completed 155000 out of 500000 steps (31%)
13:04:03:WU01:FS00:0xa7:Completed 160000 out of 500000 steps (32%)
13:05:32:WU01:FS00:0xa7:Completed 165000 out of 500000 steps (33%)
13:07:03:WU01:FS00:0xa7:Completed 170000 out of 500000 steps (34%)
13:08:34:WU01:FS00:0xa7:Completed 175000 out of 500000 steps (35%)
13:10:01:WU01:FS00:0xa7:Completed 180000 out of 500000 steps (36%)
13:11:29:WU01:FS00:0xa7:Completed 185000 out of 500000 steps (37%)
13:12:57:WU01:FS00:0xa7:Completed 190000 out of 500000 steps (38%)
13:14:25:WU01:FS00:0xa7:Completed 195000 out of 500000 steps (39%)
13:15:49:WU01:FS00:0xa7:Completed 200000 out of 500000 steps (40%)
13:17:13:WU01:FS00:0xa7:Completed 205000 out of 500000 steps (41%)
13:18:38:WU01:FS00:0xa7:Completed 210000 out of 500000 steps (42%)
13:20:03:WU01:FS00:0xa7:Completed 215000 out of 500000 steps (43%)
13:21:27:WU01:FS00:0xa7:Completed 220000 out of 500000 steps (44%)
13:22:57:WU01:FS00:0xa7:Completed 225000 out of 500000 steps (45%)
13:24:28:WU01:FS00:0xa7:Completed 230000 out of 500000 steps (46%)
13:26:02:WU01:FS00:0xa7:Completed 235000 out of 500000 steps (47%)
13:27:28:WU01:FS00:0xa7:Completed 240000 out of 500000 steps (48%)
13:28:52:WU01:FS00:0xa7:Completed 245000 out of 500000 steps (49%)
13:30:15:WU01:FS00:0xa7:Completed 250000 out of 500000 steps (50%)
13:31:38:WU01:FS00:0xa7:Completed 255000 out of 500000 steps (51%)
13:33:00:WU01:FS00:0xa7:Completed 260000 out of 500000 steps (52%)
13:34:24:WU01:FS00:0xa7:Completed 265000 out of 500000 steps (53%)
13:35:47:WU01:FS00:0xa7:Completed 270000 out of 500000 steps (54%)
13:37:11:WU01:FS00:0xa7:Completed 275000 out of 500000 steps (55%)
13:38:34:WU01:FS00:0xa7:Completed 280000 out of 500000 steps (56%)
13:40:03:WU01:FS00:0xa7:Completed 285000 out of 500000 steps (57%)
13:41:29:WU01:FS00:0xa7:Completed 290000 out of 500000 steps (58%)
13:42:55:WU01:FS00:0xa7:Completed 295000 out of 500000 steps (59%)
13:44:24:WU01:FS00:0xa7:Completed 300000 out of 500000 steps (60%)
13:45:49:WU01:FS00:0xa7:Completed 305000 out of 500000 steps (61%)
13:47:26:WU01:FS00:0xa7:Completed 310000 out of 500000 steps (62%)
13:49:18:WU01:FS00:0xa7:Completed 315000 out of 500000 steps (63%)
13:50:56:WU01:FS00:0xa7:Completed 320000 out of 500000 steps (64%)
13:52:31:WU01:FS00:0xa7:Completed 325000 out of 500000 steps (65%)
13:54:05:WU01:FS00:0xa7:Completed 330000 out of 500000 steps (66%)
13:55:31:WU01:FS00:0xa7:Completed 335000 out of 500000 steps (67%)
13:56:55:WU01:FS00:0xa7:Completed 340000 out of 500000 steps (68%)
13:58:18:WU01:FS00:0xa7:Completed 345000 out of 500000 steps (69%)
13:59:43:WU01:FS00:0xa7:Completed 350000 out of 500000 steps (70%)
14:01:07:WU01:FS00:0xa7:Completed 355000 out of 500000 steps (71%)
14:02:30:WU01:FS00:0xa7:Completed 360000 out of 500000 steps (72%)
14:03:53:WU01:FS00:0xa7:Completed 365000 out of 500000 steps (73%)
14:05:16:WU01:FS00:0xa7:Completed 370000 out of 500000 steps (74%)
14:06:39:WU01:FS00:0xa7:Completed 375000 out of 500000 steps (75%)
14:08:02:WU01:FS00:0xa7:Completed 380000 out of 500000 steps (76%)
14:09:26:WU01:FS00:0xa7:Completed 385000 out of 500000 steps (77%)
14:10:48:WU01:FS00:0xa7:Completed 390000 out of 500000 steps (78%)
14:12:10:WU01:FS00:0xa7:Completed 395000 out of 500000 steps (79%)
14:13:32:WU01:FS00:0xa7:Completed 400000 out of 500000 steps (80%)
14:14:55:WU01:FS00:0xa7:Completed 405000 out of 500000 steps (81%)
14:16:18:WU01:FS00:0xa7:Completed 410000 out of 500000 steps (82%)
14:17:40:WU01:FS00:0xa7:Completed 415000 out of 500000 steps (83%)
14:19:02:WU01:FS00:0xa7:Completed 420000 out of 500000 steps (84%)
14:20:23:WU01:FS00:0xa7:Completed 425000 out of 500000 steps (85%)
14:21:45:WU01:FS00:0xa7:Completed 430000 out of 500000 steps (86%)
14:23:08:WU01:FS00:0xa7:Completed 435000 out of 500000 steps (87%)
14:24:30:WU01:FS00:0xa7:Completed 440000 out of 500000 steps (88%)
14:25:59:WU01:FS00:0xa7:Completed 445000 out of 500000 steps (89%)
14:27:21:WU01:FS00:0xa7:Completed 450000 out of 500000 steps (90%)
14:28:42:WU01:FS00:0xa7:Completed 455000 out of 500000 steps (91%)
14:30:04:WU01:FS00:0xa7:Completed 460000 out of 500000 steps (92%)
14:31:26:WU01:FS00:0xa7:Completed 465000 out of 500000 steps (93%)
14:32:47:WU01:FS00:0xa7:Completed 470000 out of 500000 steps (94%)
14:34:15:WU01:FS00:0xa7:Completed 475000 out of 500000 steps (95%)
14:35:42:WU01:FS00:0xa7:Completed 480000 out of 500000 steps (96%)
14:37:05:WU01:FS00:0xa7:Completed 485000 out of 500000 steps (97%)
14:38:29:WU01:FS00:0xa7:Completed 490000 out of 500000 steps (98%)
17:01:43:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14197 run:3 clone:790 gen:3 core:0xa7 unit:0x000000039bf7a4d55e66d1850b1864e9
tug27224
Scientist
Re: 14197 (3, 790, 3) & (1, 763, 0) - Server responded WORK_
Post by tug27224 »
Thanks for reporting these. Just saw the increased error rates on this projects. Looking into it now.
I've paused this project for now while I investigate. Let me know if you see this error on any others in the mean time.
TheRolf
Post by TheRolf »
I also had this error for 11759 (0, 12538, 31). It's a bit disappointing as I left my laptop running during the night for a few days in order to finish in time :)
Should I paste the logs here in order to report it?
tessa
Post by tessa »
Same error here,for project 11749.
WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:11749 run:0 clone:3377 gen:18 core:0x22 unit:0x000000248ca304e75e6a800e5d75001f
09:43:57:WU02:FS01:Uploading 12.56MiB to 140.163.4.231
09:43:57:WU02:FS01:Connecting to 140.163.4.231:8080
09:44:40:WU00:FS01:Connecting to 65.254.110.245:8080
09:44:40:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
09:44:40:WU00:FS01:Connecting to 18.218.241.186:80
09:44:41:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
09:44:41:ERROR:WU00:FS01:Exception: Could not get an assignment
09:44:55:WU02:FS01:Upload 0.99%
09:45:01:WU02:FS01:Upload 22.38%
09:45:07:WU02:FS01:Upload 47.75%
09:45:13:WU02:FS01:Upload 62.18%
09:45:19:WU02:FS01:Upload 95.50%
09:45:19:WU01:FS00:0xa7:Completed 175000 out of 250000 steps (70%)
09:45:20:WU02:FS01:Upload complete
09:45:20:WU02:FS01:Server responded WORK_QUIT (404)
09:45:20:WARNING:WU02:FS01:Server did not like results, dumping
DmitryKo
Post by DmitryKo »
Same issue here, project 11751:
15:28:49:WU00:FS01:0x22:Completed 1000000 out of 1000000 steps (100%)
15:28:53:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
15:28:53:WU00:FS01:0x22:Saving result file checkpointState.xml
15:28:56:WU00:FS01:0x22:Saving result file checkpt.crc
15:28:56:WU00:FS01:0x22:Saving result file positions.xtc
15:28:58:WU00:FS01:0x22:Saving result file science.log
15:28:58:WU00:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
15:28:59:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
15:28:59:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:11751 run:0 clone:10150 gen:7 core:0x22 unit:0x0000000c8ca304e75e6d6fe8387e7726
15:28:59:WU00:FS01:Uploading 14.66MiB to 140.163.4.231
15:30:44:WU00:FS01:Upload complete
15:30:44:WU00:FS01:Server responded WORK_QUIT (404)
15:30:44:WARNING:WU00:FS01:Server did not like results, dumping
15:30:44:WU00:FS01:Cleaning up
Complete log:
*********************** Log Started 2020-04-26T08:12:17Z ***********************
08:12:31:FS01:Unpaused
08:12:32:WU00:FS01:Connecting to 65.254.110.245:80
08:12:32:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
08:12:32:WU00:FS01:Connecting to 18.218.241.186:80
08:12:35:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
08:12:35:WU00:FS01:Connecting to 65.254.110.245:80
08:12:37:WU00:FS01:Assigned to work server 140.163.4.231
08:12:37:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Baffin [Polaris11] from 140.163.4.231
08:12:37:WU00:FS01:Connecting to 140.163.4.231:8080
08:17:52:WU00:FS01:Downloading 7.93MiB
08:17:58:WU00:FS01:Download 19.71%
08:18:04:WU00:FS01:Download 78.05%
08:18:05:WU00:FS01:Download complete
08:18:05:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11751 run:0 clone:10150 gen:7 core:0x22 unit:0x0000000c8ca304e75e6d6fe8387e7726
08:18:05:WU00:FS01:Starting
08:18:05:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Dmitry\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 25380 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
08:18:05:WU00:FS01:Started FahCore on PID 25492
08:18:05:WU00:FS01:Core PID:3084
08:18:05:WU00:FS01:FahCore 0x22 started
08:18:06:WU00:FS01:0x22:*********************** Log Started 2020-04-26T08:18:05Z ***********************
08:18:06:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
08:18:06:WU00:FS01:0x22:       Type: 0x22
08:18:06:WU00:FS01:0x22:       Core: Core22
08:18:06:WU00:FS01:0x22:    Website: https://foldingathome.org/
08:18:06:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
08:18:06:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
08:18:06:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
08:18:06:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 25492 -checkpoint 15
08:18:06:WU00:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
08:18:06:WU00:FS01:0x22:     Config: <none>
08:18:06:WU00:FS01:0x22:************************************ Build *************************************
08:18:06:WU00:FS01:0x22:    Version: 0.0.2
08:18:06:WU00:FS01:0x22:       Date: Dec 6 2019
08:18:06:WU00:FS01:0x22:       Time: 21:30:31
08:18:06:WU00:FS01:0x22: Repository: Git
08:18:06:WU00:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
08:18:06:WU00:FS01:0x22:     Branch: HEAD
08:18:06:WU00:FS01:0x22:   Compiler: Visual C++ 2008
08:18:06:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
08:18:06:WU00:FS01:0x22:   Platform: win32 10
08:18:06:WU00:FS01:0x22:       Bits: 64
08:18:06:WU00:FS01:0x22:       Mode: Release
08:18:06:WU00:FS01:0x22:************************************ System ************************************
08:18:06:WU00:FS01:0x22:        CPU: AMD Ryzen 5 3600 6-Core Processor
08:18:06:WU00:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
08:18:06:WU00:FS01:0x22:       CPUs: 12
08:18:06:WU00:FS01:0x22:     Memory: 31.93GiB
08:18:06:WU00:FS01:0x22:Free Memory: 22.19GiB
08:18:06:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
08:18:06:WU00:FS01:0x22: OS Version: 6.2
08:18:06:WU00:FS01:0x22:Has Battery: false
08:18:06:WU00:FS01:0x22: On Battery: false
08:18:06:WU00:FS01:0x22: UTC Offset: 3
08:18:06:WU00:FS01:0x22:        PID: 3084
08:18:06:WU00:FS01:0x22:        CWD: C:\Users\Dmitry\AppData\Roaming\FAHClient\work
08:18:06:WU00:FS01:0x22:         OS: Windows 10 Home
08:18:06:WU00:FS01:0x22:    OS Arch: AMD64
08:18:06:WU00:FS01:0x22:********************************************************************************
08:18:06:WU00:FS01:0x22:Project: 11751 (Run 0, Clone 10150, Gen 7)
08:18:06:WU00:FS01:0x22:Unit: 0x0000000c8ca304e75e6d6fe8387e7726
08:18:06:WU00:FS01:0x22:Reading tar file core.xml
08:18:06:WU00:FS01:0x22:Reading tar file integrator.xml
08:18:06:WU00:FS01:0x22:Reading tar file state.xml
08:18:07:WU00:FS01:0x22:Reading tar file system.xml
08:18:08:WU00:FS01:0x22:Digital signatures verified
08:18:08:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
08:18:08:WU00:FS01:0x22:Version 0.0.2
08:18:27:WU00:FS01:0x22:Completed 0 out of 1000000 steps (0%)
08:18:27:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
08:22:45:WU00:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
08:27:05:WU00:FS01:0x22:Completed 20000 out of 1000000 steps (2%)
08:31:33:WU00:FS01:0x22:Completed 30000 out of 1000000 steps (3%)
08:35:52:WU00:FS01:0x22:Completed 40000 out of 1000000 steps (4%)
08:40:11:WU00:FS01:0x22:Completed 50000 out of 1000000 steps (5%)
08:44:34:WU00:FS01:0x22:Completed 60000 out of 1000000 steps (6%)
08:48:51:WU00:FS01:0x22:Completed 70000 out of 1000000 steps (7%)
08:53:12:WU00:FS01:0x22:Completed 80000 out of 1000000 steps (8%)
08:57:35:WU00:FS01:0x22:Completed 90000 out of 1000000 steps (9%)
09:02:07:WU00:FS01:0x22:Completed 100000 out of 1000000 steps (10%)
09:06:58:WU00:FS01:0x22:Completed 110000 out of 1000000 steps (11%)
09:11:27:WU00:FS01:0x22:Completed 120000 out of 1000000 steps (12%)
09:15:49:WU00:FS01:0x22:Completed 130000 out of 1000000 steps (13%)
09:20:08:WU00:FS01:0x22:Completed 140000 out of 1000000 steps (14%)
09:24:29:WU00:FS01:0x22:Completed 150000 out of 1000000 steps (15%)
09:28:55:WU00:FS01:0x22:Completed 160000 out of 1000000 steps (16%)
09:33:16:WU00:FS01:0x22:Completed 170000 out of 1000000 steps (17%)
09:37:38:WU00:FS01:0x22:Completed 180000 out of 1000000 steps (18%)
09:41:58:WU00:FS01:0x22:Completed 190000 out of 1000000 steps (19%)
09:46:17:WU00:FS01:0x22:Completed 200000 out of 1000000 steps (20%)
09:50:38:WU00:FS01:0x22:Completed 210000 out of 1000000 steps (21%)
09:54:57:WU00:FS01:0x22:Completed 220000 out of 1000000 steps (22%)
09:59:18:WU00:FS01:0x22:Completed 230000 out of 1000000 steps (23%)
10:03:37:WU00:FS01:0x22:Completed 240000 out of 1000000 steps (24%)
10:08:05:WU00:FS01:0x22:Completed 250000 out of 1000000 steps (25%)
10:12:41:WU00:FS01:0x22:Completed 260000 out of 1000000 steps (26%)
10:17:12:WU00:FS01:0x22:Completed 270000 out of 1000000 steps (27%)
10:21:40:WU00:FS01:0x22:Completed 280000 out of 1000000 steps (28%)
10:25:56:WU00:FS01:0x22:Completed 290000 out of 1000000 steps (29%)
10:30:12:WU00:FS01:0x22:Completed 300000 out of 1000000 steps (30%)
10:34:32:WU00:FS01:0x22:Completed 310000 out of 1000000 steps (31%)
10:38:48:WU00:FS01:0x22:Completed 320000 out of 1000000 steps (32%)
10:43:06:WU00:FS01:0x22:Completed 330000 out of 1000000 steps (33%)
10:47:22:WU00:FS01:0x22:Completed 340000 out of 1000000 steps (34%)
10:51:38:WU00:FS01:0x22:Completed 350000 out of 1000000 steps (35%)
10:55:58:WU00:FS01:0x22:Completed 360000 out of 1000000 steps (36%)
11:00:14:WU00:FS01:0x22:Completed 370000 out of 1000000 steps (37%)
11:04:29:WU00:FS01:0x22:Completed 380000 out of 1000000 steps (38%)
11:08:45:WU00:FS01:0x22:Completed 390000 out of 1000000 steps (39%)
11:13:03:WU00:FS01:0x22:Completed 400000 out of 1000000 steps (40%)
11:17:32:WU00:FS01:0x22:Completed 410000 out of 1000000 steps (41%)
11:21:47:WU00:FS01:0x22:Completed 420000 out of 1000000 steps (42%)
11:26:02:WU00:FS01:0x22:Completed 430000 out of 1000000 steps (43%)
11:30:18:WU00:FS01:0x22:Completed 440000 out of 1000000 steps (44%)
11:34:34:WU00:FS01:0x22:Completed 450000 out of 1000000 steps (45%)
11:38:54:WU00:FS01:0x22:Completed 460000 out of 1000000 steps (46%)
11:43:09:WU00:FS01:0x22:Completed 470000 out of 1000000 steps (47%)
11:47:26:WU00:FS01:0x22:Completed 480000 out of 1000000 steps (48%)
11:51:42:WU00:FS01:0x22:Completed 490000 out of 1000000 steps (49%)
11:55:56:WU00:FS01:0x22:Completed 500000 out of 1000000 steps (50%)
12:00:12:WU00:FS01:0x22:Completed 510000 out of 1000000 steps (51%)
12:04:26:WU00:FS01:0x22:Completed 520000 out of 1000000 steps (52%)
12:08:39:WU00:FS01:0x22:Completed 530000 out of 1000000 steps (53%)
12:12:52:WU00:FS01:0x22:Completed 540000 out of 1000000 steps (54%)
12:17:05:WU00:FS01:0x22:Completed 550000 out of 1000000 steps (55%)
12:21:22:WU00:FS01:0x22:Completed 560000 out of 1000000 steps (56%)
12:25:34:WU00:FS01:0x22:Completed 570000 out of 1000000 steps (57%)
12:29:43:WU00:FS01:0x22:Completed 580000 out of 1000000 steps (58%)
12:33:53:WU00:FS01:0x22:Completed 590000 out of 1000000 steps (59%)
12:38:02:WU00:FS01:0x22:Completed 600000 out of 1000000 steps (60%)
12:42:16:WU00:FS01:0x22:Completed 610000 out of 1000000 steps (61%)
12:46:26:WU00:FS01:0x22:Completed 620000 out of 1000000 steps (62%)
12:50:35:WU00:FS01:0x22:Completed 630000 out of 1000000 steps (63%)
12:54:44:WU00:FS01:0x22:Completed 640000 out of 1000000 steps (64%)
12:58:53:WU00:FS01:0x22:Completed 650000 out of 1000000 steps (65%)
13:03:05:WU00:FS01:0x22:Completed 660000 out of 1000000 steps (66%)
13:07:17:WU00:FS01:0x22:Completed 670000 out of 1000000 steps (67%)
13:11:33:WU00:FS01:0x22:Completed 680000 out of 1000000 steps (68%)
13:15:55:WU00:FS01:0x22:Completed 690000 out of 1000000 steps (69%)
13:20:11:WU00:FS01:0x22:Completed 700000 out of 1000000 steps (70%)
13:24:29:WU00:FS01:0x22:Completed 710000 out of 1000000 steps (71%)
13:28:46:WU00:FS01:0x22:Completed 720000 out of 1000000 steps (72%)
13:33:05:WU00:FS01:0x22:Completed 730000 out of 1000000 steps (73%)
13:37:27:WU00:FS01:0x22:Completed 740000 out of 1000000 steps (74%)
13:41:44:WU00:FS01:0x22:Completed 750000 out of 1000000 steps (75%)
13:46:03:WU00:FS01:0x22:Completed 760000 out of 1000000 steps (76%)
13:50:18:WU00:FS01:0x22:Completed 770000 out of 1000000 steps (77%)
13:54:32:WU00:FS01:0x22:Completed 780000 out of 1000000 steps (78%)
13:58:51:WU00:FS01:0x22:Completed 790000 out of 1000000 steps (79%)
14:03:09:WU00:FS01:0x22:Completed 800000 out of 1000000 steps (80%)
14:07:35:WU00:FS01:0x22:Completed 810000 out of 1000000 steps (81%)
14:11:58:WU00:FS01:0x22:Completed 820000 out of 1000000 steps (82%)
******************************* Date: 2020-04-26 *******************************
14:16:14:WU00:FS01:0x22:Completed 830000 out of 1000000 steps (83%)
14:20:31:WU00:FS01:0x22:Completed 840000 out of 1000000 steps (84%)
14:24:48:WU00:FS01:0x22:Completed 850000 out of 1000000 steps (85%)
14:29:07:WU00:FS01:0x22:Completed 860000 out of 1000000 steps (86%)
14:33:21:WU00:FS01:0x22:Completed 870000 out of 1000000 steps (87%)
14:37:33:WU00:FS01:0x22:Completed 880000 out of 1000000 steps (88%)
14:41:47:WU00:FS01:0x22:Completed 890000 out of 1000000 steps (89%)
14:46:00:WU00:FS01:0x22:Completed 900000 out of 1000000 steps (90%)
14:50:18:WU00:FS01:0x22:Completed 910000 out of 1000000 steps (91%)
14:54:33:WU00:FS01:0x22:Completed 920000 out of 1000000 steps (92%)
14:58:48:WU00:FS01:0x22:Completed 930000 out of 1000000 steps (93%)
15:03:08:WU00:FS01:0x22:Completed 940000 out of 1000000 steps (94%)
15:07:24:WU00:FS01:0x22:Completed 950000 out of 1000000 steps (95%)
15:11:41:WU00:FS01:0x22:Completed 960000 out of 1000000 steps (96%)
15:15:59:WU00:FS01:0x22:Completed 970000 out of 1000000 steps (97%)
15:20:17:WU00:FS01:0x22:Completed 980000 out of 1000000 steps (98%)
15:24:34:WU00:FS01:0x22:Completed 990000 out of 1000000 steps (99%)
15:24:35:WU01:FS01:Connecting to 65.254.110.245:80
15:24:36:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
15:24:36:WU01:FS01:Connecting to 18.218.241.186:80
15:24:36:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:24:36:WU01:FS01:Connecting to 65.254.110.245:80
15:24:37:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
15:24:37:WU01:FS01:Connecting to 18.218.241.186:80
15:24:37:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:24:37:ERROR:WU01:FS01:Exception: Could not get an assignment
15:24:37:WU01:FS01:Connecting to 65.254.110.245:80
15:24:38:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
15:24:38:WU01:FS01:Connecting to 18.218.241.186:80
15:24:38:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:24:38:WU01:FS01:Connecting to 65.254.110.245:80
15:24:39:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
15:24:39:WU01:FS01:Connecting to 18.218.241.186:80
15:24:39:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:24:39:ERROR:WU01:FS01:Exception: Could not get an assignment
15:25:37:WU01:FS01:Connecting to 65.254.110.245:80
15:25:38:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
15:25:38:WU01:FS01:Connecting to 18.218.241.186:80
15:25:39:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:25:39:WU01:FS01:Connecting to 65.254.110.245:80
15:25:39:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
15:25:39:WU01:FS01:Connecting to 18.218.241.186:80
15:25:40:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:25:40:ERROR:WU01:FS01:Exception: Could not get an assignment
15:27:15:WU01:FS01:Connecting to 65.254.110.245:80
15:27:16:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
15:27:16:WU01:FS01:Connecting to 18.218.241.186:80
15:27:16:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:27:16:WU01:FS01:Connecting to 65.254.110.245:80
15:27:17:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
15:27:17:WU01:FS01:Connecting to 18.218.241.186:80
15:27:17:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:27:17:ERROR:WU01:FS01:Exception: Could not get an assignment
15:28:59:WU00:FS01:Connecting to 140.163.4.231:8080
15:29:52:WU01:FS01:Connecting to 65.254.110.245:80
15:29:53:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
15:29:53:WU01:FS01:Connecting to 18.218.241.186:80
15:29:53:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:29:53:WU01:FS01:Connecting to 65.254.110.245:80
15:29:54:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
15:29:54:WU01:FS01:Connecting to 18.218.241.186:80
15:29:54:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:29:54:ERROR:WU01:FS01:Exception: Could not get an assignment
15:30:00:WU00:FS01:Upload 1.28%
15:30:06:WU00:FS01:Upload 8.10%
15:30:12:WU00:FS01:Upload 17.48%
15:30:18:WU00:FS01:Upload 34.96%
15:30:24:WU00:FS01:Upload 48.18%
15:30:30:WU00:FS01:Upload 65.23%
15:30:36:WU00:FS01:Upload 83.14%
15:30:42:WU00:FS01:Upload 100.00%
15:34:06:WU01:FS01:Connecting to 65.254.110.245:80
15:34:07:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
15:34:07:WU01:FS01:Connecting to 18.218.241.186:80
15:34:08:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:34:08:WU01:FS01:Connecting to 65.254.110.245:80
15:34:08:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
15:34:08:WU01:FS01:Connecting to 18.218.241.186:80
15:34:09:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:34:09:ERROR:WU01:FS01:Exception: Could not get an assignment
15:40:58:WU01:FS01:Connecting to 65.254.110.245:80
15:40:59:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
15:40:59:WU01:FS01:Connecting to 18.218.241.186:80
15:40:59:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:40:59:WU01:FS01:Connecting to 65.254.110.245:80
15:41:00:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
15:41:00:WU01:FS01:Connecting to 18.218.241.186:80
15:41:00:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:41:00:ERROR:WU01:FS01:Exception: Could not get an assignment
15:52:03:WU01:FS01:Connecting to 65.254.110.245:80
15:52:04:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
15:52:04:WU01:FS01:Connecting to 18.218.241.186:80
15:52:05:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:52:05:WU01:FS01:Connecting to 65.254.110.245:80
15:52:05:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
15:52:05:WU01:FS01:Connecting to 18.218.241.186:80
15:52:06:WU01:FS01:Assigned to work server 128.252.203.10
15:52:06:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Baffin [Polaris11] from 128.252.203.10
15:52:06:WU01:FS01:Connecting to 128.252.203.10:8080
15:53:20:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
