Please add Nvidia 1660Ti
ghstridr
Post by ghstridr »
0x8086:0x3e30:Intel Corporation:
0x8086:0x1901:Intel Corporation:
0x8086:0x1905:Intel Corporation:
0x8086:0x3e98:Intel Corporation:
0x8086:0xa379:Intel Corporation:
0x8086:0xa36d:Intel Corporation:
0x8086:0xa36f:Intel Corporation:
0x8086:0xa360:Intel Corporation:
0x8086:0xa352:Intel Corporation:
0x8086:0xa340:Intel Corporation:
0x8086:0xa338:Intel Corporation:
0x8086:0xa339:Intel Corporation:
0x8086:0xa33c:Intel Corporation:
0x8086:0xa330:Intel Corporation:
0x8086:0xa305:Intel Corporation:
0x8086:0xa348:Intel Corporation:
0x8086:0xa323:Intel Corporation:
0x8086:0xa324:Intel Corporation:
0x8086:0x15bc:Intel Corporation:
0x10de:0x2182:NVIDIA Corporation:
0x10de:0x1aeb:NVIDIA Corporation:
0x10de:0x1aec:NVIDIA Corporation:
0x10de:0x1aed:NVIDIA Corporation:
03:52:47:WU00:FS00:0xa7:*********************** Log Started 2020-02-29T03:52:47Z ***********************
03:52:47:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
03:52:47:WU00:FS00:0xa7: Type: 0xa7
03:52:47:WU00:FS00:0xa7: Core: Gromacs
03:52:47:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 704 -lifeline 40 -checkpoint 15 -np 14
03:52:47:WU00:FS00:0xa7:************************************ CBang *************************************
03:52:47:WU00:FS00:0xa7: Date: Nov 5 2019
03:52:47:WU00:FS00:0xa7: Time: 06:06:57
03:52:47:WU00:FS00:0xa7: Revision: 46c96f1aa8419571d83f3e63f9c99a0d602f6da9
03:52:47:WU00:FS00:0xa7: Branch: master
03:52:47:WU00:FS00:0xa7: Compiler: GNU 8.3.0
03:52:47:WU00:FS00:0xa7: Options: -std=c++11 -O3 -funroll-loops -fno-pie -fPIC
03:52:47:WU00:FS00:0xa7: Platform: linux2 4.19.0-5-amd64
03:52:47:WU00:FS00:0xa7: Bits: 64
03:52:47:WU00:FS00:0xa7: Mode: Release
03:52:47:WU00:FS00:0xa7:************************************ System ************************************
03:52:47:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
03:52:47:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
03:52:47:WU00:FS00:0xa7: CPUs: 16
03:52:47:WU00:FS00:0xa7: Memory: 62.84GiB
03:52:47:WU00:FS00:0xa7:Free Memory: 2.81GiB
03:52:47:WU00:FS00:0xa7: Threads: POSIX_THREADS
03:52:47:WU00:FS00:0xa7: OS Version: 4.19
03:52:47:WU00:FS00:0xa7:Has Battery: false
03:52:47:WU00:FS00:0xa7: On Battery: false
03:52:47:WU00:FS00:0xa7: UTC Offset: 0
03:52:47:WU00:FS00:0xa7: PID: 44
03:52:47:WU00:FS00:0xa7: CWD: /config/work
03:52:47:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
03:52:47:WU00:FS00:0xa7: Version: 0.0.18
03:52:47:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:52:47:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
03:52:47:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
03:52:47:WU00:FS00:0xa7: Time: 06:13:26
03:52:47:WU00:FS00:0xa7: Revision: 490c9aa2957b725af319379424d5c5cb36efb656
03:52:47:WU00:FS00:0xa7:************************************ Build *************************************
03:52:47:WU00:FS00:0xa7: SIMD: avx_256
03:52:47:WU00:FS00:0xa7:********************************************************************************
03:52:47:WU00:FS00:0xa7:Project: 13794 (Run 1, Clone 399, Gen 10)
03:52:47:WU00:FS00:0xa7:Unit: 0x0000000d0002894c5dae0b79739b031b
03:52:47:WU00:FS00:0xa7:Digital signatures verified
03:52:47:WU00:FS00:0xa7:Reducing thread count from 14 to 13 to avoid domain decomposition with large prime factor 7
03:52:47:WU00:FS00:0xa7:Reducing thread count from 13 to 12 to avoid domain decomposition by a prime number > 3
03:52:47:WU00:FS00:0xa7:Calling: mdrun -s frame10.tpr -o frame10.trr -cpi state.cpt -cpt 15 -nt 12
03:52:47:WU00:FS00:0xa7:Steps: first=25000000 total=2500000
03:52:47:WU00:FS00:0xa7:Completed 339672 out of 2500000 steps (13%)
03:53:25:WU00:FS00:0xa7:Completed 350000 out of 2500000 steps (14%)
[91m03:53:47:ERROR:WU01:FS01:Exception: Option 'gpu-index' has no default and is not set.[0m
03:54:59:WU00:FS00:0xa7:Completed 375000 out of 2500000 steps (15%)
[91m03:55:24:ERROR:WU01:FS01:Exception: Option 'gpu-index' has no default and is not set.[0m
03:56:31:WU00:FS00:0xa7:Completed 400000 out of 2500000 steps (16%)
[91m03:58:02:ERROR:WU01:FS01:Exception: Option 'gpu-index' has no default and is not set.[0m
03:58:04:WU00:FS00:0xa7:Completed 425000 out of 2500000 steps (17%)
03:59:37:WU00:FS00:0xa7:Completed 450000 out of 2500000 steps (18%)
04:01:10:WU00:FS00:0xa7:Completed 475000 out of 2500000 steps (19%)
[91m04:02:16:ERROR:WU01:FS01:Exception: Option 'gpu-index' has no default and is not set.[0m
04:02:43:WU00:FS00:0xa7:Completed 500000 out of 2500000 steps (20%)
Re: Please add Nvidia 1660Ti
A 1660 Ti is already in the GPUs.txt file:
0x10de:0x2182:2:7:TU116 [GeForce GTX 1660 Ti]
If the card you want added has a different device ID, please follow the directions in this set of posts at the top of this sub-forum - viewtopic.php?f=83&t=26208#p262892 - and post that information.
Also, when posting your log file, the first couple hundred lines are the most important to include. Either refresh the log in FAHControl's log window or go to the log file itself.
Post by foldy »
I guess it is not a GPUs.txt problem but user needs to download and install nvidia driver manually.
