Can i skip my part on a project?
- Hardware configuration: i5-2400 , 1060 6gb, 8GBram
Hi! I am just joined around 5-6 days ago to the folding team. I am new for the deep stuff, but on client level i know how the program (Globally) works. I know the goals, i know my part in it etc.
(Edit 2: after a restart at 5.58% it rolled back to only 5%, sowork as intended, but main questios still stands: can we skip?)
(Edit: after a hard restart [not the first time since i recived this unit] it started working. Previously stuck at 1-2%, now it is 5.58% since the above mentioned restart.)
My actual problem is with the #14182 project part what i recived (CPU), it's behaviour really different than the usual, it is way bigger, and/or the checkpoints (where i start if i have to power off, or pause) has a way bigger absolute gaps.
I ran it on full mode, idle was ticked off (not active), and i saw it would take around a day. OK nvm. I ran it for 2-3 hours, and i was still in the 2-3%. OK i made 5 WUs already, so i thought if i just pause it it will continue from there (somewhere, i have the client set about 15min safepoints). But it did not. It started from 1%.
My issue with this is that i do not know if this project has checkpoints (where the project can reach a point where it can continue), if it can, how far should i run it to reach it (if i need my CPU i usually stop my workings, e.g. my main browser is Firefox, what is still using CPU mainly, so if i experience slowdowns, i usually give it a minute to get its things right...etc), and if i know, can i reach it, by my avarage usage...
My general questions:
Can i check how the actual project is structured? What is the percentage where i can pause the process/ shut down my PC?
If none of it avaible, can i skip projects, if similar things occure?
Also forgot until this point: i had some startups today, and at one, the program's exe was unresponding... i will do a "be sure" startap right after posting this...
Re: Can i skip my part on the a project?
First, the easy part: Firefox is not a problem.
If you are running Windows, are you always starting FAH using the shortcut which was installed when the software was installed ... and did you accept the default installation options?
The following assume you're folding with your CPU; If you're also folding with a GPU, things will be quite different.
Assuming you're folding only with the CPU, by default, checkpoints will be written every 15 minutes.
If your CPU is capable of running with multiple CPU threads, the first WU assigned will typically only use one thread.
When the next WU is assigned, the position of the Power slider will determine how many threads can be used. I recommend that you set it to FULL and leave it there. FAH runs at an extremely low priority, so it shouldn't interfere with other applications you may be running (like FireFox).
If you're also running other Distributed Computing or mining applications, they may be running at a higher priority and they're likely to prevent FAH from getting much work done.
Which .exe program do you mean which was hung and what else was actually consuming CPU resources?
What were the Project, Run, Clone, and Gen numbers (PRCG) of the WU you were assigned.
Most of these questions (and others) would be answered if you posted FAH's log per the instructions below.
After Edit 2 i turned off my system. Today, now, i just started it, and the same error message popped up, like before, now i watched: FAHcore.exe stopped working (the folding clite is set to start with system). After that i checked the system tray, there i saw the little icon, what was still there (similarly like after the first crashy start). And opening advanced view, my CPU work was at 0%, again!
Did a reboot, i did not recived the the error message, but the CPU work was still 0% (remember, it was already saved, at 5%....) so this is my state now....
As a reply at instal i selected the start with system option, but installed it into an other folder than strictly the base, but no other modification. Only things what i changed in the client are the the auto save slider (now on 14 min), the folding power to full, and in the CPU folding slot i selected max thread count, BUT i tried them before, earlier for some works what i ha already done, but did not changed since the last work started (on the CPU).
I only mentioned firefox, because i know if i open e.g. 5-10 youtube tabs (from subscribtion feed) my CPU spikes. And during doing work (folding) i had issues with the youtube video decoding... Skipping back, stopping the video, or work (on this order) always solved that.
No mining on my PC is going on like that. Personal PC.
(Editing logs to paste as next post(s) )
*********************** Log Started 2019-12-07T16:51:30Z ***********************
16:51:30:************************* Folding@home Client *************************
16:51:30: Website: https://foldingathome.org/
16:51:30: Copyright: (c) 2009-2018 foldingathome.org
16:51:30: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:51:30: Args:
16:51:30: Config: C:\Users\LGB2017v2\AppData\Roaming\FAHClient\config.xml
16:51:30:******************************** Build ********************************
16:51:30: Version: 7.5.1
16:51:30: Date: May 11 2018
16:51:30: Time: 13:06:32
16:51:30: Repository: Git
16:51:30: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
16:51:30: Branch: master
16:51:30: Compiler: Visual C++ 2008
16:51:30: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
16:51:30: Platform: win32 10
16:51:30: Bits: 32
16:51:30: Mode: Release
16:51:30:******************************* System ********************************
16:51:30: CPU: Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
16:51:30: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
16:51:30: CPUs: 4
16:51:30: Memory: 7.98GiB
16:51:30: Free Memory: 6.21GiB
16:51:30: Threads: WINDOWS_THREADS
16:51:30: OS Version: 6.1
16:51:30: Has Battery: false
16:51:30: On Battery: false
16:51:30: UTC Offset: 1
16:51:30: PID: 4116
16:51:30: CWD: C:\Users\LGB2017v2\AppData\Roaming\FAHClient
16:51:30: OS: Windows 7 Ultimate
16:51:30: OS Arch: AMD64
16:51:30: GPUs: 1
16:51:30: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 GP106 [GeForce GTX 1060 6GB] 4372
16:51:30: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.2
16:51:30:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:441.20
16:51:30: Win32 Service: false
16:51:30:***********************************************************************
16:51:30:<config>
16:51:30: <!-- Folding Core -->
16:51:30: <checkpoint v='14'/>
16:51:30:
16:51:30: <!-- Network -->
16:51:30: <proxy v=':8080'/>
16:51:30:
16:51:30: <!-- Slot Control -->
16:51:30: <power v='full'/>
16:51:30:
16:51:30: <!-- User Information -->
16:51:30: <team v='235464'/>
16:51:30: <user v='ledgeri#9625'/>
16:51:30:
16:51:30: <!-- Folding Slots -->
16:51:30: <slot id='0' type='CPU'>
16:51:30: <cpus v='4'/>
16:51:30: <paused v='true'/>
16:51:30: </slot>
16:51:30: <slot id='1' type='GPU'>
16:51:30: </slot>
16:51:30:</config>
16:51:30:Trying to access database...
16:51:30:Successfully acquired database lock
16:51:30:Enabled folding slot 00: PAUSED cpu:4 (by user)
16:51:30:Enabled folding slot 01: PAUSED gpu:0:GP106 [GeForce GTX 1060 6GB] 4372 (by user)
16:53:18:FS01:Unpaused
16:53:18:WU00:FS01:Starting
16:53:18:WU00:FS01:Running FahCore: "C:\Program Files (x86)shared power\FAHClient/FAHCoreWrapper.exe" C:\Users\LGB2017v2\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/nvidia/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 705 -lifeline 4116 -checkpoint 14 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
16:53:18:WU00:FS01:Started FahCore on PID 5432
16:53:18:WU00:FS01:Core PID:5384
16:53:18:WU00:FS01:FahCore 0x21 started
16:53:19:WU00:FS01:0x21:*********************** Log Started 2019-12-07T16:53:18Z ***********************
16:53:19:WU00:FS01:0x21:Project: 11714 (Run 0, Clone 10549, Gen 12)
16:53:19:WU00:FS01:0x21:Unit: 0x0000000e8ca304f15de04974a99a93ff
16:53:19:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
16:53:19:WU00:FS01:0x21:Machine: 1
16:53:19:WU00:FS01:0x21:Digital signatures verified
16:53:19:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
16:53:19:WU00:FS01:0x21:Version 0.0.20
16:53:19:WU00:FS01:0x21: Found a checkpoint file
16:53:23:WU00:FS01:0x21:Completed 7000000 out of 7500000 steps (93%)
16:53:23:WU00:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
16:53:32:Removing old file 'configs/config-20191205-025515.xml'
16:53:32:Saving configuration to config.xml
16:53:32:<config>
16:53:32: <!-- Folding Core -->
16:53:32: <checkpoint v='14'/>
16:53:32:
16:53:32: <!-- Network -->
16:53:32: <proxy v=':8080'/>
16:53:32:
16:53:32: <!-- Slot Control -->
16:53:32: <power v='full'/>
16:53:32:
16:53:32: <!-- User Information -->
16:53:32: <team v='235464'/>
16:53:32: <user v='ledgeri#9625'/>
16:53:32:
16:53:32: <!-- Folding Slots -->
16:53:32: <slot id='0' type='CPU'>
16:53:32: <cpus v='4'/>
16:53:32: <paused v='true'/>
16:53:32: </slot>
16:53:32: <slot id='1' type='GPU'/>
16:53:32:</config>
16:55:40:WU00:FS01:0x21:Completed 7050000 out of 7500000 steps (94%)
16:59:06:WU00:FS01:0x21:Completed 7125000 out of 7500000 steps (95%)
17:00:41:FS01:Finishing
17:02:42:WU00:FS01:0x21:Completed 7200000 out of 7500000 steps (96%)
17:06:13:WU00:FS01:0x21:Completed 7275000 out of 7500000 steps (97%)
17:09:45:WU00:FS01:0x21:Completed 7350000 out of 7500000 steps (98%)
17:13:17:WU00:FS01:0x21:Completed 7425000 out of 7500000 steps (99%)
17:16:42:WU00:FS01:0x21:Completed 7500000 out of 7500000 steps (100%)
17:16:43:WU00:FS01:0x21:Saving result file logfile_01.txt
17:16:43:WU00:FS01:0x21:Saving result file checkpointState.xml
17:16:43:WU00:FS01:0x21:Saving result file checkpt.crc
17:16:43:WU00:FS01:0x21:Saving result file log.txt
17:16:43:WU00:FS01:0x21:Saving result file positions.xtc
17:16:43:WU00:FS01:0x21:Folding@home Core Shutdown: FINISHED_UNIT
17:16:44:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
17:16:44:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:11714 run:0 clone:10549 gen:12 core:0x21 unit:0x0000000e8ca304f15de04974a99a93ff
17:16:44:WU00:FS01:Uploading 11.80MiB to 140.163.4.241
17:16:44:WU00:FS01:Connecting to 140.163.4.241:8080
17:16:50:WU00:FS01:Upload 28.07%
17:16:56:WU00:FS01:Upload 82.08%
17:16:58:WU00:FS01:Upload complete
17:16:58:WU00:FS01:Server responded WORK_ACK (400)
17:16:58:WU00:FS01:Final credit estimate, 33314.00 points
17:16:58:WU00:FS01:Cleaning up
19:55:22:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
*********************** Log Started 2019-12-08T14:56:52Z ***********************
14:56:52:************************* Folding@home Client *************************
14:56:52: Website: https://foldingathome.org/
14:56:52: Copyright: (c) 2009-2018 foldingathome.org
14:56:52: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:56:52: Args:
14:56:52: Config: C:\Users\LGB2017v2\AppData\Roaming\FAHClient\config.xml
14:56:52:******************************** Build ********************************
14:56:52: Version: 7.5.1
14:56:52: Date: May 11 2018
14:56:52: Time: 13:06:32
14:56:52: Repository: Git
14:56:52: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
14:56:52: Branch: master
14:56:52: Compiler: Visual C++ 2008
14:56:52: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:56:52: Platform: win32 10
14:56:52: Bits: 32
14:56:52: Mode: Release
14:56:52:******************************* System ********************************
14:56:52: CPU: Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
14:56:52: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
14:56:52: CPUs: 4
14:56:52: Memory: 7.98GiB
14:56:52: Free Memory: 5.89GiB
14:56:52: Threads: WINDOWS_THREADS
14:56:52: OS Version: 6.1
14:56:52: Has Battery: false
14:56:52: On Battery: false
14:56:52: UTC Offset: 1
14:56:52: PID: 4320
14:56:52: CWD: C:\Users\LGB2017v2\AppData\Roaming\FAHClient
14:56:52: OS: Windows 7 Ultimate
14:56:52: OS Arch: AMD64
14:56:52: GPUs: 1
14:56:52: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 GP106 [GeForce GTX 1060 6GB] 4372
14:56:52: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.2
14:56:52:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:441.20
14:56:52: Win32 Service: false
14:56:52:***********************************************************************
14:56:52:<config>
14:56:52: <!-- Folding Core -->
14:56:52: <checkpoint v='14'/>
14:56:52:
14:56:52: <!-- Network -->
14:56:52: <proxy v=':8080'/>
14:56:52:
14:56:52: <!-- Slot Control -->
14:56:52: <power v='full'/>
14:56:52:
14:56:52: <!-- User Information -->
14:56:52: <team v='235464'/>
14:56:52: <user v='ledgeri#9625'/>
14:56:52:
14:56:52: <!-- Folding Slots -->
14:56:52: <slot id='0' type='CPU'>
14:56:52: <cpus v='4'/>
14:56:52: <paused v='true'/>
14:56:52: </slot>
14:56:52: <slot id='1' type='GPU'/>
14:56:52:</config>
14:56:52:Trying to access database...
14:56:52:Successfully acquired database lock
14:56:52:Enabled folding slot 00: PAUSED cpu:4 (by user)
14:56:52:Enabled folding slot 01: READY gpu:0:GP106 [GeForce GTX 1060 6GB] 4372
14:56:53:WU00:FS01:Connecting to 65.254.110.245:8080
14:56:54:WU00:FS01:Assigned to work server 140.163.4.241
14:56:54:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GP106 [GeForce GTX 1060 6GB] 4372 from 140.163.4.241
14:56:54:WU00:FS01:Connecting to 140.163.4.241:8080
14:56:55:WU00:FS01:Downloading 16.53MiB
14:57:01:WU00:FS01:Download 57.84%
14:57:03:WU00:FS01:Download complete
14:57:03:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11714 run:0 clone:6410 gen:12 core:0x21 unit:0x000000138ca304f15b21ad272c331ba5
14:57:03:WU00:FS01:Starting
14:57:03:WU00:FS01:Running FahCore: "C:\Program Files (x86)shared power\FAHClient/FAHCoreWrapper.exe" C:\Users\LGB2017v2\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/nvidia/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 705 -lifeline 4320 -checkpoint 14 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
14:57:04:WU00:FS01:Started FahCore on PID 5272
14:57:04:WU00:FS01:Core PID:2868
14:57:04:WU00:FS01:FahCore 0x21 started
14:57:06:WU00:FS01:0x21:*********************** Log Started 2019-12-08T14:57:05Z ***********************
14:57:06:WU00:FS01:0x21:Project: 11714 (Run 0, Clone 6410, Gen 12)
14:57:06:WU00:FS01:0x21:Unit: 0x000000138ca304f15b21ad272c331ba5
14:57:06:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
14:57:06:WU00:FS01:0x21:Machine: 1
14:57:06:WU00:FS01:0x21:Reading tar file core.xml
14:57:06:WU00:FS01:0x21:Reading tar file integrator.xml
14:57:06:WU00:FS01:0x21:Reading tar file state.xml
14:57:06:WU00:FS01:0x21:Reading tar file system.xml
14:57:06:WU00:FS01:0x21:Digital signatures verified
14:57:06:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
14:57:06:WU00:FS01:0x21:Version 0.0.20
14:57:12:WU00:FS01:0x21:Completed 0 out of 7500000 steps (0%)
14:57:12:WU00:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
15:00:16:FS01:Shutting core down
15:00:16:WU00:FS01:0x21:WARNING:Console control signal 1 on PID 2868
15:00:16:WU00:FS01:0x21:Exiting, please wait. . .
15:00:16:WU00:FS01:0x21:Folding@home Core Shutdown: INTERRUPTED
15:00:16:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
15:00:56:Removing old file 'configs/config-20191205-170236.xml'
15:00:56:Saving configuration to config.xml
15:00:56:<config>
15:00:56: <!-- Folding Core -->
15:00:56: <checkpoint v='14'/>
15:00:56:
15:00:56: <!-- Network -->
15:00:56: <proxy v=':8080'/>
15:00:56:
15:00:56: <!-- Slot Control -->
15:00:56: <power v='LIGHT'/>
15:00:56:
15:00:56: <!-- User Information -->
15:00:56: <team v='235464'/>
15:00:56: <user v='ledgeri#9625'/>
15:00:56:
15:00:56: <!-- Folding Slots -->
15:00:56: <slot id='0' type='CPU'>
15:00:56: <cpus v='4'/>
15:00:56: <paused v='true'/>
15:00:56: </slot>
15:00:56: <slot id='1' type='GPU'/>
15:00:56:</config>
15:02:00:FS01:Paused
15:02:19:FS00:Unpaused
15:02:19:FS00:Finishing
15:02:19:WU01:FS00:Starting
15:02:19:WARNING:WU01:FS00:AS lowered CPUs from 4 to 3
15:02:19:WU01:FS00:Running FahCore: "C:\Program Files (x86)shared power\FAHClient/FAHCoreWrapper.exe" C:\Users\LGB2017v2\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 4320 -checkpoint 14 -np 3
15:02:19:WU01:FS00:Started FahCore on PID 4240
15:02:19:WU01:FS00:Core PID:5516
15:02:19:WU01:FS00:FahCore 0xa7 started
15:02:19:WU01:FS00:0xa7:*********************** Log Started 2019-12-08T15:02:19Z ***********************
15:02:19:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
15:02:19:WU01:FS00:0xa7: Type: 0xa7
15:02:19:WU01:FS00:0xa7: Core: Gromacs
15:02:19:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 705 -lifeline 4240 -checkpoint 14 -np 3
15:02:19:WU01:FS00:0xa7:************************************ CBang *************************************
15:02:19:WU01:FS00:0xa7: Date: Oct 26 2019
15:02:19:WU01:FS00:0xa7: Time: 01:38:25
15:02:19:WU01:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
15:02:19:WU01:FS00:0xa7: Branch: master
15:02:19:WU01:FS00:0xa7: Compiler: Visual C++ 2008
15:02:19:WU01:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:02:19:WU01:FS00:0xa7: Platform: win32 10
15:02:19:WU01:FS00:0xa7: Bits: 64
15:02:19:WU01:FS00:0xa7: Mode: Release
15:02:19:WU01:FS00:0xa7:************************************ System ************************************
15:02:19:WU01:FS00:0xa7: CPU: Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
15:02:19:WU01:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
15:02:19:WU01:FS00:0xa7: CPUs: 4
15:02:19:WU01:FS00:0xa7: Memory: 7.98GiB
15:02:19:WU01:FS00:0xa7:Free Memory: 1.06GiB
15:02:19:WU01:FS00:0xa7: Threads: WINDOWS_THREADS
15:02:19:WU01:FS00:0xa7: OS Version: 6.1
15:02:19:WU01:FS00:0xa7:Has Battery: false
15:02:19:WU01:FS00:0xa7: On Battery: false
15:02:19:WU01:FS00:0xa7: UTC Offset: 1
15:02:19:WU01:FS00:0xa7: PID: 5516
15:02:19:WU01:FS00:0xa7: CWD: C:\Users\LGB2017v2\AppData\Roaming\FAHClient\work
15:02:19:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
15:02:19:WU01:FS00:0xa7: Version: 0.0.18
15:02:19:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:02:19:WU01:FS00:0xa7: Copyright: 2019 foldingathome.org
15:02:19:WU01:FS00:0xa7: Homepage: https://foldingathome.org/
15:02:19:WU01:FS00:0xa7: Time: 01:52:30
15:02:19:WU01:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
15:02:19:WU01:FS00:0xa7:************************************ Build *************************************
15:02:19:WU01:FS00:0xa7: SIMD: avx_256
15:02:19:WU01:FS00:0xa7:********************************************************************************
15:02:19:WU01:FS00:0xa7:Project: 14182 (Run 13, Clone 94, Gen 45)
15:02:19:WU01:FS00:0xa7:Unit: 0x000000350002894b5cf68495254eb574
15:02:19:WU01:FS00:0xa7:Digital signatures verified
15:02:19:WU01:FS00:0xa7:Calling: mdrun -s frame45.tpr -o frame45.trr -cpi state.cpt -cpt 14 -nt 3
15:02:19:WU01:FS00:0xa7:Steps: first=112500000 total=2500000
15:02:20:WU01:FS00:0xa7:Completed 75992 out of 2500000 steps (3%)
15:02:58:Removing old file 'configs/config-20191205-172357.xml'
15:02:58:Saving configuration to config.xml
15:02:58:<config>
15:02:58: <!-- Folding Core -->
15:02:58: <checkpoint v='14'/>
15:02:58:
15:02:58: <!-- Network -->
15:02:58: <proxy v=':8080'/>
15:02:58:
15:02:58: <!-- Slot Control -->
15:02:58: <power v='LIGHT'/>
15:02:58:
15:02:58: <!-- User Information -->
15:02:58: <team v='235464'/>
15:02:58: <user v='ledgeri#9625'/>
15:02:58:
15:02:58: <!-- Folding Slots -->
15:02:58: <slot id='0' type='CPU'>
15:02:58: <cpus v='4'/>
15:02:58: </slot>
15:02:58: <slot id='1' type='GPU'>
15:02:58: <paused v='true'/>
15:02:58: </slot>
15:02:58:</config>
15:12:41:WU01:FS00:0xa7:Completed 100000 out of 2500000 steps (4%)
15:21:55:WU01:FS00:0xa7:Completed 125000 out of 2500000 steps (5%)
15:31:24:WU01:FS00:0xa7:Completed 150000 out of 2500000 steps (6%)
15:39:34:Removing old file 'configs/config-20191205-173508.xml'
15:39:34:Saving configuration to config.xml
15:39:34:<config>
15:39:34: <!-- Folding Core -->
15:39:34: <checkpoint v='14'/>
15:39:34:
15:39:34: <!-- Network -->
15:39:34: <proxy v=':8080'/>
15:39:34:
15:39:34: <!-- Slot Control -->
15:39:34: <power v='full'/>
15:39:34:
15:39:34: <!-- User Information -->
15:39:34: <team v='235464'/>
15:39:34: <user v='ledgeri#9625'/>
15:39:34:
15:39:34: <!-- Folding Slots -->
15:39:34: <slot id='0' type='CPU'>
15:39:34: <cpus v='4'/>
15:39:34: </slot>
15:39:34: <slot id='1' type='GPU'>
15:39:34: <paused v='true'/>
15:39:34: </slot>
15:39:34:</config>
15:40:34:WU01:FS00:0xa7:Completed 175000 out of 2500000 steps (7%)
15:51:02:WU01:FS00:0xa7:Completed 200000 out of 2500000 steps (8%)
16:01:57:WU01:FS00:0xa7:Completed 225000 out of 2500000 steps (9%)
16:13:54:WU01:FS00:0xa7:Completed 250000 out of 2500000 steps (10%)
16:16:22:FS01:Unpaused
16:16:22:WU00:FS01:Starting
16:16:22:WU00:FS01:Running FahCore: "C:\Program Files (x86)shared power\FAHClient/FAHCoreWrapper.exe" C:\Users\LGB2017v2\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/nvidia/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 705 -lifeline 4320 -checkpoint 14 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
16:16:22:WU00:FS01:Started FahCore on PID 9168
16:16:22:WU00:FS01:Core PID:3408
16:16:22:WU00:FS01:FahCore 0x21 started
16:16:23:WU00:FS01:0x21:*********************** Log Started 2019-12-08T16:16:23Z ***********************
16:16:23:WU00:FS01:0x21:Project: 11714 (Run 0, Clone 6410, Gen 12)
16:16:23:WU00:FS01:0x21:Unit: 0x000000138ca304f15b21ad272c331ba5
16:16:23:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
16:16:23:WU00:FS01:0x21:Machine: 1
16:16:23:WU00:FS01:0x21:Digital signatures verified
16:16:23:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
16:16:23:WU00:FS01:0x21:Version 0.0.20
16:16:28:WU00:FS01:0x21:Completed 0 out of 7500000 steps (0%)
16:16:28:WU00:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
16:17:11:Removing old file 'configs/config-20191205-180134.xml'
16:17:11:Saving configuration to config.xml
16:17:11:<config>
16:17:11: <!-- Folding Core -->
16:17:11: <checkpoint v='14'/>
16:17:11:
16:17:11: <!-- Network -->
16:17:11: <proxy v=':8080'/>
16:17:11:
16:17:11: <!-- Slot Control -->
16:17:11: <power v='full'/>
16:17:11:
16:17:11: <!-- User Information -->
16:17:11: <team v='235464'/>
16:17:11: <user v='ledgeri#9625'/>
16:17:11:
16:17:11: <!-- Folding Slots -->
16:17:11: <slot id='0' type='CPU'>
16:17:11: <cpus v='4'/>
16:17:11: </slot>
16:17:11: <slot id='1' type='GPU'/>
16:17:11:</config>
16:20:14:WU00:FS01:0x21:Completed 75000 out of 7500000 steps (1%)
16:42:54:WU00:FS01:0x21:Completed 525000 out of 7500000 steps (7%)
16:43:21:FS00:Paused
16:43:21:FS01:Paused
16:43:21:FS00:Shutting core down
16:43:21:FS01:Shutting core down
16:43:22:WU01:FS00:0xa7:WARNING:Console control signal 1 on PID 5516
16:43:22:WU01:FS00:0xa7:Exiting, please wait. . .
16:43:25:WU01:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
16:43:26:WU00:FS01:0x21:WARNING:Console control signal 1 on PID 3408
16:43:26:WU00:FS01:0x21:Exiting, please wait. . .
16:43:26:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
16:43:26:WU00:FS01:0x21:Folding@home Core Shutdown: INTERRUPTED
16:43:26:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
16:43:37:Removing old file 'configs/config-20191205-191345.xml'
16:43:37:Saving configuration to config.xml
16:43:37:<config>
16:43:37: <!-- Folding Core -->
16:43:37: <checkpoint v='14'/>
16:43:37:
16:43:37: <!-- Network -->
16:43:37: <proxy v=':8080'/>
16:43:37:
16:43:37: <!-- Slot Control -->
16:43:37: <power v='full'/>
16:43:37:
16:43:37: <!-- User Information -->
16:43:37: <team v='235464'/>
16:43:37: <user v='ledgeri#9625'/>
16:43:37:
16:43:37: <!-- Folding Slots -->
16:43:37: <slot id='0' type='CPU'>
16:43:37: <cpus v='4'/>
16:43:37: <paused v='true'/>
16:43:37: </slot>
16:43:37: <slot id='1' type='GPU'>
16:43:37: </slot>
16:43:37:</config>
17:01:39:FS00:Unpaused
17:01:39:FS01:Unpaused
17:01:39:WU01:FS00:Starting
17:01:39:WARNING:WU01:FS00:AS lowered CPUs from 4 to 3
17:01:39:WU01:FS00:Running FahCore: "C:\Program Files (x86)shared power\FAHClient/FAHCoreWrapper.exe" C:\Users\LGB2017v2\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 4320 -checkpoint 14 -np 3
17:01:39:WU01:FS00:Started FahCore on PID 7156
17:01:39:WU01:FS00:Core PID:7164
17:01:39:WU01:FS00:FahCore 0xa7 started
17:01:39:WU00:FS01:Starting
17:01:39:WU00:FS01:Running FahCore: "C:\Program Files (x86)shared power\FAHClient/FAHCoreWrapper.exe" C:\Users\LGB2017v2\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/nvidia/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 705 -lifeline 4320 -checkpoint 14 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
17:01:39:WU00:FS01:Started FahCore on PID 7052
17:01:39:WU00:FS01:Core PID:7176
17:01:39:WU00:FS01:FahCore 0x21 started
17:01:41:WU00:FS01:0x21:*********************** Log Started 2019-12-08T17:01:40Z ***********************
17:01:41:WU00:FS01:0x21:Project: 11714 (Run 0, Clone 6410, Gen 12)
17:01:41:WU00:FS01:0x21:Unit: 0x000000138ca304f15b21ad272c331ba5
17:01:41:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
17:01:41:WU00:FS01:0x21:Machine: 1
17:01:41:WU00:FS01:0x21:Digital signatures verified
17:01:41:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
17:01:41:WU00:FS01:0x21:Version 0.0.20
17:01:41:WU00:FS01:0x21: Found a checkpoint file
17:01:41:WU01:FS00:0xa7:*********************** Log Started 2019-12-08T17:01:41Z ***********************
17:01:41:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
17:01:41:WU01:FS00:0xa7: Type: 0xa7
17:01:41:WU01:FS00:0xa7: Core: Gromacs
17:01:41:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 705 -lifeline 7156 -checkpoint 14 -np 3
17:01:41:WU01:FS00:0xa7:************************************ CBang *************************************
17:01:41:WU01:FS00:0xa7: Date: Oct 26 2019
17:01:41:WU01:FS00:0xa7: Time: 01:38:25
17:01:41:WU01:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
17:01:41:WU01:FS00:0xa7: Branch: master
17:01:41:WU01:FS00:0xa7: Compiler: Visual C++ 2008
17:01:41:WU01:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:01:41:WU01:FS00:0xa7: Platform: win32 10
17:01:41:WU01:FS00:0xa7: Bits: 64
17:01:41:WU01:FS00:0xa7: Mode: Release
17:01:41:WU01:FS00:0xa7:************************************ System ************************************
17:01:41:WU01:FS00:0xa7: CPU: Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
17:01:41:WU01:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
17:01:41:WU01:FS00:0xa7: CPUs: 4
17:01:41:WU01:FS00:0xa7: Memory: 7.98GiB
17:01:41:WU01:FS00:0xa7:Free Memory: 3.37GiB
17:01:41:WU01:FS00:0xa7: Threads: WINDOWS_THREADS
17:01:41:WU01:FS00:0xa7: OS Version: 6.1
17:01:41:WU01:FS00:0xa7:Has Battery: false
17:01:41:WU01:FS00:0xa7: On Battery: false
17:01:41:WU01:FS00:0xa7: UTC Offset: 1
17:01:41:WU01:FS00:0xa7: PID: 7164
17:01:41:WU01:FS00:0xa7: CWD: C:\Users\LGB2017v2\AppData\Roaming\FAHClient\work
17:01:41:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
17:01:41:WU01:FS00:0xa7: Version: 0.0.18
17:01:41:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:01:41:WU01:FS00:0xa7: Copyright: 2019 foldingathome.org
17:01:41:WU01:FS00:0xa7: Homepage: https://foldingathome.org/
17:01:41:WU01:FS00:0xa7: Time: 01:52:30
17:01:41:WU01:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
17:01:41:WU01:FS00:0xa7:************************************ Build *************************************
17:01:41:WU01:FS00:0xa7: SIMD: avx_256
17:01:41:WU01:FS00:0xa7:********************************************************************************
17:01:41:WU01:FS00:0xa7:Project: 14182 (Run 13, Clone 94, Gen 45)
17:01:41:WU01:FS00:0xa7:Unit: 0x000000350002894b5cf68495254eb574
17:01:41:WU01:FS00:0xa7:Digital signatures verified
17:01:41:WU01:FS00:0xa7:Calling: mdrun -s frame45.tpr -o frame45.trr -cpi state.cpt -cpt 14 -nt 3
17:01:41:WU01:FS00:0xa7:Steps: first=112500000 total=2500000
17:01:47:WU01:FS00:0xa7:Completed 291772 out of 2500000 steps (11%)
17:01:55:Removing old file 'configs/config-20191205-192355.xml'
17:01:55:Saving configuration to config.xml
17:01:55:<config>
17:01:55: <!-- Folding Core -->
17:01:55: <checkpoint v='14'/>
17:01:55:
17:01:55: <!-- Network -->
17:01:55: <proxy v=':8080'/>
17:01:55:
17:01:55: <!-- Slot Control -->
17:01:55: <power v='full'/>
17:01:55:
17:01:55: <!-- User Information -->
17:01:55: <team v='235464'/>
17:01:55: <user v='ledgeri#9625'/>
17:01:55:
17:01:55: <!-- Folding Slots -->
17:01:55: <slot id='0' type='CPU'>
17:01:55: <cpus v='4'/>
17:01:55: </slot>
17:01:55: <slot id='1' type='GPU'/>
17:01:55:</config>
17:02:00:WU00:FS01:0x21:Completed 500000 out of 7500000 steps (6%)
17:02:00:WU00:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
17:03:31:WU00:FS01:0x21:Completed 525000 out of 7500000 steps (7%)
17:07:39:WU00:FS01:0x21:Completed 600000 out of 7500000 steps (8%)
17:08:46:WU01:FS00:0xa7:Completed 300000 out of 2500000 steps (12%)
18:20:00:WU00:FS01:0x21:Completed 2025000 out of 7500000 steps (27%)
18:22:42:WU01:FS00:0xa7:Completed 400000 out of 2500000 steps (16%)
18:23:15:Removing old file 'configs/config-20191205-192456.xml'
18:23:15:Saving configuration to config.xml
18:23:15:<config>
18:23:15: <!-- Folding Core -->
18:23:15: <checkpoint v='14'/>
18:23:15:
18:23:15: <!-- Network -->
18:23:15: <proxy v=':8080'/>
18:23:15:
18:23:15: <!-- User Information -->
18:23:15: <team v='235464'/>
18:23:15: <user v='ledgeri#9625'/>
18:23:15:
18:23:15: <!-- Folding Slots -->
18:23:15: <slot id='0' type='CPU'>
18:23:15: <cpus v='4'/>
18:23:15: </slot>
18:23:15: <slot id='1' type='GPU'/>
18:23:15:</config>
18:23:42:WU00:FS01:0x21:Completed 2100000 out of 7500000 steps (28%)
18:23:46:FS00:Shutting core down
18:23:46:WU01:FS00:0xa7:WARNING:Console control signal 1 on PID 7164
18:23:46:WU01:FS00:0xa7:Exiting, please wait. . .
18:23:47:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
18:24:16:Removing old file 'configs/config-20191205-192557.xml'
18:24:16:Saving configuration to config.xml
18:24:16:<config>
18:24:16: <!-- Folding Core -->
18:24:16: <checkpoint v='14'/>
18:24:16:
18:24:16: <!-- Network -->
18:24:16: <proxy v=':8080'/>
18:24:16:
18:24:16: <!-- Slot Control -->
18:24:16: <power v='full'/>
18:24:16:
18:24:16: <!-- User Information -->
18:24:16: <team v='235464'/>
18:24:16: <user v='ledgeri#9625'/>
18:24:16:
18:24:16: <!-- Folding Slots -->
18:24:16: <slot id='0' type='CPU'>
18:24:16: <cpus v='4'/>
18:24:16: <idle v='true'/>
18:24:16: </slot>
18:24:16: <slot id='1' type='GPU'/>
18:24:16:</config>
18:27:10:WU00:FS01:0x21:Completed 2175000 out of 7500000 steps (29%)
19:36:28:WU00:FS01:0x21:Completed 3675000 out of 7500000 steps (49%)
19:37:23:WU01:FS00:Starting
19:37:23:WARNING:WU01:FS00:AS lowered CPUs from 4 to 3
19:37:23:WU01:FS00:Running FahCore: "C:\Program Files (x86)shared power\FAHClient/FAHCoreWrapper.exe" C:\Users\LGB2017v2\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 4320 -checkpoint 14 -np 3
19:37:23:WU01:FS00:Started FahCore on PID 4012
19:37:24:WU01:FS00:Core PID:4856
19:37:24:WU01:FS00:FahCore 0xa7 started
19:37:24:WU01:FS00:0xa7:*********************** Log Started 2019-12-08T19:37:24Z ***********************
19:37:24:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
19:37:24:WU01:FS00:0xa7: Type: 0xa7
19:37:24:WU01:FS00:0xa7: Core: Gromacs
19:37:24:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 705 -lifeline 4012 -checkpoint 14 -np 3
19:37:24:WU01:FS00:0xa7:************************************ CBang *************************************
19:37:24:WU01:FS00:0xa7: Date: Oct 26 2019
19:37:24:WU01:FS00:0xa7: Time: 01:38:25
19:37:24:WU01:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
19:37:24:WU01:FS00:0xa7: Branch: master
19:37:24:WU01:FS00:0xa7: Compiler: Visual C++ 2008
19:37:24:WU01:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:37:24:WU01:FS00:0xa7: Platform: win32 10
19:37:24:WU01:FS00:0xa7: Bits: 64
19:37:24:WU01:FS00:0xa7: Mode: Release
19:37:24:WU01:FS00:0xa7:************************************ System ************************************
19:37:24:WU01:FS00:0xa7: CPU: Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
19:37:24:WU01:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
19:37:24:WU01:FS00:0xa7: CPUs: 4
19:37:24:WU01:FS00:0xa7: Memory: 7.98GiB
19:37:24:WU01:FS00:0xa7:Free Memory: 5.54GiB
19:37:24:WU01:FS00:0xa7: Threads: WINDOWS_THREADS
19:37:24:WU01:FS00:0xa7: OS Version: 6.1
19:37:24:WU01:FS00:0xa7:Has Battery: false
19:37:24:WU01:FS00:0xa7: On Battery: false
19:37:24:WU01:FS00:0xa7: UTC Offset: 1
19:37:24:WU01:FS00:0xa7: PID: 4856
19:37:24:WU01:FS00:0xa7: CWD: C:\Users\LGB2017v2\AppData\Roaming\FAHClient\work
19:37:24:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
19:37:24:WU01:FS00:0xa7: Version: 0.0.18
19:37:24:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:37:24:WU01:FS00:0xa7: Copyright: 2019 foldingathome.org
19:37:24:WU01:FS00:0xa7: Homepage: https://foldingathome.org/
19:37:24:WU01:FS00:0xa7: Time: 01:52:30
19:37:24:WU01:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
19:37:24:WU01:FS00:0xa7:************************************ Build *************************************
19:37:24:WU01:FS00:0xa7: SIMD: avx_256
19:37:24:WU01:FS00:0xa7:********************************************************************************
19:37:24:WU01:FS00:0xa7:Project: 14182 (Run 13, Clone 94, Gen 45)
19:37:24:WU01:FS00:0xa7:Unit: 0x000000350002894b5cf68495254eb574
19:37:24:WU01:FS00:0xa7:Digital signatures verified
19:37:24:WU01:FS00:0xa7:Calling: mdrun -s frame45.tpr -o frame45.trr -cpi state.cpt -cpt 14 -nt 3
19:37:24:WU01:FS00:0xa7:Steps: first=112500000 total=2500000
19:37:25:WU01:FS00:0xa7:Completed 401822 out of 2500000 steps (16%)
19:37:28:Removing old file 'configs/config-20191205-202758.xml'
19:37:28:Saving configuration to config.xml
19:37:28:<config>
19:37:28: <!-- Folding Core -->
19:37:28: <checkpoint v='14'/>
19:37:28:
19:37:28: <!-- Network -->
19:37:28: <proxy v=':8080'/>
19:37:28:
19:37:28: <!-- Slot Control -->
19:37:28: <power v='full'/>
19:37:28:
19:37:28: <!-- User Information -->
19:37:28: <team v='235464'/>
19:37:28: <user v='ledgeri#9625'/>
19:37:28:
19:37:28: <!-- Folding Slots -->
19:37:28: <slot id='0' type='CPU'>
19:37:28: <cpus v='4'/>
19:37:28: </slot>
19:37:28: <slot id='1' type='GPU'/>
19:37:28:</config>
19:39:02:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
19:39:02:WARNING:WU01:FS00:FahCore crashed with Windows unhandled exception code 0x40010004, searching for this code online may provide more information
19:39:02:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (1073807364 = 0x40010004)
19:39:02:WARNING:WU00:FS01:FahCore crashed with Windows unhandled exception code 0x40010004, searching for this code online may provide more information
19:39:02:WARNING:WU00:FS01:FahCore returned: UNKNOWN_ENUM (1073807364 = 0x40010004)
19:39:03:WU01:FS00:Starting
19:39:03:WARNING:WU01:FS00:AS lowered CPUs from 4 to 3
19:39:03:WU01:FS00:Running FahCore: "C:\Program Files (x86)shared power\FAHClient/FAHCoreWrapper.exe" C:\Users\LGB2017v2\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 4320 -checkpoint 14 -np 3
19:39:03:WU01:FS00:Started FahCore on PID 3016
19:39:03:WU01:FS00:FahCore 0xa7 started
19:39:03:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
19:39:03:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073741205 = 0xc000026b)
19:39:03:WU00:FS01:Starting
19:39:03:WU00:FS01:Running FahCore: "C:\Program Files (x86)shared power\FAHClient/FAHCoreWrapper.exe" C:\Users\LGB2017v2\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/nvidia/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 705 -lifeline 4320 -checkpoint 14 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
19:39:03:WU00:FS01:Started FahCore on PID 9820
19:39:03:WU00:FS01:FahCore 0x21 started
19:39:03:WARNING:WU00:FS01:FahCore returned an unknown error code which probably indicates that it crashed
19:39:03:WARNING:WU00:FS01:FahCore returned: UNKNOWN_ENUM (-1073741205 = 0xc000026b)
____
_____
____
_____
*********************** Log Started 2019-12-08T21:50:57Z ***********************
21:50:57:************************* Folding@home Client *************************
21:50:57: Website: https://foldingathome.org/
21:50:57: Copyright: (c) 2009-2018 foldingathome.org
21:50:57: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:50:57: Args:
21:50:57: Config: C:\Users\LGB2017v2\AppData\Roaming\FAHClient\config.xml
21:50:57:******************************** Build ********************************
21:50:57: Version: 7.5.1
21:50:57: Date: May 11 2018
21:50:57: Time: 13:06:32
21:50:57: Repository: Git
21:50:57: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
21:50:57: Branch: master
21:50:57: Compiler: Visual C++ 2008
21:50:57: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:50:57: Platform: win32 10
21:50:57: Bits: 32
21:50:57: Mode: Release
21:50:57:******************************* System ********************************
21:50:57: CPU: Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
21:50:57: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
21:50:57: CPUs: 4
21:50:57: Memory: 7.98GiB
21:50:57: Free Memory: 6.67GiB
21:50:57: Threads: WINDOWS_THREADS
21:50:57: OS Version: 6.1
21:50:57: Has Battery: false
21:50:57: On Battery: false
21:50:57: UTC Offset: 1
21:50:57: PID: 1444
21:50:57: CWD: C:\Users\LGB2017v2\AppData\Roaming\FAHClient
21:50:57: OS: Windows 7 Ultimate
21:50:57: OS Arch: AMD64
21:50:57: GPUs: 1
21:50:57: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 GP106 [GeForce GTX 1060 6GB] 4372
21:50:57: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.2
21:50:57:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:441.20
21:50:57: Win32 Service: false
21:50:57:***********************************************************************
21:50:57:<config>
21:50:57: <!-- Folding Core -->
21:50:57: <checkpoint v='14'/>
21:50:57:
21:50:57: <!-- Network -->
21:50:57: <proxy v=':8080'/>
21:50:57:
21:50:57: <!-- Slot Control -->
21:50:57: <power v='full'/>
21:50:57:
21:50:57: <!-- User Information -->
21:50:57: <team v='235464'/>
21:50:57: <user v='ledgeri#9625'/>
21:50:57:
21:50:57: <!-- Folding Slots -->
21:50:57: <slot id='0' type='CPU'>
21:50:57: <cpus v='4'/>
21:50:57: </slot>
21:50:57: <slot id='1' type='GPU'/>
21:50:57:</config>
21:50:57:Trying to access database...
21:50:58:Successfully acquired database lock
21:50:58:Enabled folding slot 00: READY cpu:4
21:50:58:Enabled folding slot 01: READY gpu:0:GP106 [GeForce GTX 1060 6GB] 4372
21:50:58:WU01:FS00:Starting
21:50:58:WARNING:WU01:FS00:AS lowered CPUs from 4 to 3
21:50:58:WU01:FS00:Running FahCore: "C:\Program Files (x86)shared power\FAHClient/FAHCoreWrapper.exe" C:\Users\LGB2017v2\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 1444 -checkpoint 14 -np 3
21:50:58:WU01:FS00:Started FahCore on PID 216
21:50:59:WU01:FS00:Core PID:1296
21:50:59:WU01:FS00:FahCore 0xa7 started
21:50:59:WU00:FS01:Starting
21:50:59:WU00:FS01:Running FahCore: "C:\Program Files (x86)shared power\FAHClient/FAHCoreWrapper.exe" C:\Users\LGB2017v2\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/nvidia/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 705 -lifeline 1444 -checkpoint 14 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
21:50:59:WU00:FS01:Started FahCore on PID 3084
21:50:59:WU00:FS01:Core PID:3096
21:50:59:WU00:FS01:FahCore 0x21 started
21:51:01:WU01:FS00:0xa7:*********************** Log Started 2019-12-08T21:51:00Z ***********************
21:51:01:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
21:51:01:WU01:FS00:0xa7: Type: 0xa7
21:51:01:WU01:FS00:0xa7: Core: Gromacs
21:51:01:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 705 -lifeline 216 -checkpoint 14 -np 3
21:51:01:WU01:FS00:0xa7:************************************ CBang *************************************
21:51:01:WU01:FS00:0xa7: Date: Oct 26 2019
21:51:01:WU01:FS00:0xa7: Time: 01:38:25
21:51:01:WU01:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
21:51:01:WU01:FS00:0xa7: Branch: master
21:51:01:WU01:FS00:0xa7: Compiler: Visual C++ 2008
21:51:01:WU01:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:51:01:WU01:FS00:0xa7: Platform: win32 10
21:51:01:WU01:FS00:0xa7: Bits: 64
21:51:01:WU01:FS00:0xa7: Mode: Release
21:51:01:WU01:FS00:0xa7:************************************ System ************************************
21:51:01:WU01:FS00:0xa7: CPU: Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
21:51:01:WU01:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
21:51:01:WU01:FS00:0xa7: CPUs: 4
21:51:01:WU01:FS00:0xa7: Memory: 7.98GiB
21:51:01:WU01:FS00:0xa7:Free Memory: 6.52GiB
21:51:01:WU01:FS00:0xa7: Threads: WINDOWS_THREADS
21:51:01:WU01:FS00:0xa7: OS Version: 6.1
21:51:01:WU01:FS00:0xa7:Has Battery: false
21:51:01:WU01:FS00:0xa7: On Battery: false
21:51:01:WU01:FS00:0xa7: UTC Offset: 1
21:51:01:WU01:FS00:0xa7: PID: 1296
21:51:01:WU01:FS00:0xa7: CWD: C:\Users\LGB2017v2\AppData\Roaming\FAHClient\work
21:51:01:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
21:51:01:WU01:FS00:0xa7: Version: 0.0.18
21:51:01:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:51:01:WU01:FS00:0xa7: Copyright: 2019 foldingathome.org
21:51:01:WU01:FS00:0xa7: Homepage: https://foldingathome.org/
21:51:01:WU01:FS00:0xa7: Time: 01:52:30
21:51:01:WU01:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
21:51:01:WU01:FS00:0xa7:************************************ Build *************************************
21:51:01:WU01:FS00:0xa7: SIMD: avx_256
21:51:01:WU01:FS00:0xa7:********************************************************************************
21:51:01:WU01:FS00:0xa7:Project: 14182 (Run 13, Clone 94, Gen 45)
21:51:01:WU01:FS00:0xa7:Unit: 0x000000350002894b5cf68495254eb574
21:51:01:WU01:FS00:0xa7:Digital signatures verified
21:51:01:WU01:FS00:0xa7:Calling: mdrun -s frame45.tpr -o frame45.trr -cpi state.cpt -cpt 14 -nt 3
21:51:02:WU01:FS00:0xa7:ERROR:Guru Meditation #796e537babcc418a.32c7f8d3686ec9af (897288.1794576) '01/01/frame45.trr'
21:51:02:WU01:FS00:0xa7:WARNING:Unexpected exit() call
21:51:02:WU01:FS00:0xa7:WARNING:Unexpected exit from science code
21:51:02:WU01:FS00:0xa7:Saving result file ..\logfile_01.txt
21:51:02:WU01:FS00:0xa7:Saving result file frame45.trr
21:51:02:WU00:FS01:0x21:*********************** Log Started 2019-12-08T21:51:01Z ***********************
21:51:02:WU00:FS01:0x21:Project: 11714 (Run 0, Clone 6410, Gen 12)
21:51:02:WU00:FS01:0x21:Unit: 0x000000138ca304f15b21ad272c331ba5
21:51:02:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
21:51:02:WU00:FS01:0x21:Machine: 1
21:51:02:WU00:FS01:0x21:Digital signatures verified
21:51:02:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
21:51:02:WU00:FS01:0x21:Version 0.0.20
21:51:02:WU00:FS01:0x21: Found a checkpoint file
21:51:10:WU00:FS01:0x21:Completed 3500000 out of 7500000 steps (46%)
21:51:10:WU00:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
21:51:33:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
21:51:33:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073740777 = 0xc0000417)
21:51:34:WU01:FS00:Starting
21:51:34:WARNING:WU01:FS00:AS lowered CPUs from 4 to 3
21:51:34:WU01:FS00:Running FahCore: "C:\Program Files (x86)shared power\FAHClient/FAHCoreWrapper.exe" C:\Users\LGB2017v2\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 1444 -checkpoint 14 -np 3
21:51:34:WU01:FS00:Started FahCore on PID 8932
21:51:35:WU01:FS00:Core PID:8292
21:51:35:WU01:FS00:FahCore 0xa7 started
21:51:36:WU01:FS00:0xa7:*********************** Log Started 2019-12-08T21:51:35Z ***********************
21:51:36:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
21:51:36:WU01:FS00:0xa7: Type: 0xa7
21:51:36:WU01:FS00:0xa7: Core: Gromacs
21:51:36:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 705 -lifeline 8932 -checkpoint 14 -np 3
21:51:36:WU01:FS00:0xa7:************************************ CBang *************************************
21:51:36:WU01:FS00:0xa7: Date: Oct 26 2019
21:51:36:WU01:FS00:0xa7: Time: 01:38:25
21:51:36:WU01:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
21:51:36:WU01:FS00:0xa7: Branch: master
21:51:36:WU01:FS00:0xa7: Compiler: Visual C++ 2008
21:51:36:WU01:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:51:36:WU01:FS00:0xa7: Platform: win32 10
21:51:36:WU01:FS00:0xa7: Bits: 64
21:51:36:WU01:FS00:0xa7: Mode: Release
21:51:36:WU01:FS00:0xa7:************************************ System ************************************
21:51:36:WU01:FS00:0xa7: CPU: Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
21:51:36:WU01:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
21:51:36:WU01:FS00:0xa7: CPUs: 4
21:51:36:WU01:FS00:0xa7: Memory: 7.98GiB
21:51:36:WU01:FS00:0xa7:Free Memory: 3.95GiB
21:51:36:WU01:FS00:0xa7: Threads: WINDOWS_THREADS
21:51:36:WU01:FS00:0xa7: OS Version: 6.1
21:51:36:WU01:FS00:0xa7:Has Battery: false
21:51:36:WU01:FS00:0xa7: On Battery: false
21:51:36:WU01:FS00:0xa7: UTC Offset: 1
21:51:36:WU01:FS00:0xa7: PID: 8292
21:51:36:WU01:FS00:0xa7: CWD: C:\Users\LGB2017v2\AppData\Roaming\FAHClient\work
21:51:36:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
21:51:36:WU01:FS00:0xa7: Version: 0.0.18
21:51:36:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:51:36:WU01:FS00:0xa7: Copyright: 2019 foldingathome.org
21:51:36:WU01:FS00:0xa7: Homepage: https://foldingathome.org/
21:51:36:WU01:FS00:0xa7: Time: 01:52:30
21:51:36:WU01:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
21:51:36:WU01:FS00:0xa7:************************************ Build *************************************
21:51:36:WU01:FS00:0xa7: SIMD: avx_256
21:51:36:WU01:FS00:0xa7:********************************************************************************
21:51:36:WU01:FS00:0xa7:Project: 14182 (Run 13, Clone 94, Gen 45)
21:51:36:WU01:FS00:0xa7:Unit: 0x000000350002894b5cf68495254eb574
21:51:36:WU01:FS00:0xa7:Digital signatures verified
21:51:36:WU01:FS00:0xa7:Calling: mdrun -s frame45.tpr -o frame45.trr -cpi state.cpt -cpt 14 -nt 3
21:51:36:WU01:FS00:0xa7:ERROR:Guru Meditation #796e537babcc418a.32c7f8d3686ec9af (897288.1794576) '01/01/frame45.trr'
21:51:36:WU01:FS00:0xa7:WARNING:Unexpected exit() call
21:51:36:WU01:FS00:0xa7:WARNING:Unexpected exit from science code
21:51:36:WU01:FS00:0xa7:Saving result file ..\logfile_01.txt
21:51:36:WU01:FS00:0xa7:Saving result file frame45.trr
21:51:40:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
21:51:40:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073740777 = 0xc0000417)
21:52:34:WU01:FS00:Starting
21:52:34:WARNING:WU01:FS00:AS lowered CPUs from 4 to 3
21:52:34:WU01:FS00:Running FahCore: "C:\Program Files (x86)shared power\FAHClient/FAHCoreWrapper.exe" C:\Users\LGB2017v2\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 1444 -checkpoint 14 -np 3
21:52:34:WU01:FS00:Started FahCore on PID 3224
21:52:39:WU01:FS00:Core PID:4584
21:52:39:WU01:FS00:FahCore 0xa7 started
21:52:41:WU01:FS00:0xa7:*********************** Log Started 2019-12-08T21:52:41Z ***********************
21:52:41:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
21:52:41:WU01:FS00:0xa7: Type: 0xa7
21:52:41:WU01:FS00:0xa7: Core: Gromacs
21:52:41:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 705 -lifeline 3224 -checkpoint 14 -np 3
21:52:41:WU01:FS00:0xa7:************************************ CBang *************************************
21:52:41:WU01:FS00:0xa7: Date: Oct 26 2019
21:52:41:WU01:FS00:0xa7: Time: 01:38:25
21:52:41:WU01:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
21:52:41:WU01:FS00:0xa7: Branch: master
21:52:41:WU01:FS00:0xa7: Compiler: Visual C++ 2008
21:52:41:WU01:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:52:41:WU01:FS00:0xa7: Platform: win32 10
21:52:41:WU01:FS00:0xa7: Bits: 64
21:52:41:WU01:FS00:0xa7: Mode: Release
21:52:41:WU01:FS00:0xa7:************************************ System ************************************
21:52:41:WU01:FS00:0xa7: CPU: Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
21:52:41:WU01:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
21:52:41:WU01:FS00:0xa7: CPUs: 4
21:52:41:WU01:FS00:0xa7: Memory: 7.98GiB
21:52:41:WU01:FS00:0xa7:Free Memory: 1.36GiB
21:52:41:WU01:FS00:0xa7: Threads: WINDOWS_THREADS
21:52:41:WU01:FS00:0xa7: OS Version: 6.1
21:52:41:WU01:FS00:0xa7:Has Battery: false
21:52:41:WU01:FS00:0xa7: On Battery: false
21:52:41:WU01:FS00:0xa7: UTC Offset: 1
21:52:41:WU01:FS00:0xa7: PID: 4584
21:52:41:WU01:FS00:0xa7: CWD: C:\Users\LGB2017v2\AppData\Roaming\FAHClient\work
21:52:41:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
21:52:41:WU01:FS00:0xa7: Version: 0.0.18
21:52:41:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:52:41:WU01:FS00:0xa7: Copyright: 2019 foldingathome.org
21:52:41:WU01:FS00:0xa7: Homepage: https://foldingathome.org/
21:52:41:WU01:FS00:0xa7: Time: 01:52:30
21:52:41:WU01:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
21:52:41:WU01:FS00:0xa7:************************************ Build *************************************
21:52:41:WU01:FS00:0xa7: SIMD: avx_256
21:52:41:WU01:FS00:0xa7:********************************************************************************
21:52:42:WU01:FS00:0xa7:Project: 14182 (Run 13, Clone 94, Gen 45)
21:52:42:WU01:FS00:0xa7:Unit: 0x000000350002894b5cf68495254eb574
21:52:42:WU01:FS00:0xa7:Digital signatures verified
21:52:42:WU01:FS00:0xa7:Calling: mdrun -s frame45.tpr -o frame45.trr -cpi state.cpt -cpt 14 -nt 3
21:52:42:WU01:FS00:0xa7:ERROR:Guru Meditation #796e537babcc418a.32c7f8d3686ec9af (897288.1794576) '01/01/frame45.trr'
21:52:42:WU01:FS00:0xa7:WARNING:Unexpected exit() call
21:52:42:WU01:FS00:0xa7:WARNING:Unexpected exit from science code
21:52:42:WU01:FS00:0xa7:Saving result file ..\logfile_01.txt
21:52:42:WU01:FS00:0xa7:Saving result file frame45.trr
21:52:48:WU00:FS01:0x21:Completed 3525000 out of 7500000 steps (47%)
21:52:53:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
21:52:53:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073740777 = 0xc0000417)
21:52:53:WARNING:WU01:FS00:Too many errors, failing
21:52:53:WU01:FS00:Sending unit results: id:01 state:SEND error:FAILED project:14182 run:13 clone:94 gen:45 core:0xa7 unit:0x000000350002894b5cf68495254eb574
21:52:53:WU01:FS00:Connecting to 155.247.166.219:8080
21:52:54:WU02:FS00:Connecting to 65.254.110.245:8080
21:52:54:WU01:FS00:Server responded WORK_ACK (400)
21:52:54:WU01:FS00:Cleaning up
21:52:56:WU02:FS00:Assigned to work server 155.247.166.219
21:52:56:WU02:FS00:Requesting new work unit for slot 00: READY cpu:4 from 155.247.166.219
21:52:56:WU02:FS00:Connecting to 155.247.166.219:8080
21:52:57:WU02:FS00:Downloading 1.72MiB
21:52:59:WU02:FS00:Download complete
21:52:59:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:14182 run:13 clone:159 gen:55 core:0xa7 unit:0x0000003d0002894b5cf6849345e122ee
21:52:59:WU02:FS00:Starting
21:52:59:WU02:FS00:Running FahCore: "C:\Program Files (x86)shared power\FAHClient/FAHCoreWrapper.exe" C:\Users\LGB2017v2\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 1444 -checkpoint 14 -np 4
21:52:59:WU02:FS00:Started FahCore on PID 2156
21:52:59:WU02:FS00:Core PID:3128
21:52:59:WU02:FS00:FahCore 0xa7 started
21:53:00:WU02:FS00:0xa7:*********************** Log Started 2019-12-08T21:52:59Z ***********************
21:53:00:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
21:53:00:WU02:FS00:0xa7: Type: 0xa7
21:53:00:WU02:FS00:0xa7: Core: Gromacs
21:53:00:WU02:FS00:0xa7: Args: -dir 02 -suffix 01 -version 705 -lifeline 2156 -checkpoint 14 -np 4
21:53:00:WU02:FS00:0xa7:************************************ CBang *************************************
21:53:00:WU02:FS00:0xa7: Date: Oct 26 2019
21:53:00:WU02:FS00:0xa7: Time: 01:38:25
21:53:00:WU02:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
21:53:00:WU02:FS00:0xa7: Branch: master
21:53:00:WU02:FS00:0xa7: Compiler: Visual C++ 2008
21:53:00:WU02:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:53:00:WU02:FS00:0xa7: Platform: win32 10
21:53:00:WU02:FS00:0xa7: Bits: 64
21:53:00:WU02:FS00:0xa7: Mode: Release
21:53:00:WU02:FS00:0xa7:************************************ System ************************************
21:53:00:WU02:FS00:0xa7: CPU: Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
21:53:00:WU02:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
21:53:00:WU02:FS00:0xa7: CPUs: 4
21:53:00:WU02:FS00:0xa7: Memory: 7.98GiB
21:53:00:WU02:FS00:0xa7:Free Memory: 1.11GiB
21:53:00:WU02:FS00:0xa7: Threads: WINDOWS_THREADS
21:53:00:WU02:FS00:0xa7: OS Version: 6.1
21:53:00:WU02:FS00:0xa7:Has Battery: false
21:53:00:WU02:FS00:0xa7: On Battery: false
21:53:00:WU02:FS00:0xa7: UTC Offset: 1
21:53:00:WU02:FS00:0xa7: PID: 3128
21:53:00:WU02:FS00:0xa7: CWD: C:\Users\LGB2017v2\AppData\Roaming\FAHClient\work
21:53:00:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
21:53:00:WU02:FS00:0xa7: Version: 0.0.18
21:53:00:WU02:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:53:00:WU02:FS00:0xa7: Copyright: 2019 foldingathome.org
21:53:00:WU02:FS00:0xa7: Homepage: https://foldingathome.org/
21:53:00:WU02:FS00:0xa7: Time: 01:52:30
21:53:00:WU02:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
21:53:00:WU02:FS00:0xa7:************************************ Build *************************************
21:53:00:WU02:FS00:0xa7: SIMD: avx_256
21:53:00:WU02:FS00:0xa7:********************************************************************************
21:53:00:WU02:FS00:0xa7:Project: 14182 (Run 13, Clone 159, Gen 55)
21:53:00:WU02:FS00:0xa7:Unit: 0x0000003d0002894b5cf6849345e122ee
21:53:00:WU02:FS00:0xa7:Reading tar file core.xml
21:53:00:WU02:FS00:0xa7:Reading tar file frame55.tpr
21:53:00:WU02:FS00:0xa7:Digital signatures verified
21:53:00:WU02:FS00:0xa7:Calling: mdrun -s frame55.tpr -o frame55.trr -cpt 14 -nt 4
21:53:13:WU02:FS00:0xa7:Steps: first=137500000 total=2500000
21:53:32:WU02:FS00:0xa7:Completed 1 out of 2500000 steps (0%)
21:57:43:WU00:FS01:0x21:Completed 3600000 out of 7500000 steps (48%)
23:44:33:WU00:FS01:0x21:Completed 5850000 out of 7500000 steps (78%)
23:46:14:WU02:FS00:0xa7:Completed 25000 out of 2500000 steps (1%)
23:48:08:WU00:FS01:0x21:Completed 5925000 out of 7500000 steps (79%)
00:05:56:WU00:FS01:0x21:Completed 6300000 out of 7500000 steps (84%)
00:06:55:FS00:Paused
00:06:55:FS00:Shutting core down
00:06:56:WU02:FS00:0xa7:WARNING:Console control signal 1 on PID 3128
00:06:56:WU02:FS00:0xa7:Exiting, please wait. . .
00:07:00:WU02:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
00:07:01:WU02:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
00:07:04:FS00:Unpaused
00:07:04:WU02:FS00:Starting
00:07:04:WU02:FS00:Running FahCore: "C:\Program Files (x86)shared power\FAHClient/FAHCoreWrapper.exe" C:\Users\LGB2017v2\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 1444 -checkpoint 14 -np 4
00:07:04:WU02:FS00:Started FahCore on PID 9704
00:07:04:WU02:FS00:Core PID:4764
00:07:04:WU02:FS00:FahCore 0xa7 started
00:07:05:WU02:FS00:0xa7:*********************** Log Started 2019-12-09T00:07:04Z ***********************
00:07:05:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
00:07:05:WU02:FS00:0xa7: Type: 0xa7
00:07:05:WU02:FS00:0xa7: Core: Gromacs
00:07:05:WU02:FS00:0xa7: Args: -dir 02 -suffix 01 -version 705 -lifeline 9704 -checkpoint 14 -np 4
00:07:05:WU02:FS00:0xa7:************************************ CBang *************************************
00:07:05:WU02:FS00:0xa7: Date: Oct 26 2019
00:07:05:WU02:FS00:0xa7: Time: 01:38:25
00:07:05:WU02:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
00:07:05:WU02:FS00:0xa7: Branch: master
00:07:05:WU02:FS00:0xa7: Compiler: Visual C++ 2008
00:07:05:WU02:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
00:07:05:WU02:FS00:0xa7: Platform: win32 10
00:07:05:WU02:FS00:0xa7: Bits: 64
00:07:05:WU02:FS00:0xa7: Mode: Release
00:07:05:WU02:FS00:0xa7:************************************ System ************************************
00:07:05:WU02:FS00:0xa7: CPU: Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
00:07:05:WU02:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
00:07:05:WU02:FS00:0xa7: CPUs: 4
00:07:05:WU02:FS00:0xa7: Memory: 7.98GiB
00:07:05:WU02:FS00:0xa7:Free Memory: 767.66MiB
00:07:05:WU02:FS00:0xa7: Threads: WINDOWS_THREADS
00:07:05:WU02:FS00:0xa7: OS Version: 6.1
00:07:05:WU02:FS00:0xa7:Has Battery: false
00:07:05:WU02:FS00:0xa7: On Battery: false
00:07:05:WU02:FS00:0xa7: UTC Offset: 1
00:07:05:WU02:FS00:0xa7: PID: 4764
00:07:05:WU02:FS00:0xa7: CWD: C:\Users\LGB2017v2\AppData\Roaming\FAHClient\work
00:07:05:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
00:07:05:WU02:FS00:0xa7: Version: 0.0.18
00:07:05:WU02:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:07:05:WU02:FS00:0xa7: Copyright: 2019 foldingathome.org
00:07:05:WU02:FS00:0xa7: Homepage: https://foldingathome.org/
00:07:05:WU02:FS00:0xa7: Time: 01:52:30
00:07:05:WU02:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
00:07:05:WU02:FS00:0xa7:************************************ Build *************************************
00:07:05:WU02:FS00:0xa7: SIMD: avx_256
00:07:05:WU02:FS00:0xa7:********************************************************************************
00:07:05:WU02:FS00:0xa7:Project: 14182 (Run 13, Clone 159, Gen 55)
00:07:05:WU02:FS00:0xa7:Unit: 0x0000003d0002894b5cf6849345e122ee
00:07:05:WU02:FS00:0xa7:Digital signatures verified
00:07:05:WU02:FS00:0xa7:Calling: mdrun -s frame55.tpr -o frame55.trr -cpi state.cpt -cpt 14 -nt 4
00:07:05:WU02:FS00:0xa7:Steps: first=137500000 total=2500000
00:07:07:WU02:FS00:0xa7:Completed 27892 out of 2500000 steps (1%)
00:09:27:WU00:FS01:0x21:Completed 6375000 out of 7500000 steps (85%)
00:20:05:WU00:FS01:0x21:Completed 6600000 out of 7500000 steps (88%)
00:21:25:FS00:Paused
00:21:25:FS01:Paused
00:21:31:FS00:Shutting core down
00:21:31:FS01:Shutting core down
00:21:31:WU02:FS00:0xa7:WARNING:Console control signal 1 on PID 4764
00:21:31:WU02:FS00:0xa7:Exiting, please wait. . .
00:21:31:WU00:FS01:0x21:WARNING:Console control signal 1 on PID 3096
00:21:31:WU00:FS01:0x21:Exiting, please wait. . .
00:21:31:WU00:FS01:0x21:Folding@home Core Shutdown: INTERRUPTED
00:21:31:Removing old file 'configs/config-20191205-221321.xml'
00:21:31:Saving configuration to config.xml
00:21:31:<config>
00:21:31: <!-- Folding Core -->
00:21:31: <checkpoint v='14'/>
00:21:31:
00:21:31: <!-- Network -->
00:21:31: <proxy v=':8080'/>
00:21:31:
00:21:31: <!-- Slot Control -->
00:21:31: <power v='full'/>
00:21:31:
00:21:31: <!-- User Information -->
00:21:31: <team v='235464'/>
00:21:31: <user v='ledgeri#9625'/>
00:21:31:
00:21:31: <!-- Folding Slots -->
00:21:31: <slot id='0' type='CPU'>
00:21:31: <cpus v='4'/>
00:21:31: <paused v='true'/>
00:21:31: </slot>
00:21:31: <slot id='1' type='GPU'>
00:21:31: </slot>
00:21:31:</config>
00:21:32:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
00:21:33:WU02:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
00:21:33:WU02:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
00:31:47:9:127.0.0.1:New Web connection
02:01:31:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
*********************** Log Started 2019-12-09T02:02:21Z ***********************
02:02:21:************************* Folding@home Client *************************
02:02:21: Website: https://foldingathome.org/
02:02:21: Copyright: (c) 2009-2018 foldingathome.org
02:02:21: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:02:21: Args:
02:02:21: Config: C:\Users\LGB2017v2\AppData\Roaming\FAHClient\config.xml
02:02:21:******************************** Build ********************************
02:02:21: Version: 7.5.1
02:02:21: Date: May 11 2018
02:02:21: Time: 13:06:32
02:02:21: Repository: Git
02:02:21: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
02:02:21: Branch: master
02:02:21: Compiler: Visual C++ 2008
02:02:21: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
02:02:21: Platform: win32 10
02:02:21: Bits: 32
02:02:21: Mode: Release
02:02:21:******************************* System ********************************
02:02:21: CPU: Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
02:02:21: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
02:02:21: CPUs: 4
02:02:21: Memory: 7.98GiB
02:02:21: Free Memory: 6.70GiB
02:02:21: Threads: WINDOWS_THREADS
02:02:21: OS Version: 6.1
02:02:21: Has Battery: false
02:02:21: On Battery: false
02:02:21: UTC Offset: 1
02:02:21: PID: 3632
02:02:21: CWD: C:\Users\LGB2017v2\AppData\Roaming\FAHClient
02:02:21: OS: Windows 7 Ultimate
02:02:21: OS Arch: AMD64
02:02:21: GPUs: 1
02:02:21: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 GP106 [GeForce GTX 1060 6GB] 4372
02:02:21: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.2
02:02:21:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:441.20
02:02:21: Win32 Service: false
02:02:21:***********************************************************************
02:02:21:<config>
02:02:21: <!-- Folding Core -->
02:02:21: <checkpoint v='14'/>
02:02:21:
02:02:21: <!-- Network -->
02:02:21: <proxy v=':8080'/>
02:02:21:
02:02:21: <!-- Slot Control -->
02:02:21: <power v='full'/>
02:02:21:
02:02:21: <!-- User Information -->
02:02:21: <team v='235464'/>
02:02:21: <user v='ledgeri#9625'/>
02:02:21:
02:02:21: <!-- Folding Slots -->
02:02:21: <slot id='0' type='CPU'>
02:02:21: <cpus v='4'/>
02:02:21: <paused v='true'/>
02:02:21: </slot>
02:02:21: <slot id='1' type='GPU'>
02:02:21: </slot>
02:02:21:</config>
02:02:21:Trying to access database...
02:02:21:Successfully acquired database lock
02:02:21:Enabled folding slot 00: PAUSED cpu:4 (by user)
02:02:21:Enabled folding slot 01: PAUSED gpu:0:GP106 [GeForce GTX 1060 6GB] 4372 (by user)
02:03:38:FS00:Unpaused
02:03:38:FS01:Unpaused
02:03:38:WU00:FS01:Starting
02:03:38:WU00:FS01:Running FahCore: "C:\Program Files (x86)shared power\FAHClient/FAHCoreWrapper.exe" C:\Users\LGB2017v2\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/nvidia/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 705 -lifeline 3632 -checkpoint 14 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
02:03:38:WU00:FS01:Started FahCore on PID 7972
02:03:38:WU00:FS01:Core PID:7984
02:03:38:WU00:FS01:FahCore 0x21 started
02:03:38:WU02:FS00:Starting
02:03:38:WU02:FS00:Running FahCore: "C:\Program Files (x86)shared power\FAHClient/FAHCoreWrapper.exe" C:\Users\LGB2017v2\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 3632 -checkpoint 14 -np 4
02:03:38:WU02:FS00:Started FahCore on PID 7992
02:03:38:WU02:FS00:Core PID:8004
02:03:38:WU02:FS00:FahCore 0xa7 started
02:03:38:WU00:FS01:0x21:*********************** Log Started 2019-12-09T02:03:38Z ***********************
02:03:38:WU00:FS01:0x21:Project: 11714 (Run 0, Clone 6410, Gen 12)
02:03:38:WU00:FS01:0x21:Unit: 0x000000138ca304f15b21ad272c331ba5
02:03:38:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
02:03:38:WU00:FS01:0x21:Machine: 1
02:03:38:WU00:FS01:0x21:Digital signatures verified
02:03:38:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
02:03:38:WU00:FS01:0x21:Version 0.0.20
02:03:38:WU00:FS01:0x21: Found a checkpoint file
02:03:38:WU02:FS00:0xa7:*********************** Log Started 2019-12-09T02:03:38Z ***********************
02:03:38:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
02:03:38:WU02:FS00:0xa7: Type: 0xa7
02:03:38:WU02:FS00:0xa7: Core: Gromacs
02:03:38:WU02:FS00:0xa7: Args: -dir 02 -suffix 01 -version 705 -lifeline 7992 -checkpoint 14 -np 4
02:03:38:WU02:FS00:0xa7:************************************ CBang *************************************
02:03:38:WU02:FS00:0xa7: Date: Oct 26 2019
02:03:38:WU02:FS00:0xa7: Time: 01:38:25
02:03:38:WU02:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
02:03:38:WU02:FS00:0xa7: Branch: master
02:03:38:WU02:FS00:0xa7: Compiler: Visual C++ 2008
02:03:38:WU02:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
02:03:38:WU02:FS00:0xa7: Platform: win32 10
02:03:38:WU02:FS00:0xa7: Bits: 64
02:03:38:WU02:FS00:0xa7: Mode: Release
02:03:38:WU02:FS00:0xa7:************************************ System ************************************
02:03:38:WU02:FS00:0xa7: CPU: Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
02:03:38:WU02:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
02:03:38:WU02:FS00:0xa7: CPUs: 4
02:03:38:WU02:FS00:0xa7: Memory: 7.98GiB
02:03:38:WU02:FS00:0xa7:Free Memory: 5.10GiB
02:03:38:WU02:FS00:0xa7: Threads: WINDOWS_THREADS
02:03:38:WU02:FS00:0xa7: OS Version: 6.1
02:03:38:WU02:FS00:0xa7:Has Battery: false
02:03:38:WU02:FS00:0xa7: On Battery: false
02:03:38:WU02:FS00:0xa7: UTC Offset: 1
02:03:38:WU02:FS00:0xa7: PID: 8004
02:03:38:WU02:FS00:0xa7: CWD: C:\Users\LGB2017v2\AppData\Roaming\FAHClient\work
02:03:38:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
02:03:38:WU02:FS00:0xa7: Version: 0.0.18
02:03:38:WU02:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:03:38:WU02:FS00:0xa7: Copyright: 2019 foldingathome.org
02:03:38:WU02:FS00:0xa7: Homepage: https://foldingathome.org/
02:03:38:WU02:FS00:0xa7: Time: 01:52:30
02:03:38:WU02:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
02:03:38:WU02:FS00:0xa7:************************************ Build *************************************
02:03:38:WU02:FS00:0xa7: SIMD: avx_256
02:03:38:WU02:FS00:0xa7:********************************************************************************
02:03:38:WU02:FS00:0xa7:Project: 14182 (Run 13, Clone 159, Gen 55)
02:03:38:WU02:FS00:0xa7:Unit: 0x0000003d0002894b5cf6849345e122ee
02:03:38:WU02:FS00:0xa7:Digital signatures verified
02:03:38:WU02:FS00:0xa7:Calling: mdrun -s frame55.tpr -o frame55.trr -cpi state.cpt -cpt 14 -nt 4
02:03:38:WU02:FS00:0xa7:Steps: first=137500000 total=2500000
02:03:40:WU02:FS00:0xa7:Completed 30252 out of 2500000 steps (1%)
02:03:43:WU00:FS01:0x21:Completed 6500000 out of 7500000 steps (86%)
02:03:43:WU00:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
02:04:23:Removing old file 'configs/config-20191206-000107.xml'
02:04:23:Saving configuration to config.xml
02:04:23:<config>
02:04:23: <!-- Folding Core -->
02:04:23: <checkpoint v='14'/>
02:04:23:
02:04:23: <!-- Network -->
02:04:23: <proxy v=':8080'/>
02:04:23:
02:04:23: <!-- Slot Control -->
02:04:23: <power v='full'/>
02:04:23:
02:04:23: <!-- User Information -->
02:04:23: <team v='235464'/>
02:04:23: <user v='ledgeri#9625'/>
02:04:23:
02:04:23: <!-- Folding Slots -->
02:04:23: <slot id='0' type='CPU'>
02:04:23: <cpus v='4'/>
02:04:23: </slot>
02:04:23: <slot id='1' type='GPU'/>
02:04:23:</config>
02:04:53:WU00:FS01:0x21:Completed 6525000 out of 7500000 steps (87%)
02:08:38:WU00:FS01:0x21:Completed 6600000 out of 7500000 steps (88%)
02:09:09:FS01:Finishing
02:12:12:WU00:FS01:0x21:Completed 6675000 out of 7500000 steps (89%)
02:47:01:WU00:FS01:0x21:Completed 7425000 out of 7500000 steps (99%)
02:50:30:WU00:FS01:0x21:Completed 7500000 out of 7500000 steps (100%)
02:50:32:WU00:FS01:0x21:Saving result file logfile_01.txt
02:50:32:WU00:FS01:0x21:Saving result file checkpointState.xml
02:50:32:WU00:FS01:0x21:Saving result file checkpt.crc
02:50:32:WU00:FS01:0x21:Saving result file log.txt
02:50:32:WU00:FS01:0x21:Saving result file positions.xtc
02:50:32:WU00:FS01:0x21:Folding@home Core Shutdown: FINISHED_UNIT
02:50:32:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
02:50:32:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:11714 run:0 clone:6410 gen:12 core:0x21 unit:0x000000138ca304f15b21ad272c331ba5
02:50:32:WU00:FS01:Uploading 11.80MiB to 140.163.4.241
02:50:32:WU00:FS01:Connecting to 140.163.4.241:8080
02:50:38:WU00:FS01:Upload 24.89%
02:50:44:WU00:FS01:Upload 88.97%
02:50:46:WU00:FS01:Upload complete
02:50:46:WU00:FS01:Server responded WORK_ACK (400)
02:50:46:WU00:FS01:Final credit estimate, 62088.00 points
02:50:46:WU00:FS01:Cleaning up
02:56:15:WU02:FS00:0xa7:Completed 50000 out of 2500000 steps (2%)
03:08:56:WU02:FS00:0xa7:Completed 75000 out of 2500000 steps (3%)
03:19:54:WU02:FS00:0xa7:Completed 100000 out of 2500000 steps (4%)
03:33:27:WU02:FS00:0xa7:Completed 125000 out of 2500000 steps (5%)
03:41:17:FS00:Paused
03:41:17:FS01:Paused
03:41:17:FS00:Shutting core down
03:41:17:WU02:FS00:0xa7:WARNING:Console control signal 1 on PID 8004
03:41:17:WU02:FS00:0xa7:Exiting, please wait. . .
03:41:17:WU02:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:41:47:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
*********************** Log Started 2019-12-09T03:42:32Z ***********************
03:42:32:************************* Folding@home Client *************************
03:42:32: Website: https://foldingathome.org/
03:42:32: Copyright: (c) 2009-2018 foldingathome.org
03:42:32: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:42:32: Args:
03:42:32: Config: C:\Users\LGB2017v2\AppData\Roaming\FAHClient\config.xml
03:42:32:******************************** Build ********************************
03:42:32: Version: 7.5.1
03:42:32: Date: May 11 2018
03:42:32: Time: 13:06:32
03:42:32: Repository: Git
03:42:32: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
03:42:32: Branch: master
03:42:32: Compiler: Visual C++ 2008
03:42:32: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:42:32: Platform: win32 10
03:42:32: Bits: 32
03:42:32: Mode: Release
03:42:32:******************************* System ********************************
03:42:32: CPU: Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
03:42:32: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
03:42:32: CPUs: 4
03:42:32: Memory: 7.98GiB
03:42:32: Free Memory: 6.78GiB
03:42:32: Threads: WINDOWS_THREADS
03:42:32: OS Version: 6.1
03:42:32: Has Battery: false
03:42:32: On Battery: false
03:42:32: UTC Offset: 1
03:42:32: PID: 2548
03:42:32: CWD: C:\Users\LGB2017v2\AppData\Roaming\FAHClient
03:42:32: OS: Windows 7 Ultimate
03:42:32: OS Arch: AMD64
03:42:32: GPUs: 1
03:42:32: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 GP106 [GeForce GTX 1060 6GB] 4372
03:42:32: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.2
03:42:32:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:441.20
03:42:32: Win32 Service: false
03:42:32:***********************************************************************
03:42:32:<config>
03:42:32: <!-- Folding Core -->
03:42:32: <checkpoint v='14'/>
03:42:32:
03:42:32: <!-- Network -->
03:42:32: <proxy v=':8080'/>
03:42:32:
03:42:32: <!-- Slot Control -->
03:42:32: <power v='full'/>
03:42:32:
03:42:32: <!-- User Information -->
03:42:32: <team v='235464'/>
03:42:32: <user v='ledgeri#9625'/>
03:42:32:
03:42:32: <!-- Folding Slots -->
03:42:32: <slot id='0' type='CPU'>
03:42:32: <cpus v='4'/>
03:42:32: </slot>
03:42:32: <slot id='1' type='GPU'/>
03:42:32:</config>
03:42:32:Trying to access database...
03:42:32:Successfully acquired database lock
03:42:32:Enabled folding slot 00: READY cpu:4
03:42:32:Enabled folding slot 01: READY gpu:0:GP106 [GeForce GTX 1060 6GB] 4372
03:42:32:WU02:FS00:Starting
03:42:32:WU02:FS00:Running FahCore: "C:\Program Files (x86)shared power\FAHClient/FAHCoreWrapper.exe" C:\Users\LGB2017v2\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 2548 -checkpoint 14 -np 4
03:42:32:WU02:FS00:Started FahCore on PID 2840
03:42:33:WU02:FS00:Core PID:3088
03:42:33:WU02:FS00:FahCore 0xa7 started
03:42:33:WU00:FS01:Connecting to 65.254.110.245:8080
03:42:33:WU02:FS00:0xa7:*********************** Log Started 2019-12-09T03:42:33Z ***********************
03:42:33:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
03:42:33:WU02:FS00:0xa7: Type: 0xa7
03:42:33:WU02:FS00:0xa7: Core: Gromacs
03:42:33:WU02:FS00:0xa7: Args: -dir 02 -suffix 01 -version 705 -lifeline 2840 -checkpoint 14 -np 4
03:42:33:WU02:FS00:0xa7:************************************ CBang *************************************
03:42:33:WU02:FS00:0xa7: Date: Oct 26 2019
03:42:33:WU02:FS00:0xa7: Time: 01:38:25
03:42:33:WU02:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
03:42:33:WU02:FS00:0xa7: Branch: master
03:42:33:WU02:FS00:0xa7: Compiler: Visual C++ 2008
03:42:33:WU02:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:42:33:WU02:FS00:0xa7: Platform: win32 10
03:42:33:WU02:FS00:0xa7: Bits: 64
03:42:33:WU02:FS00:0xa7: Mode: Release
03:42:33:WU02:FS00:0xa7:************************************ System ************************************
03:42:33:WU02:FS00:0xa7: CPU: Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
03:42:33:WU02:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
03:42:33:WU02:FS00:0xa7: CPUs: 4
03:42:33:WU02:FS00:0xa7: Memory: 7.98GiB
03:42:33:WU02:FS00:0xa7:Free Memory: 6.66GiB
03:42:33:WU02:FS00:0xa7: Threads: WINDOWS_THREADS
03:42:33:WU02:FS00:0xa7: OS Version: 6.1
03:42:33:WU02:FS00:0xa7:Has Battery: false
03:42:33:WU02:FS00:0xa7: On Battery: false
03:42:33:WU02:FS00:0xa7: UTC Offset: 1
03:42:33:WU02:FS00:0xa7: PID: 3088
03:42:33:WU02:FS00:0xa7: CWD: C:\Users\LGB2017v2\AppData\Roaming\FAHClient\work
03:42:33:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
03:42:33:WU02:FS00:0xa7: Version: 0.0.18
03:42:33:WU02:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:42:33:WU02:FS00:0xa7: Copyright: 2019 foldingathome.org
03:42:33:WU02:FS00:0xa7: Homepage: https://foldingathome.org/
03:42:33:WU02:FS00:0xa7: Time: 01:52:30
03:42:33:WU02:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
03:42:33:WU02:FS00:0xa7:************************************ Build *************************************
03:42:33:WU02:FS00:0xa7: SIMD: avx_256
03:42:33:WU02:FS00:0xa7:********************************************************************************
03:42:33:WU02:FS00:0xa7:Project: 14182 (Run 13, Clone 159, Gen 55)
03:42:33:WU02:FS00:0xa7:Unit: 0x0000003d0002894b5cf6849345e122ee
03:42:33:WU02:FS00:0xa7:Digital signatures verified
03:42:33:WU02:FS00:0xa7:Calling: mdrun -s frame55.tpr -o frame55.trr -cpi state.cpt -cpt 14 -nt 4
03:42:34:WU02:FS00:0xa7:Steps: first=137500000 total=2500000
03:42:34:WU00:FS01:Assigned to work server 140.163.4.241
03:42:34:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GP106 [GeForce GTX 1060 6GB] 4372 from 140.163.4.241
03:42:34:WU00:FS01:Connecting to 140.163.4.241:8080
03:42:35:WU02:FS00:0xa7:Completed 147032 out of 2500000 steps (5%)
03:42:35:WU00:FS01:Downloading 16.53MiB
03:42:40:WU00:FS01:Download complete
03:42:40:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11714 run:0 clone:6835 gen:14 core:0x21 unit:0x0000001c8ca304f15b21ad28b0c977dc
03:42:40:WU00:FS01:Starting
03:42:40:WU00:FS01:Running FahCore: "C:\Program Files (x86)shared power\FAHClient/FAHCoreWrapper.exe" C:\Users\LGB2017v2\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/nvidia/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 705 -lifeline 2548 -checkpoint 14 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
03:42:40:WU00:FS01:Started FahCore on PID 4708
03:42:41:WU00:FS01:Core PID:4724
03:42:41:WU00:FS01:FahCore 0x21 started
03:42:42:WU00:FS01:0x21:*********************** Log Started 2019-12-09T03:42:42Z ***********************
03:42:42:WU00:FS01:0x21:Project: 11714 (Run 0, Clone 6835, Gen 14)
03:42:42:WU00:FS01:0x21:Unit: 0x0000001c8ca304f15b21ad28b0c977dc
03:42:42:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
03:42:42:WU00:FS01:0x21:Machine: 1
03:42:42:WU00:FS01:0x21:Reading tar file core.xml
03:42:42:WU00:FS01:0x21:Reading tar file integrator.xml
03:42:42:WU00:FS01:0x21:Reading tar file state.xml
03:42:42:WU00:FS01:0x21:Reading tar file system.xml
03:42:42:WU00:FS01:0x21:Digital signatures verified
03:42:42:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
03:42:42:WU00:FS01:0x21:Version 0.0.20
03:42:57:WU00:FS01:0x21:Completed 0 out of 7500000 steps (0%)
03:42:57:WU00:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
03:46:31:WU00:FS01:0x21:Completed 75000 out of 7500000 steps (1%)
03:47:22:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
03:47:24:WARNING:WU00:FS01:FahCore crashed with Windows unhandled exception code 0x40010004, searching for this code online may provide more information
03:47:24:WARNING:WU00:FS01:FahCore returned: UNKNOWN_ENUM (1073807364 = 0x40010004)
03:47:24:WARNING:WU02:FS00:FahCore crashed with Windows unhandled exception code 0x40010004, searching for this code online may provide more information
03:47:24:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (1073807364 = 0x40010004)
03:47:24:WU00:FS01:Starting
03:47:24:WU00:FS01:Running FahCore: "C:\Program Files (x86)shared power\FAHClient/FAHCoreWrapper.exe" C:\Users\LGB2017v2\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/nvidia/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 705 -lifeline 2548 -checkpoint 14 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
03:47:24:WU00:FS01:Started FahCore on PID 1476
03:47:24:WU00:FS01:FahCore 0x21 started
03:47:24:WARNING:WU00:FS01:FahCore returned an unknown error code which probably indicates that it crashed
03:47:24:WARNING:WU00:FS01:FahCore returned: UNKNOWN_ENUM (-1073741205 = 0xc000026b)
03:47:25:WU02:FS00:Starting
03:47:25:WU02:FS00:Running FahCore: "C:\Program Files (x86)shared power\FAHClient/FAHCoreWrapper.exe" C:\Users\LGB2017v2\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 2548 -checkpoint 14 -np 4
03:47:25:WU02:FS00:Started FahCore on PID 7536
03:47:25:WU02:FS00:FahCore 0xa7 started
03:47:25:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
03:47:25:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073741205 = 0xc000026b)
- Hardware configuration: i5-2400 , 1060 6gb, 8GBram
Re: Can i skip my part on the a project?
*********************** Log Started 2019-12-09T15:58:32Z ***********************
15:58:32:************************* Folding@home Client *************************
15:58:32: Website: https://foldingathome.org/
15:58:32: Copyright: (c) 2009-2018 foldingathome.org
15:58:32: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:58:32: Args:
15:58:32: Config: C:\Users\LGB2017v2\AppData\Roaming\FAHClient\config.xml
15:58:32:******************************** Build ********************************
15:58:32: Version: 7.5.1
15:58:32: Date: May 11 2018
15:58:32: Time: 13:06:32
15:58:32: Repository: Git
15:58:32: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
15:58:32: Branch: master
15:58:32: Compiler: Visual C++ 2008
15:58:32: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:58:32: Platform: win32 10
15:58:32: Bits: 32
15:58:32: Mode: Release
15:58:32:******************************* System ********************************
15:58:32: CPU: Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
15:58:32: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
15:58:32: CPUs: 4
15:58:32: Memory: 7.98GiB
15:58:32: Free Memory: 6.21GiB
15:58:32: Threads: WINDOWS_THREADS
15:58:32: OS Version: 6.1
15:58:32: Has Battery: false
15:58:32: On Battery: false
15:58:32: UTC Offset: 1
15:58:32: PID: 4596
15:58:32: CWD: C:\Users\LGB2017v2\AppData\Roaming\FAHClient
15:58:32: OS: Windows 7 Ultimate
15:58:32: OS Arch: AMD64
15:58:32: GPUs: 1
15:58:32: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 GP106 [GeForce GTX 1060 6GB] 4372
15:58:32: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.2
15:58:32:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:441.20
15:58:32: Win32 Service: false
15:58:32:***********************************************************************
15:58:32:<config>
15:58:32: <!-- Folding Core -->
15:58:32: <checkpoint v='14'/>
15:58:32:
15:58:32: <!-- Network -->
15:58:32: <proxy v=':8080'/>
15:58:32:
15:58:32: <!-- Slot Control -->
15:58:32: <power v='full'/>
15:58:32:
15:58:32: <!-- User Information -->
15:58:32: <team v='235464'/>
15:58:32: <user v='ledgeri#9625'/>
15:58:32:
15:58:32: <!-- Folding Slots -->
15:58:32: <slot id='0' type='CPU'>
15:58:32: <cpus v='4'/>
15:58:32: </slot>
15:58:32: <slot id='1' type='GPU'/>
15:58:32:</config>
15:58:32:Trying to access database...
15:58:32:Successfully acquired database lock
15:58:32:Enabled folding slot 00: READY cpu:4
15:58:32:Enabled folding slot 01: READY gpu:0:GP106 [GeForce GTX 1060 6GB] 4372
15:58:32:WU00:FS01:Starting
15:58:32:WU00:FS01:Running FahCore: "C:\Program Files (x86)shared power\FAHClient/FAHCoreWrapper.exe" C:\Users\LGB2017v2\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/nvidia/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 705 -lifeline 4596 -checkpoint 14 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
15:58:32:WU00:FS01:Started FahCore on PID 5048
15:58:32:WU00:FS01:Core PID:4180
15:58:32:WU00:FS01:FahCore 0x21 started
15:58:32:WU02:FS00:Starting
15:58:32:WU02:FS00:Running FahCore: "C:\Program Files (x86)shared power\FAHClient/FAHCoreWrapper.exe" C:\Users\LGB2017v2\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 4596 -checkpoint 14 -np 4
15:58:32:WU02:FS00:Started FahCore on PID 4508
15:58:32:WU02:FS00:Core PID:4312
15:58:32:WU02:FS00:FahCore 0xa7 started
15:58:33:WU02:FS00:0xa7:*********************** Log Started 2019-12-09T15:58:33Z ***********************
15:58:33:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
15:58:33:WU02:FS00:0xa7: Type: 0xa7
15:58:33:WU02:FS00:0xa7: Core: Gromacs
15:58:33:WU02:FS00:0xa7: Args: -dir 02 -suffix 01 -version 705 -lifeline 4508 -checkpoint 14 -np 4
15:58:33:WU02:FS00:0xa7:************************************ CBang *************************************
15:58:33:WU02:FS00:0xa7: Date: Oct 26 2019
15:58:33:WU02:FS00:0xa7: Time: 01:38:25
15:58:33:WU02:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
15:58:33:WU02:FS00:0xa7: Branch: master
15:58:33:WU02:FS00:0xa7: Compiler: Visual C++ 2008
15:58:33:WU02:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:58:33:WU02:FS00:0xa7: Platform: win32 10
15:58:33:WU02:FS00:0xa7: Bits: 64
15:58:33:WU02:FS00:0xa7: Mode: Release
15:58:33:WU02:FS00:0xa7:************************************ System ************************************
15:58:33:WU02:FS00:0xa7: CPU: Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
15:58:33:WU02:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
15:58:33:WU02:FS00:0xa7: CPUs: 4
15:58:33:WU02:FS00:0xa7: Memory: 7.98GiB
15:58:33:WU02:FS00:0xa7:Free Memory: 5.97GiB
15:58:33:WU02:FS00:0xa7: Threads: WINDOWS_THREADS
15:58:33:WU02:FS00:0xa7: OS Version: 6.1
15:58:33:WU02:FS00:0xa7:Has Battery: false
15:58:33:WU02:FS00:0xa7: On Battery: false
15:58:33:WU02:FS00:0xa7: UTC Offset: 1
15:58:33:WU02:FS00:0xa7: PID: 4312
15:58:33:WU02:FS00:0xa7: CWD: C:\Users\LGB2017v2\AppData\Roaming\FAHClient\work
15:58:33:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
15:58:33:WU02:FS00:0xa7: Version: 0.0.18
15:58:33:WU02:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:58:33:WU02:FS00:0xa7: Copyright: 2019 foldingathome.org
15:58:33:WU02:FS00:0xa7: Homepage: https://foldingathome.org/
15:58:33:WU02:FS00:0xa7: Time: 01:52:30
15:58:33:WU02:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
15:58:33:WU02:FS00:0xa7:************************************ Build *************************************
15:58:33:WU02:FS00:0xa7: SIMD: avx_256
15:58:33:WU02:FS00:0xa7:********************************************************************************
15:58:33:WU02:FS00:0xa7:Project: 14182 (Run 13, Clone 159, Gen 55)
15:58:33:WU02:FS00:0xa7:Unit: 0x0000003d0002894b5cf6849345e122ee
15:58:33:WU02:FS00:0xa7:Digital signatures verified
15:58:33:WU02:FS00:0xa7:Calling: mdrun -s frame55.tpr -o frame55.trr -cpi state.cpt -cpt 14 -nt 4
15:58:33:WU02:FS00:0xa7:ERROR:Guru Meditation #e59cb67096aeb6ba.ce9a4fc3d7db8adc (897288.1794576) '02/01/frame55.trr'
15:58:33:WU02:FS00:0xa7:WARNING:Unexpected exit() call
15:58:33:WU02:FS00:0xa7:WARNING:Unexpected exit from science code
15:58:33:WU02:FS00:0xa7:Saving result file ..\logfile_01.txt
15:58:33:WU02:FS00:0xa7:Saving result file frame55.trr
15:58:33:WU00:FS01:0x21:*********************** Log Started 2019-12-09T15:58:33Z ***********************
15:58:33:WU00:FS01:0x21:Project: 11714 (Run 0, Clone 6835, Gen 14)
15:58:33:WU00:FS01:0x21:Unit: 0x0000001c8ca304f15b21ad28b0c977dc
15:58:33:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
15:58:33:WU00:FS01:0x21:Machine: 1
15:58:33:WU00:FS01:0x21:Digital signatures verified
15:58:33:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
15:58:33:WU00:FS01:0x21:Version 0.0.20
15:58:46:WU00:FS01:0x21:Completed 0 out of 7500000 steps (0%)
15:58:46:WU00:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
15:58:50:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
15:58:50:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073740777 = 0xc0000417)
15:58:50:WU02:FS00:Starting
15:58:50:WU02:FS00:Running FahCore: "C:\Program Files (x86)shared power\FAHClient/FAHCoreWrapper.exe" C:\Users\LGB2017v2\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 4596 -checkpoint 14 -np 4
15:58:50:WU02:FS00:Started FahCore on PID 6968
15:58:50:WU02:FS00:Core PID:6980
15:58:50:WU02:FS00:FahCore 0xa7 started
15:58:51:WU02:FS00:0xa7:*********************** Log Started 2019-12-09T15:58:50Z ***********************
15:58:51:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
15:58:51:WU02:FS00:0xa7: Type: 0xa7
15:58:51:WU02:FS00:0xa7: Core: Gromacs
15:58:51:WU02:FS00:0xa7: Args: -dir 02 -suffix 01 -version 705 -lifeline 6968 -checkpoint 14 -np 4
15:58:51:WU02:FS00:0xa7:************************************ CBang *************************************
15:58:51:WU02:FS00:0xa7: Date: Oct 26 2019
15:58:51:WU02:FS00:0xa7: Time: 01:38:25
15:58:51:WU02:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
15:58:51:WU02:FS00:0xa7: Branch: master
15:58:51:WU02:FS00:0xa7: Compiler: Visual C++ 2008
15:58:51:WU02:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:58:51:WU02:FS00:0xa7: Platform: win32 10
15:58:51:WU02:FS00:0xa7: Bits: 64
15:58:51:WU02:FS00:0xa7: Mode: Release
15:58:51:WU02:FS00:0xa7:************************************ System ************************************
15:58:51:WU02:FS00:0xa7: CPU: Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
15:58:51:WU02:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
15:58:51:WU02:FS00:0xa7: CPUs: 4
15:58:51:WU02:FS00:0xa7: Memory: 7.98GiB
15:58:51:WU02:FS00:0xa7:Free Memory: 5.24GiB
15:58:51:WU02:FS00:0xa7: Threads: WINDOWS_THREADS
15:58:51:WU02:FS00:0xa7: OS Version: 6.1
15:58:51:WU02:FS00:0xa7:Has Battery: false
15:58:51:WU02:FS00:0xa7: On Battery: false
15:58:51:WU02:FS00:0xa7: UTC Offset: 1
15:58:51:WU02:FS00:0xa7: PID: 6980
15:58:51:WU02:FS00:0xa7: CWD: C:\Users\LGB2017v2\AppData\Roaming\FAHClient\work
15:58:51:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
15:58:51:WU02:FS00:0xa7: Version: 0.0.18
15:58:51:WU02:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:58:51:WU02:FS00:0xa7: Copyright: 2019 foldingathome.org
15:58:51:WU02:FS00:0xa7: Homepage: https://foldingathome.org/
15:58:51:WU02:FS00:0xa7: Time: 01:52:30
15:58:51:WU02:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
15:58:51:WU02:FS00:0xa7:************************************ Build *************************************
15:58:51:WU02:FS00:0xa7: SIMD: avx_256
15:58:51:WU02:FS00:0xa7:********************************************************************************
15:58:51:WU02:FS00:0xa7:Project: 14182 (Run 13, Clone 159, Gen 55)
15:58:51:WU02:FS00:0xa7:Unit: 0x0000003d0002894b5cf6849345e122ee
15:58:51:WU02:FS00:0xa7:Digital signatures verified
15:58:51:WU02:FS00:0xa7:Calling: mdrun -s frame55.tpr -o frame55.trr -cpi state.cpt -cpt 14 -nt 4
15:58:51:WU02:FS00:0xa7:ERROR:Guru Meditation #e59cb67096aeb6ba.ce9a4fc3d7db8adc (897288.1794576) '02/01/frame55.trr'
15:58:51:WU02:FS00:0xa7:WARNING:Unexpected exit() call
15:58:51:WU02:FS00:0xa7:WARNING:Unexpected exit from science code
15:58:51:WU02:FS00:0xa7:Saving result file ..\logfile_01.txt
15:58:51:WU02:FS00:0xa7:Saving result file frame55.trr
15:58:53:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
15:58:53:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073740777 = 0xc0000417)
15:58:59:FS01:Shutting core down
15:58:59:WU00:FS01:0x21:WARNING:Console control signal 1 on PID 4180
15:58:59:WU00:FS01:0x21:Exiting, please wait. . .
15:58:59:Clean exit
*********************** Log Started 2019-12-09T15:59:05Z ***********************
15:59:05:************************* Folding@home Client *************************
15:59:05: Website: https://foldingathome.org/
15:59:05: Copyright: (c) 2009-2018 foldingathome.org
15:59:05: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:59:05: Args: --open-web-control
15:59:05: Config: C:\Users\LGB2017v2\AppData\Roaming\FAHClient\config.xml
15:59:05:******************************** Build ********************************
15:59:05: Version: 7.5.1
15:59:05: Date: May 11 2018
15:59:05: Time: 13:06:32
15:59:05: Repository: Git
15:59:05: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
15:59:05: Branch: master
15:59:05: Compiler: Visual C++ 2008
15:59:05: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:59:05: Platform: win32 10
15:59:05: Bits: 32
15:59:05: Mode: Release
15:59:05:******************************* System ********************************
15:59:05: CPU: Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
15:59:05: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
15:59:05: CPUs: 4
15:59:05: Memory: 7.98GiB
15:59:05: Free Memory: 4.93GiB
15:59:05: Threads: WINDOWS_THREADS
15:59:05: OS Version: 6.1
15:59:05: Has Battery: false
15:59:05: On Battery: false
15:59:05: UTC Offset: 1
15:59:05: PID: 6284
15:59:05: CWD: C:\Users\LGB2017v2\AppData\Roaming\FAHClient
15:59:05: OS: Windows 7 Ultimate
15:59:05: OS Arch: AMD64
15:59:05: GPUs: 1
15:59:05: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 GP106 [GeForce GTX 1060 6GB] 4372
15:59:05: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.2
15:59:05:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:441.20
15:59:05: Win32 Service: false
15:59:05:***********************************************************************
15:59:05:<config>
15:59:05: <!-- Folding Core -->
15:59:05: <checkpoint v='14'/>
15:59:05:
15:59:05: <!-- Network -->
15:59:05: <proxy v=':8080'/>
15:59:05:
15:59:05: <!-- Slot Control -->
15:59:05: <power v='full'/>
15:59:05:
15:59:05: <!-- User Information -->
15:59:05: <team v='235464'/>
15:59:05: <user v='ledgeri#9625'/>
15:59:05:
15:59:05: <!-- Folding Slots -->
15:59:05: <slot id='0' type='CPU'>
15:59:05: <cpus v='4'/>
15:59:05: </slot>
15:59:05: <slot id='1' type='GPU'/>
15:59:05:</config>
15:59:05:Trying to access database...
15:59:05:Successfully acquired database lock
15:59:05:Enabled folding slot 00: READY cpu:4
15:59:05:Enabled folding slot 01: READY gpu:0:GP106 [GeForce GTX 1060 6GB] 4372
15:59:05:WU00:FS01:Starting
15:59:05:WU00:FS01:Running FahCore: "C:\Program Files (x86)shared power\FAHClient/FAHCoreWrapper.exe" C:\Users\LGB2017v2\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/nvidia/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 705 -lifeline 6284 -checkpoint 14 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
15:59:05:WU00:FS01:Started FahCore on PID 1180
15:59:05:WU00:FS01:Core PID:7136
15:59:05:WU00:FS01:FahCore 0x21 started
15:59:05:WU02:FS00:Starting
15:59:05:WU02:FS00:Running FahCore: "C:\Program Files (x86)shared power\FAHClient/FAHCoreWrapper.exe" C:\Users\LGB2017v2\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 6284 -checkpoint 14 -np 4
15:59:05:WU02:FS00:Started FahCore on PID 7144
15:59:05:WU02:FS00:Core PID:7156
15:59:05:WU02:FS00:FahCore 0xa7 started
15:59:06:WU00:FS01:0x21:*********************** Log Started 2019-12-09T15:59:05Z ***********************
15:59:06:WU00:FS01:0x21:Project: 11714 (Run 0, Clone 6835, Gen 14)
15:59:06:WU00:FS01:0x21:Unit: 0x0000001c8ca304f15b21ad28b0c977dc
15:59:06:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
15:59:06:WU00:FS01:0x21:Machine: 1
15:59:06:WU00:FS01:0x21:Digital signatures verified
15:59:06:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
15:59:06:WU00:FS01:0x21:Version 0.0.20
15:59:06:WU02:FS00:0xa7:*********************** Log Started 2019-12-09T15:59:05Z ***********************
15:59:06:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
15:59:06:WU02:FS00:0xa7: Type: 0xa7
15:59:06:WU02:FS00:0xa7: Core: Gromacs
15:59:06:WU02:FS00:0xa7: Args: -dir 02 -suffix 01 -version 705 -lifeline 7144 -checkpoint 14 -np 4
15:59:06:WU02:FS00:0xa7:************************************ CBang *************************************
15:59:06:WU02:FS00:0xa7: Date: Oct 26 2019
15:59:06:WU02:FS00:0xa7: Time: 01:38:25
15:59:06:WU02:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
15:59:06:WU02:FS00:0xa7: Branch: master
15:59:06:WU02:FS00:0xa7: Compiler: Visual C++ 2008
15:59:06:WU02:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:59:06:WU02:FS00:0xa7: Platform: win32 10
15:59:06:WU02:FS00:0xa7: Bits: 64
15:59:06:WU02:FS00:0xa7: Mode: Release
15:59:06:WU02:FS00:0xa7:************************************ System ************************************
15:59:06:WU02:FS00:0xa7: CPU: Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
15:59:06:WU02:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
15:59:06:WU02:FS00:0xa7: CPUs: 4
15:59:06:WU02:FS00:0xa7: Memory: 7.98GiB
15:59:06:WU02:FS00:0xa7:Free Memory: 4.90GiB
15:59:06:WU02:FS00:0xa7: Threads: WINDOWS_THREADS
15:59:06:WU02:FS00:0xa7: OS Version: 6.1
15:59:06:WU02:FS00:0xa7:Has Battery: false
15:59:06:WU02:FS00:0xa7: On Battery: false
15:59:06:WU02:FS00:0xa7: UTC Offset: 1
15:59:06:WU02:FS00:0xa7: PID: 7156
15:59:06:WU02:FS00:0xa7: CWD: C:\Users\LGB2017v2\AppData\Roaming\FAHClient\work
15:59:06:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
15:59:06:WU02:FS00:0xa7: Version: 0.0.18
15:59:06:WU02:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:59:06:WU02:FS00:0xa7: Copyright: 2019 foldingathome.org
15:59:06:WU02:FS00:0xa7: Homepage: https://foldingathome.org/
15:59:06:WU02:FS00:0xa7: Time: 01:52:30
15:59:06:WU02:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
15:59:06:WU02:FS00:0xa7:************************************ Build *************************************
15:59:06:WU02:FS00:0xa7: SIMD: avx_256
15:59:06:WU02:FS00:0xa7:********************************************************************************
15:59:06:WU02:FS00:0xa7:Project: 14182 (Run 13, Clone 159, Gen 55)
15:59:06:WU02:FS00:0xa7:Unit: 0x0000003d0002894b5cf6849345e122ee
15:59:06:WU02:FS00:0xa7:Digital signatures verified
15:59:06:WU02:FS00:0xa7:Calling: mdrun -s frame55.tpr -o frame55.trr -cpi state.cpt -cpt 14 -nt 4
15:59:06:WU02:FS00:0xa7:ERROR:Guru Meditation #e59cb67096aeb6ba.ce9a4fc3d7db8adc (897288.1794576) '02/01/frame55.trr'
15:59:06:WU02:FS00:0xa7:WARNING:Unexpected exit() call
15:59:06:WU02:FS00:0xa7:WARNING:Unexpected exit from science code
15:59:06:WU02:FS00:0xa7:Saving result file ..\logfile_01.txt
15:59:06:WU02:FS00:0xa7:Saving result file frame55.trr
15:59:10:WU00:FS01:0x21:Completed 0 out of 7500000 steps (0%)
15:59:10:WU00:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
15:59:12:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
15:59:12:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073740777 = 0xc0000417)
15:59:12:WARNING:WU02:FS00:Too many errors, failing
15:59:12:WU02:FS00:Sending unit results: id:02 state:SEND error:FAILED project:14182 run:13 clone:159 gen:55 core:0xa7 unit:0x0000003d0002894b5cf6849345e122ee
15:59:12:WU02:FS00:Connecting to 155.247.166.219:8080
15:59:12:WU02:FS00:Server responded WORK_ACK (400)
15:59:12:WU02:FS00:Cleaning up
15:59:12:WU01:FS00:Connecting to 65.254.110.245:8080
15:59:13:WU01:FS00:Assigned to work server 155.247.166.219
15:59:13:WU01:FS00:Requesting new work unit for slot 00: READY cpu:4 from 155.247.166.219
15:59:13:WU01:FS00:Connecting to 155.247.166.219:8080
15:59:13:WU01:FS00:Downloading 6.65MiB
15:59:16:WU01:FS00:Download complete
15:59:16:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14188 run:0 clone:367 gen:29 core:0xa7 unit:0x000000220002894b5d77e723261cedc8
15:59:16:WU01:FS00:Starting
15:59:16:WU01:FS00:Running FahCore: "C:\Program Files (x86)shared power\FAHClient/FAHCoreWrapper.exe" C:\Users\LGB2017v2\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 6284 -checkpoint 14 -np 4
15:59:16:WU01:FS00:Started FahCore on PID 7988
15:59:16:WU01:FS00:Core PID:8000
15:59:16:WU01:FS00:FahCore 0xa7 started
15:59:16:WU01:FS00:0xa7:*********************** Log Started 2019-12-09T15:59:16Z ***********************
15:59:16:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
15:59:16:WU01:FS00:0xa7: Type: 0xa7
15:59:16:WU01:FS00:0xa7: Core: Gromacs
15:59:16:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 705 -lifeline 7988 -checkpoint 14 -np 4
15:59:16:WU01:FS00:0xa7:************************************ CBang *************************************
15:59:16:WU01:FS00:0xa7: Date: Oct 26 2019
15:59:16:WU01:FS00:0xa7: Time: 01:38:25
15:59:16:WU01:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
15:59:16:WU01:FS00:0xa7: Branch: master
15:59:16:WU01:FS00:0xa7: Compiler: Visual C++ 2008
15:59:16:WU01:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:59:16:WU01:FS00:0xa7: Platform: win32 10
15:59:16:WU01:FS00:0xa7: Bits: 64
15:59:16:WU01:FS00:0xa7: Mode: Release
15:59:16:WU01:FS00:0xa7:************************************ System ************************************
15:59:16:WU01:FS00:0xa7: CPU: Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
15:59:16:WU01:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
15:59:16:WU01:FS00:0xa7: CPUs: 4
15:59:16:WU01:FS00:0xa7: Memory: 7.98GiB
15:59:16:WU01:FS00:0xa7:Free Memory: 4.42GiB
15:59:16:WU01:FS00:0xa7: Threads: WINDOWS_THREADS
15:59:16:WU01:FS00:0xa7: OS Version: 6.1
15:59:16:WU01:FS00:0xa7:Has Battery: false
15:59:16:WU01:FS00:0xa7: On Battery: false
15:59:16:WU01:FS00:0xa7: UTC Offset: 1
15:59:16:WU01:FS00:0xa7: PID: 8000
15:59:16:WU01:FS00:0xa7: CWD: C:\Users\LGB2017v2\AppData\Roaming\FAHClient\work
15:59:16:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
15:59:16:WU01:FS00:0xa7: Version: 0.0.18
15:59:16:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:59:16:WU01:FS00:0xa7: Copyright: 2019 foldingathome.org
15:59:16:WU01:FS00:0xa7: Homepage: https://foldingathome.org/
15:59:16:WU01:FS00:0xa7: Time: 01:52:30
15:59:16:WU01:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
15:59:16:WU01:FS00:0xa7:************************************ Build *************************************
15:59:16:WU01:FS00:0xa7: SIMD: avx_256
15:59:16:WU01:FS00:0xa7:********************************************************************************
15:59:16:WU01:FS00:0xa7:Project: 14188 (Run 0, Clone 367, Gen 29)
15:59:16:WU01:FS00:0xa7:Unit: 0x000000220002894b5d77e723261cedc8
15:59:16:WU01:FS00:0xa7:Reading tar file core.xml
15:59:16:WU01:FS00:0xa7:Reading tar file frame29.tpr
15:59:16:WU01:FS00:0xa7:Digital signatures verified
15:59:16:WU01:FS00:0xa7:Calling: mdrun -s frame29.tpr -o frame29.trr -cpt 14 -nt 4
15:59:25:8:127.0.0.1:New Web connection
16:00:20:WU01:FS00:0xa7:Steps: first=36250000 total=1250000
16:00:58:WU01:FS00:0xa7:Completed 1 out of 1250000 steps (0%)
16:01:41:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
16:01:56:WARNING:WU01:FS00:FahCore crashed with Windows unhandled exception code 0x40010004, searching for this code online may provide more information
16:01:56:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (1073807364 = 0x40010004)
16:01:57:WARNING:WU00:FS01:FahCore crashed with Windows unhandled exception code 0x40010004, searching for this code online may provide more information
16:01:57:WARNING:WU00:FS01:FahCore returned: UNKNOWN_ENUM (1073807364 = 0x40010004)
16:01:57:WU01:FS00:Starting
16:01:57:WU01:FS00:Running FahCore: "C:\Program Files (x86)shared power\FAHClient/FAHCoreWrapper.exe" C:\Users\LGB2017v2\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 6284 -checkpoint 14 -np 4
16:01:57:WU01:FS00:Started FahCore on PID 932
16:01:57:WU01:FS00:FahCore 0xa7 started
16:01:57:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
16:01:57:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073741205 = 0xc000026b)
16:01:57:WU00:FS01:Starting
16:01:57:WU00:FS01:Running FahCore: "C:\Program Files (x86)shared power\FAHClient/FAHCoreWrapper.exe" C:\Users\LGB2017v2\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/nvidia/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 705 -lifeline 6284 -checkpoint 14 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
16:01:57:WU00:FS01:Started FahCore on PID 7232
16:01:57:WU00:FS01:FahCore 0x21 started
16:01:58:WARNING:WU00:FS01:FahCore returned an unknown error code which probably indicates that it crashed
16:01:58:WARNING:WU00:FS01:FahCore returned: UNKNOWN_ENUM (-1073741205 = 0xc000026b)
*********************** Log Started 2019-12-09T16:03:06Z ***********************
16:03:06:************************* Folding@home Client *************************
16:03:06: Website: https://foldingathome.org/
16:03:06: Copyright: (c) 2009-2018 foldingathome.org
16:03:06: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:03:06: Args:
16:03:06: Config: C:\Users\LGB2017v2\AppData\Roaming\FAHClient\config.xml
16:03:06:******************************** Build ********************************
16:03:06: Version: 7.5.1
16:03:06: Date: May 11 2018
16:03:06: Time: 13:06:32
16:03:06: Repository: Git
16:03:06: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
16:03:06: Branch: master
16:03:06: Compiler: Visual C++ 2008
16:03:06: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
16:03:06: Platform: win32 10
16:03:06: Bits: 32
16:03:06: Mode: Release
16:03:06:******************************* System ********************************
16:03:06: CPU: Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
16:03:06: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
16:03:06: CPUs: 4
16:03:06: Memory: 7.98GiB
16:03:06: Free Memory: 6.29GiB
16:03:06: Threads: WINDOWS_THREADS
16:03:06: OS Version: 6.1
16:03:06: Has Battery: false
16:03:06: On Battery: false
16:03:06: UTC Offset: 1
16:03:06: PID: 4540
16:03:06: CWD: C:\Users\LGB2017v2\AppData\Roaming\FAHClient
16:03:06: OS: Windows 7 Ultimate
16:03:06: OS Arch: AMD64
16:03:06: GPUs: 1
16:03:06: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 GP106 [GeForce GTX 1060 6GB] 4372
16:03:06: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.2
16:03:06:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:441.20
16:03:06: Win32 Service: false
16:03:06:***********************************************************************
16:03:06:<config>
16:03:06: <!-- Folding Core -->
16:03:06: <checkpoint v='14'/>
16:03:06:
16:03:06: <!-- Network -->
16:03:06: <proxy v=':8080'/>
16:03:06:
16:03:06: <!-- Slot Control -->
16:03:06: <power v='full'/>
16:03:06:
16:03:06: <!-- User Information -->
16:03:06: <team v='235464'/>
16:03:06: <user v='ledgeri#9625'/>
16:03:06:
16:03:06: <!-- Folding Slots -->
16:03:06: <slot id='0' type='CPU'>
16:03:06: <cpus v='4'/>
16:03:06: </slot>
16:03:06: <slot id='1' type='GPU'/>
16:03:06:</config>
16:03:06:Trying to access database...
16:03:06:Successfully acquired database lock
16:03:06:Enabled folding slot 00: READY cpu:4
16:03:06:Enabled folding slot 01: READY gpu:0:GP106 [GeForce GTX 1060 6GB] 4372
16:03:06:WU01:FS00:Starting
16:03:06:WU01:FS00:Running FahCore: "C:\Program Files (x86)shared power\FAHClient/FAHCoreWrapper.exe" C:\Users\LGB2017v2\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 4540 -checkpoint 14 -np 4
16:03:06:WU01:FS00:Started FahCore on PID 4432
16:03:06:WU01:FS00:Core PID:4400
16:03:06:WU01:FS00:FahCore 0xa7 started
16:03:06:WU00:FS01:Starting
16:03:06:WU00:FS01:Running FahCore: "C:\Program Files (x86)shared power\FAHClient/FAHCoreWrapper.exe" C:\Users\LGB2017v2\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/nvidia/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 705 -lifeline 4540 -checkpoint 14 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
16:03:06:WU00:FS01:Started FahCore on PID 256
16:03:06:WU00:FS01:Core PID:928
16:03:06:WU00:FS01:FahCore 0x21 started
16:03:07:WU01:FS00:0xa7:*********************** Log Started 2019-12-09T16:03:07Z ***********************
16:03:07:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
16:03:07:WU01:FS00:0xa7: Type: 0xa7
16:03:07:WU01:FS00:0xa7: Core: Gromacs
16:03:07:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 705 -lifeline 4432 -checkpoint 14 -np 4
16:03:07:WU01:FS00:0xa7:************************************ CBang *************************************
16:03:07:WU01:FS00:0xa7: Date: Oct 26 2019
16:03:07:WU01:FS00:0xa7: Time: 01:38:25
16:03:07:WU01:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
16:03:07:WU01:FS00:0xa7: Branch: master
16:03:07:WU01:FS00:0xa7: Compiler: Visual C++ 2008
16:03:07:WU01:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
16:03:07:WU01:FS00:0xa7: Platform: win32 10
16:03:07:WU01:FS00:0xa7: Bits: 64
16:03:07:WU01:FS00:0xa7: Mode: Release
16:03:07:WU01:FS00:0xa7:************************************ System ************************************
16:03:07:WU01:FS00:0xa7: CPU: Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
16:03:07:WU01:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
16:03:07:WU01:FS00:0xa7: CPUs: 4
16:03:07:WU01:FS00:0xa7: Memory: 7.98GiB
16:03:07:WU01:FS00:0xa7:Free Memory: 6.13GiB
16:03:07:WU01:FS00:0xa7: Threads: WINDOWS_THREADS
16:03:07:WU01:FS00:0xa7: OS Version: 6.1
16:03:07:WU01:FS00:0xa7:Has Battery: false
16:03:07:WU01:FS00:0xa7: On Battery: false
16:03:07:WU01:FS00:0xa7: UTC Offset: 1
16:03:07:WU01:FS00:0xa7: PID: 4400
16:03:07:WU01:FS00:0xa7: CWD: C:\Users\LGB2017v2\AppData\Roaming\FAHClient\work
16:03:07:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
16:03:07:WU01:FS00:0xa7: Version: 0.0.18
16:03:07:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:03:07:WU01:FS00:0xa7: Copyright: 2019 foldingathome.org
16:03:07:WU01:FS00:0xa7: Homepage: https://foldingathome.org/
16:03:07:WU01:FS00:0xa7: Time: 01:52:30
16:03:07:WU01:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
16:03:07:WU01:FS00:0xa7:************************************ Build *************************************
16:03:07:WU01:FS00:0xa7: SIMD: avx_256
16:03:07:WU01:FS00:0xa7:********************************************************************************
16:03:07:WU01:FS00:0xa7:Project: 14188 (Run 0, Clone 367, Gen 29)
16:03:07:WU01:FS00:0xa7:Unit: 0x000000220002894b5d77e723261cedc8
16:03:07:WU01:FS00:0xa7:Digital signatures verified
16:03:07:WU01:FS00:0xa7:Calling: mdrun -s frame29.tpr -o frame29.trr -cpt 14 -nt 4
16:03:07:WU00:FS01:0x21:*********************** Log Started 2019-12-09T16:03:07Z ***********************
16:03:07:WU00:FS01:0x21:Project: 11714 (Run 0, Clone 6835, Gen 14)
16:03:07:WU00:FS01:0x21:Unit: 0x0000001c8ca304f15b21ad28b0c977dc
16:03:07:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
16:03:07:WU00:FS01:0x21:Machine: 1
16:03:07:WU00:FS01:0x21:Digital signatures verified
16:03:07:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
16:03:07:WU00:FS01:0x21:Version 0.0.20
16:03:11:WU01:FS00:0xa7:Steps: first=36250000 total=1250000
16:03:20:WU01:FS00:0xa7:Completed 1 out of 1250000 steps (0%)
16:03:25:WU00:FS01:0x21:Completed 0 out of 7500000 steps (0%)
16:03:25:WU00:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
16:07:05:WU00:FS01:0x21:Completed 75000 out of 7500000 steps (1%)
16:10:33:WU00:FS01:0x21:Completed 150000 out of 7500000 steps (2%)
16:14:00:WU00:FS01:0x21:Completed 225000 out of 7500000 steps (3%)
16:17:31:WU00:FS01:0x21:Completed 300000 out of 7500000 steps (4%)
16:18:34:FS00:Paused
16:18:34:FS01:Paused
16:18:34:FS00:Shutting core down
16:18:34:FS01:Shutting core down
16:18:34:WU01:FS00:0xa7:WARNING:Console control signal 1 on PID 4400
16:18:34:WU01:FS00:0xa7:Exiting, please wait. . .
16:18:35:WU00:FS01:0x21:WARNING:Console control signal 1 on PID 928
16:18:35:WU00:FS01:0x21:Exiting, please wait. . .
16:18:35:WU00:FS01:0x21:Folding@home Core Shutdown: INTERRUPTED
16:18:35:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
16:18:39:WU01:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
16:18:39:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
16:19:22:Removing old file 'configs/config-20191206-022428.xml'
16:19:22:Saving configuration to config.xml
16:19:22:<config>
16:19:22: <!-- Folding Core -->
16:19:22: <checkpoint v='14'/>
16:19:22:
16:19:22: <!-- Network -->
16:19:22: <proxy v=':8080'/>
16:19:22:
16:19:22: <!-- Slot Control -->
16:19:22: <power v='full'/>
16:19:22:
16:19:22: <!-- User Information -->
16:19:22: <team v='235464'/>
16:19:22: <user v='ledgeri#9625'/>
16:19:22:
16:19:22: <!-- Folding Slots -->
16:19:22: <slot id='0' type='CPU'>
16:19:22: <cpus v='4'/>
16:19:22: <paused v='true'/>
16:19:22: </slot>
16:19:22: <slot id='1' type='GPU'>
16:19:22: </slot>
16:19:22:</config>
16:32:59:FS00:Unpaused
16:32:59:FS01:Unpaused
16:32:59:WU01:FS00:Starting
16:32:59:WU01:FS00:Running FahCore: "C:\Program Files (x86)shared power\FAHClient/FAHCoreWrapper.exe" C:\Users\LGB2017v2\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 4540 -checkpoint 14 -np 4
16:32:59:WU01:FS00:Started FahCore on PID 7552
16:32:59:WU01:FS00:Core PID:6520
16:32:59:WU01:FS00:FahCore 0xa7 started
16:33:00:WU00:FS01:Starting
16:33:00:WU00:FS01:Running FahCore: "C:\Program Files (x86)shared power\FAHClient/FAHCoreWrapper.exe" C:\Users\LGB2017v2\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/nvidia/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 705 -lifeline 4540 -checkpoint 14 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
16:33:00:WU00:FS01:Started FahCore on PID 7924
16:33:00:WU00:FS01:Core PID:7232
16:33:00:WU00:FS01:FahCore 0x21 started
16:33:00:WU01:FS00:0xa7:*********************** Log Started 2019-12-09T16:33:00Z ***********************
16:33:00:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
16:33:00:WU01:FS00:0xa7: Type: 0xa7
16:33:00:WU01:FS00:0xa7: Core: Gromacs
16:33:00:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 705 -lifeline 7552 -checkpoint 14 -np 4
16:33:00:WU01:FS00:0xa7:************************************ CBang *************************************
16:33:00:WU01:FS00:0xa7: Date: Oct 26 2019
16:33:00:WU01:FS00:0xa7: Time: 01:38:25
16:33:00:WU01:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
16:33:00:WU01:FS00:0xa7: Branch: master
16:33:00:WU01:FS00:0xa7: Compiler: Visual C++ 2008
16:33:00:WU01:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
16:33:00:WU01:FS00:0xa7: Platform: win32 10
16:33:00:WU01:FS00:0xa7: Bits: 64
16:33:00:WU01:FS00:0xa7: Mode: Release
16:33:00:WU01:FS00:0xa7:************************************ System ************************************
16:33:00:WU01:FS00:0xa7: CPU: Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
16:33:00:WU01:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
16:33:00:WU01:FS00:0xa7: CPUs: 4
16:33:00:WU01:FS00:0xa7: Memory: 7.98GiB
16:33:00:WU01:FS00:0xa7:Free Memory: 2.04GiB
16:33:00:WU01:FS00:0xa7: Threads: WINDOWS_THREADS
16:33:00:WU01:FS00:0xa7: OS Version: 6.1
16:33:00:WU01:FS00:0xa7:Has Battery: false
16:33:00:WU01:FS00:0xa7: On Battery: false
16:33:00:WU01:FS00:0xa7: UTC Offset: 1
16:33:00:WU01:FS00:0xa7: PID: 6520
16:33:00:WU01:FS00:0xa7: CWD: C:\Users\LGB2017v2\AppData\Roaming\FAHClient\work
16:33:00:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
16:33:00:WU01:FS00:0xa7: Version: 0.0.18
16:33:00:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:33:00:WU01:FS00:0xa7: Copyright: 2019 foldingathome.org
16:33:00:WU01:FS00:0xa7: Homepage: https://foldingathome.org/
16:33:00:WU01:FS00:0xa7: Time: 01:52:30
16:33:00:WU01:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
16:33:00:WU01:FS00:0xa7:************************************ Build *************************************
16:33:00:WU01:FS00:0xa7: SIMD: avx_256
16:33:00:WU01:FS00:0xa7:********************************************************************************
16:33:00:WU01:FS00:0xa7:Project: 14188 (Run 0, Clone 367, Gen 29)
16:33:00:WU01:FS00:0xa7:Unit: 0x000000220002894b5d77e723261cedc8
16:33:00:WU01:FS00:0xa7:Digital signatures verified
16:33:00:WU01:FS00:0xa7:Calling: mdrun -s frame29.tpr -o frame29.trr -cpi state.cpt -cpt 14 -nt 4
16:33:00:WU00:FS01:0x21:*********************** Log Started 2019-12-09T16:33:00Z ***********************
16:33:00:WU00:FS01:0x21:Project: 11714 (Run 0, Clone 6835, Gen 14)
16:33:00:WU00:FS01:0x21:Unit: 0x0000001c8ca304f15b21ad28b0c977dc
16:33:00:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
16:33:00:WU00:FS01:0x21:Machine: 1
16:33:00:WU00:FS01:0x21:Digital signatures verified
16:33:00:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
16:33:00:WU00:FS01:0x21:Version 0.0.20
16:33:00:WU00:FS01:0x21: Found a checkpoint file
16:33:00:WU01:FS00:0xa7:Steps: first=36250000 total=1250000
16:33:02:WU01:FS00:0xa7:Completed 1452 out of 1250000 steps (0%)
16:33:05:WU00:FS01:0x21:Completed 250000 out of 7500000 steps (3%)
16:33:05:WU00:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
16:33:36:Removing old file 'configs/config-20191206-025902.xml'
16:33:36:Saving configuration to config.xml
16:33:36:<config>
16:33:36: <!-- Folding Core -->
16:33:36: <checkpoint v='14'/>
16:33:36:
16:33:36: <!-- Network -->
16:33:36: <proxy v=':8080'/>
16:33:36:
16:33:36: <!-- Slot Control -->
16:33:36: <power v='full'/>
16:33:36:
16:33:36: <!-- User Information -->
16:33:36: <team v='235464'/>
16:33:36: <user v='ledgeri#9625'/>
16:33:36:
16:33:36: <!-- Folding Slots -->
16:33:36: <slot id='0' type='CPU'>
16:33:36: <cpus v='4'/>
16:33:36: </slot>
16:33:36: <slot id='1' type='GPU'/>
16:33:36:</config>
16:35:24:WU00:FS01:0x21:Completed 300000 out of 7500000 steps (4%)
16:38:52:WU00:FS01:0x21:Completed 375000 out of 7500000 steps (5%)
16:40:35:FS00:Paused
16:40:35:FS01:Paused
16:40:35:FS00:Shutting core down
16:40:35:FS01:Shutting core down
16:40:35:WU01:FS00:0xa7:WARNING:Console control signal 1 on PID 6520
16:40:35:WU01:FS00:0xa7:Exiting, please wait. . .
16:40:35:WU00:FS01:0x21:WARNING:Console control signal 1 on PID 7232
16:40:35:WU00:FS01:0x21:Exiting, please wait. . .
16:40:35:WU00:FS01:0x21:Folding@home Core Shutdown: INTERRUPTED
16:40:36:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
16:40:38:WU01:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
16:40:38:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
16:40:43:Removing old file 'configs/config-20191206-222113.xml'
16:40:43:Saving configuration to config.xml
16:40:43:<config>
16:40:43: <!-- Folding Core -->
16:40:43: <checkpoint v='14'/>
16:40:43:
16:40:43: <!-- Network -->
16:40:43: <proxy v=':8080'/>
16:40:43:
16:40:43: <!-- Slot Control -->
16:40:43: <power v='full'/>
16:40:43:
16:40:43: <!-- User Information -->
16:40:43: <team v='235464'/>
16:40:43: <user v='ledgeri#9625'/>
16:40:43:
16:40:43: <!-- Folding Slots -->
16:40:43: <slot id='0' type='CPU'>
16:40:43: <cpus v='4'/>
16:40:43: <paused v='true'/>
16:40:43: </slot>
16:40:43: <slot id='1' type='GPU'>
16:40:43: </slot>
16:40:43:</config>
I'm not sure I understand either that statement or the separate logs you posted. FAH is designed for a single installation that can run more than one type of analysis concurrently, using all of your hardware capabilites. How/why do you show each FAHCore running separately.As a reply at instal i selected the start with system option, but installed it into an other folder than strictly the base, but no other modification.
I would expect two slots to be created at install time and both would be running. FAHCore_21 would use your GPU and one CPU thread. FAHCore_a7 would use the other three CPU threads. When you start Firefox (or whatever), FAHCore_a7 would slow down slightly, of course.
Error 0xC000026B only happens when your Software Registry is corrupt. That's a serious problem and needs to be corrected. You can download a Microsoft tool that's supposed to help fix it but I've never needed it. Your GURU MEDITATION errors suggest some serious problems with your file system or actual hardware errors.
Have you checked your disk and run standard diagnostics recently?
Thanks for the reply!
Idid not modified anyting, what could result as an "unusual separation", so that is a question to me to... (For the quoute, i only made the change on the isntall directory, by chnging from the base */programfiles/* to what i used to do in the current istall of windows, where i change it to */programfiles "reminder to me"/* so i see one step abow what am i looking for... The other, it popped up when i intalled, how i wanted to start the program, at startup (after login) or manually)
I did some disk diagnostics, yeah...
What is what i should search for, to solve the registry issues?
And my main question still up: can i skip this work? As i see the TPF is 3,5 hours. Knowing myself i barley letting the system running that long (with folding), so either way, that would not be finished at me.... while i could do work on other smaller packed projects.
FAH expects you to run FAHClient continuously ... or at least long enough to finish the assigned WUs. Once it's downloaded, you can select FINISH in FAHControl and it will not download a next WU to be processed.
To delete a WU that's not going to be able to finish, first determine the WU number (not the slot number) of the assigned WU. Each line in the log is preceded by something like this:
02:03:13:WU02:FS00:0xa7:...
The worldwide time (known as UTC or GMT or simply Z): the WU number: the FAH Slot number:the applicable FAHCore number:(the message). When multiple WUs have been downloaded, they will each have a different WU number. The Slot number and the FAHCore number help you to mentally sort out which messages come from each WU or that information can be filtered by FAHControl's log viewer.
Slots are assigned at install time. WU Numbers are established at the time the WU is downloaded and unassigned when the WU finishes.
The official method of dumping a WU is to run "FAHClient -- dump xx" (where xx is the WU number ... xx=02 in the example shown above). This acton will also notify the server that it needs to assign a duplicate WU to someone else.
The unofficial method of dumping a WU is do drill down to the "work" directory, and after pausing the WU, delete the subdirectory with the WU number (again, "02" in this example) and then unpause in FAHClient. It will discover the missing files, clean up any leftovers for the WU and (hopefully) notify the server that the WU will not be completed by you.
Thanks!bruce wrote:...
The official method of dumping a WU....
Whare should i run that? (I just checked the reply earlier, but now i do not know where to start...)bruce wrote:
Re: Can i skip my part on a project?
I had to do on the unofficial way: i have tried as launching it with shortcut pararameter, with using CMG "vannilla" [my failed attampt], with just searching to it and running it what i found, and by running as administrator the last... nothing helped
Now i have a new work, what initially started with 1 hour TPF, but after its first tick it is constantly at the managable 6 min mark, as before! So thank you!
And sorry team with the skipped WU!
When you are assigned a WU from a project that has no history on your hardware, your system has no useful information to estimate your system's performance. After some progress has been recorded, the estimates are based on actual facts.
Update:
I started running my PC, now "i had time to let it run". I started an antivirus program to check its stuff, at lest other work will be done in the same timeframe. After a while i chacked back and i saw FAH shows CPU:3, so i thought give it more, so i changed the CPU thread count from -1 to 4. Went away. Chacked back again, and i saw the antivir not progresses as usual, and like before the change, so i changed back the thread count. Went away again.
When i checked back the third time, i saw the FahCore_a7.exe crashed again (antivir finished its thing), clicked OK and it kept crashing. I gave the system a reboot, then at startup the exe crashed again one, and when it stood up i saw, it dropped the previously 90+% done poject (13***), and Downloaded back the #14188, what i dumped before. And from the logs the CPU's WU nimber switched from 00 to 01, and pushed up the GPU's WU number to 02....
*********************** Log Started 2019-12-13T14:09:13Z ***********************
14:09:13:************************* Folding@home Client *************************
14:09:13: Website: https://foldingathome.org/
14:09:13: Copyright: (c) 2009-2018 foldingathome.org
14:09:13: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:09:13: Args:
14:09:13: Config: C:\Users\LGB2017v2\AppData\Roaming\FAHClient\config.xml
14:09:13:******************************** Build ********************************
14:09:13: Version: 7.5.1
14:09:13: Date: May 11 2018
14:09:13: Time: 13:06:32
14:09:13: Repository: Git
14:09:13: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
14:09:13: Branch: master
14:09:13: Compiler: Visual C++ 2008
14:09:13: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:09:13: Platform: win32 10
14:09:13: Bits: 32
14:09:13: Mode: Release
14:09:13:******************************* System ********************************
14:09:13: CPU: Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
14:09:13: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
14:09:13: CPUs: 4
14:09:13: Memory: 7.98GiB
14:09:13: Free Memory: 6.22GiB
14:09:13: Threads: WINDOWS_THREADS
14:09:13: OS Version: 6.1
14:09:13: Has Battery: false
14:09:13: On Battery: false
14:09:13: UTC Offset: 1
14:09:13: PID: 4968
14:09:13: CWD: C:\Users\LGB2017v2\AppData\Roaming\FAHClient
14:09:13: OS: Windows 7 Ultimate
14:09:13: OS Arch: AMD64
14:09:13: GPUs: 1
14:09:13: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 GP106 [GeForce GTX 1060 6GB] 4372
14:09:13: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.2
14:09:13:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:441.20
14:09:13: Win32 Service: false
14:09:13:***********************************************************************
14:09:13:<config>
14:09:13: <!-- Folding Core -->
14:09:13: <checkpoint v='10'/>
14:09:13:
14:09:13: <!-- Network -->
14:09:13: <proxy v=':8080'/>
14:09:13:
14:09:13: <!-- Slot Control -->
14:09:13: <power v='full'/>
14:09:13:
14:09:13: <!-- User Information -->
14:09:13: <team v='235464'/>
14:09:13: <user v='ledgeri#9625'/>
14:09:13:
14:09:13: <!-- Folding Slots -->
14:09:13: <slot id='0' type='CPU'>
14:09:13: <paused v='true'/>
14:09:13: </slot>
14:09:13: <slot id='1' type='GPU'>
14:09:13: </slot>
14:09:13:</config>
14:09:13:Trying to access database...
14:09:13:Successfully acquired database lock
14:09:13:Enabled folding slot 00: PAUSED cpu:3 (by user)
14:09:13:Enabled folding slot 01: PAUSED gpu:0:GP106 [GeForce GTX 1060 6GB] 4372 (by user)
14:09:38:FS00:Unpaused
14:09:38:FS01:Unpaused
14:09:38:WU02:FS01:Starting
14:09:38:WU02:FS01:Running FahCore: "C:\Program Files (x86)shared power\FAHClient/FAHCoreWrapper.exe" C:\Users\LGB2017v2\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/nvidia/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 705 -lifeline 4968 -checkpoint 10 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
14:09:38:WU02:FS01:Started FahCore on PID 7276
14:09:39:WU02:FS01:Core PID:2488
14:09:39:WU02:FS01:FahCore 0x21 started
14:09:39:WU00:FS00:Starting
14:09:39:WU00:FS00:Running FahCore: "C:\Program Files (x86)shared power\FAHClient/FAHCoreWrapper.exe" C:\Users\LGB2017v2\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 4968 -checkpoint 10 -np 3
14:09:39:WU00:FS00:Started FahCore on PID 7504
14:09:39:WU00:FS00:Core PID:7508
14:09:39:WU00:FS00:FahCore 0xa7 started
14:09:39:WU02:FS01:0x21:*********************** Log Started 2019-12-13T14:09:39Z ***********************
14:09:39:WU02:FS01:0x21:Project: 11714 (Run 0, Clone 2732, Gen 40)
14:09:39:WU02:FS01:0x21:Unit: 0x000000488ca304f15b21ad23b719664f
14:09:39:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
14:09:39:WU02:FS01:0x21:Machine: 1
14:09:39:WU02:FS01:0x21:Digital signatures verified
14:09:39:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
14:09:39:WU02:FS01:0x21:Version 0.0.20
14:09:39:WU00:FS00:0xa7:*********************** Log Started 2019-12-13T14:09:39Z ***********************
14:09:39:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
14:09:39:WU00:FS00:0xa7: Type: 0xa7
14:09:39:WU00:FS00:0xa7: Core: Gromacs
14:09:39:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 705 -lifeline 7504 -checkpoint 10 -np 3
14:09:39:WU00:FS00:0xa7:************************************ CBang *************************************
14:09:39:WU00:FS00:0xa7: Date: Oct 26 2019
14:09:39:WU00:FS00:0xa7: Time: 01:38:25
14:09:39:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
14:09:39:WU00:FS00:0xa7: Branch: master
14:09:39:WU00:FS00:0xa7: Compiler: Visual C++ 2008
14:09:39:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:09:39:WU00:FS00:0xa7: Platform: win32 10
14:09:39:WU00:FS00:0xa7: Bits: 64
14:09:39:WU00:FS00:0xa7: Mode: Release
14:09:39:WU00:FS00:0xa7:************************************ System ************************************
14:09:39:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
14:09:39:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
14:09:39:WU00:FS00:0xa7: CPUs: 4
14:09:39:WU00:FS00:0xa7: Memory: 7.98GiB
14:09:39:WU00:FS00:0xa7:Free Memory: 5.02GiB
14:09:39:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
14:09:39:WU00:FS00:0xa7: OS Version: 6.1
14:09:39:WU00:FS00:0xa7:Has Battery: false
14:09:39:WU00:FS00:0xa7: On Battery: false
14:09:39:WU00:FS00:0xa7: UTC Offset: 1
14:09:39:WU00:FS00:0xa7: PID: 7508
14:09:39:WU00:FS00:0xa7: CWD: C:\Users\LGB2017v2\AppData\Roaming\FAHClient\work
14:09:39:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
14:09:39:WU00:FS00:0xa7: Version: 0.0.18
14:09:39:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:09:39:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
14:09:39:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
14:09:39:WU00:FS00:0xa7: Time: 01:52:30
14:09:39:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
14:09:39:WU00:FS00:0xa7:************************************ Build *************************************
14:09:39:WU00:FS00:0xa7: SIMD: avx_256
14:09:39:WU00:FS00:0xa7:********************************************************************************
14:09:39:WU00:FS00:0xa7:Project: 13828 (Run 617, Clone 2, Gen 80)
14:09:39:WU00:FS00:0xa7:Unit: 0x0000005980fccb095d657f731c7de91d
14:09:39:WU00:FS00:0xa7:Digital signatures verified
14:09:39:WU00:FS00:0xa7:Calling: mdrun -s frame80.tpr -o frame80.trr -x frame80.xtc -cpi state.cpt -cpt 10 -nt 3
14:09:44:WU00:FS00:0xa7:Steps: first=10000000 total=125000
14:09:47:WU02:FS01:0x21:Completed 0 out of 7500000 steps (0%)
14:09:47:WU02:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
14:09:58:WU00:FS00:0xa7:Completed 82892 out of 125000 steps (66%)
14:10:14:Removing old file 'configs/config-20191212-005944.xml'
14:10:14:Saving configuration to config.xml
14:10:14:<config>
14:10:14: <!-- Folding Core -->
14:10:14: <checkpoint v='10'/>
14:10:14:
14:10:14: <!-- Network -->
14:10:14: <proxy v=':8080'/>
14:10:14:
14:10:14: <!-- Slot Control -->
14:10:14: <power v='full'/>
14:10:14:
14:10:14: <!-- User Information -->
14:10:14: <team v='235464'/>
14:10:14: <user v='ledgeri#9625'/>
14:10:14:
14:10:14: <!-- Folding Slots -->
14:10:14: <slot id='0' type='CPU'/>
14:10:14: <slot id='1' type='GPU'/>
14:10:14:</config>
14:14:37:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
14:16:16:WU02:FS01:0x21:Completed 75000 out of 7500000 steps (1%)
14:16:57:WU00:FS00:0xa7:Completed 83750 out of 125000 steps (67%)
16:42:57:WU00:FS00:0xa7:Completed 113750 out of 125000 steps (91%)
16:44:14:WU02:FS01:0x21:Completed 1575000 out of 7500000 steps (21%)
16:47:40:Removing old file 'configs/config-20191212-050744.xml'
16:47:40:Saving configuration to config.xml
16:47:40:<config>
16:47:40: <!-- Folding Core -->
16:47:40: <checkpoint v='10'/>
16:47:40:
16:47:40: <!-- Network -->
16:47:40: <proxy v=':8080'/>
16:47:40:
16:47:40: <!-- Slot Control -->
16:47:40: <power v='full'/>
16:47:40:
16:47:40: <!-- User Information -->
16:47:40: <team v='235464'/>
16:47:40: <user v='ledgeri#9625'/>
16:47:40:
16:47:40: <!-- Folding Slots -->
16:47:40: <slot id='0' type='CPU'>
16:47:40: <cpus v='4'/>
16:47:40: </slot>
16:47:40: <slot id='1' type='GPU'/>
16:47:40:</config>
16:47:40:FS00:Shutting core down
16:47:40:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 7508
16:47:40:WU00:FS00:0xa7:Exiting, please wait. . .
16:47:46:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
16:47:47:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
16:47:47:WU00:FS00:Starting
16:47:47:WARNING:WU00:FS00:Changed SMP threads from 3 to 4 this can cause some work units to fail
16:47:47:WU00:FS00:Running FahCore: "C:\Program Files (x86)shared power\FAHClient/FAHCoreWrapper.exe" C:\Users\LGB2017v2\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 4968 -checkpoint 10 -np 4
16:47:47:WU00:FS00:Started FahCore on PID 8292
16:47:47:WU00:FS00:Core PID:8456
16:47:47:WU00:FS00:FahCore 0xa7 started
16:47:47:WU00:FS00:0xa7:*********************** Log Started 2019-12-13T16:47:47Z ***********************
16:47:47:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
16:47:47:WU00:FS00:0xa7: Type: 0xa7
16:47:47:WU00:FS00:0xa7: Core: Gromacs
16:47:47:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 705 -lifeline 8292 -checkpoint 10 -np 4
16:47:47:WU00:FS00:0xa7:************************************ CBang *************************************
16:47:47:WU00:FS00:0xa7: Date: Oct 26 2019
16:47:47:WU00:FS00:0xa7: Time: 01:38:25
16:47:47:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
16:47:47:WU00:FS00:0xa7: Branch: master
16:47:47:WU00:FS00:0xa7: Compiler: Visual C++ 2008
16:47:47:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
16:47:47:WU00:FS00:0xa7: Platform: win32 10
16:47:47:WU00:FS00:0xa7: Bits: 64
16:47:47:WU00:FS00:0xa7: Mode: Release
16:47:47:WU00:FS00:0xa7:************************************ System ************************************
16:47:47:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
16:47:47:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
16:47:47:WU00:FS00:0xa7: CPUs: 4
16:47:47:WU00:FS00:0xa7: Memory: 7.98GiB
16:47:47:WU00:FS00:0xa7:Free Memory: 3.82GiB
16:47:47:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
16:47:47:WU00:FS00:0xa7: OS Version: 6.1
16:47:47:WU00:FS00:0xa7:Has Battery: false
16:47:47:WU00:FS00:0xa7: On Battery: false
16:47:47:WU00:FS00:0xa7: UTC Offset: 1
16:47:47:WU00:FS00:0xa7: PID: 8456
16:47:47:WU00:FS00:0xa7: CWD: C:\Users\LGB2017v2\AppData\Roaming\FAHClient\work
16:47:47:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
16:47:47:WU00:FS00:0xa7: Version: 0.0.18
16:47:47:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:47:47:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
16:47:47:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
16:47:47:WU00:FS00:0xa7: Time: 01:52:30
16:47:47:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
16:47:47:WU00:FS00:0xa7:************************************ Build *************************************
16:47:47:WU00:FS00:0xa7: SIMD: avx_256
16:47:47:WU00:FS00:0xa7:********************************************************************************
16:47:47:WU00:FS00:0xa7:Project: 13828 (Run 617, Clone 2, Gen 80)
16:47:47:WU00:FS00:0xa7:Unit: 0x0000005980fccb095d657f731c7de91d
16:47:47:WU00:FS00:0xa7:Digital signatures verified
16:47:47:WU00:FS00:0xa7:Calling: mdrun -s frame80.tpr -o frame80.trr -x frame80.xtc -cpi state.cpt -cpt 10 -nt 4
16:48:03:WU00:FS00:0xa7:Steps: first=10000000 total=125000
16:48:04:Removing old file 'configs/config-20191212-050824.xml'
16:48:04:Saving configuration to config.xml
16:48:04:<config>
16:48:04: <!-- Folding Core -->
16:48:04: <checkpoint v='10'/>
16:48:04:
16:48:04: <!-- Network -->
16:48:04: <proxy v=':8080'/>
16:48:04:
16:48:04: <!-- Slot Control -->
16:48:04: <power v='full'/>
16:48:04:
16:48:04: <!-- User Information -->
16:48:04: <team v='235464'/>
16:48:04: <user v='ledgeri#9625'/>
16:48:04:
16:48:04: <!-- Folding Slots -->
16:48:04: <slot id='0' type='CPU'>
16:48:04: <cpus v='4'/>
16:48:04: </slot>
16:48:04: <slot id='1' type='GPU'/>
16:48:04:</config>
16:48:05:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
16:48:13:Removing old file 'configs/config-20191212-050839.xml'
16:48:13:Saving configuration to config.xml
16:48:13:<config>
16:48:13: <!-- Folding Core -->
16:48:13: <checkpoint v='10'/>
16:48:13:
16:48:13: <!-- Network -->
16:48:13: <proxy v=':8080'/>
16:48:13:
16:48:13: <!-- Slot Control -->
16:48:13: <power v='full'/>
16:48:13:
16:48:13: <!-- User Information -->
16:48:13: <team v='235464'/>
16:48:13: <user v='ledgeri#9625'/>
16:48:13:
16:48:13: <!-- Folding Slots -->
16:48:13: <slot id='0' type='CPU'/>
16:48:13: <slot id='1' type='GPU'/>
16:48:13:</config>
16:48:13:FS00:Shutting core down
16:48:13:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 8456
16:48:13:WU00:FS00:0xa7:Exiting, please wait. . .
16:49:03:WU00:FS00:0xa7:Completed 114942 out of 125000 steps (91%)
16:49:05:Removing old file 'configs/config-20191212-052134.xml'
16:49:05:Saving configuration to config.xml
16:49:05:<config>
16:49:05: <!-- Folding Core -->
16:49:05: <checkpoint v='10'/>
16:49:05:
16:49:05: <!-- Network -->
16:49:05: <proxy v=':8080'/>
16:49:05:
16:49:05: <!-- Slot Control -->
16:49:05: <power v='full'/>
16:49:05:
16:49:05: <!-- User Information -->
16:49:05: <team v='235464'/>
16:49:05: <user v='ledgeri#9625'/>
16:49:05:
16:49:05: <!-- Folding Slots -->
16:49:05: <slot id='0' type='CPU'/>
16:49:05: <slot id='1' type='GPU'/>
16:49:05:</config>
16:49:14:WARNING:FS00:Killing WU00
16:49:14:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
16:49:14:WU00:FS00:Starting
16:49:14:WARNING:WU00:FS00:Changed SMP threads from 4 to 3 this can cause some work units to fail
16:49:14:WU00:FS00:Running FahCore: "C:\Program Files (x86)shared power\FAHClient/FAHCoreWrapper.exe" C:\Users\LGB2017v2\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 4968 -checkpoint 10 -np 3
16:49:14:WU00:FS00:Started FahCore on PID 996
16:49:14:WU00:FS00:Core PID:6044
16:49:14:WU00:FS00:FahCore 0xa7 started
16:49:15:WU00:FS00:0xa7:*********************** Log Started 2019-12-13T16:49:14Z ***********************
16:49:15:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
16:49:15:WU00:FS00:0xa7: Type: 0xa7
16:49:15:WU00:FS00:0xa7: Core: Gromacs
16:49:15:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 705 -lifeline 996 -checkpoint 10 -np 3
16:49:15:WU00:FS00:0xa7:************************************ CBang *************************************
16:49:15:WU00:FS00:0xa7: Date: Oct 26 2019
16:49:15:WU00:FS00:0xa7: Time: 01:38:25
16:49:15:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
16:49:15:WU00:FS00:0xa7: Branch: master
16:49:15:WU00:FS00:0xa7: Compiler: Visual C++ 2008
16:49:15:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
16:49:15:WU00:FS00:0xa7: Platform: win32 10
16:49:15:WU00:FS00:0xa7: Bits: 64
16:49:15:WU00:FS00:0xa7: Mode: Release
16:49:15:WU00:FS00:0xa7:************************************ System ************************************
16:49:15:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
16:49:15:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
16:49:15:WU00:FS00:0xa7: CPUs: 4
16:49:15:WU00:FS00:0xa7: Memory: 7.98GiB
16:49:15:WU00:FS00:0xa7:Free Memory: 3.94GiB
16:49:15:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
16:49:15:WU00:FS00:0xa7: OS Version: 6.1
16:49:15:WU00:FS00:0xa7:Has Battery: false
16:49:15:WU00:FS00:0xa7: On Battery: false
16:49:15:WU00:FS00:0xa7: UTC Offset: 1
16:49:15:WU00:FS00:0xa7: PID: 6044
16:49:15:WU00:FS00:0xa7: CWD: C:\Users\LGB2017v2\AppData\Roaming\FAHClient\work
16:49:15:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
16:49:15:WU00:FS00:0xa7: Version: 0.0.18
16:49:15:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:49:15:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
16:49:15:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
16:49:15:WU00:FS00:0xa7: Time: 01:52:30
16:49:15:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
16:49:15:WU00:FS00:0xa7:************************************ Build *************************************
16:49:15:WU00:FS00:0xa7: SIMD: avx_256
16:49:15:WU00:FS00:0xa7:********************************************************************************
16:49:15:WU00:FS00:0xa7:Project: 13828 (Run 617, Clone 2, Gen 80)
16:49:15:WU00:FS00:0xa7:Unit: 0x0000005980fccb095d657f731c7de91d
16:49:15:WU00:FS00:0xa7:Digital signatures verified
16:49:15:WU00:FS00:0xa7:Calling: mdrun -s frame80.tpr -o frame80.trr -x frame80.xtc -cpi state.cpt -cpt 10 -nt 3
16:49:15:WU00:FS00:0xa7:ERROR:Guru Meditation #c94eb55b714e6614.91483ac29405f941 (4664832.9329664) '00/01/frame80.trr'
16:49:15:WU00:FS00:0xa7:WARNING:Unexpected exit() call
16:49:15:WU00:FS00:0xa7:WARNING:Unexpected exit from science code
16:49:15:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
16:49:15:WU00:FS00:0xa7:Saving result file frame80.trr
16:50:23:WU02:FS01:0x21:Completed 1650000 out of 7500000 steps (22%)
19:25:36:WU02:FS01:0x21:Completed 5100000 out of 7500000 steps (68%)
19:27:03:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
19:27:03:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073740777 = 0xc0000417)
19:27:03:WU00:FS00:Starting
19:27:03:WU00:FS00:Running FahCore: "C:\Program Files (x86)shared power\FAHClient/FAHCoreWrapper.exe" C:\Users\LGB2017v2\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 4968 -checkpoint 10 -np 3
19:27:03:WU00:FS00:Started FahCore on PID 5856
19:27:03:WU00:FS00:Core PID:8752
19:27:03:WU00:FS00:FahCore 0xa7 started
19:27:04:WU00:FS00:0xa7:*********************** Log Started 2019-12-13T19:27:03Z ***********************
19:27:04:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
19:27:04:WU00:FS00:0xa7: Type: 0xa7
19:27:04:WU00:FS00:0xa7: Core: Gromacs
19:27:04:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 705 -lifeline 5856 -checkpoint 10 -np 3
19:27:04:WU00:FS00:0xa7:************************************ CBang *************************************
19:27:04:WU00:FS00:0xa7: Date: Oct 26 2019
19:27:04:WU00:FS00:0xa7: Time: 01:38:25
19:27:04:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
19:27:04:WU00:FS00:0xa7: Branch: master
19:27:04:WU00:FS00:0xa7: Compiler: Visual C++ 2008
19:27:04:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:27:04:WU00:FS00:0xa7: Platform: win32 10
19:27:04:WU00:FS00:0xa7: Bits: 64
19:27:04:WU00:FS00:0xa7: Mode: Release
19:27:04:WU00:FS00:0xa7:************************************ System ************************************
19:27:04:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
19:27:04:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
19:27:04:WU00:FS00:0xa7: CPUs: 4
19:27:04:WU00:FS00:0xa7: Memory: 7.98GiB
19:27:04:WU00:FS00:0xa7:Free Memory: 3.13GiB
19:27:04:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
19:27:04:WU00:FS00:0xa7: OS Version: 6.1
19:27:04:WU00:FS00:0xa7:Has Battery: false
19:27:04:WU00:FS00:0xa7: On Battery: false
19:27:04:WU00:FS00:0xa7: UTC Offset: 1
19:27:04:WU00:FS00:0xa7: PID: 8752
19:27:04:WU00:FS00:0xa7: CWD: C:\Users\LGB2017v2\AppData\Roaming\FAHClient\work
19:27:04:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
19:27:04:WU00:FS00:0xa7: Version: 0.0.18
19:27:04:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:27:04:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
19:27:04:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
19:27:04:WU00:FS00:0xa7: Time: 01:52:30
19:27:04:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
19:27:04:WU00:FS00:0xa7:************************************ Build *************************************
19:27:04:WU00:FS00:0xa7: SIMD: avx_256
19:27:04:WU00:FS00:0xa7:********************************************************************************
19:27:04:WU00:FS00:0xa7:Project: 13828 (Run 617, Clone 2, Gen 80)
19:27:04:WU00:FS00:0xa7:Unit: 0x0000005980fccb095d657f731c7de91d
19:27:04:WU00:FS00:0xa7:Digital signatures verified
19:27:04:WU00:FS00:0xa7:Calling: mdrun -s frame80.tpr -o frame80.trr -x frame80.xtc -cpi state.cpt -cpt 10 -nt 3
19:27:04:WU00:FS00:0xa7:ERROR:Guru Meditation #c94eb55b714e6614.91483ac29405f941 (4664832.9329664) '00/01/frame80.trr'
19:27:04:WU00:FS00:0xa7:WARNING:Unexpected exit() call
19:27:04:WU00:FS00:0xa7:WARNING:Unexpected exit from science code
19:27:04:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
19:27:04:WU00:FS00:0xa7:Saving result file frame80.trr
19:27:12:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
19:27:12:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073740777 = 0xc0000417)
19:27:13:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
19:28:03:WU00:FS00:Starting
19:28:03:WU00:FS00:Running FahCore: "C:\Program Files (x86)shared power\FAHClient/FAHCoreWrapper.exe" C:\Users\LGB2017v2\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 4968 -checkpoint 10 -np 3
19:28:03:WU00:FS00:Started FahCore on PID 6108
19:28:03:WU00:FS00:Core PID:248
19:28:03:WU00:FS00:FahCore 0xa7 started
19:28:04:WU00:FS00:0xa7:*********************** Log Started 2019-12-13T19:28:03Z ***********************
19:28:04:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
19:28:04:WU00:FS00:0xa7: Type: 0xa7
19:28:04:WU00:FS00:0xa7: Core: Gromacs
19:28:04:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 705 -lifeline 6108 -checkpoint 10 -np 3
19:28:04:WU00:FS00:0xa7:************************************ CBang *************************************
19:28:04:WU00:FS00:0xa7: Date: Oct 26 2019
19:28:04:WU00:FS00:0xa7: Time: 01:38:25
19:28:04:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
19:28:04:WU00:FS00:0xa7: Branch: master
19:28:04:WU00:FS00:0xa7: Compiler: Visual C++ 2008
19:28:04:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:28:04:WU00:FS00:0xa7: Platform: win32 10
19:28:04:WU00:FS00:0xa7: Bits: 64
19:28:04:WU00:FS00:0xa7: Mode: Release
19:28:04:WU00:FS00:0xa7:************************************ System ************************************
19:28:04:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
19:28:04:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
19:28:04:WU00:FS00:0xa7: CPUs: 4
19:28:04:WU00:FS00:0xa7: Memory: 7.98GiB
19:28:04:WU00:FS00:0xa7:Free Memory: 3.65GiB
19:28:04:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
19:28:04:WU00:FS00:0xa7: OS Version: 6.1
19:28:04:WU00:FS00:0xa7:Has Battery: false
19:28:04:WU00:FS00:0xa7: On Battery: false
19:28:04:WU00:FS00:0xa7: UTC Offset: 1
19:28:04:WU00:FS00:0xa7: PID: 248
19:28:04:WU00:FS00:0xa7: CWD: C:\Users\LGB2017v2\AppData\Roaming\FAHClient\work
19:28:04:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
19:28:04:WU00:FS00:0xa7: Version: 0.0.18
19:28:04:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:28:04:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
19:28:04:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
19:28:04:WU00:FS00:0xa7: Time: 01:52:30
19:28:04:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
19:28:04:WU00:FS00:0xa7:************************************ Build *************************************
19:28:04:WU00:FS00:0xa7: SIMD: avx_256
19:28:04:WU00:FS00:0xa7:********************************************************************************
19:28:04:WU00:FS00:0xa7:Project: 13828 (Run 617, Clone 2, Gen 80)
19:28:04:WU00:FS00:0xa7:Unit: 0x0000005980fccb095d657f731c7de91d
19:28:04:WU00:FS00:0xa7:Digital signatures verified
19:28:04:WU00:FS00:0xa7:Calling: mdrun -s frame80.tpr -o frame80.trr -x frame80.xtc -cpi state.cpt -cpt 10 -nt 3
19:28:04:WU00:FS00:0xa7:ERROR:Guru Meditation #c94eb55b714e6614.91483ac29405f941 (4664832.9329664) '00/01/frame80.trr'
19:28:04:WU00:FS00:0xa7:WARNING:Unexpected exit() call
19:28:04:WU00:FS00:0xa7:WARNING:Unexpected exit from science code
19:28:04:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
19:28:04:WU00:FS00:0xa7:Saving result file frame80.trr
19:28:12:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
19:28:12:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073740777 = 0xc0000417)
19:28:13:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
19:28:24:FS00:Paused
19:28:24:FS01:Paused
19:28:24:FS01:Shutting core down
19:28:25:WU02:FS01:0x21:WARNING:Console control signal 1 on PID 2488
19:28:25:WU02:FS01:0x21:Exiting, please wait. . .
19:28:25:WU02:FS01:0x21:Folding@home Core Shutdown: INTERRUPTED
19:28:25:WU02:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
19:28:34:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
