HTTP_INTERNAL_SERVER_ERROR
werty316
Post by werty316 »
Is the GPU assignment server down? I got this error after my WU finished and uploaded:
21:12:32:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
21:12:44:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': 10001: Server responded: HTTP_INTERNAL_SERVER_ERROR
21:12:44:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
21:12:44:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': 10001: Server responded: HTTP_INTERNAL_SERVER_ERROR
21:12:44:ERROR:WU00:FS00:Exception: Could not get an assignment
21:12:45:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': 10001: Server responded: HTTP_INTERNAL_SERVER_ERROR
21:12:45:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
21:12:45:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': 10001: Server responded: HTTP_INTERNAL_SERVER_ERROR
21:12:45:ERROR:WU00:FS00:Exception: Could not get an assignment
Anyone else experiencing this problem?
Re: HTTP_INTERNAL_SERVER_ERROR
Since that was 3 hours ago and nobody else has responded, I'm going to assume it was a temporary error unless it's confirmed by others or one of my slots needs a new WU.
There have been some ongoing updates to FAH's servers. It may be that the server has moved to a new IP address. I recommend you reboot your system (which will clear any obsolete DNS entries an reset your network configuration. Does it still happen?
werty316
Post by werty316 »
Everything is working now all the sudden :roll:
bollix47
Post by bollix47 »
FYI
I saw the same message many times yesterday ... I have not seen it so far today ... problem was probably at server end but I have no 'inside' knowledge of what may have caused it.
I think it's safe to say that the problem was not at our end. :wink:
bruce wrote:There have been some ongoing updates to FAH's servers.
bollix47 wrote:I think it's safe to say that the problem was not at our end. :wink:
