GTX 1060 undervolting despite full workload
Hypernova0
Post by Hypernova0 »
Hey all,
I've been an on and off folder for several months now, but I've run into a problem with my GPU. FAH is running the GPU at .781V exclusively, according to MSI afterburner. It's stable, but I usually have it overclocked to 1.083V. So, it's using 95% of the GPU but not doing much work at all (hey, at least it runs cool now). When I first noticed it, I updated to the latest nvidia driver (430.86) but the problem persists, even when running at normal clock speeds and even undervolting/underclocking it. That's the extent of my knowledge, I bet someone knows a bit more. I pasted a few hours of log below. Thanks for your time.
*********************** Log Started 2019-06-15T21:52:50Z ***********************
21:52:50:************************* Folding@home Client *************************
21:52:50:        Website: https://foldingathome.org/
21:52:50:      Copyright: (c) 2009-2018 foldingathome.org
21:52:50:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:52:50:           Args: --open-web-control
21:52:50:         Config: C:\Users\bmurr\AppData\Roaming\FAHClient\config.xml
21:52:50:******************************** Build ********************************
21:52:50:        Version: 7.5.1
21:52:50:           Date: May 11 2018
21:52:50:           Time: 13:06:32
21:52:50:     Repository: Git
21:52:50:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
21:52:50:         Branch: master
21:52:50:       Compiler: Visual C++ 2008
21:52:50:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:52:50:       Platform: win32 10
21:52:50:           Bits: 32
21:52:50:           Mode: Release
21:52:50:******************************* System ********************************
21:52:50:            CPU: Intel(R) Core(TM) i7-7700 CPU @ 3.60GHz
21:52:50:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
21:52:50:           CPUs: 8
21:52:50:         Memory: 15.95GiB
21:52:50:    Free Memory: 10.54GiB
21:52:50:        Threads: WINDOWS_THREADS
21:52:50:     OS Version: 6.2
21:52:50:    Has Battery: false
21:52:50:     On Battery: false
21:52:50:     UTC Offset: -7
21:52:50:            PID: 7096
21:52:50:            CWD: C:\Users\bmurr\AppData\Roaming\FAHClient
21:52:50:             OS: Windows 10 Home
21:52:50:        OS Arch: AMD64
21:52:50:           GPUs: 1
21:52:50:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 GP106 [GeForce GTX 1060 3GB] 3935
21:52:50:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.2
21:52:50:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:430.64
21:52:50:  Win32 Service: false
21:52:50:***********************************************************************
21:52:50:<config>
21:52:50:  <!-- Slot Control -->
21:52:50:  <power v='MEDIUM'/>
21:52:50:
21:52:50:  <!-- User Information -->
21:52:50:  <team v='225605'/>
21:52:50:  <user v='Hypernova'/>
21:52:50:
21:52:50:  <!-- Folding Slots -->
21:52:50:  <slot id='0' type='CPU'>
21:52:50:    <paused v='true'/>
21:52:50:  </slot>
21:52:50:  <slot id='1' type='GPU'>
21:52:50:  </slot>
21:52:50:</config>
21:52:50:Trying to access database...
21:52:50:Successfully acquired database lock
21:52:50:Enabled folding slot 00: PAUSED cpu:6 (by user)
21:52:50:Enabled folding slot 01: PAUSED gpu:0:GP106 [GeForce GTX 1060 3GB] 3935 (by user)
21:52:51:8:127.0.0.1:New Web connection
21:52:57:FS00:Unpaused
21:52:57:FS01:Unpaused
21:52:57:WU00:FS00:Starting
21:52:57:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\bmurr\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 7096 -checkpoint 15 -np 6
21:52:57:WU00:FS00:Started FahCore on PID 26772
21:52:57:WU00:FS00:Core PID:16608
21:52:57:WU00:FS00:FahCore 0xa7 started
21:52:57:WU01:FS01:Connecting to 65.254.110.245:8080
21:52:57:WU00:FS00:0xa7:*********************** Log Started 2019-06-15T21:52:57Z ***********************
21:52:57:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
21:52:57:WU00:FS00:0xa7:       Type: 0xa7
21:52:57:WU00:FS00:0xa7:       Core: Gromacs
21:52:57:WU00:FS00:0xa7:    Website: https://foldingathome.org/
21:52:57:WU00:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
21:52:57:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:52:57:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 26772 -checkpoint 15 -np
21:52:57:WU00:FS00:0xa7:             6
21:52:57:WU00:FS00:0xa7:     Config: <none>
21:52:57:WU00:FS00:0xa7:************************************ Build *************************************
21:52:57:WU00:FS00:0xa7:    Version: 0.0.17
21:52:57:WU00:FS00:0xa7:       Date: Apr 27 2018
21:52:57:WU00:FS00:0xa7:       Time: 16:19:36
21:52:57:WU00:FS00:0xa7: Repository: Git
21:52:57:WU00:FS00:0xa7:   Revision: 21359963583d09ec2063ef946399441c4df4ccd7
21:52:57:WU00:FS00:0xa7:     Branch: master
21:52:57:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
21:52:57:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:52:57:WU00:FS00:0xa7:   Platform: win32 10
21:52:57:WU00:FS00:0xa7:       Bits: 64
21:52:57:WU00:FS00:0xa7:       Mode: Release
21:52:57:WU00:FS00:0xa7:       SIMD: avx_256
21:52:57:WU00:FS00:0xa7:************************************ System ************************************
21:52:57:WU00:FS00:0xa7:        CPU: Unknown
21:52:57:WU00:FS00:0xa7:     CPU ID:
21:52:57:WU00:FS00:0xa7:       CPUs: 8
21:52:57:WU00:FS00:0xa7:     Memory: 15.95GiB
21:52:57:WU00:FS00:0xa7:Free Memory: 10.49GiB
21:52:57:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
21:52:57:WU00:FS00:0xa7: OS Version: 6.2
21:52:57:WU00:FS00:0xa7:Has Battery: false
21:52:57:WU00:FS00:0xa7: On Battery: false
21:52:57:WU00:FS00:0xa7: UTC Offset: -7
21:52:57:WU00:FS00:0xa7:        PID: 16608
21:52:57:WU00:FS00:0xa7:        CWD: C:\Users\bmurr\AppData\Roaming\FAHClient\work
21:52:57:WU00:FS00:0xa7:         OS: Windows 10 Home
21:52:57:WU00:FS00:0xa7:    OS Arch: AMD64
21:52:57:WU00:FS00:0xa7:********************************************************************************
21:52:57:WU00:FS00:0xa7:Project: 13824 (Run 453, Clone 0, Gen 30)
21:52:57:WU00:FS00:0xa7:Unit: 0x0000002480fccb095c9248f2985a4a18
21:52:57:WU00:FS00:0xa7:Digital signatures verified
21:52:57:WU00:FS00:0xa7:Calling: mdrun -s frame30.tpr -o frame30.trr -x frame30.xtc -cpi state.cpt -cpt 15 -nt 6
21:52:58:WU00:FS00:0xa7:Steps: first=3750000 total=125000
21:53:00:WU00:FS00:0xa7:Completed 44722 out of 125000 steps (35%)
21:53:01:WU01:FS01:Assigned to work server 155.247.166.220
21:53:01:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP106 [GeForce GTX 1060 3GB] 3935 from 155.247.166.220
21:53:01:WU01:FS01:Connecting to 155.247.166.220:8080
21:53:05:WU01:FS01:Downloading 834.70KiB
21:53:11:WU01:FS01:Download 69.01%
21:53:15:WU01:FS01:Download complete
21:53:15:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14166 run:5 clone:84 gen:114 core:0x21 unit:0x000000970002894c5c38c017bb3a8f15
21:53:15:WU01:FS01:Starting
21:53:15:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\bmurr\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 705 -lifeline 7096 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
21:53:15:WU01:FS01:Started FahCore on PID 25348
21:53:16:WU01:FS01:Core PID:24704
21:53:16:WU01:FS01:FahCore 0x21 started
21:53:16:WU01:FS01:0x21:*********************** Log Started 2019-06-15T21:53:16Z ***********************
21:53:16:WU01:FS01:0x21:Project: 14166 (Run 5, Clone 84, Gen 114)
21:53:16:WU01:FS01:0x21:Unit: 0x000000970002894c5c38c017bb3a8f15
21:53:16:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
21:53:16:WU01:FS01:0x21:Machine: 1
21:53:16:WU01:FS01:0x21:Reading tar file core.xml
21:53:16:WU01:FS01:0x21:Reading tar file integrator.xml
21:53:16:WU01:FS01:0x21:Reading tar file state.xml
21:53:16:WU01:FS01:0x21:Reading tar file system.xml
21:53:16:WU01:FS01:0x21:Digital signatures verified
21:53:16:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
21:53:16:WU01:FS01:0x21:Version 0.0.18
21:53:21:WU01:FS01:0x21:Completed 0 out of 12500000 steps (0%)
21:53:21:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
21:53:25:WU00:FS00:0xa7:Completed 45000 out of 125000 steps (36%)
21:53:51:Saving configuration to config.xml
21:53:51:<config>
21:53:51:  <!-- Slot Control -->
21:53:51:  <power v='MEDIUM'/>
21:53:51:
21:53:51:  <!-- User Information -->
21:53:51:  <team v='225605'/>
21:53:51:  <user v='Hypernova'/>
21:53:51:
21:53:51:  <!-- Folding Slots -->
21:53:51:  <slot id='0' type='CPU'/>
21:53:51:  <slot id='1' type='GPU'/>
21:53:51:</config>
21:55:30:WU00:FS00:0xa7:Completed 46250 out of 125000 steps (37%)
21:56:07:WU01:FS01:0x21:Completed 125000 out of 12500000 steps (1%)
21:56:49:FS00:Paused
21:56:49:FS01:Paused
21:56:49:FS00:Shutting core down
21:56:49:FS01:Shutting core down
21:56:49:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 16608
21:56:49:WU00:FS00:0xa7:Exiting, please wait. . .
21:56:49:WU01:FS01:0x21:WARNING:Console control signal 1 on PID 24704
21:56:49:WU01:FS01:0x21:Exiting, please wait. . .
21:56:50:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
21:56:53:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
21:56:53:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
21:56:54:Saving configuration to config.xml
21:56:54:<config>
21:56:54:  <!-- Slot Control -->
21:56:54:  <power v='MEDIUM'/>
21:56:54:
21:56:54:  <!-- User Information -->
21:56:54:  <team v='225605'/>
21:56:54:  <user v='Hypernova'/>
21:56:54:
21:56:54:  <!-- Folding Slots -->
21:56:54:  <slot id='0' type='CPU'>
21:56:54:    <paused v='true'/>
21:56:54:  </slot>
21:56:54:  <slot id='1' type='GPU'>
21:56:54:  </slot>
21:56:54:</config>
22:01:51:FS00:Unpaused
22:01:51:FS01:Unpaused
22:01:51:WU00:FS00:Starting
22:01:51:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\bmurr\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 7096 -checkpoint 15 -np 6
22:01:51:WU00:FS00:Started FahCore on PID 15996
22:01:51:WU00:FS00:Core PID:27772
22:01:51:WU00:FS00:FahCore 0xa7 started
22:01:51:WU01:FS01:Starting
22:01:51:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\bmurr\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 705 -lifeline 7096 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
22:01:51:WU01:FS01:Started FahCore on PID 21524
22:01:51:WU01:FS01:Core PID:25292
22:01:51:WU01:FS01:FahCore 0x21 started
22:01:52:WU00:FS00:0xa7:*********************** Log Started 2019-06-15T22:01:51Z ***********************
22:01:52:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
22:01:52:WU00:FS00:0xa7:       Type: 0xa7
22:01:52:WU00:FS00:0xa7:       Core: Gromacs
22:01:52:WU00:FS00:0xa7:    Website: https://foldingathome.org/
22:01:52:WU00:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
22:01:52:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:01:52:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 15996 -checkpoint 15 -np
22:01:52:WU00:FS00:0xa7:             6
22:01:52:WU00:FS00:0xa7:     Config: <none>
22:01:52:WU00:FS00:0xa7:************************************ Build *************************************
22:01:52:WU00:FS00:0xa7:    Version: 0.0.17
22:01:52:WU00:FS00:0xa7:       Date: Apr 27 2018
22:01:52:WU00:FS00:0xa7:       Time: 16:19:36
22:01:52:WU00:FS00:0xa7: Repository: Git
22:01:52:WU00:FS00:0xa7:   Revision: 21359963583d09ec2063ef946399441c4df4ccd7
22:01:52:WU00:FS00:0xa7:     Branch: master
22:01:52:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
22:01:52:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:01:52:WU00:FS00:0xa7:   Platform: win32 10
22:01:52:WU00:FS00:0xa7:       Bits: 64
22:01:52:WU00:FS00:0xa7:       Mode: Release
22:01:52:WU00:FS00:0xa7:       SIMD: avx_256
22:01:52:WU00:FS00:0xa7:************************************ System ************************************
22:01:52:WU00:FS00:0xa7:        CPU: Unknown
22:01:52:WU00:FS00:0xa7:     CPU ID:
22:01:52:WU00:FS00:0xa7:       CPUs: 8
22:01:52:WU00:FS00:0xa7:     Memory: 15.95GiB
22:01:52:WU00:FS00:0xa7:Free Memory: 10.32GiB
22:01:52:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
22:01:52:WU00:FS00:0xa7: OS Version: 6.2
22:01:52:WU00:FS00:0xa7:Has Battery: false
22:01:52:WU00:FS00:0xa7: On Battery: false
22:01:52:WU00:FS00:0xa7: UTC Offset: -7
22:01:52:WU00:FS00:0xa7:        PID: 27772
22:01:52:WU00:FS00:0xa7:        CWD: C:\Users\bmurr\AppData\Roaming\FAHClient\work
22:01:52:WU00:FS00:0xa7:         OS: Windows 10 Home
22:01:52:WU00:FS00:0xa7:    OS Arch: AMD64
22:01:52:WU00:FS00:0xa7:********************************************************************************
22:01:52:WU00:FS00:0xa7:Project: 13824 (Run 453, Clone 0, Gen 30)
22:01:52:WU00:FS00:0xa7:Unit: 0x0000002480fccb095c9248f2985a4a18
22:01:52:WU00:FS00:0xa7:Digital signatures verified
22:01:52:WU00:FS00:0xa7:Calling: mdrun -s frame30.tpr -o frame30.trr -x frame30.xtc -cpi state.cpt -cpt 15 -nt 6
22:01:52:WU00:FS00:0xa7:Steps: first=3750000 total=125000
22:01:52:WU01:FS01:0x21:*********************** Log Started 2019-06-15T22:01:51Z ***********************
22:01:52:WU01:FS01:0x21:Project: 14166 (Run 5, Clone 84, Gen 114)
22:01:52:WU01:FS01:0x21:Unit: 0x000000970002894c5c38c017bb3a8f15
22:01:52:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
22:01:52:WU01:FS01:0x21:Machine: 1
22:01:52:WU01:FS01:0x21:Digital signatures verified
22:01:52:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
22:01:52:WU01:FS01:0x21:Version 0.0.18
22:01:53:WU01:FS01:0x21:Completed 0 out of 12500000 steps (0%)
22:01:53:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
22:01:54:WU00:FS00:0xa7:Completed 47062 out of 125000 steps (37%)
22:01:59:Saving configuration to config.xml
22:01:59:<config>
22:01:59:  <!-- Slot Control -->
22:01:59:  <power v='MEDIUM'/>
22:01:59:
22:01:59:  <!-- User Information -->
22:01:59:  <team v='225605'/>
22:01:59:  <user v='Hypernova'/>
22:01:59:
22:01:59:  <!-- Folding Slots -->
22:01:59:  <slot id='0' type='CPU'/>
22:01:59:  <slot id='1' type='GPU'/>
22:01:59:</config>
22:02:37:WU00:FS00:0xa7:Completed 47500 out of 125000 steps (38%)
22:04:34:WU00:FS00:0xa7:Completed 48750 out of 125000 steps (39%)
22:04:56:WU01:FS01:0x21:Completed 125000 out of 12500000 steps (1%)
22:06:12:FS00:Paused
22:06:12:FS01:Paused
22:06:12:FS00:Shutting core down
22:06:12:FS01:Shutting core down
22:06:12:WU01:FS01:0x21:WARNING:Console control signal 1 on PID 25292
22:06:12:WU01:FS01:0x21:Exiting, please wait. . .
22:06:13:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 27772
22:06:13:WU00:FS00:0xa7:Exiting, please wait. . .
22:06:13:WU01:FS01:0x21:Folding@home Core Shutdown: INTERRUPTED
22:06:13:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
22:06:16:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
22:06:16:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
22:07:04:Saving configuration to config.xml
22:07:04:<config>
22:07:04:  <!-- Slot Control -->
22:07:04:  <power v='MEDIUM'/>
22:07:04:
22:07:04:  <!-- User Information -->
22:07:04:  <team v='225605'/>
22:07:04:  <user v='Hypernova'/>
22:07:04:
22:07:04:  <!-- Folding Slots -->
22:07:04:  <slot id='0' type='CPU'>
22:07:04:    <paused v='true'/>
22:07:04:  </slot>
22:07:04:  <slot id='1' type='GPU'>
22:07:04:  </slot>
22:07:04:</config>
22:26:22:FS00:Unpaused
22:26:22:FS01:Unpaused
22:26:22:WU00:FS00:Starting
22:26:22:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\bmurr\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 7096 -checkpoint 15 -np 6
22:26:22:WU00:FS00:Started FahCore on PID 26196
22:26:22:WU00:FS00:Core PID:12532
22:26:22:WU00:FS00:FahCore 0xa7 started
22:26:22:WU01:FS01:Starting
22:26:22:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\bmurr\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 705 -lifeline 7096 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
22:26:22:WU01:FS01:Started FahCore on PID 14568
22:26:22:WU01:FS01:Core PID:14456
22:26:22:WU01:FS01:FahCore 0x21 started
22:26:22:WU00:FS00:0xa7:*********************** Log Started 2019-06-15T22:26:22Z ***********************
22:26:22:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
22:26:22:WU00:FS00:0xa7:       Type: 0xa7
22:26:22:WU00:FS00:0xa7:       Core: Gromacs
22:26:22:WU00:FS00:0xa7:    Website: https://foldingathome.org/
22:26:22:WU00:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
22:26:22:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:26:22:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 26196 -checkpoint 15 -np
22:26:22:WU00:FS00:0xa7:             6
22:26:22:WU00:FS00:0xa7:     Config: <none>
22:26:22:WU00:FS00:0xa7:************************************ Build *************************************
22:26:22:WU00:FS00:0xa7:    Version: 0.0.17
22:26:22:WU00:FS00:0xa7:       Date: Apr 27 2018
22:26:22:WU00:FS00:0xa7:       Time: 16:19:36
22:26:22:WU00:FS00:0xa7: Repository: Git
22:26:22:WU00:FS00:0xa7:   Revision: 21359963583d09ec2063ef946399441c4df4ccd7
22:26:22:WU00:FS00:0xa7:     Branch: master
22:26:22:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
22:26:22:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:26:22:WU00:FS00:0xa7:   Platform: win32 10
22:26:22:WU00:FS00:0xa7:       Bits: 64
22:26:22:WU00:FS00:0xa7:       Mode: Release
22:26:22:WU00:FS00:0xa7:       SIMD: avx_256
22:26:22:WU00:FS00:0xa7:************************************ System ************************************
22:26:23:WU00:FS00:0xa7:        CPU: Unknown
22:26:23:WU00:FS00:0xa7:     CPU ID:
22:26:23:WU00:FS00:0xa7:       CPUs: 8
22:26:23:WU00:FS00:0xa7:     Memory: 15.95GiB
22:26:23:WU00:FS00:0xa7:Free Memory: 10.24GiB
22:26:23:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
22:26:23:WU00:FS00:0xa7: OS Version: 6.2
22:26:23:WU00:FS00:0xa7:Has Battery: false
22:26:23:WU00:FS00:0xa7: On Battery: false
22:26:23:WU00:FS00:0xa7: UTC Offset: -7
22:26:23:WU00:FS00:0xa7:        PID: 12532
22:26:23:WU00:FS00:0xa7:        CWD: C:\Users\bmurr\AppData\Roaming\FAHClient\work
22:26:23:WU00:FS00:0xa7:         OS: Windows 10 Home
22:26:23:WU00:FS00:0xa7:    OS Arch: AMD64
22:26:23:WU00:FS00:0xa7:********************************************************************************
22:26:23:WU00:FS00:0xa7:Project: 13824 (Run 453, Clone 0, Gen 30)
22:26:23:WU00:FS00:0xa7:Unit: 0x0000002480fccb095c9248f2985a4a18
22:26:23:WU00:FS00:0xa7:Digital signatures verified
22:26:23:WU00:FS00:0xa7:Calling: mdrun -s frame30.tpr -o frame30.trr -x frame30.xtc -cpi state.cpt -cpt 15 -nt 6
22:26:23:WU00:FS00:0xa7:Steps: first=3750000 total=125000
22:26:23:Saving configuration to config.xml
22:26:23:<config>
22:26:23:  <!-- Slot Control -->
22:26:23:  <power v='MEDIUM'/>
22:26:23:
22:26:23:  <!-- User Information -->
22:26:23:  <team v='225605'/>
22:26:23:  <user v='Hypernova'/>
22:26:23:
22:26:23:  <!-- Folding Slots -->
22:26:23:  <slot id='0' type='CPU'/>
22:26:23:  <slot id='1' type='GPU'/>
22:26:23:</config>
22:26:23:WU01:FS01:0x21:*********************** Log Started 2019-06-15T22:26:22Z ***********************
22:26:23:WU01:FS01:0x21:Project: 14166 (Run 5, Clone 84, Gen 114)
22:26:23:WU01:FS01:0x21:Unit: 0x000000970002894c5c38c017bb3a8f15
22:26:23:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
22:26:23:WU01:FS01:0x21:Machine: 1
22:26:23:WU01:FS01:0x21:Digital signatures verified
22:26:23:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
22:26:23:WU01:FS01:0x21:Version 0.0.18
22:26:25:WU00:FS00:0xa7:Completed 49772 out of 125000 steps (39%)
22:26:29:WU01:FS01:0x21:Completed 0 out of 12500000 steps (0%)
22:26:29:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
22:26:46:WU00:FS00:0xa7:Completed 50000 out of 125000 steps (40%)
22:28:40:WU00:FS00:0xa7:Completed 51250 out of 125000 steps (41%)
22:28:59:WU01:FS01:0x21:Completed 125000 out of 12500000 steps (1%)
22:30:32:WU00:FS00:0xa7:Completed 52500 out of 125000 steps (42%)
22:31:29:WU01:FS01:0x21:Completed 250000 out of 12500000 steps (2%)
22:32:23:WU00:FS00:0xa7:Completed 53750 out of 125000 steps (43%)
22:34:00:WU01:FS01:0x21:Completed 375000 out of 12500000 steps (3%)
22:34:15:WU00:FS00:0xa7:Completed 55000 out of 125000 steps (44%)
22:36:06:WU00:FS00:0xa7:Completed 56250 out of 125000 steps (45%)
22:36:30:WU01:FS01:0x21:Completed 500000 out of 12500000 steps (4%)
22:37:59:WU00:FS00:0xa7:Completed 57500 out of 125000 steps (46%)
22:39:02:WU01:FS01:0x21:Completed 625000 out of 12500000 steps (5%)
22:39:52:WU00:FS00:0xa7:Completed 58750 out of 125000 steps (47%)
22:41:33:WU01:FS01:0x21:Completed 750000 out of 12500000 steps (6%)
22:41:46:WU00:FS00:0xa7:Completed 60000 out of 125000 steps (48%)
22:43:39:WU00:FS00:0xa7:Completed 61250 out of 125000 steps (49%)
22:44:06:WU01:FS01:0x21:Completed 875000 out of 12500000 steps (7%)
22:45:31:WU00:FS00:0xa7:Completed 62500 out of 125000 steps (50%)
22:46:38:WU01:FS01:0x21:Completed 1000000 out of 12500000 steps (8%)
22:47:23:WU00:FS00:0xa7:Completed 63750 out of 125000 steps (51%)
22:49:10:WU01:FS01:0x21:Completed 1125000 out of 12500000 steps (9%)
22:49:17:WU00:FS00:0xa7:Completed 65000 out of 125000 steps (52%)
22:51:15:WU00:FS00:0xa7:Completed 66250 out of 125000 steps (53%)
22:51:42:WU01:FS01:0x21:Completed 1250000 out of 12500000 steps (10%)
22:53:07:WU00:FS00:0xa7:Completed 67500 out of 125000 steps (54%)
22:54:13:WU01:FS01:0x21:Completed 1375000 out of 12500000 steps (11%)
22:54:58:WU00:FS00:0xa7:Completed 68750 out of 125000 steps (55%)
22:56:44:WU01:FS01:0x21:Completed 1500000 out of 12500000 steps (12%)
22:56:52:WU00:FS00:0xa7:Completed 70000 out of 125000 steps (56%)
22:58:45:WU00:FS00:0xa7:Completed 71250 out of 125000 steps (57%)
22:59:15:WU01:FS01:0x21:Completed 1625000 out of 12500000 steps (13%)
23:00:37:WU00:FS00:0xa7:Completed 72500 out of 125000 steps (58%)
23:01:46:WU01:FS01:0x21:Completed 1750000 out of 12500000 steps (14%)
23:02:29:WU00:FS00:0xa7:Completed 73750 out of 125000 steps (59%)
23:04:19:WU01:FS01:0x21:Completed 1875000 out of 12500000 steps (15%)
23:04:22:WU00:FS00:0xa7:Completed 75000 out of 125000 steps (60%)
23:06:13:WU00:FS00:0xa7:Completed 76250 out of 125000 steps (61%)
23:06:50:WU01:FS01:0x21:Completed 2000000 out of 12500000 steps (16%)
23:08:05:WU00:FS00:0xa7:Completed 77500 out of 125000 steps (62%)
23:09:21:WU01:FS01:0x21:Completed 2125000 out of 12500000 steps (17%)
23:09:56:WU00:FS00:0xa7:Completed 78750 out of 125000 steps (63%)
23:11:50:WU00:FS00:0xa7:Completed 80000 out of 125000 steps (64%)
23:11:53:WU01:FS01:0x21:Completed 2250000 out of 12500000 steps (18%)
23:13:42:WU00:FS00:0xa7:Completed 81250 out of 125000 steps (65%)
23:14:24:WU01:FS01:0x21:Completed 2375000 out of 12500000 steps (19%)
23:15:33:WU00:FS00:0xa7:Completed 82500 out of 125000 steps (66%)
23:16:55:WU01:FS01:0x21:Completed 2500000 out of 12500000 steps (20%)
23:17:25:WU00:FS00:0xa7:Completed 83750 out of 125000 steps (67%)
23:19:16:WU00:FS00:0xa7:Completed 85000 out of 125000 steps (68%)
23:19:26:WU01:FS01:0x21:Completed 2625000 out of 12500000 steps (21%)
23:21:07:WU00:FS00:0xa7:Completed 86250 out of 125000 steps (69%)
23:21:57:WU01:FS01:0x21:Completed 2750000 out of 12500000 steps (22%)
23:22:58:WU00:FS00:0xa7:Completed 87500 out of 125000 steps (70%)
23:24:28:WU01:FS01:0x21:Completed 2875000 out of 12500000 steps (23%)
23:24:49:WU00:FS00:0xa7:Completed 88750 out of 125000 steps (71%)
23:26:42:WU00:FS00:0xa7:Completed 90000 out of 125000 steps (72%)
23:26:58:WU01:FS01:0x21:Completed 3000000 out of 12500000 steps (24%)
23:28:33:WU00:FS00:0xa7:Completed 91250 out of 125000 steps (73%)
23:29:29:WU01:FS01:0x21:Completed 3125000 out of 12500000 steps (25%)
23:30:24:WU00:FS00:0xa7:Completed 92500 out of 125000 steps (74%)
23:32:00:WU01:FS01:0x21:Completed 3250000 out of 12500000 steps (26%)
23:32:15:WU00:FS00:0xa7:Completed 93750 out of 125000 steps (75%)
23:34:06:WU00:FS00:0xa7:Completed 95000 out of 125000 steps (76%)
23:34:31:WU01:FS01:0x21:Completed 3375000 out of 12500000 steps (27%)
23:35:57:WU00:FS00:0xa7:Completed 96250 out of 125000 steps (77%)
23:37:01:WU01:FS01:0x21:Completed 3500000 out of 12500000 steps (28%)
23:37:48:WU00:FS00:0xa7:Completed 97500 out of 125000 steps (78%)
23:39:32:WU01:FS01:0x21:Completed 3625000 out of 12500000 steps (29%)
23:39:40:WU00:FS00:0xa7:Completed 98750 out of 125000 steps (79%)
23:41:33:WU00:FS00:0xa7:Completed 100000 out of 125000 steps (80%)
23:42:03:WU01:FS01:0x21:Completed 3750000 out of 12500000 steps (30%)
23:43:24:WU00:FS00:0xa7:Completed 101250 out of 125000 steps (81%)
23:44:34:WU01:FS01:0x21:Completed 3875000 out of 12500000 steps (31%)
23:45:15:WU00:FS00:0xa7:Completed 102500 out of 125000 steps (82%)
23:47:04:WU01:FS01:0x21:Completed 4000000 out of 12500000 steps (32%)
23:47:06:WU00:FS00:0xa7:Completed 103750 out of 125000 steps (83%)
23:48:57:WU00:FS00:0xa7:Completed 105000 out of 125000 steps (84%)
23:49:35:WU01:FS01:0x21:Completed 4125000 out of 12500000 steps (33%)
23:50:49:WU00:FS00:0xa7:Completed 106250 out of 125000 steps (85%)
23:52:05:WU01:FS01:0x21:Completed 4250000 out of 12500000 steps (34%)
23:52:40:WU00:FS00:0xa7:Completed 107500 out of 125000 steps (86%)
23:54:31:WU00:FS00:0xa7:Completed 108750 out of 125000 steps (87%)
23:54:36:WU01:FS01:0x21:Completed 4375000 out of 12500000 steps (35%)
23:56:22:WU00:FS00:0xa7:Completed 110000 out of 125000 steps (88%)
23:57:07:WU01:FS01:0x21:Completed 4500000 out of 12500000 steps (36%)
23:58:15:WU00:FS00:0xa7:Completed 111250 out of 125000 steps (89%)
23:59:38:WU01:FS01:0x21:Completed 4625000 out of 12500000 steps (37%)
00:00:06:WU00:FS00:0xa7:Completed 112500 out of 125000 steps (90%)
00:01:57:WU00:FS00:0xa7:Completed 113750 out of 125000 steps (91%)
00:02:08:WU01:FS01:0x21:Completed 4750000 out of 12500000 steps (38%)
00:03:48:WU00:FS00:0xa7:Completed 115000 out of 125000 steps (92%)
00:04:39:WU01:FS01:0x21:Completed 4875000 out of 12500000 steps (39%)
00:05:40:WU00:FS00:0xa7:Completed 116250 out of 125000 steps (93%)
00:07:10:WU01:FS01:0x21:Completed 5000000 out of 12500000 steps (40%)
00:07:31:WU00:FS00:0xa7:Completed 117500 out of 125000 steps (94%)
00:09:22:WU00:FS00:0xa7:Completed 118750 out of 125000 steps (95%)
00:09:41:WU01:FS01:0x21:Completed 5125000 out of 12500000 steps (41%)
00:11:13:WU00:FS00:0xa7:Completed 120000 out of 125000 steps (96%)
00:12:11:WU01:FS01:0x21:Completed 5250000 out of 12500000 steps (42%)
00:13:06:WU00:FS00:0xa7:Completed 121250 out of 125000 steps (97%)
00:14:42:WU01:FS01:0x21:Completed 5375000 out of 12500000 steps (43%)
00:14:57:WU00:FS00:0xa7:Completed 122500 out of 125000 steps (98%)
00:16:50:WU00:FS00:0xa7:Completed 123750 out of 125000 steps (99%)
00:16:50:WU02:FS00:Connecting to 65.254.110.245:8080
00:16:50:WU02:FS00:Assigned to work server 128.252.203.9
00:16:50:WU02:FS00:Requesting new work unit for slot 00: RUNNING cpu:6 from 128.252.203.9
00:16:50:WU02:FS00:Connecting to 128.252.203.9:8080
00:16:54:WU02:FS00:Downloading 8.14MiB
00:16:55:WU02:FS00:Download complete
00:16:55:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:13826 run:480 clone:0 gen:33 core:0xa7 unit:0x0000002a80fccb095c979b0116ed9c52
00:17:15:WU01:FS01:0x21:Completed 5500000 out of 12500000 steps (44%)
00:17:33:109:127.0.0.1:New Web connection
00:19:16:WU00:FS00:0xa7:Completed 125000 out of 125000 steps (100%)
00:19:22:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
00:19:22:WU00:FS00:0xa7:Saving result file frame30.trr
00:19:22:WU00:FS00:0xa7:Saving result file frame30.xtc
00:19:22:WU00:FS00:0xa7:Saving result file md.log
00:19:22:WU00:FS00:0xa7:Saving result file science.log
00:19:22:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
00:19:22:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
00:19:22:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13824 run:453 clone:0 gen:30 core:0xa7 unit:0x0000002480fccb095c9248f2985a4a18
00:19:22:WU00:FS00:Uploading 24.66MiB to 128.252.203.9
00:19:22:WU00:FS00:Connecting to 128.252.203.9:8080
00:19:22:WU02:FS00:Starting
00:19:22:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\bmurr\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 7096 -checkpoint 15 -np 6
00:19:22:WU02:FS00:Started FahCore on PID 23496
00:19:22:WU02:FS00:Core PID:16608
00:19:22:WU02:FS00:FahCore 0xa7 started
00:19:23:WU02:FS00:0xa7:*********************** Log Started 2019-06-16T00:19:22Z ***********************
00:19:23:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
00:19:23:WU02:FS00:0xa7:       Type: 0xa7
00:19:23:WU02:FS00:0xa7:       Core: Gromacs
00:19:23:WU02:FS00:0xa7:    Website: https://foldingathome.org/
00:19:23:WU02:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
00:19:23:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:19:23:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 23496 -checkpoint 15 -np
00:19:23:WU02:FS00:0xa7:             6
00:19:23:WU02:FS00:0xa7:     Config: <none>
00:19:23:WU02:FS00:0xa7:************************************ Build *************************************
00:19:23:WU02:FS00:0xa7:    Version: 0.0.17
00:19:23:WU02:FS00:0xa7:       Date: Apr 27 2018
00:19:23:WU02:FS00:0xa7:       Time: 16:19:36
00:19:23:WU02:FS00:0xa7: Repository: Git
00:19:23:WU02:FS00:0xa7:   Revision: 21359963583d09ec2063ef946399441c4df4ccd7
00:19:23:WU02:FS00:0xa7:     Branch: master
00:19:23:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
00:19:23:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
00:19:23:WU02:FS00:0xa7:   Platform: win32 10
00:19:23:WU02:FS00:0xa7:       Bits: 64
00:19:23:WU02:FS00:0xa7:       Mode: Release
00:19:23:WU02:FS00:0xa7:       SIMD: avx_256
00:19:23:WU02:FS00:0xa7:************************************ System ************************************
00:19:23:WU02:FS00:0xa7:        CPU: Unknown
00:19:23:WU02:FS00:0xa7:     CPU ID:
00:19:23:WU02:FS00:0xa7:       CPUs: 8
00:19:23:WU02:FS00:0xa7:     Memory: 15.95GiB
00:19:23:WU02:FS00:0xa7:Free Memory: 10.19GiB
00:19:23:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
00:19:23:WU02:FS00:0xa7: OS Version: 6.2
00:19:23:WU02:FS00:0xa7:Has Battery: false
00:19:23:WU02:FS00:0xa7: On Battery: false
00:19:23:WU02:FS00:0xa7: UTC Offset: -7
00:19:23:WU02:FS00:0xa7:        PID: 16608
00:19:23:WU02:FS00:0xa7:        CWD: C:\Users\bmurr\AppData\Roaming\FAHClient\work
00:19:23:WU02:FS00:0xa7:         OS: Windows 10 Home
00:19:23:WU02:FS00:0xa7:    OS Arch: AMD64
00:19:23:WU02:FS00:0xa7:********************************************************************************
00:19:23:WU02:FS00:0xa7:Project: 13826 (Run 480, Clone 0, Gen 33)
00:19:23:WU02:FS00:0xa7:Unit: 0x0000002a80fccb095c979b0116ed9c52
00:19:23:WU02:FS00:0xa7:Reading tar file core.xml
00:19:23:WU02:FS00:0xa7:Reading tar file frame33.tpr
00:19:23:WU02:FS00:0xa7:Digital signatures verified
00:19:23:WU02:FS00:0xa7:Calling: mdrun -s frame33.tpr -o frame33.trr -x frame33.xtc -cpt 15 -nt 6
00:19:23:WU02:FS00:0xa7:Steps: first=4125000 total=125000
00:19:27:WU02:FS00:0xa7:Completed 1 out of 125000 steps (0%)
00:19:28:WU00:FS00:Upload 14.44%
00:19:34:WU00:FS00:Upload 31.68%
00:19:34:FS00:Paused
00:19:34:FS01:Paused
00:19:34:FS00:Shutting core down
00:19:34:FS01:Shutting core down
00:19:34:WU01:FS01:0x21:WARNING:Console control signal 1 on PID 14456
00:19:34:WU02:FS00:0xa7:WARNING:Console control signal 1 on PID 16608
00:19:34:WU01:FS01:0x21:Exiting, please wait. . .
00:19:34:WU02:FS00:0xa7:Exiting, please wait. . .
00:19:34:WU01:FS01:0x21:Folding@home Core Shutdown: INTERRUPTED
00:19:35:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
00:19:39:WU02:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
00:19:39:WU02:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
00:19:40:WU00:FS00:Upload 49.16%
00:19:46:WU00:FS00:Upload 66.65%
00:19:52:WU00:FS00:Upload 83.88%
00:19:58:WU00:FS00:Upload complete
00:19:58:WU00:FS00:Server responded WORK_ACK (400)
00:19:58:WU00:FS00:Final credit estimate, 1994.00 points
00:19:58:WU00:FS00:Cleaning up
00:20:15:Saving configuration to config.xml
00:20:15:<config>
00:20:15:  <!-- Slot Control -->
00:20:15:  <power v='MEDIUM'/>
00:20:15:
00:20:15:  <!-- User Information -->
00:20:15:  <team v='225605'/>
00:20:15:  <user v='Hypernova'/>
00:20:15:
00:20:15:  <!-- Folding Slots -->
00:20:15:  <slot id='0' type='CPU'>
00:20:15:    <paused v='true'/>
00:20:15:  </slot>
00:20:15:  <slot id='1' type='GPU'>
00:20:15:  </slot>
00:20:15:</config>
******************************* Date: 2019-06-17 *******************************
00:00:22:137:127.0.0.1:New Web connection
00:00:33:FS00:Unpaused
00:00:33:FS01:Unpaused
00:00:34:WU01:FS01:Starting
00:00:34:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\bmurr\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 705 -lifeline 7096 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
00:00:34:WU01:FS01:Started FahCore on PID 24040
00:00:34:WU01:FS01:Core PID:15568
00:00:34:WU01:FS01:FahCore 0x21 started
00:00:34:WU02:FS00:Starting
00:00:34:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\bmurr\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 7096 -checkpoint 15 -np 6
00:00:34:WU02:FS00:Started FahCore on PID 29668
00:00:34:WU02:FS00:Core PID:27724
00:00:34:WU02:FS00:FahCore 0xa7 started
00:00:34:WU01:FS01:0x21:*********************** Log Started 2019-06-17T00:00:34Z ***********************
00:00:34:WU01:FS01:0x21:Project: 14166 (Run 5, Clone 84, Gen 114)
00:00:34:WU01:FS01:0x21:Unit: 0x000000970002894c5c38c017bb3a8f15
00:00:34:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
00:00:34:WU01:FS01:0x21:Machine: 1
00:00:34:WU01:FS01:0x21:Digital signatures verified
00:00:34:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
00:00:34:WU01:FS01:0x21:Version 0.0.18
00:00:34:WU01:FS01:0x21:  Found a checkpoint file
00:00:34:WU02:FS00:0xa7:*********************** Log Started 2019-06-17T00:00:34Z ***********************
00:00:34:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
00:00:34:WU02:FS00:0xa7:       Type: 0xa7
00:00:34:WU02:FS00:0xa7:       Core: Gromacs
00:00:34:WU02:FS00:0xa7:    Website: https://foldingathome.org/
00:00:34:WU02:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
00:00:34:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:00:34:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 29668 -checkpoint 15 -np
00:00:34:WU02:FS00:0xa7:             6
00:00:34:WU02:FS00:0xa7:     Config: <none>
00:00:34:WU02:FS00:0xa7:************************************ Build *************************************
00:00:34:WU02:FS00:0xa7:    Version: 0.0.17
00:00:34:WU02:FS00:0xa7:       Date: Apr 27 2018
00:00:34:WU02:FS00:0xa7:       Time: 16:19:36
00:00:34:WU02:FS00:0xa7: Repository: Git
00:00:34:WU02:FS00:0xa7:   Revision: 21359963583d09ec2063ef946399441c4df4ccd7
00:00:34:WU02:FS00:0xa7:     Branch: master
00:00:34:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
00:00:34:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
00:00:34:WU02:FS00:0xa7:   Platform: win32 10
00:00:34:WU02:FS00:0xa7:       Bits: 64
00:00:34:WU02:FS00:0xa7:       Mode: Release
00:00:34:WU02:FS00:0xa7:       SIMD: avx_256
00:00:34:WU02:FS00:0xa7:************************************ System ************************************
00:00:34:WU02:FS00:0xa7:        CPU: Unknown
00:00:34:WU02:FS00:0xa7:     CPU ID:
00:00:34:WU02:FS00:0xa7:       CPUs: 8
00:00:34:WU02:FS00:0xa7:     Memory: 15.95GiB
00:00:34:WU02:FS00:0xa7:Free Memory: 9.54GiB
00:00:34:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
00:00:34:WU02:FS00:0xa7: OS Version: 6.2
00:00:34:WU02:FS00:0xa7:Has Battery: false
00:00:34:WU02:FS00:0xa7: On Battery: false
00:00:34:WU02:FS00:0xa7: UTC Offset: -7
00:00:34:WU02:FS00:0xa7:        PID: 27724
00:00:34:WU02:FS00:0xa7:        CWD: C:\Users\bmurr\AppData\Roaming\FAHClient\work
00:00:34:WU02:FS00:0xa7:         OS: Windows 10 Home
00:00:34:WU02:FS00:0xa7:    OS Arch: AMD64
00:00:34:WU02:FS00:0xa7:********************************************************************************
00:00:34:WU02:FS00:0xa7:Project: 13826 (Run 480, Clone 0, Gen 33)
00:00:34:WU02:FS00:0xa7:Unit: 0x0000002a80fccb095c979b0116ed9c52
00:00:34:WU02:FS00:0xa7:Digital signatures verified
00:00:34:WU02:FS00:0xa7:Calling: mdrun -s frame33.tpr -o frame33.trr -x frame33.xtc -cpi state.cpt -cpt 15 -nt 6
00:00:34:WU02:FS00:0xa7:Steps: first=4125000 total=125000
00:00:36:WU01:FS01:0x21:Completed 5500000 out of 12500000 steps (44%)
00:00:36:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
00:00:37:WU02:FS00:0xa7:Completed 82 out of 125000 steps (0%)
00:00:45:Saving configuration to config.xml
00:00:45:<config>
00:00:45:  <!-- Slot Control -->
00:00:45:  <power v='MEDIUM'/>
00:00:45:
00:00:45:  <!-- User Information -->
00:00:45:  <team v='225605'/>
00:00:45:  <user v='Hypernova'/>
00:00:45:
00:00:45:  <!-- Folding Slots -->
00:00:45:  <slot id='0' type='CPU'/>
00:00:45:  <slot id='1' type='GPU'/>
00:00:45:</config>
00:02:31:WU02:FS00:0xa7:Completed 1250 out of 125000 steps (1%)
00:03:40:WU01:FS01:0x21:Completed 5625000 out of 12500000 steps (45%)
00:03:49:FS00:Shutting core down
00:03:49:WU02:FS00:0xa7:WARNING:Console control signal 1 on PID 27724
00:03:49:WU02:FS00:0xa7:Exiting, please wait. . .
00:03:53:WU02:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
00:03:53:WU02:FS00:Starting
00:03:53:WARNING:WU02:FS00:Changed SMP threads from 6 to 7 this can cause some work units to fail
00:03:53:WARNING:WU02:FS00:AS lowered CPUs from 7 to 6
00:03:53:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\bmurr\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 7096 -checkpoint 15 -np 6
00:03:53:WU02:FS00:Started FahCore on PID 24208
00:03:53:WU02:FS00:Core PID:6204
00:03:53:WU02:FS00:FahCore 0xa7 started
00:03:54:WU02:FS00:0xa7:*********************** Log Started 2019-06-17T00:03:53Z ***********************
00:03:54:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
00:03:54:WU02:FS00:0xa7:       Type: 0xa7
00:03:54:WU02:FS00:0xa7:       Core: Gromacs
00:03:54:WU02:FS00:0xa7:    Website: https://foldingathome.org/
00:03:54:WU02:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
00:03:54:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:03:54:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 24208 -checkpoint 15 -np
00:03:54:WU02:FS00:0xa7:             6
00:03:54:WU02:FS00:0xa7:     Config: <none>
00:03:54:WU02:FS00:0xa7:************************************ Build *************************************
00:03:54:WU02:FS00:0xa7:    Version: 0.0.17
00:03:54:WU02:FS00:0xa7:       Date: Apr 27 2018
00:03:54:WU02:FS00:0xa7:       Time: 16:19:36
00:03:54:WU02:FS00:0xa7: Repository: Git
00:03:54:WU02:FS00:0xa7:   Revision: 21359963583d09ec2063ef946399441c4df4ccd7
00:03:54:WU02:FS00:0xa7:     Branch: master
00:03:54:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
00:03:54:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
00:03:54:WU02:FS00:0xa7:   Platform: win32 10
00:03:54:WU02:FS00:0xa7:       Bits: 64
00:03:54:WU02:FS00:0xa7:       Mode: Release
00:03:54:WU02:FS00:0xa7:       SIMD: avx_256
00:03:54:WU02:FS00:0xa7:************************************ System ************************************
00:03:54:WU02:FS00:0xa7:        CPU: Unknown
00:03:54:WU02:FS00:0xa7:     CPU ID:
00:03:54:WU02:FS00:0xa7:       CPUs: 8
00:03:54:WU02:FS00:0xa7:     Memory: 15.95GiB
00:03:54:WU02:FS00:0xa7:Free Memory: 9.60GiB
00:03:54:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
00:03:54:WU02:FS00:0xa7: OS Version: 6.2
00:03:54:WU02:FS00:0xa7:Has Battery: false
00:03:54:WU02:FS00:0xa7: On Battery: false
00:03:54:WU02:FS00:0xa7: UTC Offset: -7
00:03:54:WU02:FS00:0xa7:        PID: 6204
00:03:54:WU02:FS00:0xa7:        CWD: C:\Users\bmurr\AppData\Roaming\FAHClient\work
00:03:54:WU02:FS00:0xa7:         OS: Windows 10 Home
00:03:54:WU02:FS00:0xa7:    OS Arch: AMD64
00:03:54:WU02:FS00:0xa7:********************************************************************************
00:03:54:WU02:FS00:0xa7:Project: 13826 (Run 480, Clone 0, Gen 33)
00:03:54:WU02:FS00:0xa7:Unit: 0x0000002a80fccb095c979b0116ed9c52
00:03:54:WU02:FS00:0xa7:Digital signatures verified
00:03:54:WU02:FS00:0xa7:Calling: mdrun -s frame33.tpr -o frame33.trr -x frame33.xtc -cpi state.cpt -cpt 15 -nt 6
00:03:54:WU02:FS00:0xa7:Steps: first=4125000 total=125000
00:03:56:WU02:FS00:0xa7:Completed 2112 out of 125000 steps (1%)
00:04:33:WU02:FS00:0xa7:Completed 2500 out of 125000 steps (2%)
00:04:49:Removing old file 'configs/config-20190510-010243.xml'
00:04:49:Saving configuration to config.xml
00:04:49:<config>
00:04:49:  <!-- Slot Control -->
00:04:49:  <power v='FULL'/>
00:04:49:
00:04:49:  <!-- User Information -->
00:04:49:  <team v='225605'/>
00:04:49:  <user v='Hypernova'/>
00:04:49:
00:04:49:  <!-- Folding Slots -->
00:04:49:  <slot id='0' type='CPU'/>
00:04:49:  <slot id='1' type='GPU'/>
00:04:49:</config>
00:06:27:WU02:FS00:0xa7:Completed 3750 out of 125000 steps (3%)
00:06:46:WU01:FS01:0x21:Completed 5750000 out of 12500000 steps (46%)
00:08:23:WU02:FS00:0xa7:Completed 5000 out of 125000 steps (4%)
00:09:52:WU01:FS01:0x21:Completed 5875000 out of 12500000 steps (47%)
00:10:18:WU02:FS00:0xa7:Completed 6250 out of 125000 steps (5%)
00:12:13:WU02:FS00:0xa7:Completed 7500 out of 125000 steps (6%)
00:12:58:WU01:FS01:0x21:Completed 6000000 out of 12500000 steps (48%)
00:14:07:WU02:FS00:0xa7:Completed 8750 out of 125000 steps (7%)
00:16:04:WU01:FS01:0x21:Completed 6125000 out of 12500000 steps (49%)
00:16:04:WU02:FS00:0xa7:Completed 10000 out of 125000 steps (8%)
00:17:59:WU02:FS00:0xa7:Completed 11250 out of 125000 steps (9%)
00:19:09:WU01:FS01:0x21:Completed 6250000 out of 12500000 steps (50%)
Theodore
Re: GTX 1060 undervolting despite full workload
Post by Theodore »
Seems like your GPU does the work just fine.
I would adjust the power curve, but not the voltage.
The gtx16xx cards should run very cool, especially when on limited power and higher fan curve.
If the GPU freezes, or slows down, due to undervolting, it may just be waiting for a data stream from the GPU.
One it won't get, if the voltage isn't high enough for the GPU to pass on signals.
Even with overclocking, fah is more susceptible to errors than games, as processing a WU, taxes certain parts of the GPU continuously, rather than with bursts, like in a game.
This means chances for errors are higher.
NVidia optimized their drivers so much, that it's best to just do overclocking and lower limiting. Any manual adjustment of the voltage will most likely result in an unstable system, or one that uses more power than need be.
The automatic settings are as good as you can get.
Theodore wrote:Even with overclocking, fah is more susceptible to errors than games, as processing a WU, taxes certain parts of the GPU continuously, rather than with bursts, like in a game.
Two things.
Yes, continuous use tends generate more heat that intermittent use but If those parts of the GPU can't stand continuous use, I'd call the cooling methodology poorly designed or simply under-designed. Adjusting the fan profile may help, but then owners complain about the noise.
Laptops are classic examples of the same issue on a much larger scale. A well designed laptop CAN be designed for continuous use even though they only get tested under extreme conditions in the manufacturer's qualification lab ... plus their design emphasizes power saving techniques whenever possible simply to extend battery life.
Secondly, a game is more tolerant of errors. A minor shift in the color or position of a few pixels in a single frame won't be noticed by your eye, but the same error in a scientific calculation will hopefully be detected ... and probably will cause the calculation to be aborted or otherwise require it to be reprocessed in order for it to be accepted into the ultimate trajectory.
rwh202
3x GTX 1080 Ti
3x GTX 1060
Various other bits and pieces
Post by rwh202 »
I've also seen some funky behaviour with a GTX 1060 on windows recently.
GPU-Z and HWmonitor both showed it as being power limited and downclocking whilst folding, despite barely drawing 70W. PPD dropped to 220k from 350k. I suspect a windows / driver update applying power saving when not needed.
Tried fresh drivers and trying to force power and clocks but gave up and put in a 1660 instead. That then refused to go above base clocks. Reinstalling drivers (again) but with geforce experience included seemed to fix that. Tempted to try the 1060 again and see if that would have done the trick there too.
Hypernova0
Well, I did a fresh driver install and now it's taking full voltage but still only using 85-90% power when it could be using up to 116% w/ the overclock. This situation is better I guess so I'm just gonna hope the next windows update solves it or something.
MeeLee
Post by MeeLee »
Not every WU will make 100% use of the GPU.
Most of the time, my GPUs run at 10-30W below the stock values.
I do reduce the wattage. Sometimes resulting in power consumption near to set power values, sometimes still a few to a few tens of watts under that.
Also, there may be hardware reasons why your GPU isn't using it's full power.
If you tap PCIE 6 pin connectors off of a SATA port, for instance, in most cases the power flow is restricted to 75W.
Thw GPU utilization also depends on which project you've been assigned. If you're working on a protein with a relatively small number of atoms AND have GPU with a large number of shaders, you won't get a high utilization of those shaders. The same protein will use close to 100% of a smaller GPU. On the other hand, if you're assigned a protein with a large atom count, the utilization will go up to a higher percentage.
There is nothing that can be done about this characteristic difference between various GPUs across the spectrum of protein assignments.
foldinghomealone2
Post by foldinghomealone2 »
Bruce, wouldn't it be reasonable to block big GPUs for such small projects?
Under-utilization of GPUs is a waste of performance on other (bigger) projects
foldinghomealone2 wrote:Bruce, wouldn't it be reasonable to block big GPUs for such small projects?
They are already doing that. There are a few projects that do not scale well and do not get assigned for instance to a GTX 1080 Ti. But it is a fairly coarse sort, and if no large WU's are available a small one may be assigned instead of not assigning one at all.
foldinghomealone2
Thanks for your answer
